    d1s 哪吒mq spi 怎麼搞
    3764
    • K
      kingz1993 LV 2 最后由 编辑
      内核log:
      • tigger
        tigger LV 7 最后由 编辑
        多秀点log看看
        K 1 条回复 最后回复 回复 引用 分享 0
        • K
          kingz1993 LV 2 @tigger 最后由 whycan 编辑
          @tigger
          [32]HELLO! BOOT0 is starting!
          [34]BOOT0 commit : 603490b
          [37]set pll start
          [39]periph0 has been enabled
          [42]set pll end
          [43][pmu]: bus read error
          [46]board init ok
          [47]ZQ value = 0x2e***********
          [50]get_pmu_exist() = -1
          [53]ddr_efuse_type: 0xa
          [55][AUTO DEBUG] single rank and full DQ!
          [59]ddr_efuse_type: 0xa
          [62][AUTO DEBUG] rank 0 row = 13
          [65][AUTO DEBUG] rank 0 bank = 4
          [68][AUTO DEBUG] rank 0 page size = 2 KB
          [72]DRAM BOOT DRIVE INFO: V0.24
          [75]DRAM CLK = 528 MHz
          [77]DRAM Type = 2 (2:DDR2,3:DDR3)
          [80]DRAMC read ODT  off.
          [83]DRAM ODT off.
          [84]ddr_efuse_type: 0xa
          [87]DRAM SIZE =64 M
          [91]DRAM simple test OK.
          [93]dram size =64
          [95]card no is 0
          [96]sdcard 0 line count 4
          [99][mmc]: mmc driver ver 2021-04-2 16:45
          [108][mmc]: Wrong media type 0x0
          [111][mmc]: ***Try SD card 0***
          [119][mmc]: HSSDR52/SDR25 4 bit
          [122][mmc]: 50000000 Hz
          [124][mmc]: 30528 MB
          [126][mmc]: ***SD/MMC 0 init OK!!!***
          [174]Loading boot-pkg Succeed(index=0).
          [178]Entry_name        = opensbi
          [181]Entry_name        = u-boot
          [185]Entry_name        = dtb
          [187]mmc not para
          [189]Jump to second Boot.
          OpenSBI v0.6
                  |_|
          Platform Max HARTs     : 1
          Current Hart           : 0
          Runtime SBI Version    : 0.2
          MIDELEG : 0x0000000000000222
          MEDELEG : 0x000000000000b1ff
          PMP3    : 0x0000000000020000-0x0000000000027fff (A,�[00.266][mmc]: mmc driver v1
          [00.272][mmc]: get sdc_type fail and use default host:tm1.
          [00.278][mmc]: can't find node "mmc0",will add new node
          [00.283][mmc]: fdt err returned <no error>
          [00.287][mmc]: Using default timing para
          [00.290][mmc]: SUNXI SDMMC Controller Version:0x50310
          [00.308][mmc]: card_caps:0x3000000a
          [00.311][mmc]: host_caps:0x3000003f
          [00.326]set disp.dev2_output_type fail. using defval=0
          [00.348]Get bootloader and boot-resource partition number fail!
          [00.376]out of usb burn from boot: not need burn key
          [01.801]
          Starting kernel ...
          [01.804][mmc]: MMC Device 2 not found
          [01.807][mmc]: mmc 2 not find, so not exit
          [    0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
          [    0.000000] Linux version 5.4.61 (kimg@kimg-A320MH) (riscv64-unknown-linux-g2
          [    0.000000] cma: Reserved 8 MiB at 0x0000000043800000
          [    0.000000] Zone ranges:
          [    0.000000]   DMA32    [mem 0x0000000040200000-0x0000000043ffffff]
          [    0.000000]   node   0: [mem 0x0000000040200000-0x0000000043ffffff]
          [    0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x0000000043ffffff]
          [    0.000000] On node 0 totalpages: 15872
          [    0.000000]   DMA32 zone: 217 pages used for memmap
          [    0.000000]   DMA32 zone: 15872 pages, LIFO batch:3
          [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15655
          [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignor
          [    0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, li)
          [    0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, lin)
          [    0.000000] Memory: 40096K/63488K available (5842K kernel code, 550K rwdata,)
          [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 ji.
