    Tina Linux 存储介质切换:eMMC,SPI NAND,SPI NOR,SD Card,SD NAND
    29
    40
    59945
      YterAA LV 7 最后由 YuzukiTsuru 编辑
      存储切换方法
      SDK切换存储介质需要修改board.dts、sys_config.fex、内核配置、TINA系统配置。另外,在spinor 存储介质下,通过 u-boot-sun8iw21p1.bin 进行烧录,u-boot-spinor-sun8iw21p1.bin 启动,使用sys_partition_nor.fex作为分区表。在非spinor介质(spinand、emmc、sdnand),通过u-boot-sun8iw21p1.bin进行烧录和启动,使用sys_partition.fex作为分区表。下文将介绍spinor切换spinand、spinand切换spinor、spinor切换emmc、spinor切换sdnand四种切换方式。
      • sys_config.fex中只要关注storage_type选项,这个选项决定使用哪一种存储介质,配置后在pack过程,会自动打包对应介质的二进制文件。
        [target]
        storage_type = xxx
        其中storage_type | 0:nand | 1:sd | 2:emmc | 3:spinor  | 4:emmc3 | 5:spinand  | 6:sd1 |
      spinor切换spinand
      sys_config.fex修改
      [target]
      - storage_type = 3
      + storage_type = 5
      board.dts/uboot-board.dts修改
      &spi0 {
      -	status = "disabled";
      +	status = "okay";
      	spi-nand@0 {
      -		status="disabled";
      +		status="okay";
      uboot编译
      编译u-boot-sun8iw21p1.bin,spinand使用u-boot-sun8iw21p1.bin进行烧录、启动。
      cboot切换到uboot目录,编辑configs/sun8iw21p1_defconfig
      CONFIG_SUNXI_UBIFS=y   //SDK发布默认已选上
      执行mboot               //编译
      确保device/config/chips/vxxx/bin/u-boot-sun8iw21p1.bin已更新
      内核配置
      make kernel_menuconfig 层层选中
      内核驱动配置
      Device Driver --->
         Memory Technology Device (MTD) support --->
            sunxi-nand  --->
                <*> AWNAND CHOICE (Allwinner MTD SPINAND Device Support)  --->
            -*-   Enable UBI - Unsorted block images  --->
               [*]   Read-only block devices on top of UBI volumes
      内核文件系统配置
      File systems --->
         [*] Miscellaneous filesystems  --->
            <*>   UBIFS file system support
      TINA环境配置
      make menuconfig 层层选中
      Target Images  --->
         Boot (SD Card) Kernel format (boot.img)  ---> //默认选中
         [ ] For storage less than 32M, enable this when using ota  //取消勾选
      Global build settings  --->
         [*] Strip unnecessary functions from libraries  //取消勾选
      Utilities  --->
         <*> mtd-utils --->
            <*>   mtd-utils-mkfs.ubifs
      spinand切换spinor
      sys_config.fex修改
      [target]
      - storage_type = 5
      + storage_type = 3
      &spi0 {
      -	status = "okay";
      +	status = "disabled";
      	spi-nand@0 {
      -		status="okay";
      +		status="disabled";
      内核配置
      内核驱动配置
      Device Driver --->
            sunxi-nand  --->  //取消勾选
         Self-contained MTD device drivers  --->
            <*> Support most SPI Flash chips (AT26DF, M25P, W25X, ...)  //确认已选中
         <*>   SPI-NOR device support  --->
      内核文件系统配置
      File systems --->
            <*>   Journalling Flash File System v2 (JFFS2) support
      TINA环境配置
      Target Images  --->
         [*] For storage less than 32M, enable this when using ota  //选中
         [*] Strip unnecessary functions from libraries  //选中
      Utilities  --->
         <*> mtd-utils
            <*>   mtd-utils-mkfs.jffs2  //选中
      spinor切换emmc
      sys_config.fex修改
      [target]
      - storage_type = 3
      + storage_type = 2
      内核配置
      [*] Enable the block layer  --->
         [*]   Support for large (2TB+) block devices and files
         [*]   Block layer SG support v4
      Device Drivers  --->
         < > Memory Technology Device (MTD) support  --->  //取消勾选
         [*] Block devices  --->  //确认勾选
      File systems  --->
         <*> The Extended 4 (ext4) filesystem
      TINA环境配置
      Target Images  --->
         [ ] Strip unnecessary functions from libraries  //取消勾选
      Utilities  --->
         Filesystem  --->
            <*> e2fsprogs //选中
      spinor切换sdnand
      sys_config.fex修改
      [target]
      - storage_type = 3
      + storage_type = 1
      board.dts修改
      &sdc2 {
      	non-removable;
      	bus-width = <8>;
      	mmc-ddr-1_8v;
      	mmc-hs200-1_8v;
      	mmc-hs400-1_8v;
      	no-sdio;
      -	no-sd;
      +	//no-sd;
      	ctl-spec-caps = <0x308>;
      	cap-mmc-highspeed;
      	sunxi-power-save-mode;
      	sunxi-dis-signal-vol-sw;
      	max-frequency = <100000000>;
      	vmmc-supply = <&reg_dcdc1>;
      	/*emmc io vol 3.3v*/
      	vqmmc-supply = <&reg_bldo1>;
      	/*emmc io vol 1.8v*/
      内核配置
      Device Drivers  --->
      File systems  --->
      TINA环境配置
      Target Images  --->
      Utilities  --->
         Filesystem  --->
            <*> e2fsprogs //选中
      1 条回复 最后回复 回复 引用 分享 35
      • tigger
        tigger LV 7 最后由 编辑
        没有SDK,只能偷偷看你玩了。
        YuzukiTsuru 1 条回复 最后回复 回复 引用 分享 8
        • Moved from V Series by  YuzukiTsuru YuzukiTsuru
          柚木 鉉 LV 9 @tigger 最后由 编辑
          @tigger 全系适用的
          1 条回复 最后回复 回复 引用 分享 9
          • Referenced by  Y YterAA
            Tina 3.5 一般支持nor, nand, mmc 三种介质。
            更具体的,nand分为并口nand和spinand,mmc分emmc和sd卡
            主要需要区分的是nor和其他介质,因为需要打包的部分有所不同。
            即,emmc和nand,sd卡一般可共用一份固件,而nor则需使用另一份固件
            sys_config配置
            在sys_config中有一个配置项,storage_type,取值及含义如下
            ; storage_type 0:nand 1:sd 2:emmc 3:spinor 4:emmc3 5:spinand 6:sd1
            [target]
            storage_type = xxx
            对于nor的方案,必须配置为
             storage_type = 3
            对于其他介质,storage_type则不能配置为3
            spinand切换为spinor
            sys_config 设置介质为nor
            [target]
            storage_type = 3
            配置所用nor的大小
            [norflash]
            size		= 16
            内核配置
             make kernel_menuconfig --->
            	Device Drivers --->
                            < >Block devices  (取消选中)
            	Device Drivers --->
            		<*>Memory Technology Device (MTD) support
                                    <*>OpenFirmware partitioning information support
            			<*>SUNXI partitioning support
                   <*>   Caching block device access to MTD devices
            			<*>   SPI-NOR device support  (对于linux4.9,先选这个,下面的选项才出现)
              File systems  --->
                < > The Extended 4 (ext4) filesystem(取消选中)
              File systems  --->
                 <*>   Journalling Flash File System v2 (JFFS2) support(选中)
                [ ]   Support for large (2TB+) block devices and files(取消选中)
            menuconfig配置
            make menuconfig --->
                   Utilities  --->
                            <*> mtd-utils (选择) --->
                   Utilities  --->
                            Filesystem  --->
                                    < > e2fsprogs(取消选择)
            spinor切换为spinand
            sys_config 设置介质为spinand
            [target]
            storage_type = 5
            内核配置
                  Device Drivers --->
                             [*]Block devices --->
                                     <*>   sunxi nand flash driver
                  Device Drivers --->
            		< >Memory Technology Device (MTD) support(取消选择)
                  File systems  --->
            menuconfig 配置
                   Utilities  --->
                            < > mtd-utils (取消选择)
                            Filesystem  --->
                                    <*> e2fsprogs
            分区表配置
            注意点
            对于nand,rootfs_data分区,使用ext4格式。分配太小的话可能会创建失败。
            FAQ
            使用mkfs.ext4等工具的时候出现
            /usr/sbin/fsck.ext4 -y /dev/by-name/rootfs_data
            Error loading shared library /home/wuguanling/workspace/project/v316-sdv-tina/out/v316-sdv/staging_dir/target/rootfs/lib/libc.so: No such file or directory (needed by /usr/lib/libext2fs.so.2)
            关闭以下选项:
            make menuconfig
               | --- Global build settings
            		| --- []strip unnecessary functions for libraries
            T 1 条回复 最后回复 回复 引用 分享 13
              jetchenxg2021 LV 2 最后由 编辑
              还有env.cfg中的bootcmd也要改成从nand启动的命令
              env set bootcmd run setargs_nand boot_normal
              • tigger
                tigger LV 7 最后由 编辑
                好详细喔,收藏起来慢慢消化。
                • Referenced by  C captain
                  dream LV 6 最后由 编辑
                  扫盲贴,666。。。
                  • Referenced by  K konosiba
                  • Q
                    qqqlb LV 7 最后由 编辑
                    想问一下,你第一次发的和第二次发的有什么区别呢?我看了一下,配置好像不一样?
                    YuzukiTsuru 1 条回复 最后回复 回复 引用 分享 2
                      柚木 鉉 LV 9 @qinlinbin 最后由 编辑
                      @qinlinbin 下面那个是Tina 3.5的配置
                      Q 1 条回复 最后回复 回复 引用 分享 2
                      • Q
                        qqqlb LV 7 @YuzukiTsuru 最后由 编辑
                        @yuzukitsuru 看漏了,谢谢大佬
                        • Referenced by  Q qq354813374
                        • Referenced by  J JIAndanai
                          Justyu666 LV 5 最后由 编辑
                          亲们,请教下,从 SDC 转 nand 的 UBOOT-BOARD.DTS修改是这样没?谢谢!
                          • T
                            tanlining LV 3 @YterAA 最后由 tanlining 编辑
                            @yteraa 老师您好,各位大神们好,请教下按你的教程从nor切换到nand后启动找不到文件系统,是哪方面问题?谢谢。1676633152331.jpg-------------- 1676633142829.jpg
                            • Referenced by  WhycanService WhycanService
                            • Referenced by  N NULL037
                            • Referenced by  C chrisvista
                            • T
                              tigalight LV 2 最后由 编辑
                              非常详细,在到达lv2前先来做个提前了解,有个总体概念
                                daMing123 LV 6 最后由 xiaowenge 编辑
                                大神,帮我看看,这是什么问题,用的是V851S芯片 ,SDK是论坛下载的tina-v851-release,谢谢!
