    【XR806开发板试用】 基于MQTT远程温度采集+灯光控制
      cx1253176313 LV 2 最后由 编辑
      第一步:由于ROM的空间不够,先要将控制台程序移出编译
      • 将源码中的device\xradio\xr806\BUILD.gn文件中44行的"adapter/console:app_console"注释掉
      if (IsBootloader == "false") {
          deps += [
            "adapter/hals:adapter",
            #"adapter/console:app_console",
            "ohosdemo:ohosdemo"
      • 否则编译时可能会出现如下报错信息
      [OHOS ERROR] /opt/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-objcopy -O binary -R .xip   audio_demo.elf audio_demo.bin
      [OHOS ERROR] /opt/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-size audio_demo.elf
      [OHOS ERROR]    text       data     bss     dec     hex filename
      [OHOS ERROR] 1155588       8032   76280 1239900  12eb5c audio_demo.elf
      [OHOS ERROR] /opt/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-objcopy -O binary -j .xip audio_demo.elf audio_demo_xip.bin
      [OHOS ERROR] cp audio_demo_xip.bin ../image/"xr806"/app_xip.bin
      [OHOS ERROR] cd ../image/"xr806" && \
      [OHOS ERROR] chmod a+r *.bin && \
      [OHOS ERROR] /opt/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-gcc -E -P -CC -DCONFIG_CHIP_ARCH_VER=3 -DCONFIG_ARCH_APP_CORE -DCONFIG_CPU_CM33F -DPRJ_XIP_SIZE=8M -DPRJ_BOOT_CERT="\"null\"" -DPRJ_IMAGE_BOOT_ATTR="\"0x1\"" -DPRJ_IMAGE_APP_SRAM_OFFS="\"0x00201000\"" -DPRJ_IMAGE_APP_EP="\"0x00201101\"" -DPRJ_IMAGE_BOOT_SRAM_OFFS="\"0x00230000\"" -DPRJ_IMAGE_BOOT_EP="\"0x00230101\"" -DPRJ_IMAGE_TZ_ATTR="\"0x25\"" -DPRJ_IMAGE_TZ_XIP_ATTR="\"0x26\"" -DPRJ_IMAGE_TZ_PSRAM_ATTR="\"0x25\"" -DPRJ_APP_BIN_CERT="\"null\"" -DPRJ_APP_XIP_BIN_CERT="\"null\"" -DPRJ_APP_PSRAM_BIN_CERT="\"null\"" -DPRJ_IMAGE_APP_ATTR="\"0x1\"" -DPRJ_IMAGE_APP_XIP_ATTR="\"0x2\"" -DPRJ_IMAGE_APP_PSRAM_ATTR="\"0x1\"" -DCONFIG_RAM_START=0x00201000 -DPRJ_RAM_SIZE=300K -DPRJ_PSRAM_START_OFFS="\"0x01400000\"" -DCONFIG_PSRAM_START=0x01400000 -DPRJ_PSRAM_SIZE=0K -DPRJ_IMAGE_BOOT_BIN="\"boot_"40"M.bin\"" -DPRJ_IMAGE_SYS_SDD_BIN="\"sys_sdd_"40"M.bin\""  -I../../../../../include/generated -include autoconf.h -o .image.cfg - < image.cfg && \
      [OHOS ERROR] true && \
      [OHOS ERROR] chmod 777 ../../../../../tools/mkimage && ../../../../../tools/mkimage  -c .image.cfg -o xr_system.img
      [OHOS ERROR] err: bin 1 and bin 2 were overlaped!
      [OHOS ERROR] Overlapped size: 4096 Byte(4kB)
      [OHOS ERROR] bin 1 name:app.bin    begin: 0x00008000    end: 0x00018C00
      [OHOS ERROR] bin 2 name:app_xip.bin    begin: 0x00017C00
      [OHOS ERROR]
      [OHOS ERROR] We've rearranged bin files and generated new cfg file 'image_auto_cal.cfg', the new one is recommended.
      [OHOS ERROR] Generate image file failed
      [OHOS ERROR] cfg string:
      [OHOS ERROR] /*
      [OHOS ERROR]  *
      [OHOS ERROR]  * Automatically generated file; DO NOT EDIT.
