T113-S3 Tina 5.0 系统 一直卡在 uboot LOGO 界面
[81]HELLO! BOOT0 is starting! [83]BOOT0 commit : 84b1541181 [86]set pll start [88]fix vccio detect value:0xc0 [95]periph0 has been enabled [98]set pll end [99][pmu]: bus read error [102]board init ok [104]enable_jtag [105]ZQ value = 0x30 [107]get_pmu_exist() = -1 [110]DRAM BOOT DRIVE INFO: V0.33 [113]DRAM CLK = 792 MHz [115]DRAM Type = 3 (2:DDR2,3:DDR3) [118]DRAMC read ODT off. [120]DRAM ODT value: 0x42. [123]ddr_efuse_type: 0xa [126]DRAM SIZE =128 M [128]dram_tpr4:0x0 [130]PLL_DDR_CTRL_REG:0xf8004100 [133]DRAM_CLK_REG:0xc0000000 [136][TIMING DEBUG] MR2= 0x18 [144]DRAM simple test OK. [146]rtc standby flag is 0x0, super standby flag is 0x0 [151]dram size =128 [154]card no is 2 [155]sdcard 2 line count 4 [158][mmc]: mmc driver ver 2021-05-21 14:47 [167][mmc]: Wrong media type 0x0, but host sdc2, try mmc first [173][mmc]: ***Try MMC card 2*** [197][mmc]: RMCA OK! [199][mmc]: mmc 2 bias 0 [202][mmc]: MMC 5.1 [204][mmc]: HSSDR52/SDR25 4 bit [207][mmc]: 50000000 Hz [209][mmc]: 3728 MB [211][mmc]: ***SD/MMC 2 init OK!!!*** [302]Loading boot-pkg Succeed(index=0). [305]Entry_name = u-boot [312]Entry_name = optee [316]Entry_name = dtb [319]tunning data addr:0x430003e8 [322]Jump to second Boot. M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm U-Boot 2018.07-g895f570-dirty (May 11 2023 - 11:34:42 +0800) Allwinner Technology [00.374]CPU: Allwinner Family [00.377]Model: sun8iw20 [00.379]DRAM: 128 MiB [00.383]Relocation Offset is: 04ec9000 [00.409]secure enable bit: 0 E/TC:0 fdt_getprop_u32:343 prop trace_level not found [00.422]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz [00.428]gic: sec monitor mode sunxi flash map init [00.434]flash init start [00.436]workmode = 0,storage type = 2 [00.439][mmc]: mmc driver ver uboot2018:2022-12-07 18:56:00 [00.446][mmc]: SUNXI SDMMC Controller Version:0x50310 [00.471][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4 [00.477]sunxi flash init ok [00.480]line:703 init_clocks [00.483]drv_disp_init [00.488]handle_num : 6 [00.494]drv_disp_init finish [00.499]Loading Environment from SUNXI_FLASH... OK [00.513]boot_gui_init:start [00.515]set disp.dev2_output_type fail. using defval=0 [00.592]set disp.fb0_rot_used fail. using defval=0 [00.596]set disp.fb0_rot_degree fail. using defval=0 [00.614]boot_gui_init:finish partno erro : can't find partition bootloader [00.621]bmp_name=bootlogo.bmp size 38454 [00.634]Item0 (Map) magic is bad [00.637]the secure storage item0 copy0 magic is bad [00.645]Item0 (Map) magic is bad [00.648]the secure storage item0 copy1 magic is bad [00.653]Item0 (Map) magic is bad [00.656]usb burn from boot delay time 0 weak:otg_phy_config [00.667]usb prepare ok [00.672]LCD open finish [00.970]overtime [00.973]do_burn_from_boot usb : no usb exist List file under ULI/factory ** Unrecognized filesystem type ** root_partition is rootfs set root to /dev/mmcblk0p5 [00.988]update part info [00.990]update bootcmd [00.994]change working_fdt 0x44888e70 to 0x44868e70 [00.999][mmc]: no mmc-hs400-1_8v! [01.002][mmc]: delete mmc-hs200-1_8v from dtb [01.006][mmc]: get max-frequency ok 50000000 Hz disable nand error: FDT_ERR_BADPATH [01.031]update dts Hit any key to stop autoboot: 0 [01.240]no vendor_boot partition is found Android's image name: sun8i_arm ERROR: reserving fdt memory region failed (addr=41900000 size=200000) ERROR: reserving fdt memory region failed (addr=41c00000 size=400000) ERROR: reserving fdt memory region failed (addr=41b00000 size=100000) ERROR: reserving fdt memory region failed (addr=44913000 size=7e9000) [01.278]Starting kernel ... [01.281][mmc]: mmc exit start [01.300][mmc]: mmc 2 exit ok [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.4.61 (yuanzf@yuanzf-PC) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Thu May 11 09:57:03 CST 2023 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: sun8iw20 [ 0.000000] printk: bootconsole [earlycon0] enabled [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 4 MiB at 0x47c00000 [ 0.000000] On node 0 totalpages: 32768 [ 0.000000] Normal zone: 256 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 32768 pages, LIFO batch:7 