V851SE 修改为 spi nand flash 无法正常启动
[23]HELLO! BOOT0 is starting! [26]BOOT0 commit : 4b419f21ba [114][pmu]: bus read error [117]set pll start [119]periph0 has been enabled [122]set pll end [123]board init ok [125]DRAM use internal ZQ!! [128]ZQ value = 0x2e [130]chip id check OK [132]POWER SETTING ERROR! [134]DRAM BOOT DRIVE INFO: V0.16 [137]DRAM CLK = 528 MHz [140]DRAM Type = 2 (2:DDR2,3:DDR3) [143]DRAMC read ODT off. [145]DRAM ODT off. [148]DRAM SIZE =64 M [150]dram_tpr4:0x0 [158]DRAM simple test OK. [160]rtc standby flag is 0x0, super standby flag is 0x0 [165]dram size =64 [168]audio:avcc calibration [171]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32 [176]block from 8 to 32 [544]Check is correct. [547]Entry_name = optee [550]Entry_name = u-boot [558]Entry_name = dtb [561]Jump to second Boot. M/TC: OP-TEE version: 15ee1539b (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm E/TC:0 0 platform_standby_fdt_parse:133 no pmu node E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node U-Boot 2018.05-ga697d75 (Jul 28 2022 - 05:29:47 +0000) Allwinner Technology [00.639]CPU: Allwinner Family [00.642]Model: sun8iw21 I2C: [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed. ready [00.702]DRAM: 64 MiB [00.705]Relocation Offset is: 00ed0000 [00.738]secure enable bit: 0 E/TC:0 tee_read_fdt:433 fine node /firmware/optee failed with FDT_ERR_NOTFOUND [00.753]smc_tee_inform_fdt failed with: ffff0000 [I2C-ERROR]:twi_stop() 339 STOP can't sendout! [00.763]pmu_axp2101_probe pmic_bus_read fail [I2C-ERROR]:twi_stop() 339 STOP can't sendout! [00.771]bmu_axp2101_probe pmic_bus_read fail [00.775]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=300Mhz [00.781]gic: sec monitor mode sunxi flash map init [00.786]flash init start [00.788]workmode = 0,storage type = 0 [00.796]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:12 device nand0 <nand>, # parts = 4 #: name size offset mask_flags 0: boot0 0x00100000 0x00000000 1 1: uboot 0x00300000 0x00100000 1 2: secure_storage 0x00100000 0x00400000 1 3: sys 0x07b00000 0x00500000 0 active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000 defaults: mtdids : nand0=nand mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) [00.952]ubi0: attaching mtd4 [01.165]ubi0: scanning is finished [01.175]ubi0: attached mtd4 (name "sys", size 123 MiB) [01.179]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [01.186]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048 [01.192]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [01.198]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0 [01.203]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128 [01.210]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0 [01.218]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20 [01.226]sunxi flash init ok [01.229]line:724 init_clocks [01.232]drv_disp_init [01.242]drv_disp_init finish [01.397]Loading Environment from SUNXI_FLASH... OK [01.433]boot_gui_init:start partno erro : can't find partition Reserve0 [01.461]Get Reserve0 partition number fail! [01.468]boot_gui_init:finish partno erro : can't find partition bootloader partno erro : can't find partition boot-resource [01.522]Get bootloader and boot-resource partition number fail! [01.530]Item0 (Map) magic is bad [01.533]out of usb burn from boot: not need burn key [01.559]update bootcmd [01.583]change working_fdt 0x41e8fe70 to 0x41e6fe70 [01.595]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND [01.604]update dts Hit any key to stop autoboot: 0 input addr exceed dram scope [03.035]no vendor_boot partition is found Android's image name: v851se-perf1 [03.098]Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.9.191 (tanlining@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #3 PREEMPT Fri Feb 17 11:57:27 UTC 2023 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt:Machine model: sun8iw21 [ 0.000000] disp reserve base 0x41f13000 ,size 0x384000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] On node 0 totalpages: 16384 [ 0.000000] free_area_init_node: node 0, pgdat c0a4ecc8, node_mem_map c3f78000 [ 0.000000] Normal zone: 128 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 16384 pages, LIFO batch:3 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 [ 0.000000] Kernel command line: ubi.mtd=sys earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=ubi0_4 rootfstype=ubifs, rw init=/pseudo_init partitions=mbr@ubi0_0:boot-res@ubi0_1:env@ubi0_2:boot@ubi0_3:rootfs@ubi0_4:rootfs_data@ubi0_5:UDISK@ubi0_6: cma= snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw21p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-ga697d75(07/28/2022-05:29:47) mbr_offset=1032192 