    试着用t113的uboot测试mipi屏幕,出现问题,能不能帮帮我
    6561
      smiletiger LV 6 最后由 whycan 编辑
      用的t113的sdk编译出来的uboot,自己修改了设备树,之前用的800x480的lcd在uboot下面已经用colorbar指令测试成功了,然后想测试手头的mipi屏幕,结果出现了个问题
      用disp指令显示,我配置的刷新率应该是59帧,实际只有25.5帧,colorbar测试失败,但是用mipi指令可以获取到屏幕的id值,说明mipi其实已经跑起来了,可能是时钟哪里配置不对,没有修改uboot源码,只是修改了设备树,按照mipi初始化指令增加了屏幕的指令,这个屏幕不需要额外的初始化指令,只需要一个0x29和0x11指令就可以显示的
      uboot打印的logo如下
      U-Boot 2018.05-g2a24076-dirty (May 13 2022 - 21:35:03 +0800) Allwinner Technology
      [03.349].................................set debug mode=8[03.354]CPU:   Allwinner Family
      [03.357]Model: sun8iw20
      [03.359]DRAM:  128 MiB
      [03.362]Relocation Offset is: 04f36000
      [03.380]secure enable bit: 0
      [03.383]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [03.389]gic: normal mode
      [03.391]flash init start0
      [03.393]workmode = 0,storage type = 3
      spi sunxi_slave->max_hz:120000000
      SF: Detected w25q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
      [03.409]sunxi flash init ok
      [03.412]sunxi_flash_probe ok
      [03.415]sunxi_flash_probe ok1
      [03.417]line:703 init_clocks
      [03.420]init_clocks:finish
      [03.422]drv_disp_init
      [03.430]get flash lcd idx 0
      [03.441]HDMI 2.0 driver init start!
      [03.444]fdt_path_offset hdmi fail
      [03.447]unable to map hdmi registers
      [03.450]drv_disp_init finish
      [03.453]boot_gui_init:start
      [03.456]set disp.dev2_output_type fail. using defval=0
      [03.461]lcd_open_flow=0
      [03.463]lcd_clk_config--------------------------------
      [03.468]-------------disp_al_lcd_get_clk_info
      [03.472]DSI_VERSION_40
      [03.474]DSI_VERSION_40 lcd_dsi_format=0
      [03.477]tcon_div=4 lcd_div=1 dsi_div=6 dsi_rate=150000000
      [03.482]lcd_rate=408000000 pll_rate=408000000 tcon_div=4
      [03.488]pll_rate_set=408000000
      [03.490]2222222222
      [03.492]disp 0, clk: pll(408000000),clk(408000000),dclk(68000000) dsi_rate(150000000)
           clk real:pll(408000000),clk(408000000),dclk(102000000) dsi_rate(150000000)
      [03.507]DSI_VERSION_40
      [03.509]DSI_VERSION_40 lcd_dsi_format=0
      [03.512]tcon_div=4 lcd_div=1 dsi_div=6 dsi_rate=150000000
      [03.518]lcd_open_flow=0
      [03.851]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
      [03.858]boot_gui_init:finish
      GUID P[03.861]lcd_open_flow=0
      [03.873]lcd_panel_init dsi_dcs_write=29
      get lcd id0 0x41 get lcd id15 0xff get lcd id16 0x0 readbytes=16
      artition Table Header signature is wrong: 0xE07060200000000 != 0x5452415020494645
      part_get_info_efi: *** ERROR: In[04.192]lcd_open_flow=0
      valid GPT ***
      ERROR: attempting read past flash size
      *** ERROR: Can't read GPT header ***
      GUID Partition Table Header signature is wrong: 0xE07060200000000 != 0x5452415020494645
      [04.238]Get bootloader and boot-resource partition number fail[04.244]lcd_open_flow=0
      [04.247]lcd_open_flow=0
      [04.249]lcd_open_flow=0
      [04.251]LCD open finish
      [04.277]Loading Environment from SUNXI_FLASH... GUID Partition Table Header signature is wrong: 0xE07060200000000 != 0x5452415020494645
      *** Warning - no device, using default environment
      Failed (-19)
      [04.334]update part info
      [04.336]key 0
      [04.361]no misc partition is found
      [04.364]update bootcmd
      [04.412]libfdt fdt_check_header(): FDT_ERR_BADMAGIC
      [04.417]replace_fdt fail addr:0x43200000
      disable nand error: FDT_ERR_NOTFOUND
      [04.424](weak)update dtb dram start
      [04.428]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [04.434]update dts
      ## Error: "distro_bootcmd" not defined
      => disp
      screen 0:
      de_rate 300000000 hz, ref_fps:59
      mgr0: 720x1280 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[1] force_sync[0] unblank direct_show[false] iommu[0]
      	lcd output	backlight(100)	fps:25.5	 720x1280
      	err:0	skip:0	irq:0	vsync:0	vsync_skip:0
      希望有经验的朋友能不能帮我分析一下,是不是哪里时钟配置出错了
      uboot的dts文件如下
       * Allwinner Technology CO., Ltd. sun8iw20p1 soc board.
       * soc board support.