                                [01.540]boot_gui_init:start
                                [01.569]Get Reserve0 partition number fail!
                                [01.576]boot_gui_init:finish
                                [01.632]Get bootloader and boot-resource partition number fail!
                                [01.639]Item0 (Map) magic is bad
                                [01.641]out of usb burn from boot: not need burn key
                                [01.669]update bootcmd
                                [01.694]change working_fdt 0x41e8fe70 to 0x41e6fe70
                                [01.706]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
                                [01.715]update dts
                                input addr exceed dram scope
                                [03.151]no vendor_boot partition is found
                                Android's image name: v851s-youmu
                                [03.213]Starting kernel ...
                                [    0.000000] Linux version 4.9.191 (lin@lin-VirtualBox) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #94 PREEMPT Wed Dec 27 00:37:33 UTC 2023
                                [    0.000000] OF: fdt:Machine model: sun8iw21
                                [    0.000000] disp reserve base 0x41f12000 ,size 0x384000
                                [    0.000000] Memory policy: Data cache writeback
                                [    0.000000] free_area_init_node: node 0, pgdat c0a4f4c8, node_mem_map c3f78000
                                [    0.000000]   Normal zone: 128 pages used for memmap
                                [    0.000000]   Normal zone: 16384 pages, LIFO batch:3
                                [    0.000000] CPU: All CPU(s) started in SVC mode.
                                [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
                                [    0.000000] Kernel command line: ubi.mtd=sys earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_4 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-res@ubi0_1:env@ubi0_2:boot@ubi0_3:rootfs@ubi0_4:rootfs_data@ubi0_5:UDISK@ubi0_6: cma= snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw21p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05(12/26/2023-21:05:24) mbr_offset=1032192 disp_reserve=3686400,0x41f12000 bootreason=button aw-ubi-spinand.ubootblks=24 androidboot.dramsize=64
                                [    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
                                [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
                                [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
                                [    0.000000] Memory: 51108K/65536K available (6144K kernel code, 320K rwdata, 1324K rodata, 1024K init, 169K bss, 14428K reserved, 0K cma-reserved, 0K highmem)
                                [    0.000000]     vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
                                [    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
                                [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                                [    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
                                [    0.000000]       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
                                [    0.000000]       .data : 0xc0a00000 - 0xc0a50368   ( 321 kB)
                                [    0.000000]        .bss : 0xc0a50368 - 0xc0a7a9c8   ( 170 kB)
                                [    0.000000] sunxi_parse_sdm_info failed: -1
                                [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
                                [    0.000022] Switching to timer-based delay loop, resolution 41ns
                                [    0.000202] Console: colour dummy device 80x30
                                [    0.000233] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                                [    0.000248] pid_max: default: 32768 minimum: 301
                                [    0.000447] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
                                [    0.000460] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
                                [    0.001047] CPU: Testing write buffer coherency: ok
                                [    0.001675] Setting up static identity map for 0x40100000 - 0x40100058
                                [    0.003421] devtmpfs: initialized
                                [    0.036861] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                                [    0.037441] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                                [    0.037468] futex hash table entries: 256 (order: -1, 3072 bytes)
                                [    0.037613] atomic64_test: passed
                                [    0.037627] pinctrl core: initialized pinctrl subsystem
                                [    0.038758] NET: Registered protocol family 16
                                [    0.039647] DMA: preallocated 256 KiB pool for atomic coherent allocations
                                [    0.041022] dump_class_init,857, success
                                [    0.069514] cpuidle: using governor menu
                                [    0.070890] platform 2010000.iommu: iova_base: 0x48400000
                                [    0.071465] sunxi iommu: irq = 22
                                [    0.092475] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver
                                [    0.095590] iommu: Adding device npu to group 0
                                [    0.097722] iommu: Adding device 1c0e000.ve to group 0
                                [    0.109501] iommu: Adding device 5410000.g2d to group 0
                                [    0.110712] iommu: Adding device 5000000.disp to group 0
                                [    0.121704] iommu: Adding device 5908000.tdm to group 0
                                [    0.122424] iommu: Adding device 5900000.isp to group 0
                                [    0.123158] iommu: Adding device 58ffffc.isp to group 0
                                [    0.124178] iommu: Adding device 58ffff8.isp to group 0
                                [    0.125163] iommu: Adding device 58ffff4.isp to group 0
                                [    0.125640] iommu: Adding device 5800800.vind:isp@4 to group 0
                                [    0.126542] iommu: Adding device 5910000.scaler to group 0
                                [    0.127035] iommu: Adding device 590fffc.scaler to group 0
                                [    0.127643] iommu: Adding device 590fff8.scaler to group 0
                                [    0.128268] iommu: Adding device 590fff4.scaler to group 0
                                [    0.129006] iommu: Adding device 5910400.scaler to group 0
                                [    0.130237] iommu: Adding device 59103fc.scaler to group 0
                                [    0.130908] iommu: Adding device 59103f8.scaler to group 0
                                [    0.131387] iommu: Adding device 59103f4.scaler to group 0
                                [    0.132141] iommu: Adding device 5910800.scaler to group 0
                                [    0.132790] iommu: Adding device 59107fc.scaler to group 0
                                [    0.133281] iommu: Adding device 59107f8.scaler to group 0
                                [    0.134003] iommu: Adding device 59107f4.scaler to group 0
                                [    0.134750] iommu: Adding device 5910c00.scaler to group 0
                                [    0.135436] iommu: Adding device 5910bfc.scaler to group 0
                                [    0.135938] iommu: Adding device 5910bf8.scaler to group 0
                                [    0.136603] iommu: Adding device 5910bf4.scaler to group 0
                                [    0.137665] iommu: Adding device vinc0 to group 0
                                [    0.138633] iommu: Adding device vinc4 to group 0
                                [    0.140078] iommu: Adding device vinc8 to group 0
                                [    0.140870] iommu: Adding device vinc12 to group 0
                                [    0.188901] pwm module init!
                                [    0.197629] sunxi-pm debug v3.10
                                [    0.199846] SCSI subsystem initialized
                                [    0.201314] usbcore: registered new interface driver usbfs
                                [    0.201508] usbcore: registered new interface driver hub
                                [    0.201702] usbcore: registered new device driver usb
                                [    0.202049] sunxi_i2c_adap_init()2748 - init
                                [    0.202586] sunxi_i2c_probe()2443 - [i2c1] twi_drv_used = 0
                                [    0.202605] sunxi_i2c_probe()2450 - [i2c1] twi_pkt_interval = 0
                                [    0.202672] twi_regulator_request()647 - [i2c1] regulator not found(isn't configured in dts)!
                                [    0.202681] twi_request_gpio()463 - [i2c1] init name: (null)
                                [    0.204623] media: Linux media interface: v0.10
                                [    0.205196] Linux video capture interface: v2.00
                                [    0.207429] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
                                [    0.207808] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
                                [    0.209383] Advanced Linux Sound Architecture Driver Initialized.
                                [    0.210803] Bluetooth: Core ver 2.22
                                [    0.211000] NET: Registered protocol family 31
                                [    0.211011] Bluetooth: HCI device and connection manager initialized
                                [    0.211037] Bluetooth: HCI socket layer initialized
                                [    0.211051] Bluetooth: L2CAP socket layer initialized
                                [    0.211115] Bluetooth: SCO socket layer initialized
                                [    0.214589] G2D: rcq version initialized.major:251
                                [    0.215779] clocksource: Switched to clocksource arch_sys_counter
                                [    0.248413] get androidboot.mode fail
                                [    0.250192] NET: Registered protocol family 2
                                [    0.266166] TCP established hash table entries: 16 (order: -6, 64 bytes)
                                [    0.266188] TCP bind hash table entries: 16 (order: -6, 64 bytes)
                                [    0.266199] TCP: Hash tables configured (established 16 bind 16)
                                [    0.266280] UDP hash table entries: 256 (order: 0, 4096 bytes)
                                [    0.266300] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
                                [    0.266536] NET: Registered protocol family 1
                                [    0.267203] sunxi_spi_probe()2250 - [spi0] SPI DBI INTERFACE
                                [    0.267219] sunxi_spi_probe()2259 - [spi0] SPI MASTER MODE
                                [    0.267297] sunxi_spi_resource_get()1917 - sample_mode:1 sample_delay:16
                                [    0.267321] spi0 supply spi not found, using dummy regulator
                                [    0.267410] sunxi_spi_request_gpio()1883 - [spi0] Pinctrl init spi0
                                [    0.267503] sunxi_spi_clk_init()1954 - [spi0] mclk 100000000
                                [    0.268679] sunxi_spi_probe()2339 - [spi0]: driver probe succeed, base c4868000, irq 294
                                [    0.273206] sunxi_sid_driver_init+0x0/0x10 complete comp.
                                [    0.274599] workingset: timestamp_bits=29 max_order=14 bucket_order=0
                                [    0.289787] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                                [    0.291795] io scheduler noop registered
                                [    0.291815] io scheduler deadline registered
                                [    0.292103] io scheduler cfq registered (default)
                                [    0.293353] [DISP]disp_module_init
                                [    0.294963] [DISP] parser_disp_init_para,line:1306:
                                [    0.294980] of_property_read disp_init.disp_init_enable fail
                                [    0.295534] lcd 0, driver_name ,  panel_name default_lcd
                                [    0.295551] lcd 0, driver_name ,  panel_name he0801a068
                                [    0.295559] lcd 0, driver_name ,  panel_name inet_dsi_panel
                                [    0.295566] lcd 0, driver_name ,  panel_name lq101r1sx03
                                [    0.295574] lcd 0, driver_name ,  panel_name WilliamLcd
                                [    0.295581] lcd 0, driver_name ,  panel_name bp101wx1
                                [    0.295589] lcd 0, driver_name ,  panel_name k101im2qa04
                                [    0.295596] lcd 0, driver_name ,  panel_name t050k589
                                [    0.295603] lcd 0, driver_name ,  panel_name kd080d24
                                [    0.295611] lcd 0, driver_name ,  panel_name super_lcd_driver
                                [    0.297390] [DISP]disp_module_init finish
                                [    0.300747] uart0 supply uart not found, using dummy regulator
                                [    0.301045] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI
                                [    0.301081] sw_console_setup()2050 - console setup baud 115200 parity n bits 8, flow n
                                [    1.363657] console [ttyS0] enabled
                                [    1.368603] misc dump reg init
                                [    1.372770] npu[1][1] vipcore, platform driver device=0xc396de10
                                [    1.379899] npu[1][1] vipcore irq number is 290.
