    tplayerdemo播放视频bug
      mumula LV 4 最后由 编辑
      刚收到的板子,使用默认的固件,屏幕用的是1080P的HDMI屏
      系统启动后运行如下命令
      root@TinaLinux:/sys/kernel/debug/dispdbg# history
         0 cd /sys/kernel/debug/dispdbg
         1 echo disp0 > name; echo switch1 > command; echo 4 10 0 0 0x4 0x101 0 0 0 8 > param; echo 1 > start;
         2 tplayerdemo /usr/lib/tt-data/01-1080P-HEVC-AAC-60F.mkv&
      出现大段的类似错误
      DEBUG  : cedarc <HevcParseExtraData:3250>: ****can not find the stream type!
      几秒钟后视频开始播放可以听到画面和声音
      但是只播了几秒钟就卡住了,打印信息如下
      DEBUG  : awplayer <BaseCompPostAndWait:61>: audio decoder receive cmd: start
      (Allwinner Audio Middle Layer),line(971) : Create Decoder!!=====
      DEBUG  : audioDecItf <handleStart:1065>: Create libadecoder success...
      (Allwinner Audio Middle Layer),line(603) : AudioDec_Installaudiolib ok
      (Allwinner Audio Middle Layer),line(606) : audio decoder init start ...
      (AllwinnerAlibs),line(50) :
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Audio <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : audiocodec-v1.2
      branch: new
      commit: 3ba65962c01cbf1280ddda19d843009b6ef8ce85
      date  : Tue Jan 8 16:25:27 2019 +0800
      (AllwinnerAlibs),line(700) : ----Loading so success!
      (AllwinnerAlibs),line(902) : *************pAudioStreamInfo start******************
      (AllwinnerAlibs),line(903) : eCodecFormat         :id(4), name(aac low-complexy)
      (AllwinnerAlibs),line(904) : eSubCodecFormat      :0
      (AllwinnerAlibs),line(905) : nChannelNum          :2
      (AllwinnerAlibs),line(906) : nBitsPerSample       :32
      (AllwinnerAlibs),line(907) : nSampleRate          :48000
      (AllwinnerAlibs),line(908) : nAvgBitrate          :0
      (AllwinnerAlibs),line(909) : nMaxBitRate          :0
      (AllwinnerAlibs),line(910) : nFileSize            :0
      (AllwinnerAlibs),line(911) : eAudioBitstreamSource:0
      (AllwinnerAlibs),line(912) : eDataEncodeType      :1
      (AllwinnerAlibs),line(913) : nCodecSpecificDataLen:5
      (AllwinnerAlibs),line(914) : pCodecSpecificData   :0x3fc806b950
      (AllwinnerAlibs),line(915) : nFlags               :0
      (AllwinnerAlibs),line(916) : nBlockAlign          :0
      (AllwinnerAlibs),line(917) : *************pAudioStreamInfo end  ******************
      (AAC Decoder),line(36) : init successs...
      (Allwinner Audio Middle Layer),line(614) : AUDIO DECODE INIT OK...0
      DEBUG  : awplayer <BaseCompPostAndWait:61>: video render receive cmd: start
      DEBUG  : awplayer <handleStart:640>: video render handleStart:p->eStatus = 0
      DEBUG  : awplayer <BaseCompPostAndWait:61>: audio render receive cmd: start
      INFO   : audioRender <handleStart:295>: audio render process start message.
      DEBUG  : audioRender <initSoundDevice:478>: init sound device.
      DEBUG  : audioRender <initSoundDevice:486>: set sound devide param, sample rate = 48000, channel num = 2.
      DEBUG : tsoundcontrol <TSoundDeviceSetFormat:193>: TinaSoundDeviceSetFormat(),sc->sound_status == 2
      DEBUG : tsoundcontrol <TSoundDeviceSetFormat:195>: TinaSoundDeviceSetFormat()
      DEBUG : tsoundcontrol <TSoundDeviceSetFormat:201>: TinaSoundDeviceSetFormat()>>>sample_rate:48000,channel_num:2,sc->bytes_per_sample:4
      WARNING: awplayer <callbackProcess:3674>: message 0x40a not handled.
