    S3编译
    s3
    4308
    • X
      xingchen123 LV 3 最后由 whycan 编辑
      有没有大佬遇到过S3 sdk 编译报错类似的问题
      Makefile:638: recipe for target 'target-finalize' failed
      make: [target-finalize] Error 1 (ignored)
      find /home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target -type f \( -perm /111 -o -name '*.so*' \) -not \( -name 'libpthread*.so*' -o -name 'ld-*.so*' -o -name '*.ko' \) -print0 | xargs -0 /home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin/arm-linux-gnueabi-strip --remove-section=.comment --remove-section=.note 2>/dev/null || true
      find /home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/lib/ -type f -name 'libpthread*.so*' | \
              xargs -r /home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin/arm-linux-gnueabi-strip --remove-section=.comment --remove-section=.note --strip-debug
      find /home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/lib/ -type f -name 'ld-*.so*' | \
      echo "------/home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target-------"
      test -f /home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/ld.so.conf && \
              { echo "ERROR: we shouldn't have a /etc/ld.so.conf file"; exit 1; } || true
      test -d /home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/ld.so.conf.d && \
              { echo "ERROR: we shouldn't have a /etc/ld.so.conf.d directory"; exit 1; } || true
      mkdir -p /home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc
              echo "NAME=Buildroot"; \
              echo "VERSION=2016.11-gd867218-dirty"; \
              echo "ID=buildroot"; \
              echo "VERSION_ID=2016.11"; \
              echo "PRETTY_NAME=\"Buildroot 2016.11\"" \
      ) >  /home/hzhyxa/hyaf-s3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/os-release
        whycan晕哥 LV 9 @xingchen123 最后由 whycan 编辑
        @xingchen123
        麻烦多贴点log
        • X
          @whycan 麻烦大佬帮我看一下
          root@ubuntu:/home/hzhy/HYAF-S3/workspace# zmake all
          zmake all
          [zeta] exec mkos...
          INFO: build lichee ...
          INFO: chip: sun8iw8p1
          INFO: platform: linux
          INFO: kernel: linux-3.4
          INFO: board: zeta-evb
          INFO: output: out/sun8iw8p1/linux/zeta-evb
          INFO: build buildroot ...
          make: Entering directory '/home/hzhy/HYAF-S3/workspace/buildroot'
          >>>   Finalizing target directory
          mkdir -p /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc
          echo "zeta" > /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/hostname
          /bin/sed -i -e '$a \127.0.1.1\tzeta' -e '/^127.0.1.1/d' /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buil        droot/target/etc/hosts
          echo "Welcome to S3 Linux OS Zeta" > /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/is        sue
          mkdir -p /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/network/
          ( echo "# interface file auto-generated by buildroot"; echo ; echo "auto lo"; echo "iface lo inet loopback"; ) > /home/hzhy/HYA        F-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/network/interfaces
          /bin/sed -i -e s,^root:[^:]*:,root::, /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/s        hadow
          ln -sf busybox /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/bin/sh
          #       /bin/sed -i -e '/# GENERIC_SERIAL$/s~^.*#~ttyS0::respawn:/sbin/getty -L  ttyS0 115200 vt100 #~' /home/hzhy/HYAF-S3/work        space/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/inittab
          /bin/sed -i -e '/^#.*-o remount,rw \/$/s~^#\+~~' /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/t        arget/etc/inittab
          rm -f /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/locales.nopurge
          for i in C en_US locale-archive; do echo $i >> /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/bui        ld/locales.nopurge; done
          for dir in /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/locale; do for langdir        in $dir/*; do if [ -e "${langdir}" ]; then grep -qx "${langdir##*/}" /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/lin        ux/common/buildroot/build/locales.nopurge || rm -rf $langdir; fi done; done
          if [ -d /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/X11/locale ]; then for la        ng in C en_US; do if [ -f /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/X11/loc        ale/$lang/XLC_LOCALE ]; then echo "$lang/XLC_LOCALE: $lang"; fi done > /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/li        nux/common/buildroot/target/usr/share/X11/locale/locale.dir; fi
          rm -rf /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/include /home/hzhy/HYAF-S3/works        pace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/aclocal \
                  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/lib/pkgconfig /home/hzhy/HYAF-S        3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/pkgconfig \
                  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/lib/cmake /home/hzhy/HYAF-S3/wo        rkspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/cmake
          find /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/{lib,share}/ -name '*.cmake' -prin        t0 | xargs -0 rm -f
          find /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/lib/ /home/hzhy/HYAF-S3/workspace/out/        sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/lib/ /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/        buildroot/target/usr/libexec/ \
                  \( -name '*.a' -o -name '*.la' \) -print0 | xargs -0 rm -f
          find: ‘/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/libexec/’: No such file or direc        tory
          rm -rf /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/gdb
          rm -rf /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/zsh
          rm -rf /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/man /home/hzhy/HYAF-S3/workspace        /out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/man
          rm -rf /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/info /home/hzhy/HYAF-S3/workspac        e/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/info
          rm -rf /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/doc /home/hzhy/HYAF-S3/workspace        /out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/doc
          rm -rf /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share/gtk-doc
          rmdir /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/usr/share 2>/dev/null
          find /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target -type f \( -perm /111 -o -name '*.so*'        \) -not \( -name 'libpthread*.so*' -o -name 'ld-*.so*' -o -name '*.ko' \) -print0 | xargs -0 /home/hzhy/HYAF-S3/workspace/out/        sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin/arm-linux-gnueabi-strip --remove-section=.comment --remove-section=.no        te 2>/dev/null || true
          find /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/lib/ -type f -name 'libpthread*.so*' |        \
                  xargs -r /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin/arm-linux-gnueabi-st        rip --remove-section=.comment --remove-section=.note --strip-debug
          find /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/lib/ -type f -name 'ld-*.so*' | \
          test -f /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/ld.so.conf && \
          test -d /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/ld.so.conf.d && \
          ) >  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/etc/os-release
          >>>   Executing post-build script /home/hzhy/HYAF-S3/workspace/build/hooks/rootfs_hook.sh
          '/home/hzhy/HYAF-S3/workspace/build/hooks/udhcpd.conf' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/b        uildroot/target/etc/udhcpd.conf'
          '/home/hzhy/HYAF-S3/workspace/build/hooks/TZ' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/        target/etc/TZ'
          '/home/hzhy/HYAF-S3/workspace/build/hooks/clock' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildro        ot/target/etc/sysconfig/clock'
          '/home/hzhy/HYAF-S3/workspace/build/hooks/zoneinfo/Asia/Hong_Kong' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/li        nux/common/buildroot/target/usr/share/zoneinfo/Asia/Hong_Kong'
          '/home/hzhy/HYAF-S3/workspace/build/hooks/zoneinfo/Asia/Shanghai' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/lin        ux/common/buildroot/target/usr/share/zoneinfo/Asia/Shanghai'
          '/home/hzhy/HYAF-S3/workspace/build/hooks/zoneinfo/Asia/Chongqing' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/li        nux/common/buildroot/target/usr/share/zoneinfo/Asia/Chongqing'
          /home/hzhy/HYAF-S3/workspace/build/hooks /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target
          '/home/hzhy/HYAF-S3/workspace/build/hooks/S40zeta' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/build        root/target/etc/init.d/S40zeta'
