    D1 make时出错
    • F
      flyer LV 2 最后由 编辑
      D1哪吒开发板,按照步骤编译打包时出错,执行下面命令:
      source build/envsetup.sh
      lunch d1_nezha-tina
      make -j1
      make时出错,这个要怎么解决,谢谢。
      lp0603@ubuntu:~/tina-d1-open$ make -j1
      ===This's tina environment.===
      no need rebuild boot0, the newest file is:
      1622766287.7340362560 Thu 03 Jun 2021 05:24:47 PM PDT /home/lp0603/tina-d1-open/lichee/brandy-2.0/spl/nboot/libsun20iw1p1_spinor.o
      no need rebuild uboot, the newest file is:
      1622766418.7700388440 Thu 03 Jun 2021 05:26:58 PM PDT /home/lp0603/tina-d1-open/lichee/brandy-2.0/u-boot-2018/u-boot.cfg.configs
      === Start build scp.bin ===
      Platform d1 Skip marisc.
      [1] 2728
      build server start.
      Collecting package info: done
      Collecting target info: done
      make[1]: Entering directory /home/lp0603/tina-d1-open' make[2]: Entering directory /home/lp0603/tina-d1-open'
      make[3]: Entering directory /home/lp0603/tina-d1-open/target/allwinner' make[4]: Entering directory /home/lp0603/tina-d1-open/target/allwinner/d1-nezha'
      /home/lp0603/tina-d1-open/scripts/kconfig.pl + /home/lp0603/tina-d1-open/target/allwinner/generic/config-5.4 /home/lp0603/tina-d1-open/device/config/chips/d1/configs/nezha/linux/config-5.4 > /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.target
      awk '/^(#[[:space:]]+)?CONFIG_KERNEL/{sub("CONFIG_KERNEL_","CONFIG_");print}' /home/lp0603/tina-d1-open/.config >> /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.target
      echo "# CONFIG_KALLSYMS_EXTRA_PASS is not set" >> /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.target
      echo "# CONFIG_KALLSYMS_ALL is not set" >> /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.target
      echo "CONFIG_KALLSYMS_UNCOMPRESSED=y" >> /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.target
      /home/lp0603/tina-d1-open/scripts/metadata.pl kconfig /home/lp0603/tina-d1-open/tmp/.packageinfo /home/lp0603/tina-d1-open/.config 5.4 > /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.override
      /home/lp0603/tina-d1-open/scripts/kconfig.pl 'm+' '+' /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.target /dev/null /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.override > /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.set
      mv /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.set /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.old
      grep -v INITRAMFS /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.old > /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.set
      echo 'CONFIG_INITRAMFS_SOURCE=""' >> /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.set
      rm -rf /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/modules
      cmp -s /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.set /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.prev || { cp /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.set /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config; cp /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.set /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.prev; }
      update .config
      export MAKEFLAGS= ; [ -f /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config ] || cp /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.set /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config
      export MAKEFLAGS= ; make -C /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61 HOSTCFLAGS="-O2 -I/home/lp0603/tina-d1-open/out/host/include -I/home/lp0603/tina-d1-open/out/host/usr/include -Wall -Wmissing-prototypes -Wstrict-prototypes" CROSS_COMPILE="riscv64-unknown-linux-gnu-" ARCH="riscv" KBUILD_HAVE_NLS=no KBUILD_BUILD_USER="" KBUILD_BUILD_HOST="" CONFIG_SHELL="bash" V='' EXTRA_LDSFLAGS="-I/home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha -include symtab.h" CC="riscv64-unknown-linux-gnu-gcc" INSTALL_HDR_PATH=/home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/user_headers headers_install
      make[5]: Entering directory /home/lp0603/tina-d1-open/lichee/linux-5.4' INSTALL /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/user_headers/include make[5]: Leaving directory /home/lp0603/tina-d1-open/lichee/linux-5.4'
      . /home/lp0603/tina-d1-open/build/shell.sh; grep '=[ym]' /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.config.set | LC_ALL=C sort | md5s > /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.vermagic
      touch /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.configured
      rm -f /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/vmlinux /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/System.map
      make -C /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61 HOSTCFLAGS="-O2 -I/home/lp0603/tina-d1-open/out/host/include -I/home/lp0603/tina-d1-open/out/host/usr/include -Wall -Wmissing-prototypes -Wstrict-prototypes" CROSS_COMPILE="riscv64-unknown-linux-gnu-" ARCH="riscv" KBUILD_HAVE_NLS=no KBUILD_BUILD_USER="" KBUILD_BUILD_HOST="" CONFIG_SHELL="bash" V='' EXTRA_LDSFLAGS="-I/home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha -include symtab.h" CC="riscv64-unknown-linux-gnu-gcc" modules
      make[5]: Entering directory /home/lp0603/tina-d1-open/lichee/linux-5.4' ./scripts/Makefile.asm-generic:25: redundant generic-y found in arch/riscv/include/asm/Kbuild: device.h CALL scripts/checksyscalls.sh CALL scripts/atomic/check-atomics.sh Building modules, stage 2. MODPOST 20 modules make[5]: Leaving directory /home/lp0603/tina-d1-open/lichee/linux-5.4'
      touch /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/linux-d1-nezha/linux-5.4.61/.modules
      make -C ../generic/image compile TARGET_BUILD=
      make[5]: Entering directory /home/lp0603/tina-d1-open/target/allwinner/generic/image' make[5]: Nothing to be done for compile'.
