Navigation
    • Register
    • Login
    • Search
    • Categories
    • Tags
    [LCD][kernel] 亮屏后立马黑屏
    264
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • RayZhang
      RayZhang LV 5 last edited by
      Hello all,
      • 芯片:R818
      • 系统:TINA 2.0
      • LCD屏幕型号: k101im2byl02l
      • 背景:之前我们的产品用 TINA 0.2 可以使用,目前想要迁移到 TINA 2.0 看看是否能够解决显示的其他问题
      • 现象: 经过 uboot 和 kernel 的适配, 进入 uboot 和 kernel 可以看到画面,但是过了一会儿屏幕就灭了。
      • 尝试的排查方法:DE截屏(echo /a.bmp > /sys/class/disp/disp/attr/capture_dump) 能够获取到黑屏前的画面
      • 参考资料:《Tina Linux LCD v1.1 (2020.03.06 版本)》
      • 附件1:我们目前的 board.dts 文件
      • 附件2:r818B/configs/evb1/sys_config.fex
      • 附件3:屏显现象: 显示 color bar 后屏幕熄灭
      先谢谢各位大佬了😊
      W A 2 Replies Last reply Reply Quote Share 0
        whycan晕哥 LV 9 @RayZhang last edited by
        @rayzhang
        背光正常吗?
        RayZhang 1 Reply Last reply Reply Quote Share 0
          anruliu LV 6 @RayZhang last edited by
          @rayzhang
          1、确认是哪个阶段后黑屏的,内核加载disp驱动后?
          2、colorbar是什么时候显示的?到内核后执行命令显示的?
          3、确认黑屏状态背光是否有,屏供电是否有,lcd的各gpio是否正常
          4、开机后尝试休眠唤醒lcd,看能否点亮
          mount -t debugfs none /sys/kernel/debug
          cd /sys/kernel/debug/dispdbg
          //休眠
          echo suspend > command; echo disp0 > name; echo 1 > start
          //唤醒
          echo resume > command; echo disp0 > name; echo 1 > start
          1 Reply Last reply Reply Quote Share 1
          • RayZhang
            RayZhang LV 5 @whycan last edited by
            hello @whycan
            查看了一下
            root@TinaLinux:/# cat /sys/kernel/debug/pwm
            platform/7020c00.pwm, 1 PWM device
             pwm-0   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
            platform/300a000.pwm, 16 PWM devices
             pwm-0   (lcd                 ): requested enabled period: 20000 ns duty: 3984 ns polarity: inverse
             pwm-1   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-2   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-3   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-4   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-5   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-6   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-7   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-8   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-9   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-10  ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-11  ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-12  ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-13  ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-14  ((null)              ): period: 0 ns duty: 0 ns polarity: normal
             pwm-15  ((null)              ): period: 0 ns duty: 0 ns polarity: normal
            根据《Tina Linux LCD v1.1 (2020.03.06 版本)》, 上面的“requested enabled”表示请求并且使能了,但是 polarity: inverse不知道有没有问题?
            • RayZhang
              RayZhang LV 5 @RayZhang last edited by RayZhang
              hello @anruliu
              1. 确认是哪个阶段后黑屏的,内核加载disp驱动后?
                --> 我看代码有 pr_info("[DISP]%s\n", __func__); 不过开机后, dmesg 没有看到 dev_disp.c的代码。休眠唤醒后 dmesg | grep -i disp 才能看到相关代码。
              2. colorbar是什么时候显示的?到内核后执行命令显示的?
                --> 开头的视频我没有执行任何操作,只是单纯的系统启动。 colorbar 是因为 kernel_menuconfig 的时候配置了CONFIG_DISP2_SUNXI_BOOT_COLORBAR=y
                后来我找到了相关代码在 drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 的 disp_draw_colorbar 函数,所以 按道理,这时候 disp驱动已经被加载到 kernel 了吧?
              --> 楼上我贴了 cat /sys/kernel/debug/pwm , 不知道 polarity: inverse 之类的有没有问题呢?
              (PS1: 休眠唤醒后发现 一直都是 polarity: inverse )
              (PS2: 休眠唤醒并且正常显示 COLORBAR 的状态时候, 用 brightnesstester 程序,发现brightness数值大小和实际效果是正相关的,说明这时候 背光 应该是 OK的?)
              --> 非常神奇的是,唤醒 后, 屏幕就正常亮了~ 并且使用 echo X > /sys/class/disp/disp/attr/colorbar 命令(X: 0~8),可以 显示不同的图像出来。
              所以现在不知道是什么原因,手动休眠唤醒LCD就可以了? 这是什么原理呢?