      /dts-v1/;
      #include "sun8iw20p1-soc-system.dtsi"
      &platform {
      	eraseflag   = <1>;
      	next_work   = <3>;
      	debug_mode  = <1>;
      &target {
      	boot_clock = <1008>;	/*CPU boot frequency, Unit: MHz*/
      	storage_type = <0xffffffff>; /*boot medium, 0-nand, 1-card0, 2-card2, -1(defualt)auto scan*/
      	burn_key = <0>;		/*1:support burn key; 0:not support burn key*/
      	dragonboard_test = <0>;	/*1:support card boot dragonboard; 0:not support card boot dragonboard*/
      &charger0 {
      	pmu_safe_vol = <3500>;
      &twi6 {
      	clock-frequency = <200000>;
      	pinctrl-0 = <&s_twi0_pins_a>;
      	no_suspend = <1>;
      	twi_drv_used = <1>;
      &pwm7_pin_a {
      	pins = "PD22";
      	function = "pwm7";
      	muxsel = <5>;
      	drive-strength = <10>;
      	bias-pull-up;
      &pwm7_pin_b {
      	pins = "PD22";
      	muxsel = <0>;
      	function = "gpio_out";
      &pwm7 {
      	pinctrl-0 = <&pwm7_pin_a>;
      	pinctrl-1 = <&pwm7_pin_b>;
      &sdc0_pins_a {
      			 "PF3", "PF4", "PF5";
      	allwinner,function = "sdc0";
      	allwinner,muxsel = <2>;
      	allwinner,drive = <3>;
      	allwinner,pull = <1>;
      	function = "sdc0";
      	drive-strength = <30>;
      	bias-pull-up;
      	power-source = <3300>;
      &sdc0_pins_b {
      	function = "sdc0";
      	bias-pull-up;
      	power-source = <1800>;
      &sdc0_pins_c {
      		function = "gpio_in";
      &sdc2_pins_a {
      			 "PC5", "PC6", "PC7";
      	allwinner,function = "sdc2";
      	allwinner,muxsel = <3>;
      	function = "sdc2";
      	bias-pull-up;
      &sdc2_pins_b {
      &nand0_pins_a {
      	allwinner,pins = "PC0", "PC1", "PC2", "PC5",
      			 "PC8", "PC9", "PC10", "PC11",
      			 "PC12", "PC13", "PC14", "PC15",
      			 "PC16";
      	allwinner,pname= "nand0_we", "nand0_ale","nand0_cle", "nand0_nre",
      			 "nand0_d0", "nand0_d1", "nand0_d2", "nand0_d3",
      			 "nand0_d4", "nand0_d5", "nand0_d6", "nand0_d7",
      			 "nand0_ndqs";
      	allwinner,function = "nand0";
      	allwinner,drive = <1>;
      	allwinner,pull = <0>;
      &nand0_pins_b {
      	allwinner,pins = "PC4", "PC6", "PC03", "PC07";
      	allwinner,pname= "nand0_ce0", "nand0_rb0", "nand0_ce1", "nand0_rb1";
      	allwinner,pull = <1>;	/* only RB&CE should be pulled up */
      &nand0_pins_c {
      	allwinner,pins = "PC0", "PC1", "PC2", "PC3",
      			 "PC4", "PC5", "PC6", "PC7",
      			 "PC16";
      	allwinner,muxsel = <7>;
      &spi0_pins_a {
      	allwinner,pins = "PC2", "PC4", "PC5";
      	allwinner,pname = "spi0_sclk", "spi0_mosi", "spi0_miso";
      	allwinner,function = "spi0";
      &spi0_pins_b {
      	allwinner,pins = "PC3", "PC7", "PC6";
      	allwinner,pname = "spi0_cs0", "spi0_hold", "spi0_wp";
      	allwinner,pull = <1>;   // only CS should be pulled up
      &spi0_pins_c {
      	allwinner,pins = "PC2", "PC3", "PC4", "PC5",
      			"PC6", "PC7";
      	allwinner,function = "gpio_in";
      	allwinner,muxsel = <0>;
      &card0_boot_para {  /* Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value */
      	/* reg = <0x0 0x2 0x0 0x0>;  [> Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value <] */
      	card_ctrl = <0x0>;
      	card_high_speed = <0x1>;
      	card_line = <0x4>;
      	pinctrl-0 = <&sdc0_pins_a>;
      &card2_boot_para {  /* Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value */
      	/* reg = <0x0 0x3 0x0 0x0>;  [> Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value <] */
      	card_ctrl = <0x2>;
      	card_line = <0x4>;
      	pinctrl-0 = <&sdc2_pins_a>;
      	sdc_ex_dly_used = <0x2>;
      	sdc_io_1v8 = <0x1>;
      	sdc_tm4_win_th = <0x08>;
      	sdc_type = "tm4";
      &gpio_bias {  /* Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value */
      	device_type = "gpio_bias";
      	pc_bias = <1800>;
      &nand0 {
      	compatible = "allwinner,sun8iw20-nand";
      	device_type = "nand0";
      	//reg = <0x0 0x04011000 0x0 0x1000>;/* nand0 */
      	pinctrl-0 = <&nand0_pins_a &nand0_pins_b>;
      	pinctrl-1 = <&nand0_pins_c>;