disp_reserve=3686400,0x41f13000 bootreason=button aw-ubi-spinand.ubootblks=24 androidboot.dramsize=64 [ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes) [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Memory: 51112K/65536K available (6144K kernel code, 318K rwdata, 1368K rodata, 1024K init, 167K bss, 14424K reserved, 0K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB) [ 0.000000] lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB) [ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB) [ 0.000000] .data : 0xc0a00000 - 0xc0a4fb88 ( 319 kB) [ 0.000000] .bss : 0xc0a4fb88 - 0xc0a79948 ( 168 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] sunxi_parse_sdm_info failed: -1 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000023] Switching to timer-based delay loop, resolution 41ns [ 0.000203] Console: colour dummy device 80x30 [ 0.000235] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.000251] pid_max: default: 32768 minimum: 301 [ 0.000455] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000468] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001063] CPU: Testing write buffer coherency: ok [ 0.001697] Setting up static identity map for 0x40100000 - 0x40100058 [ 0.003443] devtmpfs: initialized [ 0.038833] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.039483] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.039519] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.039670] atomic64_test: passed [ 0.039685] pinctrl core: initialized pinctrl subsystem [ 0.040814] NET: Registered protocol family 16 [ 0.041591] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.043001] dump_class_init,857, success [ 0.069499] cpuidle: using governor menu [ 0.070860] platform 2010000.iommu: iova_base: 0x48400000 [ 0.071446] sunxi iommu: irq = 22 [ 0.093083] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver [ 0.096254] iommu: Adding device npu to group 0 [ 0.098404] iommu: Adding device 1c0e000.ve to group 0 [ 0.112094] iommu: Adding device 5410000.g2d to group 0 [ 0.113230] iommu: Adding device 5000000.disp to group 0 [ 0.125014] iommu: Adding device 5908000.tdm to group 0 [ 0.125772] iommu: Adding device 5900000.isp to group 0 [ 0.126820] iommu: Adding device 58ffffc.isp to group 0 [ 0.127800] iommu: Adding device 58ffff8.isp to group 0 [ 0.128560] iommu: Adding device 58ffff4.isp to group 0 [ 0.129203] iommu: Adding device 5800800.vind:isp@4 to group 0 [ 0.130660] iommu: Adding device 5910000.scaler to group 0 [ 0.131353] iommu: Adding device 590fffc.scaler to group 0 [ 0.131966] iommu: Adding device 590fff8.scaler to group 0 [ 0.132602] iommu: Adding device 590fff4.scaler to group 0 [ 0.133349] iommu: Adding device 5910400.scaler to group 0 [ 0.134022] iommu: Adding device 59103fc.scaler to group 0 [ 0.134665] iommu: Adding device 59103f8.scaler to group 0 [ 0.135352] iommu: Adding device 59103f4.scaler to group 0 [ 0.136265] iommu: Adding device 5910800.scaler to group 0 [ 0.136902] iommu: Adding device 59107fc.scaler to group 0 [ 0.137501] iommu: Adding device 59107f8.scaler to group 0 [ 0.138127] iommu: Adding device 59107f4.scaler to group 0 [ 0.138846] iommu: Adding device 5910c00.scaler to group 0 [ 0.139518] iommu: Adding device 5910bfc.scaler to group 0 [ 0.140419] iommu: Adding device 5910bf8.scaler to group 0 [ 0.141103] iommu: Adding device 5910bf4.scaler to group 0 [ 0.142506] iommu: Adding device vinc0 to group 0 [ 0.143429] iommu: Adding device vinc4 to group 0 [ 0.144330] iommu: Adding device vinc8 to group 0 [ 0.145241] iommu: Adding device vinc12 to group 0 [ 0.189219] pwm module init! [ 0.198012] sunxi-pm debug v3.10 [ 0.199817] SCSI subsystem initialized [ 0.201037] usbcore: registered new interface driver usbfs [ 0.201272] usbcore: registered new interface driver hub [ 0.201459] usbcore: registered new device driver usb [ 0.202023] sunxi_i2c_adap_init()2748 - init [ 0.202560] sunxi_i2c_probe()2443 - [i2c1] twi_drv_used = 0 [ 0.202579] sunxi_i2c_probe()2450 - [i2c1] twi_pkt_interval = 0 [ 0.202648] twi_regulator_request()647 - [i2c1] regulator not found(isn't configured in dts)! [ 0.202657] twi_request_gpio()463 - [i2c1] init name: (null) [ 0.204878] media: Linux media interface: v0.10 [ 0.205100] Linux video capture interface: v2.00 [ 0.206843] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000 [ 0.207254] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000 [ 0.209172] Advanced Linux Sound Architecture Driver Initialized. [ 0.210969] Bluetooth: Core ver 2.22 [ 0.211173] NET: Registered protocol family 31 [ 0.211186] Bluetooth: HCI device and connection manager initialized [ 0.211214] Bluetooth: HCI socket layer initialized [ 0.211229] Bluetooth: L2CAP socket layer initialized [ 0.211292] Bluetooth: SCO socket layer initialized [ 0.214227] clocksource: Switched to clocksource arch_sys_counter [ 0.247625] get androidboot.mode fail [ 0.250034] NET: Registered protocol family 2 [ 0.264618] TCP established hash table entries: 16 (order: -6, 64 bytes) [ 0.264640] TCP bind hash table entries: 16 (order: -6, 64 bytes) [ 0.264650] TCP: Hash tables configured (established 16 bind 16) [ 0.264727] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.264753] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.265000] NET: Registered protocol family 1 [ 0.265346] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC0 [ 0.265366] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC1 [ 0.265381] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC2 [ 0.265395] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC3 [ 0.265409] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC4 [ 0.265424] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC5 [ 0.265710] sunxi_spi_probe()2250 - [spi0] SPI DBI INTERFACE [ 0.265723] sunxi_spi_probe()2259 - [spi0] SPI MASTER MODE [ 0.265803] sunxi_spi_resource_get()1917 - sample_mode:1 sample_delay:12 [ 0.265827] spi0 supply spi not found, using dummy regulator [ 0.265921] sunxi_spi_request_gpio()1883 - [spi0] Pinctrl init spi0 [ 0.266015] sunxi_spi_clk_init()1954 - [spi0] mclk 100000000 [ 0.267243] sunxi_spi_probe()2339 - [spi0]: driver probe succeed, base c4868000, irq 294 [ 0.271741] sunxi_sid_driver_init+0x0/0x10 complete comp. [ 0.273077] workingset: timestamp_bits=29 max_order=14 bucket_order=0 [ 0.291491] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.292100] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 0.295217] io scheduler noop registered [ 0.295237] io scheduler deadline registered [ 0.295583] io scheduler cfq registered (default) [ 0.296922] [DISP]disp_module_init [ 0.298526] [DISP] parser_disp_init_para,line:1306: [ 0.298541] of_property_read disp_init.disp_init_enable fail [ 0.299095] lcd 0, driver_name , panel_name default_lcd [ 0.299111] lcd 0, driver_name , panel_name he0801a068 [ 0.299119] lcd 0, driver_name , panel_name inet_dsi_panel [ 0.299127] lcd 0, driver_name , panel_name lq101r1sx03 [ 0.299134] lcd 0, driver_name , panel_name WilliamLcd [ 0.299142] lcd 0, driver_name , panel_name bp101wx1 [ 0.299150] lcd 0, driver_name , panel_name k101im2qa04 [ 0.299157] lcd 0, driver_name , panel_name t050k589 [ 0.299165] lcd 0, driver_name , panel_name kd080d24 [ 0.299172] lcd 0, driver_name , panel_name super_lcd_driver [ 0.300570] [DISP]disp_module_init finish [ 0.303992] uart0 supply uart not found, using dummy regulator [ 0.305072] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI [ 0.305113] sw_console_setup()2050 - console setup baud 115200 parity n bits 8, flow n [ 1.413479] console [ttyS0] enabled [ 1.418461] misc dump reg init [ 1.423333] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1) [ 1.429927] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (-1) [ 1.436655] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator. [ 1.443992] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null)) [ 1.451450] sunxi-wlan soc@03000000:wlan@0: request pincrtl handle for device [soc@03000000:wlan@0] failed [ 1.462404] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=134 mul-sel=1 pull=1 drv_level=2 data=0 [ 1.473045] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed [ 1.480132] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=135 mul-sel=14 pull=1 drv_level=2 data=0 [ 1.491219] sunxi-wlan soc@03000000:wlan@0: clk_name () [ 1.498822] sunxi-spinand: AW SPINand MTD Layer Version: 2.4 20220106 [ 1.506567] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211125 [ 1.514532] sunxi-spinand-phy: detect munufacture from id table: Mxic [ 1.521773] sunxi-spinand-phy: detect spinand id: ffff12c2 ffffffff [ 1.528864] sunxi-spinand-phy: ========== arch info ========== [ 1.535541] sunxi-spinand-phy: Model: MX35LF1GE4AB [ 1.542290] sunxi-spinand-phy: Munufacture: Mxic [ 1.548292] sunxi-spinand-phy: DieCntPerChip: 1 [ 1.553965] sunxi-spinand-phy: BlkCntPerDie: 1024 [ 1.559957] sunxi-spinand-phy: PageCntPerBlk: 64 [ 1.565740] sunxi-spinand-phy: SectCntPerPage: 4 [ 1.571412] sunxi-spinand-phy: OobSizePerPage: 64 [ 1.577190] sunxi-spinand-phy: BadBlockFlag: 0x1 [ 1.583056] sunxi-spinand-phy: OperationOpt: 0x7 [ 1.588931] sunxi-spinand-phy: MaxEraseTimes: 65000 [ 1.595004] sunxi-spinand-phy: EccFlag: 0x2 [ 1.600869] sunxi-spinand-phy: EccType: 4 [ 1.606551] sunxi-spinand-phy: EccProtectedType: 3 [ 1.612222] sunxi-spinand-phy: ======================================== [ 1.619660] sunxi-spinand-phy: [ 1.623184] sunxi-spinand-phy: ========== physical info ========== [ 1.630134] sunxi-spinand-phy: TotalSize: 128 M [ 1.635522] sunxi-spinand-phy: SectorSize: 512 B [ 1.640901] sunxi-spinand-phy: PageSize: 2 K [ 1.646094] sunxi-spinand-phy: BlockSize: 128 K [ 1.651473] sunxi-spinand-phy: OOBSize: 64 B [ 1.656763] sunxi-spinand-phy: ======================================== [ 1.664192] sunxi-spinand-phy: [ 1.667725] sunxi-spinand-phy: ========== logical info ========== [ 1.674578] sunxi-spinand-phy: TotalSize: 128 M [ 1.679957] sunxi-spinand-phy: SectorSize: 512 B [ 1.685345] sunxi-spinand-phy: PageSize: 4 K [ 1.690529] sunxi-spinand-phy: BlockSize: 256 K [ 1.695916] sunxi-spinand-phy: OOBSize: 128 B [ 1.701294] sunxi-spinand-phy: ======================================== [ 1.708817] sunxi-spinand-phy: block lock register: 0x00 [ 1.714891] sunxi-spinand-phy: feature register: 0x11 [ 1.720568] sunxi-spinand-phy: sunxi physic nand init end [ 1.728866] sunxipart: failed to parse sunxi_gpt! [ 1.734176] Creating 4 MTD partitions on "sunxi_mtd_nand": [ 1.740433] 0x000000000000-0x000000100000 : "boot0" [ 1.749413] 0x000000100000-0x000000400000 : "uboot" [ 1.757153] random: fast init done [ 1.765135] 0x000000400000-0x000000500000 : "secure_storage" [ 1.775318] 0x000000500000-0x000008000000 : "sys" [ 1.996715] random: crng init done [ 2.082572] libphy: Fixed MDIO Bus: probed [ 2.088741] sunxi gmac driver's version: 2.0.2 [ 2.096309] Failed to alloc md5 [ 2.099857] eth0: Use random mac address [ 2.104817] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.112581] get ehci0-controller, regulator_io is no nocare [ 2.119246] get ehci0-controller wakeup-source is fail. [ 2.125405] sunxi ehci0-controller don't init wakeup source [ 2.131679] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a6eeb0, 0x:c4879000, irq_no:130 [ 2.143930] [sunxi-ehci0]: Not init ehci0 [ 2.148974] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.156567] get ohci0-controller, regulator_io is no nocare [ 2.162833] get ohci0-controller wakeup-source is fail. [ 2.168978] sunxi ohci0-controller don't init wakeup source [ 2.175421] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a6f0d4 [ 2.185185] [sunxi-ohci0]: Not init ohci0 [ 2.190361] usbcore: registered new interface driver uas [ 2.196850] usbcore: registered new interface driver usb-storage [ 2.203901] usbcore: registered new interface driver ums-alauda [ 2.210825] usbcore: registered new interface driver ums-cypress [ 2.217923] usbcore: registered new interface driver ums-datafab [ 2.225102] usbcore: registered new interface driver ums_eneub6250 [ 2.232336] usbcore: registered new interface driver ums-freecom [ 2.239366] usbcore: registered new interface driver ums-isd200 [ 2.246387] usbcore: registered new interface driver ums-jumpshot [ 2.253543] usbcore: registered new interface driver ums-karma [ 2.260436] usbcore: registered new interface driver ums-onetouch [ 2.267722] usbcore: registered new interface driver ums-realtek [ 2.274834] usbcore: registered new interface driver ums-sddr09 [ 2.281784] usbcore: registered new interface driver ums-sddr55 [ 2.288714] usbcore: registered new interface driver ums-usbat [ 2.295578] usb_serial_number:20080411 [ 2.300730] sunxi_gpadc_init,1949, success [ 2.306221] sunxi_gpadc_setup: get channel scan data failed [ 2.313764] input: sunxi-gpadc0 as /devices/virtual/input/input0 [ 2.323210] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0 [ 2.330486] sunxi-rtc rtc: RTC enabled [ 2.334925] fix to cold boot, save boot reason [ 2.340332] i2c /dev entries driver [ 2.345084] sunxi cedar version 0.1 [ 2.349162] VE: install start!!! [ 2.349162] [ 2.354891] VE: cedar-ve the get irq is 291 [ 2.359702] VE: regs_csi = c48a3000 [ 2.364392] VE: get debugfs_mpp_root is NULL, please check mpp [ 2.364392] [ 2.372618] VE: sunxi ve debug register driver failed, maybe ok, please check [ 2.372618] [ 2.382554] VE: ve_proc_mgr: flag = 1 [ 2.382554] [ 2.388439] VE: install end!!! [ 2.388439] [ 2.394010] google_vp9: sunxi google vp9 version 0.1 [ 2.403109] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 2.412863] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903 [ 2.420423] Bluetooth: HCI UART protocol H4 registered [ 2.426340] Bluetooth: HCI H4 protocol initialized [ 