          [    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycs
          [    0.000006] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398s
          [    0.000026] riscv_timer_clockevent depends on broadcast, but no broadcast fue
          [    0.000366] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, maxs
          [    0.001003] Console: colour dummy device 80x25
          [    0.001048] Calibrating delay loop (skipped), value calculated using timer f)
          [    0.001067] pid_max: default: 32768 minimum: 301
          [    0.001282] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linea)
          [    0.001301] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, )
          [    0.003373] ASID allocator initialised with 65536 entries
          [    0.003580] rcu: Hierarchical SRCU implementation.
          [    0.004323] devtmpfs: initialized
          [    0.018321] random: get_random_u32 called from bucket_table_alloc.isra.31+0x0
          [    0.019274] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
          [    0.019306] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
          [    0.019840] pinctrl core: initialized pinctrl subsystem
          [    0.021437] NET: Registered protocol family 16
          [    0.023437] DMA: preallocated 256 KiB pool for atomic allocations
          [    0.024164] cpuidle: using governor menu
          [    0.064585] rtc_ccu: sunxi ccu init OK
          [    0.074427] clock: sunxi ccu init OK
          [    0.075539] clock: sunxi ccu init OK
          [    0.115049] iommu: Default domain type: Translated
          [    0.115252] sunxi iommu: irq = 4
          [    0.116489] SCSI subsystem initialized
          [    0.116888] usbcore: registered new interface driver usbfs
          [    0.116986] usbcore: registered new interface driver hub
          [    0.117120] usbcore: registered new device driver usb
          [    0.117309] mc: Linux media interface: v0.10
          [    0.117376] videodev: Linux video capture interface: v2.00
          [    0.118644] sunxi-msgbox-amp 3003000.msgbox: invalid resource
          [    0.119431] Advanced Linux Sound Architecture Driver Initialized.
          [    0.120077] Bluetooth: Core ver 2.22
          [    0.120167] NET: Registered protocol family 31
          [    0.120179] Bluetooth: HCI device and connection manager initialized
          [    0.120204] Bluetooth: HCI socket layer initialized
          [    0.120221] Bluetooth: L2CAP socket layer initialized
          [    0.120260] Bluetooth: SCO socket layer initialized
          [    0.120700] pwm module init!
          [    0.122324] g2d 5410000.g2d: Adding to iommu group 0
          [    0.122901] G2D: rcq version initialized.major:250
          [    0.124372] clocksource: Switched to clocksource riscv_clocksource
          [    0.137573] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
          [    0.156317] thermal_sys: Registered thermal governor 'step_wise'
          [    0.156324] thermal_sys: Registered thermal governor 'user_space'
          [    0.156928] NET: Registered protocol family 2
          [    0.157835] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096)
          [    0.157895] TCP established hash table entries: 512 (order: 0, 4096 bytes, l)
          [    0.157916] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
          [    0.157931] TCP: Hash tables configured (established 512 bind 512)
          [    0.158100] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
          [    0.158145] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
          [    0.158418] NET: Registered protocol family 1
          [    0.159689] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc r
          [    0.160329] spi spi0: spi0 supply spi not found, using dummy regulator
          [    0.160617] sunxi_spi_resource_get()2062 - [spi0] SPI MASTER MODE
          [    0.160752] sunxi_spi_clk_init()2138 - [spi0] mclk 100000000
          [    0.161572] sunxi_spi_probe()2542 - [spi0]: driver probe succeed, base fffff1
          [    0.163592] Initialise system trusted keyrings
          [    0.163846] workingset: timestamp_bits=62 max_order=14 bucket_order=0
          [    0.171760] squashfs: version 4.0 (2009/01/31) Phillip Lougher
          [    0.192168] Key type asymmetric registered
          [    0.192187] Asymmetric key parser 'x509' registered
          [    0.192214] io scheduler mq-deadline registered
          [    0.192223] io scheduler kyber registered
          [    0.192244] atomic64_test: passed
          [    0.194506] sunxi_sid_init()506 - insmod ok
          [    0.202951] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe r
          [    0.203439] uart uart0: get regulator failed
          [    0.203470] uart uart0: uart0 supply uart not found, using dummy regulator
          [    0.203872] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) iI
          [    0.203902] sw_console_setup()1808 - console setup baud 115200 parity n bitsn
          [    0.914150] printk: console [ttyS0] enabled
          [    0.919806] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg r
          [    0.931329] uart uart1: get regulator failed
          [    0.936166] uart uart1: uart1 supply uart not found, using dummy regulator
          [    0.944215] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) iI
          [    0.953810] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb r
          [    0.965263] uart uart3: get regulator failed
          [    0.970044] uart uart3: uart3 supply uart not found, using dummy regulator
          [    0.978210] uart3: ttyS3 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) iI
          [    0.988232] misc dump reg init
          [    0.992563] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
          [    0.999827] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
          [    1.007448] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
          [    1.014771] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
          [    1.022160] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
          [    1.028703] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
          [    1.035666] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
          [    1.043507] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert1
          [    1.051653] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
          [    1.059336] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
          [    1.066138] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
          [    1.074269] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
          [    1.081930] [ADDR_MGT] addr_mgt_probe: success.
