F1C500 跑 tina 挂了, 请问这是什么问题?
[0]HELLO! BOOT0 is starting! [2]boot0 commit : 80628dcde5dc4ecdc757a9e782c58d7cf1abf959 [60]dram size =32 [62]Reg pull reg_val=0x00000000,read=0x00000010 [66]Succeed in reading toc file head. [69]The size of toc is 00054000. [127]Reg pull reg_val=0x00000000,read=0x00000010 [136]Ready to disable icache. [138]Jump to secend Boot. U-Boot 2014.07 (Jul 05 2022 - 11:58:37) Allwinner Technology uboot commit : f1592db8c49aaedd6895f7e0f90caa123f0a3d5a i2c_init: by cpux [I2C-DEBUG]:i2c_set_clock() 354 [I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed. i2c_init ok [0.187]pmbus: ready axp: get node[/soc/pmu0] error axp_probe error [0.193]PMU: cpux 408 Mhz,AXI=408 Mhz PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz key value = 4294967295, fel_key = [256,426] DRAM: 32 MiB Relocation Offset is: 01580000 axp: get node[/soc/pmu0] error int sunxi_dma_init--- irq enable workmode = 0,storage type = 3 [0.260]spinor: 0 flash size =0x4000 sectors sunxi spinor is initing...int sunxi_dma_init--- irq enable sunxi_dma_install_int ok sunxi_dma_install_int ok OK spinor id:0x1840ef spi_freq = 40000000 [0.278]sunxi flash init ok spinor read: start 0x3e0, sector 0x20 used mbr [0], count = 8 spinor read: start 0x800, sector 0x200 env size is 256 env partition is too small! can't enabled backup env functions logo addr = 0x81f00000 spinor read: start 0x400, sector 0x400 sunxi_read_bootlogo: read bootlogo partition successful do not find fastboot status flag --------fastboot partitions-------- -total partitions:8- -name- -start- -size- bootlogo : 4000 80000 env : 84000 20000 boot : a4000 280000 rootfs : 324000 340000 rootfs_data : 664000 80000 misc : 6e4000 10000 private : 6f4000 10000 UDISK : 704000 0 ----------------------------------- spinor read: start 0x3b00, sector 0x4 disable nand error: FDT_ERR_BADPATH disable nand error: FDT_ERR_BADPATH ## error: update_fdt_dram_para : FDT_ERR_NOTFOUND PowerBus = 0( 2:vBus 3:acBus other: not exist) no battery exist sunxi_bmp_logo_display Hit any key to stop autoboot: 0 spinor read: start 0x900, sector 0x40 spinor read: start 0x940, sector 0x1376 ## Booting kernel from Legacy Image at 80007fc0 ... Image Name: ARM OpenWrt Linux-3.10.65 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2583056 Bytes = 2.5 MiB Load Address: 80008000 Entry Point: 80008000 XIP Kernel Image ... OK reserving fdt memory region: addr=81000000 size=10000 Using Device Tree in place at 81000000, end 8100f25f Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.65 (yixiuge@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #241 Wed Jul 6 02:28:57 UTC 2022 [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 [ 0.000000] CPU: VIVT data cache, VIVT instruction cache [ 0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1 [ 0.000000] bootconsole [earlycon0] enabled [ 0.000000] cma: CMA: failed to reserve 32 MiB [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] On node 0 totalpages: 8192 [ 0.000000] free_area_init_node: node 0, pgdat c0542acc, node_mem_map c0570000 [ 0.000000] Normal zone: 64 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 8192 pages, LIFO batch:0 [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 [ 0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25400 initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/mtdblock4 init=/pseudo_init rdinit=/rdinit partitions=bootlogo@mtdblock1:env@mtdblock2:boot@mtdblock3:rootfs@mtdblock4:rootfs_data@mtdblock5:misc@mtdblock6:private@mtdblock7:UDISK@mtdblock8 cma=32M fb_base=0x81f00000 androidboot.serialno=<NULL> boot_type=3 [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Memory: 32MB = 32MB total [ 0.000000] Memory: 26764k/26764k available, 6004k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xc2800000 - 0xff000000 ( 968 MB) [ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .text : 0xc0008000 - 0xc043ff84 (4320 kB) [ 0.000000] .init : 0xc0440000 - 0xc045df74 ( 120 kB) [ 0.000000] .data : 0xc045e000 - 0xc05433e8 ( 917 kB) [ 0.000000] .bss : 0xc05433e8 - 0xc056fbe0 ( 178 kB) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS:256 [ 0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000] [ 0.000000] pll_cpu-set_default_rate=552000000 success! [ 0.000000] pll_video-set_default_rate=297000000 success! [ 0.000000] pll_ddr-set_default_rate=312000000 success! [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.005324] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256) [ 0.075248] pid_max: default: 32768 minimum: 301 [ 0.080428] Mount-cache hash table entries: 512 [ 0.086418] CPU: Testing write buffer coherency: ok [ 0.092210] Setting up static identity map for 0xc0340870 - 0xc03408c8 [ 0.101460] devtmpfs: initialized [ 0.106951] pinctrl core: initialized pinctrl subsystem [ 0.112813] NET: Registered