T113 nand flash 启动失败
[1053]fes begin commit:adaf1174cc [1056]set pll start [1058]fix vccio detect value:0xc0 [1065]periph0 has been enabled [1068]set pll end [1070][pmu]: bus read error [1072]board init ok [1074]beign to init dram [1077]ZQ value = 0x2d [1079]get_pmu_exist() = -1 [1081]ddr_efuse_type: 0xa [1084]trefi:7.8ms [1086][AUTO DEBUG] single rank and full DQ! [1090]ddr_efuse_type: 0xa [1093]trefi:7.8ms [1095][AUTO DEBUG] rank 0 row = 13 [1099][AUTO DEBUG] rank 0 bank = 8 [1102][AUTO DEBUG] rank 0 page size = 2 KB [1106]DRAM BOOT DRIVE INFO: V0.33 [1109]DRAM CLK = 936 MHz [1111]DRAM Type = 3 (2:DDR2,3:DDR3) [1115]DRAMC read ODT off. [1117]DRAM ODT value: 0x42. [1120]ddr_efuse_type: 0xa [1123]DRAM SIZE =128 M [1125]dram_tpr4:0x0 [1127]PLL_DDR_CTRL_REG:0xf8004d00 [1130]DRAM_CLK_REG:0xc0000000 [1133][TIMING DEBUG] MR2= 0x20 [1137]DRAM simple test OK. [1139]rtc standby flag is 0x0, super standby flag is 0x0 [1145]init dram ok U-Boot 2018.05-config-dirty (Dec 06 2023 - 10:11:56 +0800) Allwinner Technology [03.065]CPU: Allwinner Family [03.068]Model: sun8iw20 [03.070]DRAM: 128 MiB [03.073]Relocation Offset is: 04ec7000 [03.098]secure enable bit: 0 [03.100]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz [03.107]gic: normal mode [03.109]flash init start [03.111]workmode = 16,storage type = 0 [03.115]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106 [03.121]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217 [03.129]sunxi-spinand-phy: request spi0 gpio ok [03.133]sunxi-spinand-phy: request general tx dma channel ok! [03.139]sunxi-spinand-phy: request general rx dma channel ok! [03.144]sunxi-spinand-phy: set spic0 clk to 20 Mhz [03.148]sunxi-spinand-phy: init spic0 clk ok [03.152]sunxi-spinand-phy: detect munufacture from id table: Winbond [03.159]sunxi-spinand-phy: detect spinand id: ff22aaef ffffffff [03.164]sunxi-spinand-phy: ========== arch info ========== [03.169]sunxi-spinand-phy: Model: W25N02KVZEIR [03.175]sunxi-spinand-phy: Munufacture: Winbond [03.180]sunxi-spinand-phy: DieCntPerChip: 1 [03.184]sunxi-spinand-phy: BlkCntPerDie: 2048 [03.189]sunxi-spinand-phy: PageCntPerBlk: 64 [03.193]sunxi-spinand-phy: SectCntPerPage: 4 [03.198]sunxi-spinand-phy: OobSizePerPage: 64 [03.202]sunxi-spinand-phy: BadBlockFlag: 0x0 [03.207]sunxi-spinand-phy: OperationOpt: 0x7 [03.211]sunxi-spinand-phy: MaxEraseTimes: 65000 [03.216]sunxi-spinand-phy: EccFlag: 0x0 [03.221]sunxi-spinand-phy: EccType: 2 [03.225]sunxi-spinand-phy: EccProtectedType: 3 [03.230]sunxi-spinand-phy: ======================================== [03.236]sunxi-spinand-phy: [03.238]sunxi-spinand-phy: ========== physical info ========== [03.244]sunxi-spinand-phy: TotalSize: 256 M [03.248]sunxi-spinand-phy: SectorSize: 512 B [03.252]sunxi-spinand-phy: PageSize: 2 K [03.256]sunxi-spinand-phy: BlockSize: 128 K [03.260]sunxi-spinand-phy: OOBSize: 64 B [03.264]sunxi-spinand-phy: ======================================== [03.270]sunxi-spinand-phy: [03.273]sunxi-spinand-phy: ========== logical info ========== [03.278]sunxi-spinand-phy: TotalSize: 256 M [03.282]sunxi-spinand-phy: SectorSize: 512 B [03.286]sunxi-spinand-phy: PageSize: 4 K [03.290]sunxi-spinand-phy: BlockSize: 256 K [03.295]sunxi-spinand-phy: OOBSize: 128 B [03.299]sunxi-spinand-phy: ======================================== [03.305]sunxi-spinand-phy: W25N02KVZEIR reset rx bit width to 1 [03.311]sunxi-spinand-phy: W25N02KVZEIR reset tx bit width to 1 [03.316]sunxi-spinand-phy: set spic0 clk to 100 Mhz [03.321]sunxi-spinand-phy: block lock register: 0x00 [03.325]sunxi-spinand-phy: feature register: 0x19 [03.330]sunxi-spinand-phy: sunxi physic nand init end [03.335]line:703 init_clocks [03.338]init_clocks:finish [03.340]Loading Environment from SUNXI_FLASH... OK [03.344]try to burn key [03.347]out of usb burn from boot: not need burn key Hit any key to stop autoboot: 0 sunxi work mode=0x10 run usb efex buf queue page size = 16384 delay time 2500 weak:otg_phy_config usb init ok set address 0x2d set address 0x2d ok set address 0x2e set address 0x2e ok SUNXI_EFEX_ERASE_TAG erase_flag = 0x12 origin_erase_flag = 0x1 FEX_CMD_fes_verify_status FEX_CMD_fes_verify last err=0 the 0 mbr table is ok the 1 mbr table is ok the 2 mbr table is ok the 3 mbr table is ok *************MBR DUMP*************** total mbr part 8 part[0] name :boot-resource part[0] classname :DISK part[0] addrlo :0x8000 part[0] lenlo :0x1f8 part[0] user_type :32768 part[0] keydata :0 part[0] ro :0 part[1] name :env part[1] classname :DISK part[1] addrlo :0x81f8 part[1] lenlo :0x1f8 part[1] user_type :32768 part[1] keydata :0 part[1] ro :0 part[2] name :env-redund part[2] classname :DISK part[2] addrlo :0x83f0 part[2] lenlo :0x1f8 part[2] user_type :32768 part[2] keydata :0 part[2] ro :0 part[3] name :boot part[3] classname :DISK part[3] addrlo :0x85e8 part[3] lenlo :0x24b0 part[3] user_type :32768 part[3] keydata :0 part[3] ro :0 part[4] name :rootfs part[4] classname :DISK part[4] addrlo :0xaa98 part[4] lenlo :0xf000 part[4] user_type :32768 part[4] keydata :0 part[4] ro :0 part[5] name :private part[5] classname :DISK part[5] addrlo :0x19a98 part[5] lenlo :0x2800 part[5] user_type :32768 part[5] keydata :0 part[5] ro :0 part[6] name :rootfs_data part[6] classname :DISK part[6] addrlo :0x1c298 part[6] lenlo :0xc4e0 part[6] user_type :32768 part[6] keydata :0 part[6] ro :0 part[7] name :UDISK