全志T113-s3使用ov5640加载insmod vin_v4l2.ko报错
全志T113-s3使用ov5640加载insmod vin_v4l2.ko报错,各位大佬救救急,搞了很久了,一直没有眉目。
配置如下:
board.dts
/* * Allwinner Technology CO., Ltd. */ /dts-v1/; /* optee used 7MB: SHM 2M: OS: 1M: TA:4M*/ /memreserve/ 0x41B00000 0x00100000; /* DSP used 1MB */ /*/memreserve/ 0x42000000 0x00100000;*/ #include "sun8iw20p1.dtsi" /{ model = "sun8iw20"; compatible = "allwinner,r528", "arm,sun8iw20p1"; reg_vdd_cpu: vdd-cpu { compatible = "sunxi-pwm-regulator"; pwms = <&pwm 3 5000 0>; regulator-name = "vdd_cpu"; regulator-min-microvolt = <810000>; regulator-max-microvolt = <1160000>; regulator-ramp-delay = <25>; regulator-always-on; regulator-boot-on; status = "okay"; }; reg_usb1_vbus: usb1-vbus { compatible = "regulator-fixed"; regulator-name = "usb1-vbus"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; regulator-enable-ramp-delay = <1000>; gpio = <&pio PB 3 GPIO_ACTIVE_HIGH>; enable-active-high; }; }; &cpu0 { cpu-supply = <®_vdd_cpu>; }; &pio { sdc0_pins_a: sdc0@0 { allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; allwinner,function = "sdc0"; allwinner,muxsel = <2>; allwinner,drive = <3>; allwinner,pull = <1>; pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; function = "sdc0"; drive-strength = <30>; bias-pull-up; power-source = <3300>; }; sdc0_pins_b: sdc0@1 { pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; function = "sdc0"; drive-strength = <30>; bias-pull-up; power-source = <1800>; }; sdc0_pins_c: sdc0@2 { pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; function = "gpio_in"; }; /* TODO: add jtag pin */ sdc0_pins_d: sdc0@3 { pins = "PF2", "PF4"; function = "uart0"; drive-strength = <10>; bias-pull-up; }; sdc0_pins_e: sdc0@4 { pins = "PF0", "PF1", "PF3", "PF5"; function = "jtag"; drive-strength = <10>; bias-pull-up; }; sdc1_pins_a: sdc1@0 { pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; function = "sdc1"; drive-strength = <30>; bias-pull-up; }; sdc1_pins_b: sdc1@1 { pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; function = "gpio_in"; }; sdc2_pins_a: sdc2@0 { allwinner,pins = "PC2", "PC3", "PC4", "PC5", "PC6", "PC7"; allwinner,function = "sdc2"; allwinner,muxsel = <3>; allwinner,drive = <3>; allwinner,pull = <1>; pins = "PC2", "PC3", "PC4", "PC5", "PC6", "PC7"; function = "sdc2"; drive-strength = <30>; bias-pull-up; }; sdc2_pins_b: sdc2@1 { pins = "PC2", "PC3", "PC4", "PC5", "PC6", "PC7"; function = "gpio_in"; }; wlan_pins_a:wlan@0 { pins = "PG11"; function = "clk_fanout1"; }; uart0_pins_a: uart0_pins@0 { /* For EVB1 board */ pins = "PF2", "PF4"; function = "uart0"; drive-strength = <10>; bias-pull-up; }; uart0_pins_b: uart0_pins@1 { /* For EVB1 board */ pins = "PF2", "PF4"; function = "gpio_in"; }; uart1_pins_a: uart1_pins@0 { /* For EVB1 board */ pins = "PG6", "PG7", "PG8", "PG9"; function = "uart1"; drive-strength = <10>; bias-pull-up; }; uart1_pins_b: uart1_pins { /* For EVB1 board */ pins = "PG6", "PG7", "PG8", "PG9"; function = "gpio_in"; }; uart2_pins_a: uart2_pins@0 { /* For EVB1 board */ pins = "PC0", "PC1"; function = "uart2"; drive-strength = <10>; bias-pull-up; }; uart2_pins_b: uart2_pins@1 { /* For EVB1 board */ pins = "PC0", "PC1"; function = "gpio_in"; }; uart3_pins_a: uart3_pins@0 { /* For awol nezha board */ pins = "PB6", "PB7"; function = "uart3"; muxsel = <7>; drive-strength = <10>; bias-pull-up; }; uart3_pins_b: uart3_pins@1 { /* For awol nezha board */ pins = "PB6", "PB7"; function = "gpio_in"; }; twi0_pins_a: twi0@0 { pins = "PB10", "PB11"; /*sck sda*/ function = "twi0"; drive-strength = <10>; }; twi0_pins_b: twi0@1 { pins = "PB10", "PB11"; function = "gpio_in"; }; twi1_pins_a: twi1@0 { pins = "PB4", "PB5"; function = "twi1"; drive-strength = <10>; }; twi1_pins_b: twi1@1 { pins = "PB4", "PB5"; function = "gpio_in"; }; twi2_pins_a: twi2@0 { pins = "PE12", "PE13"; function = "twi2"; drive-strength = <10>; }; twi2_pins_b: twi2@1 { pins = "PE12", "PE13"; function = "gpio_in"; }; twi3_pins_a: twi3@0 { pins = "PE6", "PE7"; function = "twi3"; drive-strength = <10>; }; twi3_pins_b: twi3@1 { pins = "PE6", "PE7"; function = "gpio_in"; }; dmic_pins_a: dmic@0 { /* DMIC_PIN: CLK, DATA0, DATA1, DATA2, DATA3*/ pins = "PB12", "PB11", "PB10", "PE14", "PB8"; function = "dmic"; drive-strength = <20>; bias-disable; }; dmic_pins_b: dmic@1 { pins = "PB12", "PB11", "PB10", "PE14", "PB8"; function = "io_disabled"; drive-strength = <20>; bias-disable; }; daudio0_pins_a: daudio0@0 { pins = "PE17", "PE16", "PE15", "PE14", "PE13"; function = "i2s0"; drive-strength = <20>; bias-disable; }; daudio0_pins_b: daudio0_sleep@0 { pins = "PE17", "PE16", "PE15", "PE14", "PE13"; function = "io_disabled"; drive-strength = <20>; bias-disable; }; daudio1_pins_a: daudio1@0 { pins = "PG11", "PG12", "PG13", "PG14", "PG15"; function = "i2s1"; drive-strength = <20>; bias-disable; }; daudio1_pins_b: daudio1_sleep@0 { pins = "PG11", "PG12", "PG13", "PG14", "PG15"; function = "io_disabled"; drive-strength = <20>; bias-disable; }; daudio2_pins_a: daudio2@0 { /* I2S_PIN: MCLK, BCLK, LRCK */ pins = "PF6", "PF3", "PF5"; function = "i2s2"; drive-strength = <20>; bias-disable; }; daudio2_pins_b: daudio2@1 { /* I2S_PIN: DOUT0 */ pins = "PF1"; function = "i2s2_dout"; drive-strength = <20>; bias-disable; }; daudio2_pins_c: daudio2@2 { /* I2S_PIN: DIN0 */ pins = "PF0"; function = "i2s2_din"; drive-strength = <20>; bias-disable; }; daudio2_pins_d: daudio2_sleep@0 { pins = "PF6", "PF3", "PF5", "PF1", "PF0"; function = "io_disabled"; drive-strength = <20>; bias-disable; }; spdif_pins_a: spdif@0 { /* SPDIF_PIN: SPDIF_OUT */ pins = "PG18"; function = "spdif"; drive-strength = <20>; bias-disable; }; spdif_pins_b: spdif_sleep@0 { pins = "PG18"; function = "io_disabled"; drive-strength = <20>; bias-disable; }; spi0_pins_a: spi0@0 { pins = "PC2", "PC4", "PC5"; /* clk, mosi, miso */ function = "spi0"; muxsel = <2>; drive-strength = <10>; }; spi0_pins_b: spi0@1 { pins = "PC3", "PC7", "PC6"; function = "spi0"; muxsel = <2>; drive-strength = <10>; bias-pull-up; /* cs, hold, wp should be pulled up */ }; spi0_pins_c: spi0@2 { pins = "PC2", "PC3", "PC4", "PC5","PC6", "PC7"; function = "gpio_in"; muxsel = <0>; drive-strength = <10>; }; spi1_pins_a: spi1@0 { pins = "PD11", "PD12", "PD13"; /* clk, mosi, miso */ function = "spi1"; drive-strength = <10>; }; spi1_pins_b: spi1@1 { pins = "PD10", "PD14", "PD15"; function = "spi1"; drive-strength = <10>; bias-pull-up; /* cs, hold, wp should be pulled up */ }; spi1_pins_c: spi1@2 { pins = "PD10", "PD11", "PD12", "PD13","PD14", "PD15"; function = "gpio_in"; drive-strength = <10>; }; ledc_pins_a: ledc@0 { pins = "PG13"; function = "ledc"; drive-strength = <10>; }; ledc_pins_b: ledc@1 { pins = "PG13"; function = "gpio_in"; }; pwm0_pin_a: pwm0@0 { pins = "PD16"; function = "pwm0"; drive-strength = <10>; bias-pull-up; }; pwm0_pin_b: pwm0@1 { pins = "PD16"; function = "gpio_in"; bias-disable; }; pwm2_pin_a: pwm2@0 { pins = "PD18"; function = "pwm2"; drive-strength = <10>; bias-pull-up; }; pwm2_pin_b: pwm2@1 { pins = "PD18"; function = "gpio_out"; }; pwm7_pin_a: pwm7@0 { pins = "PD22"; function = "pwm7"; drive-strength = <10>; bias-pull-up; }; pwm7_pin_b: pwm7@1 { pins = "PD22"; function = "gpio_in"; }; s_cir0_pins_a: s_cir@0 { pins = "PB7"; function = "ir"; drive-strength = <10>; bias-pull-up; }; s_cir0_pins_b: s_cir@1 { pins = "PB7"; function = "gpio_in"; }; ir1_pins_a: ir1@0 { pins = "PB0"; function = "ir"; drive-strength = <10>; bias-pull-up; }; ir1_pins_b: ir1@1 { pins = "PB0"; function = "gpio_in"; }; }; &uart0 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&uart0_pins_a>; pinctrl-1 = <&uart0_pins_b>; status = "disabled"; }; &uart1 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&uart1_pins_a>; pinctrl-1 = <&uart1_pins_b>; status = "disabled"; }; &uart2 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&uart2_pins_a>; pinctrl-1 = <&uart2_pins_b>; status = "disabled"; }; /* for debug */ &uart3 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&uart3_pins_a>; pinctrl-1 = <&uart3_pins_b>; status = "okay"; }; /* for dsp debug &uart3 { compatible = "allwinner,sun20iw1-dsp-uart"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&uart3_pins_a>; pinctrl-1 = <&uart3_pins_b>; status = "okay"; }; */ &soc { card0_boot_para@2 { /* * Avoid dtc compiling warnings. * @TODO: Developer should modify this to the actual value */ reg = <0x0 0x2 0x0 0x0>; device_type = "card0_boot_para"; card_ctrl = <0x0>; card_high_speed = <0x1>; card_line = <0x4>; pinctrl-0 = <&sdc0_pins_a>; }; card2_boot_para@3 { /* * Avoid dtc compiling warnings. * @TODO: Developer should modify this to the actual value */ reg = <0x0 0x3 0x0 0x0>; device_type = "card2_boot_para"; card_ctrl = <0x2>; card_high_speed = <0x1>; card_line = <0x4>; pinctrl-0 = <&sdc2_pins_a>; /*pinctrl-0 = <&sdc0_pins_a>;*/ /*sdc_ex_dly_used = <0x2>;*/ sdc_io_1v8 = <0x1>; /*sdc_type = "tm4";*/ sdc_tm4_hs200_max_freq = <150>; sdc_tm4_hs400_max_freq = <100>; sdc_ex_dly_used = <2>; /*sdc_tm4_win_th = <8>;*/ /*sdc_dis_host_caps = <0x180>;*/ }; rfkill: rfkill@0 { compatible = "allwinner,sunxi-rfkill"; chip_en; power_en; pinctrl-0 = <&wlan_pins_a>; pinctrl-names = "default"; status = "okay"; wlan: wlan@0 { compatible = "allwinner,sunxi-wlan"; clock-names = "32k-fanout1"; clocks = <&ccu CLK_FANOUT1_OUT>; wlan_busnum = <0x1>; wlan_regon = <&pio PG 12 GPIO_ACTIVE_HIGH>; wlan_hostwake = <&pio PG 10 GPIO_ACTIVE_HIGH>; /*wlan_power = "VCC-3V3";*/ /*wlan_power_vol = <3300000>;*/ /*interrupt-parent = <&pio>; interrupts = < PG 10 IRQ_TYPE_LEVEL_HIGH>;*/ wakeup-source; }; bt: bt@0 { compatible = "allwinner,sunxi-bt"; clock-names = "32k-fanout1"; clocks = <&ccu CLK_FANOUT1_OUT>; /*bt_power_num = <0x01>;*/ /*bt_power = "axp803-dldo1";*/ /*bt_io_regulator = "axp803-dldo1";*/ /*bt_io_vol = <3300000>;*/ /*bt_power_vol = <330000>;*/ bt_rst_n = <&pio PG 15 GPIO_ACTIVE_LOW>; status = "okay"; }; }; btlpm: btlpm@0 { compatible = "allwinner,sunxi-btlpm"; uart_index = <0x1>; bt_wake = <&pio PG 15 GPIO_ACTIVE_HIGH>; bt_hostwake = <&pio PG 14 GPIO_ACTIVE_HIGH>; status = "okay"; }; addr_mgt: addr_mgt@0 { compatible = "allwinner,sunxi-addr_mgt"; type_addr_wifi = <0x0>; type_addr_bt = <0x0>; type_addr_eth = <0x0>; status = "okay"; }; }; &sdc2 { non-removable; bus-width = <4>; mmc-ddr-1_8v; mmc-hs200-1_8v; no-sdio; no-sd; ctl-spec-caps = <0x308>; cap-mmc-highspeed; sunxi-power-save-mode; sunxi-dis-signal-vol-sw; mmc-bootpart-noacc; max-frequency = <150000000>; /*vmmc-supply = <®_dcdc1>;*/ /*emmc io vol 3.3v*/ /*vqmmc-supply = <®_aldo1>;*/ /*emmc io vol 1.8v*/ /*vqmmc-supply = <®_eldo1>;*/ status = "disabled"; }; &sdc0 { bus-width = <4>; cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; /*non-removable;*/ /*broken-cd;*/ /*cd-inverted;*/ /*data3-detect;*/ /*card-pwr-gpios = <&pio PH 14 1 1 2 0xffffffff>;*/ cd-used-24M; cap-sd-highspeed; /*sd-uhs-sdr50;*/ /*sd-uhs-ddr50;*/ /*sd-uhs-sdr104;*/ no-sdio; no-mmc; sunxi-power-save-mode; /*sunxi-dis-signal-vol-sw;*/ max-frequency = <150000000>; ctl-spec-caps = <0x8>; /*vmmc-supply = <®_dcdc1>;*/ /*vqmmc33sw-supply = <®_dcdc1>;*/ /*vdmmc33sw-supply = <®_dcdc1>;*/ /*vqmmc18sw-supply = <®_eldo1>;*/ /*vdmmc18sw-supply = <®_eldo1>;*/ status = "okay"; }; &sdc1 { bus-width = <4>; no-mmc; no-sd; cap-sd-highspeed; /*sd-uhs-sdr12*/ /*sd-uhs-sdr25;*/ /*sd-uhs-sdr50;*/ /*sd-uhs-ddr50;*/ /*sd-uhs-sdr104;*/ /*sunxi-power-save-mode;*/ /*sunxi-dis-signal-vol-sw;*/ cap-sdio-irq; keep-power-in-suspend; ignore-pm-notify; max-frequency = <150000000>; ctl-spec-caps = <0x8>; status = "okay"; }; /* tvd configuration used (create device, 0: do not create device, 1: create device) agc_auto_enable (0: agc manual mode,agc_manual_value is valid; 1: agc auto mode) agc_manual_value (agc manual value, default value is 64) cagc_enable (cagc 0: disable, 1: enable) fliter_used (3d fliter 0: disable, 1: enable) support two PMU power (tvd_power0, tvd_power1) support two GPIO power (tvd_gpio0, tvd_gpio1) NOTICE: If tvd need pmu power or gpio power,params need be configured under [tvd] tvd_sw (the switch of all tvd driver.) tvd_interface (0: cvbs, 1: ypbpr,) tvd_format (0:TVD_PL_YUV420 , 1: MB_YUV420, 2: TVD_PL_YUV422) tvd_system (0:ntsc, 1:pal) tvd_row (total row number in multi channel mode 1-2) tvd_column (total column number in multi channel mode 1-2) tvd_channelx_en (0:disable, 1~4:position in multi channel mode,In single channel mode,mean enable) tvd_row*tvd_column is the total tvd channel number to be used in multichannel mode +--------------------+--------------------+ | | | | | | | 1 | 2 | | | | | | | +--------------------+--------------------+ | | | | | | | 3 | 4 | | | | | | | +--------------------+--------------------+ */ &tvd { tvd_sw = <1>; tvd_interface = <0>; tvd_format = <0>; tvd_system = <1>; tvd_row = <1>; tvd_column = <1>; tvd_channel0_en = <1>; tvd_channel1_en = <0>; tvd_channel2_en = <0>; tvd_channel3_en = <0>; /*tvd_gpio0 = <&pio PD 22 GPIO_ACTIVE_HIGH>;*/ /*tvd_gpio1 = <&pio PD 23 GPIO_ACTIVE_HIGH>;*/ /*tvd_gpio2 = <&pio PD 24 GPIO_ACTIVE_HIGH>;*/ /* dc1sw-supply = <®_dc1sw>;*/ /* eldo3-supply = <®_eldo3>;*/ /*tvd_power0 = "dc1sw"*/ /*tvd_power1 = "eldo3"*/ }; &tvd0 { used = <1>; agc_auto_enable = <1>; agc_manual_value = <64>; cagc_enable = <1>; fliter_used = <1>; }; /* Audio Driver modules */ &sunxi_rpaf_dsp0 { status = "disabled"; }; /* if audiocodec is used, sdc0 and uart0 should be closed to enable PA. */ &codec { /* MIC and headphone gain setting */ mic1gain = <0x1F>; mic2gain = <0x1F>; mic3gain = <0x1F>; /* ADC/DAC DRC/HPF func enabled */ /* 0x1:DAP_HP_EN; 0x2:DAP_SPK_EN; 0x3:DAP_HPSPK_EN */ adcdrc_cfg = <0x0>; adchpf_cfg = <0x1>; dacdrc_cfg = <0x0>; dachpf_cfg = <0x0>; /* Volume about */ digital_vol = <0x00>; lineout_vol = <0x1a>; headphonegain = <0x03>; /* Pa enabled about */ pa_level = <0x01>; pa_pwr_level = <0x01>; pa_msleep_time = <0x78>; /* gpio-spk = <&pio PF 2 GPIO_ACTIVE_HIGH>;*/ /* gpio-spk-pwr = <&pio PF 4 GPIO_ACTIVE_HIGH>; */ /* CMA config about */ playback_cma = <128>; capture_cma = <256>; /* regulator about */ /* avcc-supply = <®_aldo1>; */ /* hpvcc-supply = <®_eldo1>; */ status = "okay"; }; &sndcodec { hp_detect_case = <0x00>; jack_enable = <0x01>; status = "okay"; }; &dummy_cpudai { status = "okay"; }; &dmic { pinctrl-names = "default","sleep"; pinctrl-0 = <&dmic_pins_a>; pinctrl-1 = <&dmic_pins_b>; status = "disabled"; }; &dmic_codec { status = "disabled"; }; &sounddmic { status = "disabled"; }; /*----------------------------------------------------------------------------- * pcm_lrck_period 16/32/64/128/256 * slot_width_select 16bits/20bits/24bits/32bits * frametype 0 --> short frame = 1 clock width; * 1 --> long frame = 2 clock width; * tdm_config 0 --> pcm * 1 --> i2s * mclk_div 0 --> not output * 1/2/4/6/8/12/16/24/32/48/64/96/128/176/192 * (set mclk as external codec clk source, freq is pll_audio/mclk_div) * pinctrl_used 0 --> I2S/PCM use for internal * 1 --> I2S/PCM use for external audio * daudio_type: 0 --> external audio type *---------------------------------------------------------------------------*/ &daudio0 { mclk_div = <0x01>; frametype = <0x00>; tdm_config = <0x01>; sign_extend = <0x00>; msb_lsb_first = <0x00>; pcm_lrck_period = <0x80>; slot_width_select = <0x20>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&daudio0_pins_a>; pinctrl-1 = <&daudio0_pins_b>; pinctrl_used = <0x0>; status = "disabled"; }; /*----------------------------------------------------------------------------- * simple-audio-card,name name of sound card, e.g. * "snddaudio0" --> use for external audio * sound-dai "snd-soc-dummy" --> use for I2S * "ac108" --> use for external audio of ac108 *---------------------------------------------------------------------------*/ &sounddaudio0 { /* simple-audio-card,format = "i2s"; */ /* simple-audio-card,frame-master = <&daudio0_master>; */ /* simple-audio-card,bitclock-master = <&daudio0_master>; */ /* simple-audio-card,bitclock-inversion; */ /* simple-audio-card,frame-inversion; */ status = "disabled"; daudio0_master: simple-audio-card,codec { /* sound-dai = <&ac108>; */ }; }; &daudio1 { mclk_div = <0x01>; frametype = <0x00>; tdm_config = <0x01>; sign_extend = <0x00>; msb_lsb_first = <0x00>; pcm_lrck_period = <0x80>; slot_width_select = <0x20>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&daudio1_pins_a>; pinctrl-1 = <&daudio1_pins_b>; pinctrl_used = <0x0>; status = "disabled"; }; &sounddaudio1 { status = "disabled"; daudio1_master: simple-audio-card,codec { /* sound-dai = <&ac108>; */ }; }; &daudio2 { mclk_div = <0x01>; frametype = <0x00>; tdm_config = <0x01>; sign_extend = <0x00>; tx_data_mode = <0x00>; rx_data_mode = <0x00>; msb_lsb_first = <0x00>; pcm_lrck_period = <0x80>; slot_width_select = <0x20>; asrc_function_en = <0x00>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&daudio2_pins_a &daudio2_pins_b &daudio2_pins_c>; pinctrl-1 = <&daudio2_pins_d>; pinctrl_used = <0x1>; daudio_type = <0x0>; status = "disabled"; }; &sounddaudio2 { status = "disabled"; daudio2_master: simple-audio-card,codec { /* sound-dai = <&ac108>; */ }; }; &spdif { pinctrl-names = "default","sleep"; pinctrl-0 = <&spdif_pins_a>; pinctrl-1 = <&spdif_pins_b>; status = "disabled"; }; &soundspdif { status = "disabled"; }; /* *usb_port_type: usb mode. 0-device, 1-host, 2-otg. *usb_detect_type: usb hotplug detect mode. 0-none, 1-vbus/id detect, 2-id/dpdm detect. *usb_detect_mode: 0-thread scan, 1-id gpio interrupt. *usb_id_gpio: gpio for id detect. *usb_det_vbus_gpio: gpio for id detect. gpio or "axp_ctrl"; *usb_wakeup_suspend:0-SUPER_STANDBY, 1-USB_STANDBY. */ &usbc0 { device_type = "usbc0"; usb_port_type = <0x2>; usb_detect_type = <0x1>; usb_detect_mode = <0>; usb_id_gpio = <&pio PB 8 GPIO_ACTIVE_HIGH>; enable-active-high; usb_det_vbus_gpio = <&pio PB 9 GPIO_ACTIVE_LOW>; usb_wakeup_suspend = <0>; usb_serial_unique = <0>; usb_serial_number = "20080411"; rndis_wceis = <1>; status = "okay"; }; &ehci0 { drvvbus-supply = <®_usb1_vbus>; }; &ohci0 { drvvbus-supply = <®_usb1_vbus>; }; &usbc1 { device_type = "usbc1"; usb_port_type = <0x01>; sb_detect_type = <0x1>; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0>; status = "okay"; }; &ehci1 { status = "okay"; }; &ohci1 { status = "okay"; }; &twi0 { clock-frequency = <400000>; pinctrl-0 = <&twi0_pins_a>; pinctrl-1 = <&twi0_pins_b>; pinctrl-names = "default", "sleep"; status = "disabled"; eeprom@50 { compatible = "atmel,24c16"; reg = <0x50>; status = "disabled"; }; }; &twi1 { clock-frequency = <400000>; pinctrl-0 = <&twi1_pins_a>; pinctrl-1 = <&twi1_pins_b>; pinctrl-names = "default", "sleep"; status = "disabled"; }; &twi2 { clock-frequency = <400000>; pinctrl-0 = <&twi2_pins_a>; pinctrl-1 = <&twi2_pins_b>; pinctrl-names = "default", "sleep"; dmas = <&dma 45>, <&dma 45>; dma-names = "tx", "rx"; status = "okay"; /* pcf8574-usage: * only use gpio0~7, 0 means PP0. * pin set: * gpios = <&pcf8574 0 GPIO_ACTIVE_LOW>; * interrupt set: * interrupt-parent = <&pcf8574>; * interrupts = <0 IRQ_TYPE_EDGE_FALLING>; */ /*pcf8574: gpio@38 { compatible = "nxp,pcf8574"; reg = <0x38>; gpio_base = <2020>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; interrupt-parent = <&pio>; interrupts = <PB 2 IRQ_TYPE_EDGE_FALLING>; status = "disabled"; }; */ ctp@38 { compatible = "focaltech,fts"; reg = <0x38>; status = "okay"; interrupt-parent = <&pio>; interrupts = <PB 3 IRQ_TYPE_LEVEL_LOW>; focaltech,reset-gpio = <&pio PB 2 GPIO_ACTIVE_HIGH>; focaltech,irq-gpio = <&pio PB 3 IRQ_TYPE_LEVEL_LOW>; focaltech,max-touch-number = <2>; focaltech,display-coords = <0 0 800 480>; focaltech,reg_vdd = <®_pio3_3>; focaltech,reg_avdd = <®_pio3_3>; }; }; &twi3 { clock-frequency = <400000>; pinctrl-0 = <&twi3_pins_a>; pinctrl-1 = <&twi3_pins_b>; pinctrl-names = "default", "sleep"; status = "disabled"; }; /* &gmac0 { phy-mode = "rmii"; use_ephy25m = <0>; pinctrl-0 = <&gmac_pins_a>; pinctrl-1 = <&gmac_pins_b>; pinctrl-names = "default", "sleep"; phy-rst = <&pio PE 10 GPIO_ACTIVE_HIGH>; status = "okay"; };*/ &spi0 { clock-frequency = <100000000>; pinctrl-0 = <&spi0_pins_a &spi0_pins_b>; pinctrl-1 = <&spi0_pins_c>; pinctrl-names = "default", "sleep"; /*spi-supply = <®_dcdc1>;*/ spi_slave_mode = <0>; spi0_cs_number = <1>; spi0_cs_bitmap = <1>; status = "okay"; spi-nand@0 { compatible = "spi-nand"; spi-max-frequency=<100000000>; reg = <0x0>; spi-rx-bus-width=<0x04>; spi-tx-bus-width=<0x04>; status="okay"; }; spi-nor@0 { compatible = "jedec,spi-nor"; spi-max-frequency=<30000000>; reg = <0x0>; spi-rx-bus-width=<0x01>; spi-tx-bus-width=<0x01>; status="disabled"; }; }; &spi1 { clock-frequency = <100000000>; pinctrl-0 = <&spi1_pins_a &spi1_pins_b>; pinctrl-1 = <&spi1_pins_c>; pinctrl-names = "default", "sleep"; spi_slave_mode = <0>; status = "disabled"; spi_board1@0 { device_type = "spi_board1"; compatible = "rohm,dh2228fv"; spi-max-frequency = <0x5f5e100>; reg = <0x0>; spi-rx-bus-width = <0x4>; spi-tx-bus-width = <0x4>; status = "disabled"; }; }; &ledc { pinctrl-names = "default", "sleep"; pinctrl-0 = <&ledc_pins_a>; pinctrl-1 = <&ledc_pins_b>; led_count = <3>; output_mode = "GRB"; reset_ns = <84>; t1h_ns = <800>; t1l_ns = <320>; t0h_ns = <300>; t0l_ns = <800>; wait_time0_ns = <84>; wait_time1_ns = <84>; wait_data_time_ns = <600000>; status = "okay"; }; &keyboard0 { key0 = <210 0x160>; wakeup-source; status = "disabled"; }; /*---------------------------------------------------------------------------------- disp init configuration disp_mode (0:screen0<screen0,fb0>) screenx_output_type (0:none; 1:lcd; 2:tv; 3:hdmi;5:vdpo) screenx_output_mode (used for hdmi output, 0:480i 1:576i 2:480p 3:576p 4:720p50) (5:720p60 6:1080i50 7:1080i60 8:1080p24 9:1080p50 10:1080p60) screenx_output_format (for hdmi, 0:RGB 1:yuv444 2:yuv422 3:yuv420) screenx_output_bits (for hdmi, 0:8bit 1:10bit 2:12bit 2:16bit) screenx_output_eotf (for hdmi, 0:reserve 4:SDR 16:HDR10 18:HLG) screenx_output_cs (for hdmi, 0:undefined 257:BT709 260:BT601 263:BT2020) screenx_output_dvi_hdmi (for hdmi, 0:undefined 1:dvi mode 2:hdmi mode) screen0_output_range (for hdmi, 0:default 1:full 2:limited) screen0_output_scan (for hdmi, 0:no data 1:overscan 2:underscan) screen0_output_aspect_ratio (for hdmi, 8-same as original picture 9-4:3 10-16:9 11-14:9) fbx format (4:RGB655 5:RGB565 6:RGB556 7:ARGB1555 8:RGBA5551 9:RGB888 10:ARGB8888 12:ARGB4444) fbx pixel sequence (0:ARGB 1:BGRA 2:ABGR 3:RGBA) fb0_scaler_mode_enable(scaler mode enable, used FE) fbx_width,fbx_height (framebuffer horizontal/vertical pixels, fix to output resolution while equal 0) lcdx_backlight (lcd init backlight,the range:[0,256],default:197 lcdx_yy (lcd init screen bright/contrast/saturation/hue, value:0~100, default:50/50/57/50) lcd0_contrast (LCD contrast, 0~100) lcd0_saturation (LCD saturation, 0~100) lcd0_hue (LCD hue, 0~100) framebuffer software rotation setting: disp_rotation_used: (0:disable; 1:enable,you must set fbX_width to lcd_y, set fbX_height to lcd_x) degreeX: (X:screen index; 0:0 degree; 1:90 degree; 3:270 degree) degreeX_Y: (X:screen index; Y:layer index 0~15; 0:0 degree; 1:90 degree; 3:270 degree) devX_output_type : config output type in bootGUI framework in UBOOT-2018. (0:none; 1:lcd; 2:tv; 4:hdmi;) devX_output_mode : config output resolution(see include/video/sunxi_display2.h) of bootGUI framework in UBOOT-2018 devX_screen_id : config display index of bootGUI framework in UBOOT-2018 devX_do_hpd : whether do hpd detectation or not in UBOOT-2018 chn_cfg_mode : Hardware DE channel allocation config. 