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 15 pages/cpu s30912 r8192 d22336 u61440 [ 0.000000] pcpu-alloc: s30912 r8192 d22336 u61440 alloc=15*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512 [ 0.000000] Kernel command line: earlyprintk= clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:UDISK@mmcblk0p7 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.07-g895f570-dirty(05/11/2023-11:34:42) disp_reserve=8294400,0x44913000 androidboot.dramsize=128 [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear) [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 98288K/131072K available (7168K kernel code, 418K rwdata, 2508K rodata, 1024K init, 171K bss, 28688K reserved, 4096K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] random: get_random_bytes called from start_kernel+0x24c/0x3cc with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.008026] Switching to timer-based delay loop, resolution 41ns [ 0.014211] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.023958] Console: colour dummy device 80x30 [ 0.028429] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.038792] pid_max: default: 32768 minimum: 301 [ 0.043565] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.050886] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.059247] CPU: Testing write buffer coherency: ok [ 0.064517] /cpus/cpu@0 missing clock-frequency property [ 0.069853] /cpus/cpu@1 missing clock-frequency property [ 0.075225] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.081498] Setting up static identity map for 0x40100000 - 0x40100060 [ 0.088184] rcu: Hierarchical SRCU implementation. [ 0.093309] BOOTEVENT: 93.299874: ON [ 0.097708] smp: Bringing up secondary CPUs ... [ 0.103542] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.103694] smp: Brought up 1 node, 2 CPUs [ 0.113513] SMP: Total of 2 processors activated (96.00 BogoMIPS). [ 0.119693] CPU: All CPU(s) started in SVC mode. [ 0.124852] devtmpfs: initialized [ 0.141845] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.150070] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.159972] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.167110] pinctrl core: initialized pinctrl subsystem [ 0.173765] NET: Registered protocol family 16 [ 0.180067] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.223577] rtc_ccu: sunxi ccu init OK [ 0.230028] ccu: sunxi ccu init OK [ 0.234076] r_ccu: sunxi ccu init OK [ 0.281610] sun6i-dma 3002000.dma-controller: sunxi dma probed [ 0.290211] iommu: Default domain type: Translated [ 0.295357] sunxi iommu: irq = 24 [ 0.299923] SCSI subsystem initialized [ 0.304093] usbcore: registered new interface driver usbfs [ 0.309719] usbcore: registered new interface driver hub [ 0.315172] usbcore: registered new device driver usb [ 0.320506] mc: Linux media interface: v0.10 [ 0.324884] videodev: Linux video capture interface: v2.00 [ 0.331504] Advanced Linux Sound Architecture Driver Initialized. [ 0.338336] Bluetooth: Core ver 2.22 [ 0.342055] NET: Registered protocol family 31 [ 0.346531] Bluetooth: HCI device and connection manager initialized [ 0.353019] Bluetooth: HCI socket layer initialized [ 0.357905] Bluetooth: L2CAP socket layer initialized [ 0.363001] Bluetooth: SCO socket layer initialized [ 0.368166] pwm module init! [ 0.372629] g2d 5410000.g2d: Adding to iommu group 0 [ 0.378098] G2D: rcq version initialized.major:250 [ 0.383628] input: sunxi-keyboard as /devices/virtual/input/input0 [ 0.391303] clocksource: Switched to clocksource arch_sys_counter [ 0.406728] sun8iw20-pinctrl pio: initialized sunXi PIO driver [ 0.426796] thermal_sys: Registered thermal governor 'step_wise' [ 0.426804] thermal_sys: Registered thermal governor 'user_space' [ 0.433437] NET: Registered protocol family 2 [ 0.444702] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 0.453133] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.460796] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear) [ 0.467930] TCP: Hash tables configured (established 1024 bind 1024) [ 0.474443] UDP hash table entries: 256 (order: 1, 8192 bytes, linear) [ 0.480989] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear) [ 0.488198] NET: Registered protocol