      make[5]: Leaving directory /home/lp0603/tina-d1-open/target/allwinner/generic/image' make[4]: Leaving directory /home/lp0603/tina-d1-open/target/allwinner/d1-nezha'
      make[3]: Leaving directory /home/lp0603/tina-d1-open/target/allwinner' make[2]: Leaving directory /home/lp0603/tina-d1-open'
      make[2]: Entering directory /home/lp0603/tina-d1-open' rm -rf /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs make[2]: Leaving directory /home/lp0603/tina-d1-open'
      make[2]: Entering directory /home/lp0603/tina-d1-open' make[3]: Entering directory /home/lp0603/tina-d1-open/package/libs/toolchain'
      rm -rf /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libc
      mkdir -p /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libc
      for file in ./lib64xthead/lp64d/ld-.so ./lib/ld-linux.so.* ./lib64xthead/lp64d/lib{anl,c,crypt,dl,m,nsl,nss_dns,nss_files,resolv,util}{-.so,.so.} ./riscv64-unknown-linux-gnu/lib64xthead/lp64d/libgomp.so*; do dir=dirname $file ; install -d -m0755 /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libc/$dir ; cp -fpR /home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot//$file /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libc/$dir/ ; done ; install -d -m0755 /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libc/usr/bin; ln -sf ../../lib/ /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libc/usr/bin/ldd; exit 0
      cp: cannot stat '/home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot//./riscv64-unknown-linux-gnu/lib64xthead/lp64d/libgomp.so*': No such file or directory
      SHELL= flock /home/lp0603/tina-d1-open/tmp/.root-copy.flock -c 'cp -fpR /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libc/. /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/'
      touch /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp/.libc_installed
      if [ -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libc" >> /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
      rm -rf /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libgcc
      mkdir -p /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libgcc
      for file in ./lib64xthead/lp64d/libgcc_s.so.; do dir=dirname $file ; install -d -m0755 /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libgcc/$dir ; cp -fpR /home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/riscv64-unknown-linux-gnu//$file /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libgcc/$dir/ ; done ; exit 0
      SHELL= flock /home/lp0603/tina-d1-open/tmp/.root-copy.flock -c 'cp -fpR /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libgcc/. /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/'
      touch /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp/.libgcc_installed
      if [ -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libgcc" >> /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
      rm -rf /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libssp
      mkdir -p /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libssp
      for file in ./usr/lib64xthead/lp64d/libssp.so.
      ; do dir=dirname $file ; install -d -m0755 /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libssp/$dir ; cp -fpR /home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot//$file /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libssp/$dir/ ; done ; exit 0
      cp: cannot stat '/home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot//./usr/lib64xthead/lp64d/libssp.so.': No such file or directory
      SHELL= flock /home/lp0603/tina-d1-open/tmp/.root-copy.flock -c 'cp -fpR /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libssp/. /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/'
      touch /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp/.libssp_installed
      if [ -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libssp" >> /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
      rm -rf /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libstdcpp
      mkdir -p /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libstdcpp
      for file in ./lib64xthead/lp64d/libstdc++.so.