2.431977] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07 [ 2.439849] bt_fdi debugfs_init [ 2.448003] cpuidle: enable-method property 'psci' found operations [ 2.457969] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40) [ 2.467505] sunxi-mmc sdc0: ***ctl-spec-caps*** 8 [ 2.472848] sunxi-mmc sdc0: No vmmc regulator found [ 2.478467] sunxi-mmc sdc0: No vqmmc regulator found [ 2.484048] sunxi-mmc sdc0: No vdmmc regulator found [ 2.489677] sunxi-mmc sdc0: No vd33sw regulator found [ 2.495441] sunxi-mmc sdc0: No vd18sw regulator found [ 2.501118] sunxi-mmc sdc0: No vq33sw regulator found [ 2.506830] sunxi-mmc sdc0: No vq18sw regulator found [ 2.513042] sunxi-mmc sdc0: set host busy [ 2.517742] sunxi-mmc sdc0: Got CD GPIO [ 2.522577] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.533089] sunxi-mmc sdc0: no vqmmc,Check if there is regulator [ 2.564257] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.604502] sunxi-mmc sdc0: detmode:gpio irq [ 2.609591] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3 [ 2.619044] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3 [ 2.628452] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3 [ 2.637856] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3 [ 2.647258] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3 [ 2.656672] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3 [ 2.666341] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40) [ 2.675346] sunxi-mmc sdc1: ***ctl-spec-caps*** 8 [ 2.680680] sunxi-mmc sdc1: No vmmc regulator found [ 2.686198] sunxi-mmc sdc1: No vqmmc regulator found [ 2.691777] sunxi-mmc sdc1: No vdmmc regulator found [ 2.697368] sunxi-mmc sdc1: No vd33sw regulator found [ 2.703043] sunxi-mmc sdc1: No vd18sw regulator found [ 2.708729] sunxi-mmc sdc1: No vq33sw regulator found [ 2.714416] sunxi-mmc sdc1: No vq18sw regulator found [ 2.720667] sunxi-mmc sdc1: set host busy [ 2.725309] mmc:failed to get gpios [ 2.729670] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.740167] sunxi-mmc sdc1: no vqmmc,Check if there is regulator [ 2.774257] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.814293] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 2.824605] sunxi-mmc sdc1: detmode:manually by software [ 2.826238] usbcore: registered new interface driver usbhid [ 2.826242] usbhid: USB HID core driver [ 2.830324] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid [ 2.832449] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec <-> soc@03000000:codec_plat mapping ok [ 2.835565] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai <-> 2032000.daudio0_plat mapping ok [ 2.851758] NET: Registered protocol family 10 [ 2.854072] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.855767] NET: Registered protocol family 17 [ 2.855809] NET: Registered protocol family 15 [ 2.856149] Bluetooth: RFCOMM TTY layer initialized [ 2.856171] Bluetooth: RFCOMM socket layer initialized [ 2.856200] Bluetooth: RFCOMM ver 1.11 [ 2.857545] Registering SWP/SWPB emulation handler [ 2.945898] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !! [ 2.952546] ubi0: attaching mtd3 [ 2.956258] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !! [ 2.956322] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.964618] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 2.976528] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 2.987381] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 2.993305] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 2.999208] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 2.999239] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 3.000326] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.000400] sunxi-mmc sdc1: no vqmmc,Check if there is regulator [ 3.032769] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.055390] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !! [ 3.062477] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !! [ 3.068518] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.082955] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.096979] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.103958] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.110985] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.117992] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.123908] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 3.135952] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.146912] sunxi-mmc sdc1: no vqmmc,Check if there is regulator [ 3.174274] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.215876] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !! [ 