      DEBUG  : demuxComponent <DemuxThread:2115>: process message DEMUX_COMMAND_START.
      started.
      DEBUG  : awplayer <CallbackProcess:3171>: first audio pts = 0
      DEBUG  : cedarc <HevcSbmFrameCheckBitStreamType:319>: result: bStreamWithStartCode[0], with[0], whitout[1]
      DEBUG  : cedarc <HevcInitialFBM:342>: *** nExtraBufNum[6] = displayHoldNum[3] + rotateHoldNum[0] + smoothNum[3]
      DEBUG  : cedarc <HevcInitialFBM:362>: **(one output) nFbmNum[14] = maxDPBNum[6] + maxReoderNum[2] + extraNum[6]
      DEBUG  : cedarc <HevcInitialFBM:369>:  h265 initial fbm number: 14, reference pictures: 6.             reorder pictures: 2, real_w: 1920, real_h: 1080
      DEBUG  : cedarc <VeSetAdjustDramSpeedFlag:1796>: **** VeSetAdjustDramSpeedFlag: 0
      DEBUG  : cedarc <VeSetEnableAfbcFlag:1787>: **** VeSetEnableAfbcFlag: 0
      DEBUG  : cedarc <HevcInitialFBM:401>: *************** pHevcDec->bEnableAfbcFlag = 0
      DEBUG  : cedarc <HevcInitialFBM:432>: b10BitStreamFlag = 0, 0
      DEBUG  : fbm.c <FbmCreateBuffer:149>: FbmCreate, total fbm number: 14, decoder needed: 8,  nWidth=1920, nHeight=1080, nAlignStride = 32
      DEBUG  : fbm.c <FbmCreateBuffer:310>: *** calcute nLower2BitBufOffset = 0(0.00), stride = 0
      DEBUG  : fbm.c <FbmCreateBuffer:409>: *** finish fbmCreateBuffer
      DEBUG  : awplayer <RenderGetVideoFbmBufInfo:1468>: video buffer info: nWidth[1920],nHeight[1088],nBufferCount[14],ePixelFormat[5]
      DEBUG  : awplayer <RenderGetVideoFbmBufInfo:1471>: video buffer info: nAlignValue[32],bProgressiveFlag[1],bIsSoftDecoderFlag[0]
      DEBUG  : awplayer <__LayerControl:1003>: layer control cmd = 257
      DEBUG  : awplayer <__LayerControl:1005>: get the fbm buf info
      DEBUG  : awplayer <__LayerControl:1007>: fbmBufInfo->bProgressiveFlag = 1
      DEBUG  : awplayer <__LayerControl:1013>: lc->mNumHoldByLayer = 3
      DEBUG  : awplayer <__LayerSetDisplayPixelFormat:599>: Layer set expected pixel format, format = 5
      DEBUG  : awplayer <__LayerSetDisplayBufferSize:551>: __LayerSetDisplayBufferSize:width = 1920,height = 1088
      DEBUG  : awplayer <__LayerSetDisplayBufferCount:892>: LayerSetBufferCount: count = 14
      DEBUG  : awplayer <__LayerControl:1003>: layer control cmd = 260
      DEBUG  : awplayer <__LayerControl:1016>: get the fbm buf info
      DEBUG  : awplayer <__LayerControl:1022>: b10BitPicFlag = 0, nLbcLossyComMod = 0, bIsLossy = 0, bRcEn = 0
      DEBUG  : awplayer <__LayerGetBufferNumHoldByGpu:907>: num hold by gpu is 3
      DEBUG  : awplayer <SetGpuBufferToDecoder:1510>: SetGpuBufferToDecoder:nNumHoldByLayer = 3,p->nGpuBufferNum = 14
      DEBUG  : awplayer <setLayerBuffer:135>: setLayerBuffer:Fmt(5),(1920 1088, 0 x 0)
      DEBUG  : awplayer <setLayerBuffer:138>: Disp(1920x1088)buf_cnt(14),ProFlag(0),SoftDecFlag(0)
