    百问网韦老师 D1 开发板 ---- 东山哪吒STU
    d1 东山派 东山哪吒stu
    12
    8729
      whycan晕哥 LV 9 最后由 whycan 编辑
      购买链接: https://item.taobao.com/item.htm?id=669363784178
        验证体验东山哪吒STU开发板,更详细的配套视频的文档,我们将会在下周同步推出,敬请期待!
        https://riscv64.dongshanpi.com/DongshanNezhaSTU/03-QuickStart/
        https://riscv64.dongshanpi.com/DongshanNezhaSTU/05-Tina-SDKDevelopmentGuide/
          待编辑 .......
              待编辑 .......
              • baiwen
                100ask LV 6 最后由 编辑
                @whycan 在 D1 开发板 东山哪吒STU 中说:
                验证体验东山哪吒ST
                晕哥拍照就是帅😍
                  【固件发布】D1哪吒HDMI测试固件20210804(开机HDMI就有小企鹅启动logo)
                  https://bbs.aw-ol.com/topic/297/share/3
                  这个demo直接可以运行,无需LCD,只要接HDMI显示器即可。
                    添加 SPI NOR FLASH 支持
                    device/config/chips/d1/configs/hdmionly/linux-5.4/config-5.4 添加配置:
                    CONFIG_MTD_SPI_NOR=y
                    device/config/chips/d1/configs/hdmionly/linux-5.4/board.dts 关于 spi0 的配置:
                    &spi0 {
                            pinctrl-1 = <&spi0_pins_c>;
                            spi_slave_mode = <0>;
                            spi0_cs_number = <1>;
                            spi0_cs_bitmap = <1>;
                            spi-nand@0 {
                                    compatible = "spi-nand";
                                    spi-max-frequency=<0x5F5E100>;
                                    reg = <0x0>;
                                    spi-rx-bus-width=<0x04>;
                                    spi-tx-bus-width=<0x04>;
                                    status="disabled";
                            spi-nor@0 {
                                    compatible = "jedec,spi-nor";
                                    spi-max-frequency=<30000000>;
                                    reg = <0x0>;
                                    spi-rx-bus-width=<0x01>;
                                    spi-tx-bus-width=<0x01>;
                                    status="okay";
                    启动日志:
                    [    1.185294] spi-nor spi0.0: s25fl064k (8192 Kbytes)
                    [    1.193668] libphy: Fixed MDIO Bus: probed
                    [    1.198241] CAN device driver interface
                      board.dts
                      删除PC3:
                              spi0_pins_a: spi0@0 {
                                      pins = "PC2", "PC4", "PC5","PC7", "PC6"; /*clk mosi miso hold wp*/
                                      function = "spi0";
                                      muxsel = <2>;
                                      drive-strength = <10>;
                              spi0_pins_b: spi0@1 {
                                      pins = "PC7", "PC6";
                                      function = "spi0";
                                      muxsel = <2>;
                                      bias-pull-up;   /* only CS should be pulled up */
                              spi0_pins_c: spi0@2 {
                                      pins = "PC2", "PC4", "PC5","PC6", "PC7";
                                      function = "gpio_in";
                                      muxsel = <0>;
                      spi0 配置:
                      &spi0 {
                              cs-gpios = <&pio PC 3 GPIO_ACTIVE_HIGH>, <&pio PC 0 GPIO_ACTIVE_HIGH>;
                              spi-nor@0 {
                                      reg = <0x0>;//片选0
                                      status="okay";
                              spi-nor@1 {
                                      reg = <0x1>;//片选1
                                      status="okay";
                      启动日志:
                      [    1.197328] spi-nor spi0.0: s25fl064k (8192 Kbytes)
                      [    1.205463] spi-nor spi0.1: mx25l12805d (16384 Kbytes)
                      1 条回复 最后回复 回复 引用 分享 4
                      • baiwen
                        100ask LV 6 最后由 编辑
                        好多flash哇🤔 焊接技术
                          yixiuge LV 5 最后由 编辑
                          我和我的小伙伴都惊呆了,居然这么叠罗汉!
                          • tigger
                            tigger LV 7 最后由 编辑
                            @yixiuge
                            想知道最多可以叠几个?
