    这个错误怎么解呀
    • I
      itour LV 3 最后由 编辑
      if [ -f /home/yc/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/ncurses.libncurses.install.clean ]; then rm -f /home/yc/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/ncurses.libncurses.install /home/yc/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/ncurses.libncurses.install.clean; fi; echo "terminfo" >> /home/yc/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/ncurses.libncurses.install
      if [ -f /home/yc/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/ncurses.libncurses.install.clean ]; then rm -f /home/yc/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/ncurses.libncurses.install /home/yc/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/ncurses.libncurses.install.clean; fi; echo "libncurses" >> /home/yc/tina-d1-open/out/d1-nezha/staging_dir/target/pkginfo/ncurses.libncurses.install
      make[3]: Leaving directory '/home/yc/tina-d1-open/package/libs/ncurses'
      make[2]: Leaving directory '/home/yc/tina-d1-open'
      make[1]: *** [package/Makefile:189: /home/yc/tina-d1-open/out/d1-nezha/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/home/yc/tina-d1-open'
      make: *** [/home/yc/tina-d1-open/build/toplevel.mk:306:world] 错误 2
      [1]+ 已完成 $T/tools/build/buildserver --path $T
      make failed to build some targets (13 seconds)
        错误应该在更前面一点吧
        • N
          nideyida LV 5 最后由 编辑
          这里有大量类似问题,可以参考这个:https://r329.docs.allwinnertech.com/FAQ/faqbuildproblem/