          [    1.088487] libphy: Fixed MDIO Bus: probed
          [    1.093064] CAN device driver interface
          [    1.097741] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
          [    1.105076] sunxi-ehci: EHCI SUNXI driver
          [    1.110118] get ehci0-controller wakeup-source is fail.
          [    1.116116] sunxi ehci0-controller don't init wakeup source
          [    1.122342] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxe
          [    1.135858] [sunxi-ehci0]: Not init ehci0
          [    1.140744] get ehci1-controller wakeup-source is fail.
          [    1.146742] sunxi ehci1-controller don't init wakeup source
          [    1.152967] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunx1
          [    1.166507] hci: sunxi_insmod_ehci()600 WARN: get supply failed
          [    1.173151] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
          [    1.180412] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, ass1
          [    1.190288] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
          [    1.224415] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
          [    1.233295] hub 1-0:1.0: USB hub found
          [    1.237633] hub 1-0:1.0: 1 port detected
          [    1.242930] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
          [    1.249952] sunxi-ohci: OHCI SUNXI driver
          [    1.255036] get ohci0-controller wakeup-source is fail.
          [    1.260983] sunxi ohci0-controller don't init wakeup source
          [    1.267261] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunx0
          [    1.277670] [sunxi-ohci0]: Not init ohci0
          [    1.282539] get ohci1-controller wakeup-source is fail.
          [    1.288546] sunxi ohci1-controller don't init wakeup source
          [    1.294812] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunx0
          [    1.305246] hci: sunxi_insmod_ohci()265 WARN: get supply failed
          [    1.311892] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
          [    1.319177] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, ass2
          [    1.329012] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
          [    1.409508] hub 2-0:1.0: USB hub found
          [    1.413769] hub 2-0:1.0: 1 port detected
          [    1.419445] usbcore: registered new interface driver uas
          [    1.425658] usbcore: registered new interface driver usb-storage
          [    1.432436] usbcore: registered new interface driver ums-alauda
          [    1.439219] usbcore: registered new interface driver ums-cypress
          [    1.446071] usbcore: registered new interface driver ums-datafab
          [    1.452853] usbcore: registered new interface driver ums_eneub6250
          [    1.459884] usbcore: registered new interface driver ums-freecom
          [    1.466714] usbcore: registered new interface driver ums-isd200
          [    1.473387] usbcore: registered new interface driver ums-jumpshot
          [    1.480316] usbcore: registered new interface driver ums-karma
          [    1.486954] usbcore: registered new interface driver ums-onetouch
          [    1.493864] usbcore: registered new interface driver ums-realtek
          [    1.500707] usbcore: registered new interface driver ums-sddr09
          [    1.507442] usbcore: registered new interface driver ums-sddr55
          [    1.514137] usbcore: registered new interface driver ums-usbat
          [    1.521244] mousedev: PS/2 mouse device common for all mice
          [    1.528352] ts probe start
          [    1.528808] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/0
          [    1.541447] ts probe success
          [    1.541842] sunxi_gpadc_init,1968, success
          [    1.551937] sunxi-rtc 7090000.rtc: registered as rtc0
          [    1.557741] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:23:)
          [    1.566928] sunxi-rtc 7090000.rtc: sunxi rtc probed
          [    1.572753] i2c /dev entries driver
          [    1.576820] IR NEC protocol handler initialized
          [    1.581873] IR RC5(x/sz) protocol handler initialized
          [    1.587541] IR RC6 protocol handler initialized
          [    1.592591] IR JVC protocol handler initialized
          [    1.597666] IR Sony protocol handler initialized
          [    1.602813] IR SANYO protocol handler initialized
          [    1.608080] IR Sharp protocol handler initialized
          [    1.613322] IR MCE Keyboard/mouse protocol handler initialized
          [    1.619848] IR XMP protocol handler initialized
          [    1.624921] ir_imon_decoder: IR iMON protocol handler initialized
          [    1.631714] IR RCMM protocol handler initialized
          [    1.637584] sunxi cedar version 1.1
          [    1.641749] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
          [    1.648052] VE: install start!!!