          >>>   Generating root filesystem image rootfs.squashfs
          rm -f /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_fakeroot.fs
          rm -f /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
          rm -f /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_users_table.txt
          echo '#!/bin/sh' > /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_fakeroot.fs
          echo "set -e" >> /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_fakeroot.fs
          echo "chown -h -R 0:0 /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target" >> /home/hzhy/HYAF-S        3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_fakeroot.fs
          printf '        - - input -1 * - - - Input device group\n\n' >> /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/com        mon/buildroot/build/_users_table.txt
          PATH="/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/bin:/home/hzhy/HYAF-S3/workspace/out/su        n8iw8p1-linaro-5.3/linux/common/buildroot/host/sbin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroo        t/host/usr/bin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/sbin:/home/hzhy/HYAF-S3/wo        rkspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linu        x/common/buildroot/host/usr/bin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin:/home        /hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/        usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/bui        ldroot/host/usr/bin/" /home/hzhy/HYAF-S3/workspace/buildroot/support/scripts/mkusers /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1        -linaro-5.3/linux/common/buildroot/build/_users_table.txt /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/bu        ildroot/target >> /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_fakeroot.fs
          cat system/device_table.txt > /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_device_table.        txt
          printf '        /bin/busybox                     f 4755 0  0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n\n' >> /home/hzhy/HY        AF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_device_table.txt
          echo "/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin/makedevs -d /home/hzhy/HYAF-S3/        workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_device_table.txt /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-li        naro-5.3/linux/common/buildroot/target" >> /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_        fakeroot.fs
          printf '        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin/mksquashfs /home/hzhy        /HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/target /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3        /linux/common/buildroot/images/rootfs.squashfs -noappend -comp xz\n' >> /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/l        inux/common/buildroot/build/_fakeroot.fs
          chmod a+x /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_fakeroot.fs
          PATH="/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/bin:/home/hzhy/HYAF-S3/workspace/out/su        n8iw8p1-linaro-5.3/linux/common/buildroot/host/sbin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroo        t/host/usr/bin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/sbin:/home/hzhy/HYAF-S3/wo        rkspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linu        x/common/buildroot/host/usr/bin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin:/home        /hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/        usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/bui        ldroot/host/usr/bin/" /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/host/usr/bin/fakeroot -- /ho        me/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/build/_fakeroot.fs
          fakeroot: preload library `libfakeroot.so' not found, aborting.
          fs/squashfs/squashfs.mk:32: recipe for target '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/ima        ges/rootfs.squashfs' failed
          make: *** [/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot/images/rootfs.squashfs] Error 1
          make: Leaving directory '/home/hzhy/HYAF-S3/workspace/buildroot'
          ERROR: build buildroot Failed
          clean... /home/hzhy/HYAF-S3/workspace/prebuild/minigui/zeta.in
          bash: cd: /home/hzhy/HYAF-S3/workspace/prebuild/minigui: No such file or directory
          clean... /home/hzhy/HYAF-S3/workspace/prebuild/qt/zeta.in
          Clear ....
          make: Entering directory '/home/hzhy/HYAF-S3/workspace'
          ---------copy resource file---------
          make: Leaving directory '/home/hzhy/HYAF-S3/workspace'
          clean... /home/hzhy/HYAF-S3/workspace/prebuild/libs/zeta.in
          Clear ....
          -----------------begin--------------------
          target      = libcdc_base.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_base.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_base.so
          install_targets =
          ALL_MODULES=  libcdc_base.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so
          private_asflags =
          private_cflags =  -g --sysroot=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//staging -lc -I/hom        e/hzhy/HYAF-S3/workspace/core/include -D_GNU_SOURCE -Wall -Wno-unused-function -Wno-unused-variable -Wno-unused-but-set-variabl        e -Wno-unused-label -ffunction-sections -fdata-sections -DUSE_LOG_LIB_GLOG
          private_cppflags =
          private_ldflags =  -Wl,--gc-sections
          private_arflags =  -rcs
          -----------------END----------------------
          target      = libcdc_vdecoder.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vdecoder.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vdecoder.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so
          private_asflags =
          private_cppflags =
          target      = libcdc_ve.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_ve.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_ve.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so
          private_asflags =
          private_cppflags =
          target      = libcdc_vencoder.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vencoder.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vencoder.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so
          private_asflags =
          private_cppflags =
          target      = libcdc_memory.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_memory.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_memory.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so
          private_asflags =
          private_cppflags =
          target      = libcdc_sdecoder.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_sdecoder.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_sdecoder.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so
          private_asflags =
          private_cppflags =
          target      = libcdc_vd_avs.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_avs.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_avs.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so
          private_asflags =
          private_cppflags =
          target      = libcdc_vd_h264.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_h264.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_h264.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so
          private_asflags =
          private_cppflags =
          target      = libcdc_vd_h265.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_h265.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_h265.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so
          private_asflags =
          private_cppflags =
          target      = libcdc_vd_mjpegs.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_mjpegs.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_mjpegs.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so
          private_asflags =
          private_cppflags =
          target      = libaw_net.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libaw_net.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libaw_net.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so
          private_asflags =
          private_cppflags =
          target      = libcamera.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcamera.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcamera.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so libcamera.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so  /home/hzhy/HYAF-S3/workspace/out        /sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so
          private_asflags =
          private_cppflags =