      [OHOS ERROR]  * XR806 SDK Configuration
      [OHOS ERROR]  *
      [OHOS ERROR]  */
      [OHOS ERROR] {
      [OHOS ERROR]     "magic" : "AWIH",
      [OHOS ERROR]     "version" : "0.5",
      [OHOS ERROR]     "image" : {"max_size": "1532K"},
      [OHOS ERROR]     "section" :[
      [OHOS ERROR]   {"id": "0xa5ff5a00", "bin" :"boot_40M.bin", "cert": "null", "flash_offs": "0K", "sram_offs": "0x00230000", "ep": "0x00230101", "attr":"0x1"},
      [OHOS ERROR]   {"id": "0xa5fe5a01", "bin" :"app.bin", "cert": "null", "flash_offs": "32K", "sram_offs": "0x00201000", "ep": "0x00201101", "attr":"0x1"},
      [OHOS ERROR]   {"id": "0xa5fd5a02", "bin" :"app_xip.bin", "cert": "null", "flash_offs": "95K", "sram_offs": "0xffffffff", "ep": "0xffffffff", "attr":"0x2"},
      [OHOS ERROR]   {"id": "0xa5fa5a05", "bin" :"wlan_bl.bin", "cert": "null", "flash_offs": "1166K", "sram_offs": "0xffffffff", "ep": "0xffffffff", "attr":"0x1"},
      [OHOS ERROR]   {"id": "0xa5f95a06", "bin" :"wlan_fw.bin", "cert": "null", "flash_offs": "1169K", "sram_offs": "0xffffffff", "ep": "0xffffffff", "attr":"0x1"},
      [OHOS ERROR]   {"id": "0xa5f85a07", "bin" :"sys_sdd_40M.bin", "cert": "null", "flash_offs": "1194K", "sram_offs": "0xffffffff", "ep": "0xffffffff", "attr":"0x1"},
      [OHOS ERROR]   {}
      [OHOS ERROR]  ]
      [OHOS ERROR] }
      [OHOS ERROR]
      [OHOS ERROR] ../../../../project/project.mk:519: recipe for target 'image' failed
      [OHOS ERROR] make[2]: *** [image] Error 255
      [OHOS ERROR] make[2]: Leaving directory '/home/qq1253176313/ubuntu_share/samba/openharmony/device/xradio/xr806/xr_skylark/project/demo/audio_demo/gcc'
      [OHOS ERROR] ../../../../project/project.mk:493: recipe for target '__build' failed
      [OHOS ERROR] make[1]: *** [__build] Error 2
      [OHOS ERROR] make[1]: Leaving directory '/home/qq1253176313/ubuntu_share/samba/openharmony/device/xradio/xr806/xr_skylark/project/demo/audio_demo/gcc'
      [OHOS ERROR] Makefile:164: recipe for target 'build' failed
      [OHOS ERROR] make: *** [build] Error 2
      [OHOS ERROR] you can check build log in /home/qq1253176313/ubuntu_share/samba/openharmony/out/xr806/wifi_skylark/build.log
      [OHOS ERROR] command: "/home/qq1253176313/ubuntu_share/samba/openharmony/prebuilts/build-tools/linux-x86/bin/ninja -w dupbuild=warn -C /home/qq1253176313/ubuntu_share/samba/openharmony/out/xr806/wifi_skylark" failed
      [OHOS ERROR] return code: 1
      [OHOS ERROR] execution path: /home/qq1253176313/ubuntu_share/samba/openharmony
      第二步 设置device\xradio\xr806\ohosdemo\BUILD.gn文件
      • 新增一行"mqtt:app_mqtttest"
      group("ohosdemo") {
          deps = [
              "mqtt:app_mqtttest",
              #"LED:app_led",
              #"hello_demo:app_hello",
              #"wlan_demo:app_WlanTest",
      第三步 编写源码
      在device\xradio\xr806\ohosdemo\mqtt路径下创建BUILD.gn、ds18b20.c、ds18b20.h、main.c四个文件
      • device\xradio\xr806\ohosdemo\mqtt\ds18b20.c
      #include "ds18b20.h"
      //本程序只供学习使用,未经作者许可,不得用于其它任何用途
      //ALIENTEK miniSTM32开发板
      //DS18B20驱动代码
      //正点原子@ALIENTEK
      //技术论坛:www.openedv.com
      //修改日期:2012/9/12
      //版本:V1.0
      //版权所有,盗版必究。