protocol family 16 [ 0.117979] DMA: failed to allocate 256 KiB pool for atomic coherent allocation [ 0.126039] dump_class_init,844, success [ 0.135071] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver [ 0.158846] bio: create slab <bio-0> at 0 [ 0.164281] pwm module init! [ 0.169086] SCSI subsystem initialized [ 0.173379] usbcore: registered new interface driver usbfs [ 0.179158] usbcore: registered new interface driver hub [ 0.185033] usbcore: registered new device driver usb [ 0.196223] Linux video capture interface: v2.00 [ 0.201551] Advanced Linux Sound Architecture Driver Initialized. [ 0.209725] cfg80211: Calling CRDA to update world regulatory domain [ 0.217223] Switching to clocksource sun3i high-res couter [ 0.242461] get det_vbus is fail, 84 [ 0.247922] NET: Registered protocol family 2 [ 0.254586] TCP established hash table entries: 512 (order: 0, 4096 bytes) [ 0.261700] TCP bind hash table entries: 512 (order: -1, 2048 bytes) [ 0.268362] TCP: Hash tables configured (established 512 bind 512) [ 0.274916] TCP: reno registered [ 0.278314] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.284426] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.291488] NET: Registered protocol family 1 [ 0.309535] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.316196] jffs2: version 2.2. © 2001-2006 Red Hat, Inc. [ 0.322636] msgmni has been set to 52 [ 0.329752] io scheduler noop registered [ 0.334046] io scheduler cfq registered (default) [ 0.338922] [pm]aw_pm_init! [ 0.342196] [pm]valid [ 0.344684] [pm]valid [ 0.347410] [DISP]disp_module_init [ 0.353777] /soc/lcd0@01c0c000: could not find phandle [ 0.413103] pll_freq=297000000HZ, lcd_dclk_freq=33000000HZ, clk_div=9 [ 0.420517] num_screens=1 [ 0.423395] screen_id=0 [ 0.425974] para->mclk[MOD_CLK_LCD1CH0]=0xc180c300 [ 0.430924] para->mclk[MOD_CLK_LCD1CH1]=0xc180c400 [ 0.435925] disp tv init [ 0.438595] tcon_clk=0xc180c300, tcon_clk_parent=0x0 [ 0.443767] tcon_clk=0xc180c300, tcon_clk_parent=0xc18043c0 [ 0.449516] tve_clk=0xc180c400, tve_clk_parent=0xc18043c0 [ 0.455115] disp al tv init [ 0.460785] fetch script datadisp.screen2_output_type fail [ 0.466877] fetch script datadisp.screen2_output_mode fail [ 0.475252] fetch script datadisp.fb2_format fail [ 0.480440] fetch script datadisp.fb2_scaler_mode_enable fail [ 0.486748] fetch script datadisp.fb2_width fail [ 0.491838] fetch script datadisp.fb2_height fail [ 0.496800] disp_malloc fail, size=0x2ee000 [ 0.501139] disp_malloc fail! [ 0.504611] Unable to handle kernel paging request at virtual address 0005dfc0 [ 0.512052] pgd = c0004000 [ 0.515013] [0005dfc0] *pgd=00000000 [ 0.518761] Internal error: Oops: 805 [#1] ARM [ 0.523361] Modules linked in: [ 0.526571] CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.65 #241 [ 0.532764] task: c1832000 ti: c1834000 task.ti: c1834000 [ 0.538356] PC is at memcpy+0x244/0x330 [ 0.542343] LR is at 0xadc8ff9e [ 0.545632] pc : [<c0125564>] lr : [<adc8ff9e>] psr: 20000013 [ 0.545632] sp : c1835c40 ip : ff9eaec8 fp : c1835d7c [ 0.557455] r10: 000000ef r9 : ff9dacc8 r8 : ff99a8c7 [ 0.562851] r7 : ff97a6c6 r6 : ff96a5c7 r5 : ff94a2c4 r4 : ff93a2c4 [ 0.569566] r3 : ff9ca7c2 r2 : 00000460 r1 : c2854b58 r0 : 0005dfc0 [ 0.576284] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 0.583792] Control: 0005317f Table: 80004000 DAC: 00000017 [ 0.589711] [ 0.589711] PC: 0xc01254e4: [ 0.594224] 54e4 cafffff9 e2411003 eaffffba e252201c ba00001f e92d03e0 f5d1f000 e2522060 [ 0.602714] 5504 f5d1f01c ba000002 f5d1f03c f5d1f05c f5d1f07c e8b100f0 e1a0382e e2522020 [ 0.611198] 5524 e8b15300 e1833804 e1a04824 e1844805 e1a05825 e1855806 e1a06826 e1866807 [ 0.619683] 5544 e1a07827 e1877808 e1a08828 e1888809 e1a09829 e189980c e1a0c82c e18cc80e [ 0.628169] 5564 e8a013f8 aaffffe9 e3720060 aaffffe8 e8bd03e0 e212c01c 0a000005 e1a0382e [ 0.636653] 5584 e491e004 e25cc004 e183380e e4803004 cafffff9 e2411002 eaffff8e e252201c [ 0.645138] 55a4 ba00001f e92d03e0 f5d1f000 e2522060 f5d1f01c ba000002 f5d1f03c f5d1f05c [ 0.653624] 55c4 f5d1f07c e8b100f0 e1a03c2e e2522020 e8b15300 e1833404 e1a04c24 e1844405 [ 0.662111] [ 0.662111] SP: 0xc1835bc0: [ 0.666624] 5bc0 c0542acc 81f00000 c1835bfc c1835bd8 c006e17c c006d4e4 c0125564 20000013 [ 0.675109] 5be0 ffffffff c1835c2c c1835d7c c1835bf8 c000f4b8 c000a1a0 0005dfc0 c2854b58 [ 0.683593] 5c00 00000460 ff9ca7c2 ff93a2c4 ff94a2c4 ff96a5c7 ff97a6c6 ff99a8c7 ff9dacc8 [ 0.692077] 5c20 000000ef c1835d7c ff9eaec8 c1835c40 adc8ff9e c0125564 20000013 ffffffff [ 0.700560] 5c40 0005dfc0 c1835d88 000001e0 0004b036 00000000 0005dfc0 c18f0800 c0157d94 [ 0.709043] 5c60 c0477658 00000000 00000001 00000140 00000140 000000f0 c280a000 c280a036 [ 0.717527] 5c80 000001e0 00000320 00000000 00000320 c000a314 00000000 00000000 00000000 [ 0.726009] 5ca0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.734492] [ 