    D1s 根目录系统无法进入
    4434
      yuwei LV 6 最后由 编辑
      D1s 根目录系统无法进入 ,不知道什么情况,有没有大佬帮助一下,用的tina v 2.0
        yuwei LV 6 最后由 编辑
        [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
        [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
        sid_rd_ver_reg()254 - ver >= 4, soc ver:5
        sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
        input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
        Segment Routing with IPv6
        [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
        sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
        sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
        sunxi-i2c sunxi-i2c2: probe success
        mmc0: new high speed SDIO card at address 0001
        sun8iw20-pinctrl 2000000.pinctrl: pin PF2 already requested by 2500000.uart; cannot claim for 4020000.sdmmc
        sun8iw20-pinctrl 2000000.pinctrl: pin-162 (4020000.sdmmc) status -22
        sun8iw20-pinctrl 2000000.pinctrl: could not request pin 162 (PF2) from group PF2 on device 2000000.pinctrl
        sunxi-mmc 4020000.sdmmc: Error applying setting, reverse things back
        sunxi-mmc: probe of 4020000.sdmmc failed with error -22
        [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe00068b0e0, 0x:ffffffd0040f2000, irq_no:2e
        [sunxi-ehci0]: Not init ehci0
        [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe00068b4a8
        [sunxi-ohci0]: Not init ohci0
        ALSA device list:
        #0: audiocodec
        alloc_fd: slot 0 not NULL!
        /dev/root: Can't open blockdev
        VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
        Please append a correct "root=" boot option; here are the available partitions:
        Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
        CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #10
        Call Trace:
        [<ffffffe00002512c>] walk_stackframe+0x0/0x98
        [<ffffffe0000252e4>] show_stack+0x2a/0x34
        [<ffffffe000443280>] dump_stack+0x20/0x28
        [<ffffffe0000296ec>] panic+0xec/0x272
        [<ffffffe000000ef6>] mount_block_root+0x214/0x27a
        [<ffffffe000000fe2>] mount_root+0x86/0x90
        [<ffffffe000001134>] prepare_namespace+0x148/0x152
        [<ffffffe000000b58>] kernel_init_freeable+0x166/0x198
        [<ffffffe000453e34>] kernel_init+0x12/0xee
        [<ffffffe000023e98>] ret_from_exception+0x0/0xc
        ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
          whycan晕哥 LV 9 最后由 whycan 编辑
          mmc0需要申请PF2,但是PF2别处用了,导致mmc0识别失败。
          Y 2 条回复 最后回复 回复 引用 分享 0
            yuwei LV 6 @whycan 最后由 编辑
            @whycan 果然是这个问题谢谢晕哥
              @whycan pf2 被linux 5.4内核 设备树 文件里 串口给占用了,v2.0默认基于哪吒开发板的设备树吧。 我看被用来当串口了
