    V536H 开发板camera启动不了
    • jinxiangwzh
      jinxiangwzh LV 7 最后由 编辑
      下载代理提供的镜像也启动不了,麻烦看一下启动log是怎么回事
      [73]rsb_send_initseq: rsb clk 400Khz -> 3Mhz
      [77]PMU: AXP2101
      [80]set pll start
      [82]set pll end
      [84]rtc[3] value = 0x0000a201
      [87]DRAM BOOT DRIVE INFO: V0.41
      [90]the chip id is 0x00000004
      [93]the chip id is 0x00000004
      [96]the chip id is 0x00000004
      [99]the chip id is 0x00000004
      [101]the chip id is 0x00000004
      [104]chip id check OK
      [107]DRAM_VCC set to 1500 mv
      [109]DRAM CLK =792 MHZ
      [112]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [150]Training result is = 00000007
      [153]Actual DRAM SIZE =256 M
      [156]DRAM SIZE =256 MBytes, para1 = 000030da, para2 = 01000000, dram_tpr13 = 08006843
      [173]DRAM simple test OK.
      [175]dram size =256
      [179]sunxi spinor is initing...ok
      [182]spinor id is 001920c2
      [185]Succeed in reading toc file head.
      [188]The size of toc is 00084000.
      [300]Entry_name        = scp
      [310]set arisc reset to de-assert state
      [314]Entry_name        = optee
      [317]Entry_name        = u-boot
      [323]Entry_name        = soc-cfg
      [327]Entry_name        = dtb
      [331]Ready to disable icache.
      [334]Jump to secend Boot.
      MESSAGE: [0x0] TEE-CORE: OP-TEE version: sun8iw15p1_a50_8.1.0_v1.0-102-ga90d1c9 #2 2019年 05月 27日 星期一 02:20:12 UTC arm
      MESSAGE: [0x0] TEE-CORE: arisc commit: e6b659ca2dd490901ce7543224ddfca94cfa924a
      U-Boot 2014.07 (May 27 2019 - 19:31:28) Allwinner Technology
      uboot commit : b1c1c5fb19667b71b0df55c0968121310132e2bd
      secure enable bit: 0
      normal mode: with secure monitor
      [0.369]rsb init by cpus
      [0.369]pmbus:   ready
      [0.369]PMU: AXP21
      [0.370]bat_vol=1098, ratio=0
      [0.371]set power on vol to default
      [0.374]dcdc2_vol = 900, onoff=1
      [0.377]dcdc3_vol = 920, onoff=1
      [0.380]dcdc4_vol = 1360, onoff=1
      [0.383]boot0_sys_vol = 3428, onoff=1
      [0.386]find power_sply to end
      [0.389]PMU: cpux 912 Mhz,AXI=304 Mhz
      PLL6=600 Mhz,AHB1=200 Mhz, APB1=150Mhz MBus=400Mhz
      DRAM:  256 MiB
      [0.399]fdt addr: 0x4e1d2320
      [0.400]gd->fdt_size: 0x16da0
      Relocation Offset is: 0cdb3000
      gic: sec monitor mode
      [0.421]flash init start
      workmode = 0,storage type = 3
      [0.421]spinor:   0
      get flash_size warning
      flash size =0x4000 sectors
      sunxi spinor is initing...OK
      spinor id:0x1920c2
      spi_freq = 40000000
      [0.425]sunxi flash init ok
      [0.427]sunxi flash init ok
      spinor read: start 0x7e0, sector 0x20
      used mbr [0], count = 6
      [0.435]flash init end
      [0.437]try to burn key
      spinor read: start 0x7c00, sector 0x100
      --------fastboot partitions--------
      -total partitions:6-
      -name-        -start-       -size-
      boot        : 4000          2c0000
      rootfs      : 2c4000        b40000
      overlay     : e04000        80000
      env         : e84000        20000
      bootlogo    : ea4000        40000
      UDISK       : ee4000        0
      [0.477]base bootcmd=run setargs_nand boot_normal
      [0.481]key 0
      [0.482]cant find rcvy value
      [0.485]cant find fstbt value
      [0.487]no misc partition is found
      [0.490]to be run cmd=run setargs_nor boot_normal
      [0.498](weak)update dtb dram start
      [0.499]update dtb dram  end
      PowerBus = 2( 2:vBus 3:acBus other: not exist)
