    T113-S3 Mango MQ-R Wi-Fi 8723ds 问题
      hongduc10 LV 2 最后由 编辑
      硬件: Mango MQ-R (T113-S)
      系统 (build): Ubuntu 20.04
      源码: https://github.com/mangopi-sbc/Tina-Linux
      我用sd卡给MQ-R编译了一个image。 Uboot 和 linux kernel 还可以, 可是wifi驱动好像有点儿问题。求助!!
      [    4.289071]
      [    4.289071] insmod_device_driver
      [    4.289071]
      [    4.296259] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    4.308389] device_chose finished 142!
      [    5.337257] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [    5.351091] devtmpfs: mounted
      [    5.356314] Freeing unused kernel memory: 1024K
      [    5.369217] Run /pseudo_init as init process
      [    5.803127] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
      [    5.828283] EXT4-fs (mmcblk0p7): mounted filesystem with journalled data mode. Opts: data=journal
      [    6.324846] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
      insmod: can't insert '/lib/modules/5.4.61/usb-storage.ko': No such file or directory
      [    6.356485] sunxi_gpadc_init,2151, success
      [    6.361459] sunxi_gpadc_setup: get channel scan data failed
      [    6.368056] input: sunxi-gpadc0 as /devices/virtual/input/input1
      [    6.505790] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [    6.612949] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      ------run rc.final file-----
      mount: mounting /dev/mmcblk0p1 on /mnt/extsd failed: No such file or directory
      下边是全 kernel 记录:
      kernel.log
      • G
        gonboy LV 5 最后由 编辑
        楼主哪里买的是 板载 8723ds。
        我买的是8189ftv,。
        能否提供个购买链接?
        S 1 条回复 最后回复 回复 引用 分享 0
          skyshine LV 6 @gonboy 最后由 编辑
          @gonboy 现在芒果的店里应该不卖了,到闲鱼上找找应该有
