    V536开发板,AP6255模块起不来,帮看看什么问题
    4324
      shzeng LV 2 最后由 编辑
      买了块珠海六点智能的V536开发板,插上AP6255 wifi蓝牙模块后,按照文档,手动加载bcmdhd.ko模块,结果报以下错误,请大佬给分析一下估计是什么原因?
      root@tina:/# insmod /lib/modules/4.9.118/bcmdhd.ko
      [  187.282765] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.7 (r)
      [  187.291609] ======== dhd_wlan_init_plat_data ========
      [  187.297397] dhd_wlan_init_gpio: WL_REG_ON=-1, WL_HOST_WAKE=-1
      [  187.303943] dhd_wlan_init_gpio: oob_irq=28, oob_irq_flags=0x4084
      [  187.310759] dhd_wifi_platform_load: Enter
      [  187.316023] Power-up adapter 'DHD generic adapter'
      [  187.321700] wifi_platform_set_power = 1
      [  187.326857] ======== PULL WL_REG_ON(-1) HIGH! ========
      [  187.333208] sunxi-wlan wlan: check wlan io_regulator voltage: 1800000
      [  187.666779] wifi_platform_bus_enumerate device present 1
      [  187.673196] sunxi-wlan wlan: bus_index: 1
      [  187.677895] ======== Card detection to detect SDIO card! ========
      [  187.684824] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  187.695411] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [  187.726826] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  187.824667] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [  187.938683] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [  187.944715] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  187.958792] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  187.971662] sunxi-mmc sdc1: smc 2 p1 err, cmd 8, RTO !!
      [  187.978277] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [  187.984182] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [  187.990196] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [  187.996164] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [  188.002493] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [  188.008636] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [  188.014751] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [  188.020768] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [  188.020812] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  188.026777] sunxi-mmc sdc1: smc 2 p1 err, cmd 1, RTO !!
      [  188.026817] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [  189.766794] failed to power up DHD generic adapter, 3 retry left
      [  189.791427] wifi_platform_set_power = 0
      [  189.796300] ======== PULL WL_REG_ON(-1) LOW! ========
      [  189.802293] wifi_platform_bus_enumerate device present 0
      [  189.808396] sunxi-wlan wlan: bus_index: 1
      sys_config.fex中wifi部分配置如下:
      [wlan]
      wlan_used           = 1
      wlan_busnum         = 1
      ;wlan_usbnum        = 3
      wlan_power          = "vcc33-wifi"
      wlan_io_regulator   = "vcc-pg"
      ;wlan_en            = port:PG11<1><default><default><0>
      wlan_regon          = port:PG11<1><default><default><0>
      wlan_hostwake       = port:PL05<6><default><default><0>
        WL_REG_ON=-1 这个引脚貌似没有从设备树读出来,你试一试强行10k拉高?
        S 1 条回复 最后回复 回复 引用 分享 0
          shzeng LV 2 @whycan 最后由 编辑
          @whycan 如何强行拉高,是从外部直接用10k电阻接vcc拉高吗?
            whycan晕哥 LV 9 @shzeng 最后由 编辑
            @shzeng
            是的,你先量一下看是否低电平,如果本身已经3v3了,就可能不是这里问题了。