part[7] classname :DISK part[7] addrlo :0x28778 part[7] lenlo :0x0 part[7] user_type :33024 part[7] keydata :0 part[7] ro :0 total part: 9 mbr 0, 8000, 8000 boot-resource 1, 1f8, 8000 env 2, 1f8, 8000 env-redund 3, 1f8, 8000 boot 4, 24b0, 8000 rootfs 5, f000, 8000 private 6, 2800, 8000 rootfs_data 7, c4e0, 8000 UDISK 8, 0, 8100 [06.529]erase blk 0 to blk 32 need erase flash: 18 [06.632]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) device nand0 <nand>, # parts = 4 #: name size offset mask_flags 0: boot0 0x00100000 0x00000000 1 1: uboot 0x00300000 0x00100000 1 2: secure_storage 0x00100000 0x00400000 1 3: sys 0x0fb00000 0x00500000 0 active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000 defaults: mtdids : nand0=nand mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) [06.683]MTD info (4) [06.685]pagesize: 0x1000 [06.687]blksize: 0x40000 [06.689]num offset bytes name [06.693]0 0x00000000 0x00100000 boot0 [06.697]1 0x00100000 0x00300000 uboot [06.700]2 0x00400000 0x00100000 secure_storage [06.705]3 0x00500000 0x0fb00000 sys [06.708]ubi attach the last part of mtd device: NO.3 [06.819]ubi0: attaching mtd4 [07.245]ubi0: scanning is finished [07.254]ubi0: attached mtd4 (name "sys", size 251 MiB) [07.259]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [07.265]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048 [07.272]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [07.278]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0 [07.283]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128 [07.290]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0 [07.298]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40 [07.306]erase blk 0 to blk 32 [07.406]erase blk 40 to blk 2048 [13.491]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33 [13.499]Item0 (Map) magic is bad [13.502]the secure storage map is empty [13.598]sunxi-spinand: write secure storage itme 0 ok [13.603]erase secure storage: 0 ok SUNXI_EFEX_MBR_TAG mbr size = 0x10000 force mbr device nand0 <nand>, # parts = 4 #: name size offset mask_flags 0: boot0 0x00100000 0x00000000 1 1: uboot 0x00300000 0x00100000 1 2: secure_storage 0x00100000 0x00400000 1 3: sys 0x0fb00000 0x00500000 0 active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000 defaults: mtdids : nand0=nand mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) [13.651]MTD info (4) [13.653]pagesize: 0x1000 [13.655]blksize: 0x40000 [13.658]num offset bytes name [13.661]0 0x00000000 0x00100000 boot0 [13.665]1 0x00100000 0x00300000 uboot [13.668]2 0x00400000 0x00100000 secure_storage [13.673]3 0x00500000 0x0fb00000 sys [13.676]MBR info (unalign): [13.679]partno addr sects type name [13.684]0 0x00000000 0x00008000 0x00000001 mbr [13.688]1 0x00008000 0x000001f8 0x00008000 boot-resource [13.694]2 0x000081f8 0x000001f8 0x00008000 env [13.699]3 0x000083f0 0x000001f8 0x00008000 env-redund [13.704]4 0x000085e8 0x000024b0 0x00008000 boot [13.709]5 0x0000aa98 0x0000f000 0x00008000 rootfs [13.714]6 0x00019a98 0x00002800 0x00008000 private [13.719]7 0x0001c298 0x0000c4e0 0x00008000 rootfs_data [13.725]8 0x00028778 0x00000000 0x00008100 UDISK [13.730]ubi attach the last part of mtd device: NO.3 [13.734]MBR info (align): [13.737]partno addr sects type name [13.741]0 0x00002800 0x000081f0 0x00000001 mbr [13.746]1 0x0000a9f0 0x000001f8 0x00008000 boot-resource [13.752]2 0x0000abe8 0x000001f8 0x00008000 env [13.757]3 0x0000ade0 0x000001f8 0x00008000 env-redund [13.762]4 0x0000afd8 0x00002568 0x00008000 boot [13.767]5 0x0000d540 0x0000f030 0x00008000 rootfs [13.772]6 0x0001c570 0x00002958 0x00008000 private [13.777]7 0x0001eec8 0x0000c4e0 0x00008000 rootfs_data [13.782]8 0x0002b3a8 0x00000000 0x00008100 UDISK [13.787]ubi attach the last part of mtd device: NO.3 [13.792]ubi attatch mtd, name: sys [13.795]ubi0: detaching mtd4 [13.798]ubi0: mtd4 is detached [13.801]ubi0: attaching mtd4 [14.015]ubi0: scanning is finished [14.018]ubi0: empty MTD device detected [14.048]ubi0: attached mtd4 (name "sys", size 251 MiB) [14.052]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [14.059]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048 [14.065]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [14.071]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0 [14.077]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128 [14.083]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0 [14.091]ubi0: available PEBs: 960, total reserved PEBs: 44, PEBs reserved for bad PEB handling: 40 Creating static volume mbr of size 17031168 Creating dynamic volume boot-resource of size 258048 Creating dynamic volume env of size 258048 Creating dynamic volume env-redund of size 258048 Creating dynamic volume boot of size 4902912 Creating dynamic volume rootfs of size 31481856 Creating dynamic volume private of size 5419008 Creating dynamic volume rootfs_data of size 25804800 No size specified -> Using max size (162312192) [20.923]reset last volume size to 0x4d658 Creating dynamic volume UDISK of size 162312192 [20.983]fill gap start: volume mbr sects 0x7f80 [25.133]fill gap end: volume mbr [25.136]update partition map [25.138]logical area info: 960 258048 last_lba: 483839 [25.150]logical area info: 960 258048 last_lba: 483839 [25.162]logical area info: 960 258048 last_lba: 483839 [25.173]logical area info: 960 258048 last_lba: 483839 [25.185]logical area