t113-s3使用phoenixUSBPro烧录出现错误
软件debug信息:
00001141 14:07:13 [162592] [0227 14:07:13.0143|127608|E(0)|.\SDKClkdef.cpp|00219|OnBurnError]错误:(356)
00001142 14:07:13 [162592] [0227 14:07:13.0145|127608|INFO|.\ProProcMan.cpp|03671|ProProcMan::OnToolsThreadMesage]MSG Callback Code: 0x20
00001143 14:07:13 [162592] [0227 14:07:13.0145|127608|INFO|.\ProProcMan.cpp|03682|ProProcMan::OnToolsThreadMesage]free param...
00001144 14:07:13 [162592] Closing image now!
00001145 14:07:13 [162592] CloseImage OK
00001146 14:07:13 [162592] unknown Tools command(96)
00001147 14:07:13 [162592]
00001148 14:07:13 [162592] INFO: ID=4, update failed
00001149 14:07:13 [162592]
00001150 14:07:13 [162592] [0227 14:07:13.0146|127608|E(0)|.\SDKClkdef.cpp|00219|OnBurnError]错误:(356)
00001151 14:07:13 [162592] [0227 14:07:13.0147|127608|INFO|.\ProProcMan.cpp|03671|ProProcMan::OnToolsThreadMesage]MSG Callback Code: 0x20
串口信息:
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
force mbrdevice nand0 <nand>, # parts = 4
#: name size offset mask_flags
0: boot0 0x00100000 0x00000000 1
1: uboot 0x00300000 0x00100000 1
2: secure_storage 0x00100000 0x00400000 1
3: sys 0x07b00000 0x00500000 0active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000
defaults:
mtdids : nand0=nand
mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
[08.064]MTD info (4)
[08.065]pagesize: 0x1000
[08.068]blksize: 0x40000
[08.070]num offset bytes name
[08.074]0 0x00000000 0x00100000 boot0
[08.077]1 0x00100000 0x00300000 uboot
[08.081]2 0x00400000 0x00100000 secure_storage
[08.085]3 0x00500000 0x07b00000 sys
[08.089]MBR info (unalign):
[08.091]partno addr sects type name
[08.096]0 0x00000000 0x00008000 0x00000001 mbr
[08.101]1 0x00008000 0x0000103a 0x00008000 boot-resource
[08.106]2 0x0000903a 0x00000800 0x00008000 env
[08.111]3 0x0000983a 0x00000800 0x00008000 env-redund
[08.117]4 0x0000a03a 0x00008e54 0x00008000 boot
[08.121]5 0x00012e8e 0x0001e000 0x00008000 rootfs
[08.127]6 0x00030e8e 0x00000800 0x00008000 dsp0
[08.131]7 0x0003168e 0x00002800 0x00008100 private
[08.136]8 0x00033e8e 0x00000000 0x00008100 UDISK
[08.141]ubi attach the last part of mtd device: NO.3
[08.146]MBR info (align):
[08.148]partno addr sects type name
[08.153]0 0x00002800 0x000081f0 0x00000001 mbr
[08.158]1 0x0000a9f0 0x000011b8 0x00008000 boot-resource
[08.164]2 0x0000bba8 0x000009d8 0x00008000 env
[08.168]3 0x0000c580 0x000009d8 0x00008000 env-redund
[08.174]4 0x0000cf58 0x00008fb8 0x00008000 boot
[08.179]5 0x00015f10 0x0001e060 0x00008000 rootfs
[08.184]6 0x00033f70 0x000009d8 0x00008000 dsp0
[08.189]7 0x00034948 0x00002958 0x00008100 private
[08.194]8 0x000372a0 0x00000000 0x00008100 UDISK
[08.199]ubi attach the last part of mtd device: NO.3
[08.203]ubi attatch mtd, name: sys[08.207]ubi0: detaching mtd4
[08.209]ubi0: mtd4 is detached
[08.212]ubi0: attaching mtd4
[08.326]ubi0: scanning is finished
[08.329]ubi0: empty MTD device detected
[08.354]ubi0: attached mtd4 (name "sys", size 123 MiB)
[08.359]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[08.365]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[08.371]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[08.378]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[08.383]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
[08.390]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