          target      = libcutils.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcutils.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libcutils.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so libcamera.so libcutils.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so  /home/hzhy/HYAF-S3/workspace/out        /sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.        3/linux/common/buildroot//target/usr/lib/libcutils.so
          private_asflags =
          private_cppflags =
          target      = librecorder.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//librecorder.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//librecorder.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so libcamera.so libcutils.so librecorder.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so  /home/hzhy/HYAF-S3/workspace/out        /sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.        3/linux/common/buildroot//target/usr/lib/libcutils.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/build        root//target/usr/lib/librecorder.so
          private_asflags =
          private_cppflags =
          target      = libmediaplayer.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libmediaplayer.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libmediaplayer.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so libcamera.so libcutils.so librecorder.so libmediapla        yer.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so  /home/hzhy/HYAF-S3/workspace/out        /sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.        3/linux/common/buildroot//target/usr/lib/libcutils.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/build        root//target/usr/lib/librecorder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/l        ib/libmediaplayer.so
          private_asflags =
          private_cppflags =
          target      = libAdas.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libAdas.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libAdas.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so libcamera.so libcutils.so librecorder.so libmediapla        yer.so libAdas.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so  /home/hzhy/HYAF-S3/workspace/out        /sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.        3/linux/common/buildroot//target/usr/lib/libcutils.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/build        root//target/usr/lib/librecorder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/l        ib/libmediaplayer.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libAdas.so
          private_asflags =
          private_cppflags =
          target      = lib2Img.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//lib2Img.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//lib2Img.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so libcamera.so libcutils.so librecorder.so libmediapla        yer.so libAdas.so lib2Img.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so  /home/hzhy/HYAF-S3/workspace/out        /sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.        3/linux/common/buildroot//target/usr/lib/libcutils.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/build        root//target/usr/lib/librecorder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/l        ib/libmediaplayer.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libAdas.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib2Img.so
          private_asflags =
          private_cppflags =
          target      = libImg.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libImg.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libImg.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so libcamera.so libcutils.so librecorder.so libmediapla        yer.so libAdas.so lib2Img.so libImg.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so  /home/hzhy/HYAF-S3/workspace/out        /sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.        3/linux/common/buildroot//target/usr/lib/libcutils.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/build        root//target/usr/lib/librecorder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/l        ib/libmediaplayer.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libAdas.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib2Img.so  /home/hzhy/HYAF-S3/wor        kspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libImg.so
          private_asflags =
          private_cppflags =
          target      = lib250Img.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//lib250Img.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//lib250Img.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so libcamera.so libcutils.so librecorder.so libmediapla        yer.so libAdas.so lib2Img.so libImg.so lib250Img.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so  /home/hzhy/HYAF-S3/workspace/out        /sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.        3/linux/common/buildroot//target/usr/lib/libcutils.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/build        root//target/usr/lib/librecorder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/l        ib/libmediaplayer.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libAdas.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib2Img.so  /home/hzhy/HYAF-S3/wor        kspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libImg.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-li        naro-5.3/linux/common/buildroot//target/usr/lib/lib250Img.so
          private_asflags =
          private_cppflags =
          target      = libyuv.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libyuv.so
          all_objects =
          all_pre_libs = /home/hzhy/HYAF-S3/workspace/prebuild/libs//libyuv.so
          install_targets =
          ALL_MODULES=  libcdc_base.so libcdc_vdecoder.so libcdc_ve.so libcdc_vencoder.so libcdc_memory.so libcdc_sdecoder.so libcdc_vd_a        vs.so libcdc_vd_h264.so libcdc_vd_h265.so libcdc_vd_mjpegs.so libaw_net.so libcamera.so libcutils.so librecorder.so libmediapla        yer.so libAdas.so lib2Img.so libImg.so lib250Img.so libyuv.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so  /h        ome/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so  /home/hzhy/HYAF-        S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so  /home/hzhy/HYAF-S3/workspace/out/sun        8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-        5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libcdc_sdecoder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//ta        rget/usr/lib/libcdc_vd_avs.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib        cdc_vd_h264.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so  /home/hzhy/H        YAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so  /home/hzhy/HYAF-S3/workspace/out        /sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.        3/linux/common/buildroot//target/usr/lib/libcutils.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/build        root//target/usr/lib/librecorder.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/l        ib/libmediaplayer.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libAdas.so        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib2Img.so  /home/hzhy/HYAF-S3/wor        kspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libImg.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-li        naro-5.3/linux/common/buildroot//target/usr/lib/lib250Img.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/commo        n/buildroot//target/usr/lib/libyuv.so
          private_asflags =
          private_cppflags =
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_base.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vdecoder.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_ve.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vencoder.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_memory.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_sdecoder.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_avs.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h264.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_h265.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libaw_net.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcutils.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/librecorder.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libmediaplayer.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libAdas.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib2Img.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libImg.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/lib250Img.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libyuv.so'
          clean... /home/hzhy/HYAF-S3/workspace/prebuild/wifi_firmware/zeta.in
          Clear ....
          ---------install xr819 wifi firmware-----------
          clean... /home/hzhy/HYAF-S3/workspace/prebuild/configs/zeta.in
          Clear ....
          ---------copy camera.cfg-----------
          build... /home/hzhy/HYAF-S3/workspace/prebuild/minigui/zeta.in
          build... /home/hzhy/HYAF-S3/workspace/prebuild/qt/zeta.in
          make: Nothing to be done for 'modules'.
