T113烧录SPI NAND的镜像卡在这里这什么在做怪呢?
device nand0 <nand>, # parts = 4 #: name size offset mask_flags 0: boot0 0x00100000 0x00000000 1 1: uboot 0x00300000 0x00100000 1 2: secure_storage 0x00100000 0x00400000 1 3: sys 0x07b00000 0x00500000 0 active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000 defaults: mtdids : nand0=nand mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) [17.062]MTD info (4) [17.064]pagesize: 0x1000 [17.066]blksize: 0x40000 [17.068]num offset bytes name [17.072]0 0x00000000 0x00100000 boot0 [17.076]1 0x00100000 0x00300000 uboot [17.079]2 0x00400000 0x00100000 secure_storage [17.084]3 0x00500000 0x07b00000 sys [17.087]MBR info (unalign): [17.090]partno addr sects type name [17.094]0 0x00000000 0x00008000 0x00000001 mbr [17.099]1 0x00008000 0x000001f8 0x00008000 boot-resource [17.105]2 0x000081f8 0x000001f8 0x00008000 env [17.110]3 0x000083f0 0x000001f8 0x00008000 env-redund [17.115]4 0x000085e8 0x00002800 0x00008000 boot [17.120]5 0x0000ade8 0x00019000 0x00008000 rootfs [17.125]6 0x00023de8 0x00002800 0x00008000 private [17.130]7 0x000265e8 0x00002800 0x00008000 rootfs_data [17.135]8 0x00028de8 0x00000000 0x00008000 UDISK [17.140]ubi attach the last part of mtd device: NO.3 [17.145]MBR info (align): [17.147]partno addr sects type name [17.152]0 0x00002800 0x000081f0 0x00000001 mbr [17.157]1 0x0000a9f0 0x000001f8 0x00008000 boot-resource [17.163]2 0x0000abe8 0x000001f8 0x00008000 env [17.167]3 0x0000ade0 0x000001f8 0x00008000 env-redund [17.173]4 0x0000afd8 0x00002958 0x00008000 boot [17.178]5 0x0000d930 0x000191a0 0x00008000 rootfs [17.183]6 0x00026ad0 0x00002958 0x00008000 private [17.188]7 0x00029428 0x00002958 0x00008000 rootfs_data [17.193]8 0x0002bd80 0x00000000 0x00008000 UDISK [17.198]ubi attach the last part of mtd device: NO.3 [17.203]ubi attatch mtd, name: sys [17.206]ubi0: detaching mtd4 [17.209]ubi0: mtd4 is detached [17.212]ubi0: attaching mtd4 [17.315]ubi0: scanning is finished [17.321]ubi0: attached mtd4 (name "sys", size 123 MiB) [17.326]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [17.332]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048 [17.338]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [17.345]ubi0: good PEBs: 490, bad PEBs: 2, corrupted PEBs: 0 [17.350]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128 [17.357]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0 [17.364]ubi0: available PEBs: 0, total reserved PEBs: 490, PEBs reserved for bad PEB handling: 18 [17.373]volume mbr existed, not create again [17.377]volume boot-resource existed, not create again [17.382]volume env existed, not create again [17.386]volume env-redund existed, not create again [17.390]volume boot existed, not create again [17.394]volume rootfs existed, not create again [17.399]volume private existed, not create again [17.403]volume rootfs_data existed, not create again [17.408]volume UDISK existed, not create again [17.581]fill gap start: volume mbr sects 0x7f80 [21.610]fill gap end: volume mbr [21.613]update partition map [21.615]logical area info: 468 258048 last_lba: 235871 [21.624]logical area info: 468 258048 last_lba: 235871 [21.634]logical area info: 468 258048 last_lba: 235871 [21.643]logical area info: 468 258048 last_lba: 235871 [21.651]logical area info: 468 258048 last_lba: 235871 [21.659]logical area info: 468 258048 last_lba: 235871 [21.667]logical area info: 468 258048 last_lba: 235871 [21.675]logical area info: 468 258048 last_lba: 235871 [21.683]logical area info: 468 258048 last_lba: 235871 [21.692]logical area info: 468 258048 last_lba: 235871 [21.700]logical area info: 468 258048 last_lba: 235871 [21.708]logical area info: 468 258048 last_lba: 235871 [21.716]logical area info: 468 258048 last_lba: 235871 [21.724]logical area info: 468 258048 last_lba: 235871 [21.732]logical area info: 468 258048 last_lba: 235871 [21.740]logical area info: 468 258048 last_lba: 235871 [21.748]logical area info: 468 258048 last_lba: 235871 [21.757]logical area info: 468 258048 last_lba: 235871 [21.765]logical area info: 468 258048 last_lba: 235871 [21.773]logical area info: 468 258048 last_lba: 235871 [21.781]logical area info: 468 258048 last_lba: 235871 [21.789]logical area info: 468 258048 last_lba: 235871 [21.797]logical area info: 468 258048 last_lba: 235871 [21.805]logical area info: 468 258048 last_lba: 235871 [21.813]logical area info: 468 258048 last_lba: 235871 [21.821]logical area info: 468 258048 last_lba: 235871 [21.830]logical area info: 468 258048 last_lba: 235871 [21.838]logical area info: 468 258048 last_lba: 235871 [21.846]logical area info: 468 258048 last_lba: 235871 keypart write start: 0x23de8, sectors 0x2800 flash exit