    YuziKi X 100ask v851s开发板运行sample_odet_demo报错
      lw409309740 LV 3 最后由 q1215200171 编辑
      报错log如下所示:
      root@TinaLinux:/mnt/extsd# ./sample_odet_demo -path sample_odet_demo.conf
      main line 2173, run start!
      I0101 00:18:39.230742  1016 sample_odet_demo.c:1976]        <ParseCmdLine> path:[./sample_o[  118.019788] npu[3f8][3f8] vipcore, device init..
      det_demo], arg number is [3]
      I0[  118.026439] set_vip_power_clk ON
      101 00:18:39.246284  1016 confpa[  118.034960] enter aw vip mem alloc size 7340032
      rser.c:60]                                                  <createConfParser> load conf file sample_odet_demo.conf ok!
      I0101 00:18:39[  118.046650] aw_vip_mem_alloc vir 0xc5801000, phy 0x48800000
      .246582  1016 sample_odet_demo.c[  118.055527] npu[3f8][3f8] gckvip_drv_init  kernel logical phy address=0x48800000  virtual =0xc5801000
      :2115]                                                      <loadSampleConfig> mValid:1,mDevNum:0,mCaptureWidth:1920,mCaptureWidth:1080,mDisplayX:0,mDisplayY:0,mDisplayWidth:1920,mDisplayHeight:1080,mLayerNum:0,mEncodeType:265
      [0xb6f8e560]vip_init[104],
      The version of Viplite is: 1.8.0-0-AW-2022-04-21
      Create Neural Network: 243.82ms or 243819.75us
      mpp_init line 238, run start!
      I0101 00:18:39.545331  1016 mpi_sys.c:842]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      modName : MPP-Platform
      tag   : V1.0 Release
      branch: v5-dev
      commit: 4eed413532ad87725895a8cb1ba75e22fc328233
      date  : 20170725
      author: jenkins
      iniparser: cannot open /etc/cedarx.conf
      iniparser: cannot open /vendor/etc/cedarx.conf
      I0101 00:18:39.560858  1016 mpi_sys.c:1455]                 <AW_MPI_SYS_Init> ISP init
      I0101 00:18:39.561202  1016 isp_version.h:39]               <isp_version_info> [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
      IPCORE: ISP600
      branch: libisp-dev
      commit: 5b30d9b8f8190196d863bc91576af5356022b433
      date  : Thu Jan 25 17:23:23 2024 +0800
      I0101 00:18:39.561392  1016 mpi_sys.c:1457]                 <AW_MPI_SYS_Init> ISP init done
      I0101 00:18:39.574484  1016 hwdisplay.c:84]                 <hw_display_init>
      I0101 00:18:39.574779  1016 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
      I0101 00:18:39.574992  1016 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
      I0101 00:18:39.693602  1016 audio_hw.c:189]                 <MakeAllMixerElemsAvailable> pcm open and close, all MixerElems maybe exist.
      I0101 00:18:39.693855  1016 alsa_interface.c:712]           <alsaOpenMixer> open mixer:hw:0
      I0101 00:18:39.696277  1016 alsa_interface.c:767]           <alsaOpenMixer> set playback vol_val to value: 27
      I0101 00:18:39.696869  1016 alsa_interface.c:712]           <alsaOpenMixer> open mixer:hw:1
      mpp_init line 251, run finish!
      run_project line 1765, run start!
      I0101 00:18:39.698172  1016 hwdisplay.c:1248]               <hwd_get_disp_type> Current the  disp_type:0x1  tv_mode:0x0
      config_vipp_display2_vo line 1504, run start!
      config_vipp_display2_vo line 1527, vipp[4] vir_chn[0] creating.
      I0101 00:18:39.698513  1016 video.c:107]                    <video_init> [ISP]video device name is vin_video4
      I0101 00:18:39.698742  1016 isp_dev.c:566]                  <isp_video_open> [ISP]open video device[4], detect isp0 success!
      I0101 00:18:39.701278  1016 videoInputHw.c:1162]            <videoInputHw_SetChnAttr> ViCh[4], user set disable Encpp
      I0101 00:18:39.701599  1020 mpi_sys.c:1073]                 <MonitorEnvVarThread> detect user environment:
      I0101 00:18:39.701785  1020 mpi_sys.c:1074]                 <MonitorEnvVarThread> /tmp/mpp_log_level
      I0101 00:18:39.701886  1020 mpi_sys.c:1075]                 <MonitorEnvVarThread> /tmp/mpp_venc_sei_config_param
      I0101 00:18:39.958331  1016 isp_dev.c:390]                  <isp_tdm_open> [ISP]tdm_rx device name is sunxi_tdm_rx.0
      W0101 00:18:39.958589  1016 isp_dev.c:435]                  <isp_dev_open> [ISP_WARN]ISP0 maybe online mode, ignore tdm open failed.
      I0101 00:18:39.959290  1016 isp_dev.c:460]                  <isp_dev_open> [ISP]open isp device[0] success!
      E0101 00:18:39.959491  1016 isp_dev.c:956]                  <isp_sensor_get_configs> [ISP_ERR]gc2053_mipi get config failed: Invalid argument (22).
