    T113-S3 CAN模块使用的全部信息
    t113 can
    8
    9
    12306
      L13819506056 LV 5 最后由 whycan 编辑
      经过实际测试,T133-S3的CAN模块完全可用。测试相关信息如下:
      #define  CAN0  0x02504000
      #define  CAN1  0x02504400
      #define CAN_OFFSET(can_base,offset)          (*((volatile uint32_t *)(can_base + (offset))))
      #define CAN_MSEL(can_base)       CAN_OFFSET(can_base,0x0000) //CAN mode select register
      #define CAN_CMD(can_base)        CAN_OFFSET(can_base,0x0004)  //CAN command register
      #define CAN_STA(can_base)        CAN_OFFSET(can_base,0x0008)  //CAN status register
      #define CAN_INT(can_base)        CAN_OFFSET(can_base,0x000C)  //CAN interrupt register
      #define CAN_INTEN(can_base)      CAN_OFFSET(can_base,0x0010) //CAN interrupt enable register
      #define CAN_BUSTIME(can_base)    CAN_OFFSET(can_base,0x0014) //CAN bus timing register
      #define CAN_TEWL(can_base)       CAN_OFFSET(can_base,0x0018)  //CAN TX error warning limit register
      #define CAN_ERRC(can_base)       CAN_OFFSET(can_base,0x001c)  //CAN error counter register
      #define CAN_RMCNT(can_base)      CAN_OFFSET(can_base,0x0020)  //CAN receive message counter register
      #define CAN_RBUF_SADDR(can_base) CAN_OFFSET(can_base,0x0024) //CAN receive buffer start address register
      #define CAN_TRBUF0(can_base)     CAN_OFFSET(can_base,0x0040) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF1(can_base)     CAN_OFFSET(can_base,0x0044) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF2(can_base)     CAN_OFFSET(can_base,0x0048) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF3(can_base)     CAN_OFFSET(can_base,0x004c) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF4(can_base)     CAN_OFFSET(can_base,0x0050) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF5(can_base)     CAN_OFFSET(can_base,0x0054) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF6(can_base)     CAN_OFFSET(can_base,0x0058) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF7(can_base)     CAN_OFFSET(can_base,0x005c) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF8(can_base)     CAN_OFFSET(can_base,0x0060) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF9(can_base)     CAN_OFFSET(can_base,0x0064) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF10(can_base)    CAN_OFFSET(can_base,0x0068) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF11(can_base)    CAN_OFFSET(can_base,0x006c) //CAN TX/RX message buffer 0 register
      #define CAN_TRBUF12(can_base)    CAN_OFFSET(can_base,0x0070) //CAN TX/RX message buffer 0 register
      #define CAN_ACPC(can_base)       CAN_OFFSET(can_base,0x0028) //CAN acceptance code 0 register(reset mode)
      #define CAN_ACPM(can_base)       CAN_OFFSET(can_base,0x002C) //CAN acceptance mask 0 register(reset mode)
      #define CAN_RBUF_RBACK(can_base) CAN_OFFSET(can_base,0x0180) //~0x1b0 //CAN transmit buffer for read back register
      #define CAN_VERSION(can_base)    CAN_OFFSET(can_base,0x0300) //CAN Version Register
      typedef  struct _t113_can_control_t_
        volatile uint32_t  * can_clk_gate;
        uint32_t  can_base;
        uint32_t  int_id;
      }t113_can_control_t;
      t113_can_control_t t113_can[2] =
          (volatile uint32_t  *)0x0200192C,
          0x02504000,
          53
          0x02504400,
          54
      uint32_t rxd_buf[13];
      void t113_can_irq_handle(void*  p)
         uint32_t    can_base = (uint32_t) p;
         uint32_t    int_sta =   CAN_INT(can_base);
         if(int_sta &  1)
             /* 接收中断 */
             can_read_data(can_base,rxd_buf);
             /*  后续处理  */
         if(int_sta & 2 )
            /*发送中断*/
         if(int_sta & 0xFC )
            /* 错 误 中断  */
         CAN_INT(can_base) = int_sta;
      void ini_can(int can_id)
          if(can_id > 1) return;
          GPIOB->CFG0  &= ~(0xff00 <<  (can_id * 8));
          GPIOB->CFG0  |=  (0x8800 <<  (can_id * 8));
          GPIOB->DRV0  |=  (0x3300 <<  (can_id * 8));
          t113_can_control_t * can_info = &t113_can[can_id];
          uint32_t   can_base = can_info->can_base;
          int can_int_id = can_info->int_id;