0:single display with 6 channel, 1:dual display with 4 channel in main display and 2 channel in second display, 2:dual display with 3 channel in main display and 3 channel in second in display. ----------------------------------------------------------------------------------*/ &disp { disp_init_enable = <1>; disp_mode = <0>; screen0_output_type = <1>; screen0_output_mode = <4>; screen1_output_type = <3>; screen1_output_mode = <4>; screen1_output_format = <0>; screen1_output_bits = <0>; screen1_output_eotf = <4>; screen1_output_cs = <257>; screen1_output_dvi_hdmi = <2>; screen1_output_range = <2>; screen1_output_scan = <0>; screen1_output_aspect_ratio = <8>; dev0_output_type = <1>; dev0_output_mode = <4>; dev0_screen_id = <0>; dev0_do_hpd = <0>; dev1_output_type = <4>; dev1_output_mode = <10>; dev1_screen_id = <1>; dev1_do_hpd = <1>; def_output_dev = <0>; hdmi_mode_check = <1>; disp_rotation_used = <1>; degree0 = <0>; fb0_format = <0>; fb0_buffer_num = <1>; /*fb0_width = <800>;*/ /*fb0_height = <480>;*/ /*read from lcd*/ fb1_format = <0>; fb1_width = <0>; fb1_height = <0>; chn_cfg_mode = <1>; disp_para_zone = <1>; /*VCC-LCD*/ /* dc1sw-supply = <®_dc1sw>;*/ /*VCC-DSI*/ /* eldo3-supply = <®_eldo3>;*/ /*VCC-PD*/ /* dcdc1-supply = <®_dcdc1>;*/ }; /*---------------------------------------------------------------------------------- ;lcd0 configuration ;lcd_if: 0:hv(sync+de); 1:8080; 2:ttl; 3:lvds; 4:dsi; 5:edp; 6:extend dsi ;lcd_hv_if 0:Parallel RGB; 8:Serial RGB; 10:Dummy RGB; 11: RGB Dummy;12:CCIR656 ;lcd_hv_clk_phase 0:0 degree;1:90 degree;2:180 degree;3:270 degree ;lcd_hv_sync_polarity 0:vs low,hs low; 1:vs high,hslow; 2:vs low,hs high; 3:vs high,hs high ;lcd_hv_syuv_seq 0:YUYV; 1:YVYU; 2:UYVY; 3:VYUY ;lcd_cpu_if 0:18bit/1 cycle parallel(RGB666); 4:16bit/1cycle parallel (RGB565) ; 6:18bit/3 cycle parallel(RGB666); 7:16bit/2cycle parallel (RGB565) ;lcd_cpu_te 0:frame auto trigger; 1:frame triggered by te rising edge; 2:frame triggered by te falling edge; ;lcd_dsi_if 0:video mode; 1: Command mode; 2:video burst mode ;lcd_dsi_te 0:frame auto trigger; 1:frame triggered by te rising edge; 2:frame triggered by te falling edge; ;lcd_x: lcd horizontal resolution ;lcd_y: lcd vertical resolution ;lcd_width: width of lcd in mm ;lcd_height: height of lcd in mm ;lcd_dclk_freq: in MHZ unit ;lcd_pwm_freq: in HZ unit ;lcd_pwm_pol: lcd backlight PWM polarity ;lcd_pwm_max_limit lcd backlight PWM max limit(<=255) ;lcd_hbp: hsync back porch(pixel) + hsync plus width(pixel); ;lcd_ht: hsync total cycle(pixel) ;lcd_vbp: vsync back porch(line) + vysnc plus width(line) ;lcd_vt: vysnc total cycle(line) ;lcd_hspw: hsync plus width(pixel) ;lcd_vspw: vysnc plus width(pixel) ;lcd_lvds_if: 0:single link; 1:dual link ;lcd_lvds_colordepth: 0:8bit; 1:6bit ;lcd_lvds_mode: 0:NS mode; 1:JEIDA mode ;lcd_frm: 0:disable; 1:enable rgb666 dither; 2:enable rgb656 dither ;lcd_io_phase: 0:noraml; 1:intert phase(0~3bit: vsync phase; 4~7bit:hsync phase; ; 8~11bit:dclk phase; 12~15bit:de phase) ;lcd_gamma_en lcd gamma correction enable ;lcd_bright_curve_en lcd bright curve correction enable ;lcd_cmap_en lcd color map function enable ;deu_mode 0:smoll lcd screen; 1:large lcd screen(larger than 10inch) ;lcdgamma4iep: Smart Backlight parameter, lcd gamma vale * 10; ; decrease it while lcd is not bright enough; increase while lcd is too bright ;smart_color 90:normal lcd screen 65:retina lcd screen(9.7inch) ;Pin setting for special function ie.LVDS, RGB data or vsync ; name(donot care) = port:PD12<pin function><pull up or pull down><drive ability><output level> ;Pin setting for gpio: ; lcd_gpio_X = port:PD12<pin function><pull up or pull down><drive ability><output level> ;Pin setting for backlight enable pin ; lcd_bl_en = port:PD12<pin function><pull up or pull down><drive ability><output level> ;fsync setting, pulse to csi ;lcd_fsync_en (0:disable fsync,1:enable) ;lcd_fsync_act_time (active time of fsync, unit:pixel) ;lcd_fsync_dis_time (disactive time of fsync, unit:pixel) ;lcd_fsync_pol (0:positive;1:negative) ;gpio config: <&pio for cpu or &r_pio for cpus, port, port num, pio function, pull up or pull down(default 0), driver level(default 1), data> ;For dual link lvds: use lvds2link_pins_a and lvds2link_pins_b instead ;For rgb24: use rgb24_pins_a and rgb24_pins_b instead ;For lvds1: use lvds1_pins_a and lvds1_pins_b instead ;For lvds0: use lvds0_pins_a and lvds0_pins_b instead ;----------------------------------------------------------------------------------*/ &lcd0 { // 800 * 480 RGB LCD lcd_used = <1>; lcd_driver_name = "default_lcd"; lcd_backlight = <50>; lcd_if = <0>; lcd_x = <800>; lcd_y = <480>; lcd_width = <108>; lcd_height = <65>; lcd_dclk_freq = <24>; lcd_pwm_used = <1>; lcd_pwm_ch = <9>; lcd_pwm_freq = <50000>; lcd_pwm_pol = <0>; lcd_hbp = <12>; lcd_ht = <816>; lcd_hspw = <4>; lcd_vbp = <12>; lcd_vt = <496>; lcd_vspw = <4>; lcd_lvds_if = <0>; lcd_lvds_colordepth = <1>; lcd_lvds_mode = <0>; lcd_frm = <0>; lcd_io_phase = <0x0000>; lcd_gamma_en = <0>; lcd_bright_curve_en = <0>; lcd_cmap_en = <0>; deu_mode = <0>; lcdgamma4iep = <22>; smart_color = <90>; pinctrl-0 = <&rgb18_pins_a>; pinctrl-1 = <&rgb18_pins_b>; }; &pwm0 { pinctrl-names = "active", "sleep"; pinctrl-0 = <&pwm0_pin_a>; pinctrl-1 = <&pwm0_pin_b>; status = "okay"; }; &pwm2 { pinctrl-names = "active", "sleep"; pinctrl-0 = <&pwm2_pin_a>; pinctrl-1 = <&pwm2_pin_b>; status = "okay"; }; &pwm7 { pinctrl-names = "active", "sleep"; pinctrl-0 = <&pwm7_pin_a>; pinctrl-1 = <&pwm7_pin_b>; status = "okay"; }; &rtp { allwinner,tp-sensitive-adjust = <0xf>; allwinner,filter-type = <0x1>; allwinner,ts-attached; status = "disabled"; }; &tpadc { key_cnt = <5>; key1 = <420 115>; key2 = <870 114>; key3 = <1290 119>; key4 = <1630 373>; key5 = <1950 28>; status = "disabled"; }; &gpadc { channel_num = <1>; channel_select = <0x01>; channel_data_select = <0>; channel_compare_select = <0x01>; channel_cld_select = <0x01>; channel_chd_select = <0>; channel0_compare_lowdata = <1600000>; channel0_compare_higdata = <1200000>; channel1_compare_lowdata = <460000>; channel1_compare_higdata = <1200000>; key_cnt = <5>; key0_vol = <210>; key0_val = <0x19c>; key1_vol = <410>; key1_val = <0x197>; key2_vol = <590>; key2_val = <158>; key3_vol = <750>; key3_val = <28>; key4_vol = <880>; key4_val = <28>; status = "okay"; wakeup-source; }; &s_cir0 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&s_cir0_pins_a>; pinctrl-1 = <&s_cir0_pins_b>; ir_protocol_used = <0>; ir_addr_code0 = <0x0>; status = "okay"; }; &ir1 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&ir1_pins_a>; pinctrl-1 = <&ir1_pins_b>; status = "disabled"; }; &vind0 { csi_top = <378000000>; csi_isp = <327000000>; status = "okay"; /* enable twi and ver1 spi-nand max freq 30M */ actuator0: actuator@5809450 { device_type = "actuator0"; actuator0_name = "ad5820_act"; actuator0_slave = <0x18>; actuator0_af_pwdn = <>; actuator0_afvdd = "afvcc-csi"; actuator0_afvdd_vol = <2800000>; status = "okay"; }; flash0: flash@5809460 { device_type = "flash0"; flash0_type = <2>; flash0_en = <>; flash0_mode = <>; flash0_flvdd = ""; flash0_flvdd_vol = <>; device_id = <0>; status = "okay"; }; sensor0: sensor@5809470 { reg = <0x0 0x05809470 0x0 0x10>; device_type = "sensor0"; compatible = "allwinner,sunxi-sensor"; sensor0_mname = "ov5640"; sensor0_twi_cci_id = <2>; sensor0_twi_addr = <0x78>; sensor0_mclk_id = <0>; sensor0_pos = "rear"; sensor0_isp_used = <0>; sensor0_fmt = <0>; sensor0_stby_mode = <0>; sensor0_vflip = <0>; sensor0_hflip = <0>; sensor0_iovdd-supply = <>; sensor0_iovdd_vol = <>; sensor0_avdd-supply = <>; sensor0_avdd_vol = <>; sensor0_dvdd-supply = <>; sensor0_dvdd_vol = <>; sensor0_power_en = <>; sensor0_reset = <>; sensor0_pwdn = <>; sensor0_sm_vs = <>; flash_handle = <&flash0>; act_handle = <&actuator0>; device_id = <0>; status = "okay"; }; sensor1:sensor@5809480 { device_type = "sensor1"; sensor1_mname = "ov5640"; compatible = "allwinner,sunxi-sensor"; sensor1_twi_cci_id = <1>; sensor1_twi_addr = <0x6c>; sensor1_mclk_id = <1>; sensor1_pos = "front"; sensor1_isp_used = <0>; sensor1_fmt = <0>; sensor1_stby_mode = <0>; sensor1_vflip = <0>; sensor1_hflip = <0>; sensor1_iovdd-supply = <>; sensor1_iovdd_vol = <>; sensor1_avdd-supply = <>; sensor1_avdd_vol = <>; sensor1_dvdd-supply = <>; sensor1_dvdd_vol = <>; sensor1_power_en = <>; sensor1_reset = <&pio PE 7 GPIO_ACTIVE_LOW>; sensor1_pwdn = <&pio PE 6 GPIO_ACTIVE_LOW>; status = "disabled"; }; vinc0:vinc@5809000 { vinc0_csi_sel = <0>; vinc0_mipi_sel = <0xff>; vinc0_isp_sel = <0>; vinc0_isp_tx_ch = <0>; vinc0_tdm_rx_sel = <0xff>; vinc0_rear_sensor_sel = <0>; vinc0_front_sensor_sel = <0>; vinc0_sensor_list = <0>; status = "okay"; }; vinc1:vinc@5809200 { vinc1_csi_sel = <0>; vinc1_mipi_sel = <0xff>; vinc1_isp_sel = <0>; vinc1_isp_tx_ch = <1>; vinc1_tdm_rx_sel = <0xff>; vinc1_rear_sensor_sel = <0>; vinc1_front_sensor_sel = <0>; vinc1_sensor_list = <0>; status = "okay"; }; };
sun8iw20p1.dtsi
/* * Allwinner Technology CO., Ltd. sun8iw20p1 platform * * modify base on juno.dts */ /* optee used 7MB: SHM 2M: OS: 1M: TA:4M*/ /memreserve/ 0x41B00000 0x00100000; #include <dt-bindings/clock/sun8iw20-ccu.h> #include <dt-bindings/clock/sun8iw20-r-ccu.h> #include <dt-bindings/clock/sun8iw20-rtc.h> #include <dt-bindings/reset/sun8iw20-ccu.h> #include <dt-bindings/reset/sun8iw20-r-ccu.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/sun4i-gpio.h> #include <dt-bindings/thermal/thermal.h> #include <dt-bindings/power/r528-power.h> / { model = "sun8iw20"; compatible = "allwinner,sun8iw20p1"; interrupt-parent = <&gic>; #address-cells = <2>; #size-cells = <2>; aliases { serial0 = &uart0; serial1 = &uart1; serial2 = &uart2; serial3 = &uart3; serial4 = &uart4; serial5 = &uart5; spi0 = &spi0; spi1 = &spi1; twi0 = &twi0; twi1 = &twi1; twi2 = &twi2; twi3 = &twi3; mmc0 = &sdc0; mmc2 = &sdc2; pwm = &pwm; pwm0 = &pwm0; pwm1 = &pwm1; pwm2 = &pwm2; pwm3 = &pwm3; pwm4 = &pwm4; pwm5 = &pwm5; pwm6 = &pwm6; pwm7 = &pwm7; ir0 = &s_cir0; ve0 = &ve; tv0 = &tv0; tvd = &tvd; tvd0 = &tvd0; share_space0 = &share_space0; }; chosen { bootargs = "earlyprintk=sunxi-uart,0x2500000 loglevel=8 initcall_debug=0 console=ttyS0 init=/init"; //bootargs = "loglevel=8 initcall_debug=0 console=ttyS0 init=/init"; linux,initrd-start = <0x0 0x0>; linux,initrd-end = <0x0 0x0>; }; firmware { optee { compatible = "linaro,optee-tz"; method = "smc"; }; }; cpus { enable-method = "allwinner,sun8iw20p1"; #address-cells = <1>; #size-cells = <0>; cpu0: cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a7","arm,armv7"; reg = <0x0>; enable-method = "psci"; clocks = <&ccu CLK_CPUX>; dynamic-power-coefficient = <156>; cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; operating-points-v2 = <&cpu_opp_table>; #cooling-cells = <2>; }; cpu1: cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a7","arm,armv7"; reg = <0x1>; enable-method = "psci"; clocks = <&ccu CLK_CPUX>; cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; operating-points-v2 = <&cpu_opp_table>; #cooling-cells = <2>; }; idle-states { entry-method = "arm,psci"; CPU_SLEEP: cpu-sleep { compatible = "arm,idle-state"; arm,psci-suspend-param = <0x0010000>; entry-latency-us = <46>; exit-latency-us = <59>; min-residency-us = <3570>; local-timer-stop; }; CLUSTER_SLEEP: cluster-sleep { compatible = "arm,idle-state"; arm,psci-suspend-param = <0x1010000>; entry-latency-us = <47>; exit-latency-us = <74>; min-residency-us = <5000>; local-timer-stop; }; }; }; psci { compatible = "arm,psci-1.0"; method = "smc"; }; dump_reg: dump_reg@20000 { compatible = "allwinner,sunxi-dump-reg"; reg = <0x0 0x00020000 0x0 0x0004>; /* 0x00020000: dump_reg test addr, 0x0004: dump_reg test size */ }; cpu_opp_table: cpu-opp-table { compatible = "allwinner,sun50i-operating-points"; nvmem-cells = <&speedbin_efuse>, <&cpubin_efuse>; nvmem-cell-names = "speed", "bin"; opp-shared; opp@480000000 { opp-hz = /bits/ 64 <480000000>; clock-latency-ns = <244144>; /* 8 32k periods */ opp-microvolt-a0 = <900000>; opp-microvolt-a1 = <900000>; opp-microvolt-a2 = <900000>; opp-microvolt-b0 = <950000>; opp-supported-hw = <0x3>; }; opp@720000000 { opp-hz = /bits/ 64 <720000000>; clock-latency-ns = <244144>; /* 8 32k periods */ opp-microvolt-a0 = <900000>; opp-microvolt-a1 = <900000>; opp-microvolt-a2 = <900000>; opp-microvolt-b0 = <950000>; opp-supported-hw = <0x3>; }; opp@912000000 { opp-hz = /bits/ 64 <912000000>; clock-latency-ns = <244144>; /* 8 32k periods */ opp-microvolt-a0 = <950000>; opp-microvolt-a1 = <900000>; opp-microvolt-a2 = <900000>; opp-microvolt-b0 = <950000>; opp-supported-hw = <0x3>; }; opp@1008000000 { opp-hz = /bits/ 64 <1008000000>; clock-latency-ns = <244144>; /* 8 32k periods */ opp-microvolt-a0 = <1000000>; opp-microvolt-a1 = <900000>; opp-microvolt-a2 = <900000>; opp-microvolt-b0 = <950000>; opp-supported-hw = <0x3>; }; opp@1104000000 { opp-hz = /bits/ 64 <1104000000>; clock-latency-ns = <244144>; /* 8 32k periods */ opp-microvolt-a0 = <1050000>; opp-microvolt-a1 = <950000>; opp-microvolt-a2 = <950000>; opp-microvolt-b0 = <950000>; opp-supported-hw = <0x3>; }; opp@1200000000 { opp-hz = /bits/ 64 <1200000000>; clock-latency-ns = <244144>; /* 8 32k periods */ opp-microvolt-a0 = <1100000>; opp-microvolt-a1 = <1000000>; opp-microvolt-a2 = <1000000>; opp-supported-hw = <0x1>; }; }; dcxo24M: dcxo24M_clk { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <24000000>; clock-output-names = "dcxo24M"; }; rc_16m: rc16m_clk { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <16000000>; clock-accuracy = <300000000>; clock-output-names = "rc-16m"; }; ext_32k: ext32k_clk { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; clock-output-names = "ext-32k"; }; dram: dram { compatible = "allwinner,dram"; clocks = <&ccu CLK_PLL_DDR0>; clock-names = "pll_ddr"; }; memory@40000000 { device_type = "memory"; reg = <0x00000000 0x40000000 0x00000000 0x20000000>; }; share_space0: share_space@42100000 { #address-cells = <1>; #size-cells = <1>; deice_tpye = "share_space0"; /* dsp write addr and len */ /* arm write addr and len */ /* dsp log addr and len */ /* reserve */ reg = < 0x42100000 0x00001000 0x42101000 0x00001000 0x42102000 0x0000E000 0x00000000 0x00000000>; }; gic: interrupt-controller@3020000 { compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic"; #interrupt-cells = <3>; #address-cells = <0>; device_type = "gic"; interrupt-controller; reg = <0x0 0x03021000 0 0x1000>, /* GIC Dist */ <0x0 0x03022000 0 0x2000>, /* GIC CPU */ <0x0 0x03024000 0 0x2000>, /* GIC VCPU Control */ <0x0 0x03026000 0 0x2000>; /* GIC VCPU */ interrupts = <GIC_PPI 9 0xf04>; /* GIC Maintenence IRQ */ }; timer_arch { compatible = "arm,armv7-timer"; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; clock-frequency = <24000000>; arm,cpu-registers-not-fw-configured; interrupt-parent = <&gic>; arm,no-tick-in-suspend; }; pmu { compatible = "arm,cortex-a7-pmu"; interrupts = <GIC_SPI 172 4>, <GIC_SPI 173 4>; }; power: power-management@ff000000 { compatible = "allwinner,r528-pmu", "syscon", "simple-mfd"; reg = <0x0 0x07001000 0x0 0x400>; pd: power-controller { compatible = "allwinner,r528-power-controller"; clocks = <&r_ccu CLK_R_PPU>; clock-names = "ppu"; resets = <&r_ccu RST_R_PPU>; reset-names = "ppu_rst"; #power-domain-cells = <1>; #address-cells = <1>; #size-cells = <0>; /* These power domains are grouped by VD_SYS */ pd_ve@R528_PD_VE { reg = <R528_PD_VE>; }; }; }; mmu_aw: iommu@2010000 { compatible = "allwinner,sunxi-iommu"; reg = <0x0 0x02010000 0x0 0x1000>; interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "iommu-irq"; clocks = <&ccu CLK_BUS_IOMMU>; clock-names = "iommu"; #iommu-cells = <2>; status = "okay"; }; reg_pio1_8: pio-18 { compatible = "regulator-fixed"; regulator-name = "pio-18"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; }; reg_pio3_3: pio-33 { compatible = "regulator-fixed"; regulator-name = "pio-33"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; }; thermal-zones { cpu_thermal_zone: cpu_thermal_zone { polling-delay-passive = <500>; polling-delay = <1000>; thermal-sensors = <&ths 0>; sustainable-power = <589>; cpu_trips: trips { cpu_threshold: trip-point@0 { temperature = <70000>; type = "passive"; hysteresis = <0>; }; cpu_target: trip-point@1 { temperature = <90000>; type = "passive"; hysteresis = <0>; }; cpu_crit: cpu_crit@0 { temperature = <110000>; type = "critical"; hysteresis = <0>; }; }; cooling-maps { map0 { trip = <&cpu_target>; cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; contribution = <1024>; }; }; }; }; soc: soc@3000000 { compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; ranges; device_type = "soc"; sram_ctrl: sram_ctrl@3000000 { compatible = "allwinner,sram_ctrl"; reg = <0x0 0x3000000 0 0x16C>; soc_ver { offset = <0x24>; mask = <0x7>; shift = <0>; ver_a = <0x18590000>; ver_b = <0x18590002>; ver_d = <0x18590003>; }; soc_id { offset = <0x200>; mask = <0x1>; shift = <22>; }; soc_bin { offset = <0x0>; mask = <0x3ff>; shift = <0x0>; }; }; rtc_ccu: rtc_ccu@7090000 { compatible = "allwinner,sun8iw20-rtc-ccu"; device_type = "rtc-ccu"; reg = <0x0 0x07090000 0x0 0x320>; /* The same as rtc */ #clock-cells = <1>; }; ccu: ccu@2001000 { compatible = "allwinner,sun8iw20-ccu"; reg = <0x0 0x02001000 0x0 0x1000>; clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>; clock-names = "hosc", "losc", "iosc"; #clock-cells = <1>; #reset-cells = <1>; }; r_ccu: r_ccu@7010000 { compatible = "allwinner,sun8iw20-r-ccu"; reg = <0x0 0x07010000 0x0 0x240>; clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>, <&ccu CLK_PLL_PERIPH0>; clock-names = "hosc", "losc", "iosc", "pll-periph0"; #clock-cells = <1>; #reset-cells = <1>; }; rtc: rtc@7090000 { compatible = "allwinner,sun8iw20-rtc"; device_type = "rtc"; wakeup-source; reg = <0x0 0x07090000 0x0 0x320>; interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; clocks = <&r_ccu CLK_R_AHB_BUS_RTC>, <&rtc_ccu CLK_RTC_1K>, <&rtc_ccu CLK_RTC_SPI>; clock-names = "r-ahb-rtc", "rtc-1k", "rtc-spi"; resets = <&r_ccu RST_R_AHB_BUS_RTC>; gpr_cur_pos = <6>; }; dma:dma-controller@3002000 { compatible = "allwinner,sun8iw20-dma"; reg = <0x0 0x03002000 0x0 0x1000>; interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>; clock-names = "bus", "mbus"; dma-channels = <8>; dma-requests = <48>; resets = <&ccu RST_BUS_DMA>; #dma-cells = <1>; }; soc_timer0: timer@2050000 { compatible = "allwinner,sun4i-a10-timer"; device_type = "soc_timer"; reg = <0x0 0x02050000 0x0 0xA0>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; clocks = <&dcxo24M>; }; wdt: watchdog@20500A0 { compatible = "allwinner,sun6i-a31-wdt"; reg = <0x0 0x020500A0 0x0 0x20>; /* In Timers Spec */ interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; /* In GIC Spec */ }; mbus0: mbus-controller@3102000 { compatible = "allwinner,sun8i-mbus"; reg = <0x0 0x03102000 0x0 0x1000>; /* In SDRAM Controller Spec: DRAMC Common Register */ #mbus-cells = <1>; }; pio: pinctrl@2000000 { compatible = "allwinner,sun8iw20-pinctrl"; reg = <0x0 0x02000000 0x0 0x500>; interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>, /* AW1859_GIC_Spec: GPIOB: 101-32=69 */ <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; device_type = "pio"; clocks = <&ccu CLK_APB0>, <&dcxo24M>, <&rtc_ccu CLK_OSC32K>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <3>; interrupt-controller; #interrupt-cells = <3>; #size-cells = <0>; vcc-pf-supply = <®_pio1_8>; vcc-pfo-supply = <®_pio3_3>; test_pins_a: test_pins@0 { allwinner,pins = "PB0", "PB1"; allwinner,function = "test"; allwinner,muxsel = <0x9>; allwinner,drive = <1>; allwinner,pull = <1>; }; test_pins_b: test_pins@1 { pins = "PB0", "PB1"; function = "io_disabled"; allwinner,muxsel = <0xF>; allwinner,drive = <1>; allwinner,pull = <1>; }; csi_mclk0_pins_a: csi_mclk0@0 { pins = "PE3"; function = "csi0"; drive-strength = <10>; }; csi_mclk0_pins_b: csi_mclk0@1 { pins = "PE3"; function = "gpio_in"; }; csi0_pins_a: csi0@0 { pins = "PE2", "PE0", "PE1", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11"; function = "ncsi0"; drive-strength = <10>; }; csi0_pins_b: csi0@1 { pins = "PE2", "PE0", "PE1", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11"; function = "io_disabled"; drive-strength = <10>; }; lvds0_pins_a: lvds0@0 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9"; function = "lvds0"; drive-strength = <30>; bias-disable; }; lvds0_pins_b: lvds0@1 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9"; function = "io_disabled"; drive-strength = <30>; bias-disable; }; rgb24_pins_a: rgb24@0 { pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \ "PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \ "PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \ "PD18", "PD19", "PD20", "PD21"; function = "lcd0"; drive-strength = <30>; bias-disable; }; rgb24_pins_b: rgb24@1 { pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \ "PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \ "PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \ "PD18", "PD19", "PD20", "PD21"; function = "io_disabled"; bias-disable; }; rgb18_pins_a: rgb18@0 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \ "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \ "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \ "PD18", "PD19", "PD20", "PD21"; function = "lcd0"; drive-strength = <30>; bias-disable; }; rgb18_pins_b: rgb18@1 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \ "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \ "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \ "PD18", "PD19", "PD20", "PD21"; function = "io_disabled"; bias-disable; }; dsi2lane_pins_a: dsi2lane@0 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5"; function = "dsi"; drive-strength = <30>; bias-disable; }; dsi2lane_pins_b: dsi2lane@1 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5"; function = "io_disabled"; bias-disable; }; dsi4lane_pins_a: dsi4lane@0 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9"; function = "dsi"; drive-strength = <30>; bias-disable; }; dsi4lane_pins_b: dsi4lane@1 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9"; function = "io_disabled"; bias-disable; }; }; pinctrl_test: pinctrl_test@0 { reg = <0x0 0x0 0x0 0x0>; compatible = "allwinner,sunxi-pinctrl-test"; device_type = "pinctrl-test"; /* For pin state selecting test */ pinctrl-0 = <&test_pins_a>; pinctrl-1 = <&test_pins_b>; pinctrl-names = "default", "sleep"; /* For pin basic_function/irq test */ test-gpios = <&pio PB 0 GPIO_ACTIVE_LOW>; interrupt-parent = <&pio>; interrupts = <PB 1 IRQ_TYPE_LEVEL_HIGH>; }; uart0: uart@2500000 { compatible = "allwinner,sun8i-uart"; device_type = "uart0"; reg = <0x0 0x02500000 0x0 0x400>; interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; sunxi,uart-fifosize = <64>; clocks = <&ccu CLK_BUS_UART0>; clock-names = "uart0"; resets = <&ccu RST_BUS_UART0>; uart0_port = <0>; uart0_type = <2>; status = "disabled"; }; uart1: uart@2500400 { compatible = "allwinner,sun8i-uart"; device_type = "uart1"; reg = <0x0 0x02500400 0x0 0x400>; interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; sunxi,uart-fifosize = <256>; clocks = <&ccu CLK_BUS_UART1>; clock-names = "uart1"; resets = <&ccu RST_BUS_UART1>; uart1_port = <1>; uart1_type = <4>; status = "okay"; }; uart2: uart@2500800 { compatible = "allwinner,sun8i-uart"; device_type = "uart2"; reg = <0x0 0x02500800 0x0 0x400>; interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; sunxi,uart-fifosize = <256>; clocks = <&ccu CLK_BUS_UART2>; clock-names = "uart2"; resets = <&ccu RST_BUS_UART2>; uart2_port = <2>; uart2_type = <4>; status = "disabled"; }; uart3: uart@2500c00 { compatible = "allwinner,sun8i-uart"; device_type = "uart3"; reg = <0x0 0x02500c00 0x0 0x400>; interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; sunxi,uart-fifosize = <256>; clocks = <&ccu CLK_BUS_UART3>; clock-names = "uart3"; resets = <&ccu RST_BUS_UART3>; uart3_port = <3>; uart3_type = <4>; status = "disabled"; }; uart4: uart@2501000 { compatible = "allwinner,sun8i-uart"; device_type = "uart4"; reg = <0x0 0x02501000 0x0 0x400>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; sunxi,uart-fifosize = <256>; clocks = <&ccu CLK_BUS_UART4>; clock-names = "uart4"; resets = <&ccu RST_BUS_UART4>; uart4_port = <4>; uart4_type = <2>; status = "disabled"; }; uart5: uart@2501400 { compatible = "allwinner,sun8i-uart"; device_type = "uart5"; reg = <0x0 0x02501400 0x0 0x400>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; sunxi,uart-fifosize = <256>; clocks = <&ccu CLK_BUS_UART5>; clock-names = "uart5"; resets = <&ccu RST_BUS_UART5>; uart5_port = <5>; uart5_type = <2>; status = "disabled"; }; cryptoengine: ce@03040000 { compatible = "allwinner,sunxi-ce"; device_name = "ce"; reg = <0x0 0x03040000 0x0 0xa0>, /* non-secure space */ <0x0 0x03040800 0x0 0xa0>; /* secure space */ interrupts = <GIC_SPI 52 IRQ_TYPE_EDGE_RISING>, /*non-secure*/ <GIC_SPI 53 IRQ_TYPE_EDGE_RISING>; /* secure*/ clock-frequency = <400000000>; /* 400MHz */ clocks = <&ccu CLK_BUS_CE>, <&ccu CLK_CE>, <&ccu CLK_MBUS_CE>, <&ccu CLK_PLL_PERIPH0_2X>; clock-names = "bus_ce", "ce_clk", "mbus_ce", "pll_periph0_2x"; resets = <&ccu RST_BUS_CE>; status = "okay"; }; gmac0: eth@4500000 { compatible = "allwinner,sunxi-gmac"; reg = <0x0 0x04500000 0x0 0x10000>, <0x0 0x03000030 0x0 0x4>; interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "gmacirq"; clocks = <&ccu CLK_BUS_EMAC0>, <&ccu CLK_EMAC0_25M>; clock-names = "gmac", "ephy"; resets = <&ccu RST_BUS_EMAC0>; device_type = "gmac0"; gmac-power0; gmac-power1; gmac-power2; status = "disabled"; }; sdc2: sdmmc@4022000 { compatible = "allwinner,sunxi-mmc-v4p6x"; device_type = "sdc2"; reg = <0x0 0x04022000 0x0 0x1000>; interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; clocks = <&dcxo24M>, <&ccu CLK_PLL_PERIPH0_2X>, <&ccu CLK_MMC2>, <&ccu CLK_BUS_MMC2>; clock-names = "osc24m","pll_periph","mmc","ahb"; resets = <&ccu RST_BUS_MMC2>; reset-names = "rst"; pinctrl-names = "default","sleep"; pinctrl-0 = <&sdc2_pins_a>; pinctrl-1 = <&sdc2_pins_b>; bus-width = <4>; req-page-count = <2>; cap-mmc-highspeed; cap-cmd23; mmc-cache-ctrl; non-removable; /*max-frequency = <200000000>;*/ max-frequency = <50000000>; cap-erase; mmc-high-capacity-erase-size; no-sdio; no-sd; /*-- speed mode --*/ /*sm0: DS26_SDR12*/ /*sm1: HSSDR52_SDR25*/ /*sm2: HSDDR52_DDR50*/ /*sm3: HS200_SDR104*/ /*sm4: HS400*/ /*-- frequency point --*/ /*f0: CLK_400K*/ /*f1: CLK_25M*/ /*f2: CLK_50M*/ /*f3: CLK_100M*/ /*f4: CLK_150M*/ /*f5: CLK_200M*/ sdc_tm4_sm0_freq0 = <0>; sdc_tm4_sm0_freq1 = <0>; sdc_tm4_sm1_freq0 = <0x00000000>; sdc_tm4_sm1_freq1 = <0>; sdc_tm4_sm2_freq0 = <0x00000000>; sdc_tm4_sm2_freq1 = <0>; sdc_tm4_sm3_freq0 = <0x05000000>; sdc_tm4_sm3_freq1 = <0x00000005>; sdc_tm4_sm4_freq0 = <0x00050000>; sdc_tm4_sm4_freq1 = <0x00000004>; sdc_tm4_sm4_freq0_cmd = <0>; sdc_tm4_sm4_freq1_cmd = <0>; /*vmmc-supply = <®_3p3v>;*/ /*vqmc-supply = <®_3p3v>;*/ /*vdmc-supply = <®_3p3v>;*/ /*vmmc = "vcc-card";*/ /*vqmc = "";*/ /*vdmc = "";*/ /*sunxi-power-save-mode;*/ }; sdc0: sdmmc@4020000 { compatible = "allwinner,sunxi-mmc-v5p3x"; device_type = "sdc0"; reg = <0x0 0x04020000 0x0 0x1000>; interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; clocks = <&dcxo24M>, <&ccu CLK_PLL_PERIPH0_2X>, <&ccu CLK_MMC0>, <&ccu CLK_BUS_MMC0>; clock-names = "osc24m","pll_periph","mmc","ahb"; resets = <&ccu RST_BUS_MMC0>; reset-names = "rst"; pinctrl-names = "default","mmc_1v8","sleep","uart_jtag"; pinctrl-0 = <&sdc0_pins_a>; pinctrl-1 = <&sdc0_pins_b>; pinctrl-2 = <&sdc0_pins_c>; pinctrl-3 = <&sdc0_pins_d &sdc0_pins_e>; max-frequency = <50000000>; bus-width = <4>; req-page-count = <2>; /*non-removable;*/ /*broken-cd;*/ /*cd-inverted*/ /*cd-gpios = <&pio PF 6 GPIO_ACTIVE_LOW>;*/ /* vmmc-supply = <®_3p3v>;*/ /* vqmc-supply = <®_3p3v>;*/ /* vdmc-supply = <®_3p3v>;*/ /*vmmc = "vcc-card";*/ /*vqmc = "";*/ /*vdmc = "";*/ cap-sd-highspeed; cap-wait-while-busy; no-sdio; no-mmc; /*sd-uhs-sdr50;*/ /*sd-uhs-ddr50;*/ /*cap-sdio-irq;*/ /*keep-power-in-suspend;*/ /*ignore-pm-notify;*/ /*sunxi-power-save-mode;*/ /*sunxi-dly-400k = <1 0 0 0>; */ /*sunxi-dly-26M = <1 0 0 0>;*/ /*sunxi-dly-52M = <1 0 0 0>;*/ /*sunxi-dly-52M-ddr4 = <1 0 0 0>;*/ /*sunxi-dly-52M-ddr8 = <1 0 0 0>;*/ /*sunxi-dly-104M = <1 0 0 0>;*/ /*sunxi-dly-208M = <1 0 0 0>;*/ /*sunxi-dly-104M-ddr = <1 0 0 0>;*/ /*sunxi-dly-208M-ddr = <1 0 0 0>;*/ }; sdc1: sdmmc@4021000 { compatible = "allwinner,sunxi-mmc-v5p3x"; device_type = "sdc1"; reg = <0x0 0x04021000 0x0 0x1000>; interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; clocks = <&dcxo24M>, <&ccu CLK_PLL_PERIPH0_2X>, <&ccu CLK_MMC1>, <&ccu CLK_BUS_MMC1>; clock-names = "osc24m","pll_periph","mmc","ahb"; resets = <&ccu RST_BUS_MMC1>; reset-names = "rst"; pinctrl-names = "default","sleep"; pinctrl-0 = <&sdc1_pins_a>; pinctrl-1 = <&sdc1_pins_b>; max-frequency = <50000000>; bus-width = <4>; /*broken-cd;*/ /*cd-inverted*/ /*cd-gpios = <&pio PG 6 6 1 2 0>;*/ /* vmmc-supply = <®_3p3v>;*/ /* vqmc-supply = <®_3p3v>;*/ /* vdmc-supply = <®_3p3v>;*/ /*vmmc = "vcc-card";*/ /*vqmc = "";*/ /*vdmc = "";*/ cap-sd-highspeed; no-mmc; /*sd-uhs-sdr50;*/ /*sd-uhs-ddr50;*/ /*sd-uhs-sdr104;*/ /*cap-sdio-irq;*/ keep-power-in-suspend; /*ignore-pm-notify;*/ /*sunxi-power-save-mode;*/ /*sunxi-dly-400k = <1 0 0 0 0>; */ /*sunxi-dly-26M = <1 0 0 0 0>;*/ /*sunxi-dly-52M = <1 0 0 0 0>;*/ sunxi-dly-52M-ddr4 = <1 0 0 0 2>; /*sunxi-dly-52M-ddr8 = <1 0 0 0 0>;*/ sunxi-dly-104M = <1 0 0 0 1>; /*sunxi-dly-208M = <1 1 0 0 0>;*/ sunxi-dly-208M = <1 0 0 0 1>; /*sunxi-dly-104M-ddr = <1 0 0 0 0>;*/ /*sunxi-dly-208M-ddr = <1 0 0 0 0>;*/ status = "okay"; }; tpadc: tpadc@2009c00 { compatible = "allwinner,tp_key"; reg = <0x0 0x02009c00 0x0 0x400>; interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_TPADC>, <&ccu CLK_BUS_TPADC>; clock-names = "mod", "bus"; clock-frequency = <1000000>; resets = <&ccu RST_BUS_TPADC>; status = "disabled"; }; rtp:rtp@2009c00 { compatible = "allwinner,sun8i-ts"; reg = <0x0 0x02009c00 0x0 0x400>; clocks = <&ccu CLK_TPADC>, <&ccu CLK_BUS_TPADC>; clock-names = "mod", "bus"; clock-frequency = <1000000>; resets = <&ccu RST_BUS_TPADC>; interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; }; spi0: spi@4025000 { #address-cells = <1>; #size-cells = <0>; compatible = "allwinner,sun8i-spi"; device_type = "spi0"; reg = <0x0 0x04025000 0x0 0x1000>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI0>, <&ccu CLK_BUS_SPI0>; clock-names = "pll", "mod", "bus"; resets = <&ccu RST_BUS_SPI0>; clock-frequency = <100000000>; spi0_cs_number = <1>; spi0_cs_bitmap = <1>; dmas = <&dma 22>, <&dma 22>; dma-names = "tx", "rx"; status = "disabled"; }; spi1: spi@4026000 { #address-cells = <1>; #size-cells = <0>; compatible = "allwinner,sun8i-spi"; device_type = "spi1"; reg = <0x0 0x04026000 0x0 0x1000>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI1>, <&ccu CLK_BUS_SPI1>; clock-names = "pll", "mod", "bus"; resets = <&ccu RST_BUS_SPI1>; clock-frequency = <100000000>; spi1_cs_number = <1>; spi1_cs_bitmap = <1>; dmas = <&dma 23>, <&dma 23>; dma-names = "tx", "rx"; status = "disabled"; }; ve: ve@1c0e000 { compatible = "allwinner,sunxi-cedar-ve"; reg = <0x0 0x01c0e000 0x0 0x1000>, <0x0 0x03000000 0x0 0x10>, <0x0 0x03001000 0x0 0x1000>; interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_VE>, <&ccu CLK_VE>, <&ccu CLK_MBUS_VE>; clock-names = "bus_ve", "ve", "mbus_ve"; resets = <&ccu RST_BUS_VE>; power-domains = <&pd R528_PD_VE>; iommus = <&mmu_aw 0 1>; status = "okay"; }; twi0: twi@2502000{ #address-cells = <1>; #size-cells = <0>; compatible = "allwinner,sun8i-twi"; device_type = "twi0"; reg = <0x0 0x02502000 0x0 0x400>; interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C0>; resets = <&ccu RST_BUS_I2C0>; clock-names = "bus"; clock-frequency = <400000>; status = "disabled"; }; twi1: twi@2502400{ #address-cells = <1>; #size-cells = <0>; compatible = "allwinner,sun8i-twi"; device_type = "twi1"; reg = <0x0 0x02502400 0x0 0x400>; interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C1>; resets = <&ccu RST_BUS_I2C1>; clock-names = "bus"; clock-frequency = <200000>; status = "disabled"; }; twi2: twi@2502800{ #address-cells = <1>; #size-cells = <0>; compatible = "allwinner,sun8i-twi"; device_type = "twi2"; reg = <0x0 0x02502800 0x0 0x400>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C2>; resets = <&ccu RST_BUS_I2C2>; clock-names = "bus"; clock-frequency = <100000>; status = "disabled"; }; twi3: twi@2502c00{ #address-cells = <1>; #size-cells = <0>; compatible = "allwinner,sun8i-twi"; device_type = "twi3"; reg = <0x0 0x02502c00 0x0 0x400>; interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C3>; resets = <&ccu RST_BUS_I2C3>; clock-names = "bus"; clock-frequency = <100000>; status = "disabled"; }; ledc: ledc@2008000 { #address-cells = <1>; #size-cells = <0>; compatible = "allwinner,sunxi-leds"; reg = <0x0 0x02008000 0x0 0x400>; interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "ledcirq"; clocks = <&ccu CLK_LEDC>, <&ccu CLK_BUS_LEDC>; clock-names = "clk_ledc", "clk_cpuapb"; dmas = <&dma 42>, <&dma 42>; dma-names = "rx", "tx"; resets = <&ccu RST_BUS_LEDC>; reset-names = "ledc_reset"; status = "disable"; }; pwm: pwm@2000c00 { #pwm-cells = <0x3>; compatible = "allwinner,sunxi-pwm"; reg = <0x0 0x02000c00 0x0 0x400>; clocks = <&ccu CLK_BUS_PWM>; resets = <&ccu RST_BUS_PWM>; pwm-number = <8>; pwm-base = <0x0>; sunxi-pwms = <&pwm0>, <&pwm1>, <&pwm2>, <&pwm3>, <&pwm4>, <&pwm5>, <&pwm6>, <&pwm7>; }; pwm0: pwm0@2000c10 { compatible = "allwinner,sunxi-pwm0"; pinctrl-names = "active", "sleep"; reg = <0x0 0x02000c10 0x0 0x4>; reg_base = <0x02000c00>; }; pwm1: pwm1@2000c11 { compatible = "allwinner,sunxi-pwm1"; pinctrl-names = "active", "sleep"; reg = <0x0 0x02000c11 0x0 0x4>; reg_base = <0x02000c00>; }; pwm2: pwm2@2000c12 { compatible = "allwinner,sunxi-pwm2"; pinctrl-names = "active", "sleep"; reg = <0x0 0x02000c12 0x0 0x4>; reg_base = <0x02000c00>; }; pwm3: pwm3@2000c13 { compatible = "allwinner,sunxi-pwm3"; pinctrl-names = "active", "sleep"; reg = <0x0 0x02000c13 0x0 0x4>; reg_base = <0x02000c00>; }; pwm4: pwm4@2000c14 { compatible = "allwinner,sunxi-pwm4"; pinctrl-names = "active", "sleep"; reg = <0x0 0x02000c14 0x0 0x4>; reg_base = <0x02000c00>; }; pwm5: pwm5@2000c15 { compatible = "allwinner,sunxi-pwm5"; pinctrl-names = "active", "sleep"; reg = <0x0 0x02000c15 0x0 0x4>; reg_base = <0x02000c00>; }; pwm6: pwm6@2000c16 { compatible = "allwinner,sunxi-pwm6"; pinctrl-names = "active", "sleep"; reg = <0x0 0x02000c16 0x0 0x4>; reg_base = <0x02000c00>; }; pwm7: pwm7@2000c17 { compatible = "allwinner,sunxi-pwm7"; pinctrl-names = "active", "sleep"; reg = <0x0 0x02000c17 0x0 0x4>; reg_base = <0x02000c00>; }; lcd_fb0: lcd_fb0@0 { compatible = "allwinner,sunxi-lcd_fb0"; pinctrl-names = "active","sleep"; status = "okay"; }; keyboard0: keyboard@2009800 { compatible = "allwinner,keyboard_1350mv"; reg = <0x0 0x02009800 0x0 0x400>; interrupts = <GIC_SPI 61 IRQ_TYPE_EDGE_RISING>; clocks = <&ccu CLK_BUS_LRADC>; clock-names = "mclk"; resets = <&ccu RST_BUS_LRADC>; key_cnt = <5>; key0 = <210 115>; key1 = <410 114>; key2 = <590 139>; key3 = <750 28>; key4 = <880 172>; wakeup-source; status = "okay"; }; sid@3006000 { compatible = "allwinner,sun8iw20p1-sid", "allwinner,sunxi-sid"; reg = <0x0 0x03006000 0 0x1000>; #address-cells = <1>; #size-cells = <1>; secure_status { reg = <0x0 0>; offset = <0xa0>; size = <0x4>; }; chipid { reg = <0x0 0>; offset = <0x200>; size = <0x10>; }; rotpk { reg = <0x0 0>; offset = <0x140>; size = <0x4>; }; speedbin_efuse: speedbin@00 { reg = <0x00 4>; }; cpubin_efuse: cpubin@28 { reg = <0x28 4>; }; ths_calib: calib@14 { reg = <0x14 8>; }; }; gpadc: gpadc@2009000 { compatible = "allwinner,sunxi-gpadc"; reg = <0x0 0x02009000 0x0 0x400>; interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_GPADC>; clock-names = "bus"; resets = <&ccu RST_BUS_GPADC>; status = "okay"; }; vind0: vind@5800800 { compatible = "allwinner,sunxi-vin-media", "simple-bus"; #address-cells = <2>; #size-cells = <2>; ranges; device_id = <0>; csi_top = <336000000>; csi_isp = <327000000>; reg = <0x0 0x05800800 0x0 0x200>, <0x0 0x05800000 0x0 0x800>; clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>, <&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>, <&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>; clock-names = "csi_top", "csi_top_src", "csi_mclk0", "csi_mclk0_24m", "csi_mclk0_pll", "csi_bus", "csi_mbus"; resets = <&ccu RST_BUS_CSI>; reset-names = "csi_ret"; pinctrl-names = "mclk0-default", "mclk0-sleep"; pinctrl-0 = <&csi_mclk0_pins_a>; pinctrl-1 = <&csi_mclk0_pins_b>; status = "okay"; csi0: csi@5801000{ compatible = "allwinner,sunxi-csi"; reg = <0x0 0x05801000 0x0 0x1000>; interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default","sleep"; pinctrl-0 = <&csi0_pins_a>; pinctrl-1 = <&csi0_pins_b>; device_id = <0>; iommus = <&mmu_aw 1 1>; status = "okay"; }; isp0: isp@5809410 { compatible = "allwinner,sunxi-isp"; reg = <0x0 0x05809410 0x0 0x10>; device_id = <0xfe>; status = "okay"; }; isp1: isp@5809420 { compatible = "allwinner,sunxi-isp"; reg = <0x0 0x05809420 0x0 0x10>; device_id = <0xff>; status = "okay"; }; scaler0: scaler@5809430 { compatible = "allwinner,sunxi-scaler"; reg = <0x0 0x05809430 0x0 0x10>; device_id = <0xfe>; status = "okay"; }; scaler1: scaler@5809440 { compatible = "allwinner,sunxi-scaler"; reg = <0x0 0x05809440 0x0 0x10>; device_id = <0xff>; status = "okay"; }; actuator0: actuator@5809450 { compatible = "allwinner,sunxi-actuator"; device_type = "actuator0"; reg = <0x0 0x05809450 0x0 0x10>; actuator0_name = "ad5820_act"; actuator0_slave = <0x18>; actuator0_af_pwdn = <>; actuator0_afvdd = "afvcc-csi"; actuator0_afvdd_vol = <2800000>; status = "disabled"; }; flash0: flash@5809460 { device_type = "flash0"; compatible = "allwinner,sunxi-flash"; reg = <0x0 0x05809460 0x0 0x10>; flash0_type = <2>; flash0_en = <>; flash0_mode = <>; flash0_flvdd = ""; flash0_flvdd_vol = <>; device_id = <0>; status = "disabled"; }; sensor0: sensor@5809470 { reg = <0x0 0x05809470 0x0 0x10>; device_type = "sensor0"; compatible = "allwinner,sunxi-sensor"; sensor0_mname = "ov5640"; sensor0_twi_cci_id = <2>; sensor0_twi_addr = <0x78>; sensor0_mclk_id = <0>; sensor0_pos = "rear"; sensor0_isp_used = <0>; sensor0_fmt = <0>; sensor0_stby_mode = <0>; sensor0_vflip = <0>; sensor0_hflip = <0>; sensor0_iovdd-supply = <>; sensor0_iovdd_vol = <>; sensor0_avdd-supply = <>; sensor0_avdd_vol = <>; sensor0_dvdd-supply = <>; sensor0_dvdd_vol = <>; sensor0_power_en = <>; sensor0_reset = <&pio PE 9 GPIO_ACTIVE_LOW>; sensor0_pwdn = <&pio PE 8 GPIO_ACTIVE_LOW>; sensor0_sm_vs = <>; flash_handle = <&flash0>; act_handle = <&actuator0>; device_id = <0>; status = "disabled"; }; sensor1: sensor@5809480 { reg = <0x0 0x05809480 0x0 0x10>; device_type = "sensor1"; compatible = "allwinner,sunxi-sensor"; sensor1_mname = "ov5647"; sensor1_twi_cci_id = <3>; sensor1_twi_addr = <0x6c>; sensor1_mclk_id = <1>; sensor1_pos = "front"; sensor1_isp_used = <0>; sensor1_fmt = <0>; sensor1_stby_mode = <0>; sensor1_vflip = <0>; sensor1_hflip = <0>; sensor1_iovdd-supply = <>; sensor1_iovdd_vol = <>; sensor1_avdd-supply = <>; sensor1_avdd_vol = <>; sensor1_dvdd-supply = <>; sensor1_dvdd_vol = <>; sensor1_power_en = <>; sensor1_reset = <&pio PE 7 GPIO_ACTIVE_LOW>; sensor1_pwdn = <&pio PE 6 GPIO_ACTIVE_LOW>; sensor1_sm_vs = <>; flash_handle = <>; act_handle = <>; device_id = <1>; status = "disabled"; }; vinc0: vinc@5809000 { compatible = "allwinner,sunxi-vin-core"; device_type = "vinc0"; reg = <0x0 0x05809000 0x0 0x200>; interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; vinc0_csi_sel = <0>; vinc0_mipi_sel = <0xff>; vinc0_isp_sel = <0>; vinc0_tdm_rx_sel = <0xff>; vinc0_rear_sensor_sel = <0>; vinc0_front_sensor_sel = <0>; vinc0_sensor_list = <0>; device_id = <0>; iommus = <&mmu_aw 1 1>; status = "okay"; }; vinc1: vinc@5809200 { device_type = "vinc1"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x05809200 0x0 0x200>; interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; vinc1_csi_sel = <0>; vinc1_mipi_sel = <0xff>; vinc1_isp_sel = <1>; vinc1_tdm_rx_sel = <0xff>; vinc1_rear_sensor_sel = <0>; vinc1_front_sensor_sel = <0>; vinc1_sensor_list = <0>; device_id = <1>; iommus = <&mmu_aw 1 1>; status = "okay"; }; }; s_cir0: s_cir@7040000 { compatible = "allwinner,s_cir"; reg = <0x0 0x07040000 0x0 0x400>; interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>; clocks = <&r_ccu CLK_R_APB0_BUS_IRRX>, <&dcxo24M>, <&r_ccu CLK_R_APB0_IRRX>; clock-names = "bus", "pclk", "mclk"; resets = <&r_ccu RST_R_APB0_BUS_IRRX>; status = "disabled"; }; ir1: ir@2003000 { compatible = "allwinner,irtx"; reg = <0x0 0x02003000 0x0 0x400>; interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_IR_TX>, <&dcxo24M>, <&ccu CLK_IR_TX>; clock-names = "bus", "pclk", "mclk"; resets = <&ccu RST_BUS_IR_TX>; status = "disabled"; }; di: deinterlace@5400000 { compatible = "allwinner,sunxi-deinterlace"; reg = <0x0 0x05400000 0x0 0x0000ffff>; interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_DI>, <&ccu CLK_BUS_DI>, <&ccu CLK_PLL_PERIPH0_2X>; clock-names = "clk_di", "pll_periph", "clk_bus_di"; resets = <&ccu RST_BUS_DI>; reset-names = "rst_bus_di"; assigned-clocks = <&ccu CLK_DI>; assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>; assigned-clock-rates = <300000000>; iommus = <&mmu_aw 4 1>; status = "okay"; }; g2d: g2d@5410000 { compatible = "allwinner,sunxi-g2d"; reg = <0x0 0x05410000 0x0 0x3ffff>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_G2D>, <&ccu CLK_G2D>, <&ccu CLK_MBUS_G2D>; clock-names = "bus", "g2d", "mbus_g2d"; resets = <&ccu RST_BUS_G2D>; iommus = <&mmu_aw 3 1>; status = "okay"; }; disp: disp@5000000 { compatible = "allwinner,sunxi-disp"; reg = <0x0 0x05000000 0x0 0x3fffff>, /* de0 */ <0x0 0x05460000 0x0 0xfff>, /*display_if_top*/ <0x0 0x05461000 0x0 0xfff>, /* tcon-lcd0 */ <0x0 0x05470000 0x0 0xfff>, /* tcon-tv */ <0x0 0x05450000 0x0 0x1fff>; /* dsi0*/ interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>,/*tcon-lcd0*/ <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,/*tcon-tv */ <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>;/*dsi*/ clocks = <&ccu CLK_DE0>, <&ccu CLK_DE0>, <&ccu CLK_BUS_DE0>, <&ccu CLK_BUS_DE0>, <&ccu CLK_BUS_DPSS_TOP0>, <&ccu CLK_BUS_DPSS_TOP0>, <&ccu CLK_MIPI_DSI>, <&ccu CLK_BUS_MIPI_DSI>, <&ccu CLK_TCON_LCD0>, <&ccu CLK_TCON_TV>, <&ccu CLK_BUS_TCON_LCD0>, <&ccu CLK_BUS_TCON_TV>, <&ccu CLK_MIPI_DSI>, <&ccu CLK_BUS_MIPI_DSI>; clock-names = "clk_de0", "clk_de1", "clk_bus_de0", "clk_bus_de1", "clk_bus_dpss_top0", "clk_bus_dpss_top1", "clk_mipi_dsi0", "clk_bus_mipi_dsi0", "clk_tcon0", "clk_tcon1",/*tcon-tv actually*/ "clk_bus_tcon0", "clk_bus_tcon1",/*tcon-tv actually*/ "clk_mipi_dsi0", "clk_bus_mipi_dsi0"; resets = <&ccu RST_BUS_DE0>, <&ccu RST_BUS_DE0>, <&ccu RST_BUS_DPSS_TOP0>, <&ccu RST_BUS_DPSS_TOP0>, <&ccu RST_BUS_MIPI_DSI>, <&ccu RST_BUS_TCON_LCD0>, <&ccu RST_BUS_TCON_TV>, <&ccu RST_BUS_LVDS0>; reset-names = "rst_bus_de0", "rst_bus_de1", "rst_bus_dpss_top0", "rst_bus_dpss_top1", "rst_bus_mipi_dsi0", "rst_bus_tcon0", "rst_bus_tcon1", "rst_bus_lvds0"; assigned-clocks = <&ccu CLK_DE0>, <&ccu CLK_MIPI_DSI>, <&ccu CLK_TCON_LCD0>, <&ccu CLK_TCON_TV>; assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>, <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_PLL_VIDEO0_4X>, <&ccu CLK_PLL_VIDEO1_4X>; assigned-clock-rates = <300000000>, <150000000>, <0>, <0>; boot_disp = <0>; boot_disp1 = <0>; boot_disp2 = <0>; fb_base = <0>; iommus = <&mmu_aw 2 0>; status = "okay"; }; lcd0: lcd0@5461000 { compatible = "allwinner,sunxi-lcd0"; reg = <0x0 0x05461000 0x0 0xfff>; pinctrl-names = "active","sleep"; status = "okay"; }; tv0: tv0@5600000 { compatible = "allwinner,sunxi-tv"; reg = <0x0 0x05600000 0x0 0x3fff>, <0x0 0x05604000 0x0 0x3fff>; clocks = <&ccu CLK_BUS_TVE_TOP>, <&ccu CLK_TVE>, <&ccu CLK_BUS_TVE>; clock-names = "clk_bus_tve_top", "clk_tve", "clk_bus_tve"; resets = <&ccu RST_BUS_TVE_TOP>, <&ccu RST_BUS_TVE>; reset-names = "rst_bus_tve_top", "rst_bus_tve"; device_type = "tv0"; pinctrl-names = "active","sleep"; status = "okay"; }; hwspinlock: hwspinlock@0x3005000 { compatible = "allwinner,sunxi-hwspinlock"; reg = <0x0 0x3005000 0x0 0x1000>; #hwlock-cells = <1>; clocks = <&ccu CLK_BUS_SPINLOCK>; clock-names = "clk_hwspinlock_bus"; resets = <&ccu RST_BUS_SPINLOCK>; reset-names = "rst"; num-locks = <32>; status = "disabled"; }; /* old msgbox in dts msgbox: msgbox@3003000 { compatible = "sunxi,msgbox-amp"; reg = <0x0 0x03003000 0x0 0x1000>, <0x0 0x01701000 0x0 0x1000>, <0x0 0x0601f000 0x0 0x1000>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_MSGBOX0>; rpmsg_id = "sunxi,dsp-msgbox","sunxi,dsp-power-msgbox"; resets = <&ccu RST_BUS_MSGBOX0>; reset-names = "rst"; msgbox_amp_counts = <3>; msgbox_amp_local = <0>; rpmsg_amp_remote-0 = <1>; rpmsg_read_channel-0 = <1>; rpmsg_write_channel-0 = <1>; rpmsg_amp_remote-1 = <1>; rpmsg_read_channel-1 = <0>; rpmsg_write_channel-1 = <0>; }; */ msgbox: msgbox@3003000 { compatible = "allwinner,sun8iw20-msgbox"; #mbox-cells = <1>; reg = <0x0 0x03003000 0x0 0x1000>, <0x0 0x01701000 0x0 0x1000>, <0x0 0x0601f000 0x0 0x1000>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_MSGBOX0>; resets = <&ccu RST_BUS_MSGBOX0>; reset-names = "rst"; local_id = <0>; status = "okay"; }; hdmi: hdmi@5500000 { compatible = "allwinner,sunxi-hdmi"; reg = <0x0 0x05500000 0x0 0xfffff>; interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_HDMI>, <&ccu CLK_HDMI_24M>, <&ccu CLK_HDMI_CEC>, <&ccu CLK_TCON_TV>; clock-names = "clk_bus_hdmi", "clk_ddc", "clk_cec", "clk_tcon_tv"; resets = <&ccu RST_BUS_HDMI_SUB>, <&ccu RST_BUS_HDMI_MAIN>; reset-names = "rst_bus_sub", "rst_bus_main"; assigned-clocks = <&ccu CLK_HDMI_CEC>; assigned-clock-parents = <&ccu CLK_HDMI_CEC_32K>; assigned-clock-rates = <0>; status = "okay"; }; usbc0:usbc0@0 { device_type = "usbc0"; compatible = "allwinner,sunxi-otg-manager"; usb_port_type = <2>; usb_detect_type = <1>; usb_id_gpio; usb_det_vbus_gpio; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0>; usb_luns = <3>; usb_serial_unique = <0>; usb_serial_number = "20080411"; rndis_wceis = <1>; status = "okay"; }; udc:udc-controller@0x04100000 { compatible = "allwinner,sunxi-udc"; reg = <0x0 0x04100000 0x0 0x1000>, /*udc base*/ <0x0 0x00000000 0x0 0x100>; /*sram base*/ interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_OTG>; clock-names = "bus_otg"; resets = <&ccu RST_BUS_OTG>, <&ccu RST_USB_PHY0>; reset-names = "otg", "phy"; status = "okay"; }; ehci0:ehci0-controller@0x04101000 { compatible = "allwinner,sunxi-ehci0"; reg = <0x0 0x04101000 0x0 0xFFF>, /*hci0 base*/ <0x0 0x00000000 0x0 0x100>, /*sram base*/ <0x0 0x04100000 0x0 0x1000>; /*otg base*/ interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_EHCI0>; clock-names = "bus_hci"; resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_USB_PHY0>; reset-names = "hci", "phy"; hci_ctrl_no = <0>; status = "okay"; }; ohci0:ohci0-controller@0x04101400 { compatible = "allwinner,sunxi-ohci0"; reg = <0x0 0x04101400 0x0 0xFFF>, /*hci0 base*/ <0x0 0x00000000 0x0 0x100>, /*sram base*/ <0x0 0x04100000 0x0 0x1000>; /*otg base*/ interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>; clock-names = "bus_hci", "ohci"; resets = <&ccu RST_BUS_OHCI0>, <&ccu RST_USB_PHY0>; reset-names = "hci", "phy"; hci_ctrl_no = <0>; status = "okay"; }; usbc1:usbc1@0 { device_type = "usbc1"; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0>; status = "disable"; }; ehci1:ehci1-controller@0x04200000 { compatible = "allwinner,sunxi-ehci1"; reg = <0x0 0x04200000 0x0 0xFFF>, /*ehci1 base*/ <0x0 0x00000000 0x0 0x100>, /*sram base*/ <0x0 0x04100000 0x0 0x1000>; /*otg base*/ interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_EHCI1>; clock-names = "bus_hci"; resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_USB_PHY1>; reset-names = "hci", "phy"; hci_ctrl_no = <1>; status = "disable"; }; ohci1:ohci1-controller@0x04200400 { compatible = "allwinner,sunxi-ohci1"; reg = <0x0 0x04200400 0x0 0xFFF>, /*ohci1 base*/ <0x0 0x00000000 0x0 0x100>, /*sram base*/ <0x0 0x04100000 0x0 0x1000>; /*otg base*/ interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_OHCI1>, <&ccu CLK_USB_OHCI1>; clock-names = "bus_hci", "ohci"; resets = <&ccu RST_BUS_OHCI1>, <&ccu RST_USB_PHY1>; reset-names = "hci", "phy"; hci_ctrl_no = <1>; status = "disable"; }; /* codec addr: 0x02030000, the others is invalid to avoid build warining */ codec:codec@2030000 { #sound-dai-cells = <0>; compatible = "allwinner,sunxi-internal-codec"; reg = <0x0 0x02030000 0x0 0x34c>; clocks = <&ccu CLK_PLL_AUDIO0>, <&ccu CLK_PLL_AUDIO1_DIV5>, <&ccu CLK_AUDIO_DAC>, <&ccu CLK_AUDIO_ADC>, <&ccu CLK_BUS_AUDIO_CODEC>; clock-names = "pll_audio0", "pll_audio1_div5", "audio_clk_dac", "audio_clk_adc", "audio_clk_bus"; resets = <&ccu RST_BUS_AUDIO_CODEC>; rx_sync_en = <0x00>; device_type = "codec"; status = "okay"; }; dummy_cpudai:dummy_cpudai@203034c { compatible = "allwinner,sunxi-dummy-cpudai"; reg = <0x0 0x0203034c 0x0 0x4>; tx_fifo_size = <128>; rx_fifo_size = <256>; dac_txdata = <0x02030020>; adc_txdata = <0x02030040>; playback_cma = <128>; capture_cma = <256>; device_type = "cpudai"; dmas = <&dma 7>, <&dma 7>; dma-names = "tx", "rx"; status = "okay"; }; sndcodec:sound@2030340 { compatible = "allwinner,sunxi-codec-machine"; reg = <0x0 0x02030340 0x0 0x4>; interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; sunxi,audio-codec = <&codec>; sunxi,cpudai-controller = <&dummy_cpudai>; device_type = "sndcodec"; status = "okay"; }; sunxi_rpaf_dsp0:rpaf-dsp@203034c { compatible = "allwinner,rpaf-dsp0"; device_type = "sunxi_rpaf_dsp0"; dsp_id = <0x0>; status = "okay"; }; /* dmic addr: 0x02031000, the others is invalid to avoid build warining */ dmic:dmic@2031000{ #sound-dai-cells = <0>; compatible = "allwinner,sunxi-dmic"; reg = <0x0 0x02031000 0x0 0x50>; clocks = <&ccu CLK_PLL_AUDIO0>, /* 98.304M / 90.3168M */ <&ccu CLK_DMIC>, <&ccu CLK_BUS_DMIC>; clock-names = "pll_audio", "dmic", "dmic_bus"; resets = <&ccu RST_BUS_DMIC>; dmas = <&dma 8>; dma-names = "rx"; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; clk_parent = <0x1>; capture_cma = <256>; data_vol = <0xB0>; rx_chmap = <0x76543210>; rx_sync_en = <0x00>; device_type = "dmic"; status = "disabled"; }; dmic_codec:sound@2031050{ #sound-dai-cells = <0>; compatible = "dmic-codec"; reg = <0x0 0x02031050 0x0 0x4>; num-channels = <8>; }; sounddmic:sounddmic@2031060 { reg = <0x0 0x02031060 0x0 0x4>; compatible = "sunxi,simple-audio-card"; simple-audio-card,name = "snddmic"; simple-audio-card,capture_only; status = "disabled"; /* simple-audio-card,format = "i2s"; */ simple-audio-card,cpu { sound-dai = <&dmic>; }; simple-audio-card,codec { sound-dai = <&dmic_codec>; }; }; /* daudio0 addr: 0x02032000, the others is invalid to avoid build warining */ daudio0:daudio@2032000 { #sound-dai-cells = <0>; compatible = "allwinner,sunxi-daudio"; reg = <0x0 0x02032000 0x0 0xa0>; clocks = <&ccu CLK_PLL_AUDIO0>, /* 98.304M / 90.3168M */ <&ccu CLK_I2S0>, <&ccu CLK_BUS_I2S0>; clock-names = "pll_audio", "i2s0", "i2s0_bus"; resets = <&ccu RST_BUS_I2S0>; dmas = <&dma 3>, <&dma 3>; dma-names = "tx", "rx"; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; pinctrl_used = <0x01>; sign_extend = <0x00>; tx_data_mode = <0x00>; rx_data_mode = <0x00>; msb_lsb_first = <0x00>; pcm_lrck_period = <0x80>; slot_width_select = <0x20>; frametype = <0x00>; tdm_config = <0x01>; tdm_num = <0x00>; mclk_div = <0x00>; clk_parent = <0x00>; capture_cma = <128>; playback_cma = <128>; tx_num = <4>; tx_chmap1 = <0x76543210>; tx_chmap0 = <0xFEDCBA98>; rx_num = <4>; rx_chmap3 = <0x03020100>; rx_chmap2 = <0x07060504>; rx_chmap1 = <0x0B0A0908>; rx_chmap0 = <0x0F0E0D0C>; asrc_function_en = <0x00>; rx_sync_en = <0x00>; device_type = "daudio0"; status = "disabled"; }; sounddaudio0: sounddaudio0@20320a0 { reg = <0x0 0x020320a0 0x0 0x4>; compatible = "sunxi,simple-audio-card"; simple-audio-card,name = "snddaudio0"; simple-audio-card,format = "i2s"; status = "disabled"; /* simple-audio-card,frame-master = <&daudio0_master>; */ /* simple-audio-card,bitclock-master = <&daudio0_master>; */ /* simple-audio-card,bitclock-inversion; */ /* simple-audio-card,frame-inversion; */ simple-audio-card,cpu { sound-dai = <&daudio0>; }; }; /* daudio1 addr: 0x02033000, the others is invalid to avoid build warining */ daudio1:daudio@2033000 { #sound-dai-cells = <0>; compatible = "allwinner,sunxi-daudio"; reg = <0x0 0x02033000 0x0 0xa0>; clocks = <&ccu CLK_PLL_AUDIO0>, /* 98.304M / 90.3168M */ <&ccu CLK_I2S1>, <&ccu CLK_BUS_I2S1>; clock-names = "pll_audio", "i2s1", "i2s1_bus"; resets = <&ccu RST_BUS_I2S1>; dmas = <&dma 4>, <&dma 4>; dma-names = "tx", "rx"; interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; pinctrl_used = <0x01>; sign_extend = <0x00>; tx_data_mode = <0x00>; rx_data_mode = <0x00>; msb_lsb_first = <0x00>; pcm_lrck_period = <0x80>; slot_width_select = <0x20>; frametype = <0x00>; tdm_config = <0x01>; tdm_num = <0x01>; mclk_div = <0x00>; clk_parent = <0x00>; capture_cma = <128>; playback_cma = <128>; tx_num = <4>; tx_chmap1 = <0x76543210>; tx_chmap0 = <0xFEDCBA98>; rx_num = <4>; rx_chmap3 = <0x03020100>; rx_chmap2 = <0x07060504>; rx_chmap1 = <0x0B0A0908>; rx_chmap0 = <0x0F0E0D0C>; asrc_function_en = <0x00>; rx_sync_en = <0x00>; device_type = "daudio1"; status = "disabled"; }; sounddaudio1: sounddaudio1@20330a0 { reg = <0x0 0x020330a0 0x0 0x4>; compatible = "sunxi,simple-audio-card"; simple-audio-card,name = "snddaudio1"; simple-audio-card,format = "i2s"; status = "disabled"; simple-audio-card,cpu { sound-dai = <&daudio1>; }; }; /* daudio2 addr: 0x02034000, the others is invalid to avoid build warining */ daudio2:daudio@2034000 { #sound-dai-cells = <0>; compatible = "allwinner,sunxi-daudio"; reg = <0x0 0x02034000 0x0 0xa0>; clocks = <&ccu CLK_PLL_AUDIO0>, /* 98.304M / 90.3168M */ <&ccu CLK_I2S2>, <&ccu CLK_BUS_I2S2>, <&ccu CLK_PLL_AUDIO0_4X>, <&ccu CLK_I2S2_ASRC>; resets = <&ccu RST_BUS_I2S2>; dmas = <&dma 5>, <&dma 5>; dma-names = "tx", "rx"; interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; pinctrl_used = <0x01>; daudio_type = <0x00>; sign_extend = <0x00>; tx_data_mode = <0x00>; rx_data_mode = <0x00>; msb_lsb_first = <0x00>; pcm_lrck_period = <0x80>; slot_width_select = <0x20>; frametype = <0x00>; tdm_config = <0x01>; tdm_num = <0x02>; mclk_div = <0x01>; clk_parent = <0x00>; capture_cma = <128>; playback_cma = <128>; tx_num = <4>; tx_chmap1 = <0x76543210>; tx_chmap0 = <0xFEDCBA98>; rx_num = <4>; rx_chmap3 = <0x03020100>; rx_chmap2 = <0x07060504>; rx_chmap1 = <0x0B0A0908>; rx_chmap0 = <0x0F0E0D0C>; asrc_function_en = <0x00>; rx_sync_en = <0x00>; device_type = "daudio2"; status = "disabled"; }; sounddaudio2: sounddaudio2@20340a0 { reg = <0x0 0x020340a0 0x0 0x4>; compatible = "sunxi,simple-audio-card"; simple-audio-card,name = "snddaudio2"; simple-audio-card,format = "i2s"; status = "disabled"; simple-audio-card,cpu { sound-dai = <&daudio2>; }; }; hdmiaudio: hdmiaudio@20340a4 { #sound-dai-cells = <0>; reg = <0x0 0x020340a4 0x0 0x4>; compatible = "allwinner,sunxi-hdmiaudio"; status = "disabled"; }; /* spdif addr: 0x02036000, the others is invalid to avoid build warining */ spdif:spdif@2036000 { #sound-dai-cells = <0>; compatible = "allwinner,sunxi-spdif"; reg = <0x0 0x02036000 0x0 0x58>; clocks = <&ccu CLK_PLL_AUDIO0_4X>, /* 90.3168M */ <&ccu CLK_SPDIF_TX>, <&ccu CLK_BUS_SPDIF>, <&ccu CLK_PLL_AUDIO1>, /* 98.304M */ <&ccu CLK_PLL_AUDIO1_DIV5>, <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPDIF_RX>; clock-names = "pll_audio0", "spdif", "spdif_bus", "pll_audio1", "pll_audio1_div5", "pll_periph", "spdif_rx"; resets = <&ccu RST_BUS_SPDIF>; dmas = <&dma 2>, <&dma 2>; dma-names = "tx", "rx"; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; clk_parent = <0x1>; playback_cma = <128>; capture_cma = <128>; rx_sync_en = <0>; device_type = "spdif"; status = "disabled"; }; soundspdif:soundspdif@203605c { reg = <0x0 0x0203605c 0x0 0x4>; compatible = "sunxi,simple-audio-card"; simple-audio-card,name = "sndspdif"; status = "disabled"; /* simple-audio-card,format = "i2s"; */ simple-audio-card,cpu { sound-dai = <&spdif>; }; simple-audio-card,codec { /*snd-soc-dummy*/ }; }; ths: ths@02009400 { compatible = "allwinner,sun8iw20p1-ths"; reg = <0x0 0x02009400 0x0 0x400>; clocks = <&ccu CLK_BUS_THS>; clock-names = "bus"; resets = <&ccu RST_BUS_THS>; nvmem-cells = <&ths_calib>; nvmem-cell-names = "calibration"; #thermal-sensor-cells = <1>; }; tvd: tvd@05c00000 { compatible = "allwinner,sunxi-tvd"; reg = <0x0 0x05c00000 0x0 0x00010000>;/*tvd_top*/ interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_TVD_TOP>, <&ccu CLK_MBUS_TVIN>; clock-names = "clk_bus_tvd_top", "clk_mbus_tvd"; resets = <&ccu RST_BUS_TVD_TOP>; reset-names = "rst_bus_tvd_top"; tvd-number = <1>; tvds = <&tvd0>; status = "okay"; }; tvd0: tvd0@05c01000 { compatible = "allwinner,sunxi-tvd0"; reg = <0x0 0x05c01000 0x0 0x00010000>; interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_TVD>, <&ccu CLK_BUS_TVD>; clock-names = "clk_tvd0","clk_bus_tvd0"; resets = <&ccu RST_BUS_TVD>; reset-names = "rst_bus_tvd0"; assigned-clocks = <&ccu CLK_TVD>; assigned-clock-parents = <&ccu CLK_PLL_VIDEO1>; tvd_used = <1>; tvd_if = <0>; status = "okay"; }; }; };
config-5.4
# # Automatically generated file; DO NOT EDIT. # Linux/arm 5.4.61 Kernel Configuration # CONFIG_CC_VERSION_TEXT="arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1" CONFIG_CC_IS_GCC=y CONFIG_GCC_VERSION=60401 CONFIG_CLANG_VERSION=0 CONFIG_CC_CAN_LINK=y CONFIG_CC_HAS_ASM_GOTO=y CONFIG_IRQ_WORK=y CONFIG_BUILDTIME_EXTABLE_SORT=y # # General setup # CONFIG_INIT_ENV_ARG_LIMIT=32 # CONFIG_COMPILE_TEST is not set CONFIG_LOCALVERSION="" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_BUILD_SALT="" CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_HAVE_KERNEL_LZ4=y CONFIG_KERNEL_GZIP=y # CONFIG_KERNEL_LZMA is not set # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set # CONFIG_KERNEL_LZ4 is not set CONFIG_DEFAULT_HOSTNAME="(none)" # CONFIG_SWAP is not set CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y # CONFIG_POSIX_MQUEUE is not set CONFIG_CROSS_MEMORY_ATTACH=y # CONFIG_USELIB is not set # CONFIG_AUDIT is not set # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_SHOW_LEVEL=y CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y CONFIG_GENERIC_IRQ_MIGRATION=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_CHIP=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_IRQ_MSI_IOMMU=y CONFIG_HANDLE_DOMAIN_IRQ=y CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y # CONFIG_GENERIC_IRQ_DEBUGFS is not set # end of IRQ subsystem CONFIG_GENERIC_IRQ_MULTI_HANDLER=y CONFIG_ARCH_CLOCKSOURCE_DATA=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_ARCH_HAS_TICK_BROADCAST=y CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y # CONFIG_NO_HZ_FULL is not set CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y # end of Timers subsystem # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_COUNT=y CONFIG_PREEMPTION=y # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set # CONFIG_IRQ_TIME_ACCOUNTING is not set CONFIG_BSD_PROCESS_ACCT=y CONFIG_BSD_PROCESS_ACCT_V3=y # CONFIG_TASKSTATS is not set # CONFIG_PSI is not set # end of CPU/Task time and stats accounting CONFIG_CPU_ISOLATION=y # # RCU Subsystem # CONFIG_PREEMPT_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y CONFIG_TREE_SRCU=y CONFIG_TASKS_RCU=y CONFIG_RCU_STALL_COMMON=y CONFIG_RCU_NEED_SEGCBLIST=y # end of RCU Subsystem CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y # CONFIG_IKHEADERS is not set CONFIG_LOG_BUF_SHIFT=20 CONFIG_LOG_CPU_MAX_BUF_SHIFT=12 CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13 CONFIG_GENERIC_SCHED_CLOCK=y # # Scheduler features # # end of Scheduler features # CONFIG_CGROUPS is not set # CONFIG_NAMESPACES is not set # CONFIG_CHECKPOINT_RESTORE is not set # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set # CONFIG_BLK_DEV_INITRD is not set # CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE is not set CONFIG_CC_OPTIMIZE_FOR_SIZE=y CONFIG_SYSCTL=y CONFIG_HAVE_UID16=y CONFIG_BPF=y CONFIG_EXPERT=y CONFIG_UID16=y CONFIG_MULTIUSER=y # CONFIG_SGETMASK_SYSCALL is not set # CONFIG_SYSFS_SYSCALL is not set # CONFIG_SYSCTL_SYSCALL is not set # CONFIG_FHANDLE is not set CONFIG_POSIX_TIMERS=y CONFIG_PRINTK=y CONFIG_PRINTK_NMI=y CONFIG_BUG=y # CONFIG_ELF_CORE is not set CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_FUTEX_PI=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y # CONFIG_AIO is not set CONFIG_IO_URING=y CONFIG_ADVISE_SYSCALLS=y CONFIG_MEMBARRIER=y CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set CONFIG_KALLSYMS_BASE_RELATIVE=y # CONFIG_BPF_SYSCALL is not set # CONFIG_USERFAULTFD is not set CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y CONFIG_RSEQ=y # CONFIG_DEBUG_RSEQ is not set CONFIG_EMBEDDED=y CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # CONFIG_PC104 is not set # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_DEBUG_PERF_USE_VMALLOC is not set # end of Kernel Performance Events And Counters CONFIG_VM_EVENT_COUNTERS=y # CONFIG_SLUB_DEBUG is not set # CONFIG_COMPAT_BRK is not set # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set CONFIG_SLAB_MERGE_DEFAULT=y # CONFIG_SLAB_FREELIST_RANDOM is not set # CONFIG_SLAB_FREELIST_HARDENED is not set # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set CONFIG_SLUB_CPU_PARTIAL=y # CONFIG_PROFILING is not set # end of General setup CONFIG_ARM=y CONFIG_ARM_HAS_SG_CHAIN=y CONFIG_ARM_DMA_USE_IOMMU=y CONFIG_ARM_DMA_IOMMU_ALIGNMENT=8 CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_HAVE_PROC_CPU=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_FIX_EARLYCON_MEM=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_ARCH_SUPPORTS_UPROBES=y CONFIG_ARM_PATCH_PHYS_VIRT=y CONFIG_GENERIC_BUG=y CONFIG_PGTABLE_LEVELS=2 # # System Type # CONFIG_MMU=y CONFIG_ARCH_MMAP_RND_BITS_MIN=8 CONFIG_ARCH_MMAP_RND_BITS_MAX=16 CONFIG_ARCH_MULTIPLATFORM=y # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_IOP32X is not set # CONFIG_ARCH_IXP4XX is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_PXA is not set # CONFIG_ARCH_RPC is not set # CONFIG_ARCH_SA1100 is not set # CONFIG_ARCH_S3C24XX is not set # CONFIG_ARCH_OMAP1 is not set # # Multiple platform selection # # # CPU Core family selection # # CONFIG_ARCH_MULTI_V6 is not set CONFIG_ARCH_MULTI_V7=y CONFIG_ARCH_MULTI_V6_V7=y # end of Multiple platform selection # CONFIG_ARCH_VIRT is not set # CONFIG_ARCH_ACTIONS is not set # CONFIG_ARCH_ALPINE is not set # CONFIG_ARCH_ARTPEC is not set # CONFIG_ARCH_ASPEED is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_BCM is not set # CONFIG_ARCH_BERLIN is not set # CONFIG_ARCH_DIGICOLOR is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_HISI is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_KEYSTONE is not set # CONFIG_ARCH_MEDIATEK is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MILBEAUT is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_ARCH_NPCM is not set # # TI OMAP/AM/DM/DRA Family # # CONFIG_ARCH_OMAP3 is not set # CONFIG_ARCH_OMAP4 is not set # CONFIG_SOC_OMAP5 is not set # CONFIG_SOC_AM33XX is not set # CONFIG_SOC_AM43XX is not set # CONFIG_SOC_DRA7XX is not set # end of TI OMAP/AM/DM/DRA Family # CONFIG_ARCH_SIRF is not set # CONFIG_ARCH_QCOM is not set # CONFIG_ARCH_RDA is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_RENESAS is not set # CONFIG_ARCH_SOCFPGA is not set # CONFIG_PLAT_SPEAR is not set # CONFIG_ARCH_STI is not set # CONFIG_ARCH_STM32 is not set CONFIG_ARCH_SUNXI=y # CONFIG_MACH_SUN4I is not set # CONFIG_MACH_SUN5I is not set # CONFIG_MACH_SUN6I is not set # CONFIG_MACH_SUN7I is not set # CONFIG_MACH_SUN8I is not set # CONFIG_MACH_SUN9I is not set CONFIG_ARCH_SUN8I=y # CONFIG_ARCH_SUN8IW15 is not set CONFIG_ARCH_SUN8IW20=y # CONFIG_FPGA_V4_PLATFORM is not set # CONFIG_FPGA_V7_PLATFORM is not set CONFIG_EVB_PLATFORM=y CONFIG_SUNXI_SOC_NAME="sun8iw20" # CONFIG_ARCH_TANGO is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_WM8850 is not set # CONFIG_ARCH_ZX is not set # CONFIG_ARCH_ZYNQ is not set # # Processor Type # CONFIG_CPU_V7=y CONFIG_CPU_THUMB_CAPABLE=y CONFIG_CPU_32v6K=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # # CONFIG_ARM_LPAE is not set CONFIG_ARM_THUMB=y # CONFIG_ARM_THUMBEE is not set CONFIG_ARM_VIRT_EXT=y CONFIG_SWP_EMULATE=y # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_ICACHE_MISMATCH_WORKAROUND is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_CPU_SPECTRE=y CONFIG_HARDEN_BRANCH_PREDICTOR=y CONFIG_KUSER_HELPERS=y # CONFIG_VDSO is not set CONFIG_OUTER_CACHE=y CONFIG_OUTER_CACHE_SYNC=y CONFIG_MIGHT_HAVE_CACHE_L2X0=y CONFIG_CACHE_L2X0=y # CONFIG_CACHE_L2X0_PMU is not set # CONFIG_PL310_ERRATA_588369 is not set # CONFIG_PL310_ERRATA_727915 is not set # CONFIG_PL310_ERRATA_753970 is not set # CONFIG_PL310_ERRATA_769419 is not set CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_ARM_HEAVY_MB=y CONFIG_DEBUG_ALIGN_RODATA=y # CONFIG_ARM_ERRATA_430973 is not set CONFIG_ARM_ERRATA_643719=y # CONFIG_ARM_ERRATA_720789 is not set # CONFIG_ARM_ERRATA_754322 is not set # CONFIG_ARM_ERRATA_754327 is not set # CONFIG_ARM_ERRATA_764369 is not set # CONFIG_ARM_ERRATA_775420 is not set # CONFIG_ARM_ERRATA_798181 is not set # CONFIG_ARM_ERRATA_773022 is not set # CONFIG_ARM_ERRATA_818325_852422 is not set # CONFIG_ARM_ERRATA_821420 is not set # CONFIG_ARM_ERRATA_825619 is not set # CONFIG_ARM_ERRATA_857271 is not set # CONFIG_ARM_ERRATA_852421 is not set # CONFIG_ARM_ERRATA_852423 is not set # CONFIG_ARM_ERRATA_857272 is not set # end of System Type # # Bus support # # CONFIG_ARM_ERRATA_814220 is not set # end of Bus support # # Kernel Features # CONFIG_HAVE_SMP=y CONFIG_SMP=y CONFIG_SMP_ON_UP=y CONFIG_ARM_CPU_TOPOLOGY=y CONFIG_SCHED_MC=y # CONFIG_SCHED_SMT is not set CONFIG_HAVE_ARM_ARCH_TIMER=y # CONFIG_MCPM is not set # CONFIG_BIG_LITTLE is not set CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_3G_OPT is not set # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 CONFIG_NR_CPUS=2 CONFIG_HOTPLUG_CPU=y CONFIG_ARM_PSCI=y CONFIG_ARCH_NR_GPIO=416 CONFIG_HZ_FIXED=0 CONFIG_HZ_100=y # CONFIG_HZ_200 is not set # CONFIG_HZ_250 is not set # CONFIG_HZ_300 is not set # CONFIG_HZ_500 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=100 CONFIG_SCHED_HRTICK=y # CONFIG_THUMB2_KERNEL is not set CONFIG_ARM_PATCH_IDIV=y CONFIG_AEABI=y CONFIG_OABI_COMPAT=y CONFIG_HAVE_ARCH_PFN_VALID=y # CONFIG_HIGHMEM is not set CONFIG_CPU_SW_DOMAIN_PAN=y CONFIG_ARCH_WANT_GENERAL_HUGETLB=y # CONFIG_ARM_MODULE_PLTS is not set CONFIG_FORCE_MAX_ZONEORDER=11 CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set # CONFIG_SECCOMP is not set # CONFIG_PARAVIRT is not set # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set # CONFIG_XEN is not set # end of Kernel Features # # Boot options # CONFIG_USE_OF=y # CONFIG_ATAGS is not set CONFIG_ZBOOT_ROM_TEXT=0 CONFIG_ZBOOT_ROM_BSS=0 # CONFIG_ARM_APPENDED_DTB is not set CONFIG_CMDLINE="loglevel=8 initcall_debug=1 console=ttyS0 init=/init" # CONFIG_KEXEC is not set # CONFIG_CRASH_DUMP is not set CONFIG_AUTO_ZRELADDR=y # CONFIG_EFI is not set # end of Boot options # # CPU Power Management # # # CPU Frequency scaling # # CONFIG_CPU_FREQ is not set # end of CPU Frequency scaling # # CPU Idle # # CONFIG_CPU_IDLE is not set # end of CPU Idle # end of CPU Power Management # # Floating point emulation # # # At least one emulation must be selected # # CONFIG_FPE_NWFPE is not set # CONFIG_FPE_FASTFPE is not set CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y CONFIG_KERNEL_MODE_NEON=y # end of Floating point emulation # # Power management options # CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y # CONFIG_SUSPEND_SKIP_SYNC is not set CONFIG_PM_SLEEP=y CONFIG_PM_SLEEP_SMP=y # CONFIG_PM_AUTOSLEEP is not set CONFIG_PM_WAKELOCKS=y CONFIG_PM_WAKELOCKS_LIMIT=100 CONFIG_PM_WAKELOCKS_GC=y CONFIG_PM=y CONFIG_PM_DEBUG=y CONFIG_PM_ADVANCED_DEBUG=y CONFIG_PM_SLEEP_DEBUG=y # CONFIG_APM_EMULATION is not set CONFIG_PM_CLK=y CONFIG_PM_GENERIC_DOMAINS=y CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y CONFIG_PM_GENERIC_DOMAINS_SLEEP=y CONFIG_PM_GENERIC_DOMAINS_OF=y CONFIG_CPU_PM=y CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_ARM_CPU_SUSPEND=y CONFIG_ARCH_HIBERNATION_POSSIBLE=y # end of Power management options # # Firmware Drivers # # CONFIG_FIRMWARE_MEMMAP is not set # CONFIG_FW_CFG_SYSFS is not set # CONFIG_QCOM_SCM is not set # CONFIG_TRUSTED_FOUNDATIONS is not set CONFIG_HAVE_ARM_SMCCC=y CONFIG_ARM_PSCI_FW=y # CONFIG_GOOGLE_FIRMWARE