就是一直在boot0这里循环,我看boot0初始化也没有错误,就是不加载uboot,有大佬知道怎么解决吗
C
c18842780426 发布的最新帖子
T113s4的boot0启动异常发布在 T Series
[28]HELLO! lidf===BOOT0 is starting! [32]BOOT0 commit : 41ad3d9-dirty [35]set pll start [41]periph0 has been enabled [44]set pll end [45][pmu]: bus read error [48]board init ok [50]enable_jtag [51]ZQ value = 0x2f [53]get_pmu_exist() = -1 [55]DRAM BOOT DRIVE INFO: V0.34 [58]DRAM CLK = 792 MHz [61]DRAM Type = 3 (2:DDR2,3:DDR3) [64]DRAMC read ODT off. [66]DRAM ODT value: 0x42. [69]ddr_efuse_type: 0xa [72]DRAM SIZE = 256 MB [79]DRAM simple test OK. [81]rtc standby flag is 0x0, super standby flag is 0x0 [86]dram size =256 [89]card no is 2 [90]sdcard 2 line count 4 [93][mmc]: mmc driver ver 2021-05-21 14:47 [102][mmc]: Wrong media type 0x0, but host sdc2, try mmc first [108][mmc]: ***Try MMC card 2*** [131][mmc]: RMCA OK! [133][mmc]: mmc 2 bias 0 [136][mmc]: MMC 5.1 [138][mmc]: HSSDR52/SDR25 4 bit [141][mmc]: 50000000 Hz [143][mmc]: 7396 MB [145][mmc]: ***SD/MMC 2 init OK!!!*** [28]HELLO! lidf===BOOT0 is starting! [32]BOOT0 commit : 41ad3d9-dirty [35]set pll start [41]periph0 has been enabled [44]set pll end [45][pmu]: bus read error [48]board init ok [50]enable_jtag [51]ZQ value = 0x2f [53]get_pmu_exist() = -1 [55]DRAM BOOT DRIVE INFO: V0.34 [58]DRAM CLK = 792 MHz [61]DRAM Type = 3 (2:DDR2,3:DDR3) [64]DRAMC read ODT off. [66]DRAM ODT value: 0x42. [69]ddr_efuse_type: 0xa [72]DRAM SIZE = 256 MB [79]DRAM simple test OK. [81]rtc standby flag is 0x0, super standby flag is 0x0 [86]dram size =256 [89]card no is 2 [90]sdcard 2 line count 4 [93][mmc]: mmc driver ver 2021-05-21 14:47 [102][mmc]: Wrong media type 0x0, but host sdc2, try mmc first [108][mmc]: ***Try MMC card 2*** [131][mmc]: RMCA OK! [132][mmc]: mmc 2 bias 0 [136][mmc]: MMC 5.1 [138][mmc]: HSSDR52/SDR25 4 bit [141][mmc]: 50000000 Hz [143][mmc]: 7396 MB [145][mmc]: ***SD/MMC 2 init OK!!!****