info: 960 258048 last_lba: 483839 [25.196]logical area info: 960 258048 last_lba: 483839 [25.208]logical area info: 960 258048 last_lba: 483839 [25.219]logical area info: 960 258048 last_lba: 483839 [25.231]logical area info: 960 258048 last_lba: 483839 [25.242]logical area info: 960 258048 last_lba: 483839 [25.254]logical area info: 960 258048 last_lba: 483839 [25.266]logical area info: 960 258048 last_lba: 483839 [25.277]logical area info: 960 258048 last_lba: 483839 [25.289]logical area info: 960 258048 last_lba: 483839 [25.300]logical area info: 960 258048 last_lba: 483839 [25.312]logical area info: 960 258048 last_lba: 483839 [25.323]logical area info: 960 258048 last_lba: 483839 [25.335]logical area info: 960 258048 last_lba: 483839 [25.346]logical area info: 960 258048 last_lba: 483839 [25.358]logical area info: 960 258048 last_lba: 483839 [25.369]logical area info: 960 258048 last_lba: 483839 [25.381]logical area info: 960 258048 last_lba: 483839 [25.393]logical area info: 960 258048 last_lba: 483839 [25.404]logical area info: 960 258048 last_lba: 483839 [25.416]logical area info: 960 258048 last_lba: 483839 [25.427]logical area info: 960 258048 last_lba: 483839 [25.439]logical area info: 960 258048 last_lba: 483839 [25.450]logical area info: 960 258048 last_lba: 483839 FEX_CMD_fes_verify_status FEX_CMD_fes_verify last err=0 [25.503]fill gap start: volume boot-resource sects 0x158 [25.592]fill gap end: volume boot-resource FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x14000 FEX_CMD_fes_verify_value 0xe6f75b5c [25.649]fill gap start: volume env sects 0xf8 [25.737]fill gap end: volume env FEX_CMD_fes_verify_value, start 0x81f8, size high 0x0:low 0x20000 FEX_CMD_fes_verify_value 0x7fcd5778 [25.801]fill gap start: volume env-redund sects 0xf8 [25.890]fill gap end: volume env-redund FEX_CMD_fes_verify_value, start 0x83f0, size high 0x0:low 0x20000 FEX_CMD_fes_verify_value 0x7fcd5778 [27.078]fill gap start: volume boot sects 0x1c8 [27.168]fill gap end: volume boot FEX_CMD_fes_verify_value, start 0x85e8, size high 0x0:low 0x45d000 FEX_CMD_fes_verify_value 0xbce5663b [31.385]fill gap start: volume rootfs sects 0x8000 [31.587]fill gap end: volume rootfs FEX_CMD_fes_verify_value, start 0xaa98, size high 0x0:low 0xe00000 FEX_CMD_fes_verify_value 0x1a83a347 bootfile_mode=4 SUNXI_EFEX_BOOT1_TAG boot1 size = 0x13c000, max size = 0x400000 uboot size = 0x13c000 storage type = 0 [33.186]uboot blk range [8-32) [33.189]download uboot to block 8 (10 blocks) len 1264K [33.515]download uboot to block 18 (10 blocks) len 1264K FEX_CMD_fes_verify_status FEX_CMD_fes_verify last err=0 bootfile_mode=4 SUNXI_EFEX_BOOT0_TAG boot0 size = 0xc000 dram para[0] = 3a8 dram para[1] = 3 dram para[2] = 7b7bfb dram para[3] = 0 dram para[4] = 10d2 dram para[5] = 800000 dram para[6] = 1e14 dram para[7] = 42 dram para[8] = 20 dram para[9] = 0 dram para[10] = 4899d7 dram para[11] = 1c241d0 dram para[12] = a4073 dram para[13] = b4787896 dram para[14] = 0 dram para[15] = 48484848 dram para[16] = 48 dram para[17] = 1620121e dram para[18] = 0 dram para[19] = 0 dram para[20] = 0 dram para[21] = 340000 dram para[22] = 46 dram para[23] = b4006103 dram para[24] = 0 dram para[25] = 0 dram para[26] = 0 dram para[27] = 0 dram para[28] = 0 dram para[29] = 0 dram para[30] = 0 dram para[31] = 0 storage type = 0 [33.924]download boot0 to block 0 len 48K [33.942]download boot0 to block 1 len 48K [33.960]download boot0 to block 2 len 48K [33.977]download boot0 to block 3 len 48K [33.995]download boot0 to block 4 len 48K [34.013]download boot0 to block 5 len 48K [34.031]download boot0 to block 6 len 48K [34.049]download boot0 to block 7 len 48K FEX_CMD_fes_verify_status FEX_CMD_fes_verify last err=0 sunxi_efex_next_action=2 exit usb next work 2 [28]HELLO! BOOT0 is starting!OT [31]BOOT0 commit : adaf1174cc [34]set pll start [40]periph0 has been enabled [43]set pll end [44][pmu]: bus read error [47]board init ok [49]ZQ value = 0x2d [51]get_pmu_exist() = -1 [53]DRAM BOOT DRIVE INFO: V0.33 [56]DRAM CLK = 936 MHz [58]DRAM Type = 3 (2:DDR2,3:DDR3) [61]DRAMC read ODT off. [64]DRAM ODT value: 0x42. [66]ddr_efuse_type: 0xa [69]DRAM SIZE =128 M [71]dram_tpr4:0x0 [73]PLL_DDR_CTRL_REG:0xf8004d00 [76]DRAM_CLK_REG:0xc0000000 [79][TIMING DEBUG] MR2= 0x20 [86]DRAM simple test OK. [88]rtc standby flag is 0x0, super standby flag is 0x0 [93]dram size =128 [96]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32 [101]block from 8 to 32 [223]Check is correct. [225]dma 0x29c9c int is not used yet [228]dma 0x29c9c int is free, you do not need to free it again [234]Entry_name = u-boot [241]Entry_name = optee [245]Entry_name = dtb [248]Jump to second Boot. M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 23 09:25:11 UTC 2021 arm U-Boot 2018.05-config-dirty (Dec 06 2023 - 10:11:56 +0800) Allwinner Technology [00.301]CPU: Allwinner Family [00.304]Model: sun8iw20 [00.306]DRAM: 128 MiB [00.309]Relocation Offset is: 04ec7000 [00.334]secure enable bit: 0 [00.336]smc_tee_inform_fdt failed with: -65526[00.340]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz [00.346]gic: sec monitor mode [00.349]flash init start [00.351]workmode = 0,storage type = 0 device nand0 <nand>, # parts = 4 #: name size offset mask_flags 0: boot0 0x00100000 0x00000000 1 1: uboot 0x00300000 0x00100000 1 2: secure_storage 0x00100000 0x00400000 1 3: sys 