family 1 [ 0.495130] Initialise system trusted keyrings [ 0.499762] workingset: timestamp_bits=30 max_order=15 bucket_order=0 [ 0.517060] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.523244] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.527930] fuse: init (API version 7.31) [ 0.562883] NET: Registered protocol family 38 [ 0.567338] Key type asymmetric registered [ 0.571510] Asymmetric key parser 'x509' registered [ 0.576505] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 0.583920] io scheduler mq-deadline registered [ 0.588463] io scheduler kyber registered [ 0.592570] atomic64_test: passed [ 0.597422] [DISP]disp_module_init [ 0.601474] disp 5000000.disp: Adding to iommu group 0 [ 0.607277] [DISP] disp_init,line:2331: [ 0.607282] smooth display screen:0 type:1 mode:4 [ 0.632367] display_fb_request,fb_id:0 [ 0.657339] disp_al_manager_apply ouput_type:1 [ 0.662002] [DISP]disp_module_init finish [ 0.662057] [DISP] lcd_clk_config,line:777: [ 0.662070] disp 0, clk: pll(888000000),clk(888000000),dclk(148000000) dsi_rate(148000000) [ 0.662070] clk real:pll(888000000),clk(888000000),dclk(222000000) dsi_rate(150000000) [ 0.667652] sunxi_sid_init()783 - insmod ok [ 0.692020] pwm-regulator: supplied by regulator-dummy [ 0.698759] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator [ 0.707191] uart uart3: uart3 supply uart not found, using dummy regulator [ 0.714485] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI [ 0.722452] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n 0.730426] printk: console [ttyS3] enabled [ 0.730426] printk: console [ttyS3] enabled [ 0.739357] printk: bootconsole [earlycon0] disabled [ 0.739357] printk: bootconsole [earlycon0] disabled [ 0.751023] misc dump reg init [ 0.755059] deinterlace 5400000.deinterlace: Adding to iommu group 0 [ 0.762727] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110 [ 0.772413] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9 [ 0.776249] Freeing logo buffer memory: 8100K [ 0.779656] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed [ 0.791942] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed [ 0.799338] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1) [ 0.805893] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power. [ 0.812839] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1) [ 0.820544] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=111 assert=1 [ 0.828493] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator [ 0.837390] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1 [ 0.845501] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled [ 0.853179] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power. [ 0.859929] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1) [ 0.867461] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=110 assert=0 [ 0.876876] libphy: Fixed MDIO Bus: probed [ 0.881481] CAN device driver interface [ 0.886352] usbcore: registered new interface driver asix [ 0.892566] usbcore: registered new interface driver ax88179_178a [ 0.899429] usbcore: registered new interface driver cdc_ether [ 0.906059] usbcore: registered new interface driver net1080 [ 0.912489] usbcore: registered new interface driver cdc_subset [ 0.919155] usbcore: registered new interface driver zaurus [ 0.925523] usbcore: registered new interface driver cdc_ncm [ 0.931874] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.939173] sunxi-ehci: EHCI SUNXI driver [ 0.944070] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.950991] sunxi-ohci: OHCI SUNXI driver [ 0.956142] usbcore: registered new interface driver uas [ 0.962203] usbcore: registered new interface driver usb-storage [ 0.968964] usbcore: registered new interface driver ums-alauda [ 0.975680] usbcore: registered new interface driver ums-cypress [ 0.982475] usbcore: registered new interface driver ums-datafab [ 0.989272] usbcore: registered new interface driver ums_eneub6250 [ 0.996248] usbcore: registered new interface driver ums-freecom [ 1.003031] usbcore: registered new interface driver ums-isd200 [ 1.009713] usbcore: registered new interface driver ums-jumpshot [ 1.016583] usbcore: registered new interface driver