0.734492] IP: 0xff9eae48: [ 0.739005] ae48 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.747498] ae68 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.755982] ae88 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.764465] aea8 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.772949] aec8 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.781432] aee8 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.789915] af08 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.798399] af28 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.806885] [ 0.806885] FP: 0xc1835cfc: [ 0.811397] 5cfc 000001e0 ffffffff 00000000 00000000 00000320 000001e0 00000000 00000000 [ 0.819881] 5d1c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.828362] 5d3c 00000320 000001e0 00000000 00000000 00000000 00000000 c05551f8 00000000 [ 0.836843] 5d5c 00000000 c0555468 c0555470 c0555468 00000004 c1835ddc c1835d80 c0158b04 [ 0.845326] 5d7c c0157614 c0555470 00000001 00000000 00000000 00000002 00000320 000001e0 [ 0.853810] 5d9c 00000320 000001e0 00000000 00000000 00000000 c0154334 c05551f8 c185f800 [ 0.862292] 5dbc c185f810 c0478d4c 00000000 c0459d50 00000000 c1835dfc c1835de0 c0155d44 [ 0.870776] 5ddc c01580ac c185f810 c0558ac4 00000000 c0478d4c c1835e0c c1835e00 c01a3d8c [ 0.879262] [ 0.879262] R1: 0xc2854ad8: [ 0.883774] 4ad8 2376ff0e 2073ff0d 2173ff0b 2372ff0b 2273ff0b 2272ff0b 2170ff0b 206fff0a [ 0.892262] 4af8 2170ff0c 2170ff0c 206dff0c 206cff0c 206cff0d 206cff0d 206aff0d 1f6aff0d [ 0.900750] 4b18 1f6aff0d 216aff0d 1f68ff0d 1e65ff0b 1e65ff0a 1f66ff0a 6c94ff0b a7c2ff62 [ 0.909238] 4b38 a2c4ff9c a2c4ff93 a5c7ff94 a6c6ff96 a8c7ff97 acc8ff99 aec8ff9d adc8ff9e [ 0.917726] 4b58 adc8ff9f b1cbff9f b1ccffa3 b1ccffa3 b4ceffa5 b2ccffa8 b3ceffa6 b8cdffa7 [ 0.926214] 4b78 bbcfffad bcd0ffb0 bed2ffb1 bed0ffb3 bfd1ffb3 c1d3ffb4 c3d5ffb6 c5d5ffb8 [ 0.934701] 4b98 c8d9ffbb c9daffbf cbdcffc0 c8d8ffc2 cad9ffbf ccdbffc1 cddcffc3 cedeffc4 [ 0.943189] 4bb8 d0e0ffc3 d0e0ffc4 d0e0ffc4 d2e3ffc4 d1e3ffc8 d3e4ffc8 d1e2ffca d0e0ffc8 [ 0.951680] [ 0.951680] R3: 0xff9ca742: [ 0.956192] a740 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.964675] a760 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.973158] a780 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.981642] a7a0 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.990126] a7c0 ******** ******** ******** ******** ******** ******** ******** ******** [ 0.998610] a7e0 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.007093] a800 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.015577] a820 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.024060] a840 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.032545] [ 1.032545] R4: 0xff93a244: [ 1.037058] a244 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.045541] a264 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.054025] a284 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.062509] a2a4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.070992] a2c4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.079475] a2e4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.087958] a304 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.096441] a324 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.104927] [ 1.104927] R5: 0xff94a244: [ 1.109439] a244 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.117922] a264 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.126405] a284 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.134889] a2a4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.143372] a2c4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.151856] a2e4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.160340] a304 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.168824] a324 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.177310] [ 1.177310] R6: 0xff96a547: [ 1.181822] a544 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.190306] a564 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.198789] a584 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.207272] a5a4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.215756] a5c4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.224239] a5e4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.232723] a604 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.241206] a624 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.249690] a644 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.258176] [ 1.258176] R7: 0xff97a646: [ 1.262689] a644 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.271171] a664 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.279655] a684 