0x0fb00000 0x00500000 0 active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000 defaults: mtdids : nand0=nand mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) [00.506]ubi0: attaching mtd4 [00.932]ubi0: scanning is finished [00.941]ubi0: attached mtd4 (name "sys", size 251 MiB) [00.946]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [00.952]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048 [00.958]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [00.965]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0 [00.970]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128 [00.977]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0 [00.984]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40 [00.993]sunxi flash init ok [00.996]line:703 init_clocks [00.999]drv_disp_init request pwm success, pwm7:pwm7:0x2000c00. fdt get node offset faill: hdmi [01.015]unable to map hdmi registers [01.018]drv_disp_init finish [01.209]Loading Environment from SUNXI_FLASH... OK [01.243]boot_gui_init:start [01.246]set disp.dev2_output_type fail. using defval=0 [01.253]boot_gui_init:finish partno erro : can't find partition bootloader 54 bytes read in 1 ms (52.7 KiB/s) [01.284]bmp_name=bootlogo.bmp size 38454 38454 bytes read in 5 ms (7.3 MiB/s) [01.299]Item0 (Map) magic is bad secure storage read widevine fail [01.305]secure storage read widevine fail with:-1 secure storage read ec_key fail [01.312]secure storage read ec_key fail with:-1 secure storage read ec_cert1 fail [01.319]secure storage read ec_cert1 fail with:-1 secure storage read ec_cert2 fail [01.327]secure storage read ec_cert2 fail with:-1 secure storage read ec_cert3 fail [01.334]secure storage read ec_cert3 fail with:-1 secure storage read rsa_key fail [01.342]secure storage read rsa_key fail with:-1 secure storage read rsa_cert1 fail [01.349]secure storage read rsa_cert1 fail with:-1 secure storage read rsa_cert2 fail [01.357]secure storage read rsa_cert2 fail with:-1 secure storage read rsa_cert3 fail [01.364]secure storage read rsa_cert3 fail with:-1 [01.369]out of usb burn from boot: not need burn key List file under ULI/factory ** Unrecognized filesystem type ** [01.401]update bootcmd [01.424]change working_fdt 0x43e86e70 to 0x43e66e70 FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL sunxi_pwm_pin_set_state, fdt_set_all_pin, ret=-1 [01.442]LCD open finish [01.454]update dts Hit any key to stop autoboot: 0 [02.952]no vendor_boot partition is found Android's image name: t113-mq_r [02.963]Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.4.61 (root@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #15 SMP PREEMPT Wed Dec 6 02:11:14 UTC 2023 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: sun8iw20 [ 0.000000] printk: bootconsole [earlycon0] enabled [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] On node 0 totalpages: 32768 [ 0.000000] Normal zone: 256 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 32768 pages, LIFO batch:7 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 15 pages/cpu s30860 r8192 d22388 u61440 [ 0.000000] pcpu-alloc: s30860 r8192 d22388 u61440 alloc=15*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512 [ 0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:private@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-config-dirty(12/06/2023-10:11:56) disp_reserve=1536000,0x43f23000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128 [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear) [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.000000] mem auto-init: stack:byref(zero), heap alloc:off, heap free:off [ 0.000000] Memory: 110032K/131072K available (6144K kernel code, 412K rwdata, 2192K rodata, 1024K init, 162K bss, 21040K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] random: get_random_bytes called from start_kernel+0x260/0x3e8 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.008001] Switching to timer-based delay loop, resolution 41ns [ 0.014339] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.024201] Console: colour dummy device 80x30 [ 0.028674] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.039051] pid_max: default: 32768 minimum: 301 [ 0.044485] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.051827] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.062778] CPU: Testing write buffer coherency: ok [ 0.068885] /cpus/cpu@0 missing clock-frequency property [ 0.074264] /cpus/cpu@1 missing clock-frequency property [ 0.079591] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.087027] Setting up static identity map for 0x40100000 - 0x40100060 [ 0.093874] rcu: Hierarchical SRCU implementation. [ 0.099441] BOOTEVENT: 99.430999: ON [ 0.104146] smp: Bringing up secondary CPUs ... [ 0.110813] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.110973] smp: Brought up 1 node, 2 CPUs [ 0.120788] SMP: Total of 2 processors activated (96.00 BogoMIPS). [ 0.126968] CPU: All CPU(s) started in SVC mode. [ 0.133981] devtmpfs: initialized [ 0.305780] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.315603] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.325497] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.332561] pinctrl core: initialized pinctrl subsystem [ 0.345337] NET: Registered protocol family 16 [ 0.351137] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.532012] rtc_ccu: sunxi ccu init OK [ 0.549584] ccu: sunxi ccu init OK [ 0.554971] r_ccu: sunxi ccu init OK [ 0.779665] iommu: Default domain type: Translated [ 0.786024] sunxi iommu: irq = 24 [ 0.799289] SCSI subsystem initialized [ 0.805812] usbcore: registered new interface driver usbfs [ 0.811847] usbcore: registered new interface driver hub [ 0.817894] usbcore: registered new device driver usb [ 0.830076] Advanced Linux Sound Architecture Driver Initialized. [ 0.841680] pwm module init! [ 0.849748] g2d 5410000.g2d: Adding to iommu group 0 [ 0.858445] G2D: rcq version initialized.major:252 [ 0.865647] clocksource: Switched to clocksource arch_sys_counter [ 0.943043] sun8iw20-pinctrl pio: initialized sunXi PIO driver [ 1.037779] NET: Registered protocol family 2 [ 1.048398] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 1.057956] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 1.065690] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear) [ 1.072742] TCP: Hash tables configured (established 1024 bind 1024) [ 1.079808] UDP hash table entries: 256 (order: 1, 8192 bytes, linear) [ 1.086427] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear) [ 1.094207] NET: Registered protocol family 1 [ 1.103866] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator [ 1.113843] spi spi0: spi0 supply spi not found, using dummy regulator [ 1.122161] sunxi_spi_resource_get()2116 - [spi0] SPI MASTER MODE [ 1.128542] sunxi_spi_resource_get()2154 - Failed to get sample mode [ 1.134897] sunxi_spi_resource_get()2159 - Failed to get sample delay [ 1.141369] sunxi_spi_resource_get()2163 - sample_mode:-1431633921 sample_delay:-1431633921 [ 1.149773] sunxi_spi_clk_init()2205 - [spi0] mclk 100000000 [ 1.159232] sunxi_spi_probe()2623 - [spi0]: driver probe succeed, base c8860000, irq 39 [ 1.174183] Initialise system trusted keyrings [ 1.179128] workingset: timestamp_bits=30 max_order=15 bucket_order=0 [ 1.294290] ntfs: driver 2.1.32 [Flags: R/W]. [ 1.304919] NET: Registered protocol family 38 [ 1.309494] Key type asymmetric registered [ 1.313587] Asymmetric key parser 'x509' registered [ 1.318803] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250) [ 1.326228] io scheduler mq-deadline registered [ 1.330755] io scheduler kyber registered [ 1.334881] atomic64_test: passed [ 1.346882] [DISP]disp_module_init [ 1.352751] disp 5000000.disp: Adding to iommu group 0 [ 1.360930] [DISP] parser_disp_init_para,line:1430: [ 1.360935] of_property_read fb0_width fail [ 1.370088] [DISP] disp_init,line:2386: [ 1.370092] smooth display screen:0 type:1 mode:4 [ 1.398925] display_fb_request,fb_id:0 [ 1.406062] Freeing logo buffer memory: 1500K [ 1.412352] disp_al_manager_apply ouput_type:1 [ 1.418286] sunxi_pwm_enable_dual: can't parse pwm device [ 1.425624] [DISP]disp_module_init finish [ 1.431935] sunxi_sid_init()551 - insmod ok [ 1.438170] pwm-regulator: supplied by regulator-dummy [ 1.448855] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator [ 1.457505] uart uart0: uart0 supply uart not found, using dummy regulator [ 1.466167] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI [ 1.474060] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n [ 1.482048] printk: console [ttyS0] enabled [ 1.482048] printk: console [ttyS0] enabled [ 1.490940] printk: bootconsole [earlycon0] disabled [ 1.490940] printk: bootconsole [earlycon0] disabled [ 1.505588] misc dump reg init [ 1.516182] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator [ 1.525485] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9 [ 1.532910] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed [ 1.540386] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed [ 1.547870] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1) [ 1.554375] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power. [ 1.561334] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1) [ 1.569209] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1 [ 1.577271] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1 [ 1.585387] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled [ 1.593863] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power. [ 1.600654] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1) [ 1.608417] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0 [ 1.617701] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11 [ 1.625666] [ADDR_MGT] addr_mgt_probe: success. [ 1.637747] libphy: Fixed MDIO Bus: probed [ 1.642876] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.650275] sunxi-ehci: EHCI SUNXI driver [ 1.655517] get ehci1-controller wakeup-source is fail. [ 1.661827] sunxi ehci1-controller don't init wakeup source [ 1.668134] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b86b98, 0x:c8875000, irq_no:3a [ 1.680249] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator [ 1.693785] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator [ 1.706411] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller [ 1.713798] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1 [ 1.724504] sunxi-ehci 4200000.ehci1-controller: irq 58, io mem 0x04200000 [ 1.755676] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00 [ 1.769470] hub 1-0:1.0: USB hub found [ 1.773931] hub 1-0:1.0: 1 port detected [ 1.782296] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.789301] sunxi-ohci: OHCI SUNXI driver [ 1.794603] get