          build... /home/hzhy/HYAF-S3/workspace/prebuild/libs/zeta.in
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          target      = libAdas.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          target      = lib2Img.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          target      = libImg.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          target      = libyuv.so
          src_files   =
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   =
          cpp_objects =
          inc_path    =
          shared_libs =
          static_libs =
          whole_static_libs =
          all_objects =
          install_targets =
          private_asflags =
          private_cppflags =
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_base.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/co        mmon/buildroot//target/usr/lib/libcdc_base.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vdecoder.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linu        x/common/buildroot//target/usr/lib/libcdc_vdecoder.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_ve.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/comm        on/buildroot//target/usr/lib/libcdc_ve.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vencoder.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linu        x/common/buildroot//target/usr/lib/libcdc_vencoder.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_memory.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/        common/buildroot//target/usr/lib/libcdc_memory.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_sdecoder.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linu        x/common/buildroot//target/usr/lib/libcdc_sdecoder.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_avs.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/        common/buildroot//target/usr/lib/libcdc_vd_avs.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_h264.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux        /common/buildroot//target/usr/lib/libcdc_vd_h264.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_h265.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux        /common/buildroot//target/usr/lib/libcdc_vd_h265.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcdc_vd_mjpegs.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/lin        ux/common/buildroot//target/usr/lib/libcdc_vd_mjpegs.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libaw_net.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/comm        on/buildroot//target/usr/lib/libaw_net.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcamera.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/comm        on/buildroot//target/usr/lib/libcamera.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libcutils.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/comm        on/buildroot//target/usr/lib/libcutils.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//librecorder.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/co        mmon/buildroot//target/usr/lib/librecorder.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libmediaplayer.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux        /common/buildroot//target/usr/lib/libmediaplayer.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libAdas.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/libAdas.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//lib2Img.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common        /buildroot//target/usr/lib/lib2Img.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libImg.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/        buildroot//target/usr/lib/libImg.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//lib250Img.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/comm        on/buildroot//target/usr/lib/lib250Img.so'
          '/home/hzhy/HYAF-S3/workspace/prebuild/libs//libyuv.so' -> '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/        buildroot//target/usr/lib/libyuv.so'
          build... /home/hzhy/HYAF-S3/workspace/prebuild/wifi_firmware/zeta.in
          build... /home/hzhy/HYAF-S3/workspace/prebuild/configs/zeta.in
          clean... /home/hzhy/HYAF-S3/workspace/core/utils/zeta.in
          Clear ....
          target      = /home/hzhy/HYAF-S3/workspace/core/utils//libutils.so
          src_files   = /home/hzhy/HYAF-S3/workspace/core/utils//Thread.cpp
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   = /home/hzhy/HYAF-S3/workspace/core/utils//Thread.cpp
          cpp_objects = /home/hzhy/HYAF-S3/workspace/core/utils//Thread.o
          inc_path    = -I/home/hzhy/HYAF-S3/workspace/core/include
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =    /home/hzhy/HYAF-S3/workspace/core/utils//Thread.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libutils.so
          ALL_MODULES=  libutils.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/utils//libutils.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/lin        ux/common/buildroot//target/usr/lib/libutils.so
          private_asflags =
          private_cflags =  -fPIC -Wall -g --sysroot=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//stagin        g -lc -I/home/hzhy/HYAF-S3/workspace/core/include -D_GNU_SOURCE -Wall -Wno-unused-function -Wno-unused-variable -Wno-unused-but        -set-variable -Wno-unused-label -ffunction-sections -fdata-sections -DUSE_LOG_LIB_GLOG
          private_cppflags =  -fPIC -Wall
          private_ldflags =   --shared -Wl,--gc-sections -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/comm        on/buildroot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildr        oot//target/usr/lib
          removed '/home/hzhy/HYAF-S3/workspace/core/utils//libutils.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libutils.so'
          removed '/home/hzhy/HYAF-S3/workspace/core/utils//libutils.a'
          removed './Thread.o'
          clean... /home/hzhy/HYAF-S3/workspace/core/watermark/zeta.in
          Clear ....
          target      = /home/hzhy/HYAF-S3/workspace/core/watermark//libwater_mark.so
          src_files   = /home/hzhy/HYAF-S3/workspace/core/watermark//water_mark.c /home/hzhy/HYAF-S3/workspace/core/watermark//water_mark        _interface.c
          asm_files   =
          asm_objects =
          c_objects   = /home/hzhy/HYAF-S3/workspace/core/watermark//water_mark.o /home/hzhy/HYAF-S3/workspace/core/watermark//water_mark        _interface.o
          cpp_files   =
          cpp_objects =
          inc_path    = -I/home/hzhy/HYAF-S3/workspace/core/include/include_watermark
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =   /home/hzhy/HYAF-S3/workspace/core/watermark//water_mark.o /home/hzhy/HYAF-S3/workspace/core/watermark//water_ma        rk_interface.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libwater_mark.so
          ALL_MODULES=  libwater_mark.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/watermark//libwater_mark.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linar        o-5.3/linux/common/buildroot//target/usr/lib/libwater_mark.so
          private_asflags =
          private_cflags =  -fPIC -Wall    -g --sysroot=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//sta        ging -lc -I/home/hzhy/HYAF-S3/workspace/core/include -D_GNU_SOURCE -Wall -Wno-unused-function -Wno-unused-variable -Wno-unused-        but-set-variable -Wno-unused-label -ffunction-sections -fdata-sections -DUSE_LOG_LIB_GLOG
          private_ldflags = -lcutils  --shared -Wl,--gc-sections -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/li        nux/common/buildroot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/commo        n/buildroot//target/usr/lib
          removed '/home/hzhy/HYAF-S3/workspace/core/watermark//libwater_mark.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libwater_mark.so'
          removed './water_mark.o'
          removed './water_mark_interface.o'
          clean... /home/hzhy/HYAF-S3/workspace/core/display/zeta.in
          Clear ....
          target      = /home/hzhy/HYAF-S3/workspace/core/display//libhwdisp.so
          src_files   = /home/hzhy/HYAF-S3/workspace/core/display//hwdisplay.cpp
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   = /home/hzhy/HYAF-S3/workspace/core/display//hwdisplay.cpp
          cpp_objects = /home/hzhy/HYAF-S3/workspace/core/display//hwdisplay.o
          inc_path    = -I/home/hzhy/HYAF-S3/workspace/core/include/cutils
          shared_libs = libcutils.so
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =    /home/hzhy/HYAF-S3/workspace/core/display//hwdisplay.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libhwdisp.so
          ALL_MODULES=  libhwdisp.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/display//libhwdisp.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/        linux/common/buildroot//target/usr/lib/libhwdisp.so
          private_asflags =
          removed '/home/hzhy/HYAF-S3/workspace/core/display//libhwdisp.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libhwdisp.so'
          removed './hwdisplay.o'
          clean... /home/hzhy/HYAF-S3/workspace/core/tinyalsa/zeta.in
          Clear ....
