T113 TINA使用Nor Flash报错
T113使用TINA,想切换成Nor Flash。
修改 BoardConfig.mk
LICHEE_BRANDY_DEFCONF:=sun8iw20p1_nor_defconfig
按手册上进行修改,能烧进去系统。
启动时uboot报错,屏幕上已显示启动画面。
T113的配置只有SD卡的,求一个Spi NorFlash的配置U-Boot 2018.05 (Apr 02 2022 - 06:28:13 +0000) Allwinner Technology ....... 54 bytes read in 0 ms [00.289]bmp_name=bootlogo.bmp size 38454 38454 bytes read in 7 ms (5.2 MiB/s) [00.308]Loading Environment from SUNXI_FLASH... *** Warning - bad CRC, using default environment *** Warning - no device, using default environment Failed (-5) [00.344]update part info [00.347]update bootcmd [00.349]change working_fdt 0x46b19e70 to 0x46af9e70 disable nand error: FDT_ERR_NOTFOUND [00.372]update dts Hit any key to stop autoboot: 2 FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL sunxi_pwm_pin_set_state, fdt_set_all_pin, ret=-1 [00.468]LCD open finish 0 ## Error: "distro_bootcmd" not defined
停在这个画面 -
pri显示的结果为:
baudrate=115200
bootcmd=run distro_bootcmd
bootdelay=2
fdtcontroladdr=46b19e70
force_normal_boot=1
partitions=boot-resource@mtdblock1:env@mtdblock2:env-redund@mtdblock3:boot@mtdblock4:rootfs@mtdblock5:UDISK@mtdblock6Environment size: 230/131068 bytes
baudrate=115200
bootdelay=2
force_normal_boot=1
@zhangheyang 你用的哪个工具烧录的,我刚开始研究,换个SPI NOR FLASH
