    全志芯片Tina Linux 修改 UART 引脚、UART端口
    12
    16
    28961
      YterAA LV 7 最后由 xiaowenge 编辑
      场景一:同样使用UART0,需要从PF2、PF4改到PE2、PE4
      1. 修改sys_config.fex(BOOT0与Uboot的串口)
      sys_config.fex 的路径是 device/config/chips/t113/configs/evb1/sys_config.fex 中的 uart_debug_port
      修改前:
      [uart_para]
      uart_debug_port = 0
      uart_debug_tx   = port:PF02<3><1><default><default>
      uart_debug_rx   = port:PF04<3><1><default><default>
      修改后
      [uart_para]
      uart_debug_port = 0
      uart_debug_tx   = port:PE02<6><1><default><default>
      uart_debug_rx   = port:PE03<6><1><default><default>
      其中<3>改为<6> 是查阅数据手册中 PE2、PE3 的UART0是 Function6 得知的
      port:PE02    <6><1><default><default>
             PE2脚  引脚功能6(查阅datasheet得知)
      1. 修改设备树(Linux使用的串口输出)
      路径:device/config/chips/t113/configs/evb1/board.dts
      修改前
      	pins = "PF2", "PF4";
      	function = "uart0";
      	drive-strength = <10>;
      	allwinner,muxsel = <3>;
      	bias-pull-up;
      	function = "gpio_in";
      修改后
      	pins = "PE2", "PE3";
      	function = "uart0";
      	allwinner,muxsel = <6>;
      	bias-pull-up;
      D 1 条回复 最后回复 回复 引用 分享 14
        YterAA LV 7 最后由 YuzukiTsuru 编辑
        场景二:使用UART3,需要从UART0改为UART3(PB6,PB7)
        修改前:
        [uart_para]
        uart_debug_port = 0
        修改后
        [uart_para]
        uart_debug_port = 3
        uart_debug_tx   = port:PB06<7><1><default><default>
        uart_debug_rx   = port:PB07<7><1><default><default>
        修改前
        uart3_pins_a: uart3_pins@0 {
        	pins = "PC6", "PC7";
        	function = "uart0";
        	allwinner,muxsel = <4>;
        	bias-pull-up;
        uart3_pins_b: uart3_pins@1 {
        &uart0 {
        	pinctrl-0 = <&uart0_pins_a>;
        	pinctrl-1 = <&uart0_pins_b>;
        &uart3 {
        	pinctrl-0 = <&uart3_pins_a>;
        	pinctrl-1 = <&uart3_pins_b>;
        	status = "disabled";
        修改后
        	pins = "PB6", "PB7";
        	function = "uart0";
        	allwinner,muxsel = <7>;
        	bias-pull-up;
        &uart0 {
        	status = "disabled";                               # 关闭UART0
        &uart3 {
        	status = "okay";                                   # 开启UART3
        1. 修改UBOOT CONSOLE INDEX
        路径:brandy/brandy-2.0/u-boot-2018/configs/sun8iw20p1_defconfig
        增加下列内容
        CONFIG_SPECIFY_CONSOLE_INDEX=y
        CONFIG_CONS_INDEX=4                            # UART 3+1 = 4
        1. 修改启动bootargs
        路径:device/config/chips/t113/configs/evb1/env.cfg
        修改前
        earlyprintk=sunxi-uart,0x02500000
        initcall_debug=0
        console=ttyS0,115200
        修改后
        earlyprintk=sunxi-uart,0x02500000 需要修改为 UART3 的地址,查阅手册可知为 0x02500C00
        earlyprintk=sunxi-uart,0x02500C00
        initcall_debug=0
        console=ttyS3,115200
        注意 ARM 平台还需要设置Kernel,如下:
        make kernel_menuconfig 找到 Kernel low-level debugging functions,修改寄存器地址
        RISC-V 不需要此操作
        1 条回复 最后回复 回复 引用 分享 12
        • jinxiangwzh
          jinxiangwzh LV 7 最后由 编辑
          学习了,感谢您的高质量输出
          radxiaohe 1 条回复 最后回复 回复 引用 分享 1
          • Referenced by  J jr_online
          • Referenced by  B buyadong
          • how0723
            how0723 LV 5 最后由 编辑
            非常不错,解决了我的问题
            • Referenced by  H Honey130602
              YterAA LV 7 最后由 编辑
              RISC-V 不需要此操作
              (之前忘记说了,现在补上
              • K
                kelsey LV 6 最后由 编辑
                为何在场景二中,从UART0改为UART3
                uart_debug_port 并不需要修改呢????
                Y 1 条回复 最后回复 回复 引用 分享 0
                  YterAA LV 7 @kelsey 最后由 编辑
                  @kelsey 写错了已修改
                  K 1 条回复 最后回复 回复 引用 分享 0
                  • K
                    kelsey LV 6 @YterAA 最后由 编辑
                    @yteraa 哈哈哈,好的
                      dream LV 6 @YterAA 最后由 编辑
                      @yteraa 收藏一波,谢谢楼主分享
                        one001 LV 5 最后由 编辑
                        我在R11芯片上通过修改下面内容从uart0换到uart1,kernel是3.4的,但是呢,uart1打印kernel启动2秒多后就卡住了似乎,uart1没反应了,不知道是不是还有哪里没修改的,而且kernel3.4版本没找到修改调试口的地方,请问可以帮我解决下吗,这是我发的贴子,R11 DEBUG uart0 换 uart1
                          one001 LV 5 最后由 编辑
                          @YterAA 帮我看下我的这个问题哦 链接文本
                          • Referenced by  K kw___
                          • Referenced by  C cruise33
                          • Referenced by  A axw_fae
                          • G
                            gonboy LV 5 最后由 编辑
                            按照文档配置。 uart0 改为 uart3 后, kernel 的日志无法打印。无法进入控制台。
                            • radxiaohe
                              radxiaohe LV 5 @jinxiangwzh 最后由 编辑
                              @jinxiangwzh 在 全志芯片Tina Linux 修改 UART 引脚、UART端口 中说:
                              学习了,感谢您的高质量输出
                                hubbell LV 3 最后由 编辑
                                教程不错,学习了。
                                uart debug配置搞了很久。
                                • aldfaaa
                                  whycan矿工-小叶 LV 7 最后由 编辑
                                  挖一个古早期的修改UART帖😊
                                  D1s分别在Tina Linx, Melis修改调试串口实录
                                  https://bbs.aw-ol.com/topic/3194/share/1
                                  • Referenced by  W whycanservice2
                                  • Referenced by  C cwj1986521
                                  • Referenced by  KunYi KunYi
                                    sunbin3240 LV 2 最后由 编辑
                                    R528 SDK,UART0是A7核的调试串口,UART2是DSP的调试串口。现在想把UART2作为A7核的调试串口,UART0其它复用功能。请问哪位大神知道怎么修改?