      //Copyright(C) 广州市星翼电子科技有限公司 2009-2019
      //All rights reserved
      const GPIO_InitParam input_param = {
          .driving = GPIO_DRIVING_LEVEL_1,
          .mode = GPIOx_Pn_F0_INPUT,
      	.pull = GPIO_PULL_UP,
      const GPIO_InitParam output_param = {
          .mode = GPIOx_Pn_F1_OUTPUT,
      	.pull = GPIO_PULL_NONE,
      //复位DS18B20
      void DS18B20_Rst(void)
      	DS18B20_IO_OUT(); //SET PA0 OUTPUT
          DS18B20_DQ_OUT_0; //拉低DQ
          delay_us(750);    //拉低750us
          DS18B20_DQ_OUT_1; //DQ=1
      	delay_us(15);     //15US
      //等待DS18B20的回应
      //返回1:未检测到DS18B20的存在
      //返回0:存在
      u8 DS18B20_Check(void)
      	u8 retry=0;
      	DS18B20_IO_IN();//SET PA0 INPUT
          while (DS18B20_DQ_IN&&retry<200)
      		retry++;
      		delay_us(1);
      	if(retry>=200)return 1;
      	else retry=0;
          while (!DS18B20_DQ_IN&&retry<240)
      		retry++;
      		delay_us(1);
      	if(retry>=240)return 1;
      //从DS18B20读取一个位
      //返回值:1/0
      u8 DS18B20_Read_Bit(void) 			 // read one bit
          u8 data;
      	DS18B20_IO_OUT();//SET PA0 OUTPUT
          DS18B20_DQ_OUT_0;
      	delay_us(2);
          DS18B20_DQ_OUT_1;
      	delay_us(12);
      	if(DS18B20_DQ_IN)data=1;
          else data=0;
          delay_us(50);
          return data;
      //从DS18B20读取一个字节
      //返回值:读到的数据
      u8 DS18B20_Read_Byte(void)    // read one byte
          u8 i,j,dat;
          dat=0;
      	for (i=1;i<=8;i++)
              j=DS18B20_Read_Bit();
              dat=(j<<7)|(dat>>1);
          return dat;
      //写一个字节到DS18B20
      //dat:要写入的字节
      void DS18B20_Write_Byte(u8 dat)
          u8 j;
          u8 testb;
      	DS18B20_IO_OUT();//SET PA0 OUTPUT;
          for (j=1;j<=8;j++)
              testb=dat&0x01;
              dat=dat>>1;
              if (testb)
                  DS18B20_DQ_OUT_0;// Write 1
                  delay_us(2);
                  DS18B20_DQ_OUT_1;
                  delay_us(60);
                  DS18B20_DQ_OUT_0;// Write 0
                  delay_us(60);
                  DS18B20_DQ_OUT_1;
                  delay_us(2);
      //开始温度转换
      void DS18B20_Start(void)// ds1820 start convert
          DS18B20_Rst();
      	DS18B20_Check();
          DS18B20_Write_Byte(0xcc);// skip rom
          DS18B20_Write_Byte(0x44);// convert
      //初始化DS18B20的IO口 DQ 同时检测DS的存在
      //返回1:不存在
      //返回0:存在
      u8 DS18B20_Init(void)
      	DS18B20_IO_OUT();
          DS18B20_Rst();
      //从ds18b20得到温度值
      //精度:0.1C
      //返回值:温度值 (-550~1250)
      short DS18B20_Get_Temp(void)
          u8 temp;
          u8 TL,TH;
      	short tem;
          DS18B20_Start ();                    // ds1820 start convert
          DS18B20_Rst();
          DS18B20_Check();
          DS18B20_Write_Byte(0xbe);// convert
          TL=DS18B20_Read_Byte(); // LSB
          TH=DS18B20_Read_Byte(); // MSB
          if(TH>7)
              TH=~TH;
              TL=~TL;
              temp=0;//温度为负
          }else temp=1;//温度为正
          tem=TH; //获得高八位
          tem<<=8;
          tem+=TL;//获得底八位
          tem=(float)tem*0.625;//转换
      	if(temp)return tem; //返回温度值
      	else return -tem;
      • device\xradio\xr806\ohosdemo\mqtt\ds18b20.h
