【分享】D1S新增一款MIPI屏[480*480] ST7701S
第一次玩MIPI屏,还算比较顺利,有需要的可以参考:
分辨率:480x480
驱动IC:ST7701S
接--口:MIPI 2Lane
规格书:1960496392HX40007ACT 规格书.pdf&lcd0 { lcd_used = <1>; lcd_driver_name = "st7701s"; lcd_backlight = <100>; lcd_if = <4>; lcd_pwm_used = <1>; lcd_pwm_ch = <7>; lcd_pwm_freq = <1000>; lcd_pwm_pol = <0>; lcd_pwm_max_limit = <255>; // 480*480 lcd_x = <480>; lcd_y = <480>; lcd_width = <72>; lcd_height = <72>; lcd_dclk_freq = <16>; // lcd_ht * lcd_vt * 60 lcd_dsi_lane = <2>; pinctrl-0 = <&dsi2lane_pins_a>; pinctrl-1 = <&dsi2lane_pins_b>; lcd_hbp = <30>; // hsync back porch(pixel) + hsync plus width(pixel); lcd_ht = <525>; // hsync total cycle(pixel) lcd_hspw = <25>; // hsync plus width(pixel) lcd_vbp = <20>; // vsync back porch(line) + vysnc plus width(line) lcd_vt = <525>; // vysnc total cycle(line) lcd_vspw = <8>; // vysnc plus width(pixel) lcd_dsi_if = <0>; lcd_lvds_if = <0>; lcd_lvds_colordepth = <0>; lcd_lvds_mode = <0>; lcd_frm = <0>; lcd_hv_clk_phase = <0>; lcd_hv_sync_polarity= <0>; lcd_io_phase = <0x0000>; lcd_gamma_en = <0>; lcd_bright_curve_en = <0>; lcd_cmap_en = <0>; lcd_fsync_en = <0>; lcd_fsync_act_time = <1000>; lcd_fsync_dis_time = <1000>; lcd_fsync_pol = <0>; deu_mode = <0>; lcdgamma4iep = <22>; smart_color = <90>; lcd_gpio_0 = <&pio PB 2 GPIO_ACTIVE_HIGH>; };
初始化代码:
static struct LCM_setting_table lcm_initialization_setting[] = { // {0x11, 1, {0x00} }, {REGFLAG_DELAY, 60, {} }, {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x10} }, {0xc0, 2, {0x3b, 0x00} }, {0xc1, 2, {0x0d, 0x02} }, {0xc2, 2, {0x31, 0x05} }, {0xcd, 1, {0x08} }, {0xb0, 16, {0x00, 0x11, 0x18, 0x0e, 0x11, 0x06, 0x07, 0x08, 0x07, 0x22, 0x04, 0x12, 0x0f, 0xaa, 0x31, 0x18} }, {0xb1, 16, {0x00, 0x11, 0x19, 0x0e, 0x12, 0x07, 0x08, 0x08, 0x08, 0x22, 0x04, 0x11, 0x11, 0xa9, 0x32, 0x18} }, {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x11} }, {0xb0, 1, {0x60} }, {0xb1, 1, {0x32} }, {0xb2, 1, {0x07} }, {0xb3, 1, {0x80} }, {0xb5, 1, {0x49} }, {0xb7, 1, {0x85} }, {0xb8, 1, {0x21} }, // {0xb9, 1, {0x10} }, {0xc1, 1, {0x78} }, {0xc2, 1, {0x78} }, {REGFLAG_DELAY, 50, {} }, {0x21, 1, {0x00} }, // {0xd0, 1, {0x88} }, {0xe0, 3, {0x00, 0x1b, 0x02} }, {0xe1, 11, {0x08, 0xa0, 0x00, 0x00, 0x07, 0xa0, 0x00, 0x00, 0x00, 0x44, 0x44} }, {0xe2, 12, {0x11, 0x11, 0x44, 0x44, 0xed, 0xa0, 0x00, 0x00, 0xec, 0xa0, 0x00, 0x00} }, {0xe3, 4, {0x00, 0x00, 0x11, 0x11} }, {0xe4, 2, {0x44, 0x44} }, {0xe5, 16, {0x0a, 