ums-karma [ 1.023182] usbcore: registered new interface driver ums-onetouch [ 1.030053] usbcore: registered new interface driver ums-realtek [ 1.036830] usbcore: registered new interface driver ums-sddr09 [ 1.043525] usbcore: registered new interface driver ums-sddr55 [ 1.050202] usbcore: registered new interface driver ums-usbat [ 1.056911] usbcore: registered new interface driver option [ 1.063207] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.071986] sunxi_gpadc_init,2151, success [ 1.076871] sunxi_gpadc_setup: get channel scan data failed [ 1.083408] input: sunxi-gpadc0 as /devices/virtual/input/input1 [ 1.091173] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1 [ 1.102477] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate! [ 1.113272] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate! [ 1.124525] sunxi-rtc 7090000.rtc: registered as rtc0 [ 1.130213] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate! [ 1.140852] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:02 UTC (2) [ 1.149744] sunxi-rtc 7090000.rtc: sunxi rtc probed [ 1.155713] i2c /dev entries driver [ 1.159834] IR NEC protocol handler initialized [ 1.164968] IR RC5(x/sz) protocol handler initialized [ 1.171009] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator [ 1.180007] sunxi-rc-recv 7040000.s_cir: sunxi_irrx_resource_get: get ir protocol failed [ 1.189199] Registered IR keymap rc_map_sunxi [ 1.194251] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0 [ 1.202945] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx [ 1.215169] usbcore: registered new interface driver uvcvideo [ 1.221645] USB Video Class driver (1.1.1) [ 1.226245] gspca_main: v2.14.0 registered [ 1.230815] sunxi cedar version 1.1 [ 1.234948] sunxi-cedar 1c0e000.ve: Adding to iommu group 0 [ 1.241246] VE: sunxi_cedar_probe power-domain init!!! [ 1.247006] VE: install start!!! [ 1.247006] [ 1.252574] VE: cedar-ve the get irq is 40 [ 1.252574] [ 1.259072] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval) [ 1.259072] [ 1.268330] VE: install end!!! [ 1.268330] [ 1.273419] VE: sunxi_cedar_probe [ 1.278497] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 1.287659] Bluetooth: HCI UART driver ver 2.3 [ 1.292681] Bluetooth: HCI UART protocol H4 registered [ 1.300522] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator [ 1.309487] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40) [ 1.319358] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308 [ 1.325769] sunxi-mmc 4022000.sdmmc: No vmmc regulator found [ 1.332108] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found [ 1.338523] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found [ 1.344958] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found [ 1.351478] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found [ 1.357996] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found [ 1.364523] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found [ 1.371060] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed [ 1.380662] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.404456] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.428650] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable) [ 1.435812] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.448714] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40) [ 1.458612] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8 [ 1.459649] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.464826] sunxi-mmc 4020000.sdmmc: No vmmc regulator found [ 1.477735] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.482745] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found [ 1.500735] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found [ 1.507175] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found [ 1.513721] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found [ 1.520236] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found [ 1.526774] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.526851] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.538379] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found [ 1.556961] sunxi-mmc 4020000.sdmmc: Got CD GPIO [ 