is not set # # Tegra firmware driver # # end of Tegra firmware driver # end of Firmware Drivers # CONFIG_ARM_CRYPTO is not set # CONFIG_VIRTUALIZATION is not set # # General architecture-dependent options # CONFIG_HAVE_OPROFILE=y # CONFIG_KPROBES is not set CONFIG_JUMP_LABEL=y # CONFIG_STATIC_KEYS_SELFTEST is not set CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y CONFIG_ARCH_USE_BUILTIN_BSWAP=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_OPTPROBES=y CONFIG_HAVE_NMI=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_ARCH_HAS_FORTIFY_SOURCE=y CONFIG_ARCH_HAS_KEEPINITRD=y CONFIG_ARCH_HAS_SET_MEMORY=y CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y CONFIG_ARCH_32BIT_OFF_T=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_RSEQ=y CONFIG_HAVE_CLK=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y CONFIG_HAVE_STACKPROTECTOR=y CONFIG_CC_HAS_STACKPROTECTOR_NONE=y CONFIG_STACKPROTECTOR=y CONFIG_STACKPROTECTOR_STRONG=y CONFIG_LTO_NONE=y CONFIG_HAVE_CONTEXT_TRACKING=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_REL=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_ARCH_MMAP_RND_BITS=y CONFIG_HAVE_EXIT_THREAD=y CONFIG_ARCH_MMAP_RND_BITS=8 CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y CONFIG_HAVE_COPY_THREAD_TLS=y CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_OLD_SIGACTION=y CONFIG_64BIT_TIME=y CONFIG_COMPAT_32BIT_TIME=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y CONFIG_STRICT_KERNEL_RWX=y CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y CONFIG_STRICT_MODULE_RWX=y CONFIG_ARCH_HAS_PHYS_TO_DMA=y CONFIG_REFCOUNT_FULL=y # CONFIG_LOCK_EVENT_COUNTS is not set # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y # end of GCOV-based kernel profiling CONFIG_PLUGIN_HOSTCC="" CONFIG_HAVE_GCC_PLUGINS=y # end of General architecture-dependent options CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y # CONFIG_MODULE_FORCE_LOAD is not set CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set # CONFIG_MODULE_SIG is not set # CONFIG_MODULE_COMPRESS is not set # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set # CONFIG_UNUSED_SYMBOLS is not set # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_MODULES_TREE_LOOKUP=y CONFIG_BLOCK=y CONFIG_BLK_SCSI_REQUEST=y # CONFIG_BLK_DEV_BSG is not set # CONFIG_BLK_DEV_BSGLIB is not set # CONFIG_BLK_DEV_INTEGRITY is not set # CONFIG_BLK_DEV_ZONED is not set # CONFIG_BLK_CMDLINE_PARSER is not set # CONFIG_BLK_WBT is not set CONFIG_BLK_DEBUG_FS=y # CONFIG_BLK_SED_OPAL is not set # CONFIG_BLK_INLINE_ENCRYPTION is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y CONFIG_EFI_PARTITION=y # end of Partition Types CONFIG_BLK_PM=y # # IO Schedulers # CONFIG_MQ_IOSCHED_DEADLINE=y CONFIG_MQ_IOSCHED_KYBER=y # CONFIG_IOSCHED_BFQ is not set # end of IO Schedulers CONFIG_ASN1=y CONFIG_UNINLINE_SPIN_UNLOCK=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y CONFIG_MUTEX_SPIN_ON_OWNER=y CONFIG_RWSEM_SPIN_ON_OWNER=y CONFIG_LOCK_SPIN_ON_OWNER=y # CONFIG_GKI_HIDDEN_DRM_CONFIGS is not set # CONFIG_GKI_HIDDEN_REGMAP_CONFIGS is not set # CONFIG_GKI_HIDDEN_CRYPTO_CONFIGS is not set # CONFIG_GKI_HIDDEN_SND_CONFIGS is not set # CONFIG_GKI_HIDDEN_SND_SOC_CONFIGS is not set # CONFIG_GKI_HIDDEN_MMC_CONFIGS is not set # CONFIG_GKI_HIDDEN_GPIO_CONFIGS is not set # CONFIG_GKI_HIDDEN_QCOM_CONFIGS is not set # CONFIG_GKI_HIDDEN_MEDIA_CONFIGS is not set # CONFIG_GKI_HIDDEN_VIRTUAL_CONFIGS is not set # CONFIG_GKI_LEGACY_WEXT_ALLCONFIG is not set # CONFIG_GKI_HIDDEN_USB_CONFIGS is not set # CONFIG_GKI_HIDDEN_SOC_BUS_CONFIGS is not set # CONFIG_GKI_HIDDEN_RPMSG_CONFIGS is not set # CONFIG_GKI_HIDDEN_GPU_CONFIGS is not set # CONFIG_GKI_HIDDEN_IRQ_CONFIGS is not set # CONFIG_GKI_HIDDEN_HYPERVISOR_CONFIGS is not set # CONFIG_GKI_HACKS_TO_FIX is not set # CONFIG_GKI_OPT_FEATURES is not set CONFIG_FREEZER=y # # Executable file formats # CONFIG_BINFMT_ELF=y # CONFIG_BINFMT_ELF_FDPIC is not set CONFIG_ELFCORE=y CONFIG_BINFMT_SCRIPT=y CONFIG_ARCH_HAS_BINFMT_FLAT=y # CONFIG_BINFMT_FLAT is not set CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y # CONFIG_BINFMT_MISC is not set CONFIG_COREDUMP=y # end of Executable file formats # # Memory Management options # CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_ARCH_KEEP_MEMBLOCK=y CONFIG_MEMORY_ISOLATION=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_COMPACTION=y CONFIG_MIGRATION=y CONFIG_CONTIG_ALLOC=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 # CONFIG_CLEANCACHE is not set CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # CONFIG_CMA_DEBUGFS is not set CONFIG_CMA_AREAS=7 # CONFIG_ZPOOL is not set # CONFIG_ZBUD is not set # CONFIG_ZSMALLOC is not set CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_IDLE_PAGE_TRACKING is not set CONFIG_FRAME_VECTOR=y # CONFIG_PERCPU_STATS is not set # CONFIG_GUP_BENCHMARK is not set # end of Memory Management options CONFIG_NET=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_DIAG is not set CONFIG_UNIX=y CONFIG_UNIX_SCM=y # CONFIG_UNIX_DIAG is not set # CONFIG_TLS is not set # CONFIG_XFRM_USER is not set # CONFIG_NET_KEY is not set CONFIG_INET=y CONFIG_IP_MULTICAST=y CONFIG_IP_ADVANCED_ROUTER=y # CONFIG_IP_FIB_TRIE_STATS is not set CONFIG_IP_MULTIPLE_TABLES=y CONFIG_IP_ROUTE_MULTIPATH=y CONFIG_IP_ROUTE_VERBOSE=y # CONFIG_IP_PNP is not set # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set CONFIG_IP_MROUTE_COMMON=y CONFIG_IP_MROUTE=y CONFIG_IP_MROUTE_MULTIPLE_TABLES=y # CONFIG_IP_PIMSM_V1 is not set # CONFIG_IP_PIMSM_V2 is not set CONFIG_SYN_COOKIES=y # CONFIG_NET_IPVTI is not set # CONFIG_NET_FOU is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set # CONFIG_INET_DIAG is not set CONFIG_TCP_CONG_ADVANCED=y # CONFIG_TCP_CONG_BIC is not set CONFIG_TCP_CONG_CUBIC=y # CONFIG_TCP_CONG_WESTWOOD is not set # CONFIG_TCP_CONG_HTCP is not set # CONFIG_TCP_CONG_HSTCP is not set # CONFIG_TCP_CONG_HYBLA is not set # CONFIG_TCP_CONG_VEGAS is not set # CONFIG_TCP_CONG_NV is not set # CONFIG_TCP_CONG_SCALABLE is not set # CONFIG_TCP_CONG_LP is not set # CONFIG_TCP_CONG_VENO is not set # CONFIG_TCP_CONG_YEAH is not set # CONFIG_TCP_CONG_ILLINOIS is not set # CONFIG_TCP_CONG_DCTCP is not set # CONFIG_TCP_CONG_CDG is not set # CONFIG_TCP_CONG_BBR is not set CONFIG_DEFAULT_CUBIC=y # CONFIG_DEFAULT_RENO is not set CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set CONFIG_IPV6=y # CONFIG_IPV6_ROUTER_PREF is not set # CONFIG_IPV6_OPTIMISTIC_DAD is not set # CONFIG_INET6_AH is not set # CONFIG_INET6_ESP is not set # CONFIG_INET6_IPCOMP is not set # CONFIG_IPV6_MIP6 is not set # CONFIG_IPV6_VTI is not set # CONFIG_IPV6_SIT is not set # CONFIG_IPV6_TUNNEL is not set CONFIG_IPV6_MULTIPLE_TABLES=y CONFIG_IPV6_SUBTREES=y CONFIG_IPV6_MROUTE=y # CONFIG_IPV6_MROUTE_MULTIPLE_TABLES is not set # CONFIG_IPV6_PIMSM_V2 is not set # CONFIG_IPV6_SEG6_LWTUNNEL is not set # CONFIG_IPV6_SEG6_HMAC is not set # CONFIG_NETWORK_SECMARK is not set # CONFIG_NETWORK_PHY_TIMESTAMPING is not set # CONFIG_NETFILTER is not set # CONFIG_BPFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set CONFIG_STP=y CONFIG_BRIDGE=y CONFIG_BRIDGE_IGMP_SNOOPING=y CONFIG_HAVE_NET_DSA=y # CONFIG_NET_DSA is not set # CONFIG_VLAN_8021Q is not set # CONFIG_DECNET is not set CONFIG_LLC=y # CONFIG_LLC2 is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_6LOWPAN is not set # CONFIG_IEEE802154 is not set CONFIG_NET_SCHED=y # # Queueing/Scheduling # # CONFIG_NET_SCH_CBQ is not set # CONFIG_NET_SCH_HTB is not set # CONFIG_NET_SCH_HFSC is not set # CONFIG_NET_SCH_PRIO is not set # CONFIG_NET_SCH_MULTIQ is not set # CONFIG_NET_SCH_RED is not set # CONFIG_NET_SCH_SFB is not set # CONFIG_NET_SCH_SFQ is not set # CONFIG_NET_SCH_TEQL is not set # CONFIG_NET_SCH_TBF is not set # CONFIG_NET_SCH_CBS is not set # CONFIG_NET_SCH_ETF is not set # CONFIG_NET_SCH_TAPRIO is not set # CONFIG_NET_SCH_GRED is not set # CONFIG_NET_SCH_DSMARK is not set # CONFIG_NET_SCH_NETEM is not set # CONFIG_NET_SCH_DRR is not set # CONFIG_NET_SCH_MQPRIO is not set # CONFIG_NET_SCH_SKBPRIO is not set # CONFIG_NET_SCH_CHOKE is not set # CONFIG_NET_SCH_QFQ is not set # CONFIG_NET_SCH_CODEL is not set CONFIG_NET_SCH_FQ_CODEL=y # CONFIG_NET_SCH_CAKE is not set # CONFIG_NET_SCH_FQ is not set # CONFIG_NET_SCH_HHF is not set # CONFIG_NET_SCH_PIE is not set # CONFIG_NET_SCH_PLUG is not set # CONFIG_NET_SCH_DEFAULT is not set # # Classification # # CONFIG_NET_CLS_BASIC is not set # CONFIG_NET_CLS_TCINDEX is not set # CONFIG_NET_CLS_ROUTE4 is not set # CONFIG_NET_CLS_FW is not set # CONFIG_NET_CLS_U32 is not set # CONFIG_NET_CLS_RSVP is not set # CONFIG_NET_CLS_RSVP6 is not set # CONFIG_NET_CLS_FLOW is not set # CONFIG_NET_CLS_BPF is not set # CONFIG_NET_CLS_FLOWER is not set # CONFIG_NET_CLS_MATCHALL is not set # CONFIG_NET_EMATCH is not set # CONFIG_NET_CLS_ACT is not set CONFIG_NET_SCH_FIFO=y # CONFIG_DCB is not set # CONFIG_DNS_RESOLVER is not set # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set # CONFIG_NETLINK_DIAG is not set # CONFIG_MPLS is not set # CONFIG_NET_NSH is not set # CONFIG_HSR is not set # CONFIG_NET_SWITCHDEV is not set # CONFIG_NET_L3_MASTER_DEV is not set # CONFIG_NET_NCSI is not set CONFIG_RPS=y CONFIG_RFS_ACCEL=y CONFIG_XPS=y CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y # CONFIG_BPF_JIT is not set CONFIG_NET_FLOW_LIMIT=y # # Network testing # # CONFIG_NET_PKTGEN is not set # end of Network testing # end of Networking options # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set CONFIG_BT=y CONFIG_BT_BREDR=y CONFIG_BT_RFCOMM=y CONFIG_BT_RFCOMM_TTY=y # CONFIG_BT_BNEP is not set # CONFIG_BT_HIDP is not set # CONFIG_BT_HS is not set # CONFIG_BT_LE is not set # CONFIG_BT_LEDS is not set # CONFIG_BT_SELFTEST is not set CONFIG_BT_DEBUGFS=y # # Bluetooth device drivers # # CONFIG_BT_HCIBTUSB is not set CONFIG_BT_HCIUART_RTL3WIRE=y # CONFIG_BT_HCIBTSDIO is not set CONFIG_BT_HCIUART=y CONFIG_BT_HCIUART_H4=y CONFIG_BT_HCIUART_BCSP=y # CONFIG_BT_HCIUART_ATH3K is not set # CONFIG_BT_HCIUART_INTEL is not set # CONFIG_BT_HCIUART_AG6XX is not set # CONFIG_BT_HCIBCM203X is not set # CONFIG_BT_HCIBPA10X is not set # CONFIG_BT_HCIBFUSB is not set # CONFIG_BT_HCIVHCI is not set # CONFIG_BCM_BT_LPM is not set CONFIG_RTL_BT_LPM=y # CONFIG_XR_BT_LPM is not set # CONFIG_BT_MRVL is not set # CONFIG_BT_MTKSDIO is not set # end of Bluetooth device drivers # CONFIG_AF_RXRPC is not set # CONFIG_AF_KCM is not set CONFIG_FIB_RULES=y CONFIG_WIRELESS=y CONFIG_CFG80211=y # CONFIG_NL80211_TESTMODE is not set # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set CONFIG_CFG80211_CERTIFICATION_ONUS=y # CONFIG_CFG80211_REQUIRE_SIGNED_REGDB is not set # CONFIG_CFG80211_REG_CELLULAR_HINTS is not set # CONFIG_CFG80211_REG_RELAX_NO_IR is not set CONFIG_CFG80211_DEFAULT_PS=y # CONFIG_CFG80211_DEBUGFS is not set CONFIG_CFG80211_CRDA_SUPPORT=y # CONFIG_CFG80211_WEXT is not set # CONFIG_MAC80211 is not set CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 # CONFIG_WIMAX is not set # CONFIG_RFKILL is not set # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # CONFIG_NFC is not set # CONFIG_PSAMPLE is not set # CONFIG_NET_IFE is not set # CONFIG_LWTUNNEL is not set # CONFIG_FAILOVER is not set CONFIG_HAVE_EBPF_JIT=y # # Device Drivers # CONFIG_HAVE_PCI=y # CONFIG_PCI is not set # CONFIG_PCCARD is not set # # Generic Driver Options # # CONFIG_UEVENT_HELPER is not set CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y # # Firmware loader # CONFIG_FW_LOADER=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_FW_LOADER_USER_HELPER is not set # CONFIG_FW_LOADER_COMPRESS is not set CONFIG_FW_CACHE=y # end of Firmware loader CONFIG_ALLOW_DEV_COREDUMP=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set CONFIG_GENERIC_CPU_AUTOPROBE=y CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_SPI=y CONFIG_REGMAP_MMIO=y CONFIG_DMA_SHARED_BUFFER=y # CONFIG_DMA_FENCE_TRACE is not set CONFIG_GENERIC_ARCH_TOPOLOGY=y # end of Generic Driver Options # # Bus devices # # CONFIG_BRCMSTB_GISB_ARB is not set # CONFIG_MOXTET is not set # CONFIG_SIMPLE_PM_BUS is not set # CONFIG_SUN50I_DE2_BUS is not set # CONFIG_SUNXI_RSB is not set CONFIG_SUNXI_MBUS=y # CONFIG_SUNXI_NSI is not set # CONFIG_VEXPRESS_CONFIG is not set # end of Bus devices # CONFIG_CONNECTOR is not set # CONFIG_GNSS is not set CONFIG_MTD=y # CONFIG_MTD_TESTS is not set # CONFIG_MTD_REDBOOT_PARTS is not set # CONFIG_MTD_CMDLINE_PARTS is not set # CONFIG_MTD_AFS_PARTS is not set CONFIG_MTD_OF_PARTS=y # CONFIG_MTD_AR7_PARTS is not set # CONFIG_MTD_SUNXI_PARTS is not set # # Partition parsers # # end of Partition parsers # # User Modules And Translation Layers # CONFIG_MTD_BLKDEVS=y # CONFIG_MTD_CHAR is not set CONFIG_MTD_BLOCK=y # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # CONFIG_MTD_PARTITIONED_MASTER is not set # # RAM/ROM/Flash chip drivers # # CONFIG_MTD_CFI is not set # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # end of RAM/ROM/Flash chip drivers # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_PLATRAM is not set # end of Mapping drivers for chip access # # Self-contained MTD device drivers # # CONFIG_MTD_DATAFLASH is not set # CONFIG_MTD_MCHP23K256 is not set # CONFIG_MTD_SST25L is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOCG3 is not set # end of Self-contained MTD device drivers # CONFIG_MTD_ONENAND is not set # CONFIG_MTD_RAW_NAND is not set # CONFIG_MTD_SPI_NAND is not set # # sunxi-nand # CONFIG_AW_MTD_SPINAND=y # CONFIG_AW_MTD_RAWNAND is not set CONFIG_AW_SPINAND_PHYSICAL_LAYER=y CONFIG_AW_SPINAND_SECURE_STORAGE=y # CONFIG_AW_SPINAND_PSTORE_MTD_PART is not set # CONFIG_AW_SPINAND_ENABLE_PHY_CRC16 is not set CONFIG_AW_SPINAND_SIMULATE_MULTIPLANE=y # CONFIG_AW_MTD_SPINAND_OOB_RAW_SPARE is not set # end of sunxi-nand # # LPDDR & LPDDR2 PCM memory drivers # # CONFIG_MTD_LPDDR is not set # CONFIG_MTD_LPDDR2_NVM is not set # end of LPDDR & LPDDR2 PCM memory drivers # CONFIG_MTD_SPI_NOR is not set CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_LIMIT=40 # CONFIG_MTD_UBI_FASTMAP is not set # CONFIG_MTD_UBI_GLUEBI is not set CONFIG_MTD_UBI_BLOCK=y CONFIG_MTD_UBI_BLOCK_MAX_ACTIVE_WORKS=4 # CONFIG_MTD_HYPERBUS is not set CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_KOBJ=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_NET=y CONFIG_OF_MDIO=y CONFIG_OF_RESERVED_MEM=y # CONFIG_OF_OVERLAY is not set CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set # CONFIG_BLK_DEV_LOOP is not set # CONFIG_BLK_DEV_DRBD is not set # CONFIG_BLK_DEV_NBD is not set # CONFIG_BLK_DEV_RAM is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_BLK_DEV_RBD is not set # # NVME Support # # CONFIG_NVME_FC is not set # CONFIG_NVME_TARGET is not set # end of NVME Support # # Misc devices # # CONFIG_AD525X_DPOT is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_LATTICE_ECP3_CONFIG is not set # CONFIG_SRAM is not set # CONFIG_XILINX_SDFEC is not set # CONFIG_PVPANIC is not set # CONFIG_HISI_HIKEY_USB is not set # CONFIG_SUNXI_DIRECT_GPIO is not set # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_AT24 is not set # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set # CONFIG_EEPROM_93CX6 is not set # CONFIG_EEPROM_93XX46 is not set # CONFIG_EEPROM_IDT_89HPESX is not set # CONFIG_EEPROM_EE1004 is not set # end of EEPROM support # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # end of Texas Instruments shared transport line discipline # CONFIG_SENSORS_LIS3_SPI is not set # CONFIG_SENSORS_LIS3_I2C is not set # CONFIG_ALTERA_STAPL is not set # # Intel MIC & related support # # # Intel MIC Bus Driver # # # SCIF Bus Driver # # # VOP Bus Driver # # CONFIG_VOP_BUS is not set # # Intel MIC Host Driver # # # Intel MIC Card Driver # # # SCIF Driver # # # Intel MIC Coprocessor State Management (COSM) Drivers # # # VOP Driver # # end of Intel MIC & related support # CONFIG_ECHO is not set # CONFIG_MISC_RTSX_USB is not set CONFIG_SUNXI_RFKILL=y CONFIG_SUNXI_ADDR_MGT=y # CONFIG_SUNXI_BOOTEVENT is not set # # sunxi Gorilla ESL platform # # CONFIG_SUNXI_GORILLA is not set # end of sunxi Gorilla ESL platform # CONFIG_SUNXI_MIPSLOADER is not set # CONFIG_SUNXI_TVUTILS is not set # end of Misc devices # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=y CONFIG_SCSI_DMA=y CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_BLK_DEV_SR is not set # CONFIG_CHR_DEV_SG is not set # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set # end of SCSI Transports CONFIG_SCSI_LOWLEVEL=y # CONFIG_ISCSI_TCP is not set # CONFIG_ISCSI_BOOT_SYSFS is not set # CONFIG_SCSI_UFSHCD is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_DH is not set # end of SCSI device support # CONFIG_ATA is not set # CONFIG_MD is not set # CONFIG_TARGET_CORE is not set CONFIG_NETDEVICES=y CONFIG_MII=m CONFIG_NET_CORE=y # CONFIG_BONDING is not set # CONFIG_DUMMY is not set # CONFIG_EQUALIZER is not set # CONFIG_NET_TEAM is not set # CONFIG_MACVLAN is not set # CONFIG_IPVLAN is not set # CONFIG_VXLAN is not set # CONFIG_GENEVE is not set # CONFIG_GTP is not set # CONFIG_MACSEC is not set # CONFIG_NETCONSOLE is not set # CONFIG_TUN is not set # CONFIG_TUN_VNET_CROSS_LE is not set # CONFIG_VETH is not set # CONFIG_NLMON is not set # # CAIF transport drivers # # # Distributed Switch Architecture drivers # # end of Distributed Switch Architecture drivers CONFIG_ETHERNET=y # CONFIG_NET_VENDOR_ALACRITECH is not set CONFIG_NET_VENDOR_ALLWINNER=y # CONFIG_SUN4I_EMAC is not set CONFIG_SUNXI_GMAC=m CONFIG_SUNXI_EXT_PHY=y # CONFIG_ALTERA_TSE is not set # CONFIG_NET_VENDOR_AMAZON is not set # CONFIG_NET_VENDOR_AQUANTIA is not set # CONFIG_NET_VENDOR_ARC is not set # CONFIG_NET_VENDOR_AURORA is not set # CONFIG_NET_VENDOR_BROADCOM is not set # CONFIG_NET_VENDOR_CADENCE is not set # CONFIG_NET_VENDOR_CAVIUM is not set # CONFIG_NET_VENDOR_CIRRUS is not set # CONFIG_NET_VENDOR_CORTINA is not set # CONFIG_DM9000 is not set # CONFIG_DNET is not set # CONFIG_NET_VENDOR_EZCHIP is not set # CONFIG_NET_VENDOR_FARADAY is not set # CONFIG_NET_VENDOR_GOOGLE is not set # CONFIG_NET_VENDOR_HISILICON is not set # CONFIG_NET_VENDOR_HUAWEI is not set # CONFIG_NET_VENDOR_INTEL is not set # CONFIG_NET_VENDOR_MARVELL is not set # CONFIG_NET_VENDOR_MELLANOX is not set # CONFIG_NET_VENDOR_MICREL is not set # CONFIG_NET_VENDOR_MICROCHIP is not set # CONFIG_NET_VENDOR_MICROSEMI is not set # CONFIG_NET_VENDOR_NATSEMI is not set # CONFIG_NET_VENDOR_NETRONOME is not set # CONFIG_NET_VENDOR_NI is not set # CONFIG_ETHOC is not set # CONFIG_NET_VENDOR_PENSANDO is not set # CONFIG_NET_VENDOR_QUALCOMM is not set # CONFIG_NET_VENDOR_RENESAS is not set # CONFIG_NET_VENDOR_ROCKER is not set # CONFIG_NET_VENDOR_SAMSUNG is not set # CONFIG_NET_VENDOR_SEEQ is not set # CONFIG_NET_VENDOR_SOLARFLARE is not set # CONFIG_NET_VENDOR_SMSC is not set # CONFIG_NET_VENDOR_SOCIONEXT is not set # CONFIG_NET_VENDOR_STMICRO is not set # CONFIG_NET_VENDOR_SYNOPSYS is not set # CONFIG_NET_VENDOR_VIA is not set # CONFIG_NET_VENDOR_WIZNET is not set # CONFIG_NET_VENDOR_XILINX is not set CONFIG_MDIO_DEVICE=y CONFIG_MDIO_BUS=y # CONFIG_MDIO_BCM_UNIMAC is not set # CONFIG_MDIO_BITBANG is not set # CONFIG_MDIO_BUS_MUX_GPIO is not set # CONFIG_MDIO_BUS_MUX_MMIOREG is not set # CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set # CONFIG_MDIO_HISI_FEMAC is not set # CONFIG_MDIO_MSCC_MIIM is not set # CONFIG_MDIO_SUN4I is not set CONFIG_PHYLIB=y CONFIG_SWPHY=y # CONFIG_LED_TRIGGER_PHY is not set # # MII PHY device drivers # # CONFIG_ADIN_PHY is not set # CONFIG_AMD_PHY is not set # CONFIG_AQUANTIA_PHY is not set # CONFIG_AX88796B_PHY is not set # CONFIG_AT803X_PHY is not set # CONFIG_BCM7XXX_PHY is not set # CONFIG_BCM87XX_PHY is not set # CONFIG_BROADCOM_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_CORTINA_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_DP83822_PHY is not set # CONFIG_DP83TC811_PHY is not set # CONFIG_DP83848_PHY is not set # CONFIG_DP83867_PHY is not set CONFIG_FIXED_PHY=y # CONFIG_ICPLUS_PHY is not set # CONFIG_INTEL_XWAY_PHY is not set # CONFIG_LSI_ET1011C_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_MARVELL_PHY is not set # CONFIG_MARVELL_10G_PHY is not set # CONFIG_MICREL_PHY is not set # CONFIG_MICROCHIP_PHY is not set # CONFIG_MICROCHIP_T1_PHY is not set # CONFIG_MICROSEMI_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_NXP_TJA11XX_PHY is not set # CONFIG_QSEMI_PHY is not set CONFIG_REALTEK_PHY=y # CONFIG_RENESAS_PHY is not set # CONFIG_ROCKCHIP_PHY is not set # CONFIG_RTL8363_NB is not set # CONFIG_SMSC_PHY is not set # CONFIG_STE10XP is not set # CONFIG_TERANETICS_PHY is not set # CONFIG_VITESSE_PHY is not set # CONFIG_XILINX_GMII2RGMII is not set # CONFIG_MICREL_KS8995MA is not set # CONFIG_PPP is not set # CONFIG_SLIP is not set # CONFIG_USB_NET_DRIVERS is not set CONFIG_WLAN=y # CONFIG_WIRELESS_WDS is not set # CONFIG_WLAN_VENDOR_ADMTEK is not set # CONFIG_WLAN_VENDOR_ATH is not set # CONFIG_WLAN_VENDOR_ATMEL is not set # CONFIG_WLAN_VENDOR_BROADCOM is not set # CONFIG_WLAN_VENDOR_CISCO is not set # CONFIG_WLAN_VENDOR_INTEL is not set # CONFIG_WLAN_VENDOR_INTERSIL is not set # CONFIG_WLAN_VENDOR_MARVELL is not set # CONFIG_WLAN_VENDOR_MEDIATEK is not set # CONFIG_WLAN_VENDOR_RALINK is not set # CONFIG_WLAN_VENDOR_REALTEK is not set # CONFIG_WLAN_VENDOR_RSI is not set # CONFIG_WLAN_VENDOR_ST is not set # CONFIG_WLAN_VENDOR_TI is not set # CONFIG_WLAN_VENDOR_ZYDAS is not set # CONFIG_WLAN_VENDOR_QUANTENNA is not set # CONFIG_XR829_WLAN is not set # CONFIG_XR819S_WLAN is not set # CONFIG_SPARD_WLAN_SUPPORT is not set # CONFIG_BCMDHD is not set # CONFIG_AIC_WLAN_SUPPORT is not set CONFIG_RTL8723DS=m # CONFIG_USB_NET_RNDIS_WLAN is not set # CONFIG_VIRT_WIFI is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # CONFIG_WAN is not set # CONFIG_NETDEVSIM is not set # CONFIG_NET_FAILOVER is not set # CONFIG_ISDN is not set # CONFIG_NVM is not set # # Input device support # CONFIG_INPUT=y # CONFIG_INPUT_LEDS is not set # CONFIG_INPUT_FF_MEMLESS is not set # CONFIG_INPUT_POLLDEV is not set # CONFIG_INPUT_SPARSEKMAP is not set # CONFIG_INPUT_MATRIXKMAP is not set # # Userland interfaces # # CONFIG_INPUT_MOUSEDEV is not set # CONFIG_INPUT_JOYDEV is not set CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set CONFIG_INPUT_SENSORINIT=y # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ADP5589 is not set # CONFIG_KEYBOARD_ATKBD is not set # CONFIG_KEYBOARD_QT1050 is not set # CONFIG_KEYBOARD_QT1070 is not set # CONFIG_KEYBOARD_QT2160 is not set # CONFIG_KEYBOARD_DLINK_DIR685 is not set # CONFIG_KEYBOARD_LKKBD is not set # CONFIG_KEYBOARD_GPIO is not set # CONFIG_KEYBOARD_GPIO_POLLED is not set # CONFIG_KEYBOARD_TCA6416 is not set # CONFIG_KEYBOARD_TCA8418 is not set # CONFIG_KEYBOARD_MATRIX is not set # CONFIG_KEYBOARD_LM8323 is not set # CONFIG_KEYBOARD_LM8333 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_MCS is not set # CONFIG_KEYBOARD_MPR121 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set # CONFIG_KEYBOARD_SAMSUNG is not set # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_SUN4I_LRADC is not set # CONFIG_KEYBOARD_OMAP4 is not set # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set # CONFIG_KEYBOARD_XTKBD is not set # CONFIG_KEYBOARD_CAP11XX is not set # CONFIG_KEYBOARD_BCM is not set # CONFIG_KEYBOARD_SUNXI is not set # CONFIG_KEYBOARD_TPKEY is not set # CONFIG_INPUT_MOUSE is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set CONFIG_INPUT_TOUCHSCREEN=y CONFIG_TOUCHSCREEN_PROPERTIES=y # CONFIG_TOUCHSCREEN_ADS7846 is not set # CONFIG_TOUCHSCREEN_AD7877 is not set # CONFIG_TOUCHSCREEN_AD7879 is not set # CONFIG_TOUCHSCREEN_AR1021_I2C is not set # CONFIG_TOUCHSCREEN_ATMEL_MXT is not set # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set # CONFIG_TOUCHSCREEN_BU21013 is not set # CONFIG_TOUCHSCREEN_BU21029 is not set # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set # CONFIG_TOUCHSCREEN_DYNAPRO is not set # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_EGALAX is not set # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set # CONFIG_TOUCHSCREEN_EXC3000 is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set # CONFIG_TOUCHSCREEN_GOODIX is not set # CONFIG_TOUCHSCREEN_HIDEEP is not set # CONFIG_TOUCHSCREEN_ILI210X is not set # CONFIG_TOUCHSCREEN_S6SY761 is not set # CONFIG_TOUCHSCREEN_GUNZE is not set # CONFIG_TOUCHSCREEN_EKTF2127 is not set # CONFIG_TOUCHSCREEN_ELAN is not set # CONFIG_TOUCHSCREEN_ELO is not set # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set # CONFIG_TOUCHSCREEN_WACOM_I2C is not set # CONFIG_TOUCHSCREEN_MAX11801 is not set # CONFIG_TOUCHSCREEN_MCS5000 is not set # CONFIG_TOUCHSCREEN_MMS114 is not set # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set # CONFIG_TOUCHSCREEN_MTOUCH is not set # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set # CONFIG_TOUCHSCREEN_INEXIO is not set # CONFIG_TOUCHSCREEN_MK712 is not set # CONFIG_TOUCHSCREEN_PENMOUNT is not set # CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set # CONFIG_TOUCHSCREEN_TOUCHWIN is not set # CONFIG_TOUCHSCREEN_PIXCIR is not set # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC_SERIO is not set # CONFIG_TOUCHSCREEN_TSC2004 is not set # CONFIG_TOUCHSCREEN_TSC2005 is not set # CONFIG_TOUCHSCREEN_TSC2007 is not set # CONFIG_TOUCHSCREEN_RM_TS is not set # CONFIG_TOUCHSCREEN_SILEAD is not set # CONFIG_TOUCHSCREEN_SIS_I2C is not set # CONFIG_TOUCHSCREEN_ST1232 is not set # CONFIG_TOUCHSCREEN_STMFTS is not set # CONFIG_TOUCHSCREEN_SUN4I is not set # CONFIG_TOUCHSCREEN_SUNXI is not set # CONFIG_TOUCHSCREEN_SUR40 is not set # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set # CONFIG_TOUCHSCREEN_SX8654 is not set # CONFIG_TOUCHSCREEN_TPS6507X is not set # CONFIG_TOUCHSCREEN_ZET6223 is not set # CONFIG_TOUCHSCREEN_ZFORCE is not set # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set # CONFIG_TOUCHSCREEN_IQS5XX is not set CONFIG_TOUCHSCREEN_GSLX680NEW=m CONFIG_TOUCHSCREEN_GT9XXNEW_TS=m # CONFIG_TOUCHSCREEN_GT9XXNEWDUP_TS is not set CONFIG_TOUCHSCREEN_FTS=y # CONFIG_INPUT_MISC is not set # CONFIG_RMI4_CORE is not set CONFIG_INPUT_SENSOR=y # CONFIG_SENSORS_SC7A20 is not set # CONFIG_SENSORS_MIR3DA is not set # CONFIG_STK3X1X is not set # CONFIG_SUNXI_TPADC is not set CONFIG_SUNXI_GPADC=m # # Hardware I/O ports # # CONFIG_SERIO is not set # CONFIG_GAMEPORT is not set # end of Hardware I/O ports # end of Input device support # # Character devices # CONFIG_TTY=y # CONFIG_VT is not set CONFIG_UNIX98_PTYS=y # CONFIG_LEGACY_PTYS is not set # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_N_GSM is not set # CONFIG_TRACE_SINK is not set # CONFIG_NULL_TTY is not set # CONFIG_LDISC_AUTOLOAD is not set # CONFIG_DEVMEM is not set # CONFIG_DEVKMEM is not set # # Serial drivers # # CONFIG_SERIAL_8250 is not set # # Non-8250 serial port support # # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set # CONFIG_SERIAL_SAMSUNG is not set # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX310X is not set # CONFIG_SERIAL_UARTLITE is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_SIFIVE is not set # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_SC16IS7XX is not set # CONFIG_SERIAL_BCM63XX is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_IFX6X60 is not set # CONFIG_SERIAL_XILINX_PS_UART is not set # CONFIG_SERIAL_ARC is not set # CONFIG_SERIAL_FSL_LPUART is not set # CONFIG_SERIAL_FSL_LINFLEXUART is not set # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set # CONFIG_SERIAL_ST_ASC is not set # CONFIG_SERIAL_SPRD is not set CONFIG_SERIAL_SUNXI=y # CONFIG_SERIAL_SUNXI_DMA is not set CONFIG_SERIAL_SUNXI_CONSOLE=y # CONFIG_SERIAL_SUNXI_EARLYCON is not set # end of Serial drivers # CONFIG_SERIAL_DEV_BUS is not set # CONFIG_TTY_PRINTK is not set # CONFIG_HVC_DCC is not set # CONFIG_IPMI_HANDLER is not set # CONFIG_IPMB_DEVICE_INTERFACE is not set # CONFIG_HW_RANDOM is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set # CONFIG_XILLYBUS is not set # CONFIG_SUNXI_BS83B16C is not set # end of Character devices # CONFIG_RANDOM_TRUST_BOOTLOADER is not set CONFIG_DUMP_REG=y CONFIG_DUMP_REG_MISC=y CONFIG_SUNXI_G2D=y CONFIG_SUNXI_G2D_MIXER=y CONFIG_SUNXI_G2D_ROTATE=y CONFIG_SUNXI_SYNCFENCE=y # CONFIG_SUNXI_DI is not set # CONFIG_SUNXI_STANDBY_DEBUG is not set # CONFIG_SUNXI_SYS_INFO is not set # CONFIG_SUNXI_SMC is not set # # I2C support # CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y # CONFIG_I2C_COMPAT is not set CONFIG_I2C_CHARDEV=y # CONFIG_I2C_MUX is not set # CONFIG_I2C_HELPER_AUTO is not set # CONFIG_I2C_SMBUS is not set # # I2C Algorithms # # CONFIG_I2C_ALGOBIT is not set # CONFIG_I2C_ALGOPCF is not set # CONFIG_I2C_ALGOPCA is not set # end of I2C Algorithms # # I2C Hardware Bus support # # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_CBUS_GPIO is not set # CONFIG_I2C_DESIGNWARE_PLATFORM is not set # CONFIG_I2C_EMEV2 is not set # CONFIG_I2C_GPIO is not set # CONFIG_I2C_MV64XXX is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_SUNXI=y # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_RK3X is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_ROBOTFUZZ_OSIF is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # end of I2C Hardware Bus support # CONFIG_I2C_STUB is not set CONFIG_I2C_SLAVE=y # CONFIG_I2C_SLAVE_EEPROM is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # end of I2C support # CONFIG_I3C is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y # CONFIG_SPI_MEM is not set # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_AXI_SPI_ENGINE is not set # CONFIG_SPI_BITBANG is not set # CONFIG_SPI_CADENCE is not set # CONFIG_SPI_DESIGNWARE is not set # CONFIG_SPI_NXP_FLEXSPI is not set # CONFIG_SPI_GPIO is not set # CONFIG_SPI_FSL_SPI is not set # CONFIG_SPI_OC_TINY is not set # CONFIG_SPI_ROCKCHIP is not set # CONFIG_SPI_SC18IS602 is not set # CONFIG_SPI_SIFIVE is not set # CONFIG_SPI_SUN4I is not set # CONFIG_SPI_SUN6I is not set # CONFIG_SPI_MXIC is not set CONFIG_SPI_SUNXI=y # CONFIG_SPI_XCOMM is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_ZYNQMP_GQSPI is not set # # SPI Protocol Masters # CONFIG_SPI_SPIDEV=y # CONFIG_SPI_LOOPBACK_TEST is not set # CONFIG_SPI_TLE62X0 is not set # CONFIG_SPI_SLAVE is not set # CONFIG_SPMI is not set # CONFIG_HSI is not set # CONFIG_PPS is not set # # PTP clock support # # CONFIG_PTP_1588_CLOCK is not set # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # # end of PTP clock support CONFIG_PINCTRL=y CONFIG_PINMUX=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set # CONFIG_PINCTRL_AMD is not set # CONFIG_PINCTRL_MCP23S08 is not set # CONFIG_PINCTRL_SINGLE is not set # CONFIG_PINCTRL_SX150X is not set # CONFIG_PINCTRL_STMFX is not set # CONFIG_PINCTRL_OCELOT is not set # # Allwinner SOC PINCTRL DRIVER # CONFIG_PINCTRL_SUNXI=y # CONFIG_PINCTRL_SUNXI_DEBUGFS is not set # CONFIG_PINCTRL_SUNXI_TEST is not set # CONFIG_PINCTRL_SUN8IW15P1 is not set # CONFIG_PINCTRL_SUN8IW15P1_R is not set CONFIG_PINCTRL_SUN8IW20=y # CONFIG_PINCTRL_SUN50IW9 is not set # CONFIG_PINCTRL_SUN50IW9_R is not set # CONFIG_PINCTRL_SUN50IW10P1 is not set # CONFIG_PINCTRL_SUN50IW10P1_R is not set # CONFIG_PINCTRL_SUN50IW12 is not set # CONFIG_PINCTRL_SUN50IW12_R is not set # CONFIG_PINCTRL_SUN55IW3 is not set # CONFIG_PINCTRL_SUN55IW3_R is not set # CONFIG_PINCTRL_SUN4I_A10 is not set # CONFIG_PINCTRL_SUN5I is not set # CONFIG_PINCTRL_SUN6I_A31 is not set # CONFIG_PINCTRL_SUN6I_A31_R is not set # CONFIG_PINCTRL_SUN8I_A23 is not set # CONFIG_PINCTRL_SUN8I_A33 is not set # CONFIG_PINCTRL_SUN8I_A83T is not set # CONFIG_PINCTRL_SUN8I_A83T_R is not set # CONFIG_PINCTRL_SUN8I_A23_R is not set # CONFIG_PINCTRL_SUN8I_H3 is not set # CONFIG_PINCTRL_SUN8I_H3_R is not set # CONFIG_PINCTRL_SUN8I_V3S is not set # CONFIG_PINCTRL_SUN9I_A80 is not set # CONFIG_PINCTRL_SUN9I_A80_R is not set # CONFIG_PINCTRL_SUN50I_A64 is not set # CONFIG_PINCTRL_SUN50I_A64_R is not set # CONFIG_PINCTRL_SUN50I_A100 is not set # CONFIG_PINCTRL_SUN50I_A100_R is not set # CONFIG_PINCTRL_SUN50I_H5 is not set # CONFIG_PINCTRL_SUN50I_H6 is not set # CONFIG_PINCTRL_SUN50I_H6_R is not set # end of Allwinner SOC PINCTRL DRIVER CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y CONFIG_GPIOLIB=y CONFIG_GPIOLIB_FASTPATH_LIMIT=512 CONFIG_OF_GPIO=y # CONFIG_DEBUG_GPIO is not set CONFIG_GPIO_SYSFS=y # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set # CONFIG_GPIO_ALTERA is not set # CONFIG_GPIO_SUNXI is not set # CONFIG_GPIO_CADENCE is not set # CONFIG_GPIO_DWAPB is not set # CONFIG_GPIO_FTGPIO010 is not set # CONFIG_GPIO_GENERIC_PLATFORM is not set # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_HLWD is not set # CONFIG_GPIO_MB86S7X is not set # CONFIG_GPIO_MPC8XXX is not set # CONFIG_GPIO_SAMA5D2_PIOBU is not set # CONFIG_GPIO_SYSCON is not set # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_ZEVIO is not set # CONFIG_GPIO_AMD_FCH is not set # end of Memory mapped GPIO drivers # # I2C GPIO expanders # # CONFIG_GPIO_ADP5588 is not set # CONFIG_GPIO_ADNP is not set # CONFIG_GPIO_BS83B16C is not set # CONFIG_GPIO_GW_PLD is not set # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCA953X is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_TPIC2810 is not set # end of I2C GPIO expanders # # MFD GPIO expanders # # CONFIG_HTC_EGPIO is not set # end of MFD GPIO expanders # # SPI GPIO expanders # # CONFIG_GPIO_74X164 is not set # CONFIG_GPIO_MAX3191X is not set # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MC33880 is not set # CONFIG_GPIO_PISOSR is not set # CONFIG_GPIO_XRA1403 is not set # end of SPI GPIO expanders # # USB GPIO expanders # # end of USB GPIO expanders # CONFIG_GPIO_MOCKUP is not set # CONFIG_W1 is not set # CONFIG_POWER_AVS is not set # CONFIG_POWER_RESET is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set CONFIG_POWER_SUPPLY_HWMON=y # CONFIG_PDA_POWER is not set # CONFIG_TEST_POWER is not set # CONFIG_CHARGER_ADP5061 is not set # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set # CONFIG_BATTERY_SBS is not set # CONFIG_CHARGER_SBS is not set # CONFIG_BATTERY_BQ27XXX is not set # CONFIG_BATTERY_MAX17040 is not set # CONFIG_BATTERY_MAX17042 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_MANAGER is not set # CONFIG_CHARGER_LT3651 is not set # CONFIG_CHARGER_DETECTOR_MAX14656 is not set # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24257 is not set # CONFIG_CHARGER_BQ24735 is not set # CONFIG_CHARGER_BQ25890 is not set # CONFIG_CHARGER_SMB347 is not set # CONFIG_BATTERY_GAUGE_LTC2941 is not set # CONFIG_CHARGER_RT9455 is not set # CONFIG_CHARGER_UCS1002 is not set CONFIG_HWMON=y # CONFIG_HWMON_DEBUG_CHIP is not set # # Native drivers # # CONFIG_SENSORS_AD7314 is not set # CONFIG_SENSORS_AD7414 is not set # CONFIG_SENSORS_AD7418 is not set # CONFIG_SENSORS_ADM1021 is not set # CONFIG_SENSORS_ADM1025 is not set # CONFIG_SENSORS_ADM1026 is not set # CONFIG_SENSORS_ADM1029 is not set # CONFIG_SENSORS_ADM1031 is not set # CONFIG_SENSORS_ADM9240 is not set # CONFIG_SENSORS_ADT7310 is not set # CONFIG_SENSORS_ADT7410 is not set # CONFIG_SENSORS_ADT7411 is not set # CONFIG_SENSORS_ADT7462 is not set # CONFIG_SENSORS_ADT7470 is not set # CONFIG_SENSORS_ADT7475 is not set # CONFIG_SENSORS_AS370 is not set # CONFIG_SENSORS_ASC7621 is not set # CONFIG_SENSORS_ASPEED is not set # CONFIG_SENSORS_ATXP1 is not set # CONFIG_SENSORS_DS620 is not set # CONFIG_SENSORS_DS1621 is not set # CONFIG_SENSORS_F71805F is not set # CONFIG_SENSORS_F71882FG is not set # CONFIG_SENSORS_F75375S is not set # CONFIG_SENSORS_GL518SM is not set # CONFIG_SENSORS_GL520SM is not set # CONFIG_SENSORS_G760A is not set # CONFIG_SENSORS_G762 is not set # CONFIG_SENSORS_GPIO_FAN is not set # CONFIG_SENSORS_HIH6130 is not set # CONFIG_SENSORS_IT87 is not set # CONFIG_SENSORS_JC42 is not set # CONFIG_SENSORS_POWR1220 is not set # CONFIG_SENSORS_LINEAGE is not set # CONFIG_SENSORS_LTC2945 is not set # CONFIG_SENSORS_LTC2990 is not set # CONFIG_SENSORS_LTC4151 is not set # CONFIG_SENSORS_LTC4215 is not set # CONFIG_SENSORS_LTC4222 is not set # CONFIG_SENSORS_LTC4245 is not set # CONFIG_SENSORS_LTC4260 is not set # CONFIG_SENSORS_LTC4261 is not set # CONFIG_SENSORS_MAX1111 is not set # CONFIG_SENSORS_MAX16065 is not set # CONFIG_SENSORS_MAX1619 is not set # CONFIG_SENSORS_MAX1668 is not set # CONFIG_SENSORS_MAX197 is not set # CONFIG_SENSORS_MAX31722 is not set # CONFIG_SENSORS_MAX6621 is not set # CONFIG_SENSORS_MAX6639 is not set # CONFIG_SENSORS_MAX6642 is not set # CONFIG_SENSORS_MAX6650 is not set # CONFIG_SENSORS_MAX6697 is not set # CONFIG_SENSORS_MAX31790 is not set # CONFIG_SENSORS_MCP3021 is not set # CONFIG_SENSORS_TC654 is not set # CONFIG_SENSORS_ADCXX is not set # CONFIG_SENSORS_LM63 is not set # CONFIG_SENSORS_LM70 is not set # CONFIG_SENSORS_LM73 is not set # CONFIG_SENSORS_LM75 is not set # CONFIG_SENSORS_LM77 is not set # CONFIG_SENSORS_LM78 is not set # CONFIG_SENSORS_LM80 is not set # CONFIG_SENSORS_LM83 is not set # CONFIG_SENSORS_LM85 is not set # CONFIG_SENSORS_LM87 is not set # CONFIG_SENSORS_LM90 is not set # CONFIG_SENSORS_LM92 is not set # CONFIG_SENSORS_LM93 is not set # CONFIG_SENSORS_LM95234 is not set # CONFIG_SENSORS_LM95241 is not set # CONFIG_SENSORS_LM95245 is not set # CONFIG_SENSORS_PC87360 is not set # CONFIG_SENSORS_PC87427 is not set # CONFIG_SENSORS_NTC_THERMISTOR is not set # CONFIG_SENSORS_NCT6683 is not set # CONFIG_SENSORS_NCT6775 is not set # CONFIG_SENSORS_NCT7802 is not set # CONFIG_SENSORS_NCT7904 is not set # CONFIG_SENSORS_NPCM7XX is not set # CONFIG_SENSORS_OCC_P8_I2C is not set # CONFIG_SENSORS_PCF8591 is not set # CONFIG_PMBUS is not set # CONFIG_SENSORS_PWM_FAN is not set # CONFIG_SENSORS_SHT15 is not set # CONFIG_SENSORS_SHT21 is not set # CONFIG_SENSORS_SHT3x is not set # CONFIG_SENSORS_SHTC1 is not set # CONFIG_SENSORS_DME1737 is not set # CONFIG_SENSORS_EMC1403 is not set # CONFIG_SENSORS_EMC2103 is not set # CONFIG_SENSORS_EMC6W201 is not set # CONFIG_SENSORS_SMSC47M1 is not set # CONFIG_SENSORS_SMSC47M192 is not set # CONFIG_SENSORS_SMSC47B397 is not set # CONFIG_SENSORS_STTS751 is not set # CONFIG_SENSORS_SMM665 is not set # CONFIG_SENSORS_ADC128D818 is not set # CONFIG_SENSORS_ADS7828 is not set # CONFIG_SENSORS_ADS7871 is not set # CONFIG_SENSORS_AMC6821 is not set # CONFIG_SENSORS_INA209 is not set # CONFIG_SENSORS_INA2XX is not set # CONFIG_SENSORS_INA3221 is not set # CONFIG_SENSORS_TC74 is not set # CONFIG_SENSORS_THMC50 is not set # CONFIG_SENSORS_TMP102 is not set # CONFIG_SENSORS_TMP103 is not set # CONFIG_SENSORS_TMP108 is not set # CONFIG_SENSORS_TMP401 is not set # CONFIG_SENSORS_TMP421 is not set # CONFIG_SENSORS_VT1211 is not set # CONFIG_SENSORS_W83773G is not set # CONFIG_SENSORS_W83781D is not set # CONFIG_SENSORS_W83791D is not set # CONFIG_SENSORS_W83792D is not set # CONFIG_SENSORS_W83793 is not set # CONFIG_SENSORS_W83795 is not set # CONFIG_SENSORS_W83L785TS is not set # CONFIG_SENSORS_W83L786NG is not set # CONFIG_SENSORS_W83627HF is not set # CONFIG_SENSORS_W83627EHF is not set # CONFIG_THERMAL is not set # CONFIG_WATCHDOG is not set CONFIG_SSB_POSSIBLE=y # CONFIG_SSB is not set CONFIG_BCMA_POSSIBLE=y # CONFIG_BCMA is not set # # Multifunction device drivers # # CONFIG_MFD_ACX00 is not set # CONFIG_MFD_ACT8945A is not set # CONFIG_MFD_SUN4I_GPADC is not set # CONFIG_MFD_AS3711 is not set # CONFIG_MFD_AS3722 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_BCM590XX is not set # CONFIG_MFD_BD9571MWV is not set # CONFIG_MFD_AXP2101_I2C is not set # CONFIG_MFD_AXP20X_I2C is not set # CONFIG_MFD_MADERA is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9062 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_DA9150 is not set # CONFIG_MFD_DLN2 is not set # CONFIG_MFD_MC13XXX_SPI is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_MFD_HI6421_PMIC is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX14577 is not set # CONFIG_MFD_MAX77620 is not set # CONFIG_MFD_MAX77650 is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX77843 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_MFD_MT6397 is not set # CONFIG_MFD_MENF21BMC is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_CPCAP is not set # CONFIG_MFD_VIPERBOARD is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_PM8XXX is not set # CONFIG_MFD_RT5033 is not set # CONFIG_MFD_RC5T583 is not set # CONFIG_MFD_RK808 is not set # CONFIG_MFD_RN5T618 is not set # CONFIG_MFD_SEC_CORE is not set # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SKY81452 is not set # CONFIG_MFD_SMSC is not set # CONFIG_ABX500_CORE is not set # CONFIG_MFD_STMPE is not set # CONFIG_MFD_SUN6I_PRCM is not set CONFIG_MFD_SYSCON=y # CONFIG_MFD_TI_AM335X_TSCADC is not set # CONFIG_MFD_LP3943 is not set # CONFIG_MFD_LP8788 is not set # CONFIG_MFD_TI_LMU is not set # CONFIG_MFD_PALMAS is not set # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65086 is not set # CONFIG_MFD_TPS65090 is not set # CONFIG_MFD_TPS65217 is not set # CONFIG_MFD_TI_LP873X is not set # CONFIG_MFD_TI_LP87565 is not set # CONFIG_MFD_TPS65218 is not set # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_TPS65910 is not set # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set # CONFIG_MFD_TPS80031 is not set # CONFIG_TWL4030_CORE is not set # CONFIG_TWL6040_CORE is not set # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_MFD_TQMX86 is not set # CONFIG_MFD_LOCHNAGAR is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_ARIZONA_SPI is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set # CONFIG_MFD_ROHM_BD718XX is not set # CONFIG_MFD_ROHM_BD70528 is not set # CONFIG_MFD_STPMIC1 is not set # CONFIG_MFD_STMFX is not set # end of Multifunction device drivers CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set CONFIG_REGULATOR_FIXED_VOLTAGE=y # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_88PG86X is not set # CONFIG_REGULATOR_ACT8865 is not set # CONFIG_REGULATOR_AD5398 is not set # CONFIG_REGULATOR_ANATOP is not set # CONFIG_SUNXI_REGULATOR_PWM is not set # CONFIG_REGULATOR_DA9210 is not set # CONFIG_REGULATOR_DA9211 is not set # CONFIG_REGULATOR_FAN53555 is not set # CONFIG_REGULATOR_GPIO is not set # CONFIG_REGULATOR_ISL9305 is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_LP872X is not set # CONFIG_REGULATOR_LP8755 is not set # CONFIG_REGULATOR_LTC3589 is not set # CONFIG_REGULATOR_LTC3676 is not set # CONFIG_REGULATOR_MAX1586 is not set # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8952 is not set # CONFIG_REGULATOR_MCP16502 is not set # CONFIG_REGULATOR_MT6311 is not set # CONFIG_REGULATOR_PFUZE100 is not set # CONFIG_REGULATOR_PV88060 is not set # CONFIG_REGULATOR_PV88080 is not set # CONFIG_REGULATOR_PV88090 is not set # CONFIG_REGULATOR_PWM is not set # CONFIG_REGULATOR_SLG51000 is not set # CONFIG_REGULATOR_SY8106A is not set # CONFIG_REGULATOR_SY8824X is not set # CONFIG_REGULATOR_TPS51632 is not set # CONFIG_REGULATOR_TPS62360 is not set # CONFIG_REGULATOR_TPS65023 is not set # CONFIG_REGULATOR_TPS6507X is not set # CONFIG_REGULATOR_TPS65132 is not set # CONFIG_REGULATOR_TPS6524X is not set # CONFIG_REGULATOR_VCTRL is not set CONFIG_RC_CORE=y CONFIG_RC_MAP=y CONFIG_LIRC=y CONFIG_RC_DECODERS=y # CONFIG_IR_NEC_DECODER is not set # CONFIG_IR_RC5_DECODER is not set # CONFIG_IR_RC6_DECODER is not set # CONFIG_IR_JVC_DECODER is not set # CONFIG_IR_SONY_DECODER is not set # CONFIG_IR_SANYO_DECODER is not set # CONFIG_IR_SHARP_DECODER is not set # CONFIG_IR_MCE_KBD_DECODER is not set # CONFIG_IR_XMP_DECODER is not set # CONFIG_IR_IMON_DECODER is not set # CONFIG_IR_RCMM_DECODER is not set CONFIG_RC_DEVICES=y # CONFIG_RC_ATI_REMOTE is not set # CONFIG_IR_HIX5HD2 is not set # CONFIG_IR_IMON is not set # CONFIG_IR_IMON_RAW is not set # CONFIG_IR_MCEUSB is not set # CONFIG_IR_REDRAT3 is not set # CONFIG_IR_SPI is not set # CONFIG_IR_STREAMZAP is not set # CONFIG_IR_IGORPLUGUSB is not set # CONFIG_IR_IGUANA is not set # CONFIG_IR_TTUSBIR is not set # CONFIG_RC_LOOPBACK is not set # CONFIG_IR_GPIO_CIR is not set # CONFIG_IR_GPIO_TX is not set # CONFIG_IR_PWM_TX is not set # CONFIG_IR_SUNXI is not set # CONFIG_IR_RX_SUNXI is not set # CONFIG_IR_TX_SUNXI is not set # CONFIG_IR_SERIAL is not set # CONFIG_IR_SIR is not set # CONFIG_RC_XBOX_DVD is not set CONFIG_MEDIA_SUPPORT=y # # Multimedia core support # CONFIG_MEDIA_CAMERA_SUPPORT=y # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set # CONFIG_MEDIA_RADIO_SUPPORT is not set # CONFIG_MEDIA_SDR_SUPPORT is not set # CONFIG_MEDIA_CEC_SUPPORT is not set CONFIG_MEDIA_CONTROLLER=y CONFIG_VIDEO_DEV=y CONFIG_VIDEO_V4L2_SUBDEV_API=y CONFIG_VIDEO_V4L2=y CONFIG_VIDEO_V4L2_I2C=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set CONFIG_V4L2_MEM2MEM_DEV=m # # Media drivers # CONFIG_MEDIA_USB_SUPPORT=y # # Webcam devices # CONFIG_USB_VIDEO_CLASS=y CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y # CONFIG_USB_GSPCA is not set # CONFIG_USB_PWC is not set # CONFIG_VIDEO_CPIA2 is not set # CONFIG_USB_ZR364XX is not set # CONFIG_USB_STKWEBCAM is not set # CONFIG_USB_S2255 is not set # CONFIG_VIDEO_USBTV is not set # # Webcam, TV (analog/digital) USB devices # # CONFIG_VIDEO_EM28XX is not set CONFIG_V4L_PLATFORM_DRIVERS=y # CONFIG_VIDEO_CADENCE is not set # CONFIG_VIDEO_ASPEED is not set # CONFIG_VIDEO_MUX is not set # CONFIG_VIDEO_XILINX is not set # CONFIG_VIDEO_SUN4I_CSI is not set # CONFIG_VIDEO_SUN6I_CSI is not set # CONFIG_VIDEO_SUNXI_TVD is not set CONFIG_SUNXI_PLATFORM_DRIVERS=y CONFIG_VIDEO_SUNXI_VIN=m CONFIG_CSI_VIN=m # CONFIG_ENABLE_SENSOR_FLIP_OPTION is not set CONFIG_CSI_CCI=m # CONFIG_CCI is not set CONFIG_CCI_TO_TWI=y # CONFIG_FLASH is not set # CONFIG_ACTUATOR is not set # CONFIG_SENSOR_LIST is not set # CONFIG_BUF_AUTO_UPDATE is not set # CONFIG_VIN_LOG is not set # CONFIG_PIPELINE_RESET is not set # CONFIG_MULTI_FRAME is not set # CONFIG_SUPPORT_ISP_TDM is not set # CONFIG_DISPPLAY_SYNC is not set # CONFIG_VIN_IOMMU is not set # CONFIG_D3D is not set CONFIG_WDR=y # CONFIG_WDR_COMPRESS_EN is not set # CONFIG_SAME_I2C is not set # # sensor driver select # # CONFIG_SENSOR_RN6854M is not set # CONFIG_SENSOR_NVP6158C is not set # CONFIG_SENSOR_GC030A is not set # CONFIG_SENSOR_GC2385 is not set # CONFIG_SENSOR_GC5025 is not set # CONFIG_SENSOR_IMX278 is not set # CONFIG_SENSOR_IMX278_2LANE is not set # CONFIG_SENSOR_IMX386 is not set # CONFIG_SENSOR_IMX386_2LANE is not set CONFIG_SENSOR_OV5640=m # CONFIG_SENSOR_OV2775 is not set # CONFIG_SENSOR_GC2145 is not set # CONFIG_SENSOR_GC0310 is not set # CONFIG_SENSOR_GC2355 is not set # CONFIG_SENSOR_GC5024 is not set # CONFIG_SENSOR_GC5035 is not set # CONFIG_SENSOR_GC2590 is not set # CONFIG_SENSOR_SP5409 is not set # CONFIG_SENSOR_IMX214 is not set # CONFIG_SENSOR_IMX219 is not set # CONFIG_SENSOR_IMX274_SLVDS is not set # CONFIG_SENSOR_IMX291_DVP is not set # CONFIG_SENSOR_IMX291 is not set # CONFIG_SENSOR_IMX317 is not set # CONFIG_SENSOR_IMX335 is not set # CONFIG_SENSOR_IMX326 is not set # CONFIG_SENSOR_IMX477 is not set # CONFIG_SENSOR_OV2710 is not set # CONFIG_SENSOR_OV2718 is not set # CONFIG_SENSOR_AR0238 is not set # CONFIG_SENSOR_OV8858_R2A_4LANE is not set # CONFIG_SENSOR_OV2680 is not set # CONFIG_SENSOR_S5K3H5XA is not set # CONFIG_SENSOR_AR0238_HISPI is not set # CONFIG_SENSOR_NVP6134 is not set # CONFIG_SENSOR_NVP6324 is not set # CONFIG_SENSOR_TP9950 is not set # CONFIG_SENSOR_SC2232 is not set # CONFIG_SENSOR_GC02M2 is not set # end of sensor driver select # CONFIG_SENSOR_POWER is not set CONFIG_V4L_MEM2MEM_DRIVERS=y CONFIG_VIDEO_MEM2MEM_DEINTERLACE=m CONFIG_VIDEO_SH_VEU=m # CONFIG_V4L_TEST_DRIVERS is not set # # Supported MMC/SDIO adapters # # CONFIG_CYPRESS_FIRMWARE is not set CONFIG_VIDEOBUF2_CORE=y CONFIG_VIDEOBUF2_V4L2=y CONFIG_VIDEOBUF2_MEMOPS=y CONFIG_VIDEOBUF2_DMA_CONTIG=m CONFIG_VIDEOBUF2_VMALLOC=y # # Media ancillary drivers (tuners, sensors, i2c, spi, frontends) # # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set # CONFIG_VIDEO_IR_I2C is not set # # I2C Encoders, decoders, sensors and other helper chips # # # Audio decoders, processors and mixers # # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TDA1997X is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_CS3308 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_UDA1342 is not set # CONFIG_VIDEO_WM8775 is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_VP27SMPX is not set # CONFIG_VIDEO_SONY_BTF_MPX is not set # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # # Video decoders # # CONFIG_VIDEO_ADV7180 is not set # CONFIG_VIDEO_ADV7183 is not set # CONFIG_VIDEO_ADV748X is not set # CONFIG_VIDEO_ADV7604 is not set # CONFIG_VIDEO_ADV7842 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_KS0127 is not set # CONFIG_VIDEO_ML86V7667 is not set # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_TC358743 is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set # CONFIG_VIDEO_TVP7002 is not set # CONFIG_VIDEO_TW2804 is not set # CONFIG_VIDEO_TW9903 is not set # CONFIG_VIDEO_TW9906 is not set # CONFIG_VIDEO_TW9910 is not set # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_CX25840 is not set # # Video encoders # # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_ADV7393 is not set # CONFIG_VIDEO_ADV7511 is not set # CONFIG_VIDEO_AD9389B is not set # CONFIG_VIDEO_AK881X is not set # CONFIG_VIDEO_THS8200 is not set # # Camera sensor devices # # CONFIG_VIDEO_IMX258 is not set # CONFIG_VIDEO_IMX274 is not set # CONFIG_VIDEO_IMX319 is not set # CONFIG_VIDEO_IMX355 is not set # CONFIG_VIDEO_OV2640 is not set # CONFIG_VIDEO_OV2659 is not set # CONFIG_VIDEO_OV2680 is not set # CONFIG_VIDEO_OV2685 is not set # CONFIG_VIDEO_OV5640 is not set # CONFIG_VIDEO_OV5645 is not set # CONFIG_VIDEO_OV5647 is not set # CONFIG_VIDEO_OV6650 is not set # CONFIG_VIDEO_OV5670 is not set # CONFIG_VIDEO_OV5675 is not set # CONFIG_VIDEO_OV5695 is not set # CONFIG_VIDEO_OV7251 is not set # CONFIG_VIDEO_OV772X is not set # CONFIG_VIDEO_OV7640 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_OV7740 is not set # CONFIG_VIDEO_OV8856 is not set # CONFIG_VIDEO_OV9640 is not set # CONFIG_VIDEO_OV9650 is not set # CONFIG_VIDEO_OV13858 is not set # CONFIG_VIDEO_VS6624 is not set # CONFIG_VIDEO_MT9M001 is not set # CONFIG_VIDEO_MT9M032 is not set # CONFIG_VIDEO_MT9M111 is not set # CONFIG_VIDEO_MT9P031 is not set # CONFIG_VIDEO_MT9T001 is not set # CONFIG_VIDEO_MT9T112 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_MT9V032 is not set # CONFIG_VIDEO_MT9V111 is not set # CONFIG_VIDEO_SR030PC30 is not set # CONFIG_VIDEO_NOON010PC30 is not set # CONFIG_VIDEO_M5MOLS is not set # CONFIG_VIDEO_RJ54N1 is not set # CONFIG_VIDEO_S5K6AA is not set # CONFIG_VIDEO_S5K6A3 is not set # CONFIG_VIDEO_S5K4ECGX is not set # CONFIG_VIDEO_S5K5BAF is not set # CONFIG_VIDEO_SMIAPP is not set # CONFIG_VIDEO_ET8EK8 is not set # CONFIG_VIDEO_S5C73M3 is not set # # Lens drivers # # CONFIG_VIDEO_AD5820 is not set # CONFIG_VIDEO_AK7375 is not set # CONFIG_VIDEO_DW9714 is not set # CONFIG_VIDEO_DW9807_VCM is not set # # Flash devices # # CONFIG_VIDEO_ADP1653 is not set # CONFIG_VIDEO_LM3560 is not set # CONFIG_VIDEO_LM3646 is not set # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set # # Audio/Video compression chips # # CONFIG_VIDEO_SAA6752HS is not set # # SDR tuner chips # # # Miscellaneous helper chips # # CONFIG_VIDEO_THS7303 is not set # CONFIG_VIDEO_M52790 is not set # CONFIG_VIDEO_I2C is not set # CONFIG_VIDEO_ST_MIPID02 is not set # end of I2C Encoders, decoders, sensors and other helper chips # # SPI helper chips # # CONFIG_VIDEO_GS1662 is not set # end of SPI helper chips # # Media SPI Adapters # # end of Media SPI Adapters # # Customise DVB Frontends # # # Tools to develop new frontends # # end of Customise DVB Frontends CONFIG_VIDEO_ENCODER_DECODER_SUNXI=y # CONFIG_VIDEO_GOOGLE_DECODER_SUNXI is not set # # Graphics support # # CONFIG_IMX_IPUV3_CORE is not set # CONFIG_DRM is not set # CONFIG_DRM_DP_CEC is not set # # ARM devices # # end of ARM devices # # ACP (Audio CoProcessor) Configuration # # end of ACP (Audio CoProcessor) Configuration # # Frame buffer Devices # CONFIG_FB_CMDLINE=y CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set # CONFIG_FB_FOREIGN_ENDIAN is not set # CONFIG_FB_MODE_HELPERS is not set # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_OPENCORES is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_SMSCUFX is not set # CONFIG_FB_UDL is not set # CONFIG_FB_IBM_GXT4500 is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_SIMPLE is not set # CONFIG_FB_SSD1307 is not set # # Video support for sunxi # # CONFIG_FB_CONSOLE_SUNXI is not set CONFIG_DISP2_SUNXI=y CONFIG_SUNXI_DISP2_FB_DISABLE_ROTATE=y # CONFIG_SUNXI_DISP2_FB_ROTATION_SUPPORT is not set # CONFIG_SUNXI_DISP2_FB_HW_ROTATION_SUPPORT is not set # CONFIG_SUNXI_DISP2_FB_DECOMPRESS_LZMA is not set # CONFIG_HDMI_DISP2_SUNXI is not set # CONFIG_HDMI2_DISP2_SUNXI is not set # CONFIG_HDMI_EP952_DISP2_SUNXI is not set # CONFIG_TV_DISP2_SUNXI is not set # CONFIG_VDPO_DISP2_SUNXI is not set # CONFIG_EDP_DISP2_SUNXI is not set # CONFIG_DISP2_SUNXI_BOOT_COLORBAR is not set # CONFIG_DISP2_SUNXI_DEBUG is not set # CONFIG_DISP2_SUNXI_COMPOSER is not set # CONFIG_DISP2_LCD_ESD_DETECT is not set # CONFIG_LCD_FB is not set # CONFIG_LCD_FB_ENABLE_DEFERRED_IO is not set # # LCD panels select # # CONFIG_LCD_SUPPORT_GG1P4062UTSW is not set # CONFIG_LCD_SUPPORT_DX0960BE40A1 is not set # CONFIG_LCD_SUPPORT_TFT720X1280 is not set # CONFIG_LCD_SUPPORT_FD055HD003S is not set # CONFIG_LCD_SUPPORT_HE0801A068 is not set # CONFIG_LCD_SUPPORT_ILI9341 is not set # CONFIG_LCD_SUPPORT_LH219WQ1 is not set # CONFIG_LCD_SUPPORT_LS029B3SX02 is not set # CONFIG_LCD_SUPPORT_LT070ME05000 is not set # CONFIG_LCD_SUPPORT_S6D7AA0X01 is not set # CONFIG_LCD_SUPPORT_T27P06 is not set # CONFIG_LCD_SUPPORT_TFT720x1280 is not set # CONFIG_LCD_SUPPORT_WTQ05027D01 is not set # CONFIG_LCD_SUPPORT_H245QBN02 is not set # CONFIG_LCD_SUPPORT_ST7789V is not set # CONFIG_LCD_SUPPORT_ST7796S is not set # CONFIG_LCD_SUPPORT_ST7701S is not set # CONFIG_LCD_SUPPORT_T30P106 is not set # CONFIG_LCD_SUPPORT_TO20T20000 is not set # CONFIG_LCD_SUPPORT_FRD450H40014 is not set # CONFIG_LCD_SUPPORT_S2003T46G is not set # CONFIG_LCD_SUPPORT_WILLIAMLCD is not set # CONFIG_LCD_SUPPORT_LQ101R1SX03 is not set # CONFIG_LCD_SUPPORT_INET_DSI_PANEL is not set # CONFIG_LCD_SUPPORT_WTL096601G03 is not set # CONFIG_LCD_SUPPORT_RT13QV005D is not set # CONFIG_LCD_SUPPORT_ST7789V_CPU is not set # CONFIG_LCD_SUPPORT_CC08021801_310_800X1280 is not set # CONFIG_LCD_SUPPORT_JD9366AB_3 is not set # CONFIG_LCD_SUPPORT_TFT08006 is not set CONFIG_LCD_SUPPORT_BP101WX1_206=y CONFIG_LCD_SUPPORT_FX070=y CONFIG_LCD_SUPPORT_K101IM2QA04=y CONFIG_LCD_SUPPORT_K101_IM2BYL02_L_800X1280=y CONFIG_LCD_SUPPORT_K080_IM2HYL802R_800X1280=y # CONFIG_LCD_SUPPORT_NT35510_MIPI is not set # CONFIG_LCD_SUPPORT_ST7701S_3SPI is not set # CONFIG_LCD_SUPPORT_D395T9375V0 is not set # end of LCD panels select # # Display engine feature select # CONFIG_DISP2_SUNXI_SUPPORT_SMBL=y CONFIG_DISP2_SUNXI_SUPPORT_ENAHNCE=y CONFIG_DISP2_SUNXI_DEVICE_OFF_ON_RELEASE=y # end of Display engine feature select # end of Video support for sunxi # end of Frame buffer Devices # # Backlight & LCD device support # # CONFIG_LCD_CLASS_DEVICE is not set # CONFIG_BACKLIGHT_CLASS_DEVICE is not set # end of Backlight & LCD device support # CONFIG_LOGO is not set # end of Graphics support CONFIG_SOUND=y CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_DMAENGINE_PCM=y CONFIG_SND_JACK=y CONFIG_SND_JACK_INPUT_DEV=y # CONFIG_SND_MIXER_OSS is not set CONFIG_SND_PCM_TIMER=y # CONFIG_SND_HRTIMER is not set # CONFIG_SND_DYNAMIC_MINORS is not set # CONFIG_SND_SUPPORT_OLD_API is not set # CONFIG_SND_PROC_FS is not set # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set # CONFIG_SND_SEQUENCER is not set CONFIG_SND_DRIVERS=y # CONFIG_SND_DUMMY is not set # CONFIG_SND_ALOOP is not set # CONFIG_SND_MTPAV is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_MPU401 is not set # # HD-Audio # # end of HD-Audio CONFIG_SND_HDA_PREALLOC_SIZE=64 # CONFIG_SND_ARM is not set # CONFIG_SND_SPI is not set CONFIG_SND_USB=y # CONFIG_SND_USB_AUDIO is not set # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set # CONFIG_SND_USB_6FIRE is not set # CONFIG_SND_USB_HIFACE is not set # CONFIG_SND_BCD2000 is not set # CONFIG_SND_USB_POD is not set # CONFIG_SND_USB_PODHD is not set # CONFIG_SND_USB_TONEPORT is not set # CONFIG_SND_USB_VARIAX is not set CONFIG_SND_SOC=y CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y # CONFIG_SND_SOC_AMD_ACP is not set # CONFIG_SND_ATMEL_SOC is not set # CONFIG_SND_DESIGNWARE_I2S is not set # # SoC Audio for Freescale CPUs # # # Common SoC Audio options for Freescale CPUs: # # CONFIG_SND_SOC_FSL_ASRC is not set # CONFIG_SND_SOC_FSL_SAI is not set # CONFIG_SND_SOC_FSL_AUDMIX is not set # CONFIG_SND_SOC_FSL_SSI is not set # CONFIG_SND_SOC_FSL_SPDIF is not set # CONFIG_SND_SOC_FSL_ESAI is not set # CONFIG_SND_SOC_FSL_MICFIL is not set # CONFIG_SND_SOC_IMX_AUDMUX is not set # end of SoC Audio for Freescale CPUs # CONFIG_SND_I2S_HI6210_I2S is not set # CONFIG_SND_I2S_HI3660_I2S is not set # CONFIG_SND_SOC_IMG is not set # CONFIG_SND_SOC_MTK_BTCVSD is not set # CONFIG_SND_SOC_SOF_TOPLEVEL is not set # # STMicroelectronics STM32 SOC audio support # # end of STMicroelectronics STM32 SOC audio support CONFIG_SND_SUNXI_SOC=y CONFIG_SND_SUNXI_SOC_CPUDAI=y CONFIG_SND_SUN8IW20_CODEC=y # # Allwinner SoC Audio support # CONFIG_SND_SUNXI_SOC_SUN8IW20_CODEC=y CONFIG_SND_SUNXI_SOC_SIMPLE_CARD=y CONFIG_SND_SUNXI_SOC_DAUDIO=y # CONFIG_SND_SUNXI_SOC_DAUDIO_ASRC is not set # CONFIG_SND_SUNXI_SOC_SUNXI_HDMIAUDIO is not set CONFIG_SND_SUNXI_SOC_SPDIF=y # CONFIG_SND_SUNXI_SOC_SPDIF_RX_IEC61937 is not set CONFIG_SND_SUNXI_SOC_DMIC=y # CONFIG_SUNXI_AUDIO_DEBUG is not set # CONFIG_SUNXI_RX_SYNC is not set # end of Allwinner SoC Audio support # CONFIG_SND_SUNXI_RPAF is not set # # Allwinner SoC Audio support V2 # # CONFIG_SND_SOC_SUNXI_SPDIF is not set # CONFIG_SND_SOC_SUNXI_DMIC is not set # CONFIG_SND_SOC_SUNXI_DAUDIO is not set # CONFIG_SND_SOC_SUNXI_COMPONENTS is not set # end of Allwinner SoC Audio support V2 # CONFIG_SND_SOC_XILINX_I2S is not set # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set # CONFIG_SND_SOC_XILINX_SPDIF is not set # CONFIG_SND_SOC_XTFPGA_I2S is not set # CONFIG_ZX_TDM is not set CONFIG_SND_SOC_I2C_AND_SPI=y # # CODEC drivers # # CONFIG_SND_SOC_AC97_CODEC is not set # CONFIG_SND_SOC_ADAU1701 is not set # CONFIG_SND_SOC_ADAU1761_I2C is not set # CONFIG_SND_SOC_ADAU1761_SPI is not set # CONFIG_SND_SOC_ADAU7002 is not set # CONFIG_SND_SOC_AK4104 is not set # CONFIG_SND_SOC_AK4118 is not set # CONFIG_SND_SOC_AK4458 is not set # CONFIG_SND_SOC_AK4554 is not set # CONFIG_SND_SOC_AK4613 is not set # CONFIG_SND_SOC_AK4642 is not set # CONFIG_SND_SOC_AK5386 is not set # CONFIG_SND_SOC_AK5558 is not set # CONFIG_SND_SOC_ALC5623 is not set # CONFIG_SND_SOC_BD28623 is not set # CONFIG_SND_SOC_BT_SCO is not set # CONFIG_SND_SOC_CS35L32 is not set # CONFIG_SND_SOC_CS35L33 is not set # CONFIG_SND_SOC_CS35L34 is not set # CONFIG_SND_SOC_CS35L35 is not set # CONFIG_SND_SOC_CS35L36 is not set # CONFIG_SND_SOC_CS42L42 is not set # CONFIG_SND_SOC_CS42L51_I2C is not set # CONFIG_SND_SOC_CS42L52 is not set # CONFIG_SND_SOC_CS42L56 is not set # CONFIG_SND_SOC_CS42L73 is not set # CONFIG_SND_SOC_CS4265 is not set # CONFIG_SND_SOC_CS4270 is not set # CONFIG_SND_SOC_CS4271_I2C is not set # CONFIG_SND_SOC_CS4271_SPI is not set # CONFIG_SND_SOC_CS42XX8_I2C is not set # CONFIG_SND_SOC_CS43130 is not set # CONFIG_SND_SOC_CS4341 is not set # CONFIG_SND_SOC_CS4349 is not set # CONFIG_SND_SOC_CS53L30 is not set # CONFIG_SND_SOC_CX2072X is not set CONFIG_SND_SOC_DMIC=y # CONFIG_SND_SOC_ES7134 is not set # CONFIG_SND_SOC_ES7241 is not set # CONFIG_SND_SOC_ES8316 is not set # CONFIG_SND_SOC_ES8328_I2C is not set # CONFIG_SND_SOC_ES8328_SPI is not set # CONFIG_SND_SOC_GTM601 is not set # CONFIG_SND_SOC_INNO_RK3036 is not set # CONFIG_SND_SOC_MAX98088 is not set # CONFIG_SND_SOC_MAX98357A is not set # CONFIG_SND_SOC_MAX98504 is not set # CONFIG_SND_SOC_MAX9867 is not set # CONFIG_SND_SOC_MAX98927 is not set # CONFIG_SND_SOC_MAX98373 is not set # CONFIG_SND_SOC_MAX9860 is not set # CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set # CONFIG_SND_SOC_PCM1681 is not set # CONFIG_SND_SOC_PCM1789_I2C is not set # CONFIG_SND_SOC_PCM179X_I2C is not set # CONFIG_SND_SOC_PCM179X_SPI is not set # CONFIG_SND_SOC_PCM186X_I2C is not set # CONFIG_SND_SOC_PCM186X_SPI is not set # CONFIG_SND_SOC_PCM3060_I2C is not set # CONFIG_SND_SOC_PCM3060_SPI is not set # CONFIG_SND_SOC_PCM3168A_I2C is not set # CONFIG_SND_SOC_PCM3168A_SPI is not set # CONFIG_SND_SOC_PCM512x_I2C is not set # CONFIG_SND_SOC_PCM512x_SPI is not set # CONFIG_SND_SOC_RK3328 is not set # CONFIG_SND_SOC_RT5616 is not set # CONFIG_SND_SOC_RT5631 is not set # CONFIG_SND_SOC_SGTL5000 is not set # CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set # CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set # CONFIG_SND_SOC_SPDIF is not set # CONFIG_SND_SOC_SSM2305 is not set # CONFIG_SND_SOC_SSM2602_SPI is not set # CONFIG_SND_SOC_SSM2602_I2C is not set # CONFIG_SND_SOC_SSM4567 is not set # CONFIG_SND_SOC_STA32X is not set # CONFIG_SND_SOC_STA350 is not set # CONFIG_SND_SOC_STI_SAS is not set # CONFIG_SND_SOC_TAS2552 is not set # CONFIG_SND_SOC_TAS5086 is not set # CONFIG_SND_SOC_TAS571X is not set # CONFIG_SND_SOC_TAS5720 is not set # CONFIG_SND_SOC_TAS6424 is not set # CONFIG_SND_SOC_TDA7419 is not set # CONFIG_SND_SOC_TFA9879 is not set # CONFIG_SND_SOC_TLV320AIC23_I2C is not set # CONFIG_SND_SOC_TLV320AIC23_SPI is not set # CONFIG_SND_SOC_TLV320AIC31XX is not set # CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set # CONFIG_SND_SOC_TLV320AIC3X is not set # CONFIG_SND_SOC_TS3A227E is not set # CONFIG_SND_SOC_TSCS42XX is not set # CONFIG_SND_SOC_TSCS454 is not set # CONFIG_SND_SOC_UDA1334 is not set # CONFIG_SND_SOC_WM8510 is not set # CONFIG_SND_SOC_WM8523 is not set # CONFIG_SND_SOC_WM8524 is not set # CONFIG_SND_SOC_WM8580 is not set # CONFIG_SND_SOC_WM8711 is not set # CONFIG_SND_SOC_WM8728 is not set # CONFIG_SND_SOC_WM8731 is not set # CONFIG_SND_SOC_WM8737 is not set # CONFIG_SND_SOC_WM8741 is not set # CONFIG_SND_SOC_WM8750 is not set # CONFIG_SND_SOC_WM8753 is not set # CONFIG_SND_SOC_WM8770 is not set # CONFIG_SND_SOC_WM8776 is not set # CONFIG_SND_SOC_WM8782 is not set # CONFIG_SND_SOC_WM8804_I2C is not set # CONFIG_SND_SOC_WM8804_SPI is not set # CONFIG_SND_SOC_WM8903 is not set # CONFIG_SND_SOC_WM8904 is not set # CONFIG_SND_SOC_WM8960 is not set # CONFIG_SND_SOC_WM8962 is not set # CONFIG_SND_SOC_WM8974 is not set # CONFIG_SND_SOC_WM8978 is not set # CONFIG_SND_SOC_WM8985 is not set # CONFIG_SND_SOC_ZX_AUD96P22 is not set # CONFIG_SND_SOC_MAX9759 is not set # CONFIG_SND_SOC_MT6351 is not set # CONFIG_SND_SOC_MT6358 is not set # CONFIG_SND_SOC_NAU8540 is not set # CONFIG_SND_SOC_NAU8810 is not set # CONFIG_SND_SOC_NAU8822 is not set # CONFIG_SND_SOC_NAU8824 is not set # CONFIG_SND_SOC_TPA6130A2 is not set # CONFIG_SND_SOC_AC107 is not set # CONFIG_SND_SOC_AC108 is not set # CONFIG_SND_SOC_TD100 is not set # end of CODEC drivers CONFIG_SND_SIMPLE_CARD_UTILS=y # CONFIG_SND_SIMPLE_CARD is not set # CONFIG_SND_AUDIO_GRAPH_CARD is not set # # HID support # # CONFIG_HID is not set # # USB HID support # # CONFIG_USB_HID is not set # CONFIG_HID_PID is not set # # USB HID Boot Protocol drivers # # CONFIG_USB_KBD is not set # CONFIG_USB_MOUSE is not set # end of USB HID Boot Protocol drivers # end of USB HID support # # I2C HID support # # CONFIG_I2C_HID is not set # end of I2C HID support # end of HID support CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y # CONFIG_USB_LED_TRIG is not set # CONFIG_USB_ULPI_BUS is not set # CONFIG_USB_CONN_GPIO is not set CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=y # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set # # Miscellaneous USB options # CONFIG_USB_DEFAULT_PERSIST=y # CONFIG_USB_DYNAMIC_MINORS is not set # CONFIG_USB_OTG is not set # CONFIG_USB_OTG_WHITELIST is not set # CONFIG_USB_OTG_BLACKLIST_HUB is not set # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set CONFIG_USB_AUTOSUSPEND_DELAY=2 # CONFIG_USB_MON is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set # CONFIG_USB_XHCI_HCD is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_ROOT_HUB_TT=y CONFIG_USB_EHCI_TT_NEWSCHED=y # CONFIG_USB_EHCI_FSL is not set CONFIG_USB_EHCI_HCD_SUNXI=y # CONFIG_USB_EHCI_HCD_PLATFORM is not set # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_FOTG210_HCD is not set # CONFIG_USB_MAX3421_HCD is not set CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_HCD_SUNXI=y # CONFIG_USB_OHCI_HCD_PLATFORM is not set # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_HCD_TEST_MODE is not set CONFIG_USB_SUNXI_HCD=y CONFIG_USB_SUNXI_HCI=y CONFIG_USB_SUNXI_EHCI0=y CONFIG_USB_SUNXI_EHCI1=y CONFIG_USB_SUNXI_OHCI0=y CONFIG_USB_SUNXI_OHCI1=y # # USB Device Class drivers # # CONFIG_USB_ACM is not set # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=m # CONFIG_USB_STORAGE_DEBUG is not set # CONFIG_USB_STORAGE_REALTEK is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_STORAGE_ENE_UB6250 is not set # CONFIG_USB_UAS is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # CONFIG_USBIP_CORE is not set # CONFIG_USB_CDNS3 is not set # CONFIG_USB_MUSB_HDRC is not set # CONFIG_USB_DWC3 is not set # CONFIG_USB_DWC2 is not set # CONFIG_USB_CHIPIDEA is not set # CONFIG_USB_ISP1760 is not set # # USB port drivers # # CONFIG_USB_SERIAL is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_EHSET_TEST_FIXTURE is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_EZUSB_FX2 is not set # CONFIG_USB_HUB_USB251XB is not set # CONFIG_USB_HSIC_USB3503 is not set # CONFIG_USB_HSIC_USB4604 is not set # CONFIG_USB_LINK_LAYER_TEST is not set # # USB Physical Layer drivers # # CONFIG_NOP_USB_XCEIV is not set # CONFIG_USB_GPIO_VBUS is not set # CONFIG_USB_ISP1301 is not set # CONFIG_USB_ULPI is not set # end of USB Physical Layer drivers CONFIG_USB_GADGET=y # CONFIG_USB_GADGET_DEBUG is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2 # CONFIG_U_SERIAL_CONSOLE is not set # # USB Peripheral Controller # # CONFIG_USB_FUSB300 is not set # CONFIG_USB_FOTG210_UDC is not set # CONFIG_USB_GR_UDC is not set # CONFIG_USB_R8A66597 is not set # CONFIG_USB_PXA27X is not set # CONFIG_USB_MV_UDC is not set # CONFIG_USB_MV_U3D is not set # CONFIG_USB_SNP_UDC_PLAT is not set # CONFIG_USB_M66592 is not set # CONFIG_USB_BDC_UDC is not set # CONFIG_USB_NET2272 is not set CONFIG_USB_SUNXI_UDC0=y # CONFIG_USB_GADGET_XILINX is not set # CONFIG_USB_DUMMY_HCD is not set # end of USB Peripheral Controller CONFIG_USB_LIBCOMPOSITE=y CONFIG_USB_U_SERIAL=y CONFIG_USB_F_SERIAL=y CONFIG_USB_F_FS=y CONFIG_USB_CONFIGFS=y CONFIG_USB_CONFIGFS_UEVENT=y CONFIG_USB_CONFIGFS_SERIAL=y # CONFIG_USB_CONFIGFS_ACM is not set # CONFIG_USB_CONFIGFS_OBEX is not set # CONFIG_USB_CONFIGFS_NCM is not set # CONFIG_USB_CONFIGFS_ECM is not set # CONFIG_USB_CONFIGFS_ECM_SUBSET is not set # CONFIG_USB_CONFIGFS_RNDIS is not set # CONFIG_USB_CONFIGFS_EEM is not set # CONFIG_USB_CONFIGFS_MASS_STORAGE is not set # CONFIG_USB_CONFIGFS_F_LB_SS is not set CONFIG_USB_CONFIGFS_F_FS=y # CONFIG_USB_CONFIGFS_F_AUDIO_SRC is not set # CONFIG_USB_CONFIGFS_F_UAC1 is not set # CONFIG_USB_CONFIGFS_F_UAC1_LEGACY is not set # CONFIG_USB_CONFIGFS_F_UAC2 is not set # CONFIG_USB_CONFIGFS_F_MIDI is not set # CONFIG_USB_CONFIGFS_F_HID is not set # CONFIG_USB_CONFIGFS_F_UVC is not set # CONFIG_USB_CONFIGFS_F_PRINTER is not set CONFIG_USB_SUNXI_USB=y CONFIG_USB_SUNXI_USB_MANAGER=y # CONFIG_USB_SUNXI_USB_DEBUG is not set CONFIG_USB_SUNXI_USB_ADB=y CONFIG_TYPEC=y # CONFIG_TYPEC_TCPM is not set # CONFIG_TYPEC_UCSI is not set # CONFIG_TYPEC_TPS6598X is not set # # USB Type-C Multiplexer/DeMultiplexer Switch support # # CONFIG_TYPEC_MUX_PI3USB30532 is not set # end of USB Type-C Multiplexer/DeMultiplexer Switch support # # USB Type-C Alternate Mode drivers # # CONFIG_TYPEC_DP_ALTMODE is not set # end of USB Type-C Alternate Mode drivers CONFIG_USB_ROLE_SWITCH=y CONFIG_MMC=y CONFIG_PWRSEQ_EMMC=y CONFIG_PWRSEQ_SIMPLE=y CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=8 # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_DEBUG is not set # CONFIG_MMC_SDHCI is not set # CONFIG_MMC_SPI is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MMC_USDHI6ROL0 is not set CONFIG_MMC_SUNXI=y CONFIG_MMC_SUNXI_V4P1X=y CONFIG_MMC_SUNXI_V4P00X=y CONFIG_MMC_SUNXI_V4P10X=y CONFIG_MMC_SUNXI_V4P5X=y CONFIG_MMC_SUNXI_V5P3X=y # CONFIG_MMC_CQHCI is not set # CONFIG_MMC_HSQ is not set # CONFIG_MMC_MTK is not set # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y # CONFIG_LEDS_CLASS_FLASH is not set # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set # # LED drivers # # CONFIG_LEDS_AN30259A is not set # CONFIG_LEDS_BCM6328 is not set # CONFIG_LEDS_BCM6358 is not set # CONFIG_LEDS_CR0014114 is not set # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_LM3532 is not set # CONFIG_LEDS_LM3642 is not set # CONFIG_LEDS_LM3692X is not set # CONFIG_LEDS_PCA9532 is not set # CONFIG_LEDS_GPIO is not set # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP3952 is not set # CONFIG_LEDS_LP5521 is not set # CONFIG_LEDS_LP5523 is not set # CONFIG_LEDS_LP5562 is not set # CONFIG_LEDS_LP8501 is not set # CONFIG_LEDS_LP8860 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_PCA963X is not set # CONFIG_LEDS_DAC124S085 is not set # CONFIG_LEDS_PWM is not set # CONFIG_LEDS_REGULATOR is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_TCA6507 is not set # CONFIG_LEDS_TLC591XX is not set # CONFIG_LEDS_LM355x is not set # CONFIG_LEDS_IS31FL319X is not set # CONFIG_LEDS_IS31FL32XX is not set # # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM) # # CONFIG_LEDS_BLINKM is not set # CONFIG_LEDS_SYSCON is not set # CONFIG_LEDS_MLXREG is not set # CONFIG_LEDS_USER is not set # CONFIG_LEDS_SPI_BYTE is not set # CONFIG_LEDS_TI_LMU_COMMON is not set CONFIG_LEDS_SUNXI=y # CONFIG_MATRIX_LEDS_SUNXI is not set # # LED Triggers # CONFIG_LEDS_TRIGGERS=y CONFIG_LEDS_TRIGGER_TIMER=y # CONFIG_LEDS_TRIGGER_ONESHOT is not set # CONFIG_LEDS_TRIGGER_MTD is not set # CONFIG_LEDS_TRIGGER_HEARTBEAT is not set # CONFIG_LEDS_TRIGGER_BACKLIGHT is not set # CONFIG_LEDS_TRIGGER_CPU is not set # CONFIG_LEDS_TRIGGER_ACTIVITY is not set # CONFIG_LEDS_TRIGGER_GPIO is not set CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # # CONFIG_LEDS_TRIGGER_TRANSIENT is not set # CONFIG_LEDS_TRIGGER_CAMERA is not set # CONFIG_LEDS_TRIGGER_PANIC is not set CONFIG_LEDS_TRIGGER_NETDEV=y # CONFIG_LEDS_TRIGGER_PATTERN is not set # CONFIG_LEDS_TRIGGER_AUDIO is not set # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_EDAC_ATOMIC_SCRUB=y CONFIG_EDAC_SUPPORT=y CONFIG_RTC_LIB=y # CONFIG_RTC_CLASS is not set CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y # CONFIG_ALTERA_MSGDMA is not set CONFIG_DMA_SUN6I=y # CONFIG_DW_AXI_DMAC is not set # CONFIG_FSL_EDMA is not set # CONFIG_FSL_QDMA is not set # CONFIG_INTEL_IDMA64 is not set # CONFIG_NBPFAXI_DMA is not set # CONFIG_QCOM_HIDMA_MGMT is not set # CONFIG_QCOM_HIDMA is not set # CONFIG_DW_DMAC is not set # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set # CONFIG_DMATEST is not set # # DMABUF options # CONFIG_SYNC_FILE=y CONFIG_SW_SYNC=y CONFIG_UDMABUF=y CONFIG_DMABUF_SELFTESTS=y # end of DMABUF options # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set # CONFIG_VFIO is not set # CONFIG_VIRT_DRIVERS is not set # CONFIG_VIRTIO_MENU is not set # # Microsoft Hyper-V guest support # # end of Microsoft Hyper-V guest support # CONFIG_GREYBUS is not set CONFIG_STAGING=y # CONFIG_PRISM2_USB is not set # CONFIG_COMEDI is not set # CONFIG_RTLLIB is not set # CONFIG_RTL8723BS is not set # CONFIG_R8712U is not set # CONFIG_R8188EU is not set # # Speakup console speech # # end of Speakup console speech # CONFIG_STAGING_MEDIA is not set # # Android # # CONFIG_ASHMEM is not set # CONFIG_ANDROID_TIMED_OUTPUT is not set CONFIG_ION=y CONFIG_ION_SYSTEM_HEAP=y CONFIG_ION_CMA_HEAP=y # end of Android # CONFIG_STAGING_BOARD is not set # CONFIG_LTE_GDM724X is not set # CONFIG_GS_FPGABOOT is not set # CONFIG_UNISYSSPAR is not set # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set # CONFIG_FB_TFT is not set # CONFIG_WILC1000_SDIO is not set # CONFIG_WILC1000_SPI is not set # CONFIG_MOST is not set # CONFIG_KS7010 is not set # CONFIG_PI433 is not set # # Gasket devices # # end of Gasket devices # CONFIG_XIL_AXIS_FIFO is not set # CONFIG_FIELDBUS_DEV is not set # CONFIG_USB_WUSB_CBAF is not set # CONFIG_UWB is not set CONFIG_EXFAT_FS=y CONFIG_EXFAT_DONT_MOUNT_VFAT=y CONFIG_EXFAT_DISCARD=y CONFIG_EXFAT_DELAYED_SYNC=y CONFIG_EXFAT_KERNEL_DEBUG=y CONFIG_EXFAT_DEBUG_MSG=y CONFIG_EXFAT_DEFAULT_CODEPAGE=437 CONFIG_EXFAT_DEFAULT_IOCHARSET="utf8" # CONFIG_GOLDFISH is not set # CONFIG_MFD_CROS_EC is not set # CONFIG_CHROME_PLATFORMS is not set # CONFIG_MELLANOX_PLATFORM is not set CONFIG_CLKDEV_LOOKUP=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Common Clock Framework # # CONFIG_COMMON_CLK_DEBUG is not set # CONFIG_CLK_HSDK is not set # CONFIG_COMMON_CLK_MAX9485 is not set # CONFIG_COMMON_CLK_SI5341 is not set # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_COMMON_CLK_SI514 is not set # CONFIG_COMMON_CLK_SI544 is not set # CONFIG_COMMON_CLK_SI570 is not set # CONFIG_COMMON_CLK_CDCE706 is not set # CONFIG_COMMON_CLK_CDCE925 is not set # CONFIG_COMMON_CLK_CS2000_CP is not set # CONFIG_CLK_QORIQ is not set # CONFIG_COMMON_CLK_PWM is not set # CONFIG_COMMON_CLK_VC5 is not set # CONFIG_COMMON_CLK_FIXED_MMIO is not set CONFIG_CLK_SUNXI=y # CONFIG_CLK_SUNXI_CLOCKS is not set # CONFIG_CLK_SUNXI_DDR is not set # CONFIG_CLK_SUNXI_PRCM_SUN6I is not set # CONFIG_CLK_SUNXI_PRCM_SUN8I is not set # CONFIG_CLK_SUNXI_PRCM_SUN9I is not set CONFIG_SUNXI_CCU=y CONFIG_SUN8IW20_CCU=y CONFIG_SUN8IW20_R_CCU=y # CONFIG_SUN8I_A83T_CCU is not set # CONFIG_SUN8I_DE2_CCU is not set # CONFIG_SUN8I_R_CCU is not set CONFIG_SUNXI_RTC_CCU=y # end of Common Clock Framework # CONFIG_HWSPINLOCK is not set # CONFIG_HWSPINLOCK_SUNXI is not set # # Clock Source drivers # CONFIG_TIMER_OF=y CONFIG_TIMER_PROBE=y CONFIG_CLKSRC_MMIO=y CONFIG_SUN4I_TIMER=y # CONFIG_SUN50I_TIMER is not set # CONFIG_SUNXI_TIMER is not set # CONFIG_SUNXI_TIMER_TEST is not set CONFIG_ARM_ARCH_TIMER=y # CONFIG_ARM_ARCH_TIMER_EVTSTREAM is not set # CONFIG_MTK_TIMER is not set # end of Clock Source drivers # CONFIG_MAILBOX is not set CONFIG_IOMMU_IOVA=y CONFIG_IOMMU_API=y # CONFIG_IOMMU_LIMIT_IOVA_ALIGNMENT is not set CONFIG_IOMMU_SUPPORT=y # # Generic IOMMU Pagetable Support # # CONFIG_IOMMU_IO_PGTABLE_LPAE is not set # CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set # end of Generic IOMMU Pagetable Support # CONFIG_IOMMU_DEBUGFS is not set # CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set CONFIG_OF_IOMMU=y CONFIG_IOMMU_DMA=y # CONFIG_ARM_SMMU is not set CONFIG_SUNXI_IOMMU=y CONFIG_SUNXI_IOMMU_DEBUG=y CONFIG_SUNXI_IOMMU_TESTS=y # # Remoteproc drivers # # CONFIG_REMOTEPROC is not set # end of Remoteproc drivers # # Rpmsg drivers # # CONFIG_RPMSG_SUNXI_AMP is not set # CONFIG_RPMSG_DSP_STANDBY is not set # CONFIG_RPMSG_VIRTIO is not set # CONFIG_RPMSG_SUNXI_TTY is not set # CONFIG_RPMSG_SUNXI_CLIENT_SAMPLE is not set # end of Rpmsg drivers # # Rpbuf drivers # # CONFIG_RPBUF_DEV is not set # # Service # # CONFIG_RPBUF_SERVICE_RPMSG is not set # # Controller # # CONFIG_RPBUF_CONTROLLER_SUNXI is not set # # Sample # # CONFIG_RPBUF_SAMPLE_SUNXI is not set # end of Rpbuf drivers # CONFIG_SOUNDWIRE is not set # # SOC (System On Chip) specific Drivers # # # Amlogic SoC drivers # # end of Amlogic SoC drivers # # Aspeed SoC drivers # # end of Aspeed SoC drivers # # Broadcom SoC drivers # # CONFIG_SOC_BRCMSTB is not set # end of Broadcom SoC drivers # # NXP/Freescale QorIQ SoC drivers # # end of NXP/Freescale QorIQ SoC drivers # # i.MX SoC drivers # # end of i.MX SoC drivers # # Qualcomm SoC drivers # # end of Qualcomm SoC drivers # CONFIG_SUNXI_SRAM is not set CONFIG_SUNXI_PM_DOMAINS=y # CONFIG_SUNXI_POWER_DOMAIN_TEST is not set CONFIG_SUNXI_SID=y # CONFIG_SUNXI_RISCV_SUSPEND is not set # CONFIG_PM_TRACE_NVMEM is not set # CONFIG_SOC_TI is not set # # Xilinx SoC drivers # # CONFIG_XILINX_VCU is not set # end of Xilinx SoC drivers # end of SOC (System On Chip) specific Drivers # CONFIG_PM_DEVFREQ is not set # CONFIG_EXTCON is not set # CONFIG_MEMORY is not set # CONFIG_IIO is not set CONFIG_PWM=y CONFIG_PWM_SYSFS=y # CONFIG_PWM_FSL_FTM is not set # CONFIG_PWM_PCA9685 is not set # CONFIG_PWM_SUN4I is not set CONFIG_PWM_SUNXI_GROUP=y # CONFIG_DSP_DEBUG is not set # # IRQ chip support # CONFIG_IRQCHIP=y CONFIG_ARM_GIC=y CONFIG_ARM_GIC_MAX_NR=1 # CONFIG_AL_FIC is not set # CONFIG_SUNXI_WAKEUPGEN is not set # CONFIG_SUN8I_NMI is not set # end of IRQ chip support # CONFIG_IPACK_BUS is not set CONFIG_ARCH_HAS_RESET_CONTROLLER=y CONFIG_RESET_CONTROLLER=y CONFIG_RESET_SIMPLE=y CONFIG_RESET_SUNXI=y # CONFIG_RESET_TI_SYSCON is not set # # PHY Subsystem # # CONFIG_GENERIC_PHY is not set # CONFIG_PHY_SUN6I_MIPI_DPHY is not set # CONFIG_PHY_SUN9I_USB is not set # CONFIG_BCM_KONA_USB2_PHY is not set # CONFIG_PHY_CADENCE_DP is not set # CONFIG_PHY_CADENCE_DPHY is not set # CONFIG_PHY_CADENCE_SIERRA is not set # CONFIG_PHY_FSL_IMX8MQ_USB is not set # CONFIG_PHY_MIXEL_MIPI_DPHY is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set # CONFIG_PHY_MAPPHONE_MDM6600 is not set # CONFIG_PHY_OCELOT_SERDES is not set # end of PHY Subsystem # CONFIG_POWERCAP is not set # CONFIG_MCB is not set # # Performance monitor support # # CONFIG_ARM_CCI_PMU is not set # CONFIG_ARM_CCN is not set # CONFIG_ARM_PMU is not set # end of Performance monitor support # CONFIG_RAS is not set # # Android # CONFIG_ANDROID=y # CONFIG_ANDROID_BINDER_IPC is not set # end of Android # CONFIG_DAX is not set CONFIG_NVMEM=y CONFIG_NVMEM_SYSFS=y # CONFIG_NVMEM_SUNXI_SID is not set # # HW tracing support # # CONFIG_STM is not set # CONFIG_INTEL_TH is not set # end of HW tracing support # CONFIG_FPGA is not set # CONFIG_FSI is not set # CONFIG_TEE is not set CONFIG_PM_OPP=y # CONFIG_SIOX is not set # CONFIG_SLIMBUS is not set # CONFIG_INTERCONNECT is not set # CONFIG_COUNTER is not set # end of Device Drivers # # File systems # CONFIG_DCACHE_WORD_ACCESS=y # CONFIG_VALIDATE_FS_PARSER is not set # CONFIG_EXT2_FS is not set # CONFIG_EXT3_FS is not set # CONFIG_EXT4_FS is not set # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set # CONFIG_F2FS_FS is not set CONFIG_FS_POSIX_ACL=y CONFIG_EXPORTFS=y # CONFIG_EXPORTFS_BLOCK_OPS is not set CONFIG_FILE_LOCKING=y CONFIG_MANDATORY_FILE_LOCKING=y # CONFIG_FS_ENCRYPTION is not set # CONFIG_FS_VERITY is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set # CONFIG_AUTOFS4_FS is not set # CONFIG_AUTOFS_FS is not set # CONFIG_FUSE_FS is not set CONFIG_OVERLAY_FS=y # CONFIG_OVERLAY_FS_REDIRECT_DIR is not set CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y # CONFIG_OVERLAY_FS_INDEX is not set # CONFIG_OVERLAY_FS_XINO_AUTO is not set # CONFIG_OVERLAY_FS_METACOPY is not set # CONFIG_INCREMENTAL_FS is not set # # Caches # # CONFIG_FSCACHE is not set # end of Caches # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # end of CD-ROM/DVD Filesystems # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y # CONFIG_MSDOS_FS is not set CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" CONFIG_FAT_DEFAULT_UTF8=y CONFIG_NTFS_FS=y # CONFIG_NTFS_DEBUG is not set CONFIG_NTFS_RW=y # end of DOS/FAT/NT Filesystems # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y # CONFIG_PROC_PAGE_MONITOR is not set # CONFIG_PROC_CHILDREN is not set CONFIG_KERNFS=y CONFIG_SYSFS=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_TMPFS_XATTR=y CONFIG_MEMFD_CREATE=y CONFIG_CONFIGFS_FS=y # end of Pseudo filesystems CONFIG_MISC_FILESYSTEMS=y # CONFIG_ORANGEFS_FS is not set # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set # CONFIG_JFFS2_FS is not set CONFIG_UBIFS_FS=y CONFIG_UBIFS_FS_ADVANCED_COMPR=y # CONFIG_UBIFS_FS_LZO is not set # CONFIG_UBIFS_FS_ZLIB is not set # CONFIG_UBIFS_FS_ZSTD is not set # CONFIG_UBIFS_ATIME_SUPPORT is not set CONFIG_UBIFS_FS_XATTR=y CONFIG_UBIFS_FS_SECURITY=y # CONFIG_UBIFS_FS_AUTHENTICATION is not set # CONFIG_CRAMFS is not set CONFIG_SQUASHFS=y # CONFIG_SQUASHFS_FILE_CACHE is not set CONFIG_SQUASHFS_FILE_DIRECT=y # CONFIG_SQUASHFS_DECOMP_SINGLE is not set # CONFIG_SQUASHFS_DECOMP_MULTI is not set CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU=y # CONFIG_SQUASHFS_XATTR is not set CONFIG_SQUASHFS_ZLIB=y # CONFIG_SQUASHFS_LZ4 is not set # CONFIG_SQUASHFS_LZO is not set # CONFIG_SQUASHFS_XZ is not set # CONFIG_SQUASHFS_ZSTD is not set # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set # CONFIG_SQUASHFS_EMBEDDED is not set CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3 # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set # CONFIG_PSTORE is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # CONFIG_EROFS_FS is not set # CONFIG_NETWORK_FILESYSTEMS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set # CONFIG_NLS_UTF8 is not set # CONFIG_DLM is not set # CONFIG_UNICODE is not set # end of File systems # # Security options # CONFIG_KEYS=y # CONFIG_KEYS_REQUEST_CACHE is not set # CONFIG_PERSISTENT_KEYRINGS is not set # CONFIG_BIG_KEYS is not set # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEY_DH_OPERATIONS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set # CONFIG_SECURITY is not set # CONFIG_SECURITYFS is not set CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y # CONFIG_HARDENED_USERCOPY is not set # CONFIG_FORTIFY_SOURCE is not set # CONFIG_STATIC_USERMODEHELPER is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity" # # Kernel hardening options # # # Memory initialization # CONFIG_INIT_STACK_NONE=y # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set # end of Memory initialization # end of Kernel hardening options # end of Security options CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=y CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_BLKCIPHER=y CONFIG_CRYPTO_BLKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=y CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_RNG_DEFAULT=y CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_AKCIPHER=y CONFIG_CRYPTO_KPP2=y CONFIG_CRYPTO_KPP=y CONFIG_CRYPTO_ACOMP2=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y # CONFIG_CRYPTO_USER is not set CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y CONFIG_CRYPTO_NULL=y CONFIG_CRYPTO_NULL2=y # CONFIG_CRYPTO_PCRYPT is not set # CONFIG_CRYPTO_CRYPTD is not set # CONFIG_CRYPTO_AUTHENC is not set # CONFIG_CRYPTO_TEST is not set # # Public-key cryptography # CONFIG_CRYPTO_RSA=y # CONFIG_CRYPTO_DH is not set CONFIG_CRYPTO_ECC=y CONFIG_CRYPTO_ECDH=y # CONFIG_CRYPTO_ECRDSA is not set # # Authenticated Encryption with Associated Data # CONFIG_CRYPTO_CCM=y # CONFIG_CRYPTO_GCM is not set # CONFIG_CRYPTO_CHACHA20POLY1305 is not set # CONFIG_CRYPTO_AEGIS128 is not set CONFIG_CRYPTO_SEQIV=y # CONFIG_CRYPTO_ECHAINIV is not set # # Block modes # # CONFIG_CRYPTO_CBC is not set # CONFIG_CRYPTO_CFB is not set CONFIG_CRYPTO_CTR=y # CONFIG_CRYPTO_CTS is not set CONFIG_CRYPTO_ECB=y # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_OFB is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # CONFIG_CRYPTO_KEYWRAP is not set # CONFIG_CRYPTO_ADIANTUM is not set # CONFIG_CRYPTO_ESSIV is not set # # Hash modes # CONFIG_CRYPTO_CMAC=y CONFIG_CRYPTO_HMAC=y # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_VMAC is not set # # Digest # CONFIG_CRYPTO_CRC32C=y # CONFIG_CRYPTO_CRC32 is not set # CONFIG_CRYPTO_XXHASH is not set # CONFIG_CRYPTO_CRCT10DIF is not set # CONFIG_CRYPTO_GHASH is not set # CONFIG_CRYPTO_POLY1305 is not set # CONFIG_CRYPTO_MD4 is not set # CONFIG_CRYPTO_MD5 is not set # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set # CONFIG_CRYPTO_SHA1 is not set CONFIG_CRYPTO_LIB_SHA256=y CONFIG_CRYPTO_SHA256=y # CONFIG_CRYPTO_SHA512 is not set # CONFIG_CRYPTO_SHA3 is not set # CONFIG_CRYPTO_SM3 is not set # CONFIG_CRYPTO_STREEBOG is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # CONFIG_CRYPTO_LIB_AES=y CONFIG_CRYPTO_AES=y # CONFIG_CRYPTO_AES_TI is not set # CONFIG_CRYPTO_ANUBIS is not set CONFIG_CRYPTO_LIB_ARC4=y CONFIG_CRYPTO_ARC4=y # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set # CONFIG_CRYPTO_DES is not set # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SALSA20 is not set # CONFIG_CRYPTO_CHACHA20 is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_SM4 is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # CONFIG_CRYPTO_DEFLATE=y CONFIG_CRYPTO_LZO=y # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set # CONFIG_CRYPTO_ZSTD is not set # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set CONFIG_CRYPTO_DRBG_MENU=y CONFIG_CRYPTO_DRBG_HMAC=y # CONFIG_CRYPTO_DRBG_HASH is not set # CONFIG_CRYPTO_DRBG_CTR is not set CONFIG_CRYPTO_DRBG=y CONFIG_CRYPTO_JITTERENTROPY=y # CONFIG_CRYPTO_USER_API_HASH is not set # CONFIG_CRYPTO_USER_API_SKCIPHER is not set # CONFIG_CRYPTO_USER_API_RNG is not set # CONFIG_CRYPTO_USER_API_AEAD is not set CONFIG_CRYPTO_HASH_INFO=y CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set # CONFIG_CRYPTO_DEV_SAFEXCEL is not set # CONFIG_CRYPTO_DEV_CCREE is not set # # Support for Allwinner Sunxi CryptoEngine # # # Choose one according to the actual usage # # CONFIG_CRYPTO_DEV_SUNXI is not set # CONFIG_CRYPTO_DEV_SUNXI_IOCTL is not set # end of Support for Allwinner Sunxi CryptoEngine # CONFIG_ASYMMETRIC_KEY_TYPE is not set # # Certificates for signature checking # # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set # end of Certificates for signature checking # # Library routines # # CONFIG_PACKING is not set CONFIG_BITREVERSE=y CONFIG_HAVE_ARCH_BITREVERSE=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y # CONFIG_CORDIC is not set CONFIG_RATIONAL=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y # CONFIG_CRC_CCITT is not set CONFIG_CRC16=y # CONFIG_CRC_T10DIF is not set # CONFIG_CRC_ITU_T is not set CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set # CONFIG_CRC32_SLICEBY8 is not set # CONFIG_CRC32_SLICEBY4 is not set CONFIG_CRC32_SARWATE=y # CONFIG_CRC32_BIT is not set # CONFIG_CRC64 is not set # CONFIG_CRC4 is not set # CONFIG_CRC7 is not set # CONFIG_LIBCRC32C is not set # CONFIG_CRC8 is not set # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y # CONFIG_XZ_DEC is not set CONFIG_GENERIC_ALLOCATOR=y CONFIG_ASSOCIATIVE_ARRAY=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT_MAP=y CONFIG_HAS_DMA=y CONFIG_NEED_SG_DMA_LENGTH=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_DMA_DECLARE_COHERENT=y CONFIG_ARCH_HAS_SETUP_DMA_OPS=y CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y CONFIG_DMA_REMAP=y CONFIG_DMA_CMA=y # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=16 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=8 # CONFIG_DMA_API_DEBUG is not set CONFIG_SGL_ALLOC=y CONFIG_CPU_RMAP=y CONFIG_DQL=y CONFIG_NLATTR=y CONFIG_CLZ_TAB=y # CONFIG_IRQ_POLL is not set CONFIG_MPILIB=y CONFIG_LIBFDT=y CONFIG_GENERIC_GETTIMEOFDAY=y CONFIG_SG_POOL=y CONFIG_SBITMAP=y # CONFIG_STRING_SELFTEST is not set # end of Library routines # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y # CONFIG_PRINTK_CALLER is not set CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_CONSOLE_LOGLEVEL_QUIET=4 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # CONFIG_DYNAMIC_DEBUG_CORE is not set # end of printk and dmesg options # # Compile-time checks and compiler options # # CONFIG_DEBUG_INFO is not set CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=2048 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set CONFIG_DEBUG_FS=y # CONFIG_HEADERS_INSTALL is not set CONFIG_OPTIMIZE_INLINING=y # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_SECTION_MISMATCH_WARN_ONLY=y # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # end of Compile-time checks and compiler options # CONFIG_MAGIC_SYSRQ is not set CONFIG_DEBUG_KERNEL=y CONFIG_DEBUG_MISC=y # # Memory Debugging # # CONFIG_PAGE_EXTENSION is not set # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_PAGE_OWNER is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_RODATA_TEST is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SLUB_STATS is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_DEBUG_VM is not set CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y # CONFIG_DEBUG_VIRTUAL is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_PER_CPU_MAPS is not set CONFIG_CC_HAS_KASAN_GENERIC=y CONFIG_KASAN_STACK=1 # end of Memory Debugging CONFIG_ARCH_HAS_KCOV=y CONFIG_CC_HAS_SANCOV_TRACE_PC=y # CONFIG_KCOV is not set # CONFIG_DEBUG_SHIRQ is not set # # Debug Lockups and Hangs # # CONFIG_SOFTLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_WQ_WATCHDOG is not set # end of Debug Lockups and Hangs # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 # CONFIG_SCHED_DEBUG is not set # CONFIG_SCHEDSTATS is not set # CONFIG_SCHED_STACK_END_CHECK is not set # CONFIG_DEBUG_TIMEKEEPING is not set # CONFIG_DEBUG_PREEMPT is not set # # Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_LOCK_DEBUGGING_SUPPORT=y # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_DEBUG_SPINLOCK is not set CONFIG_DEBUG_MUTEXES=y # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_RWSEMS is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_WW_MUTEX_SELFTEST is not set # end of Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_STACKTRACE is not set # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set # CONFIG_DEBUG_KOBJECT is not set # CONFIG_DEBUG_BUGVERBOSE is not set # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PLIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_RCU_PERF_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=20 # CONFIG_RCU_TRACE is not set # CONFIG_RCU_EQS_DEBUG is not set # end of RCU Debugging # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set # CONFIG_LATENCYTOP is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set # CONFIG_RUNTIME_TESTING_MENU is not set # CONFIG_MEMTEST is not set # CONFIG_BUG_ON_DATA_CORRUPTION is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_UBSAN is not set CONFIG_UBSAN_ALIGNMENT=y CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y # CONFIG_ARM_PTDUMP_DEBUGFS is not set # CONFIG_DEBUG_WX is not set # CONFIG_UNWINDER_FRAME_POINTER is not set CONFIG_UNWINDER_ARM=y CONFIG_ARM_UNWIND=y # CONFIG_DEBUG_USER is not set CONFIG_DEBUG_LL=y # CONFIG_DEBUG_SUNXI_UART0 is not set # CONFIG_DEBUG_SUNXI_UART1 is not set # CONFIG_DEBUG_SUNXI_UART2 is not set # CONFIG_DEBUG_ICEDCC is not set # CONFIG_DEBUG_SEMIHOSTING is not set CONFIG_DEBUG_LL_UART_8250=y # CONFIG_DEBUG_LL_UART_PL01X is not set CONFIG_DEBUG_LL_INCLUDE="debug/8250.S" CONFIG_DEBUG_UART_PHYS=0x02500C00 CONFIG_DEBUG_UART_VIRT=0xf2500C00 CONFIG_DEBUG_UART_8250_SHIFT=2 # CONFIG_DEBUG_UART_8250_WORD is not set # CONFIG_DEBUG_UART_8250_PALMCHIP is not set # CONFIG_DEBUG_UART_8250_FLOW_CONTROL is not set # CONFIG_DEBUG_UNCOMPRESS is not set CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h" CONFIG_EARLY_PRINTK=y # CONFIG_PID_IN_CONTEXTIDR is not set # CONFIG_SUNXI_DUMP is not set # CONFIG_CORESIGHT is not set # end of Kernel hacking
加载顺序:
insmod videobuf2-memops.ko
insmod videobuf2-dma-contig.ko
insmod videobuf2-vmalloc.ko
insmod vin_io.ko
insmod ov5640.ko
insmod vin_v4l2.ko错误日志(能识别到ov5640):
请问您解决了吗?我也是差不多这个问题
我也遇到这个问题,
D1-H (MQ-Pro)驱动 OV5640 摄像头
https://bbs.aw-ol.com/topic/4017/share/1 -
请问大伙解决该问题了吗?
@shz18877605430 报错是使用呢CSI 不是MIPI-CSIS