      W0101 00:18:39.966597  1016 isp_helper.c:106]               <isp_ctx_save_init> [ISP_WARN]open /mnt/extsd/isp0_0_0_0_0_gc2053_mipi_ctx_saved.bin failed, err:No such file or directory.
      I0101 00:18:39.966919  1016 isp_ini_parse.c:1650]           <parser_ini_info> [ISP]prefer isp config: [gc2053_mipi], 0x0, 0, 0, 0
      W0101 00:18:39.967132  1016 isp_ini_parse.c:1669]           <parser_ini_info> [ISP_WARN]cannot find gc2053_mipi_0_0_0_0_0 isp config, use gc2053_mipi_1920_1088_20_0_0 -> [gc2053_mipi_isp600_20220511_164617_vlc4_day]
      E0101 00:18:39.995799  1016 isp_manage.c:2575]              <isp_ctx_config_init> [ISP_ERR]sensor attribute is not init.
      I0101 00:18:39.996153  1016 isp.c:1235]                     <isp_run> [ISP]create isp0 server thread!
      E0101 00:18:39.996912  1019 isp_dev.c:956]                  <isp_sensor_get_configs> [ISP_ERR]gc2053_mipi get config failed: Invalid argument (22).
      W0101 00:18:39.997147  1019 videoInputHw.c:6258]            <VideoInputHw_CapThread> fatal error! Get isp[0] sensor information failed! must be called AW_MPI_ISP_Run before AW_MPI_VI_EnableVipp.
      I0101 00:18:40.009335  1019 videoInputHw.c:6297]            <VideoInputHw_CapThread> EnableVipp[4]: vfmt.bufs:5, online:0
      I0101 00:18:40.049559  1016 videoInputHw.c:1316]            <videoInputHw_ChnEnable> receive enable vipp[4] reply: 0x0!
      I0101 00:18:40.050488  1016 hwdisplay.c:1121]               <hwd_layer_request_hlay> hlay:4, zorder=4, cnt:2
      I0101 00:18:40.051195  1016 mpi_vo.c:1038]                  <AW_MPI_VO_SetVideoLayerAttr> ch[1]lyl[0]:dispRect changed, [0, 0, 320x240]->[0, 0, 1280x720]
      I0101 00:18:40.051388  1016 hwdisplay.c:409]                <hwd_layer_set_rect> ch[1]lyl[0]: screen_win[0,0, 1280x720]
      open /dev/sunxi_soc_info failed!config_vipp_display2_vo line 1638, create vo channel[0] success!
      I0101 00:18:40.052093  1016 mpi_vo.c:1086]                  <AW_MPI_VO_SetVideoLayerPriority> layer[4] priority changed [4]->[11]
      config_vipp_display2_vo line 1685, run finish!
      npu_worker_thread line 1750, run start!
      npu_config_and_run line 829, run start!
      npu_config_and_run line 852, vipp[8] vir_chn[0] creating.
      I0101 00:18:40.053192  1024 video.c:107]                    <video_init> [ISP]video device name is vin_video8
      I0101 00:18:40.053476  1024 isp_dev.c:566]                  <isp_video_open> [ISP]open video device[8], detect isp0 success!
      I0101 00:18:40.053797  1024 video.c:1063]                   <video_set_isp_bk_buffer_align> [ISP]video_set_isp_bk_buffer_align yuv_align_en = 1, lbc_align_en = 0
      E0101 00:18:40.053948  1024 video.c:1065]                   <video_set_isp_bk_buffer_align> [ISP_ERR]video8 video_set_isp_bk_buffer_align failed!!!
      I0101 00:18:40.054063  1024 videoInputHw.c:1162]            <videoInputHw_SetChnAttr> ViCh[8], user set disable Encpp
      I0101 00:18:40.054779  1016 isp_ini_parse.c:1650]           <parser_ini_info> [ISP]prefer isp config: [gc2053_mipi], 0x0, 0, 0, 0
      W0101 00:18:40.054992  1016 isp_ini_parse.c:1669]           <parser_ini_info> [ISP_WARN]cannot find gc2053_mipi_0_0_0_0_0 isp config, use gc2053_mipi_1920_1088_20_0_0 -> [gc2053_mipi_isp600_20220511_164617_vlc4_day]
      E0101 00:18:40.055700  1016 isp_manage.c:2575]              <isp_ctx_config_init> [ISP_ERR]sensor attribute is not init.
      venc_recorder_thread line 1734, run start!
      config_venc_channel line 1872, run start!
      I0101 00:18:40.056094  1025 sample_odet_demo.c:1882]        <config_venc_channel> VeAttr.Type:265
      config_venc_channel line 1944, run finish!
      venc_channel_run line 1254, run start!
      venc_channel_run line 1277, vipp[0] vir_chn[0] creating.
      I0101 00:18:40.056409  1025 video.c:107]                    <video_init> [ISP]video device name is vin_video0
      I0101 00:18:40.056663  1025 isp_dev.c:566]                  <isp_video_open> [ISP]open video device[0], detect isp0 success!