ohci1-controller wakeup-source is fail. [ 1.800915] sunxi ohci1-controller don't init wakeup source [ 1.807154] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b86e28 [ 1.816901] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator [ 1.830396] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator [ 1.843004] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller [ 1.850419] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2 [ 1.860985] sunxi-ohci 4200400.ohci1-controller: irq 59, io mem 0x04200400 [ 1.945527] hub 2-0:1.0: USB hub found [ 1.950062] hub 2-0:1.0: 1 port detected [ 1.959248] usbcore: registered new interface driver uas [ 1.965800] usbcore: registered new interface driver usb-storage [ 1.972803] usbcore: registered new interface driver ums-alauda [ 1.979753] usbcore: registered new interface driver ums-cypress [ 1.986777] usbcore: registered new interface driver ums-datafab [ 1.993755] usbcore: registered new interface driver ums_eneub6250 [ 2.000971] usbcore: registered new interface driver ums-freecom [ 2.007962] usbcore: registered new interface driver ums-isd200 [ 2.014885] usbcore: registered new interface driver ums-jumpshot [ 2.021983] usbcore: registered new interface driver ums-karma [ 2.028804] usbcore: registered new interface driver ums-onetouch [ 2.036137] usbcore: registered new interface driver ums-realtek [ 2.043115] usbcore: registered new interface driver ums-sddr09 [ 2.050142] usbcore: registered new interface driver ums-sddr55 [ 2.057062] usbcore: registered new interface driver ums-usbat [ 2.065618] sunxi_gpadc_init,2151, success [ 2.071399] sunxi_gpadc_setup: get channel scan data failed [ 2.080464] input: sunxi-gpadc0 as /devices/virtual/input/input0 [ 2.090747] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1 [ 2.103452] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate! [ 2.114162] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate! [ 2.128201] sunxi-rtc 7090000.rtc: registered as rtc0 [ 2.133897] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate! [ 2.144514] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:35 UTC (35) [ 2.153549] sunxi-rtc 7090000.rtc: sunxi rtc probed [ 2.159953] i2c /dev entries driver [ 2.164225] IR NEC protocol handler initialized [ 2.169299] IR RC5(x/sz) protocol handler initialized [ 2.175480] sunxi cedar version 1.1 [ 2.182693] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 2.202281] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40) [ 2.212361] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8 [ 2.218594] sunxi-mmc 4020000.sdmmc: No vmmc regulator found [ 2.224904] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found [ 2.231334] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found [ 2.237762] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found [ 2.244263] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found [ 2.250785] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found [ 2.257299] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found [ 2.265625] sunxi-mmc 4020000.sdmmc: Got CD GPIO [ 2.272451] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.283597] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator [ 2.303720] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.328750] sunxi-mmc 4020000.sdmmc: detmode:gpio irq [ 2.336749] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40) [ 2.346880] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8 [ 2.353056] sunxi-mmc 4021000.sdmmc: No vmmc regulator found [ 2.359385] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found [ 2.365815] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found [ 2.372220] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found [ 2.378735] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found [ 2.385244] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found [ 2.391758] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found [ 2.398535] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed [ 2.410469] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.421629] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator [ 2.441750] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.466013] sunxi-mmc 4021000.sdmmc: detmode:manually by software [ 2.473654] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !! [ 2.481339] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !! [ 2.488204] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.497632] usbcore: registered new interface driver usbhid [ 2.502899] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.506016] usbhid: USB HID core driver [ 2.519791] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 2.522202] exFAT: Version 1.3.0 [ 2.529710] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 2.535730] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 2.540920] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 2.557905] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 2.564643] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 2.576438] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1 [ 2.576438] [ 2.593887] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0 [ 2.606451] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished [ 2.620019] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present! [ 2.629959] [SNDCODEC][sunxi_card_init][583]:card