                                [    1.385091] gckvip_drv_adjust_param 232 SUCCESS
                                [    1.390313] the freq of pll_npux4 clk is fixed
                                [    1.395313] Want set pclk rate(348000000) support(1392000000) real(1392000000)
                                [    1.403560] Want set mclk rate(348000000) support(348000000) real(348000000)
                                [    1.411572] npu[1][1] This device support 64bits DMA
                                [    1.417746] npu[1][1] core_0, request irqline=290, name=vipcore_0
                                [    1.424678] npu[1][1] =======vipcore parameter=====
                                [    1.430398] npu[1][1] registerMemBase     0x03050000,
                                [    1.436239] npu[1][1] registerMemSize     0x00020000,
                                [    1.442014] npu[1][1] irqLine             0x00000122,
                                [    1.447825] npu[1][1] contiguousSize      0x00100000
                                [    1.453402] npu[1][1] contiguousBase      0x30000000
                                [    1.459057] npu[1][1] vipContiguousBase   0x0
                                [    1.463950] npu[1][1] drvType             0x00000000
                                [    1.469559] npu[1][1] AXISramSize         0x00000000
                                [    1.475135] npu[1][1] AXISramBaseAddress  0x00000000
                                [    1.480736] npu[1][1] VIPSramSize         0x00020000
                                [    1.486326] npu[1][1] VIPSramBaseAddress  0x00400000
                                [    1.491902] npu[1][1] sysHeapSize         0x00200000
                                [    1.497488] npu[1][1] ===============================
                                [    1.503249] npu[1][1] VIPLite driver version 1.8.1.0-AW-2022-07-26
                                [    1.511431] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
                                [    1.517976] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (-1)
                                [    1.524632] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator.
                                [    1.532035] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null))
                                [    1.539421] sunxi-wlan soc@03000000:wlan@0: request pincrtl handle for device [soc@03000000:wlan@0] failed
                                [    1.550411] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=134  mul-sel=1  pull=1  drv_level=2  data=0
                                [    1.561055] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
                                [    1.568163] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=135  mul-sel=14  pull=1  drv_level=2  data=0
                                [    1.579249] sunxi-wlan soc@03000000:wlan@0: clk_name ()
                                [    1.586775] sunxi-spinand: AW SPINand MTD Layer Version: 2.4 20220106
                                [    1.594027] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211125
                                [    1.602386] sunxi-spinand-phy: detect munufacture from id table: Winbond
                                [    1.609991] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
                                [    1.617067] sunxi-spinand-phy: ========== arch info ==========
                                [    1.623618] sunxi-spinand-phy: Model:               W25N01GVZEIG
                                [    1.630479] sunxi-spinand-phy: Munufacture:         Winbond
                                [    1.636776] sunxi-spinand-phy: DieCntPerChip:       1
                                [    1.642449] sunxi-spinand-phy: BlkCntPerDie:        1024
                                [    1.648440] sunxi-spinand-phy: PageCntPerBlk:       64
                                [    1.654209] sunxi-spinand-phy: SectCntPerPage:      4
                                [    1.659892] sunxi-spinand-phy: OobSizePerPage:      64
                                [    1.665661] sunxi-spinand-phy: BadBlockFlag:        0x0
                                [    1.671537] sunxi-spinand-phy: OperationOpt:        0x7
                                [    1.677412] sunxi-spinand-phy: MaxEraseTimes:       65000
                                [    1.683474] sunxi-spinand-phy: EccFlag:             0x0
                                [    1.689350] sunxi-spinand-phy: EccType:             2
                                [    1.695022] sunxi-spinand-phy: EccProtectedType:    3
                                [    1.700702] sunxi-spinand-phy: ========================================
                                [    1.708140] sunxi-spinand-phy:
                                [    1.711663] sunxi-spinand-phy: ========== physical info ==========
                                [    1.718615] sunxi-spinand-phy: TotalSize:    128 M
                                [    1.723993] sunxi-spinand-phy: SectorSize:   512 B
                                [    1.729381] sunxi-spinand-phy: PageSize:     2 K
                                [    1.734564] sunxi-spinand-phy: BlockSize:    128 K
                                [    1.739952] sunxi-spinand-phy: OOBSize:      64 B
                                [    1.745232] sunxi-spinand-phy: ========================================
                                [    1.752669] sunxi-spinand-phy:
                                [    1.756202] sunxi-spinand-phy: ========== logical info ==========
                                [    1.763045] sunxi-spinand-phy: TotalSize:    128 M
                                [    1.768433] sunxi-spinand-phy: SectorSize:   512 B
                                [    1.773811] sunxi-spinand-phy: PageSize:     4 K
                                [    1.779004] sunxi-spinand-phy: BlockSize:    256 K
                                [    1.784383] sunxi-spinand-phy: OOBSize:      128 B
                                [    1.789770] sunxi-spinand-phy: ========================================
                                [    1.797296] sunxi-spinand-phy: block lock register: 0x00
                                [    1.803353] sunxi-spinand-phy: feature register: 0x19
                                [    1.809051] sunxi-spinand-phy: sunxi physic nand init end
                                [    1.817339] sunxipart: failed to parse sunxi_gpt!
                                [    1.822650] Creating 4 MTD partitions on "sunxi_mtd_nand":
                                [    1.828877] 0x000000000000-0x000000100000 : "boot0"
                                [    1.837295] 0x000000100000-0x000000400000 : "uboot"
                                [    1.847207] 0x000000400000-0x000000500000 : "secure_storage"
                                [    1.856820] 0x000000500000-0x000008000000 : "sys"
                                [    1.862741] random: fast init done
                                [    1.962810] sunxi-spinand-phy: phy blk 684 is bad
                                [    1.968397] sunxi-spinand-phy: phy blk 687 is bad
                                [    1.985167] sunxi-spinand-phy: phy blk 764 is bad
                                [    1.990769] sunxi-spinand-phy: phy blk 767 is bad
                                [    2.014825] sunxi-spinand-phy: phy blk 893 is bad
                                [    2.020579] sunxi-spinand-phy: phy blk 896 is bad
                                [    2.047536] libphy: Fixed MDIO Bus: probed
                                [    2.053183] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                                [    2.061040] get ehci0-controller, regulator_io is no nocare
                                [    2.067392] get ehci0-controller wakeup-source is fail.
                                [    2.073449] sunxi ehci0-controller don't init wakeup source
                                [    2.079909] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a6ff38, 0x:c4873000, irq_no:12e
                                [    2.092076] [sunxi-ehci0]: Not init ehci0
                                [    2.097091] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                                [    2.104495] get ohci0-controller, regulator_io is no nocare
                                [    2.110976] get ohci0-controller wakeup-source is fail.
                                [    2.117110] sunxi ohci0-controller don't init wakeup source
                                [    2.123465] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a7015c
                                [    2.133225] [sunxi-ohci0]: Not init ohci0
                                [    2.138449] usbcore: registered new interface driver uas
                                [    2.144846] usbcore: registered new interface driver usb-storage
                                [    2.151890] usbcore: registered new interface driver ums-alauda
                                [    2.158898] usbcore: registered new interface driver ums-cypress
                                [    2.166069] usbcore: registered new interface driver ums-datafab
                                [    2.173001] usbcore: registered new interface driver ums_eneub6250
                                [    2.180289] usbcore: registered new interface driver ums-freecom
                                [    2.187392] usbcore: registered new interface driver ums-isd200
                                [    2.194343] usbcore: registered new interface driver ums-jumpshot
                                [    2.201546] usbcore: registered new interface driver ums-karma
                                [    2.208513] usbcore: registered new interface driver ums-onetouch
                                [    2.215683] usbcore: registered new interface driver ums-realtek
                                [    2.222700] usbcore: registered new interface driver ums-sddr09
                                [    2.229688] usbcore: registered new interface driver ums-sddr55
                                [    2.236762] usbcore: registered new interface driver ums-usbat
                                [    2.243441] usb_serial_number:20080411
                                [    2.248774] sunxi_gpadc_init,1949, success
                                [    2.253816] sunxi_gpadc_setup: get channel scan data failed
                                [    2.261726] input: sunxi-gpadc0 as /devices/virtual/input/input0
                                [    2.271084] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
                                [    2.278402] sunxi-rtc rtc: RTC enabled
                                [    2.282694] fix to hot reboot, save boot reason
                                [    2.288381] i2c /dev entries driver
                                [    2.293072] sunxi cedar version 0.1
                                [    2.297535] VE: install start!!!
                                [    2.297535]
                                [    2.303010] VE: cedar-ve the get irq is 291
                                [    2.307985] VE: regs_csi = c48ad000
                                [    2.312620] VE: ve_proc_mgr: flag = 1
                                [    2.312620]
                                [    2.318707] VE: install end!!!
                                [    2.318707]
                                [    2.324295] google_vp9: sunxi google vp9 version 0.1
                                [    2.333482] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
                                [    2.343306] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
                                [    2.350942] Bluetooth: HCI UART protocol H4 registered
                                [    2.356853] Bluetooth: HCI H4 protocol initialized
                                [    2.362497] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
                                [    2.370400] bt_fdi debugfs_init
                                [    2.378663] cpuidle: enable-method property 'psci' found operations
                                [    2.389927] usbcore: registered new interface driver usbhid
                                [    2.396681] usbhid: USB HID core driver
                                [    2.404921] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
                                [    2.416374] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec <-> soc@03000000:codec_plat mapping ok
                                [    2.430628] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai <-> 2032000.daudio0_plat mapping ok
                                [    2.445622] NET: Registered protocol family 10
                                [    2.452908] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
                                [    2.461150] NET: Registered protocol family 17
                                [    2.466684] NET: Registered protocol family 15
                                [    2.471847] Bluetooth: RFCOMM TTY layer initialized
                                [    2.477531] Bluetooth: RFCOMM socket layer initialized
                                [    2.483343] Bluetooth: RFCOMM ver 1.11
                                [    2.489026] Registering SWP/SWPB emulation handler
                                [    2.504110] ubi0: attaching mtd3
                                [    2.604128] random: crng init done
                                [    2.737414] ubi0: scanning is finished
                                [    2.752614] ubi0: attached mtd3 (name "sys", size 123 MiB)
                                [    2.758905] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                                [    2.766679] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                                [    2.774312] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                                [    2.782277] ubi0: good PEBs: 486, bad PEBs: 6, corrupted PEBs: 0
                                [    2.789079] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
                                [    2.797308] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                                [    2.806725] ubi0: available PEBs: 10, total reserved PEBs: 476, PEBs reserved for bad PEB handling: 4
                                [    2.817110] ubi0: background thread "ubi_bgt0d" started, PID 686
                                [    2.824452] get det_vbus is fail, 84
                                [    2.828683] get id is fail, 84
                                [    2.833245] sunxi-rtc rtc: setting system clock to 1970-01-01 00:51:37 UTC (3097)
                                [    2.842846] clk: Not disabling unused clocks
                                [    2.847865] ALSA device list:
                                [    2.851213]   #0: audiocodec
                                [    2.854450]   #1: snddaudio0
                                [    2.858250] VFS: Cannot open root device "ubiblock0_4" or unknown-block(0,0): error -6
                                [    2.867287] Please append a correct "root=" boot option; here are the available partitions:
                                [    2.876744] 1f00            1024 mtdblock0  (driver?)