          target      = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//libtinyalsa.so
          src_files   = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//mixer.c /home/hzhy/HYAF-S3/workspace/core/tinyalsa//pcm.c
          asm_files   =
          asm_objects =
          c_objects   = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//mixer.o /home/hzhy/HYAF-S3/workspace/core/tinyalsa//pcm.o
          cpp_files   =
          cpp_objects =
          inc_path    = -I/home/hzhy/HYAF-S3/workspace/core/include/tinyalsa
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =   /home/hzhy/HYAF-S3/workspace/core/tinyalsa//mixer.o /home/hzhy/HYAF-S3/workspace/core/tinyalsa//pcm.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libtinyalsa.so
          ALL_MODULES=  libtinyalsa.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/tinyalsa//libtinyalsa.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5        .3/linux/common/buildroot//target/usr/lib/libtinyalsa.so
          private_asflags =
          private_ldflags = -lcutils -lutils  --shared -Wl,--gc-sections -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linar        o-5.3/linux/common/buildroot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/lin        ux/common/buildroot//target/usr/lib
          target      = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinyplay
          src_files   = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinyplay.c
          asm_files   =
          asm_objects =
          c_objects   = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinyplay.o
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =   /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinyplay.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinyplay
          ALL_MODULES=  libtinyalsa.so tinyplay
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/tinyalsa//libtinyalsa.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5        .3/linux/common/buildroot//target/usr/lib/libtinyalsa.so  /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinyplay  /home/hzhy/HYAF        -S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinyplay
          private_asflags =
          private_ldflags = -lcutils -lutils -ltinyalsa  -Wl,--gc-sections -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-lin        aro-5.3/linux/common/buildroot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/l        inux/common/buildroot//target/usr/lib -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildr        oot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//targ        et/usr/lib
          target      = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinycap
          src_files   = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinycap.c
          asm_files   =
          asm_objects =
          c_objects   = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinycap.o
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =   /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinycap.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinycap
          ALL_MODULES=  libtinyalsa.so tinyplay tinycap
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/tinyalsa//libtinyalsa.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5        .3/linux/common/buildroot//target/usr/lib/libtinyalsa.so  /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinyplay  /home/hzhy/HYAF        -S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinyplay  /home/hzhy/HYAF-S3/workspace/core/tinya        lsa//tinycap  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinycap
          private_asflags =
          private_cflags =  -fPIC -Wall -fPIC -Wall -g --sysroot=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/build        root//staging -lc -I/home/hzhy/HYAF-S3/workspace/core/include -D_GNU_SOURCE -Wall -Wno-unused-function -Wno-unused-variable -Wn        o-unused-but-set-variable -Wno-unused-label -ffunction-sections -fdata-sections -DUSE_LOG_LIB_GLOG
          private_cppflags =  -fPIC -Wall -fPIC -Wall
          private_ldflags = -lcutils -lutils -ltinyalsa  -Wl,--gc-sections -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-lin        aro-5.3/linux/common/buildroot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/l        inux/common/buildroot//target/usr/lib -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildr        oot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//targ        et/usr/lib -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib -Wl,--n        o-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib
          target      = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinymix
          src_files   = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinymix.c
          asm_files   =
          asm_objects =
          c_objects   = /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinymix.o
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =   /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinymix.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinymix
          ALL_MODULES=  libtinyalsa.so tinyplay tinycap tinymix
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/tinyalsa//libtinyalsa.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5        .3/linux/common/buildroot//target/usr/lib/libtinyalsa.so  /home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinyplay  /home/hzhy/HYAF        -S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinyplay  /home/hzhy/HYAF-S3/workspace/core/tinya        lsa//tinycap  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinycap  /home/hzhy/        HYAF-S3/workspace/core/tinyalsa//tinymix  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/        usr/bin/tinymix
          private_asflags =
          private_ldflags = -lcutils -lutils -ltinyalsa  -Wl,--gc-sections -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-lin        aro-5.3/linux/common/buildroot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/l        inux/common/buildroot//target/usr/lib -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildr        oot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//targ        et/usr/lib -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib -Wl,--n        o-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib -Wl,-rpath-link=        /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib -Wl,--no-whole-archive -L/home/hzh        y/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib
          removed '/home/hzhy/HYAF-S3/workspace/core/tinyalsa//libtinyalsa.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libtinyalsa.so'
          removed '/home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinyplay'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinyplay'
          removed '/home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinycap'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinycap'
          removed '/home/hzhy/HYAF-S3/workspace/core/tinyalsa//tinymix'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/tinymix'
          removed './tinyplay.o'
          removed './tinycap.o'
          removed './mixer.o'
          removed './tinymix.o'
          removed './pcm.o'
          clean... /home/hzhy/HYAF-S3/workspace/core/interface/zeta.in
          Clear ....
          target      = /home/hzhy/HYAF-S3/workspace/core/interface//libinterface.so
          src_files   = /home/hzhy/HYAF-S3/workspace/core/interface//MemoryBase.cpp /home/hzhy/HYAF-S3/workspace/core/interface//ZetaDisp        layInterface.cpp /home/hzhy/HYAF-S3/workspace/core/interface//ZetaCameraInterface.cpp /home/hzhy/HYAF-S3/workspace/core/interfa        ce//ZetaMediaPlayInterface.cpp
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          cpp_files   = /home/hzhy/HYAF-S3/workspace/core/interface//MemoryBase.cpp /home/hzhy/HYAF-S3/workspace/core/interface//ZetaDisp        layInterface.cpp /home/hzhy/HYAF-S3/workspace/core/interface//ZetaCameraInterface.cpp /home/hzhy/HYAF-S3/workspace/core/interfa        ce//ZetaMediaPlayInterface.cpp
          cpp_objects = /home/hzhy/HYAF-S3/workspace/core/interface//MemoryBase.o /home/hzhy/HYAF-S3/workspace/core/interface//ZetaDispla        yInterface.o /home/hzhy/HYAF-S3/workspace/core/interface//ZetaCameraInterface.o /home/hzhy/HYAF-S3/workspace/core/interface//Ze        taMediaPlayInterface.o
          inc_path    = -I/home/hzhy/HYAF-S3/workspace -I/home/hzhy/HYAF-S3/workspace/core/include/cutils -I/home/hzhy/HYAF-S3/workspace/        core/include/recorder -I/home/hzhy/HYAF-S3/workspace/core/include/mediaplayer -I/home/hzhy/HYAF-S3/workspace/core/include/inter        face -I/home/hzhy/HYAF-S3/workspace/core/include/inculde_adas -I/home/hzhy/HYAF-S3/workspace/core/display -I/home/hzhy/HYAF-S3/        workspace/core/include/hardware -I/home/hzhy/HYAF-S3/workspace/core/include/media -I/home/hzhy/HYAF-S3/workspace/core/include/m        edia/openmax -I/home/hzhy/HYAF-S3/workspace/core/include/system -I/home/hzhy/HYAF-S3/workspace/core/include/cedar
          shared_libs = libhwdisp.so libcamera.so librecorder.so libAdas.so
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =    /home/hzhy/HYAF-S3/workspace/core/interface//MemoryBase.o /home/hzhy/HYAF-S3/workspace/core/interface//ZetaDis        playInterface.o /home/hzhy/HYAF-S3/workspace/core/interface//ZetaCameraInterface.o /home/hzhy/HYAF-S3/workspace/core/interface/        /ZetaMediaPlayInterface.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libinterface.so
          ALL_MODULES=  libinterface.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/interface//libinterface.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro        -5.3/linux/common/buildroot//target/usr/lib/libinterface.so
          private_asflags =
          private_arflags =  -rcs
          -----------------END----------------------
          removed '/home/hzhy/HYAF-S3/workspace/core/interface//libinterface.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libinterface.so'
          removed './MemoryBase.o'
          removed './ZetaMediaPlayInterface.o'
          removed './ZetaCameraInterface.o'
          removed './ZetaDisplayInterface.o'
          make: Leaving directory '/home/hzhy/HYAF-S3/workspace'
          clean... /home/hzhy/HYAF-S3/workspace/core/wifi/zeta.in
          Clear ....