      ; do dir=dirname $file ; install -d -m0755 /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libstdcpp/$dir ; cp -fpR /home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/riscv64-unknown-linux-gnu//$file /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libstdcpp/$dir/ ; done ; exit 0
      SHELL= flock /home/lp0603/tina-d1-open/tmp/.root-copy.flock -c 'cp -fpR /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libstdcpp/. /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/'
      touch /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp/.libstdcpp_installed
      if [ -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libstdcpp" >> /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
      rm -rf /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libpthread
      mkdir -p /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libpthread
      for file in ./lib64xthead/lp64d/libpthread{-.so,.so.}; do dir=dirname $file ; install -d -m0755 /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libpthread/$dir ; cp -fpR /home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot//$file /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libpthread/$dir/ ; done ; exit 0
      SHELL= flock /home/lp0603/tina-d1-open/tmp/.root-copy.flock -c 'cp -fpR /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-libpthread/. /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/'
      touch /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp/.libpthread_installed
      if [ -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libpthread" >> /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
      rm -rf /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-librt
      mkdir -p /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-librt
      for file in ./lib64xthead/lp64d/librt{-.so,.so.}; do dir=dirname $file ; install -d -m0755 /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-librt/$dir ; cp -fpR /home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot//$file /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-librt/$dir/ ; done ; exit 0
      SHELL= flock /home/lp0603/tina-d1-open/tmp/.root-copy.flock -c 'cp -fpR /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/tmp-librt/. /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/'
      touch /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/rootfs/stamp/.librt_installed
      if [ -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "librt" >> /home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
      make[3]: Leaving directory /home/lp0603/tina-d1-open/package/libs/toolchain' make[3]: Entering directory /home/lp0603/tina-d1-open/package/libs/alsa-lib'
      CFLAGS="-Os -pipe -mcmodel=medany -mabi=lp64d -march=rv64gcxthead -g3 -fno-caller-saves -Wno-format-truncation -Wno-unused-result -Wl,-z,now -Wl,-z,relro -fpic -I/home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/usr/include -I/home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/include -I/home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/usr/include -I/home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/include " CXXFLAGS="-Os -pipe -mcmodel=medany -mabi=lp64d -march=rv64gcxthead -g3 -fno-caller-saves -Wno-format-truncation -Wno-unused-result -Wl,-z,now -Wl,-z,relro -fpic -Wno-virtual-dtor -I/home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/usr/include -I/home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/include -I/home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/usr/include -I/home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/include " LDFLAGS="-L/home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/usr/lib -L/home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/lib -L/home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/usr/lib -L/home/lp0603/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/lib -znow -zrelro -ldl " LIBS="" make -j1 -C /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/alsa-lib-1.1.4.1/. AR="riscv64-unknown-linux-gnu-ar" AS="riscv64-unknown-linux-gnu-gcc -c -Os -pipe -mcmodel=medany -mabi=lp64d -march=rv64gcxthead -g3 -fno-caller-saves -Wno-format-truncation -Wno-unused-result -Wl,-z,now -Wl,-z,relro -fpic" LD=riscv64-unknown-linux-gnu-ld NM="riscv64-unknown-linux-gnu-nm" CC="riscv64-unknown-linux-gnu-gcc" GCC="riscv64-unknown-linux-gnu-gcc" CXX="riscv64-unknown-linux-gnu-g++" RANLIB="riscv64-unknown-linux-gnu-ranlib" STRIP=riscv64-unknown-linux-gnu-strip OBJCOPY=riscv64-unknown-linux-gnu-objcopy OBJDUMP=riscv64-unknown-linux-gnu-objdump SIZE=riscv64-unknown-linux-gnu-size CROSS="riscv64-unknown-linux-gnu-" ARCH="riscv" ;
      make[4]: Entering directory /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/alsa-lib-1.1.4.1' make[4]: *** No targets. Stop. make[4]: Leaving directory /home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/alsa-lib-1.1.4.1'
      make[3]: *** [/home/lp0603/tina-d1-open/out/d1-nezha/compile_dir/target/alsa-lib-1.1.4.1/.built] Error 2
      make[3]: Leaving directory /home/lp0603/tina-d1-open/package/libs/alsa-lib' make[2]: *** [package/libs/alsa-lib/compile] Error 2 make[2]: Leaving directory /home/lp0603/tina-d1-open'
      make[1]: *** [/home/lp0603/tina-d1-open/out/d1-nezha/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory `/home/lp0603/tina-d1-open'
      make: *** [world] Error 2
      make failed to build some targets (01:33 (mm:ss))