      #ifndef __DS18B20_H
      #define __DS18B20_H
      #include "driver/chip/hal_gpio.h"
      #include "driver/chip/hal_util.h"
      typedef unsigned long int u32;
      typedef unsigned short int u16;
      typedef unsigned char  u8;
      typedef	long int 	s32;
      typedef	short int 	s16;
      typedef	char 		s8;
      extern const GPIO_InitParam input_param;
      extern const GPIO_InitParam output_param;
      #define DS18B20_PORT           GPIO_PORT_B
      #define DS18B20_PIN            GPIO_PIN_4
      #define DS18B20_IO_IN()  {HAL_GPIO_Init(DS18B20_PORT, DS18B20_PIN, &input_param);}
      #define DS18B20_IO_OUT() {HAL_GPIO_Init(DS18B20_PORT, DS18B20_PIN, &output_param);}
      #define delay_us HAL_UDelay
      ////IO操作函数
      #define	DS18B20_DQ_OUT_0 HAL_GPIO_WritePin(DS18B20_PORT, DS18B20_PIN, GPIO_PIN_LOW)
      #define	DS18B20_DQ_OUT_1 HAL_GPIO_WritePin(DS18B20_PORT, DS18B20_PIN, GPIO_PIN_HIGH)
      #define	DS18B20_DQ_IN  HAL_GPIO_ReadPin(DS18B20_PORT, DS18B20_PIN)  //数据端口	PA0
      u8 DS18B20_Init(void);			//初始化DS18B20
      short DS18B20_Get_Temp(void);	//获取温度
      void DS18B20_Start(void);		//开始温度转换
      void DS18B20_Write_Byte(u8 dat);//写入一个字节
      u8 DS18B20_Read_Byte(void);		//读出一个字节
      u8 DS18B20_Read_Bit(void);		//读出一个位
      u8 DS18B20_Check(void);			//检测是否存在DS18B20
      void DS18B20_Rst(void);			//复位DS18B20
      • device\xradio\xr806\ohosdemo\mqtt\main.c
      #include <math.h>
      #include "ohos_init.h"
      #include "kernel/os/os.h"
      #include <string.h>
      #include "wifi_device.h"
      #include "wifi_hotspot.h"
      #include "common/framework/platform_init.h"
      #include "net/wlan/wlan.h"
      #include "common/framework/net_ctrl.h"
      #include "net/mqtt/MQTTClient-C/MQTTClient.h"
      #define WIFI_DEVICE_CONNECT_AP_SSID "ZhuoTK_5F91"
      #define WIFI_DEVICE_CONNECT_AP_PSK "qq1253176313"
      #define MQTT_DEMO_THREAD_STACK_SIZE (8 * 1024) /* ssl need more stack */
      static OS_Thread_t mqtt_demo_thread;
      static MQTTPacket_connectData mqtt_demo_connectData = MQTTPacket_connectData_initializer;
      static Client mqtt_demo_client;
      static Network mqtt_demo_network;
      #define MQTT_DEMO_CLIENT_ID "mqt1212ad564617"
      #define MQTT_DEMO_HOST_NAME "xxx.xxx.xxx.xxx"   //填写自己MQTT服务器地址
      #define MQTT_DEMO_PORT      "1883"
      #define MQTT_DEMO_USERNAME  "user1"
      #define MQTT_DEMO_PASSWORD  "123123"
      #define MQTT_DEMO_TOPIC     "/topic/led"
      // #define MQTT_DEMO_CLIENT_ID "1234785|securemode=2,signmethod=hmacsha1,timestamp=789|"
      // #define MQTT_DEMO_HOST_NAME "iot-as-mqtt.cn-shanghai.aliyuncs.com"
      // #define MQTT_DEMO_PORT      "1883"
      // #define MQTT_DEMO_USERNAME  "xr806_senor_set0&vo84Hm3xbUj"
      // #define MQTT_DEMO_PASSWORD  "4f9ebb2143f01e4489133c1ea55051fbbfc4c44e"
      // #define MQTT_DEMO_TOPIC     "/vo84Hm3xbUj/xr806_senor_set0/data"
      #define MQTT_DEMO_BUF_SIZE (2*1024)
      #define WIFI_START 1
      #define MQTT_DEMO_MSG_TEXT "mqtt demo test"
      #define LED_PORT           GPIO_PORT_A
      #define LED_PIN            GPIO_PIN_21
      static void led_init(void)
      	GPIO_InitParam param;