init finished [ 2.638447] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok [ 2.656301] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1 [ 2.671095] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished [ 2.685791] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch [ 2.688814] NET: Registered protocol family 10 [ 2.705796] Segment Routing with IPv6 [ 2.710217] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.727667] NET: Registered protocol family 17 [ 2.732723] NET: Registered protocol family 15 [ 2.738656] Registering SWP/SWPB emulation handler [ 2.746397] Loading compiled-in X.509 certificates [ 2.758056] HDMI 2.0 driver init start! [ 2.762409] boot_hdmi=false [ 2.765681] ERROR: can not get hdmi_cts_compatibility [ 2.771337] ERROR: can not get hdmi_cec_support node [ 2.777099] ERROR: can not get hdmi_cec_super_standby node [ 2.783212] ERROR: can not get hdmi_hdcp_enable [ 2.788404] ERROR: pinctrl_get for HDMI2.0 DDC fail [ 2.793839] ERROR: can not get ddc_en_io_ctrl [ 2.798777] ERROR: can not get hdmi_power_cnt [ 2.806024] HDMI2.0 module init end [ 2.929555] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator [ 2.943135] sunxi-i2c sunxi-i2c2: probe success [ 2.951086] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator [ 2.974231] platform 2000c13.pwm3: pinctrl_get failed [ 2.980131] platform 2000c13.pwm3: pinctrl_get failed [ 2.985797] cpu cpu0: _set_opp_voltage: failed to set voltage (1000000 1000000 1000000 mV): -19 [ 2.995708] platform 2000c13.pwm3: pinctrl_get failed [ 3.001510] platform 2000c13.pwm3: pinctrl_get failed [ 3.007162] cpu cpu0: _set_opp_voltage: failed to set voltage (900000 900000 900000 mV): -19 [ 3.016584] cpufreq: __target_index: Failed to change cpu frequency: -19 [ 3.027032] get ehci0-controller wakeup-source is fail. [ 3.033248] sunxi ehci0-controller don't init wakeup source [ 3.039495] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b86678, 0x:c88f7000, irq_no:38 [ 3.051432] [sunxi-ehci0]: Not init ehci0 [ 3.056812] get ohci0-controller wakeup-source is fail. [ 3.063105] sunxi ohci0-controller don't init wakeup source [ 3.069349] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b86908 [ 3.078964] [sunxi-ohci0]: Not init ohci0 [ 3.087466] platform 2000c13.pwm3: pinctrl_get failed [ 3.089850] UBI error: cannot open mtd sys, error -2 [ 3.093300] platform 2000c13.pwm3: pinctrl_get failed [ 3.101742] get usb_detect_mode is fail, -22 [ 3.104342] cpu cpu0: _set_opp_voltage: failed to set voltage (1000000 1000000 1000000 mV): -19 [ 3.104557] platform 2000c13.pwm3: pinctrl_get failed [ 3.109571] get det_vbus is fail, -84 [ 3.119387] platform 2000c13.pwm3: pinctrl_get failed [ 3.124574] get id is fail, -84 [ 3.128632] cpu cpu0: _set_opp_voltage: failed to set voltage (900000 900000 900000 mV): -19 [ 3.140943] get ctp_power is fail, -22 [ 3.147425] cpufreq: __target_index: Failed to change cpu frequency: -19 [ 3.159780] get ctp_power_ldo_vol is fail, -22 [ 3.164931] sunxi_ctp_startup: ctp_power_io is invalid. [ 3.171255] get ctp_gesture_wakeup fail, no gesture wakeup [ 3.177430] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator [ 3.345749] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.353839] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.361487] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.369564] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.377203] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.385279] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.392912] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.400991] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.408628] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.416706] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.424284] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset. [ 3.585657] <<-GTP-ERROR->> GTP i2c test failed time 1. [ 3.615706] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.623790] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.631417] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.639497] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.647130] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.655206] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.662841] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.670917] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.678553] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.686629] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.694205] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset. [ 3.855656] <<-GTP-ERROR->> GTP i2c test failed time 2. [ 3.885714] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.893790] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.901418] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.909492] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.917118] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.925188] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.932825] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.940902] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.948528] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 3.956605] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 3.964172] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset. [ 4.125687] <<-GTP-ERROR->> GTP i2c test failed time 3. [ 