                                [    2.882436] 1f01            3072 mtdblock1  (driver?)
                                [    2.888162] 1f02            1024 mtdblock2  (driver?)
                                [    2.893848] 1f03          125952 mtdblock3  (driver?)
                                [    2.899630] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                                [    2.908920] CPU: 0 PID: 1 Comm: swapper Not tainted 4.9.191 #94
                                [    2.915567] Hardware name: sun8iw21
                                [    2.919516] [<c010d3cc>] (unwind_backtrace) from [<c010a51c>] (show_stack+0x10/0x14)
                                [    2.928227] [<c010a51c>] (show_stack) from [<c016ff58>] (panic+0xac/0x2b0)
                                [    2.935962] [<c016ff58>] (panic) from [<c0901270>] (mount_block_root+0x208/0x2f4)
                                [    2.944380] [<c0901270>] (mount_block_root) from [<c0901504>] (prepare_namespace+0x138/0x178)
                                [    2.953967] [<c0901504>] (prepare_namespace) from [<c0900e80>] (kernel_init_freeable+0x11c/0x178)
                                [    2.963942] [<c0900e80>] (kernel_init_freeable) from [<c06098d0>] (kernel_init+0x8/0x108)
                                [    2.973138] [<c06098d0>] (kernel_init) from [<c0106ca8>] (ret_from_fork+0x14/0x2c)
                                [    2.981649] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                                [    2.991809] sunxi dump enabled
                                [    2.995234] dump regs done
                                [    2.998304] flush cache done
                                [    3.001555] crashdump enter
                                D 1 条回复 最后回复 回复 引用 分享 0
                                  daMing123 LV 6 @daMing123 最后由 编辑
                                  想了几天,终于想明白了
                                  S Q 2 条回复 最后回复 回复 引用 分享 0
                                    steven73 LV 4 @daMing123 最后由 编辑
                                    @daming123 你好,我也遇到了一样的问题,能请教一下解决思路么?
                                    D 1 条回复 最后回复 回复 引用 分享 1
                                      daMing123 LV 6 @steven73 最后由 编辑
                                      @steven73
                                      用的是什么存储介质启动?
                                      完整打印看下
                                      • N
                                        nihao123 LV 2 最后由 编辑
                                        • Referenced by  F fanhuacloud
                                          chunyangjs LV 2 最后由 编辑
                                          在T113S3上实测有效
                                          Y 1 条回复 最后回复 回复 引用 分享 1
                                          • Referenced by  K kwongwo
                                          • N
                                            nice0513 LV 4 最后由 编辑
                                            感谢分享,谢谢。。。。
                                              yyyyppppp LV 5 最后由 编辑
                                              大佬你好,我如果t113存储介质切换 由spi namd flash 128M切换到 512M
                                              上面的几种方法 也可以适用吗?
                                                yyyyppppp LV 5 @chunyangjs 最后由 编辑
                                                @chunyangjs你好! 我的T113目前使用spi nand flash 128M 如果将它升级到512M 这个方法也可以吗?
                                                • Referenced by  L leokemp
                                                • N
                                                  NathanLiu LV 5 最后由 编辑
                                                  大佬,可以帮忙解答下吗
                                                  Z 1 条回复 最后回复 回复 引用 分享 0
                                                    zoipuus LV 5 @NathanLiu 最后由 编辑
                                                    @nathanliu spi配置没问题,查一下brandy/brandy-2.0/u-boot-2018/drivers/mtd/awnand/spinand/physic/id.c的struct aw_spinand_phy_info gigadevice[],应该没有你现在用的SPI NAND
                                                    后续还要检查kernel/linux-5.4/drivers/mtd/awnand/spinand/physic/id.c,两个路径需要同时添加
                                                      away123456 LV 4 @tanlining 最后由 编辑
                                                      @tanlining 请问阁下你这个问题是怎么解决呢 感谢
                                                        away123456 LV 4 最后由 编辑
                                                        [10342]fes begin commit:2a3ec52022
                                                        [10345]set pll start
                                                        [10347]periph0 has been enabled
                                                        [10350]set pll end
                                                        [10410][pmu]: bus read error
                                                        [10413]board init ok
                                                        [10415]beign to init dram
                                                        [10417]DRAM use internal ZQ!!
                                                        [10420]ZQ value = 0x30
                                                        [10422]chip id check OK
                                                        [10424]POWER SETTING ERROR!
                                                        [10427]trefi:7.8ms
                                                        [10430][AUTO DEBUG] single rank and full DQ!
                                                        [10434]trefi:7.8ms
                                                        [10436][AUTO DEBUG] rank 0 row = 13
                                                        [10439][AUTO DEBUG] rank 0 bank = 4
                                                        [10443][AUTO DEBUG] rank 0 page size = 2 KB
                                                        [10447]DRAM BOOT DRIVE INFO: V0.16
                                                        [10450]DRAM CLK = 528 MHz
                                                        [10452]DRAM Type = 2 (2:DDR2,3:DDR3)
                                                        [10456]DRAMC read ODT  off.
                                                        [10459]DRAM ODT off.
                                                        [10461]DRAM SIZE =64 M
                                                        [10463]dram_tpr4:0x0
                                                        [10467]DRAM simple test OK.
                                                        [10470]rtc standby flag is 0x0, super standby flag is 0x0
                                                        [10475]init dram ok
                                                        U-Boot 2018.05-g3a34d5f-dirty (Nov 11 2024 - 08:21:33 -0800) Allwinner Technology
                                                        [11.958]CPU:   Allwinner Family
                                                        [11.961]Model: sun8iw21
                                                        I2C:   [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed.
                                                        ready
                                                        [12.021]DRAM:  64 MiB
                                                        [12.024]Relocation Offset is: 01eef000
                                                        [12.053]secure enable bit: 0
                                                        [I2C-ERROR]:twi_stop() 339 STOP can't sendout!
                                                        [12.060]pmu_axp2101_probe pmic_bus_read fail
                                                        [12.064]PMU: no found
                                                        [12.070]bmu_axp2101_probe pmic_bus_read fail
                                                        [12.074]BMU: no found
                                                        [12.076]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
                                                        [12.082]gic: normal mode
                                                        sunxi flash map init
                                                        [12.086]flash init start xxx
                                                        [12.089]workmode = 16,storage type = 0
                                                        try card 2
                                                        set card number 2
                                                        get card number 2
                                                        [12.097][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
                                                        [12.102][mmc]: get sdc_type fail and use default host:tm4.
                                                        [12.109][mmc]: Is not Boot mode!
                                                        [12.112][mmc]: SUNXI SDMMC Controller Version:0x50400
                                                        [12.123][mmc]: ************Try SD card 2************
                                                        [12.128][mmc]: mmc 2 cmd timeout 100 status 100
                                                        [12.132][mmc]: smc 2 err, cmd 8,  RTO
                                                        [12.136][mmc]: mmc 2 close bus gating and reset
                                                        [12.141][mmc]: mmc 2 cmd timeout 100 status 100
                                                        [12.145][mmc]: smc 2 err, cmd 55,  RTO
                                                        [12.148][mmc]: mmc 2 close bus gating and reset
                                                        [12.153][mmc]: ************Try MMC card 2************
                                                        [12.161][mmc]: mmc 2 cmd timeout 100 status 100
                                                        [12.166][mmc]: smc 2 err, cmd 1,  RTO
                                                        [12.169][mmc]: mmc 2 close bus gating and reset
                                                        [12.173][mmc]: Card did not respond to voltage select!
                                                        [12.178][mmc]: ************SD/MMC 2 init error!************
                                                        [12.183][mmc]: mmc init product failed
                                                        MMC init failed
                                                        try emmc fail
                                                        [12.190]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
                                                        [12.196]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
                                                        [12.204]sunxi-spinand-phy: request spi0 gpio ok
                                                        [12.208]sunxi-spinand-phy: request general tx dma channel ok!
                                                        [12.214]sunxi-spinand-phy: request general rx dma channel ok!