      	param.driving = GPIO_DRIVING_LEVEL_1;
      	param.mode = GPIOx_Pn_F1_OUTPUT;
      	param.pull = GPIO_PULL_NONE;
      	HAL_GPIO_Init(LED_PORT, LED_PIN, &param);
      static void led_ctl(uint8_t level)
      	HAL_GPIO_WritePin(LED_PORT, LED_PIN, level ? GPIO_PIN_HIGH : GPIO_PIN_LOW);
      void wifi_scan_connect(){
      	if(WIFI_SUCCESS != EnableWifi()){
      		printf("Error:wifi enable fail!\n");
      		return;
      	if(WIFI_SUCCESS != Scan()){
      		printf("Error:wifi scan fail!\n");
      	printf("WIFI SCAN STARTED!\n");
      	OS_Sleep(3);
      	WifiScanInfo scan_result[30];
      	unsigned int scan_num = 30;
      	if(WIFI_SUCCESS != GetScanInfoList(scan_result, &scan_num)){
      		printf("Error: get scan result fail!\n");
      		return;
      	printf("Scan successful,you've got:\n");
      	for(int i = 0;i < scan_num;i++){
      		printf("SSID: %s ",scan_result[i].ssid);
      		printf("RSSI: %d",scan_result[i].rssi);
      	printf("Scan End \n");
      	const char ssid_want_connect[] = WIFI_DEVICE_CONNECT_AP_SSID;
      	const char psk[] = WIFI_DEVICE_CONNECT_AP_PSK;
      	printf("Connecting...");
      	if(WIFI_STA_ACTIVE == IsWifiActive()){
      		printf("Wifi is active.\n");
      	OS_Sleep(1);
      	WifiDeviceConfig config = {0};
      	int netId = 0;
      	int i;
      	for(i = 0;i < scan_num;i++){
      		if(0 == strcmp(scan_result[i].ssid, ssid_want_connect)){
      			memcpy(config.ssid, scan_result[i].ssid, WIFI_MAX_SSID_LEN);
      			memcpy(config.bssid, scan_result[i].bssid, WIFI_MAC_LEN);
      			config.securityType = scan_result[i].securityType;
      			config.freq = scan_result[i].frequency;
      			break;
      	if(i >= scan_num){
      		printf("Error: No SSID SET FOUND!\n");
      		return;
      	printf("Found Correct SSID in Scan List!\n");
      	if(WIFI_SUCCESS != AddDeviceConfig(&config, &netId)){
      		printf("Error: Add Device config failed!\n");
      		return;
      	printf("Add Device Config successful!\n");
      	if(WIFI_SUCCESS != ConnectTo(netId)){
      		printf("Error: Connect to Wifi FAILED!\n");
      		return;
      	printf("Connect to %s successful!\n",config.ssid);
      	OS_Sleep(3);
      static int mqtt_demo_init(void)
      	char *send_buf;
      	char *recv_buf;
      	/* init client id */
      	mqtt_demo_connectData.clientID.cstring = MQTT_DEMO_CLIENT_ID;
      	/* init keep alive interval */
      	mqtt_demo_connectData.keepAliveInterval = 30; // 30s
      	/* enable session reuse */
      	mqtt_demo_connectData.cleansession = 0;
      	/* set mqtt version */
      	mqtt_demo_connectData.MQTTVersion = 4; //Version of MQTT 3.1.1
      	/* send/recv buffer must free when mqtt deinit */
      	send_buf = malloc(MQTT_DEMO_BUF_SIZE);
      	if (send_buf == NULL) {
      		printf("no memory\n");
      		return -1;
      	recv_buf = malloc(MQTT_DEMO_BUF_SIZE);
      	if (recv_buf == NULL) {
      		free(send_buf);
      		return -1;
      	/* init network */
      	NewNetwork(&mqtt_demo_network);
      	/* init mqtt client object */
      	MQTTClient(&mqtt_demo_client, &mqtt_demo_network, 6000,
      	           (unsigned char *)send_buf, MQTT_DEMO_BUF_SIZE,
