    Tina2.0添加NFS编译错误
      long0304 LV 3 最后由 编辑
      ERROR: module '/home/long/allwinner/tina-d1-h/out/d1-h-nezha/compile_dir/target/linux-d1-h-nezha/linux-5.4.61/fs/nfs_common/nfs_acl.ko' is missing.
      modules/fs.mk:333: recipe for target '/home/long/allwinner/tina-d1-h/out/d1-h-nezha/packages/kernel/kmod-fs-nfs-common_5.4.61-1_sunxi.ipk' failed
      make[3]: *** [/home/long/allwinner/tina-d1-h/out/d1-h-nezha/packages/kernel/kmod-fs-nfs-common_5.4.61-1_sunxi.ipk] Error 1
      make[3]: Leaving directory '/home/long/allwinner/tina-d1-h/package/kernel/linux'
      package/Makefile:192: recipe for target 'package/kernel/linux/compile' failed
      make[2]: *** [package/kernel/linux/compile] Error 2
      make[2]: Leaving directory '/home/long/allwinner/tina-d1-h'
      package/Makefile:189: recipe for target '/home/long/allwinner/tina-d1-h/out/d1-h-nezha/staging_dir/target/stamp/.package_compile' failed
      make[1]: *** [/home/long/allwinner/tina-d1-h/out/d1-h-nezha/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/home/long/allwinner/tina-d1-h'
      /home/long/allwinner/tina-d1-h/build/toplevel.mk:304: recipe for target 'world' failed
      make: *** [world] Error 2
      [2]+  Done                    $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      #### make failed to build some targets (54 seconds) ####
      Tina2.0在make menuconfig->kernal module ->filesystem勾上NFS后,编译错误,这个怎么解决?看错误好像是缺.ko文件,tina2.0是不支持NFS吗?
        whycan晕哥 LV 9 @long0304 最后由 编辑
        @long0304
        再执行 make kernel_menuconfig
        把 nfs 相关配置设置为m,
        确保 linux-5.4.61/fs/nfs_common/nfs_acl.ko 能生成,就不会报这个错误了。
          long0304 LV 3 @whycan 最后由 编辑
          @whycan 好的,谢谢,已经编译通过了。感谢大佬。👍