              多谢多谢😳
              A 1 Reply Last reply Reply Quote Share 0
                @rayzhang 可以用示波器量下黑屏那一刻,屏的各gpio有没有什么变化,电有没有变化。比较常见的是开机过程中rest被拉低了
                RayZhang 1 Reply Last reply Reply Quote Share 1
                • RayZhang
                  RayZhang LV 5 @anruliu last edited by
                  hello @anruliu , 请教一下整个显示流程哪个步骤会拉低RESET呢? 我们现在是手头上没有示波器这些硬件调试手段 😧 😧 😧
                  PS1: 现在 uboot 阶段偶尔不亮屏幕
                  PS2: 休眠唤醒lcd 一定能够亮起屏幕
                  PS3: 我们现在手头上的源码(tina 2.0) 信息如下,应该不会有问题吧?
                  # repo forall -c "pwd; git log --oneline;echo;echo"
                  /works/to-download/build
                  9677096 smartx-r818-tina-v2.0-release release
                  11276aa smartx-r818-tina-v1.0.0-release release
                  0aee083 smartx-r818-tina-v0.2.0-release release
                  /r818/config
                  b9b4e3e smartx-r818-tina-v1.0.0-release release
                  c265e5d smartx-r818-tina-v0.2.0-release release
                  /r818/device/config/chips/r818
                  961a3d9 [fix] 适配产品,可以 烧写并 adb shell
                  7667829 smartx-r818-tina-v2.0-release release
                  /r818/device/config/common
                  d3d5e39 smartx-r818-tina-v1.0.0-release release
                  a76bf10 smartx-r818-tina-v0.2.0-release release
                  /r818/dl
                  6b687c4 remove unused package
                  1819cd9 smartx-r818-tina-v1.0.0-release release
                  0e5a144 smartx-r818-tina-v0.2.0-release release
                  /r818/docs
                  e4127ef smartx-r818-tina-v0.2.0-release release
                  /r818/lichee/arisc
                  c357572 smartx-r818-tina-v2.0-release release
                  589bc39 smartx-r818-tina-v1.0.0-release release
                  bfc598f smartx-r818-tina-v0.2.0-release release
                  /r818/lichee/brandy-2.0/spl
                  0ca0957 smartx-r818-tina-v2.0-release release
                  0f2b788 smartx-r818-tina-v1.0.0-release release
                  9ab7078 smartx-r818-tina-v0.2.0-release release
                  /r818/lichee/brandy-2.0/tools
                  3f0f997 smartx-r818-tina-v1.0.0-release release
                  77e0592 smartx-r818-tina-v0.2.0-release release
                  /r818/lichee/brandy-2.0/u-boot-2018
                  5ec57ef [fix] 勾选 LCD_SUPPORT_K101IM2BYL02L
                  e568104 smartx-r818-tina-v2.0-release release
                  9b56363 smartx-r818-tina-v1.0.0-release release
                  44e5477 smartx-r818-tina-v0.2.0-release release
                  /r818/lichee/linux-4.9
                  8a99727f0 [feature]添加 k101im2byl02l 屏幕显示驱动
                  8b9cb8723 smartx-r818-tina-v2.0-release release
                  352550f19 smartx-r818-tina-v1.0.0-release release
                  842f0db32 smartx-r818-tina-v0.2.0-release release
                  /r818/package
                  38e46ac3 smartx-r818-tina-v2.0-release release
                  04e65073 remove unused package
                  667cc61e smartx-r818-tina-v1.0.0-release release
                  047ce9bd smartx-r818-tina-v0.2.0-release release
                  /r818/prebuilt
                  d771fad smartx-r818-tina-v0.2.0-release release
                  /r818/scripts
                  37ecb36 smartx-r818-tina-v2.0-release release
                  984d79d smartx-r818-tina-v1.0.0-release release
                  1c87d6c smartx-r818-tina-v0.2.0-release release
                  /r818/target
                  50cf978 smartx-r818-tina-v2.0-release release
                  b804823 defconfig:remove unused info
                  7a1879a smartx-r818-tina-v1.0.0-release release
                  8582b0c smartx-r818-tina-v0.2.0-release release
                  /r818/toolchain
                  9f90325 smartx-r818-tina-v0.2.0-release release
                  /r818/tools
                  48b4556 smartx-r818-tina-v2.0-release release
                  936113f smartx-r818-tina-v1.0.0-release release
                  a4745b7 smartx-r818-tina-v0.2.0-release release
                  • Referenced by  RayZhang RayZhang
                  Copyright © 2022 深圳全志在线有限公司 粤ICP备2021084185号 粤公网安备44030502007680号