      	           (unsigned char *)recv_buf, MQTT_DEMO_BUF_SIZE);
      	 * set will function, when this client disconnect,
      	 * server will sent the message to every client in MQTT_DEMO_TOPIC
      	mqtt_demo_connectData.willFlag = 1;
      	mqtt_demo_connectData.will.topicName.cstring = MQTT_DEMO_TOPIC;
      	mqtt_demo_connectData.will.message.cstring = "I am disconnected";
      	mqtt_demo_connectData.will.retained = 0;
      	mqtt_demo_connectData.will.qos = 0;
      	/* set username and password */
      	mqtt_demo_connectData.username.cstring = MQTT_DEMO_USERNAME;
      	mqtt_demo_connectData.password.cstring = MQTT_DEMO_PASSWORD;
      static int mqtt_demo_connect(char *host_name, char *host_port)
      	int ret = -1;
      	/* need connect the server in tcp level first, if use ssl, use TLSConnectNetwork() */
      	ret = ConnectNetwork(&mqtt_demo_network, host_name, atoi(host_port));
      	if (ret != 0) {
      		printf("mqtt connect faild, ret:%d, host:%s, port:%s\n", ret, host_name, host_port);
      		goto exit;
      	/* if tcp level connected, then connect mqtt level */
      	ret = MQTTConnect(&mqtt_demo_client, &mqtt_demo_connectData);
      	if (ret != 0) {
      		printf("mqtt connect faild, ret:%d\n", ret);
      		/* disconnect the tcp level */
      		mqtt_demo_network.disconnect(&mqtt_demo_network);
      		goto exit;
      	printf("mqtt connected\n");
      exit:
      	return ret;
      static void mqtt_demo_msg_cb(MessageData *data)
      	char topic_buf[20]={0};
      	char payload_buf[20]={0};
      	memcpy(topic_buf, data->topicName->lenstring.data, data->topicName->lenstring.len);
      	memcpy(payload_buf,(char *)data->message->payload, data->message->payloadlen);
      	printf("get a message, topic: %s, msg: %s\n", topic_buf, payload_buf);
      	if(strcmp(topic_buf,"/topic/led") == 0){
      		if(strcmp((char *)payload_buf,"led8 on") == 0){
      			led_ctl(1);
      			printf("led1 on\r\n");
      		else if(strcmp((char *)payload_buf,"led8 off") == 0){
      			led_ctl(0);
      			printf("led1 off\r\n");
      static int mqtt_demo_subscribe(char *topic)
      	int ret = -1;
      	if (mqtt_demo_client.isconnected) {
      		/* set the message callback */
      		ret = MQTTSubscribe(&mqtt_demo_client, topic, 0, mqtt_demo_msg_cb);
      		if (ret != 0)
      			printf("mqtt subscribe faild ret:%d\n", ret);
      	return ret;
      static int mqtt_demo_unsubscribe(char *topic)
      	int ret = -1;
      		ret = MQTTUnsubscribe(&mqtt_demo_client, topic);
      		if (ret != 0)
      			printf("mqtt unsubscribe faild, ret:%d\n", ret);
      	return ret;
      static int mqtt_demo_publish(char *topic, char *msg)
      	int ret = -1;
      	MQTTMessage message;
      	memset(&message, 0, sizeof(message));
      	message.qos = 0;
      	message.retained = 0; /* disable retain the message in server */
      	message.payload = msg;
      	message.payloadlen = strlen(msg);
      	ret = MQTTPublish(&mqtt_demo_client, topic, &message);
      	if (ret != 0)
      		printf("mqtt publish faild, ret:%d\n", ret);
      	return ret;
      static int mqtt_demo_disconnect(void)
      	int ret = -1;