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.288138] a6a4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.296622] a6c4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.305105] a6e4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.313589] a704 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.322072] a724 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.330555] a744 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.339041] [ 1.339041] R8: 0xff99a847: [ 1.343553] a844 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.352037] a864 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.360521] a884 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.369004] a8a4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.377487] a8c4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.385970] a8e4 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.394453] a904 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.402937] a924 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.411422] a944 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.419908] [ 1.419908] R9: 0xff9dac48: [ 1.424421] ac48 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.432904] ac68 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.441388] ac88 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.449871] aca8 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.458355] acc8 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.466838] ace8 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.475323] ad08 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.483807] ad28 ******** ******** ******** ******** ******** ******** ******** ******** [ 1.492299] Process swapper (pid: 1, stack limit = 0xc18341b8) [ 1.498311] Stack: (0xc1835c40 to 0xc1836000) [ 1.502843] 5c40: 0005dfc0 c1835d88 000001e0 0004b036 00000000 0005dfc0 c18f0800 c0157d94 [ 1.511245] 5c60: c0477658 00000000 00000001 00000140 00000140 000000f0 c280a000 c280a036 [ 1.519646] 5c80: 000001e0 00000320 00000000 00000320 c000a314 00000000 00000000 00000000 [ 1.528045] 5ca0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1.536445] 5cc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1.544846] 5ce0: 00000000 00000000 ff000001 00000000 00000000 00000000 00000320 000001e0 [ 1.553246] 5d00: ffffffff 00000000 00000000 00000320 000001e0 00000000 00000000 00000000 [ 1.561646] 5d20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000320 [ 1.570046] 5d40: 000001e0 00000000 00000000 00000000 00000000 c05551f8 00000000 00000000 [ 1.578449] 5d60: c0555468 c0555470 c0555468 00000004 c1835ddc c1835d80 c0158b04 c0157614 [ 1.586851] 5d80: c0555470 00000001 00000000 00000000 00000002 00000320 000001e0 00000320 [ 1.595253] 5da0: 000001e0 00000000 00000000 00000000 c0154334 c05551f8 c185f800 c185f810 [ 1.603655] 5dc0: c0478d4c 00000000 c0459d50 00000000 c1835dfc c1835de0 c0155d44 c01580ac [ 1.612058] 5de0: c185f810 c0558ac4 00000000 c0478d4c c1835e0c c1835e00 c01a3d8c c0155be4 [ 1.620462] 5e00: c1835e34 c1835e10 c01a2b60 c01a3d80 c185f810 c185f844 c0478d4c 00000000 [ 1.628865] 5e20: 00000000 c0459d50 c1835e54 c1835e38 c01a2cb4 c01a2a2c 00000000 c0478d4c [ 1.637268] 5e40: c01a2c60 00000000 c1835e7c c1835e58 c01a11b0 c01a2c70 c1823f4c c185c870 [ 1.645673] 5e60: c18cde14 c0478d4c c18cdde0 c0533e60 c1835e8c c1835e80 c01a2610 c01a1138 [ 1.654076] 5e80: c1835ebc c1835e90 c01a2240 c01a2600 c03f4533 c045de44 c1835ebc c0478d4c [ 1.662479] 5ea0: c03f4533 00000000 c045de44 00000000 c1835ee4 c1835ec0 c01a3264 c01a2108 [ 1.670882] 5ec0: c0554f80 c03f4533 00000000 c045de44 00000000 c0459d50 c1835ef4 c1835ee8 [ 1.679285] 5ee0: c01a42ec c01a31cc c1835f1c c1835ef8 c044d3f0 c01a42b0 c03f4533 c01a31cc [ 1.687689] 5f00: c1835f1c c1834000 c044d314 c0543400 c1835f5c c1835f20 c000a4d4 c044d324 [ 1.696091] 5f20: 00000006 00000006 0000005c c05c0149 c003b8a0 00000007 c0543400 0000005c [ 1.704494] 5f40: c045de44 c0459d48 c0459d50 00000000 c1835f94 c1835f60 c0440c0c c000a3c8 [ 1.712895] 5f60: 00000006 00000006 c04404d0 00000000 00000000 c033b5fc 00000000 00000000 [ 1.721297] 5f80: 00000000 00000000 c1835fac c1835f98 c033b60c c0440a78 00000000 c033b5fc [ 1.729698] 5fa0: 00000000 c1835fb0 c000f930 c033b60c 00000000 00000000 00000000 00000000 [ 1.738099] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1.746499] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000 [ 1.754879] Backtrace: [ 1.757515] [<c0157604>] (Display_Fb_Request+0x0/0x814) from [<c0158b04>] (Fb_Init+0xa68/0xc24) [ 1.766459] [<c015809c>] (Fb_Init+0x0/0xc24) from [<c0155d44>] (disp_probe+0x170/0x1f0) [ 1.774703] [<c0155bd4>] (disp_probe+0x0/0x1f0) from [<c01a3d8c>] (platform_drv_probe+0x1c/0x20) [ 1.783706] r7:c0478d4c r6:00000000 r5:c0558ac4 r4:c185f810 [ 1.789611] [<c01a3d70>] (platform_drv_probe+0x0/0x20) from [<c01a2b60>] (driver_probe_device+0x144/0x1f8) [ 1.799513] [<c01a2a1c>] (driver_probe_device+0x0/0x1f8) from [<c01a2cb4>] (__driver_attach+0x54/0x94) [ 1.809041] r9:c0459d50 r8:00000000 r7:00000000 r6:c0478d4c r5:c185f844 r4:c185f810 [ 1.817254] [<c01a2c60>] (__driver_attach+0x0/0x94) from [<c01a11b0>] (bus_for_each_dev+0x88/0x98) [ 1.826429] r7:00000000 r6:c01a2c60 r5:c0478d4c r4:00000000 [ 1.832326] [<c01a1128>] (bus_for_each_dev+0x0/0x98) from [<c01a2610>] (driver_attach+0x20/0x28) [ 1.841325] r6:c0533e60 r5:c18cdde0 r4:c0478d4c [ 1.846153] [<c01a25f0>] (driver_attach+0x0/0x28) from [<c01a2240>] (bus_add_driver+0x148/0x220) [ 1.855175] [<c01a20f8>] (bus_add_driver+0x0/0x220) from [<c01a3264>] (driver_register+0xa8/0x124) [ 1.864349] r8:00000000 r7:c045de44 r6:00000000 r5:c03f4533 r4:c0478d4c [ 1.871325] [<c01a31bc>] (driver_register+0x0/0x124) from [<c01a42ec>] (platform_driver_register+0x4c/0x60) [ 1.881293] r9:c0459d50 r8:00000000 r7:c045de44 r6:00000000 r5:c03f4533 r4:c0554f80 [ 1.889530] [<c01a42a0>] (platform_driver_register+0x0/0x60) from [<c044d3f0>] (disp_module_init+0xdc/0x128) [ 1.899616] [<c044d314>] (disp_module_init+0x0/0x128) from [<c000a4d4>] (do_one_initcall+0x11c/0x148) [ 1.909055] r6:c0543400 r5:c044d314 r4:c1834000 [ 1.913890] [<c000a3b8>] (do_one_initcall+0x0/0x148) from [<c0440c0c>] (kernel_init_freeable+0x1a4/0x1e4) [ 1.923711] [<c0440a68>] (kernel_init_freeable+0x0/0x1e4) from [<c033b60c>] (kernel_init+0x10/0xe8) [ 1.932973] r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c033b5fc r4:00000000 [ 1.941200] [<c033b5fc>] (kernel_init+0x0/0xe8) from [<c000f930>] (ret_from_fork+0x14/0x24) [ 1.949759] r5:c033b5fc r4:00000000 [ 1.953514] Code: e1a09829 e189980c e1a0c82c e18cc80e (e8a013f8) [ 1.959971] ---[ end trace 4c9adbe59771339d ]--- [ 1.964864] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 1.964864]
disp的de问题
那怎么改呢?
思来想去, 感觉CMA内存配置太多了:
CONFIG_CLKSRC_OF=y CONFIG_CLONE_BACKWARDS=y CONFIG_CMA=y CONFIG_CMA_ALIGNMENT=8 CONFIG_CMA_AREAS=7 # CONFIG_CMA_DEBUG is not set CONFIG_CMA_SIZE_MBYTES=16 # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_SIZE_SEL_MBYTES=y
16M 字节
配成 1M / 4M / 8M 一番折腾半小时, 问题依旧.
问题可能来自 env 文件, 果然发现了32M的踪影:
enforcing=1 earlyprintk=sunxi-uart,0x01c25400 initcall_debug=0 console=ttyS1,115200 nor_root=/dev/mtdblock4 nand_root=/dev/nandd mmc_root=/dev/mmcblk0p7 init=/sbin/init rdinit=/rdinit loglevel=8 cma=32M verify=no rootdelay=5
改成 4M, 一切正常:
[0]HELLO! BOOT0 is starting! [2]boot0 commit : 80628dcde5dc4ecdc757a9e782c58d7cf1abf959 [60]dram size =32 [62]Reg pull reg_val=0x00000000,read=0x00000010 [66]Succeed in reading toc file head. [69]The size of toc is 00054000. [127]Reg pull reg_val=0x00000000,read=0x00000010 [136]Ready to disable icache. [138]Jump to secend Boot. 7 U-Boot 2014.07 (Jul 05 2022 - 11:58:37) Allwinner Technology uboot commit : f1592db8c49aaedd6895f7e0f90caa123f0a3d5a i2c_init: by cpux [I2C-DEBUG]:i2c_set_clock() 354 [I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed. i2c_init ok [0.187]pmbus: ready axp: get node[/soc/pmu0] error axp_probe error [0.193]PMU: cpux 408 Mhz,AXI=408 Mhz PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz key value = 4294967295, fel_key = [256,426] DRAM: 32 MiB Relocation Offset is: 01580000 axp: get node[/soc/pmu0] error int sunxi_dma_init--- irq enable workmode = 0,storage type = 3 [0.259]spinor: 0 flash size =0x4000 sectors sunxi spinor is initing...int sunxi_dma_init--- irq enable sunxi_dma_install_int ok sunxi_dma_install_int ok OK spinor id:0x1840ef spi_freq = 40000000 [0.277]sunxi flash init ok spinor read: start 0x3e0, sector 0x20 used mbr [0], count = 8 spinor read: start 0x800, sector 0x200 env size is 256 env partition is too small! can't enabled backup env functions logo addr = 0x81f00000 spinor read: start 0x400, sector 0x400 sunxi_read_bootlogo: read bootlogo partition successful do not find fastboot status flag --------fastboot partitions-------- -total partitions:8- -name- -start- -size- bootlogo : 4000 80000 env : 84000 20000 boot : a4000 280000 rootfs : 324000 340000 rootfs_data : 664000 80000 misc : 6e4000 10000 private : 6f4000 10000 UDISK : 704000 0 ----------------------------------- spinor read: start 0x3b00, sector 0x4 disable nand error: FDT_ERR_BADPATH disable nand error: FDT_ERR_BADPATH ## error: update_fdt_dram_para : FDT_ERR_NOTFOUND PowerBus = 0( 2:vBus 3:acBus other: not exist) no battery exist sunxi_bmp_logo_display Hit any key to stop autoboot: 0 spinor read: start 0x900, sector 0x40 spinor read: start 0x940, sector 0x1376 ## Booting kernel from Legacy Image at 80007fc0 ... Image Name: ARM OpenWrt Linux-3.10.65 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2583056 Bytes = 2.5 MiB Load Address: 80008000 Entry Point: 80008000 XIP Kernel Image ... OK reserving fdt memory region: addr=81000000 size=10000 Using Device Tree in place at 81000000, end 8100f25f Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.65 (whycan@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #244 Wed Jul 6 03:35:16 UTC 2022 [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 [ 0.000000] CPU: VIVT data cache, VIVT instruction cache [ 0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1 [ 0.000000] bootconsole [earlycon0] enabled [ 0.000000] cma: CMA: reserved 4 MiB at 81c00000 [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] On node 0 totalpages: 8192 [ 0.000000] free_area_init_node: node 0, pgdat c0542acc, node_mem_map c0570000 [ 0.000000] Normal zone: 64 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 8192 pages, LIFO batch:0 [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 [ 0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25400 initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/mtdblock4 init=/pseudo_init rdinit=/rdinit partitions=bootlogo@mtdblock1:env@mtdblock2:boot@mtdblock3:rootfs@mtdblock4:rootfs_data@mtdblock5:misc@mtdblock6:private@mtdblock7:UDISK@mtdblock8 cma=4M fb_base=0x81f00000 androidboot.serialno=<NULL> boot_type=3 [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Memory: 32MB = 32MB total [ 0.000000] Memory: 22660k/22660k available, 10108k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xc2800000 - 0xff000000 ( 968 MB) [ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .text : 0xc0008000 - 0xc043ff84 (4320 kB) [ 0.000000] .init : 0xc0440000 - 0xc045df74 ( 120 kB) [ 0.000000] .data : 0xc045e000 - 0xc05433e8 ( 917 kB) [ 0.000000] .bss : 0xc05433e8 - 0xc056fbe0 ( 178 kB) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS:256 [ 0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000] [ 0.000000] pll_cpu-set_default_rate=552000000 success! [ 0.000000] pll_video-set_default_rate=297000000 success! [ 0.000000] pll_ddr-set_default_rate=312000000 success! [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.005240] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256) [ 0.075335] pid_max: default: 32768 minimum: 301 [ 0.080426] Mount-cache hash table entries: 512 [ 0.086330] CPU: Testing write buffer coherency: ok [ 0.092016] Setting up static identity map for 0xc0340870 - 0xc03408c8 [ 0.101175] devtmpfs: initialized [ 0.106609] pinctrl core: initialized pinctrl subsystem [ 0.113284] NET: Registered protocol family 16 [ 0.121081] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.128650] dump_class_init,844, success [ 0.137578] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver [ 0.161252] bio: create slab <bio-0> at 0 [ 0.166611] pwm module init! [ 0.171352] SCSI subsystem initialized [ 0.175576] usbcore: registered new interface driver usbfs [ 0.181250] usbcore: registered new interface driver hub [ 0.187048] usbcore: registered new device driver usb [ 0.198124] Linux video capture interface: v2.00 [ 0.203466] Advanced Linux Sound Architecture Driver Initialized. [ 0.211194] cfg80211: Calling CRDA to update world regulatory domain [ 0.218592] Switching to clocksource sun3i high-res couter [ 0.243830] get det_vbus is fail, 84 [ 0.249228] NET: Registered protocol family 2 [ 0.255822] TCP established hash table entries: 512 (order: 0, 4096 bytes) [ 0.262810] TCP bind hash table entries: 512 (order: -1, 2048 bytes) [ 0.269354] TCP: Hash tables configured (established 512 bind 512) [ 0.275790] TCP: reno registered [ 0.279128] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.285133] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.292082] NET: Registered protocol family 1 [ 0.310031] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.316588] jffs2: version 2.2. © 2001-2006 Red Hat, Inc. [ 0.322928] msgmni has been set to 52 [ 0.330054] io scheduler noop registered [ 0.334163] io scheduler cfq registered (default) [ 0.339056] [pm]aw_pm_init! [ 0.342287] [pm]valid [ 0.344727] [pm]valid [ 0.347415] [DISP]disp_module_init [ 0.353598] /soc/lcd0@01c0c000: could not find phandle [ 0.414365] pll_freq=297000000HZ, lcd_dclk_freq=33000000HZ, clk_div=9 [ 0.421624] num_screens=1 [ 0.424461] screen_id=0 [ 0.426997] para->mclk[MOD_CLK_LCD1CH0]=0xc140c340 [ 0.431858] para->mclk[MOD_CLK_LCD1CH1]=0xc140c440 [ 0.436772] disp tv init [ 0.439395] tcon_clk=0xc140c340, tcon_clk_parent=0x0 [ 0.444470] tcon_clk=0xc140c340, tcon_clk_parent=0xc1404400 [ 0.450115] tve_clk=0xc140c440, tve_clk_parent=0xc1404400 [ 0.455613] disp al tv init [ 0.461225] fetch script datadisp.screen2_output_type fail [ 0.467215] fetch script datadisp.screen2_output_mode fail [ 0.475493] fetch script datadisp.fb2_format fail [ 0.480579] fetch script datadisp.fb2_scaler_mode_enable fail [ 0.486782] fetch script datadisp.fb2_width fail [ 0.491790] fetch script datadisp.fb2_height fail [ 0.511438] [DISP] Fb_map_kernel_logo,line:561: this is not a bmp picture [ 0.523077] [DISP]disp_module_init finish [ 