                                                        [12.219]sunxi-spinand-phy: set spic0 clk to 20 Mhz
                                                        [12.224]sunxi-spinand-phy: init spic0 clk ok
                                                        [12.228]sunxi-spinand-phy: detect munufacture from id table: Mxic
                                                        [12.233]sunxi-spinand-phy: detect spinand id: ff0326c2 ffffffff
                                                        [12.239]sunxi-spinand-phy: ========== arch info ==========
                                                        [12.244]sunxi-spinand-phy: Model:               MX35LF2GE4AD
                                                        [12.250]sunxi-spinand-phy: Munufacture:         Mxic
                                                        [12.254]sunxi-spinand-phy: DieCntPerChip:       1
                                                        [12.259]sunxi-spinand-phy: BlkCntPerDie:        2048
                                                        [12.263]sunxi-spinand-phy: PageCntPerBlk:       64
                                                        [12.268]sunxi-spinand-phy: SectCntPerPage:      4
                                                        [12.272]sunxi-spinand-phy: OobSizePerPage:      64
                                                        [12.277]sunxi-spinand-phy: BadBlockFlag:        0x1
                                                        [12.281]sunxi-spinand-phy: OperationOpt:        0x7
                                                        [12.286]sunxi-spinand-phy: MaxEraseTimes:       65000
                                                        [12.291]sunxi-spinand-phy: EccFlag:             0x2
                                                        [12.295]sunxi-spinand-phy: EccType:             8
                                                        [12.300]sunxi-spinand-phy: EccProtectedType:    3
                                                        [12.304]sunxi-spinand-phy: ========================================
                                                        [12.310]sunxi-spinand-phy:
                                                        [12.313]sunxi-spinand-phy: ========== physical info ==========
                                                        [12.318]sunxi-spinand-phy: TotalSize:    256 M
                                                        [12.322]sunxi-spinand-phy: SectorSize:   512 B
                                                        [12.327]sunxi-spinand-phy: PageSize:     2 K
                                                        [12.330]sunxi-spinand-phy: BlockSize:    128 K
                                                        [12.335]sunxi-spinand-phy: OOBSize:      64 B
                                                        [12.339]sunxi-spinand-phy: ========================================
                                                        [12.345]sunxi-spinand-phy:
                                                        [12.347]sunxi-spinand-phy: ========== logical info ==========
                                                        [12.353]sunxi-spinand-phy: TotalSize:    256 M
                                                        [12.357]sunxi-spinand-phy: SectorSize:   512 B
                                                        [12.361]sunxi-spinand-phy: PageSize:     4 K
                                                        [12.365]sunxi-spinand-phy: BlockSize:    256 K
                                                        [12.369]sunxi-spinand-phy: OOBSize:      128 B
                                                        [12.373]sunxi-spinand-phy: ========================================
                                                        [12.380]sunxi-spinand-phy: MX35LF2GE4AD reset rx bit width to 1
                                                        [12.385]sunxi-spinand-phy: MX35LF2GE4AD reset tx bit width to 1
                                                        [12.391]sunxi-spinand-phy: block lock register: 0x00
                                                        [12.396]sunxi-spinand-phy: feature register: 0x11
                                                        [12.400]sunxi-spinand-phy: sunxi physic nand init end
                                                        [12.822]sunxi-spinand-phy: set spic0 clk to 100 Mhz
                                                        [14.056]sunxi-spinand-phy: Sample mode:1  min_delay:4160 max_delay:14120 right_delay:19)
                                                        [14.219]line:724 init_clocks
                                                        [14.222]init_clocks:finish
                                                        [14.225]Loading Environment from SUNXI_FLASH... OK
                                                        [14.229]try to burn key
                                                        [14.232]out of usb burn from boot: not need burn key
                                                        sunxi work mode=0x10
                                                        run usb efex
                                                        delay time 2500
                                                        weak:otg_phy_config
                                                        usb init ok
                                                        set address 0x9
                                                        set address 0x9 ok
                                                        SUNXI_EFEX_ERASE_TAG
                                                        erase_flag = 0x12
                                                        origin_erase_flag = 0x1
                                                        FEX_CMD_fes_verify_status
                                                        FEX_CMD_fes_verify last err=0
                                                        the 0 mbr table is ok
                                                        the 1 mbr table is ok
                                                        the 2 mbr table is ok
                                                        the 3 mbr table is ok
                                                        total mbr part 6
                                                        part[0] name      :boot-res
                                                        part[0] classname :DISK
                                                        part[0] addrlo    :0x2000
                                                        part[0] lenlo     :0x400
                                                        part[0] user_type :32768
                                                        part[0] keydata   :0
                                                        part[0] ro        :0
                                                        part[1] name      :env
                                                        part[1] classname :DISK
                                                        part[1] addrlo    :0x2400
                                                        part[1] lenlo     :0x200
                                                        part[1] user_type :32768
                                                        part[1] keydata   :0
                                                        part[1] ro        :0
                                                        part[2] name      :boot
                                                        part[2] classname :DISK
                                                        part[2] addrlo    :0x2600
                                                        part[2] lenlo     :0x5710
                                                        part[2] user_type :32768
                                                        part[2] keydata   :0
                                                        part[2] ro        :0
                                                        part[3] name      :rootfs
                                                        part[3] classname :DISK
                                                        part[3] addrlo    :0x7d10
                                                        part[3] lenlo     :0x1e910
                                                        part[3] user_type :32768
                                                        part[3] keydata   :0
                                                        part[3] ro        :0
                                                        part[4] name      :rootfs_data
                                                        part[4] classname :DISK
                                                        part[4] addrlo    :0x26620
                                                        part[4] lenlo     :0x19000
                                                        part[4] user_type :32768
                                                        part[4] keydata   :0
                                                        part[4] ro        :0
                                                        part[5] name      :UDISK
                                                        part[5] classname :DISK
                                                        part[5] addrlo    :0x3f620
                                                        part[5] lenlo     :0x0
                                                        part[5] user_type :33024
                                                        part[5] keydata   :0
                                                        part[5] ro        :0
                                                        total part: 7
                                                        mbr 0, 2000, 8000
                                                        boot-res 1, 400, 8000
                                                        env 2, 200, 8000
                                                        boot 3, 5710, 8000
                                                        rootfs 4, 1e910, 8000
                                                        rootfs_data 5, 19000, 8000
                                                        UDISK 6, 0, 8100
                                                        [17.227]erase blk 0 to blk 32
                                                        [17.230]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.234]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.241]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.246]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.253]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.257]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.264]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.269]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.276]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.280]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.287]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.292]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.299]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        [17.303]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
                                                        need erase flash: 18
                                                        [17.376]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
                                                        defaults:
                                                        mtdids  : nand0=nand
                                                        [17.427]MTD info (4)
                                                        [17.429]pagesize: 0x1000
                                                        [17.431]blksize: 0x40000
                                                        [17.433]num  offset     bytes      name
                                                        [17.437]0    0x00000000 0x00100000 boot0
                                                        [17.440]1    0x00100000 0x00300000 uboot
                                                        [17.444]2    0x00400000 0x00100000 secure_storage
                                                        [17.449]3    0x00500000 0x0fb00000 sys
                                                        [17.452]ubi attach the last part of mtd device: NO.3
                                                        [17.756]ubi0: attaching mtd4
                                                        [18.228]ubi0: scanning is finished
                                                        [18.239]ubi0: attached mtd4 (name "sys", size 251 MiB)
                                                        [18.243]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                                                        [18.250]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                                                        [18.256]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                                                        [18.262]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
                                                        [18.268]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
                                                        [18.274]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                                                        [18.282]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
                                                        [18.291]erase blk 0 to blk 32
                                                        [18.349]erase blk 40 to blk 2048
                                                        [22.339]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
                                                        [22.347]Item0 (Map) magic is bad
                                                        [22.350]the secure storage map is empty
                                                        [22.447]sunxi-spinand: write secure storage itme 0 ok
                                                        [22.452]erase secure storage: 0 ok
                                                        SUNXI_EFEX_MBR_TAG
                                                        mbr size = 0x10000
                                                        force mbr
                                                        defaults:
                                                        mtdids  : nand0=nand
                                                        [22.500]MTD info (4)
                                                        [22.502]pagesize: 0x1000
                                                        [22.504]blksize: 0x40000
                                                        [22.506]num  offset     bytes      name
                                                        [22.510]0    0x00000000 0x00100000 boot0
                                                        [22.514]1    0x00100000 0x00300000 uboot
                                                        [22.517]2    0x00400000 0x00100000 secure_storage
                                                        [22.522]3    0x00500000 0x0fb00000 sys
                                                        [22.525]MBR info (unalign):
                                                        [22.528]partno   addr       sects      type       name
                                                        [22.532]0        0x00000000 0x00002000 0x00000001 mbr
                                                        [22.537]1        0x00002000 0x00000400 0x00008000 boot-res
                                                        [22.542]2        0x00002400 0x00000200 0x00008000 env
                                                        [22.547]3        0x00002600 0x00005710 0x00008000 boot
                                                        [22.552]4        0x00007d10 0x0001e910 0x00008000 rootfs
                                                        [22.557]5        0x00026620 0x00019000 0x00008000 rootfs_data
                                                        [22.563]6        0x0003f620 0x00000000 0x00008100 UDISK
                                                        [22.567]ubi attach the last part of mtd device: NO.3
                                                        [22.572]MBR info (align):
                                                        [22.574]partno   addr       sects      type       name
                                                        [22.579]0        0x00002800 0x00002178 0x00000001 mbr
                                                        [22.584]1        0x00004978 0x000005e8 0x00008000 boot-res
                                                        [22.589]2        0x00004f60 0x000003f0 0x00008000 env
                                                        [22.594]3        0x00005350 0x00005898 0x00008000 boot
                                                        [22.599]4        0x0000abe8 0x0001ea38 0x00008000 rootfs
                                                        [22.604]5        0x00029620 0x000191a0 0x00008000 rootfs_data
                                                        [22.609]6        0x000427c0 0x00000000 0x00008100 UDISK
                                                        [22.614]ubi attach the last part of mtd device: NO.3
                                                        [22.619]ubi attatch mtd, name: sys
                                                        [22.622]ubi0: detaching mtd4
                                                        [22.625]ubi0: mtd4 is detached
                                                        [22.628]ubi0: attaching mtd4
                                                        [22.865]ubi0: scanning is finished
                                                        [22.868]ubi0: empty MTD device detected
                                                        [22.895]ubi0: attached mtd4 (name "sys", size 251 MiB)
                                                        [22.899]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                                                        [22.905]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                                                        [22.912]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                                                        [22.918]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
                                                        [22.923]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
                                                        [22.930]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
                                                        [22.938]ubi0: available PEBs: 960, total reserved PEBs: 44, PEBs reserved for bad PEB handling: 40
                                                        Creating static volume mbr of size 4386816
                                                        Creating dynamic volume boot-res of size 774144
                                                        Creating dynamic volume env of size 516096
                                                        Creating dynamic volume boot of size 11612160
                                                        Creating dynamic volume rootfs of size 64253952
                                                        Creating dynamic volume rootfs_data of size 52641792
                                                        No size specified -> Using max size (113541120)
                                                        [27.162]reset last volume size to 0x36240
                                                        Creating dynamic volume UDISK of size 113541120
                                                        [27.195]existed volume UDISK size is 221760(sects) , inside ubi part size is 0(sects),existed volume size to update inside ubi part size
                                                        [27.207]existed volume UDISK size is 221760(sects) , inside ubi part size is 0(sects),existed volume size to update inside ubi part size
                                                        [27.243]fill gap start: volume mbr sects 0x1f80
                                                        [28.783]fill gap end: volume mbr
                                                        [28.786]update partition map
                                                        [28.788]logical area info: 960 258048 last_lba: 483839
                                                        [28.801]logical area info: 960 258048 last_lba: 483839
                                                        [28.813]logical area info: 960 258048 last_lba: 483839
                                                        [28.826]logical area info: 960 258048 last_lba: 483839
                                                        [28.838]logical area info: 960 258048 last_lba: 483839
                                                        [28.850]logical area info: 960 258048 last_lba: 483839
                                                        [28.863]logical area info: 960 258048 last_lba: 483839
                                                        [28.875]logical area info: 960 258048 last_lba: 483839