[08.397]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
Creating static volume mbr of size 17031168
Creating dynamic volume boot-resource of size 2322432
Creating dynamic volume env of size 1290240
Creating dynamic volume env-redund of size 1290240
Creating dynamic volume boot of size 18837504
Creating dynamic volume rootfs of size 62963712
Creating dynamic volume dsp0 of size 1290240
Creating dynamic volume private of size 5419008
No size specified -> Using max size (10321920)
[10.409]reset last volume size to 0x4ec0
Creating dynamic volume UDISK of size 10321920
[10.460]fill gap start: volume mbr sects 0x7f80
[15.001]fill gap end: volume mbr
[15.004]update partition map
[15.007]logical area info: 468 258048 last_lba: 235871
[15.019]logical area info: 468 258048 last_lba: 235871
[15.031]logical area info: 468 258048 last_lba: 235871
[15.043]logical area info: 468 258048 last_lba: 235871
[15.055]logical area info: 468 258048 last_lba: 235871
[15.067]logical area info: 468 258048 last_lba: 235871
[15.079]logical area info: 468 258048 last_lba: 235871
[15.091]logical area info: 468 258048 last_lba: 235871
[15.104]logical area info: 468 258048 last_lba: 235871
[15.116]logical area info: 468 258048 last_lba: 235871
[15.128]logical area info: 468 258048 last_lba: 235871
[15.140]logical area info: 468 258048 last_lba: 235871
[15.152]logical area info: 468 258048 last_lba: 235871
[15.164]logical area info: 468 258048 last_lba: 235871
[15.176]logical area info: 468 258048 last_lba: 235871
[15.188]logical area info: 468 258048 last_lba: 235871
[15.200]logical area info: 468 258048 last_lba: 235871
[15.212]logical area info: 468 258048 last_lba: 235871
[15.224]logical area info: 468 258048 last_lba: 235871
[15.237]logical area info: 468 258048 last_lba: 235871
[15.249]logical area info: 468 258048 last_lba: 235871
[15.261]logical area info: 468 258048 last_lba: 235871
[15.273]logical area info: 468 258048 last_lba: 235871
[15.285]logical area info: 468 258048 last_lba: 235871
[15.297]logical area info: 468 258048 last_lba: 235871
[15.309]logical area info: 468 258048 last_lba: 235871
[15.321]logical area info: 468 258048 last_lba: 235871
[15.333]logical area info: 468 258048 last_lba: 235871
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
[15.734]fill gap start: volume boot-resource sects 0x548
[15.831]fill gap end: volume boot-resource
FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x15e400
FEX_CMD_fes_verify_value 0xdaa11b1f
[16.033]fill gap start: volume env sects 0x700
[16.130]fill gap end: volume env
FEX_CMD_fes_verify_value, start 0x903a, size high 0x0:low 0x20000
FEX_CMD_fes_verify_value 0x75b20d79
[16.186]fill gap start: volume env-redund sects 0x700
[16.283]fill gap end: volume env-redund
FEX_CMD_fes_verify_value, start 0x983a, size high 0x0:low 0x20000
[21.623]fill gap start: volume boot sects 0xb0
[21.718]fill gap end: volume boot
FEX_CMD_fes_verify_value, start 0xa03a, size high 0x0:low 0x11b4800
FEX_CMD_fes_verify_value 0xd67f4928
[35.034]fill gap start: volume rootfs sects 0xa500
[35.207]fill gap end: volume rootfs
FEX_CMD_fes_verify_value, start 0x12e8e, size high 0x0:low 0x2760000
FEX_CMD_fes_verify_value 0x3a266f10
[39.763]fill gap start: volume dsp0 sects 0x601
[39.861]fill gap end: volume dsp0
FEX_CMD_fes_verify_value, start 0x30e8e, size high 0x0:low 0x3fc78
FEX_CMD_fes_verify_value 0xb80b7e41