      	nand0_regulator1 = "vcc-nand";
      	nand0_regulator2 = "none";
      	nand0_cache_level = <0x55aaaa55>;
      	nand0_flush_cache_num = <0x55aaaa55>;
      	nand0_capacity_level = <0x55aaaa55>;
      	nand0_id_number_ctl = <0x55aaaa55>;
      	nand0_print_level = <0x55aaaa55>;
      	nand0_p0 = <0x55aaaa55>;
      	nand0_p1 = <0x55aaaa55>;
      	nand0_p2 = <0x55aaaa55>;
      	nand0_p3 = <0x55aaaa55>;
      	chip_code = "sun8iw20";
      	status = "disabled";
      &spi0 {
      	pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi0_cs_number = <1>;
      	spi0_cs_bitmap = <1>;
      	spi-nand@0 {
      		compatible = "spi-nand";
      		spi-max-frequency=<0x5F5E100>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x04>;
      		spi-tx-bus-width=<0x04>;
      		status="okay";
      &disp {
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      /*800x480 tft*/
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_backlight       = <100>;
      	lcd_if              = <0>;
      	lcd_x               = <800>;
      	lcd_y               = <480>;
      	lcd_width           = <150>;
      	lcd_height          = <94>;
      	lcd_dclk_freq       = <36>;
      	lcd_hv_clk_phase    = <0>;
      	lcd_hv_sync_polarity= <3>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <7>;
      	lcd_pwm_freq        = <20000>;
      	lcd_pwm_pol         = <0>;
      	lcd_hbp             = <46>;
      	lcd_ht              = <1055>;
      	lcd_hspw            = <0>;
      	lcd_vbp             = <23>;
      	lcd_vt              = <525>;
      	lcd_vspw            = <0>;
      	lcd_lvds_if         = <0>;
      	lcd_lvds_colordepth = <1>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <1>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	pinctrl-0 = <&rgb18_pins_a>;
      	pinctrl-1 = <&rgb18_pins_b>;
      &aliases {
      	nand0 = &nand0;
      	twi6 = &twi6;
      	pwm = &pwm;
      	pwm0 = &pwm0;
      	pwm1 = &pwm1;
      	pwm2 = &pwm2;
      	pwm3 = &pwm3;
      	pwm4 = &pwm4;
      	pwm5 = &pwm5;
      	pwm6 = &pwm6;
      	pwm7 = &pwm7;
      	disp = &disp;
      	lcd0 = &lcd0;
      	lcd1 = &lcd1;
      	eink = &eink;
      	spi0 = &spi0;
      &lcd0 {
      	/* part 1 */
      lcd_used            = <1>;
      lcd_driver_name     = "lq055k3sx02";
      	/* part 2 */
      lcd_if = <4>;
      lcd_dsi_if = <0>;
      	/* part 3 */
      lcd_x = <720>;
      lcd_y = <1280>;
      lcd_width = <135>;
      lcd_height = <216>;
      lcd_dclk_freq = <68>;
      lcd_hbp = <40>;
      lcd_ht = <870>;
      lcd_hspw = <10>;
      lcd_vbp = <11>;
      lcd_vt = <1305>;
      lcd_vspw = <1>;
      /* part 4 */
      lcd_pwm_used = <1>;
      lcd_pwm_ch = <7>;
      lcd_pwm_pol = <0>;
      lcd_pwm_max_limit = <100>;
      //lcd_bl_en = <&pio PD 22 1 0 3 1>;//pwm7 pd22
      /* part 5 */
      lcd_dsi_lane = <4>;
      lcd_dsi_format = <0>;
      lcd_dsi_te = <0>;
      /* part 6 */
      lcd_frm = <0>;
      lcd_gamma_en = <0>;
      lcd_cmap_en = <0>;
      /* part 7 */
      //lcd_pin_power = "dcdc1";
      //lcd_pin_power1 = "eldo3";
      //lcd_power = "dc1sw";
      lcd_gpio_0 = <&pio PG 10 1 0 3 1>;//rst(PG10)
      lcd_gpio_1 = <&pio PG 13 1 0 3 1>;//   led(PG13)
      &aliases {
      	nand0 = &nand0;
      	twi6 = &twi6;
      	pwm = &pwm;
      	pwm0 = &pwm0;
      	pwm1 = &pwm1;
      	pwm2 = &pwm2;
      	pwm3 = &pwm3;
      	pwm4 = &pwm4;
      	pwm5 = &pwm5;
      	pwm6 = &pwm6;
      	pwm7 = &pwm7;
      	disp = &disp;
      	lcd0 = &lcd0;
      	lcd1 = &lcd1;
      	eink = &eink;
      	spi0 = &spi0;
        whycan晕哥 LV 9 @smiletiger 最后由 编辑
        @smiletiger
        我也出现一模一样的问题了,
        同样的D1s板子,同一个固件,淘宝上面买的渣TF卡,有一张卡不正常:
        [32]HELLO! BOOT0 is starting!
        [35]BOOT0 commit : 88480af-dirty
        [38]set pll start
        [40]periph0 has been enabled
        [43]set pll end
        [44][pmu]: bus read error
        [47]board init ok
        [48]ZQ value = 0x30
        [50]get_pmu_exist() = -1
        [53]ddr_efuse_type: 0xa
        [55]trefi:7.8ms
        [57][AUTO DEBUG] single rank and full DQ!