                                                        [28.888]logical area info: 960 258048 last_lba: 483839
                                                        [28.900]logical area info: 960 258048 last_lba: 483839
                                                        [28.912]logical area info: 960 258048 last_lba: 483839
                                                        [28.925]logical area info: 960 258048 last_lba: 483839
                                                        [28.937]logical area info: 960 258048 last_lba: 483839
                                                        [28.949]logical area info: 960 258048 last_lba: 483839
                                                        [28.962]logical area info: 960 258048 last_lba: 483839
                                                        [28.974]logical area info: 960 258048 last_lba: 483839
                                                        [28.987]logical area info: 960 258048 last_lba: 483839
                                                        [28.999]logical area info: 960 258048 last_lba: 483839
                                                        [29.011]logical area info: 960 258048 last_lba: 483839
                                                        [29.024]logical area info: 960 258048 last_lba: 483839
                                                        [29.036]logical area info: 960 258048 last_lba: 483839
                                                        [29.048]logical area info: 960 258048 last_lba: 483839
                                                        [29.088]fill gap start: volume boot-res sects 0x360
                                                        [29.184]fill gap end: volume boot-res
                                                        FEX_CMD_fes_verify_value, start 0x2000, size high 0x0:low 0x14000
                                                        [29.239]fill gap start: volume env sects 0x100
                                                        [29.333]fill gap end: volume env
                                                        FEX_CMD_fes_verify_value, start 0x2400, size high 0x0:low 0x20000
                                                        FEX_CMD_fes_verify_value 0x12e446f8
                                                        [31.557]fill gap start: volume boot sects 0x1b98
                                                        [31.679]fill gap end: volume boot
                                                        FEX_CMD_fes_verify_value, start 0x2600, size high 0x0:low 0x76f000
                                                        FEX_CMD_fes_verify_value 0xbdbf9631
                                                        [41.076]fill gap start: volume rootfs sects 0x10110
                                                        [41.442]fill gap end: volume rootfs
                                                        FEX_CMD_fes_verify_value, start 0x7d10, size high 0x0:low 0x1d00000
                                                        FEX_CMD_fes_verify_value 0x77474c0a
                                                        bootfile_mode=4
                                                        SUNXI_EFEX_BOOT1_TAG
                                                        boot1 size = 0xe8000, max size = 0x200000
                                                        uboot size = 0xe8000
                                                        storage type = 0
                                                        [45.050]uboot blk range [8-32)
                                                        [45.052]download uboot to block 8 (8 blocks) len 928K
                                                        [45.306]download uboot to block 16 (8 blocks) len 928K
                                                        [45.559]download uboot to block 24 (8 blocks) len 928K
                                                        bootfile_mode=4
                                                        SUNXI_EFEX_BOOT0_TAG
                                                        boot0 size = 0xa000
                                                        dram para[0] = 210
                                                        dram para[1] = 2
                                                        dram para[2] = 7b7bf9
                                                        dram para[3] = 0
                                                        dram para[4] = d2
                                                        dram para[5] = 400000
                                                        dram para[6] = e73
                                                        dram para[7] = 2
                                                        dram para[8] = 0
                                                        dram para[9] = 0
                                                        dram para[10] = 471992
                                                        dram para[11] = 131a10c
                                                        dram para[12] = 57041
                                                        dram para[13] = b4787896
                                                        dram para[14] = 0
                                                        dram para[15] = 48484848
                                                        dram para[16] = 48
                                                        dram para[17] = 1621121e
                                                        dram para[18] = 0
                                                        dram para[19] = 0
                                                        dram para[20] = 0
                                                        dram para[21] = 22
                                                        dram para[22] = 77
                                                        dram para[23] = b4006103
                                                        dram para[24] = 0
                                                        dram para[25] = 0
                                                        dram para[26] = 0
                                                        dram para[27] = 0
                                                        dram para[28] = 0
                                                        dram para[29] = 0
                                                        dram para[30] = 0
                                                        dram para[31] = 0
                                                        storage type = 0
                                                        [45.883]download boot0 to block 0 len 40K
                                                        [45.899]download boot0 to block 1 len 40K
                                                        [45.914]download boot0 to block 2 len 40K
                                                        [45.930]download boot0 to block 3 len 40K
                                                        [45.945]download boot0 to block 4 len 40K
                                                        [45.960]download boot0 to block 5 len 40K
                                                        [45.976]download boot0 to block 6 len 40K
                                                        [45.991]download boot0 to block 7 len 40K
                                                        sunxi_efex_next_action=2
                                                        exit usb
                                                        next work 2
                                                        ?[22]HELLO! BOOT0 is starting!T
                                                        [25]BOOT0 commit : 2a3ec52022
                                                        [28]set pll start
                                                        [30]periph0 has been enabled
                                                        [32]set pll end
                                                        [108][pmu]: bus read error
                                                        [111]board init ok
                                                        [113]DRAM use internal ZQ!!
                                                        [115]ZQ value = 0x30
                                                        [117]chip id check OK
                                                        [119]POWER SETTING ERROR!
                                                        [122]DRAM BOOT DRIVE INFO: V0.16
                                                        [125]DRAM CLK = 528 MHz
                                                        [127]DRAM Type = 2 (2:DDR2,3:DDR3)
                                                        [131]DRAMC read ODT  off.
                                                        [133]DRAM ODT off.
                                                        [136]DRAM SIZE =64 M
                                                        [138]dram_tpr4:0x0
                                                        [145]DRAM simple test OK.
                                                        [147]rtc standby flag is 0x0, super standby flag is 0x0
                                                        [152]dram size =64
                                                        [155]audio:avcc calibration
                                                        [158]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
                                                        [163]block from 8 to 32
                                                        [496]Check is correct.
                                                        [498]Entry_name        = optee
                                                        [501]Entry_name        = u-boot
                                                        [509]Entry_name        = dtb
                                                        [512]Jump to second Boot.
                                                        E/TC:0 0 platform_standby_fdt_parse:133 no pmu node
                                                        E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
                                                        [00.590]CPU:   Allwinner Family
                                                        [00.593]Model: sun8iw21
                                                        ready
                                                        [00.653]DRAM:  64 MiB
                                                        [00.656]Relocation Offset is: 01eef000
                                                        [00.685]secure enable bit: 0
                                                        [00.699]smc_tee_inform_fdt failed with: ffff0000
                                                        [00.709]pmu_axp2101_probe pmic_bus_read fail
                                                        [00.718]bmu_axp2101_probe pmic_bus_read fail
                                                        [00.722]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
                                                        [00.728]gic: sec monitor mode
                                                        [00.733]flash init start xxx
                                                        [00.735]workmode = 0,storage type = 0
                                                        [00.743]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:19
                                                        defaults:
                                                        mtdids  : nand0=nand
                                                        [01.089]ubi0: attaching mtd4
                                                        [01.561]ubi0: scanning is finished
                                                        [01.571]ubi0: attached mtd4 (name "sys", size 251 MiB)
                                                        [01.576]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                                                        [01.582]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                                                        [01.588]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                                                        [01.595]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
                                                        [01.600]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
                                                        [01.607]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                                                        [01.615]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
                                                        [01.623]sunxi flash init ok
                                                        [01.626]line:724 init_clocks
                                                        [01.794]Loading Environment from SUNXI_FLASH... backup env check CRC fail
                                                        Now update backup env
                                                        Saving Environment to SUNXI_FLASH... Writing to env...
                                                        OK
                                                        OK
                                                        [01.965]Item0 (Map) magic is bad
                                                        [01.968]out of usb burn from boot: not need burn key
                                                        [01.997]update bootcmd
                                                        [02.022]change working_fdt 0x42aaee70 to 0x42a8ee70
                                                        disable nand error: FDT_ERR_NOTFOUND
                                                        [02.037]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
                                                        [02.042]update dts
                                                        [03.977]no vendor_boot partition is found
                                                        [04.038]Starting kernel ...
                                                        [    0.000000] Linux version 4.9.191 (vmuser@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #8 PREEMPT Wed Nov 13 08:16:42 PST 2024
                                                        [    0.000000] free_area_init_node: node 0, pgdat c0a430f8, node_mem_map c3f78000
                                                        [    0.000000] Kernel command line: ubi.mtd=sys earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_4 rootfstype=ubifs, rw init=/init partitions=mbr@ubi0_0:boot-res@ubi0_1:env@ubi0_2:boot@ubi0_3:rootfs@ubi0_4:rootfs_data@ubi0_5:UDISK@ubi0_6: cma= snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw21p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g3a34d5f-dirty(11/11/2024-08:21:33) mbr_offset=1032192 bootreason=button aw-ubi-spinand.ubootblks=24 androidboot.dramsize=64
                                                        [    0.000000] Memory: 54784K/65536K available (6144K kernel code, 272K rwdata, 1404K rodata, 1024K init, 150K bss, 10752K reserved, 0K cma-reserved, 0K highmem)
                                                        [    0.000000]       .data : 0xc0a00000 - 0xc0a44138   ( 273 kB)
                                                        [    0.000000]        .bss : 0xc0a44138 - 0xc0a69a48   ( 151 kB)
                                                        [    0.000020] Switching to timer-based delay loop, resolution 41ns
                                                        [    0.000200] Console: colour dummy device 80x30
                                                        [    0.000232] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                                                        [    0.000246] pid_max: default: 32768 minimum: 301
                                                        [    0.000443] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
                                                        [    0.000456] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
                                                        [    0.001034] CPU: Testing write buffer coherency: ok
                                                        [    0.001663] Setting up static identity map for 0x40100000 - 0x40100058
                                                        [    0.003412] devtmpfs: initialized
                                                        [    0.034801] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                                                        [    0.035380] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                                                        [    0.035412] futex hash table entries: 256 (order: -1, 3072 bytes)
                                                        [    0.035560] atomic64_test: passed
                                                        [    0.035573] pinctrl core: initialized pinctrl subsystem
                                                        [    0.036747] NET: Registered protocol family 16
                                                        [    0.037517] DMA: preallocated 256 KiB pool for atomic coherent allocations
                                                        [    0.038867] dump_class_init,857, success
                                                        [    0.059409] cpuidle: using governor menu
                                                        [    0.060768] platform 2010000.iommu: iova_base: 0x48400000
                                                        [    0.061356] sunxi iommu: irq = 22
                                                        [    0.082173] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver
                                                        [    0.085184] iommu: Adding device npu to group 0
                                                        [    0.087241] iommu: Adding device 1c0e000.ve to group 0
                                                        [    0.100226] iommu: Adding device 5410000.g2d to group 0
                                                        [    0.101098] iommu: Adding device 5000000.disp to group 0
                                                        [    0.113039] iommu: Adding device 5908000.tdm to group 0
                                                        [    0.114003] iommu: Adding device 5900000.isp to group 0
                                                        [    0.115021] iommu: Adding device 58ffffc.isp to group 0
                                                        [    0.115889] iommu: Adding device 58ffff8.isp to group 0
                                                        [    0.116592] iommu: Adding device 58ffff4.isp to group 0
                                                        [    0.117050] iommu: Adding device 5800800.vind:isp@4 to group 0
                                                        [    0.117942] iommu: Adding device 5910000.scaler to group 0
                                                        [    0.118596] iommu: Adding device 590fffc.scaler to group 0
                                                        [    0.119279] iommu: Adding device 590fff8.scaler to group 0
                                                        [    0.120204] iommu: Adding device 590fff4.scaler to group 0
                                                        [    0.121105] iommu: Adding device 5910400.scaler to group 0
                                                        [    0.121764] iommu: Adding device 59103fc.scaler to group 0
                                                        [    0.122377] iommu: Adding device 59103f8.scaler to group 0
                                                        [    0.122864] iommu: Adding device 59103f4.scaler to group 0
                                                        [    0.123755] iommu: Adding device 5910800.scaler to group 0
                                                        [    0.124407] iommu: Adding device 59107fc.scaler to group 0
                                                        [    0.125095] iommu: Adding device 59107f8.scaler to group 0
                                                        [    0.125703] iommu: Adding device 59107f4.scaler to group 0
                                                        [    0.126592] iommu: Adding device 5910c00.scaler to group 0
                                                        [    0.127243] iommu: Adding device 5910bfc.scaler to group 0
                                                        [    0.127733] iommu: Adding device 5910bf8.scaler to group 0
                                                        [    0.128340] iommu: Adding device 5910bf4.scaler to group 0
                                                        [    0.129650] iommu: Adding device vinc0 to group 0
                                                        [    0.130878] iommu: Adding device vinc4 to group 0
                                                        [    0.131759] iommu: Adding device vinc8 to group 0
                                                        [    0.132494] iommu: Adding device vinc12 to group 0
                                                        [    0.182206] pwm module init!
