    d1s tina 配置里添加dbus 之后编译出现了报错不知道怎么解决
      yuwei LV 6 最后由 whycan 编辑
      在 make menuconfig 里添加了 这个 之后就开始编译报错
      np_scene_utils.c: In function 'SetBootLock':
      np_scene_utils.c:121:19: error: 'CPU0LOCK' undeclared (first use in this function); did you mean 'F_ULOCK'?
        return setConfig(CPU0LOCK, bootlock);
                         F_ULOCK
      np_scene_utils.c:121:19: note: each undeclared identifier is reported only once for each function it appears in
      np_scene_utils.c: In function 'SetRoomage':
      np_scene_utils.c:126:19: error: 'ROOMAGE' undeclared (first use in this function)
        return setConfig(ROOMAGE, roomage);
      np_scene_utils.c: In function 'SetCpuFreq':
      np_scene_utils.c:173:32: error: 'CPUFREQ_AVAIL' undeclared (first use in this function)
        if(!GetActualFreq(actualfreq, CPUFREQ_AVAIL))
      np_scene_utils.c:175:12: error: 'CPUFREQ_MAX' undeclared (first use in this function)
        setConfig(CPUFREQ_MAX, actualfreq);
      np_scene_utils.c:176:12: error: 'CPUFREQ_MIN' undeclared (first use in this function)
        setConfig(CPUFREQ_MIN, actualfreq);
      np_scene_utils.c: In function 'SetCpuFreqMax':
      np_scene_utils.c:183:19: error: 'CPUFREQ_MAX' undeclared (first use in this function)
        return setConfig(CPUFREQ_MAX, cpu_freq_max);
      np_scene_utils.c: In function 'SetCpuFreqMin':
      np_scene_utils.c:188:19: error: 'CPUFREQ_MIN' undeclared (first use in this function)
        return setConfig(CPUFREQ_MIN, cpu_freq_min);
      np_scene_utils.c: In function 'GetCpuFreq':
      np_scene_utils.c:193:19: error: 'CPUFREQ' undeclared (first use in this function)
        return getConfig(CPUFREQ, buf, len);
      np_scene_utils.c: In function 'GetCpuOnline':
      np_scene_utils.c:198:19: error: 'CPUONLINE' undeclared (first use in this function); did you mean 'CPU_SCENE'?
        return getConfig(CPUONLINE, buf, len);
                         CPU_SCENE
      np_scene_utils.c: In function 'GetCpuGov':
      np_scene_utils.c:203:19: error: 'CPU0GOV' undeclared (first use in this function)
        return getConfig(CPU0GOV, buf, len);
      np_scene_utils.c: In function 'SetCpuGov':
      np_scene_utils.c:208:19: error: 'CPU0GOV' undeclared (first use in this function)
        return setConfig(CPU0GOV, cpu_gov);
      np_scene_utils.c: In function 'SetCpuHot':
      np_scene_utils.c:213:19: error: 'CPUHOT' undeclared (first use in this function)
        return setConfig(CPUHOT, cpu_hot);
      np_scene_utils.c: In function 'SetCpuOnline':
      np_scene_utils.c:218:14: error: 'CPU_NUM_MAX' undeclared (first use in this function); did you mean 'UINT8_MAX'?
        char online[CPU_NUM_MAX];
                    UINT8_MAX
      np_scene_utils.c: In function 'SetDramFreqAdaptive':
      np_scene_utils.c:260:19: error: 'DRAMMODE' undeclared (first use in this function); did you mean 'O_ACCMODE'?
        return setConfig(DRAMMODE, pause);
                         O_ACCMODE
      np_scene_utils.c: In function 'SetDramFreq':
      np_scene_utils.c:268:32: error: 'DRAMFREQ_AVAIL' undeclared (first use in this function)
        if(!GetActualFreq(actualfreq, DRAMFREQ_AVAIL))
      np_scene_utils.c:272:12: error: 'DRAMFREQ_MAX' undeclared (first use in this function); did you mean 'RAND_MAX'?
        setConfig(DRAMFREQ_MAX, actualfreq);
                  RAND_MAX
      np_scene_utils.c:273:12: error: 'DRAMFREQ_MIN' undeclared (first use in this function)
        setConfig(DRAMFREQ_MIN, actualfreq);
      np_scene_utils.c: In function 'SetDramFreqMax':
      np_scene_utils.c:280:19: error: 'DRAMFREQ_MAX' undeclared (first use in this function); did you mean 'RAND_MAX'?
        return setConfig(DRAMFREQ_MAX, dram_freq_max);
                         RAND_MAX
      np_scene_utils.c: In function 'SetDramFreqMin':
      np_scene_utils.c:285:19: error: 'DRAMFREQ_MIN' undeclared (first use in this function)
        return setConfig(DRAMFREQ_MIN, dram_freq_min);
      np_scene_utils.c: In function 'GetDramFreq':
      np_scene_utils.c:290:19: error: 'DRAMFREQ' undeclared (first use in this function); did you mean 'DRAM_SCENE'?
        return getConfig(DRAMFREQ, buf, len);
                         DRAM_SCENE
      np_scene_utils.c: At top level:
      np_scene_utils.c:320:16: warning: initialization of 'int (*)(char *, int)' from incompatible pointer type 'int (*)(char *, size_t)' {aka 'int (*)(char *, long unsigned int)'} [-Wincompatible-pointer-types]
        .GetGpuFreq = GetGpuFreq,
      np_scene_utils.c:320:16: note: (near initialization for 'gpu_ops.GetGpuFreq')
      make[4]: *** [libscenemanager.so] Error 1
      make[4]: Leaving directory `/home/yuwei/linux/D1s/d1_sdk_v2.0_repo_sync_local/tina_d1_open_v2/out/d1s-mq/compile_dir/target/nativepower/libscenemanager'
      make[3]: *** [/home/yuwei/linux/D1s/d1_sdk_v2.0_repo_sync_local/tina_d1_open_v2/out/d1s-mq/compile_dir/target/nativepower/.built] Error 2
      make[3]: Leaving directory `/home/yuwei/linux/D1s/d1_sdk_v2.0_repo_sync_local/tina_d1_open_v2/package/allwinner/nativepower'
      make[2]: *** [package/allwinner/nativepower/compile] Error 2
      make[2]: Leaving directory `/home/yuwei/linux/D1s/d1_sdk_v2.0_repo_sync_local/tina_d1_open_v2'
      make[1]: *** [/home/yuwei/linux/D1s/d1_sdk_v2.0_repo_sync_local/tina_d1_open_v2/out/d1s-mq/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory `/home/yuwei/linux/D1s/d1_sdk_v2.0_repo_sync_local/tina_d1_open_v2'
      make: *** [world] 错误 2
      [4]+  已完成               $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      #### make failed to build some targets (14 seconds) ####
      root@yuwei-VirtualBox:/home/yuwei/linux/D1s/d1_sdk_v2.0_repo_sync_local/tina_d1_open_v2#
      不知道什么情况 有没有大佬帮忙看一下
        感觉这个包可能是 for arm only,
        你看下源码, 看样子可能里面有 arm 的汇编代码。
        Y 1 条回复 最后回复 回复 引用 分享 0
          yuwei LV 6 @whycan 最后由 编辑
          @whycan 在 d1s tina 配置里添加dbus 之后编译出现了报错不知道怎么解决 中说:
          for arm only
          最离谱的是我改回来,编译还会报错。