3.223496] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !! [ 3.229526] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.244146] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.258530] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.266079] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.273595] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.281135] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.287066] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 3.298988] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.310183] sunxi-mmc sdc1: no vqmmc,Check if there is regulator [ 3.344266] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.387486] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !! [ 3.396701] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !! [ 3.402724] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.417968] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 3.433910] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.443067] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.452224] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.461407] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !! [ 3.467361] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 3.536495] ubi0: scanning is finished [ 3.551714] ubi0: attached mtd3 (name "sys", size 123 MiB) [ 3.558002] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [ 3.565775] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048 [ 3.573404] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 3.581372] ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0 [ 3.588171] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128 [ 3.596336] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0 [ 3.605751] ubi0: available PEBs: 10, total reserved PEBs: 482, PEBs reserved for bad PEB handling: 10 [ 3.616234] ubi0: background thread "ubi_bgt0d" started, PID 693 [ 3.623562] get det_vbus is fail, 84 [ 3.627794] get id is fail, 84 [ 3.632325] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:07 UTC (7) [ 3.641602] clk: Not disabling unused clocks [ 3.646529] ALSA device list: [ 3.649863] #0: audiocodec [ 3.653110] #1: snddaudio0 [ 3.660272] List of all partitions: [ 3.664574] 1f00 1024 mtdblock0 (driver?) [ 3.670267] 1f01 3072 mtdblock1 (driver?) [ 3.676025] 1f02 1024 mtdblock2 (driver?) [ 3.681705] 1f03 125952 mtdblock3 (driver?) [ 3.687531] No filesystem could mount root, tried: ubifs [ 3.693611] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) [ 3.702903] CPU: 0 PID: 1 Comm: swapper Not tainted 4.9.191 #3 [ 3.709451] Hardware name: sun8iw21 [ 3.713401] [<c010d3cc>] (unwind_backtrace) from [<c010a51c>] (show_stack+0x10/0x14) [ 3.722112] [<c010a51c>] (show_stack) from [<c016ff58>] (panic+0xac/0x2b0) [ 3.729846] [<c016ff58>] (panic) from [<c0901270>] (mount_block_root+0x208/0x2f4) [ 3.738260] [<c0901270>] (mount_block_root) from [<c0901450>] (prepare_namespace+0x84/0x178) [ 3.747747] [<c0901450>] (prepare_namespace) from [<c0900e80>] (kernel_init_freeable+0x11c/0x178) [ 3.757724] [<c0900e80>] (kernel_init_freeable) from [<c0649f90>] (kernel_init+0x8/0x108) [ 3.766921] [<c0649f90>] (kernel_init) from [<c0106ca8>] (ret_from_fork+0x14/0x2c) [ 3.775432] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) [ 3.785593] sunxi dump enabled [ 3.789017] dump regs done [ 3.792091] flush cache done [ 3.795341] crashdump enter哪位大神知道是什么问题,帮忙指点迷津,谢谢。
[ 1.612222] sunxi-spinand-phy: ======================================== [ 1.619660] sunxi-spinand-phy: [ 1.623184] sunxi-spinand-phy: ========== physical info ========== [ 1.630134] sunxi-spinand-phy: TotalSize: 128 M [ 1.635522] sunxi-spinand-phy: SectorSize: 512 B [ 1.640901] sunxi-spinand-phy: PageSize: 2 K [ 1.646094] sunxi-spinand-phy: BlockSize: 128 K [ 1.651473] sunxi-spinand-phy: OOBSize: 64 B [ 1.656763] sunxi-spinand-phy: ======================================== [ 1.664192] sunxi-spinand-phy: [ 1.667725] sunxi-spinand-phy: ========== logical info ========== [ 1.674578] sunxi-spinand-phy: TotalSize: 128 M [ 1.679957] sunxi-spinand-phy: SectorSize: 512 B [ 1.685345] sunxi-spinand-phy: PageSize: 4 K [ 1.690529] sunxi-spinand-phy: BlockSize: 256 K [ 1.695916] sunxi-spinand-phy: OOBSize: 128 B [ 1.701294] sunxi-spinand-phy: ======================================== [ 1.708817] sunxi-spinand-phy: block lock register: 0x00 [ 1.714891] sunxi-spinand-phy: feature register: 0x11 [ 1.720568] sunxi-spinand-phy: sunxi physic nand init end [ 1.728866] sunxipart: failed to parse sunxi_gpt! [ 1.734176] Creating 4 MTD partitions on "sunxi_mtd_nand": [ 1.740433] 0x000000000000-0x000000100000 : "boot0" [ 1.749413] 0x000000100000-0x000000400000 : "uboot" [ 1.757153] random: fast init done [ 1.765135] 0x000000400000-0x000000500000 : "secure_storage" [ 1.775318] 0x000000500000-0x000008000000 : "sys"nand 识别到了,但是没有ubifs的配置层