4.155699] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.163785] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.171412] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.179499] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.187125] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.195208] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.202836] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.210939] [ 4.210939] insmod_device_driver [ 4.210939] [ 4.210958] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.218238] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator [ 4.225458] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.238644] device_chose finished 142! [ 4.245574] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.256969] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset. [ 4.425666] <<-GTP-ERROR->> GTP i2c test failed time 4. [ 4.455707] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.463783] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.471414] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.479491] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.487121] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.495195] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.502820] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.510897] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.518522] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received [ 4.526600] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14) [ 4.534167] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset. [ 4.680853] random: fast init done [ 4.695654] <<-GTP-ERROR->> GTP i2c test failed time 5. [ 4.725653] I2C communication ERROR! [ 4.725719] regulator-dummy: Underflow of regulator enable count [ 4.737375] gt9xxnew_ts: probe of 2-0014 failed with error -1 [ 4.745166] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 4.759686] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 4.767749] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 4.777462] cfg80211: failed to load regulatory.db [ 4.777464] clk: Not disabling unused clocks [ 4.777476] ALSA device list: [ 4.790928] #0: audiocodec [ 4.794207] alloc_fd: slot 0 not NULL! [ 4.800470] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -19 [ 4.809928] Please append a correct "root=" boot option; here are the available partitions: [ 4.819306] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) [ 4.828525] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #15 [ 4.835219] Hardware name: Generic DT based system [ 4.840574] [<c010e6fc>] (unwind_backtrace) from [<c010abc0>] (show_stack+0x10/0x14) [ 4.849210] [<c010abc0>] (show_stack) from [<c06ca148>] (dump_stack+0x7c/0x98) [ 4.857266] [<c06ca148>] (dump_stack) from [<c0119bfc>] (panic+0x108/0x3d8) [ 4.865032] [<c0119bfc>] (panic) from [<c0a01260>] (mount_block_root+0x230/0x320) [ 4.873378] [<c0a01260>] (mount_block_root) from [<c0a01508>] (prepare_namespace+0x138/0x178) [ 4.882887] [<c0a01508>] (prepare_namespace) from [<c06de7f4>] (kernel_init+0x8/0x118) [ 4.891716] [<c06de7f4>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c) [ 4.900152] Exception stack(0xc784dfb0 to 0xc784dff8) [ 4.905782] dfa0: 00000000 00000000 00000000 00000000 [ 4.914899] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 4.924016] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 4.931395] CPU0: stopping [ 4.934413] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #15 [ 4.941104] Hardware name: Generic DT based system [ 4.946450] [<c010e6fc>] (unwind_backtrace) from [<c010abc0>] (show_stack+0x10/0x14) [ 4.955084] [<c010abc0>] (show_stack) from [<c06ca148>] (dump_stack+0x7c/0x98) [ 4.963139] [<c06ca148>] (dump_stack) from [<c010c9a8>] (handle_IPI+0xcc/0x168) [ 4.971292] [<c010c9a8>] (handle_IPI) from [<c03810f8>] (gic_handle_irq+0x70/0x78) [ 4.979733] [<c03810f8>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8) [ 4.988071] Exception stack(0xc0b01f40 to 0xc0b01f88) [ 4.993704] 1f40: 00000ee0 c7ebd534 00000000 c0115100 00000001 c0b00000 c0b03de4 c0b03e20 [ 5.002822] 1f60: c0b68000 c7ffc540 c0a2c0c0 00000000 c0b72890 c0b01f90 c0108210 c0108200 [ 5.011936] 1f80: 60000113 ffffffff [ 5.015828] [<c01021cc>] (__irq_svc) from [<c0108200>] (arch_cpu_idle+0x1c/0x38) [ 5.024077] [<c0108200>] (arch_cpu_idle) from [<c013ee30>] (do_idle+0xd0/0x120) [ 5.032228] [<c013ee30>] (do_idle) from [<c013f130>] (cpu_startup_entry+0x18/0x20) [ 5.040670] [<c013f130>] (cpu_startup_entry) from [<c0a00c78>] (start_kernel+0x358/0x3e8) [ 5.049788] [<c0a00c78>] (start_kernel) from [<00000000>] (0x0)
@cwj1986521 内核没有配置UBIFS
CONFIG_UBIFS_FS=y CONFIG_UBIFS_FS_ADVANCED_COMPR=y # CONFIG_UBIFS_FS_LZO is not set # CONFIG_UBIFS_FS_ZLIB is not set # CONFIG_UBIFS_FS_ZSTD is not set # CONFIG_UBIFS_ATIME_SUPPORT is not set CONFIG_UBIFS_FS_XATTR=y CONFIG_UBIFS_FS_SECURITY=y
@awwwwa
内核配置我一开始都是配置过的,奇怪刚看了下确实又没有了,我配置的时候是进入内核代码部分 make ARCH=arm menuconfig 配置的 再Tina 目录下make的时候为什么又要restart config -
我这样选对么?
@cwj1986521 需要用 make kernel_menuconfig,如果使用的是build.sh 需要 ./build.sh menuconfig
内核配置文件会被SDK覆盖,进入内核文件夹修改的均无效
@awwwwa 刚改后还是会提示需要restart config
./src/basic/missing.h: At top level:
./src/basic/missing.h:583:6: error: #error "neither secure_getenv nor __secure_getenv are available"error "neither secure_getenv nor __secure_getenv are available"
这个是什么错误?是我重新同步配置的时候哪一步没设置好么