          make: Entering directory '/home/hzhy/HYAF-S3/workspace'
          -----------------begin--------------------
          target      = /home/hzhy/HYAF-S3/workspace/core/wifi//libwifi_ap.so
          src_files   = /home/hzhy/HYAF-S3/workspace/core/wifi//wifi_ap.c
          asm_files   =
          asm_objects =
          c_objects   = /home/hzhy/HYAF-S3/workspace/core/wifi//wifi_ap.o
          cpp_files   =
          cpp_objects =
          inc_path    = -I/home/hzhy/HYAF-S3/workspace/core/include/include_wifi
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =   /home/hzhy/HYAF-S3/workspace/core/wifi//wifi_ap.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libwifi_ap.so
          ALL_MODULES=  libwifi_ap.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/wifi//libwifi_ap.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/li        nux/common/buildroot//target/usr/lib/libwifi_ap.so
          private_asflags =
          private_cflags =  -fPIC -g --sysroot=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//staging -lc        -I/home/hzhy/HYAF-S3/workspace/core/include -D_GNU_SOURCE -Wall -Wno-unused-function -Wno-unused-variable -Wno-unused-but-set-v        ariable -Wno-unused-label -ffunction-sections -fdata-sections -DUSE_LOG_LIB_GLOG
          private_cppflags =
          private_ldflags =  -lpthread  --shared -Wl,--gc-sections -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/        linux/common/buildroot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/com        mon/buildroot//target/usr/lib
          removed '/home/hzhy/HYAF-S3/workspace/core/wifi//libwifi_ap.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libwifi_ap.so'
          removed './wifi_ap.o'
          clean... /home/hzhy/HYAF-S3/workspace/core/camera256/zeta.in
          Clear ....
          target      = /home/hzhy/HYAF-S3/workspace/core/camera256//libcamera256.so
          src_files   = /home/hzhy/HYAF-S3/workspace/core/camera256//v4l2dev.c /home/hzhy/HYAF-S3/workspace/core/camera256//fbdev.c /home        /hzhy/HYAF-S3/workspace/core/camera256//lcd.c /home/hzhy/HYAF-S3/workspace/core/camera256//netdbg.c /home/hzhy/HYAF-S3/workspac        e/core/camera256//usbdbg.c /home/hzhy/HYAF-S3/workspace/core/camera256//imutil.c /home/hzhy/HYAF-S3/workspace/core/camera256//t        imeutil.c /home/hzhy/HYAF-S3/workspace/core/camera256//cvtcolor.c /home/hzhy/HYAF-S3/workspace/core/camera256//font_8x8.c /home        /hzhy/HYAF-S3/workspace/core/camera256//bmp.c /home/hzhy/HYAF-S3/workspace/core/camera256//rgb2jpg.c /home/hzhy/HYAF-S3/workspa        ce/core/camera256//show.c /home/hzhy/HYAF-S3/workspace/core/camera256//emision.c
          asm_files   =
          asm_objects =
          c_objects   = /home/hzhy/HYAF-S3/workspace/core/camera256//v4l2dev.o /home/hzhy/HYAF-S3/workspace/core/camera256//fbdev.o /home        /hzhy/HYAF-S3/workspace/core/camera256//lcd.o /home/hzhy/HYAF-S3/workspace/core/camera256//netdbg.o /home/hzhy/HYAF-S3/workspac        e/core/camera256//usbdbg.o /home/hzhy/HYAF-S3/workspace/core/camera256//imutil.o /home/hzhy/HYAF-S3/workspace/core/camera256//t        imeutil.o /home/hzhy/HYAF-S3/workspace/core/camera256//cvtcolor.o /home/hzhy/HYAF-S3/workspace/core/camera256//font_8x8.o /home        /hzhy/HYAF-S3/workspace/core/camera256//bmp.o /home/hzhy/HYAF-S3/workspace/core/camera256//rgb2jpg.o /home/hzhy/HYAF-S3/workspa        ce/core/camera256//show.o /home/hzhy/HYAF-S3/workspace/core/camera256//emision.o
          cpp_files   =
          cpp_objects =
          inc_path    = -I/home/hzhy/HYAF-S3/workspace/core/camera256 -I/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/commo        n/buildroot/host/usr/arm-buildroot-linux-gnueabi/sysroot/usr/include/freetype2
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =   /home/hzhy/HYAF-S3/workspace/core/camera256//v4l2dev.o /home/hzhy/HYAF-S3/workspace/core/camera256//fbdev.o /ho        me/hzhy/HYAF-S3/workspace/core/camera256//lcd.o /home/hzhy/HYAF-S3/workspace/core/camera256//netdbg.o /home/hzhy/HYAF-S3/worksp        ace/core/camera256//usbdbg.o /home/hzhy/HYAF-S3/workspace/core/camera256//imutil.o /home/hzhy/HYAF-S3/workspace/core/camera256/        /timeutil.o /home/hzhy/HYAF-S3/workspace/core/camera256//cvtcolor.o /home/hzhy/HYAF-S3/workspace/core/camera256//font_8x8.o /ho        me/hzhy/HYAF-S3/workspace/core/camera256//bmp.o /home/hzhy/HYAF-S3/workspace/core/camera256//rgb2jpg.o /home/hzhy/HYAF-S3/works        pace/core/camera256//show.o /home/hzhy/HYAF-S3/workspace/core/camera256//emision.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera256.so
          ALL_MODULES=  libcamera256.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/camera256//libcamera256.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro        -5.3/linux/common/buildroot//target/usr/lib/libcamera256.so
          private_asflags =