[ 3.660272] List of all partitions: [ 3.664574] 1f00 1024 mtdblock0 (driver?) [ 3.670267] 1f01 3072 mtdblock1 (driver?) [ 3.676025] 1f02 1024 mtdblock2 (driver?) [ 3.681705] 1f03 125952 mtdblock3 (driver?) [ 3.687531] No filesystem could mount root, tried: ubifs -
# CONFIG_LOCALVERSION_AUTO is not set CONFIG_SYSVIPC=y # CONFIG_FHANDLE is not set CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y CONFIG_BSD_PROCESS_ACCT=y CONFIG_BSD_PROCESS_ACCT_V3=y CONFIG_LOG_BUF_SHIFT=14 CONFIG_CC_OPTIMIZE_FOR_SIZE=y # CONFIG_SYSFS_SYSCALL is not set # CONFIG_AIO is not set CONFIG_EMBEDDED=y # CONFIG_SLUB_DEBUG is not set # CONFIG_COMPAT_BRK is not set CONFIG_JUMP_LABEL=y CONFIG_CC_STACKPROTECTOR_REGULAR=y CONFIG_MODULES=y CONFIG_MODULE_UNLOAD=y # CONFIG_BLK_DEV_BSG is not set CONFIG_ARCH_SUNXI=y CONFIG_ARCH_SUN8IW21=y CONFIG_EVB_PLATFORM=y CONFIG_SUNXI_SOC_NAME="sun8iw21" CONFIG_SWP_EMULATE=y # CONFIG_VDSO is not set CONFIG_ARM_PSCI=y CONFIG_PREEMPT=y CONFIG_AEABI=y CONFIG_OABI_COMPAT=y CONFIG_HIGHMEM=y # CONFIG_COMPACTION is not set CONFIG_CMA=y CONFIG_ARM_FLUSH_CONSOLE_ON_RESTART=y CONFIG_USE_OF=y # CONFIG_ATAGS is not set CONFIG_CMDLINE="earlyprintk=sunxi-uart,0x05000000 loglevel=8 initcall_debug=1 console=ttyS0 init=/init" CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_GOV_POWERSAVE=y CONFIG_CPU_FREQ_GOV_USERSPACE=y CONFIG_CPU_FREQ_GOV_ONDEMAND=y CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y CONFIG_CPU_FREQ_GOV_INTERACTIVE=y CONFIG_CPUFREQ_DT=y CONFIG_ARM_ALLWINNER_SUN50I_CPUFREQ_NVMEM=y CONFIG_CPU_IDLE=y CONFIG_ARM_CPUIDLE=y CONFIG_SUNXI_CPU0IDLE=y CONFIG_VFP=y CONFIG_NEON=y # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set CONFIG_PM_WAKELOCKS=y CONFIG_PM_DEBUG=y CONFIG_PM_ADVANCED_DEBUG=y CONFIG_NET=y CONFIG_PACKET=y CONFIG_PACKET_DIAG=y CONFIG_UNIX=y CONFIG_UNIX_DIAG=y CONFIG_NET_KEY=y CONFIG_INET=y CONFIG_IP_MULTICAST=y CONFIG_IP_ADVANCED_ROUTER=y CONFIG_IP_PING=y CONFIG_IP_FIB_TRIE_STATS=y CONFIG_IP_MULTIPLE_TABLES=y CONFIG_IP_ROUTE_MULTIPATH=y CONFIG_IP_ROUTE_VERBOSE=y CONFIG_IP_MROUTE=y CONFIG_IP_MROUTE_MULTIPLE_TABLES=y CONFIG_IPV6_MULTIPLE_TABLES=y CONFIG_IPV6_SUBTREES=y CONFIG_IPV6_MROUTE=y CONFIG_BT=y CONFIG_BT_RFCOMM=y CONFIG_BT_RFCOMM_TTY=y # CONFIG_BT_HS is not set # CONFIG_BT_LE is not set CONFIG_XR_BT_LPM=y CONFIG_XR_BT_FDI=y CONFIG_BT_HCIUART=y CONFIG_BT_HCIUART_H4=y CONFIG_HFP_OVER_PCM=y CONFIG_CFG80211=y CONFIG_RFKILL=y CONFIG_RFKILL_GPIO=y CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug" CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_SUNXI_MBUS=y CONFIG_MTD=y CONFIG_MTD_BLOCK=y CONFIG_MTD_CFI=y CONFIG_MTD_CFI_INTELEXT=y CONFIG_MTD_CFI_AMDSTD=y CONFIG_MTD_COMPLEX_MAPPINGS=y CONFIG_MTD_PHYSMAP_OF=y CONFIG_MTD_NAND_IDS=y CONFIG_AW_MTD_SPINAND=y CONFIG_MTD_UBI_BLOCK=y CONFIG_SUNXI_RFKILL=y CONFIG_SCSI=y CONFIG_BLK_DEV_SD=y CONFIG_NETDEVICES=y CONFIG_SUNXI_GMAC=y CONFIG_NET_VENDOR_AURORA=y # CONFIG_USB_NET_DRIVERS is not set # CONFIG_WLAN_VENDOR_ADMTEK is not set # CONFIG_WLAN_VENDOR_ATH is not set # CONFIG_WLAN_VENDOR_ATMEL is not set # CONFIG_WLAN_VENDOR_BROADCOM is not set # CONFIG_WLAN_VENDOR_CISCO is not set # CONFIG_WLAN_VENDOR_INTEL is not set # CONFIG_WLAN_VENDOR_INTERSIL is not set # CONFIG_WLAN_VENDOR_MARVELL is not set # CONFIG_WLAN_VENDOR_MEDIATEK is not set # CONFIG_WLAN_VENDOR_RALINK is not set # CONFIG_WLAN_VENDOR_REALTEK is not set # CONFIG_WLAN_VENDOR_RSI is not set # CONFIG_WLAN_VENDOR_ST is not set # CONFIG_WLAN_VENDOR_TI is not set # CONFIG_WLAN_VENDOR_ZYDAS is not set CONFIG_XR829_WLAN=m CONFIG_ISDN=y # CONFIG_INPUT_MOUSEDEV is not set CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_SENSORINIT is not set # CONFIG_INPUT_KEYBOARD is not set # CONFIG_INPUT_MOUSE is not set CONFIG_INPUT_TOUCHSCREEN=y # CONFIG_TOUCHSCREEN_PROPERTIES is not set CONFIG_TOUCHSCREEN_FT6236=y # CONFIG_TOUCHSCREEN_GT82X is not set # CONFIG_TOUCHSCREEN_IT7257_TS is not set # CONFIG_TOUCHSCREEN_GSLX680NEW is not set # CONFIG_TOUCHSCREEN_FT5X16_TS is not set # CONFIG_TOUCHSCREEN_GT9XX_TS is not set # CONFIG_TOUCHSCREEN_TLSC6X_TS is not set CONFIG_INPUT_MISC=y CONFIG_SUNXI_WIEGAND=y CONFIG_INPUT_SENSOR=y # CONFIG_SENSORS_BMA250 is not set # CONFIG_SENSORS_SC7A30 is not set # CONFIG_SENSORS_MMA7660 is not set # CONFIG_SENSORS_MIR3DA is not set # CONFIG_SENSORS_MXC622X is not set # CONFIG_SENSORS_MMA8452 