        [61]ddr_efuse_type: 0xa
        [63]trefi:7.8ms
        [65][AUTO DEBUG] rank 0 row = 13
        [68][AUTO DEBUG] rank 0 bank = 4
        [71][AUTO DEBUG] rank 0 page size = 2 KB
        [75]DRAM BOOT DRIVE INFO: V0.33
        [78]DRAM CLK = 528 MHz
        [80]DRAM Type = 2 (2:DDR2,3:DDR3)
        [83]DRAMC read ODT  off.
        [86]DRAM ODT off.
        [87]ddr_efuse_type: 0xa
        [90]DRAM SIZE =64 M
        [92]dram_tpr4:0x0
        [94]PLL_DDR_CTRL_REG:0xf8002b00
        [97]DRAM_CLK_REG:0xc0000000
        [99][TIMING DEBUG] MR2= 0x0
        [104]DRAM simple test OK.
        [106]dram size =64
        [108]card no is 0
        [109]sdcard 0 line count 4
        [112][mmc]: mmc driver ver 2021-04-2 16:45
        [121][mmc]: Wrong media type 0x0
        [124][mmc]: ***Try SD card 0***
        [133][mmc]: HSSDR52/SDR25 4 bit
        [136][mmc]: 50000000 Hz
        [138][mmc]: 3763 MB
        [140][mmc]: ***SD/MMC 0 init OK!!!***
        [179]Loading boot-pkg Succeed(index=0).
        [182]Entry_name        = opensbi
        [186]Entry_name        = u-boot
        [189]Entry_name        = dtb
        [192]mmc not para
        ▒193]Jump to second Boot.
        U-Boot 2018.05-g24521d6-dirty (Feb 08 2023 - 22:56:48 +0800) Allwinner Technology
        [00.203]DRAM:  64 MiB
        [00.206]Relocation Offset is: 01f27000
        [00.210]secure enable bit: 0
        [00.213]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
        [00.219]flash init start
        [00.221]workmode = 0,storage type = 1
        [00.225][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
        [00.230][mmc]: get sdc_type fail and use default host:tm1.
        [00.237][mmc]: can't find node "mmc0",will add new node
        [00.242][mmc]: fdt err returned <no error>
        [00.246][mmc]: Using default timing para
        [00.249][mmc]: SUNXI SDMMC Controller Version:0x50310
        [00.267][mmc]: card_caps:0x3000000a
        [00.270][mmc]: host_caps:0x3000003f
        [00.274]sunxi flash init ok
        [00.276]line:703 init_clocks
        GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
        [00.304]Loading Environment from SUNXI_FLASH... GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
        Can't find env partition
        Failed (-19)
        [00.340]out of usb burn from boot: not need burn key
        cann't get the boot_base from the env
        [00.348]Item0 (Map) magic is bad
        [00.351]the secure storage item0 copy0 magic is bad
        [00.356]Item0 (Map) magic is bad
        [00.359]the secure storage item0 copy1 magic is bad
        [00.364]Item0 (Map) magic is bad
        [00.417]update part info
        [00.443]update bootcmd
        [00.492]change working_fdt 0x42ae6da0 to 0x42ac6da0
        [00.527]update dts
        noncached_alloc(): addr = 0x42b4ba00
        noncached_alloc(): addr = 0x42b4ba40
        noncached_alloc(): addr = 0x42b4ba80
        noncached_alloc(): addr = 0x42b4c2c0
        geth_sys_init fail!
        [00.547]Board Net Initialization Failed
        [00.551]No ethernet found.
        有一张正常:
        [35]HELLO! BOOT0 is starting!
        [38]BOOT0 commit : 88480af-dirty
        [41]set pll start
        [43]periph0 has been enabled
        [46]set pll end
        [48][pmu]: bus read error
        [50]board init ok
        [52]ZQ value = 0x30
        [54]get_pmu_exist() = -1
        [56]ddr_efuse_type: 0xa
        [58]trefi:7.8ms
        [60][AUTO DEBUG] single rank and full DQ!
        [64]ddr_efuse_type: 0xa
        [66]trefi:7.8ms
        [68][AUTO DEBUG] rank 0 row = 13
        [71][AUTO DEBUG] rank 0 bank = 4
        [75][AUTO DEBUG] rank 0 page size = 2 KB
        [78]DRAM BOOT DRIVE INFO: V0.33
        [81]DRAM CLK = 528 MHz
        [83]DRAM Type = 2 (2:DDR2,3:DDR3)
        [87]DRAMC read ODT  off.
        [89]DRAM ODT off.
        [91]ddr_efuse_type: 0xa
        [93]DRAM SIZE =64 M
        [95]dram_tpr4:0x0
        [97]PLL_DDR_CTRL_REG:0xf8002b00
        [100]DRAM_CLK_REG:0xc0000000
        [102][TIMING DEBUG] MR2= 0x0
        [107]DRAM simple test OK.
        [109]dram size =64
        [111]card no is 0
        [113]sdcard 0 line count 4
        [115][mmc]: mmc driver ver 2021-04-2 16:45
        [125][mmc]: Wrong media type 0x0
        [127][mmc]: ***Try SD card 0***
        [140][mmc]: HSSDR52/SDR25 4 bit
        [143][mmc]: 50000000 Hz
        [145][mmc]: 3780 MB
        [147][mmc]: ***SD/MMC 0 init OK!!!***
        [191]Loading boot-pkg Succeed(index=0).