          private_cflags =  -fPIC -Wall  -g --sysroot=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//stagi        ng -lc -I/home/hzhy/HYAF-S3/workspace/core/include -D_GNU_SOURCE -Wall -Wno-unused-function -Wno-unused-variable -Wno-unused-bu        t-set-variable -Wno-unused-label -ffunction-sections -fdata-sections -DUSE_LOG_LIB_GLOG
          private_ldflags =  -lpthread --shared -Wl,--gc-sections -Wl,-rpath-link=/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/l        inux/common/buildroot//target/usr/lib -Wl,--no-whole-archive -L/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/comm        on/buildroot//target/usr/lib
          removed '/home/hzhy/HYAF-S3/workspace/core/camera256//libcamera256.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera256.so'
          removed './timeutil.o'
          removed './usbdbg.o'
          removed './v4l2dev.o'
          removed './fbdev.o'
          removed './imutil.o'
          removed './font_8x8.o'
          removed './rgb2jpg.o'
          removed './bmp.o'
          removed './cvtcolor.o'
          removed './emision.o'
          removed './lcd.o'
          removed './netdbg.o'
          removed './show.o'
          clean... /home/hzhy/HYAF-S3/workspace/core/camera320/zeta.in
          Clear ....
          target      = /home/hzhy/HYAF-S3/workspace/core/camera320//libcamera320.so
          src_files   = /home/hzhy/HYAF-S3/workspace/core/camera320//v4l2dev.c /home/hzhy/HYAF-S3/workspace/core/camera320//fbdev.c /home        /hzhy/HYAF-S3/workspace/core/camera320//lcd.c /home/hzhy/HYAF-S3/workspace/core/camera320//netdbg.c /home/hzhy/HYAF-S3/workspac        e/core/camera320//usbdbg.c /home/hzhy/HYAF-S3/workspace/core/camera320//imutil.c /home/hzhy/HYAF-S3/workspace/core/camera320//t        imeutil.c /home/hzhy/HYAF-S3/workspace/core/camera320//cvtcolor.c /home/hzhy/HYAF-S3/workspace/core/camera320//font_8x8.c /home        /hzhy/HYAF-S3/workspace/core/camera320//bmp.c /home/hzhy/HYAF-S3/workspace/core/camera320//rgb2jpg.c /home/hzhy/HYAF-S3/workspa        ce/core/camera320//show.c
          asm_files   =
          asm_objects =
          c_objects   = /home/hzhy/HYAF-S3/workspace/core/camera320//v4l2dev.o /home/hzhy/HYAF-S3/workspace/core/camera320//fbdev.o /home        /hzhy/HYAF-S3/workspace/core/camera320//lcd.o /home/hzhy/HYAF-S3/workspace/core/camera320//netdbg.o /home/hzhy/HYAF-S3/workspac        e/core/camera320//usbdbg.o /home/hzhy/HYAF-S3/workspace/core/camera320//imutil.o /home/hzhy/HYAF-S3/workspace/core/camera320//t        imeutil.o /home/hzhy/HYAF-S3/workspace/core/camera320//cvtcolor.o /home/hzhy/HYAF-S3/workspace/core/camera320//font_8x8.o /home        /hzhy/HYAF-S3/workspace/core/camera320//bmp.o /home/hzhy/HYAF-S3/workspace/core/camera320//rgb2jpg.o /home/hzhy/HYAF-S3/workspa        ce/core/camera320//show.o
          cpp_files   =
          cpp_objects =
          inc_path    = -I/home/hzhy/HYAF-S3/workspace/core/camera320 -I/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/commo        n/buildroot/host/usr/arm-buildroot-linux-gnueabi/sysroot/usr/include/freetype2
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_objects =   /home/hzhy/HYAF-S3/workspace/core/camera320//v4l2dev.o /home/hzhy/HYAF-S3/workspace/core/camera320//fbdev.o /ho        me/hzhy/HYAF-S3/workspace/core/camera320//lcd.o /home/hzhy/HYAF-S3/workspace/core/camera320//netdbg.o /home/hzhy/HYAF-S3/worksp        ace/core/camera320//usbdbg.o /home/hzhy/HYAF-S3/workspace/core/camera320//imutil.o /home/hzhy/HYAF-S3/workspace/core/camera320/        /timeutil.o /home/hzhy/HYAF-S3/workspace/core/camera320//cvtcolor.o /home/hzhy/HYAF-S3/workspace/core/camera320//font_8x8.o /ho        me/hzhy/HYAF-S3/workspace/core/camera320//bmp.o /home/hzhy/HYAF-S3/workspace/core/camera320//rgb2jpg.o /home/hzhy/HYAF-S3/works        pace/core/camera320//show.o
          all_pre_libs =
          install_targets = /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera320.so
          ALL_MODULES=  libcamera320.so
          TARGET_CLEAN =  /home/hzhy/HYAF-S3/workspace/core/camera320//libcamera320.so  /home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro        -5.3/linux/common/buildroot//target/usr/lib/libcamera320.so
          private_asflags =
          removed '/home/hzhy/HYAF-S3/workspace/core/camera320//libcamera320.so'
          removed '/home/hzhy/HYAF-S3/workspace/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/lib/libcamera320.so'
          removed './fbdev.o'
          removed './bmp.o'
          removed './lcd.o'
          removed './show.o'
          build... /home/hzhy/HYAF-S3/workspace/core/utils/zeta.in
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
             CPP    /home/hzhy/HYAF-S3/workspace/core/utils//Thread.o
          /home/hzhy/HYAF-S3/workspace/core/utils//Thread.cpp:16:19: fatal error: stdio.h: No such file or directory
          compilation terminated.