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[0]:0x3fcf101000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[1]:0x3fcee04000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[2]:0x3fceb07000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[3]:0x3fce80a000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[4]:0x3fce50d000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[5]:0x3fce210000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[6]:0x3fcdf13000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[7]:0x3fcdc16000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[8]:0x3fcd919000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[9]:0x3fcd61c000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[10]:0x3fcd31f000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[11]:0x3fcd022000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[12]:0x3fccd25000
      DEBUG  : awplayer <setLayerBuffer:325>: SunxiMemPalloc buf[13]:0x3fcca28000
      DEBUG  : awplayer <__LayerDequeueBuffer:724>: numNotHoldByLayer = 11,lc->nGpuBufferCount = 14
      ERROR  : awplayer <__LayerQueueBuffer:865>: *** picNode is full when queue buffer
      DEBUG  : awplayer <callbackProcess:3503>: *************decoded nWidth = 1920,nHeight = 1080********
      DEBUG : tplayer <CallbackFromXPlayer:96>: video decoded width = 1920,height = 1080
      *****tplayer:video decoded width = 1920,height = 1080
      *****tplayerdemo:video decoded width = 1920,height = 1080real set to display rect:w = 1920,h = 1080
      warning: unknown callback from Tinaplayer.
      INFO   : awplayer <callbackProcess:3519>: xxxxxxxxxx video size : width = 1920, height = 1080
      DEBUG : tplayer <CallbackFromXPlayer:85>: video width = 1920,height = 1080
      *****tplayer:video width = 1920,height = 1080
      DEBUG  : awplayer <CallbackProcess:3045>: first video pts = 0
      DEBUG  : audioRender <startSoundDevice:708>: start sound device.
      DEBUG : tsoundcontrol <TSoundDeviceStart:212>: TinaSoundDeviceStart(): sc->sound_status = 2
      DEBUG : tsoundcontrol <setSoundDeviceParams:62>: setSoundDeviceParams()
      DEBUG : tsoundcontrol <setSoundDeviceParams:117>: alsa-init: chunksize set to 960
      DEBUG : tsoundcontrol <setSoundDeviceParams:126>: alsa-init: fragcount=4
      DEBUG : tsoundcontrol <setSoundDeviceParams:136>: setSoundDeviceParams():sc->alsa_can_pause = 0
      WARNING: audioRender <checkSampleRate:647>: sample rate change from 48000 to 48000.
      WARNING: audioRender <checkSampleRate:649>: channel num change from 2 to 2.
      WARNING: audioRender <checkSampleRate:651>: bitPerSample num change from 16 to 16.
      WARNING: audioRender <checkSampleRate:653>: if need direct out put flag change from 0 to 1.
      WARNING: audioRender <checkSampleRate:655>: data type change from 1 to 1.
      DEBUG : tsoundcontrol <TSoundDeviceStop:259>: TinaSoundDeviceStop():sc->sound_status = 0
      WARNING: audioRender <checkSampleRate:674>: start sound devide again because samplaRate or channelNum change
      ERROR  : fbm.c <FbmReturnPicture:1002>: invalid frame status, a picture being returned,                 but bUsedByRender=0, bInValidPictureQueue=0, bAlreadyDisplayed=0.
      ERROR  : fbm.c <FbmReturnPicture:1003>: **picture[0x3fc4002438],id[11]
      WARNING: cedarc <ReturnPicture:1849>: FbmReturnPicture return fail,            it means the picture being returned it not one of this FBM.
        whycan晕哥 LV 9 @mumula 最后由 编辑
        @mumula
        试一试.mp4文件。
        M 1 条回复 最后回复 回复 引用 分享 0
          mumula LV 4 @whycan 最后由 编辑
          @whycan 好吧