        [195]Entry_name        = opensbi
        [198]Entry_name        = u-boot
        [202]Entry_name        = dtb
        [204]mmc not para
        ▒206]Jump to second Boot.
        U-Boot 2018.05-g24521d6-dirty (Feb 09 2023 - 21:12:54 +0800) Allwinner Technology
        [00.216]DRAM:  64 MiB
        [00.218]Relocation Offset is: 01f27000
        [00.222]secure enable bit: 0
        [00.226]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
        [00.232]flash init start
        [00.234]workmode = 0,storage type = 1
        [00.237][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
        [00.243][mmc]: get sdc_type fail and use default host:tm1.
        [00.250][mmc]: can't find node "mmc0",will add new node
        [00.254][mmc]: fdt err returned <no error>
        [00.258][mmc]: Using default timing para
        [00.262][mmc]: SUNXI SDMMC Controller Version:0x50310
        [00.282][mmc]: card_caps:0x3000000a
        [00.285][mmc]: host_caps:0x3000003f
        [00.290]sunxi flash init ok
        [00.292]line:703 init_clocks
        [00.318]Loading Environment from SUNXI_FLASH... OK
        [00.343]out of usb burn from boot: not need burn key
        [00.363]Item0 (Map) magic is bad
        root_partition is rootfs
        set root to /dev/mmcblk0p5
        [00.380]update part info
        [00.385]update bootcmd
        [00.390]change working_fdt 0x42ae6da0 to 0x42ac6da0
        [00.425]update dts
        noncached_alloc(): addr = 0x42b4afc0
        noncached_alloc(): addr = 0x42b4b000
        noncached_alloc(): addr = 0x42b4b040
        noncached_alloc(): addr = 0x42b4b880
        geth_sys_init fail!
        [00.445]Board Net Initialization Failed
        [00.448]No ethernet found.
        [00.656]no vendor_boot partition is found
        Android's image name: d1s-whycanpih
        Detect comp gzip
        [00.935]
        Starting kernel ...
        [00.938][mmc]: MMC Device 2 not found
        [00.941][mmc]: mmc 2 not find, so not exit
        ▒** 17 printk messages dropped **
        [    0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [    0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
        [    0.000000] Memory: 56316K/65536K available (4943K kernel code, 428K rwdata, 1914K rodata, 156K init, 237K bss, 9220K reserved, 0K cma-reserved)
        [    0.000009] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
        [    0.000032] riscv_timer_clockevent depends on broadcast, but no broadcast function available
        [    0.000437] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
        [    0.001236] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
        [    0.001261] pid_max: default: 32768 minimum: 301
        [    0.001480] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
        [    0.001504] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
        [    0.003805] ASID allocator initialised with 65536 entries
        [    0.004015] rcu: Hierarchical SRCU implementation.
        [    0.004826] devtmpfs: initialized
        [    0.025392] random: get_random_u32 called from bucket_table_alloc.isra.27+0x10a/0x12c with crng_init=0
        [    0.026850] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.026891] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
        [    0.027080] pinctrl core: initialized pinctrl subsystem
        [    0.028945] NET: Registered protocol family 16
        [    0.030003] DMA: preallocated 256 KiB pool for atomic allocations
        [    0.035896] cpuidle: using governor menu
        [    0.145503] rtc_ccu: sunxi ccu init OK
        [    0.156066] clock: sunxi ccu init OK
        [    0.157489] clock: sunxi ccu init OK
        [    0.290983] iommu: Default domain type: Translated
        [    0.291915] sunxi iommu: irq = 4
        [    0.295166] SCSI subsystem initialized
        [    0.296614] usbcore: registered new interface driver usbfs
        [    0.296940] usbcore: registered new interface driver hub
        [    0.297252] usbcore: registered new device driver usb
        [    0.298245] mc: Linux media interface: v0.10
        [    0.298684] videodev: Linux video capture interface: v2.00
        [    0.304674] Advanced Linux Sound Architecture Driver Initialized.
        [    0.306109] Bluetooth: Core ver 2.22
        [    0.306386] NET: Registered protocol family 31
        [    0.306402] Bluetooth: HCI device and connection manager initialized
        [    0.306429] Bluetooth: HCI socket layer initialized
        [    0.306444] Bluetooth: L2CAP socket layer initialized
        [    0.306498] Bluetooth: SCO socket layer initialized
        [    0.307200] pwm module init!
        [    0.310031] g2d 5410000.g2d: Adding to iommu group 0
        [    0.310996] G2D: rcq version initialized.major:251
        [    0.312811] clocksource: Switched to clocksource riscv_clocksource
        [    0.334719] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
        [    0.343333] NET: Registered protocol family 2
        [    0.344718] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
        [    0.344777] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
        [    0.344806] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
        [    0.344824] TCP: Hash tables configured (established 512 bind 512)
        [    0.345003] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
        [    0.345058] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
        [    0.345364] NET: Registered protocol family 1
        [    0.347805] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
        [    0.348690] spi spi0: spi0 supply spi not found, using dummy regulator
        [    0.349244] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
        [    0.349325] sunxi_spi_resource_get()2189 - Failed to get sample mode
        [    0.349337] sunxi_spi_resource_get()2194 - Failed to get sample delay
        [    0.349349] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
        [    0.349431] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
        [    0.351018] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base ffffffd004058000, irq 31
        [    0.356804] workingset: timestamp_bits=62 max_order=14 bucket_order=0
        [    0.392652] squashfs: version 4.0 (2009/01/31) Phillip Lougher
        [    0.394012] ntfs: driver 2.1.32 [Flags: R/W].