1.562182] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.571730] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.584959] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator [ 1.598597] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.605112] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.633431] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01) [ 1.634226] random: fast init done [ 1.643192] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01) [ 1.647033] sunxi-mmc 4020000.sdmmc: detmode:gpio polling [ 1.656683] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01) [ 1.663297] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40) [ 1.672752] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01) [ 1.682175] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 1.692136] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8 [ 1.709107] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B [ 1.709200] sunxi-mmc 4021000.sdmmc: No vmmc regulator found [ 1.727046] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B [ 1.738827] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found [ 1.738836] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B [ 1.757122] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-DDR52 dt B [ 1.761321] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found [ 1.774935] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found [ 1.781489] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found [ 1.788013] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found [ 1.794571] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found [ 1.794581] mmc0: new DDR MMC card at address 0001 [ 1.801129] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed [ 1.807810] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB [ 1.820715] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.831920] mmcblk0rpmb: mmc0:0001 4FTE4R partition 3 512 KiB, chardev (243:0) [ 1.832147] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator [ 1.848942] mmcblk0: p1 p2 p3 p4 p5 p6 p7 [ 1.860322] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.884640] sunxi-mmc 4021000.sdmmc: detmode:manually by software [ 1.892345] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !! [ 1.899467] usbcore: registered new interface driver usbhid [ 1.905724] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !! [ 1.912644] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.921332] usbhid: USB HID core driver [ 1.927355] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.928477] exFAT: Version 1.3.0 [ 1.942133] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !! [ 1.944180] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ... [ 1.951316] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !! [ 1.958010] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok... [ 1.965293] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !! [ 1.972025] rpmsg_tty_init: Sunxi rpmsg tty driver will init [ 1.979528] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !! [ 1.984869] rpmsg_tty_init: Sunxi rpmsg tty driver init ok [ 1.991624] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 2.000726] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1 [ 2.000726] [ 2.025854] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0 [ 2.026383] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished [ 2.046140] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present! [ 2.055932] [SNDCODEC][sunxi_card_init][583]:card init finished [ 2.063140] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok [ 2.074245] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input3 [ 2.086364] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished [ 2.095233] NET: Registered protocol family 10 [ 2.101205] Segment Routing with IPv6 [ 2.105361] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch [ 2.111422] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.121208] NET: Registered protocol family 17 [ 2.126494] NET: Registered protocol family 15 [ 2.131568] can: controller area network core (rev 20170425 abi 9) [ 2.138569] NET: Registered protocol family 29 [ 2.143571] can: raw protocol (rev 20170425) [ 