                                                        [    0.186845] sunxi-pm debug v3.10
                                                        [    0.187890] SCSI subsystem initialized
                                                        [    0.188256] usbcore: registered new interface driver usbfs
                                                        [    0.188348] usbcore: registered new interface driver hub
                                                        [    0.192300] usbcore: registered new device driver usb
                                                        [    0.192664] sunxi_i2c_adap_init()2754 - init
                                                        [    0.192895] sun8iw21p1-pinctrl pio: expect_func as:twi6, but muxsel(4) is func:twi3
                                                        [    0.192912] sun8iw21p1-pinctrl pio: expect_func as:twi6, but muxsel(4) is func:twi3
                                                        [    0.193249] sunxi_i2c_probe()2449 - [i2c3] twi_drv_used = 0
                                                        [    0.193266] sunxi_i2c_probe()2456 - [i2c3] twi_pkt_interval = 0
                                                        [    0.193336] twi_regulator_request()653 - [i2c3] regulator not found(isn't configured in dts)!
                                                        [    0.193347] twi_request_gpio()469 - [i2c3] init name: (null)
                                                        [    0.194383] media: Linux media interface: v0.10
                                                        [    0.194567] Linux video capture interface: v2.00
                                                        [    0.196686] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
                                                        [    0.197886] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
                                                        [    0.198939] Advanced Linux Sound Architecture Driver Initialized.
                                                        [    0.199942] Bluetooth: Core ver 2.22
                                                        [    0.200412] NET: Registered protocol family 31
                                                        [    0.200428] Bluetooth: HCI device and connection manager initialized
                                                        [    0.200454] Bluetooth: HCI socket layer initialized
                                                        [    0.200469] Bluetooth: L2CAP socket layer initialized
                                                        [    0.200543] Bluetooth: SCO socket layer initialized
                                                        [    0.203896] G2D: rcq version initialized.major:251
                                                        [    0.205216] clocksource: Switched to clocksource arch_sys_counter
                                                        [    0.237762] get androidboot.mode fail
                                                        [    0.239967] NET: Registered protocol family 2
                                                        [    0.255592] TCP established hash table entries: 16 (order: -6, 64 bytes)
                                                        [    0.255613] TCP bind hash table entries: 16 (order: -6, 64 bytes)
                                                        [    0.255623] TCP: Hash tables configured (established 16 bind 16)
                                                        [    0.255702] UDP hash table entries: 256 (order: 0, 4096 bytes)
                                                        [    0.255725] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
                                                        [    0.255969] NET: Registered protocol family 1
                                                        [    0.256297] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC0
                                                        [    0.256319] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC1
                                                        [    0.256334] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC2
                                                        [    0.256350] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC3
                                                        [    0.256364] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC4
                                                        [    0.256379] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC5
                                                        [    0.256614] sunxi_spi_probe()2250 - [spi0] SPI DBI INTERFACE
                                                        [    0.256629] sunxi_spi_probe()2259 - [spi0] SPI MASTER MODE
                                                        [    0.256707] sunxi_spi_resource_get()1917 - sample_mode:1 sample_delay:19
                                                        [    0.256731] spi0 supply spi not found, using dummy regulator
                                                        [    0.256828] sunxi_spi_request_gpio()1883 - [spi0] Pinctrl init spi0
                                                        [    0.256922] sunxi_spi_clk_init()1954 - [spi0] mclk 100000000
                                                        [    0.258111] sunxi_spi_probe()2339 - [spi0]: driver probe succeed, base c486a000, irq 294
                                                        [    0.262420] workingset: timestamp_bits=29 max_order=14 bucket_order=0
                                                        [    0.279673] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                                                        [    0.280308] jffs2: version 2.2. (NAND) (SUMMARY)  ? 2001-2006 Red Hat, Inc.
                                                        [    0.282840] io scheduler noop registered
                                                        [    0.282861] io scheduler deadline registered
                                                        [    0.283174] io scheduler cfq registered (default)
                                                        [    0.287517] uart0 supply uart not found, using dummy regulator
                                                        [    0.287782] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI
                                                        [    0.287817] sw_console_setup()2050 - console setup baud 115200 parity n bits 8, flow n
                                                        [    1.315293] console [ttyS0] enabled
                                                        [    1.320671] misc dump reg init
                                                        [    1.324848] npu[1][1] vipcore, platform driver device=0xc39efe10
                                                        [    1.331945] npu[1][1] vipcore irq number is 290.
                                                        [    1.337197] gckvip_drv_adjust_param 232 SUCCESS
                                                        [    1.342318] the freq of pll_npux4 clk is fixed
                                                        [    1.347426] Want set pclk rate(348000000) support(1392000000) real(1392000000)
                                                        [    1.355565] Want set mclk rate(348000000) support(348000000) real(348000000)
                                                        [    1.363493] npu[1][1] This device support 64bits DMA
                                                        [    1.369642] npu[1][1] core_0, request irqline=290, name=vipcore_0
                                                        [    1.376784] npu[1][1] =======vipcore parameter=====
                                                        [    1.382246] npu[1][1] registerMemBase     0x03050000,
                                                        [    1.388068] npu[1][1] registerMemSize     0x00020000,
                                                        [    1.393815] npu[1][1] irqLine             0x00000122,
                                                        [    1.399597] npu[1][1] contiguousSize      0x02000000
                                                        [    1.405150] npu[1][1] contiguousBase      0x30000000
                                                        [    1.410780] npu[1][1] vipContiguousBase   0x0
                                                        [    1.415688] npu[1][1] drvType             0x00000000
                                                        [    1.421238] npu[1][1] AXISramSize         0x00000000
                                                        [    1.426815] npu[1][1] AXISramBaseAddress  0x00000000
                                                        [    1.432364] npu[1][1] VIPSramSize         0x00020000
                                                        [    1.437930] npu[1][1] VIPSramBaseAddress  0x00400000
                                                        [    1.443481] npu[1][1] sysHeapSize         0x00200000
                                                        [    1.449044] npu[1][1] ===============================
                                                        [    1.454779] npu[1][1] VIPLite driver version 1.8.0.0-AW-2022-04-21
                                                        [    1.462924] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
                                                        [    1.469436] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (-1)
                                                        [    1.476135] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator.
                                                        [    1.483439] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null))
                                                        [    1.490798] sunxi-wlan soc@03000000:wlan@0: request pincrtl handle for device [soc@03000000:wlan@0] failed
                                                        [    1.501739] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=134  mul-sel=1  pull=1  drv_level=2  data=0
                                                        [    1.512335] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
                                                        [    1.519414] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=135  mul-sel=14  pull=1  drv_level=2  data=0
                                                        [    1.530448] sunxi-wlan soc@03000000:wlan@0: clk_name ()
                                                        [    1.538532] libphy: Fixed MDIO Bus: probed
                                                        [    1.544751] sunxi gmac driver's version: 2.0.2
                                                        [    1.552181] Failed to alloc md5
                                                        [    1.555820] eth0: Use random mac address
                                                        [    1.560657] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                                                        [    1.568748] get ehci0-controller, regulator_io is no nocare
                                                        [    1.574991] get ehci0-controller wakeup-source is fail.
                                                        [    1.581115] sunxi ehci0-controller don't init wakeup source
                                                        [    1.587488] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a5daf0, 0x:c4872000, irq_no:130
                                                        [    1.599593] [sunxi-ehci0]: Not init ehci0
                                                        [    1.604554] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                                                        [    1.612094] get ohci0-controller, regulator_io is no nocare
                                                        [    1.618421] get ohci0-controller wakeup-source is fail.
                                                        [    1.624437] sunxi ohci0-controller don't init wakeup source
                                                        [    1.630849] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a5dd14
                                                        [    1.640567] [sunxi-ohci0]: Not init ohci0
                                                        [    1.645790] usbcore: registered new interface driver uas
                                                        [    1.652156] usbcore: registered new interface driver usb-storage
                                                        [    1.659174] usbcore: registered new interface driver ums-alauda
                                                        [    1.666141] usbcore: registered new interface driver ums-cypress
                                                        [    1.673166] usbcore: registered new interface driver ums-datafab
                                                        [    1.680224] usbcore: registered new interface driver ums_eneub6250
                                                        [    1.687551] usbcore: registered new interface driver ums-freecom
                                                        [    1.694559] usbcore: registered new interface driver ums-isd200
                                                        [    1.701450] usbcore: registered new interface driver ums-jumpshot
                                                        [    1.708606] usbcore: registered new interface driver ums-karma
                                                        [    1.715526] usbcore: registered new interface driver ums-onetouch
                                                        [    1.722674] usbcore: registered new interface driver ums-realtek
                                                        [    1.729682] usbcore: registered new interface driver ums-sddr09
                                                        [    1.736644] usbcore: registered new interface driver ums-sddr55
                                                        [    1.743558] usbcore: registered new interface driver ums-usbat
                                                        [    1.750341] usb_serial_number:20080411
                                                        [    1.755652] sunxi_gpadc_init,1949, success
                                                        [    1.760678] sunxi_gpadc_setup: get channel scan data failed
                                                        [    1.768529] input: sunxi-gpadc0 as /devices/virtual/input/input0
                                                        [    1.777850] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
                                                        [    1.784740] sunxi-rtc rtc: RTC enabled
                                                        [    1.789371] fix to cold boot, save boot reason
                                                        [    1.794778] i2c /dev entries driver
                                                        [    1.799819] usbcore: registered new interface driver uvcvideo
                                                        [    1.806662] USB Video Class driver (1.1.1)
                                                        [    1.811262] sunxi cedar version 0.1
                                                        [    1.815417] VE: install start!!!