SUNXI_EFEX_MBR_TAG mbr size = 0x10000 force mbr device nand0 <nand>, # parts = 4 #: name size offset mask_flags 0: boot0 0x00100000 0x00000000 1 1: uboot 0x00300000 0x00100000 1 2: secure_storage 0x00100000 0x00400000 1 3: sys 0x07b00000 0x00500000 0 active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000 defaults: mtdids : nand0=nand mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) [21.969]MTD info (4) [21.971]pagesize: 0x1000 [21.973]blksize: 0x40000 [21.976]num offset bytes name [21.979]0 0x00000000 0x00100000 boot0 [21.983]1 0x00100000 0x00300000 uboot [21.986]2 0x00400000 0x00100000 secure_storage [21.991]3 0x00500000 0x07b00000 sys [21.994]MBR info (unalign): [21.997]partno addr sects type name [22.002]0 0x00000000 0x00008000 0x00000001 mbr [22.006]1 0x00008000 0x000001f8 0x00008000 boot-resource [22.012]2 0x000081f8 0x000001f8 0x00008000 env [22.017]3 0x000083f0 0x000001f8 0x00008000 env-redund [22.022]4 0x000085e8 0x00002800 0x00008000 boot [22.027]5 0x0000ade8 0x00019000 0x00008000 rootfs [22.032]6 0x00023de8 0x00002800 0x00008000 private [22.037]7 0x000265e8 0x00002800 0x00008000 rootfs_data [22.043]8 0x00028de8 0x00000000 0x00008000 UDISK [22.048]ubi attach the last part of mtd device: NO.3 [22.052]MBR info (align): [22.055]partno addr sects type name [22.060]0 0x00002800 0x000081f0 0x00000001 mbr [22.064]1 0x0000a9f0 0x000001f8 0x00008000 boot-resource [22.070]2 0x0000abe8 0x000001f8 0x00008000 env [22.075]3 0x0000ade0 0x000001f8 0x00008000 env-redund [22.080]4 0x0000afd8 0x00002958 0x00008000 boot [22.085]5 0x0000d930 0x000191a0 0x00008000 rootfs [22.090]6 0x00026ad0 0x00002958 0x00008000 private [22.095]7 0x00029428 0x00002958 0x00008000 rootfs_data [22.101]8 0x0002bd80 0x00000000 0x00008000 UDISK [22.105]ubi attach the last part of mtd device: NO.3 [22.110]ubi attatch mtd, name: sys [22.113]ubi0: detaching mtd4 [22.116]ubi0: mtd4 is detached [22.119]ubi0: attaching mtd4 [22.222]ubi0: scanning is finished [22.228]ubi0: attached mtd4 (name "sys", size 123 MiB) [22.233]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [22.239]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048 [22.245]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [22.251]ubi0: good PEBs: 490, bad PEBs: 2, corrupted PEBs: 0 [22.257]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128 [22.263]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0 [22.271]ubi0: available PEBs: 0, total reserved PEBs: 490, PEBs reserved for bad PEB handling: 18 [22.280]volume mbr existed, not create again [22.284]volume boot-resource existed, not create again [22.289]volume env existed, not create again [22.293]volume env-redund existed, not create again [22.297]volume boot existed, not create again [22.301]volume rootfs existed, not create again [22.305]volume private existed, not create again [22.310]volume rootfs_data existed, not create again [22.314]volume UDISK existed, not create again [22.487]fill gap start: volume mbr sects 0x7f80 [26.505]fill gap end: volume mbr [26.508]update partition map [26.514]logical area info: 468 258048 last_lba: 235871 [26.524]logical area info: 468 258048 last_lba: 235871 [26.532]logical area info: 468 258048 last_lba: 235871 [26.540]logical area info: 468 258048 last_lba: 235871 [26.549]logical area info: 468 258048 last_lba: 235871 [26.560]logical area info: 468 258048 last_lba: 235871 [26.568]logical area info: 468 258048 last_lba: 235871 [26.576]logical area info: 468 258048 last_lba: 235871 [26.584]logical area info: 468 258048 last_lba: 235871 [26.592]logical area info: 468 258048 last_lba: 235871 [26.600]logical area info: 468 258048 last_lba: 235871 [26.608]logical area info: 468 258048 last_lba: 235871 [26.616]logical area info: 468 258048 last_lba: 235871 [26.625]logical area info: 468 258048 last_lba: 235871 [26.634]logical area info: 468 258048 last_lba: 235871 [26.642]logical area info: 468 258048 last_lba: 235871 [26.652]logical area info: 468 258048 last_lba: 235871 [26.661]logical area info: 468 258048 last_lba: 235871 [26.669]logical area info: 468 258048 last_lba: 235871 [26.677]logical area info: 468 258048 last_lba: 235871 [26.685]logical area info: 468 258048 last_lba: 235871 [26.693]logical area info: 468 258048 last_lba: 235871 [26.701]logical area info: 468 258048 last_lba: 235871 [26.709]logical area info: 468 258048 last_lba: 235871 [26.717]logical area info: 468 258048 last_lba: 235871 [26.725]logical area info: 468 258048 last_lba: 235871 [26.733]logical area info: 468 258048 last_lba: 235871 FEX_CMD_fes_verify_status FEX_CMD_fes_verify last err=0 [26.763]fill gap start: volume boot-resource sects 0x158
@lansecd 晶振在作怪,跳线成无源晶振直接就刷进去了。。。。。。。。。。。。。。。。