          [    1.648052]
          [    1.653588] VE: cedar-ve the get irq is 6
          [    1.653588]
          [    1.659984] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), )
          [    1.659984]
          [    1.671580] VE: install end!!!
          [    1.671580]
          [    1.678168] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, no)
          [    1.687335] Bluetooth: HCI UART driver ver 2.3
          [    1.692294] Bluetooth: HCI UART protocol H4 registered
          [    1.698072] Bluetooth: HCI UART protocol BCSP registered
          [    1.703996] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
          [    1.711318] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
          [    1.717758] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
          [    1.724292] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
          [    1.724292]
          [    1.732973] [XR_BT_LPM] bluesleep_probe: uart_index(1)
          [    1.741909] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.1)
          [    1.751925] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
          [    1.758147] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
          [    1.764487] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
          [    1.770893] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
          [    1.777329] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
          [    1.783832] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
          [    1.790363] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
          [    1.796895] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
          [    1.803918] sunxi-mmc 4020000.sdmmc: Got CD GPIO
          [    1.809456] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
          [    1.816191] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 B
          [    1.827351] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
          [    1.847509] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdB
          [    1.871980] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
          [    1.877709] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdB
          [    1.890026] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.1)
          [    1.900189] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
          [    1.906449] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
          [    1.912818] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
          [    1.919289] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdB
          [    1.930871] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
          [    1.937315] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
          [    1.943821] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
          [    1.950468] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
          [    1.957046] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
          [    1.963629] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check id
          [    1.972696] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdB
          [    1.985239] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 B
          [    1.996451] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
          [    2.005363] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdB
          [    2.016964] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdB
          [    2.041288] sunxi-mmc 4021000.sdmmc: detmode:manually by software
          [    2.048998] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [    2.056633] usbcore: registered new interface driver usbhid
          [    2.062896] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [    2.069807] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdB
          [    2.081434] usbhid: USB HID core driver
          [    2.086037] fbtft_of_value: width = 240
          [    2.090434] fbtft_of_value: height = 320
          [    2.094938] fbtft_of_value: buswidth = 8
          [    2.099415] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdB
          [    2.111033] mmc0: host does not support reading read-only switch, assuming we
          [    2.120011] fbtft_of_value: debug = 0
          [    2.124094] fbtft_of_value: rotate = 0
          [    2.128343] fbtft_of_value: fps = 60
          [    2.132374] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdB
          [    2.145633] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.153525] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    2.160417] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON B
          [    2.172073] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    2.179686] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    2.187262] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    2.193998] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 B
          [    2.205161] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON B
          [    2.225853] mmc0: new high speed SDHC card at address 0001
          [    2.245494] mmcblk0: mmc0:0001 00000 29.8 GiB
          [    2.281689] GPT:Primary header thinks Alt. header is not at the end of the d.
          [    2.304395] GPT:166400 != 62521343
          [    2.308176] GPT:Alternate GPT header not at the end of the disk.