                                                        [    1.815417]
                                                        [    1.820845] VE: cedar-ve the get irq is 291
                                                        [    1.825746] VE: regs_csi = c48ab000
                                                        [    1.830352] VE: ve_debug_proc_info:c0a61300, data:c3bd8000, lock:c0a61388, flag: 1
                                                        [    1.830352]
                                                        [    1.840842] VE: install end!!!
                                                        [    1.840842]
                                                        [    1.846476] google_vp9: sunxi google vp9 version 0.1
                                                        [    1.854931] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
                                                        [    1.864739] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
                                                        [    1.872369] Bluetooth: HCI UART protocol H4 registered
                                                        [    1.878256] Bluetooth: HCI H4 protocol initialized
                                                        [    1.883870] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
                                                        [    1.891724] bt_fdi debugfs_init
                                                        [    1.897399] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 900000 KHz
                                                        [    1.935321] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 912000 KHz
                                                        [    1.945642] cpuidle: enable-method property 'psci' found operations
                                                        [    1.955637] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
                                                        [    1.964613] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
                                                        [    1.970250] sunxi-mmc sdc0: No vmmc regulator found
                                                        [    1.975861] sunxi-mmc sdc0: No vqmmc regulator found
                                                        [    1.981422] sunxi-mmc sdc0: No vdmmc regulator found
                                                        [    1.987072] sunxi-mmc sdc0: No vd33sw regulator found
                                                        [    1.992731] sunxi-mmc sdc0: No vd18sw regulator found
                                                        [    1.998426] sunxi-mmc sdc0: No vq33sw regulator found
                                                        [    2.004082] sunxi-mmc sdc0: No vq18sw regulator found
                                                        [    2.010401] sunxi-mmc sdc0: set host busy
                                                        [    2.015006] sunxi-mmc sdc0: Got CD GPIO
                                                        [    2.019880] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.203044] random: fast init done
                                                        [    2.275310] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
                                                        [    2.305277] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.345480] sunxi-mmc sdc0: detmode:gpio irq
                                                        [    2.350548] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
                                                        [    2.360066] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
                                                        [    2.369448] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
                                                        [    2.378820] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
                                                        [    2.388187] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
                                                        [    2.397550] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
                                                        [    2.407228] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
                                                        [    2.416208] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
                                                        [    2.421522] sunxi-mmc sdc1: No vmmc regulator found
                                                        [    2.427025] sunxi-mmc sdc1: No vqmmc regulator found
                                                        [    2.432585] sunxi-mmc sdc1: No vdmmc regulator found
                                                        [    2.438160] sunxi-mmc sdc1: No vd33sw regulator found
                                                        [    2.443816] sunxi-mmc sdc1: No vd18sw regulator found
                                                        [    2.449486] sunxi-mmc sdc1: No vq33sw regulator found
                                                        [    2.455142] sunxi-mmc sdc1: No vq18sw regulator found
                                                        [    2.461433] sunxi-mmc sdc1: set host busy
                                                        [    2.466070] mmc:failed to get gpios
                                                        [    2.470384] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.480844] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
                                                        [    2.515260] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.555306] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.565593] sunxi-mmc sdc1: detmode:manually by software
                                                        [    2.567176] usbcore: registered new interface driver usbhid
                                                        [    2.567180] usbhid: USB HID core driver
                                                        [    2.567276] fbtft_of_value: buswidth = 8
                                                        [    2.567282] fbtft_of_value: debug = 0
                                                        [    2.567286] fbtft_of_value: rotate = 0
                                                        [    2.567289] fbtft_of_value: fps = 60
                                                        [    2.646101] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
                                                        [    2.652882] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
                                                        [    2.658909] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.687732] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.717118] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    2.723789] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    2.730483] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    2.737163] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    2.743023] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.766306] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.785293] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
                                                        [    2.815232] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.866316] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
                                                        [    2.873351] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
                                                        [    2.879334] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.907825] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.937374] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    2.944312] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    2.951276] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    2.958247] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    2.964113] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                                        [    2.986299] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.005335] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
                                                        [    3.035226] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.086847] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
                                                        [    3.094418] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
                                                        [    3.100400] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.128050] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.157953] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    3.165424] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    3.172888] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    3.180368] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    3.186250] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.206325] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.235314] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
                                                        [    3.265229] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.318449] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
                                                        [    3.327613] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
                                                        [    3.333574] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.358816] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.379226] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    3.388510] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    3.397690] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    3.405693] Console: switching to colour frame buffer device 30x30
                                                        [    3.413281] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
                                                        [    3.413347] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                                        [    3.431401] graphics fb0: fb_st7789v frame buffer, 240x240, 112 KiB video memory, 4 KiB DMA buffer memory, fps=100, spi0.0 at 100 MHz
                                                        [    3.454628] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
                                                        [    3.466670] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec <-> soc@03000000:codec_plat mapping ok
                                                        [    3.480966] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai <-> 2032000.daudio0_plat mapping ok
                                                        [    3.495974] NET: Registered protocol family 10
                                                        [    3.503283] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
                                                        [    3.511567] NET: Registered protocol family 17
                                                        [    3.517071] NET: Registered protocol family 15
                                                        [    3.522216] Bluetooth: RFCOMM TTY layer initialized
                                                        [    3.527882] Bluetooth: RFCOMM socket layer initialized
                                                        [    3.533666] Bluetooth: RFCOMM ver 1.11
                                                        [    3.539306] Registering SWP/SWPB emulation handler
                                                        [    3.555025] UBI error: cannot open mtd sys, error -2get det_vbus is fail, 84
                                                        [    3.563897] get id is fail, 84
                                                        [    3.568781] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:53 UTC (53)
                                                        [    3.578425] clk: Not disabling unused clocks
                                                        [    3.583238] ALSA device list:
                                                        [    3.586705]   #0: audiocodec
                                                        [    3.589932]   #1: snddaudio0
                                                        [    3.593624] List of all partitions:
                                                        [    3.597655] No filesystem could mount root, tried:  ubifs
                                                        [    3.603736] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                                                        [    3.612985] CPU: 0 PID: 1 Comm: swapper Not tainted 4.9.191 #8
                                                        [    3.619502] Hardware name: sun8iw21
                                                        [    3.623432] [<c010d5a0>] (unwind_backtrace) from [<c010a694>] (show_stack+0x10/0x14)
                                                        [    3.632098] [<c010a694>] (show_stack) from [<c017050c>] (panic+0xac/0x2b8)
                                                        [    3.639793] [<c017050c>] (panic) from [<c09012cc>] (mount_block_root+0x258/0x300)
                                                        [    3.648165] [<c09012cc>] (mount_block_root) from [<c0901500>] (prepare_namespace+0x118/0x178)
                                                        [    3.657702] [<c0901500>] (prepare_namespace) from [<c0900eb4>] (kernel_init_freeable+0x144/0x178)
                                                        [    3.667627] [<c0900eb4>] (kernel_init_freeable) from [<c066134c>] (kernel_init+0x8/0x118)
                                                        [    3.676783] [<c066134c>] (kernel_init) from [<c0106e08>] (ret_from_fork+0x14/0x2c)
                                                        [    3.685257] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                                                        [    3.695366] sunxi dump enabled
                                                        [    3.698774] dump regs done
                                                        [    3.701828] flush cache done
                                                        [    3.705061] crashdump enter
                                                        请问我这个切换spinand启动不了文件系统是什么问题呢,另外为啥有emmc的打印呢,storage type已经改成5了,我的spinand容量是256M,求助各位老板
                                                        Q 1 条回复 最后回复 回复 引用 分享 0
                                                        • Q
                                                          qqfshendu LV 2 @daMing123 最后由 编辑
                                                          @daming123 大佬,用的是SPI nand,打印log和你的几乎一样,请教下是什么解决的呢,谢谢
                                                          • Q
                                                            qqfshendu LV 2 @away123456 最后由 编辑
                                                            @away123456 您这个解决了吗?我切换到SPI nand,log和你的很类似,不知道哪里有问题
                                                            • Refee
                                                              Refee LV 7 最后由 编辑
                                                              赞一个先,非常详细!学习中……
                                                              • X
        XREF0 LV 3 最后由 编辑
        非常棒的资料 T113s3跟着搞好了 norflash
        radxiaohe 1 条回复 最后回复 回复 引用 分享 0
        away123456 LV 4 @qqfshendu 最后由 编辑
        @qqfshendu 我没解决呀,你解决了吗,感觉原厂的就有问题
        lztmfx LV 5 最后由 编辑
        D1S/F133默认nand,sd,都是ubi只读文件系统,想要TF卡为EXT4文件系统,buildroot取消squashfs,选ext4后uboot就报错找不到分区了,uboot和kernel都选好了ext4,还是不行,还要修改什么地方?
        P 1 条回复 最后回复 回复 引用 分享 0
        sundaygeek LV 2 最后由 编辑
        • radxiaohe
        radxiaohe LV 5 @XREF0 最后由 编辑
        @xref0 你好,请问T113-s要怎么配置,用longan SDK可以调试出来吗?
        ljtty LV 2 最后由 编辑
        码住了 666
        • P
        pippinliu LV 2 @lztmfx 最后由 编辑
        @lztmfx 👍 👍 👍 👍 👍 👍
        • P
        pippinliu LV 2 最后由 编辑
        非常不错,非常不错,顶!
        shaofan_126 LV 4 最后由 编辑
        HelloWorld_666 LV 2 最后由 编辑
        非常详细,已收藏,后续慢慢学习
        liux_pro LV 3 最后由 编辑
        怎么看自己的tina版本呢?拉的d1的sdk,从分支名里看像是2.0版本?这个是tina版本吗?是不是不适用本文了
