求问 V851se h264压缩异常 cedarc <H264EncOpenVer2:5775>: error: the driver do not support the ic 23010
root@TinaLinux:/tmp# encodertest ******************************************************************************* please enter following instructoins! encodertest argv[1] argv[2] argv[3] argv[4] argv[5] argv[6] argv[7] argv[8] argv[9] argv[1]: encode format---0:H264 1:JPEG argv[2]: input format---YV12 YU12 NV12 NV21 YUV420 YUYV argv[3]: input data width argv[4]: input data height argv[5]: output data width argv[6]: output data height argv[7]: encode frame number argv[8]: input data path argv[9]: out data path ******************************************************************************* for instance : encodertest 0 NV21 640 480 1280 720 10 /tmp/source_data.yuv /tmp ******************************************************************************* root@TinaLinux:/tmp# encodertest 0 YUV420 640 360 640 360 10 /tmp/aaa.yuv /tmp INFO : cedarc <VeInitialize:13[ 912.627574] VE: before freq=300000000 07>: *** ic_version = 0x13020000[ 912.634746] VE: real freq=300000000 23010, INFO : cedarc <VeInitialize:1307>: *** ic_version = 0x1302000023010, ERROR : cedarc <H264EncOpenVer2:5775>: error: the driver do not support the ic 23010 create encoder failed root@TinaLinux:/tmp# [308]HELLO! BOOT0 is starting!
@jaying 你要打上补丁包,链接就是tinyvision那个github那个,1.3的压缩包,解压到你的sdk根目录。
@heqiliao 亲 能发我一个么?我没在git上找到 感谢感谢
@heqiliao 是参考mpp_libcedarc这个么?我试下 感谢