0xe9, 0xd8, 0xa0, 0x0c, 0xeb, 0xd8, 0xa0, 0x0e, 0xed, 0xd8, 0xa0, 0x10, 0xef, 0xd8, 0xa0} }, {0xe6, 4, {0x00, 0x00, 0x11, 0x11} }, {0xe7, 2, {0x44, 0x44} }, {0xe8, 16, {0x09, 0xe8, 0xd8, 0xa0, 0x0b, 0xea, 0xd8, 0xa0, 0x0d, 0xec, 0xd8, 0xa0, 0x0f, 0xee, 0xd8, 0xa0} }, {0xeb, 7, {0x02, 0x00, 0xe4, 0xe4, 0x88, 0x00, 0x40} }, {0xec, 2, {0x3c, 0x00} }, {0xed, 16, {0xab, 0x89, 0x76, 0x54, 0x02, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x20, 0x45, 0x67, 0x98, 0xba} }, {0x36, 1, {0x00} }, {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x13} }, {0xe5, 1, {0xe4} }, {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x00} }, {0x3a, 2, {0x66, 0x21} }, {REGFLAG_DELAY, 50, {} }, {0x11, 1, {0x00} }, {REGFLAG_DELAY, 120, {} }, {0x29, 1, {0x00} }, {REGFLAG_END_OF_TABLE, 0x00, {} } };
还有一款720 x 720的4Lane MIPI屏还没调通
@jerrychen 这个屏厂家给的原始初始化代码方便发一下不~我看看和我差异多大~~
@whycanservice 看到了~~ @jerrychen 打算画转接板不~~ 我有类似的屏,还没点亮~也是按照厂家的配,连背光都不亮~要是画转接板,记得@一下我。啊哈哈。
@soso90 就1楼的代码片段2就是卖家给的,我只是把他转换为这个平台的格式了
@soso90 应该不画,也不会画(都忘记怎么画板了),就一块这个屏,买来玩玩的
@jerrychen 方便加个qq不,我断断续续也在调mipi的屏,也是7701s~ qq:491532763
@jerrychen 有没有测试镜像,方便发我测试一下~~屏已经买了。怕硬件没飞好线~
@jerrychen
果不其然,按照你修改的。没有点亮。驱动是加载了。但是只亮背光。有可能是转接板有问题。看到贴子的话,方便帮我试试我的镜像?或是分享你的镜像给我。谢谢
tina_f133-mq_r_uart0_mipi_2.img -
@jerrychen 非常感谢大佬百忙之中传上固件。实际测试后还是不行。应该是我的硬件有问题。万分感谢。后续我有进展,继续跟进~~
@soso90 在 【分享】D1S新增一款MIPI屏[480*480] ST7701S 中说:
@jerrychen
tina_f133-mq_r_uart0_mipi_2.img重新手动飞线,能亮了。这个镜像也可以。。。兜兜转转,才搞定硬件。谢谢楼主,完楼~~
@jerrychen 在 【分享】D1S新增一款MIPI屏[480*480] ST7701S 中说:
4Lane
请问下,我现在用A133 驱动st7701s[480x480],dts配置如下,我配置了2lane ,奇怪的是lane2 lane3都有数据,不知道哪里没配置对,谢谢指点
lcd0: lcd0@01c0c000 {lcd_used = <1>; lcd_driver_name = "st7701s"; lcd_backlight = <100>; lcd_if = <4>; lcd_x = <480>; lcd_y = <480>; lcd_width = <72>; lcd_height = <72>; lcd_dclk_freq = <16>; lcd_pwm_used = <1>; lcd_pwm_ch = <3>; lcd_pwm_freq = <1000>; lcd_pwm_pol = <0>; lcd_pwm_max_limit = <255>; lcd_hbp = <30>; lcd_ht = <525>; lcd_hspw = <25>; lcd_vbp = <20>; lcd_vt = <525>; lcd_vspw = <8>; lcd_frm = <0>; lcd_gamma_en = <0>; lcd_bright_curve_en = <0>; lcd_cmap_en = <0>; deu_mode = <0>; lcdgamma4iep = <22>; smart_color = <90>; lcd_dsi_if = <0>; lcd_dsi_lane = <2>; lcd_dsi_format = <0>; lcd_dsi_te = <0>; lcd_dsi_eotp = <0>; lcd_pin_power = "dcdc1"; lcd_pin_power1 = "eldo3"; lcd_power = "dc1sw"; lcd_gpio_0 = <&r_pio PL 11 1 0 3 1>; pinctrl-0 = <&dsi2lane_pins_a>; pinctrl-1 = <&dsi2lane_pins_b>; }