2.148342] can: broadcast manager protocol (rev 20170425 t) [ 2.154683] can: netlink gateway (rev 20190810) max_hops=1 [ 2.161358] Bluetooth: RFCOMM TTY layer initialized [ 2.166826] Bluetooth: RFCOMM socket layer initialized [ 2.172647] Bluetooth: RFCOMM ver 1.11 [ 2.177601] Registering SWP/SWPB emulation handler [ 2.183413] Loading compiled-in X.509 certificates [ 2.207233] sunxi-i2c 2502c00.twi: 2502c00.twi supply twi not found, using dummy regulator [ 2.217349] sunxi-i2c 2502c00.twi: probe success [ 2.223916] sunxi-thermal 2009400.ths: sun8iw20 cp version:15 [ 2.234217] platform 2000c13.pwm3: pinctrl_get failed [ 2.239921] platform 2000c13.pwm3: pinctrl_get failed [ 2.245639] cpu cpu0: _set_opp_voltage: failed to set voltage (950000 950000 950000 mV): -19 [ 2.255125] platform 2000c13.pwm3: pinctrl_get failed [ 2.260811] platform 2000c13.pwm3: pinctrl_get failed [ 2.266476] cpu cpu0: _set_opp_voltage: failed to set voltage (950000 950000 950000 mV): -19 [ 2.275929] cpufreq: __target_index: Failed to change cpu frequency: -19 [ 2.285027] get drvvbus-en is fail, 22 [ 2.289228] get ehci0-controller wakeup-source is fail. [ 2.295243] sunxi ehci0-controller don't init wakeup source [ 2.301506] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c894b8, 0x:c88cd000, irq_no:36 [ 2.313475] [sunxi-ehci0]: Not init ehci0 [ 2.318436] get drvvbus-en is fail, 22 [ 2.322655] get ohci0-controller wakeup-source is fail. [ 2.328624] sunxi ohci0-controller don't init wakeup source [ 2.334889] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c89768 [ 2.344525] [sunxi-ohci0]: Not init ohci0 [ 2.349463] get drvvbus-en is fail, 22 [ 2.353681] get ehci1-controller wakeup-source is fail. [ 2.359637] sunxi ehci1-controller don't init wakeup source [ 2.365887] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c89a18, 0x:c88e9000, irq_no:38 [ 2.378166] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator [ 2.390755] platform 2000c13.pwm3: pinctrl_get failed [ 2.396523] platform 2000c13.pwm3: pinctrl_get failed [ 2.402223] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller [ 2.409468] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1 [ 2.419121] cpu cpu0: _set_opp_voltage: failed to set voltage (950000 950000 950000 mV): -19 [ 2.428634] platform 2000c13.pwm3: pinctrl_get failed [ 2.434375] platform 2000c13.pwm3: pinctrl_get failed [ 2.440018] cpu cpu0: _set_opp_voltage: failed to set voltage (950000 950000 950000 mV): -19 [ 2.449565] cpufreq: __target_index: Failed to change cpu frequency: -19 [ 2.457306] sunxi-ehci 4200000.ehci1-controller: irq 56, io mem 0x04200000 [ 2.491324] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00 [ 2.499110] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect [ 2.508727] hub 1-0:1.0: USB hub found [ 2.513020] hub 1-0:1.0: 1 port detected [ 2.518434] get drvvbus-en is fail, 22 [ 2.522668] get ohci1-controller wakeup-source is fail. [ 2.528655] sunxi ohci1-controller don't init wakeup source [ 2.534933] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c89cc8 [ 2.544840] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator [ 2.557173] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller [ 2.564455] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2 [ 2.574382] sunxi-ohci 4200400.ohci1-controller: irq 57, io mem 0x04200400 [ 2.656286] hub 2-0:1.0: USB hub found [ 2.660575] hub 2-0:1.0: 1 port detected [ 2.667319] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator [ 2.678928] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator [ 2.691789] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 2.703296] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 2.710767] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 2.711421] clk: Not disabling unused clocks [ 2.720444] cfg80211: failed to load regulatory.db [ 2.725182] ALSA device list: [ 2.733852] #0: audiocodec [ 2.737074] alloc_fd: slot 0 not NULL! [ 2.745879] VFS: Mounted root (squashfs filesystem) readonly on device 179:5. [ 2.755987] Freeing unused kernel memory: 1024K [ 2.801568] Kernel init done [ 2.804793] Run /init as init process [ 2.891404] usb 1-1: new high-speed USB device number 2 using