        [    0.425659] io scheduler mq-deadline registered
        [    0.425677] io scheduler kyber registered
        [    0.427921] [DISP]disp_module_init
        [    0.428947] disp 5000000.disp: Adding to iommu group 0
        [    0.479607] display_fb_request,fb_id:0
        [    0.483653] [DISP] Fb_copy_boot_fb,line:1443:
        [    0.483658] no boot_fb0
        [    0.484431] disp_al_manager_apply ouput_type:0
        [    0.484914] [DISP] lcd_clk_config,line:744:
        [    0.484931] disp 0, clk: pll(224000000),clk(224000000),dclk(8000000) dsi_rate(224000000)
        [    0.484931]      clk real:pll(288000000),clk(288000000),dclk(10285714) dsi_rate(0)
        [    0.484990] LCD_open_flow line136: 1111111111111111111111111111111111
        [    0.485004] LCD_power_on line158: 1111111111111111111111111111111111
        [    0.486182] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
        [    0.487407] [DISP]disp_module_init finish
        [    0.489365] sunxi_sid_init()551 - insmod ok
        [    0.490695] pwm-regulator: supplied by regulator-dummy
        [    0.494140] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
        [    0.494754] uart uart1: get regulator failed
        [    0.494792] uart uart1: uart1 supply uart not found, using dummy regulator
        [    0.496189] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
        [    0.497418] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
        [    0.497965] uart uart3: get regulator failed
        [    0.498002] uart uart3: uart3 supply uart not found, using dummy regulator
        [    0.498689] uart3: ttyS3 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) is a SUNXI
        [    0.498722] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
        [    0.613592] LCD_panel_init line200: 1111111111111111111111111111111111
        [    0.613599] [ST7789V LCD INFO] LINE:0201-->LCD_panel_init:
        [    0.613604] [ST7789V LCD INFO] LINE:0202-->LCD_panel_init:init statr!
        [    0.613606] ili9327 statr
        [    0.613612] lcd_panel_ili9327_init line218: 1111111111111111111111111111111111
        [    0.613617] lcd_panel_ili9327_init line219: 1111111111111111111111111111111111
        [    0.613622] lcd_panel_ili9327_init line220: 1111111111111111111111111111111111
        [    0.613627] [ST7789V LCD INFO] LINE:0222-->lcd_panel_ili9327_init:
        [    0.633378] [ST7789V LCD INFO] LINE:0226-->lcd_panel_ili9327_init:reset do!
        [    0.633383] ili9327 reset!
        [    1.061128] ili9327 init over!
        [    1.223203] LCD_bl_open line182: 1111111111111111111111111111111111
        [    1.223210] [ST7789V LCD INFO] LINE:0183-->LCD_bl_open:bl open!
        [    1.223212] ili9327 open
        [    1.223533] [DISP] disp_device_attached_and_enable,line:233:
        [    1.223540] attached ok, mgr0<-->dev0
        [    1.223544] [DISP] disp_device_attached_and_enable,line:236:
        [    1.223557] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
        [    1.287862] printk: console [ttyS3] enabled
        [    1.295053] misc dump reg init
        [    1.300955] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
        [    1.308725] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
        [    1.316253] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
        [    1.323863] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
        [    1.330380] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
        [    1.337529] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
        [    1.345388] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
        [    1.353439] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
        [    1.361550] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
        [    1.369606] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
        [    1.376626] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
        [    1.384329] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=141 assert=0
        [    1.391969] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
        [    1.404966] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
        [    1.413930] [ADDR_MGT] addr_mgt_probe: success.
        [    1.421428] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
        [    1.429684] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
        [    1.437867] sunxi-spinand-phy: not detect any munufacture from id table
        [    1.445517] sunxi-spinand-phy: get spi-nand Model from fdt fail
        [    1.452176] sunxi-spinand-phy: get phy info from fdt fail
        [    1.458432] sunxi-spinand-phy: not detect munufacture from fdt
        [    1.465359] sunxi-spinand-phy: detect munufacture from id table: GD
        [    1.472396] sunxi-spinand-phy: get spi-nand Model from fdt fail
        [    1.479114] sunxi-spinand-phy: get phy info from fdt fail
        [    1.485264] sunxi-spinand-phy: not detect munufacture from fdt
        [    1.491820] sunxi-spinand-phy: not match spinand: f1c8f1c8 f1c8f1c8
        [    1.500032] libphy: Fixed MDIO Bus: probed
        [    1.505646] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
        [    1.513263] sunxi-ehci: EHCI SUNXI driver
        [    1.518445] get ehci0-controller wakeup-source is fail.
        [    1.524641] sunxi ehci0-controller don't init wakeup source
        [    1.530928] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe00076f910, 0x:ffffffd00406f000, irq_no:2e
        [    1.544618] [sunxi-ehci0]: Not init ehci0
        [    1.549821] get ehci1-controller wakeup-source is fail.