          *can_info->can_clk_gate  |= (1 << (16 + can_id)) | (1 << can_id);/* CCU_CAN_BGR */
          CAN_MSEL(can_base) |= 1; /* Reset mode selected*/
         /* 500KHz CAN速率 */
          CAN_BUSTIME(can_base) = (9          /* apb_clk = 100Mz , 100/10 = 10MHz*/
                                 | (1 << 14)   /* Synchronization Jump Width :2 Tq clock cycles */
                                 | (13 << 16)  /*Phase Segment 1 : 14 Tq clock cycles  */
                                 | ( 3 << 20)  /*Phase Segment 2 :  4 Tq clock cycles  */
                                 | ( 0 << 23));  /*  Bus line is sampled three times at the sample point */
         CAN_ACPC(can_base)  = 0xffffffff; /*实际使用时根据需要设置滤波*/
         CAN_ACPM(can_base)  = 0xffffffff; /*实际使用时根据需要设置滤波*/
         CAN_MSEL(can_base) &= (~1);
         // CAN_MSEL(can_base) |= (1 << 2); /* Loopback Mode */
         CAN_MSEL(can_base) |= (1 << 3);/* Single Filter  */
         bsp_int_vect_set(can_int_id,  /* Assign ISR handler. */
                         1u,            /* 中断的优先级         */
                         1u,            /* 中断的目标CPU        */
                         (void *)can_base,        /* 参数      */
                         t113_can_irq_handle);
          irq_enable(can_int_id);//
          /* 使能中断  */
          CAN_INTEN(can_base) = 0x0FF;
      void can_send_data(uint32_t    can_base,uint8_t * buf,int  len)
          CAN_CMD(can_base) |= (1 << 2);
          int retry = 1000;
          do{
             if(--retry == 0) break;
          }while(!(CAN_STA(can_base) & (1 << 2)));
          if(retry == 0) return;//
          uint32_t * des =  &CAN_TRBUF0(can_base);
          for(int i = 0; i < len; i++)
           des[i] = buf[i];
          //CAN_CMD(can_base) = (1 << 4);
           CAN_CMD(can_base) |= (1 << 0);
      void can_read_data(uint32_t    can_base,uint8_t * buf)
          uint32_t * src =  &CAN_TRBUF0(can_base);
          for(int i = 0; i < 13; i++)
             buf[i] = (char)src[i];
      uint8_t can_teat_data[13] =
            8,
            0,
            0x80,
            0x55, /*   SFF - TX data byte 1 / EFF- ID[12:5]  */
            0x55, /*  SFF-TX data byte2[7:3] / EFF-ID[4:0]
                      SFF-TX data byte2[2:0] */
            0x55, /* SFF-TX data byte 3 / EFF-TX data byte 1 */
            0x55, /* SDATA4_EDATA2  SFF-TX data byte 4 / EFF-TX data byte 2  */
            0x55, /* SDATA5_EDATA3 SFF-TX data byte 5 / EFF-TX data byte 3   */
            0x55,/* SDATA5_EDATA4  SFF-TX data byte 6 / EFF-TX data byte 4   */
            0x55,/* SDATA5_EDATA5  SFF-TX data byte 7 / EFF-TX data byte 5   */
            0x55,/* SDATA5_EDATA6  SFF-TX data byte 8 / EFF-TX data byte 6   */
            0x55, /* SDATA5_EDATA7   */
            0x55 /*  SDATA5_EDATA8   */
      /* can_id: is 0 or 1 */
      void t113_can_test(void)
          ini_can(0);
          ini_can(1);
         while(1)
          can_send_data(CAN0,can_data);
           ms_delay(500);
          can_send_data(CAN1,can_data);
           ms_delay(500);
      K W A 3 条回复 最后回复 回复 引用 分享 3
      • tigger
        tigger LV 7 最后由 编辑
        楼主牛,是不是对照a20手册搞定的?
          L13819506056 LV 5 最后由 编辑
          没有,做的测试代码测试出来的。
            yelong98 LV 7 最后由 编辑
            楼主威武,这都搞定了
            • aozima
              aozima LV 7 最后由 编辑
              这就NB大发了,能探测下D1S上面有没有不?
              • K
                kakatoo LV 4 @L13819506056 最后由 编辑
                @l13819506056
                有更具体的说明嘛? 还有性能这块如何?
                  SpeedyGonzales LV 2 最后由 编辑
                  Hello, i need to run Canbus for T113-S3. i used your codes. but the TX_RDY bit is never ready(1) after the first can_send_data function is called. and although the first canbus message appears to be gone, there is no outgoing message from the oscilloscope. How can I solve this problem?
                    weichengjie LV 4 @L13819506056 最后由 编辑
                    @l13819506056 需要配置kernel_menuconfig 哪些内容,以及需要修改哪些代码,方便把方法写出来吗?谢谢。
                      a892755772 LV 5 @L13819506056 最后由 编辑
                      @l13819506056 你好 我在《T113-S3_Datasheet_V1.5.pdf》与 《T113-S3_User_Manual_V1.2.pdf》找不到相关的CAN 寄存器说明,请问你是哪里查到的啊?