sunxi-ehci [ 3.094569] hub 1-1:1.0: USB hub found [ 3.099239] hub 1-1:1.0: 4 ports detected [ 3.505135] init: Console is alive [ 3.509201] init: - watchdog - [ 3.513505] init: - preinit - [ 3.762819] kmodloader: loading kernel modules from /etc/modules-boot.d/* [ 3.771100] kmodloader: done loading kernel modules from /etc/modules-boot.d/* [ 4.137805] random: jshn: uninitialized urandom read (4 bytes read) [ 4.162608] random: jshn: uninitialized urandom read (4 bytes read) /dev/by-name/UDISK already format by ext4 [ 4.523306] mount_root: loading kmods from internal overlay [ 4.539308] kmodloader: loading kernel modules from //etc/modules-boot.d/* [ 4.547161] kmodloader: done loading kernel modules from //etc/modules-boot.d/* [ 4.596035] block: attempting to load /etc/config/fstab e2fsck 1.45.6 (20-Mar-2020) /dev/by-name/UDISK: clean, 35/228928 files, 34356/914660 blocks [ 4.967301] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: [ 4.967768] random: procd: uninitialized urandom read (4 bytes read) [ 4.984615] block: extroot: UUID mismatch (root: eef28811-39e41115-4ad4edcc-f7d79513, overlay: 0d3ca24a-ca5093d3-1ae52b9c-25239031) [ 5.003680] mount_root: unable to create loop device [ 5.010593] mount_root: no usable overlay filesystem found, using tmpfs overlay [ 6.240784] procd: - early - [ 6.241380] [ 6.241380] insmod_device_driver [ 6.241380] [ 6.244281] procd: - watchdog - [ 6.251222] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator [ 6.471088] procd: - watchdog - [ 6.502329] procd: - ubus - [ 6.581736] random: ubusd: uninitialized urandom read (4 bytes read) [ 6.591866] random: ubusd: uninitialized urandom read (4 bytes read) [ 6.599474] random: ubusd: uninitialized urandom read (4 bytes read) [ 6.609493] procd: - init - Please press Enter to activate this console. [ 6.990466] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate! [ 7.506993] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 7.617092] kmodloader: loading kernel modules from /etc/modules.d/* [ 7.784071] ======== XRADIO WIFI OPEN ======== [ 7.792960] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31 [ 7.799746] [XRADIO] Allocated hw_priv @ (ptrval) [ 7.838006] [ADDR_MGT] get_addr_by_name: t->addr: [ 7.891453] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1 [ 7.919721] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success [ 8.219636] file system registered [ 8.407880] configfs-gadget 4100000.udc-controller: failed to start g1: -19 [ 8.753783] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 8.770477] [XRADIO] Detect SDIO card 1 [ 8.782672] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator [ 8.809423] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 8.867745] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 8.903628] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 8.943014] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B [ 8.972969] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B [ 9.017331] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B [ 9.043645] mmc2: new high speed SDIO card at address 0001 [ 9.063486] read descriptors [ 9.066779] read strings [ 9.095370] [SBUS] XRadio Device:sdio clk=50000000 [ 9.111877] [XRADIO] XRADIO_HW_REV 1.0 detected. [ 9.352001] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x01400000. [ 9.459433] [XRADIO] Bootloader complete [ 9.564703] [XRADIO] Firmware completed. [ 9.571664] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09 [ 9.589272] [XRADIO] Firmware Startup Done. [ 9.594421] [XRADIO_WRN] enable Multi-Rx! [ 9.602812] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 9.618779] kmodloader: done loading kernel modules from /etc/modules.d/* kmodloader done [ 10.529710] random: crng init done [ 10.533523] random: 4 urandom warning(s) missed due to ratelimiting [ 11.178245] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=dc:44:6d:7e:7b:8f [ 11.186515] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=dc:44:6d:7e:7b:8f [ 11.202944] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined. Trying to connect to SWUpdate... -
默认屏幕是bootlog,卡在软件升级了
@whycanservice 没有在升级,已经升级完了,现在我基本把所有外设都关闭了,还是进不去系统
@swain 考虑是否是终端tty绑定错误,可以试试adb能不能用