      		/* need disconnect mqtt level first */
      		ret = MQTTDisconnect(&mqtt_demo_client);
      		if (ret != 0)
      			printf("mqtt disconnect fail, ret:%d\n", ret);
      		/* then disconnect tcp level */
      	return ret;
      static void mqtt_demo_deinit(void)
      	if (mqtt_demo_client.buf) {
      		free(mqtt_demo_client.buf);
      		mqtt_demo_client.buf = NULL;
      	if (mqtt_demo_client.readbuf) {
      		free(mqtt_demo_client.readbuf);
      		mqtt_demo_client.readbuf = NULL;
      static void mqtt_demo_fun(void *arg)
      	// uint8_t level = 1;
      	int ret;
      	int reconnect_times = 0;
      	short int int_temp=0;
      	char temp_buf[10]={0};
      	led_init();
      	DS18B20_Init();			//初始化DS18B20
      	wifi_scan_connect();
      	/* mqtt init */
      	mqtt_demo_init();
      	/* mqtt connect */
      re:
      	ret = mqtt_demo_connect(MQTT_DEMO_HOST_NAME, MQTT_DEMO_PORT);
      	if (ret != 0)
      		OS_MSleep(500);
      		goto re;
      	/* subscribe topic */
      	ret = mqtt_demo_subscribe(MQTT_DEMO_TOPIC);
      	if (ret != 0)
      		goto exit;
      	while (1) {
      		int_temp = DS18B20_Get_Temp();
      		sprintf(temp_buf,"%d.%d",int_temp/10, abs(int_temp%10));
      		printf("temp:%s\r\n", temp_buf);
      		/* publish message to topic */
      		mqtt_demo_publish("/topic/temp", temp_buf);
      		ret = MQTTYield(&mqtt_demo_client, 300);
      		if (ret != 0) {
      			printf("mqtt yield err, ret:%d\n", ret);
      reconnect:
      			printf("mqtt reconnect\n");
      			mqtt_demo_disconnect();
      			if (ret != 0) {
      				reconnect_times++;
      				if (reconnect_times > 5)
      					goto exit;
      				OS_MSleep(5000); //5s
      				goto reconnect;
      		// level = (!level & 0x01);
      		// led_ctl(level);
      		OS_MSleep(1000); //1s
      exit:
      	mqtt_demo_unsubscribe(MQTT_DEMO_TOPIC);
      	mqtt_demo_deinit();
      	OS_ThreadDelete(&mqtt_demo_thread);
      int mqtt_entry(void)
      	if (OS_ThreadCreate(&mqtt_demo_thread, "mqtt_demo_thread", mqtt_demo_fun, NULL,
      			                OS_THREAD_PRIO_APP,
      			                8 * 1024) != OS_OK) {
      SYS_RUN(mqtt_entry);
      • device\xradio\xr806\ohosdemo\mqtt\BUILD.gn;
      import("//device/xradio/xr806/liteos_m/config.gni")     #必须,config中定义了头文件路径和关键宏定义
      static_library("app_mqtttest") {                             #必须,所有应用工程必须是app_打头
         configs = []
         sources = [
            "main.c",
            "ds18b20.c",
         cflags = board_cflags                                #必须,board_cflags是在config.gni中定义的关键宏定义
         include_dirs = board_include_dirs                    #必须,board_include_dirs是在config.gni中定义的文件路径
         include_dirs += [
            "//device/xradio/xr806/xr_skylark/include/net/mqtt/MQTTClient-C",
            "//device/xradio/xr806/xr_skylark/project",
      第四步 编译下载
      • 编译:hb build -f命令开始编译
      • 烧写程序:在下载器设置里勾选下载后重启(由于注释掉了控制台,所以没复位功能了,复位需要拔掉电源线)
      第五步 验证效果
      1.打开串口助手,每秒会输出一次温度
      2. 在电脑上打开MQTT.fx软件连接上对应的MQTT服务器,并阅订“/topic/temp”主题,每秒会接收到一次开发板传来的温度
      3. 在电脑上打开MQTT.fx软件连接上对应的MQTT服务器发布“/topic/led”主题,内容“led8 on”,就可以远程打开开发板上的LED,发布“led8 off”就可以关开发板上的LED