0.541423] uart1: ttyS1 at MMIO 0x1c25400 (irq = 104) is a SUNXI [ 0.547750] sw_console_setup()1324 - console setup baud 115200 parity n bits 8, flow n [ 0.555824] console [ttyS1] enabled, bootconsole disabled [ 0.555824] console [ttyS1] enabled, bootconsole disabled [ 0.568378] misc dump reg init [ 0.573053] sunxi-wlan wlan: wlan_busnum (0) [ 0.577938] sunxi-wlan wlan: wlan_power_num (0) [ 0.582983] sunxi-wlan wlan: Missing wlan_io_regulator. [ 0.588840] sunxi-wlan wlan: io_regulator_name ((null)) [ 0.594714] sunxi-wlan wlan: request pincrtl handle for device [wlan] failed [ 0.602652] /soc/wlan: could not find phandle [ 0.607558] sunxi-wlan wlan: get gpio wlan_regon failed [ 0.613409] sunxi-wlan wlan: wlan_hostwake gpio=117 mul-sel=6 pull=-1 drv_level=-1 data=1 [ 0.622989] sunxi-wlan wlan: Missing clocks. [ 0.627801] sunxi-wlan wlan: clk_name ((null)) [ 0.632770] sunxi-wlan wlan: clk not config [ 0.637843] lradc_battery_probe:lradc_battery_probe ++++++ [ 0.643941] lradc_battery_dts_parse:lradc_battery_dts_parse ++++++ [ 0.650913] key base: f1c23400 [ 0.654496] irq num: 114 ! [ 0.657504] battery_data_hw_init:battery_data_hw_init ++++++ [ 0.663837] lradc_battery_probe:lradc_battery_probe ------ [ 0.672520] spi spi0: master is unqueued, this is deprecated [ 0.680222] m25p80 spi0.0: found w25q128, expected m25p64 [ 0.686355] m25p80 spi0.0: w25q128 (16384 Kbytes) - fast mode [ 0.697241] 9 sunxipart partitions found on MTD device (null) [ 0.703638] Creating 9 MTD partitions on "(null)": [ 0.709044] 0x000000000000-0x000000080000 : "uboot" [ 0.716616] 0x000000080000-0x000000100000 : "bootlogo" [ 0.724402] 0x000000100000-0x000000120000 : "env" [ 0.731402] 0x000000120000-0x0000003a0000 : "boot" [ 0.738613] 0x0000003a0000-0x0000006e0000 : "rootfs" [ 0.746125] 0x0000006e0000-0x000000760000 : "rootfs_data" [ 0.753945] 0x000000760000-0x000000770000 : "misc" [ 0.761355] 0x000000770000-0x000000780000 : "private" [ 0.768963] 0x000000780000-0x000001000000 : "UDISK" [ 0.776772] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.785561] /soc/usbc0@0: could not find phandle [ 0.790710] get regulator_io is no nocare [ 0.795447] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver [ 0.803396] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1 [ 0.815359] hub 1-0:1.0: USB hub found [ 0.819583] hub 1-0:1.0: 1 port detected [ 0.824578] wrn: hcd is not enable, need not stop hcd [ 0.830948] sunxi_keyboard_startup: keyboard has no clk. [ 0.837525] input: sunxi-keyboard as /devices/virtual/input/input0 [ 0.845555] rtc-pcf8563 0-0051: chip found, driver version 0.4.3 [ 0.852626] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x51) [ 0.861893] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error [ 0.869161] rtc-pcf8563 0-0051: rtc core: registered rtc-pcf8563 as rtc0 [ 0.876819] sunxi cedar version 0.1 [ 0.880949] VE: install start!!! [ 0.880949] [ 0.886418] cedar_ve: cedar-ve the get irq is 103 [ 0.892247] VE: install end!!! [ 0.892247] [ 0.899089] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v0.91 2018-5-29 14:19) Compiled in Jul 6 2022 at 03:29:35 [ 0.911583] sunxi-mmc sdc0: Can't get vmmc regulator string [ 0.917896] sunxi-mmc sdc0: Can't get vqmmc regulator string [ 0.924190] sunxi-mmc sdc0: Can't get vdmmc regulator string [ 0.930532] sunxi-mmc sdc0: Failed getting OCR mask: 0 [ 0.937748] sunxi-mmc sdc0: ***set host ocr*** [ 0.943086] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 0.964393] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 0.994550] sunxi-mmc sdc0: base:0xf1c0f000 irq:107 [ 1.000011] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !! [ 1.006869] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !! [ 1.012861] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.027373] failed to get gpio-spk and gpio_num [ 1.035925] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTR [ 1.043927] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTL [ 1.051944] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKL [ 1.059724] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKR [ 1.067487] sunxi-codec-machine sound.2: ASoC: DAPM unknown pin External Speaker [ 1.076825] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.087837] sunxi-internal-cpudai 1c23c00.cpudai0-controller: ASoC: pcm constructor failed: -12 [ 1.097587] sunxi-codec-machine sound.2: ASoC: can't create pcm SUNXI-CODEC :-12 [ 1.105852] sunxi-codec-machine sound.2: ASoC: failed to instantiate card -12 [ 1.114171] snd_soc_register_card failed -12 [ 1.119130] sunxi-codec-machine: probe of sound.2 failed with error -12 [ 1.127276] ipip: IPv4 over IPv4 tunneling driver [ 1.133619] gre: GRE over IPv4 demultiplexor driver [ 1.139169] ip_gre: GRE over IPv4 tunneling driver [ 1.146527] sunxi-mmc sdc0: smc 0 p0 err, cmd 8, RTO !! [ 