      I0101 00:18:40.056906  1025 videoInputHw.c:1162]            <videoInputHw_SetChnAttr> ViCh[0], user set disable Encpp
      E0101 00:18:40.226480  1021 isp_dev.c:274]                  <isp_stat_process_buffer> [ISP_ERR]AEWB: stats error, skipping buffer.
      E0101 00:18:40.228073  1019 isp_dev.c:956]                  <isp_sensor_get_configs> [ISP_ERR]gc2053_mipi get config failed: Invalid argument (22).
      I0101 00:18:40.228429  1023 video_render_linux.cpp:224]     <vr4l_init> mDisplayFormat[0x101], new CedarXNativeRenderer
      I0101 00:18:40.228585  1023 CedarXNativeRenderer.cpp:176]   <CedarXNativeRenderer> hwc disp fmt[0x62], color space:260
      I0101 00:18:40.228716  1023 hwdisplay.c:240]                <hwd_layer_set_src> x: 0, y: 0, width: 0x500, height: 0x2d0
      I0101 00:18:40.228816  1023 hwdisplay.c:247]                <hwd_layer_set_src> width: 0x50000000000, height: 0x2d000000000
      I0101 00:18:40.228908  1023 hwdisplay.c:367]                <hwd_layer_set_src> set fb.format 98 76, color_space 260 end, size0[1280x720], size1[640x360]
      vocallback_wrapper line 296, VO callback: VO Layer[4] chn[0] event:257
      vocallback_wrapper line 308, vo layer[4] report video display size[1280x720].
      I0101 00:18:40.229131  1023 VideoRender_Component.c:2319]   <VideoRender_ComponentThread> init video_render, param: displayRect[0,0][1280x720], bufSize[1280x720], vdecColorFormat[0x6]
      I0101 00:18:40.229257  1023 mpi_vo.c:508]                   <VideoRenderEventHandler> KeyFrameDecoded, pts[118992242]us
      vocallback_wrapper line 296, VO callback: VO Layer[4] chn[0] event:258
      vocallback_wrapper line 313, vo layer[4] report rendering start.
      E0101 00:18:40.260354  1021 isp_dev.c:859]                  <isp_sync_debug_info> [ISP_ERR]VIDIOC_VIN_ISP_GET_INFO error!
      W0101 00:18:40.260567  1021 isp.c:450]                      <isp_ctx_get_sensor_info> [ISP_WARN]isp debugfs node not support!!!
      [  119.507460] L2 PageTable Invalid
      [  119.511083] 0x48f14000 is not mapped!
      [  119.515179] DE invalid address: 0x48f14000, data:0x0, id:0x4
      [  119.522292] [DISP] disp_mgr_set_layer_config,line:1504:
      [  119.527960] NULL hdl!
      [  119.537440] L2 PageTable Invalid
      [  119.541056] 0x48f00000 is not mapped!
      [  119.545151] DE invalid address: 0x48f00000, data:0x0, id:0x4
      [  119.554103] L2 PageTable Invalid
      [  119.557716] 0x48f00000 is not mapped!
      [  119.561810] DE invalid address: 0x48f00000, data:0x0, id:0x4
      [  119.570770] L2 PageTable Invalid
      [  119.574388] 0x48f00000 is not mapped!
      [  119.578484] DE invalid address: 0x48f00000, data:0x0, id:0x4
      [  119.587428] L2 PageTable Invalid
      [  119.591037] 0x48f00000 is not mapped!
      [  119.595131] DE invalid address: 0x48f00000, data:0x0, id:0x4
      [  120.598481] [DISP] de_fcm_set_para,line:491:
      [  120.603087] fcm lut 0 not find, auto retry after init
      [  120.609126] [DISP] de_fcm_set_para,line:491:
      [  120.613724] fcm lut 0 not find, auto retry after init
      [  120.746740] npu[3f8][3fd] gckvip_drv_exit, aw_vip_mem_free
      [  120.753008] aw_vip_mem_free vir 0xc5801000, phy 0x48800000
      [  120.759190] aw_vip_mem_free dma_unmap_sg_atrs
      [  120.764111] aw_vip_mem_free ion_unmap_kernel
      [  120.769209] aw_vip_mem_free ion_free
      [  120.773239] aw_vip_mem_free ion_client_destroy
      [  120.782813] npu[3f8][3fd] vipcore, device un-init..
      Arithmetic exception (core dumped)
      配置文件日下:
      venc_vaild = 1
      venc_vipp_dev = 0
      venc_capture_width = 1920
      venc_capture_height = 1080
      venc_display_width = 1920
      venc_display_height = 1080
      venc_encode_type = "H.265"
      venc_file_path = "/mnt/extsd/venc_stream.raw"
      preview_vipp_dev = 4
      preview_capture_width = 1280
      preview_capture_height = 720
      preview_layer_num = 4
      preview_display_x = 0
      preview_display_y = 0
      preview_display_width = 1280
      preview_display_height = 720
      npu_vipp_dev = 8
      npu_nbg_file_path = "/mnt/extsd/network_binary.nb"
      test_duration = 60 #unit:s, 0:Infinite duration.
      麻烦哪位大神看一下是什么原因?谢谢。
