    V851S Tina 错误的 libAWIspApi 生成文件
    makefile v851s libawispapi
    • kanken6174
      kanken6174 LV 6 最后由 编辑
      当尝试编译 libAWIspApi 时,您可能会收到编译错误,make 抱怨“all”目标没有构建候选者,这是因为 libAWIspApi makefile 不正确(或者我认为是这样),而不是这样:
      /tina-v853-open/openwrt/openwrt/package/subpackage/allwinner/vision/libAWIspApi/Makefile
      include $(TOPDIR)/rules.mk
      -include machinfo/$(LICHEE_IC)/build.mk
      PKG_NAME:=libAWIspApi
      PKG_VERSION:=1
      PKG_RELEASE:=1
      PKG_BUILD_DIR := $(BUILD_DIR)/$(PKG_NAME)
      include $(INCLUDE_DIR)/package.mk
      define Package/$(PKG_NAME)
        SUBMENU:=Vision
        SECTION:=allwinner
        CATEGORY:=Allwinner
        TITLE:=camera VIN ISP api for Allwinner
      endef
      define Package/$(PKG_NAME)/description
        camera VIN ISP api for allwinner
      endef
      define Build/Prepare
      	$(INSTALL_DIR) $(PKG_BUILD_DIR)/src
      	$(CP) ./src/$(ISP_DIR)/* $(PKG_BUILD_DIR)/src
      endef
      define Build/Compile
      	$(MAKE) -C $(PKG_BUILD_DIR)/src\
      		ARCH="$(TARGET_ARCH)" \
      		AR="$(TARGET_AR)" \
      		CC="$(TARGET_CC)" \
      		CXX="$(TARGET_CXX)" \
      		CFLAGS="$(TARGET_CFLAGS)" \
      		LDFLAGS="$(TARGET_LDFLAGS)" \
      		INSTALL_PREFIX="$(PKG_INSTALL_DIR)" \
      		C_LIB_TYPE="$(CONFIG_LIBC)$(if $(CONFIG_EXT_TOOLCHAIN_GCC_8_3_0),-gcc8_3_0)" \
      		CPU_VARIANT="$(TARGET_CPU_VARIANT)$(if $(CONFIG_COMPLILE_KERNEL64_USER32),-user-32bit)" \
      		all
      endef
      define Build/InstallDev
      	$(INSTALL_DIR) $(1)/usr/lib
      	$(INSTALL_DIR) $(1)/usr/include
      	$(CP) $(PKG_INSTALL_DIR)/usr/lib/* $(1)/usr/lib/
      	$(CP) $(PKG_INSTALL_DIR)/usr/include/* $(1)/usr/include/
      endef
      define Package/$(PKG_NAME)/install
      	$(INSTALL_DIR) $(1)/usr/lib/
      	$(INSTALL_BIN) $(PKG_INSTALL_DIR)/usr/lib/* $(1)/usr/lib/
      endef
      $(eval $(call BuildPackage,$(PKG_NAME)))
      它应该是这样的:
      PKG_VERSION:=1
      PKG_RELEASE:=1
        SUBMENU:=Vision
        SECTION:=allwinner
        CATEGORY:=Allwinner
      endef
      endef
      	$(INSTALL_DIR) $(PKG_BUILD_DIR)/src/isp600
      	$(CP) ./src/isp600/$(ISP_DIR)/* $(PKG_BUILD_DIR)/src/isp600
      endef
      	$(MAKE) -C $(PKG_BUILD_DIR)/src/isp600\
      		AR="$(TARGET_AR)" \
      		CC="$(TARGET_CC)" \
      		all
      endef
      endef
      endef
      这对我有用。
      H 1 条回复 最后回复 回复 引用 分享 2
        HEchunmu LV 3 @kanken6174 最后由 编辑
        @kanken6174 对我也有用 感谢分享