1.153280] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !! [ 1.160092] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !! [ 1.166036] TCP: cubic registered [ 1.169720] Initializing XFRM netlink socket [ 1.174605] NET: Registered protocol family 17 [ 1.179577] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !! [ 1.185576] NET: Registered protocol family 15 [ 1.190552] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !! [ 1.196911] VFP support v0.3: not present [ 1.202330] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !! [ 1.208781] [LCD]lcd_module_init [ 1.212432] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !! [ 1.219326] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !! [ 1.226585] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !! [ 1.232912] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 1.245673] enhance_en=1 [ 1.248546] matrixresult:(0x0, 0x3c4, 0x0, 0x0) [ 1.253713] pll_freq=297000000HZ, lcd_dclk_freq=33000000HZ, clk_div=9 [ 1.260996] clk_div=9 [ 1.263525] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA [ 1.269174] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA [ 1.274811] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA [ 1.280408] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA [ 1.286033] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA [ 1.291629] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA [ 1.297252] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA [ 1.304229] sunxi-mmc sdc0: smc 0 p0 err, cmd 1, RTO !! [ 1.310270] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 1.320962] [LCD]open, step 0 finish [ 1.364369] [LCD]open, step 1 finish [ 1.424349] [LCD]open, step 2 finish [ 1.534780] [LCD]open, step 3 finish [ 1.544867] [LCD]lcd_module_init finish [ 1.549664] usb_serial_number:20080411 [ 1.554561] file system registered [ 1.561012] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 1.568795] android_usb gadget: Number of LUNs=3 [ 1.573932] lun0: LUN: removable file: (no medium) [ 1.579440] lun1: LUN: removable file: (no medium) [ 1.584904] lun2: LUN: removable file: (no medium) [ 1.591230] android_usb gadget: android_usb ready [ 1.597044] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x51) [ 1.606318] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error [ 1.613025] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock [ 1.620975] ALSA device list: [ 1.624373] No soundcards found. [ 1.643819] VFS: Mounted root (squashfs filesystem) readonly on device 31:4. [ 1.661693] devtmpfs: mounted [ 1.666154] Freeing unused kernel memory: 116K (c0440000 - c045d000) mount: mounting none on /dev failed: Resource busy mount: mounting pstore on /sys/fs/pstore failed: No such file or directory -- run rc.preboot -- -- set volume -- Failed to open mixer -- play music -- -- end -- failed to open for pcm 0,0 [ 4.264325] [ 4.264325] insmod_device_driver [ 4.264325] [ 4.271463] device_chose finished 77! -- run rc.final -- insmod F1C200s-board -- wifi connect -- insmod wifi kernel module -------------------- insmod: can't insert '/lib/modules/3.10.65/xradio_wlan.ko': No such file or directory start wpa_supplicant ------------------------ [ 5.515719] android_usb: already disabled [ 5.571478] adb_open [ 5.575308] adb_bind_config [ 5.828309] android_work: sent uevent USB_STATE=CONNECTED [ 5.916425] android_usb gadget: high-speed config #1: android [ 5.932047] android_work: sent uevent USB_STATE=CONFIGURED Successfully initialized wpa_supplicant Line 6: Invalid passphrase length 6 (expected: 8..63) '******"'. Line 6: failed to parse psk '"******"'. Line 7: failed to parse network block. Failed to read or parse configuration '/etc/wpa_supplicant.conf'. start udhcpc ---------------- -- end -- BusyBox v1.27.2 () built-in shell (ash) _____ _ __ _ |_ _||_| ___ _ _ | | |_| ___ _ _ _ _ | | _ | || | | |__ | || || | ||_'_| | | | || | || _ | |_____||_||_|_||___||_,_| |_| |_||_|_||_|_| Tina is Based on OpenWrt! ---------------------------------------------- Tina Linux (Neptune, 5C1C9C53) ---------------------------------------------- udhcpc: SIOCGIFINDEX: No such device root@TinaLinux:/# root@TinaLinux:/# root@TinaLinux:/# root@TinaLinux:/#
root@TinaLinux:/# cat /proc/meminfo MemTotal: 26872 kB MemFree: 14840 kB Buffers: 1444 kB Cached: 2128 kB SwapCached: 0 kB Active: 1640 kB Inactive: 2160 kB Active(anon): 236 kB Inactive(anon): 20 kB Active(file): 1404 kB Inactive(file): 2140 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 0 kB SwapFree: 0 kB Dirty: 0 kB Writeback: 0 kB AnonPages: 240 kB Mapped: 596 kB Shmem: 28 kB Slab: 4020 kB SReclaimable: 832 kB SUnreclaim: 3188 kB KernelStack: 312 kB PageTables: 80 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 13436 kB Committed_AS: 1292 kB VmallocTotal: 991232 kB VmallocUsed: 4160 kB VmallocChunk: 745392 kB
剩下还挺多的