          [    2.324393] GPT:166400 != 62521343
          [    2.328184] GPT: Use GNU Parted to correct GPT errors.
          [    2.333964]  mmcblk0: p1 p2 p3 p4
          [    2.382614] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.390660] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.398697] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.406724] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.414758] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.422740] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.430771] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.438806] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.446834] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.454866] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.462851] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.470883] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.478917] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.486945] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.494978] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.502962] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.510995] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.519029] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.527056] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.535086] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.543069] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.551102] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.559135] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.567163] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.575194] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.583179] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.591245] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.602798] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.614283] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.625765] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.637206] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.648689] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.660176] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.671653] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.683139] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.694622] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.706064] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.717509] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.728997] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.740477] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.751964] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.763444] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.774931] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.786373] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.797809] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.809298] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.820781] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.832262] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.843744] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.855225] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.866667] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.878150] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.889637] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.901118] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.912606] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.924088] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.935578] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.947021] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.958508] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.969990] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.981474] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    2.992956] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    3.004479] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    3.015911] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    3.025687] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    3.033680] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    3.041728] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    3.049762] spi_set_clk()520 - [spi0] set spi clock failed, use clk:10000000
          [    3.058209] graphics fb0: fb_st7789v frame buffer, 240x320, 150 KiB video mez
          [    3.073386] usbcore: registered new interface driver snd-usb-audio
          [    3.084292] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp!
          [    3.095937] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0d
          [    3.108170] NET: Registered protocol family 10
          [    3.114791] Segment Routing with IPv6
          [    3.119094] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
          [    3.126697] NET: Registered protocol family 17
          [    3.131732] can: controller area network core (rev 20170425 abi 9)
          [    3.138850] NET: Registered protocol family 29
          [    3.143817] can: raw protocol (rev 20170425)
          [    3.148621] can: broadcast manager protocol (rev 20170425 t)
          [    3.154971] can: netlink gateway (rev 20190810) max_hops=1
          [    3.161463] Bluetooth: RFCOMM TTY layer initialized
          [    3.167043] Bluetooth: RFCOMM socket layer initialized
          [    3.172806] Bluetooth: RFCOMM ver 1.11
          [    3.178084] Loading compiled-in X.509 certificates
          [    3.210464] twi twi2: twi2 supply twi not found, using dummy regulator
          [    3.223508] sunxi_i2c_probe()2262 - [i2c2] probe success
          [    3.234981] cfg80211: Loading compiled-in X.509 certificates for regulatory e
          [    3.246379] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [    3.253847] platform regulatory.0: Direct firmware load for regulatory.db fa2
          [    3.263675] clk: Not disabling unused clocks
          [    3.268556] cfg80211: failed to load regulatory.db
          [    3.273998] ALSA device list:
          [    3.277467]   No soundcards found.
          [    3.289377] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. )
          [    3.298606] VFS: Mounted root (ext4 filesystem) readonly on device 179:4.
          [    3.307174] devtmpfs: mounted
          [    3.310802] Freeing unused kernel memory: 272K
          [    3.315810] This architecture does not have kernel memory protection.
          [    3.322994] Run /sbin/init as init process
          [    3.460488] EXT4-fs (mmcblk0p4): re-mounted. Opts: (null)
          Starting syslogd: OK
          Starting klogd: OK
          Running sysctl: OK
          Populating /dev using udev: [    3.730620] udevd[99]: starting version 3.2.9
          [    3.743803] random: fast init done
          [    3.748886] random: udevd: uninitialized urandom read (16 bytes read)
          [    3.757949] random: udevd: uninitialized urandom read (16 bytes read)
          [    3.765815] random: udevd: uninitialized urandom read (16 bytes read)
          [    3.817222] udevd[100]: starting eudev-3.2.9
          [    6.844401]
          [    6.844401] insmod_device_driver
          [    6.844401]
          done
          Welcome to Buildroot
          buildroot login:
          tigger 1 条回复 最后回复 回复 引用 分享 0
          • tigger
            tigger LV 7 @kingz1993 最后由 编辑
            @kingz1993
            dts 是怎么配置的呢?