        [    1.556114] sunxi ehci1-controller don't init wakeup source
        [    1.562405] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0007700a0, 0x:ffffffd004073000, irq_no:31
        [    1.576146] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
        [    1.589134] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
        [    1.601819] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
        [    1.609204] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
        [    1.619306] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
        [    1.652885] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
        [    1.662384] hub 1-0:1.0: USB hub found
        [    1.667096] hub 1-0:1.0: 1 port detected
        [    1.673442] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
        [    1.680456] sunxi-ohci: OHCI SUNXI driver
        [    1.686319] get ohci0-controller wakeup-source is fail.
        [    1.692289] sunxi ohci0-controller don't init wakeup source
        [    1.698759] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe00076fcd8
        [    1.709320] [sunxi-ohci0]: Not init ohci0
        [    1.714640] get ohci1-controller wakeup-source is fail.
        [    1.720690] sunxi ohci1-controller don't init wakeup source
        [    1.727269] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe000770468
        [    1.737889] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
        [    1.750901] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
        [    1.763569] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
        [    1.770883] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
        [    1.781408] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
        [    1.858499] hub 2-0:1.0: USB hub found
        [    1.863208] hub 2-0:1.0: 1 port detected
        [    1.869955] sunxi_gpadc_init,2151, success
        [    1.875866] sunxi_gpadc_setup: get channel scan data failed
        [    1.883334] input: sunxi-gpadc0 as /devices/virtual/input/input0
        [    1.895405] sunxi-rtc 7090000.rtc: registered as rtc0
        [    1.901265] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T04:02:42 UTC (14562)
        [    1.911365] sunxi-rtc 7090000.rtc: sunxi rtc probed
        [    1.917931] i2c /dev entries driver
        [    1.922493] IR NEC protocol handler initialized
        [    1.928116] sun8iw20-pinctrl 2000000.pinctrl: pin PB7 already requested by 2500c00.uart; cannot claim for 7040000.s_cir
        [    1.940457] sun8iw20-pinctrl 2000000.pinctrl: pin-39 (7040000.s_cir) status -22
        [    1.948690] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 39 (PB7) from group PB7  on device 2000000.pinctrl
        [    1.960835] sunxi-rc-recv 7040000.s_cir: Error applying setting, reverse things back
        [    1.969608] sunxi-rc-recv: probe of 7040000.s_cir failed with error -22
        [    1.981799] usbcore: registered new interface driver uvcvideo
        [    1.988838] USB Video Class driver (1.1.1)
        [    1.993597] sunxi cedar version 1.1
        [    1.997842] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
        [    2.004346] VE: install start!!!
        [    2.004346]
        [    2.010362] VE: cedar-ve the get irq is 6
        [    2.010362]
        [    2.017218] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
        [    2.017218]
        [    2.028944] VE: install end!!!
        [    2.028944]
        [    2.034098] VE: sunxi_cedar_probe
        [    2.038489] Bluetooth: HCI UART driver ver 2.3
        [    2.043917] Bluetooth: HCI UART protocol H4 registered
        [    2.049743] Bluetooth: HCI UART protocol BCSP registered
        [    2.055791] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
        [    2.063350] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
        [    2.069843] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
        [    2.076617] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
        [    2.076617]
        [    2.085437] [XR_BT_LPM] bluesleep_probe: uart_index(1)
        [    2.096723] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
        [    2.107138] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
        [    2.113483] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
        [    2.119860] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
        [    2.126599] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
        [    2.133128] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
        [    2.139687] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
        [    2.146352] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
        [    2.152934] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
        [    2.160077] sunxi-mmc 4020000.sdmmc: Got CD GPIO
        [    2.165563] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
        [    2.172475] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.183909] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
        [    2.202921] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.227584] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
        [    2.233340] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.246119] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
        [    2.256697] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
        [    2.263024] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
        [    2.269466] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
        [    2.276015] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.287717] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
        [    2.294298] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
        [    2.300821] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
        [    2.307629] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
        [    2.314306] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
        [    2.320912] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
        [    2.330097] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.342761] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.354387] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
        [    2.363756] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.375412] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.399922] sunxi-mmc 4021000.sdmmc: detmode:manually by software
        [    2.407711] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
        [    2.415499] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
        [    2.422420] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.434840] sunxi_led_probe()1751 - start
        [    2.439740] sunxi_get_str_of_property()1597 - failed to get the string of propname led_regulator!