          /home/hzhy/HYAF-S3/workspace/build/Makefile.static:134: recipe for target '/home/hzhy/HYAF-S3/workspace/core/utils//Thread.o' f        ailed
          make: *** [/home/hzhy/HYAF-S3/workspace/core/utils//Thread.o] Error 1
          build... /home/hzhy/HYAF-S3/workspace/core/watermark/zeta.in
          asm_files   =
          asm_objects =
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
             CC    /home/hzhy/HYAF-S3/workspace/core/watermark//water_mark.o
          /home/hzhy/HYAF-S3/workspace/core/watermark//water_mark.c:3:19: fatal error: stdio.h: No such file or directory
          /home/hzhy/HYAF-S3/workspace/build/Makefile.build:152: recipe for target '/home/hzhy/HYAF-S3/workspace/core/watermark//water_ma        rk.o' failed
          make: *** [/home/hzhy/HYAF-S3/workspace/core/watermark//water_mark.o] Error 1
          build... /home/hzhy/HYAF-S3/workspace/core/display/zeta.in
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
             CPP    /home/hzhy/HYAF-S3/workspace/core/display//hwdisplay.o
          In file included from /home/hzhy/HYAF-S3/workspace/core/include/cutils/log.h:1:0,
                           from /home/hzhy/HYAF-S3/workspace/core/display//hwdisplay.cpp:18:
          /home/hzhy/HYAF-S3/workspace/core/include/log/log.h:4:19: fatal error: stdio.h: No such file or directory
          /home/hzhy/HYAF-S3/workspace/build/Makefile.build:156: recipe for target '/home/hzhy/HYAF-S3/workspace/core/display//hwdisplay.        o' failed
          make: *** [/home/hzhy/HYAF-S3/workspace/core/display//hwdisplay.o] Error 1
          build... /home/hzhy/HYAF-S3/workspace/core/tinyalsa/zeta.in
          asm_files   =
          asm_objects =
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
          asm_files   =
          asm_objects =
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
          asm_files   =
          asm_objects =
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
          asm_files   =
          asm_objects =
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
             CC    /home/hzhy/HYAF-S3/workspace/core/tinyalsa//mixer.o
          /home/hzhy/HYAF-S3/workspace/core/tinyalsa//mixer.c:29:19: fatal error: stdio.h: No such file or directory
          /home/hzhy/HYAF-S3/workspace/build/Makefile.build:152: recipe for target '/home/hzhy/HYAF-S3/workspace/core/tinyalsa//mixer.o'        failed
          make: *** [/home/hzhy/HYAF-S3/workspace/core/tinyalsa//mixer.o] Error 1
          build... /home/hzhy/HYAF-S3/workspace/core/interface/zeta.in
          asm_files   =
          asm_objects =
          c_files     =
          c_objects   =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
             CPP    /home/hzhy/HYAF-S3/workspace/core/interface//MemoryBase.o
          In file included from /home/hzhy/HYAF-S3/workspace/core/interface//MemoryBase.cpp:1:0:
          /home/hzhy/HYAF-S3/workspace/core/include/interface/MemoryBase.h:4:20: fatal error: stdlib.h: No such file or directory
           #include <stdlib.h>
          /home/hzhy/HYAF-S3/workspace/build/Makefile.build:156: recipe for target '/home/hzhy/HYAF-S3/workspace/core/interface//MemoryBa        se.o' failed
          make: *** [/home/hzhy/HYAF-S3/workspace/core/interface//MemoryBase.o] Error 1
          build... /home/hzhy/HYAF-S3/workspace/core/wifi/zeta.in
          asm_files   =
          asm_objects =
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
          private_cppflags =
             CC    /home/hzhy/HYAF-S3/workspace/core/wifi//wifi_ap.o
          /home/hzhy/HYAF-S3/workspace/core/wifi//wifi_ap.c:16:20: fatal error: unistd.h: No such file or directory
          /home/hzhy/HYAF-S3/workspace/build/Makefile.build:152: recipe for target '/home/hzhy/HYAF-S3/workspace/core/wifi//wifi_ap.o' fa        iled
          make: *** [/home/hzhy/HYAF-S3/workspace/core/wifi//wifi_ap.o] Error 1
          build... /home/hzhy/HYAF-S3/workspace/core/camera256/zeta.in
          asm_files   =
          asm_objects =
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
             CC    /home/hzhy/HYAF-S3/workspace/core/camera256//v4l2dev.o
          /home/hzhy/HYAF-S3/workspace/core/camera256//v4l2dev.c:1:19: fatal error: stdio.h: No such file or directory
          /home/hzhy/HYAF-S3/workspace/build/Makefile.build:152: recipe for target '/home/hzhy/HYAF-S3/workspace/core/camera256//v4l2dev.        o' failed
          make: *** [/home/hzhy/HYAF-S3/workspace/core/camera256//v4l2dev.o] Error 1
          build... /home/hzhy/HYAF-S3/workspace/core/camera320/zeta.in
          asm_files   =
          asm_objects =
          cpp_files   =
          cpp_objects =
          shared_libs =
          static_libs =
          whole_static_libs =
          pre_shared_libs =
          all_pre_libs =
          private_asflags =
             CC    /home/hzhy/HYAF-S3/workspace/core/camera320//v4l2dev.o
          /home/hzhy/HYAF-S3/workspace/core/camera320//v4l2dev.c:1:19: fatal error: stdio.h: No such file or directory
          /home/hzhy/HYAF-S3/workspace/build/Makefile.build:152: recipe for target '/home/hzhy/HYAF-S3/workspace/core/camera320//v4l2dev.        o' failed
          make: *** [/home/hzhy/HYAF-S3/workspace/core/camera320//v4l2dev.o] Error 1
            whycan晕哥 LV 9 @xingchen123 最后由 编辑
            @xingchen123
            不知道为啥会这样, 建议重新解压SDK编译试一试,如果再不行就问下索智那边FAE。
            X 1 条回复 最后回复 回复 引用 分享 0
            • X
              xingchen123 LV 3 @whycan 最后由 编辑
              @whycan 谢谢了