is not set # CONFIG_SENSORS_MMA865X is not set # CONFIG_SENSORS_MC32X0 is not set CONFIG_SENSORS_GPADC=y CONFIG_KEY_GPIO=y # CONFIG_SENSORS_DA380 is not set # CONFIG_SERIO is not set # CONFIG_LEGACY_PTYS is not set # CONFIG_DEVMEM is not set # CONFIG_DEVKMEM is not set # CONFIG_HW_RANDOM is not set # CONFIG_SUNXI_SYS_INFO is not set CONFIG_SUNXI_G2D=y CONFIG_SUNXI_G2D_MIXER=y CONFIG_SUNXI_G2D_ROTATE=y CONFIG_SUNXI_NNA_VIP=y CONFIG_I2C=y CONFIG_I2C_CHARDEV=y CONFIG_I2C_SUNXI=y CONFIG_SPI=y CONFIG_SPI_SUNXI=y CONFIG_GPIOLIB=y CONFIG_GPIO_SYSFS=y CONFIG_POWER_SUPPLY=y CONFIG_AXP2101_POWER=y CONFIG_THERMAL=y CONFIG_THERMAL_GOV_USER_SPACE=y CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y CONFIG_CPU_THERMAL=y CONFIG_THERMAL_EMULATION=y CONFIG_SUNXI_THERMAL_NG=y CONFIG_WATCHDOG=y CONFIG_SUNXI_WATCHDOG=y CONFIG_MFD_AXP2101_I2C=y CONFIG_MFD_SYSCON=y CONFIG_REGULATOR=y CONFIG_REGULATOR_FIXED_VOLTAGE=y CONFIG_REGULATOR_VIRTUAL_CONSUMER=y CONFIG_REGULATOR_AXP2101=y CONFIG_MEDIA_SUPPORT=y CONFIG_MEDIA_CAMERA_SUPPORT=y CONFIG_MEDIA_CONTROLLER=y CONFIG_VIDEO_V4L2_SUBDEV_API=y CONFIG_V4L_PLATFORM_DRIVERS=y CONFIG_VIDEO_SUNXI_VIN=m # CONFIG_CSI_CCI is not set CONFIG_VIN_IOMMU=y CONFIG_D3D=y CONFIG_D3D_COMPRESS_EN=y # CONFIG_WDR is not set CONFIG_SENSOR_GC2053_MIPI=m # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set CONFIG_FB=y CONFIG_DISP2_SUNXI=y CONFIG_SUNXI_DISP2_FB_HW_ROTATION_SUPPORT=y CONFIG_DISP2_SUNXI_DEBUG=y CONFIG_LCD_SUPPORT_D310T9362V1_MIPI=y # CONFIG_LCD_SUPPORT_HE0801A068 is not set # CONFIG_LCD_SUPPORT_WILLIAMLCD is not set # CONFIG_LCD_SUPPORT_LQ101R1SX03 is not set # CONFIG_LCD_SUPPORT_INET_DSI_PANEL is not set # CONFIG_LCD_SUPPORT_BP101WX1_206 is not set # CONFIG_LCD_SUPPORT_K101IM2QA04 is not set # CONFIG_LCD_SUPPORT_T050K589 is not set # CONFIG_LCD_SUPPORT_KD080D24 is not set CONFIG_SOUND=y CONFIG_SND=y CONFIG_SND_SOC=y CONFIG_SND_SOC_SUNXI_AAUDIO=y CONFIG_SND_SOC_SUNXI_DAUDIO=y CONFIG_SND_SOC_SUNXI_COMPONENTS=y CONFIG_SND_SOC_SUNXI_RXSYNC=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_SUNXI_HCD=y CONFIG_USB_SUNXI_HCI=y CONFIG_USB_SUNXI_EHCI0=y CONFIG_USB_SUNXI_EHCI1=y CONFIG_USB_SUNXI_OHCI0=y CONFIG_USB_SUNXI_OHCI1=y CONFIG_USB_STORAGE=y CONFIG_USB_STORAGE_REALTEK=y CONFIG_USB_STORAGE_DATAFAB=y CONFIG_USB_STORAGE_FREECOM=y CONFIG_USB_STORAGE_ISD200=y CONFIG_USB_STORAGE_USBAT=y CONFIG_USB_STORAGE_SDDR09=y CONFIG_USB_STORAGE_SDDR55=y CONFIG_USB_STORAGE_JUMPSHOT=y CONFIG_USB_STORAGE_ALAUDA=y CONFIG_USB_STORAGE_ONETOUCH=y CONFIG_USB_STORAGE_KARMA=y CONFIG_USB_STORAGE_CYPRESS_ATACB=y CONFIG_USB_STORAGE_ENE_UB6250=y CONFIG_USB_UAS=y CONFIG_USB_GADGET=y CONFIG_USB_SUNXI_UDC0=y CONFIG_USB_CONFIGFS=y CONFIG_USB_CONFIGFS_MASS_STORAGE=y CONFIG_USB_CONFIGFS_F_FS=y CONFIG_USB_CONFIGFS_UEVENT=y CONFIG_USB_CONFIGFS_F_HID=y CONFIG_USB_SUNXI_USB=y CONFIG_USB_SUNXI_USB_MANAGER=y CONFIG_USB_SUNXI_USB_DEBUG=y CONFIG_USB_SUNXI_USB_ADB=y CONFIG_MMC=y CONFIG_MMC_SUNXI=y CONFIG_RTC_CLASS=y CONFIG_RTC_DRV_SUNXI=y CONFIG_SUNXI_BOOTUP_EXTEND=y CONFIG_SUNXI_RTC_BOOTCOUNT=y CONFIG_DMADEVICES=y CONFIG_DMA_SUNXI=y CONFIG_STAGING=y CONFIG_ION=y CONFIG_ION_SUNXI=y # CONFIG_COMMON_CLK_DEBUG is not set # CONFIG_ARM_ARCH_TIMER_EVTSTREAM is not set CONFIG_MAILBOX=y CONFIG_SUNXI_MBOX=y CONFIG_SUNXI_RV32_STANBY=y CONFIG_SUNXI_IOMMU=y CONFIG_SUNXI_RPROC=y CONFIG_SUNXI_MSGBOX=y CONFIG_SUNXI_RPMSG_E907=y CONFIG_SUNXI_RPMSG_SPEEDTEST=y CONFIG_SUNXI_RPMSG_HEARBEAT=y CONFIG_RPMSG_CTRL=y CONFIG_RPMSG_NOTIFY=y CONFIG_RPMSG_VIRTIO=y CONFIG_PWM=y CONFIG_PWM_SUNXI_GROUP=y CONFIG_ANDROID=y CONFIG_NVMEM=y CONFIG_NVMEM_SUN50I_SID=y CONFIG_SUNXI_MPP=y CONFIG_EXT4_FS=y # CONFIG_FILE_LOCKING is not set # CONFIG_DNOTIFY is not set # CONFIG_INOTIFY_USER is not set CONFIG_OVERLAY_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_UTF8=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_JFFS2_FS=y CONFIG_JFFS2_SUMMARY=y CONFIG_JFFS2_FS_XATTR=y # CONFIG_JFFS2_FS_POSIX_ACL is not set # CONFIG_JFFS2_FS_SECURITY is not set CONFIG_JFFS2_COMPRESSION_OPTIONS=y # CONFIG_JFFS2_ZLIB is not set CONFIG_UBIFS_FS=y CONFIG_SQUASHFS=y CONFIG_SQUASHFS_LZ4=y CONFIG_SQUASHFS_LZO=y CONFIG_SQUASHFS_XZ=y CONFIG_SQUASHFS_ZSTD=y # CONFIG_NETWORK_FILESYSTEMS is not set CONFIG_NLS_CODEPAGE_437=y CONFIG_NLS_ISO8859_1=y CONFIG_PRINTK_TIME=y CONFIG_FRAME_WARN=2048 CONFIG_DEBUG_FS=y CONFIG_DEBUG_VM=y # CONFIG_SCHED_DEBUG is not set CONFIG_DEBUG_MUTEXES=y CONFIG_STACKTRACE=y # CONFIG_FTRACE is not set CONFIG_ATOMIC64_SELFTEST=y CONFIG_SUNXI_DUMP=y -
@whycanservice
麻烦帮忙看下哪里配错了或者漏配了谢谢!!!! -
@tanlining 直接拿我的config替换吧
@whycanservice 好的 我试一下
@tanlining 兄弟,这个问题你是怎么解决的呀,求助