        [    2.450066] sunxi_register_led_classdev()1485 - led_classdev start
        [    2.458589] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.472453] mmc0: host does not support reading read-only switch, assuming write-enable
        [    2.481921] sunxi_led_probe()1847 - finish
        [    2.488557] ledtrig-cpu: registered to indicate activity on CPUs
        [    2.496828] ashmem: initialized
        [    2.500495] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [    2.512463] exFAT: Version 1.3.0
        [    2.516119] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [    2.523319] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [    2.535036] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [    2.542805] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [    2.550505] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [    2.557360] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [    2.570218] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
        [    2.588877] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
        [    2.588877]
        [    2.606464] mmc0: new high speed SDHC card at address 0001
        [    2.614631] mmcblk0: mmc0:0001 3333 3.69 GiB
        [    2.619846] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
        [    2.634941] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
        [    2.644853]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
        [    2.651190] sid_rd_ver_reg()254 - ver >= 4, soc ver:5
        [    2.663456] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
        [    2.673623] [SNDCODEC][sunxi_card_init][583]:card init finished
        [    2.683254] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
        [    2.695942] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
        [    2.709314] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
        [    2.722526] NET: Registered protocol family 10
        [    2.727679] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
        [    2.737647] Segment Routing with IPv6
        [    2.742026] NET: Registered protocol family 17
        [    2.747617] Bluetooth: RFCOMM TTY layer initialized
        [    2.753476] Bluetooth: RFCOMM socket layer initialized
        [    2.759287] Bluetooth: RFCOMM ver 1.11
        [    2.797946] sunxi-i2c sunxi-i2c0: sunxi-i2c0 supply twi not found, using dummy regulator
        [    2.817440] sunxi-i2c sunxi-i2c0: probe success
        [    2.824419] sun8iw20-pinctrl 2000000.pinctrl: pin PB7 already requested by 2500c00.uart; cannot claim for 7040000.s_cir
        [    2.836820] sun8iw20-pinctrl 2000000.pinctrl: pin-39 (7040000.s_cir) status -22
        [    2.845188] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 39 (PB7) from group PB7  on device 2000000.pinctrl
        [    2.857286] sunxi-rc-recv 7040000.s_cir: Error applying setting, reverse things back
        [    2.866115] sunxi-rc-recv: probe of 7040000.s_cir failed with error -22
        [    2.879560] clk: Not disabling unused clocks
        [    2.884886] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
        [    2.895096] ALSA device list:
        [    2.898411]   #0: audiocodec
        [    2.901685] alloc_fd: slot 0 not NULL!
        [    2.906068] cfg80211: failed to load regulatory.db
        [    2.920827] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
        [    2.934454] devtmpfs: mounted
        [    2.937996] Freeing unused kernel memory: 156K
        [    2.943068] This architecture does not have kernel memory protection.
          @smiletiger
          我也出现一模一样的问题了,
          [38]set pll start
          [43]set pll end
          [47]board init ok
          [48]ZQ value = 0x30
          [55]trefi:7.8ms
          [63]trefi:7.8ms
          [86]DRAM ODT off.
          [90]DRAM SIZE =64 M
          [92]dram_tpr4:0x0
          [106]dram size =64
          [108]card no is 0
          [138][mmc]: 3763 MB
          [192]mmc not para
          Failed (-19)
          [00.527]update dts
          geth_sys_init fail!
          有一张正常:
          [41]set pll start
          [46]set pll end
          [50]board init ok
          [52]ZQ value = 0x30
          [58]trefi:7.8ms
          [66]trefi:7.8ms
          [89]DRAM ODT off.
          [93]DRAM SIZE =64 M
          [95]dram_tpr4:0x0
          [109]dram size =64
          [111]card no is 0
          [145][mmc]: 3780 MB
          [204]mmc not para
          [00.425]update dts
          geth_sys_init fail!
          Detect comp gzip
          [00.935]
          Starting kernel ...
          [    2.004346]
          [    2.010362]
          [    2.017218]
          [    2.028944]
          [    2.076617]
          [    2.588877]
            @smiletiger
            我也出现一模一样的问题了,
            [38]set pll start
            [43]set pll end
            [47]board init ok
            [48]ZQ value = 0x30
            [55]trefi:7.8ms
            [63]trefi:7.8ms
            [86]DRAM ODT off.
            [90]DRAM SIZE =64 M
            [92]dram_tpr4:0x0
            [106]dram size =64
            [108]card no is 0
            [138][mmc]: 3763 MB
            [192]mmc not para
            Failed (-19)
            [00.527]update dts
            geth_sys_init fail!
            有一张正常:
            [41]set pll start
            [46]set pll end
            [50]board init ok
            [52]ZQ value = 0x30
            [58]trefi:7.8ms
            [66]trefi:7.8ms
            [89]DRAM ODT off.
            [93]DRAM SIZE =64 M
            [95]dram_tpr4:0x0
            [109]dram size =64
            [111]card no is 0
            [145][mmc]: 3780 MB
            [204]mmc not para
            [00.425]update dts
            geth_sys_init fail!
            Detect comp gzip
            [00.935]
            Starting kernel ...
            [    2.004346]
            [    2.010362]
            [    2.017218]
            [    2.028944]
            [    2.076617]
            [    2.588877]
              whycan晕哥 LV 9 @whycan 最后由 编辑
              @whycan 在 试着用t113的uboot测试mipi屏幕,出现问题,能不能帮帮我 中说:
              所以,楼主换张卡应该就OK了.
              • G
                grantho LV 6 最后由 编辑
                我也是显示25.5Hz, 太奇怪了,我调高时钟也解决不了...
                在根文件系统中,获取信息
                root@TinaLinux:/# cat /sys/class/disp/disp/attr/sys
                screen 0:
                de_rate 300000000 hz, ref_fps:60
                mgr0: 800x1280 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[0]
                dmabuf: cache[0] cache max[0] umap skip[0] umap skip max[0]
                        lcd output      backlight(100)  fps:25.5         800x1280
                   BUF    enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[  0] fb[ 800,1280; 800,1280; 800,1280] crop[   0,   0, 800,1280] frame[   0,   0, 800,1280] addr[       0,       0,       0] flags[0x       0] trd[0,0]