      pre sys mode
      Battery Voltage=413, Ratio=0
      key trigger
      sunxi_bmp_logo_display
      spinor read: start 0x7d00, sector 0x200
      [0.681]inter uboot shell
      [0.681]read partition: boot or recovery
      spinor read: start 0x800, sector 0x40
      spinor read: start 0x840, sector 0x13fb
      [0.946]sunxi flash read :offset 4000, 2652064 bytes OK
      ## Booting kernel from Legacy Image at 45000000 ...
         Image Name:   ARM OpenWrt Linux-4.9.118
         Image Type:   ARM Linux Kernel Image (uncompressed)
         Data Size:    2651488 Bytes = 2.5 MiB
         Load Address: 40008000
         Entry Point:  40008000
         Loading Kernel Image ... OK
         reserving fdt memory region: addr=419e4000 size=13000
         reserving fdt memory region: addr=419f7000 size=4000
         reserving fdt memory region: addr=419fb000 size=5000
         Using Device Tree in place at 42000000, end 42019d9f
      force sunxi spinor exit
      Starting kernel ...
      [    0.000000] Linux version 4.9.118 (jamo@jamo-pc) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #7 SMP PREEMPT Mon May 23 06:05:11 UTC 2022
      [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
      [    0.000000] OF: fdt:Machine model: sun8iw16
      [    0.000000] ion_mem_reserve: reserve 180MiB at 0x44c00000
      [    0.000000] On node 0 totalpages: 65536
      [    0.000000] free_area_init_node: node 0, pgdat c03e8500, node_mem_map c49f8000
      [    0.000000]   Normal zone: 512 pages used for memmap
      [    0.000000]   Normal zone: 65536 pages, LIFO batch:15
      [    0.000000] percpu: Embedded 13 pages/cpu @c499f000 s21132 r8192 d23924 u53248
      [    0.000000] pcpu-alloc: s21132 r8192 d23924 u53248 alloc=13*4096
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000c00 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mtdblock2 init=/pseudo_init partitions=boot@mtdblock1:rootfs@mtdblock2:overlay@mtdblock3:env@mtdblock4:bootlogo@mtdblock5:UDISK@mtdblock6 cma= ion_carveout_list=180M@256M
      [    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
      [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
      [    0.000000] Memory: 70872K/262144K available (2491K kernel code, 188K rwdata, 988K rodata, 160K init, 138K bss, 191272K reserved, 0K cma-reserved, 0K highmem)
      [    0.000000]     vmalloc : 0xd0800000 - 0xff800000   ( 752 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
      [    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc0276f04   (2492 kB)
      [    0.000000]       .init : 0xc0392000 - 0xc03ba000   ( 160 kB)
      [    0.000000]       .data : 0xc03ba000 - 0xc03e9308   ( 189 kB)
      [    0.000000]        .bss : 0xc03e9308 - 0xc040be9c   ( 139 kB)
      [    0.000018] Switching to timer-based delay loop, resolution 41ns
      [    0.000054] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000067] pid_max: default: 4096 minimum: 301
      [    0.000213] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000224] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000767] CPU: Testing write buffer coherency: ok
      [    0.001166] CPU0: update cpu_capacity 1024
      [    0.001179] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.001205] Setting up static identity map for 0x40008240 - 0x4000828c
      [    0.170589] CPU1: update cpu_capacity 1024
      [    0.170596] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.170683] Brought up 2 CPUs
      [    0.170702] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.170709] CPU: All CPU(s) started in SVC mode.
      [    0.171326] devtmpfs: initialized
      [    0.193127] OF: Duplicate name in regulator@0, renamed to "regulator2#1"
      [    0.193170] OF: Duplicate name in regulator@0, renamed to "regulator3#1"
      [    0.193202] OF: Duplicate name in regulator@0, renamed to "regulator7#1"
      [    0.197966] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.198546] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.198568] futex hash table entries: 16 (order: -2, 1024 bytes)
      [    0.198655] pinctrl core: initialized pinctrl subsystem
      [    0.199855] NET: Registered protocol family 16
      [    0.200140] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.201502] dump_class_init,862, success
      [    0.239739] cpuidle: using governor menu
      [    0.243235] sun8iw16p1-r-pinctrl r_pio: initialized sunXi PIO driver
      [    0.255997] sun8iw16p1-pinctrl pio: initialized sunXi PIO driver
      [    0.257502] sunxi hwspinlock vbase:0xd0858000
      [    0.310112] pwm module init!
      [    0.313843] sunxi-pm debug v3.10
      [    0.315514] G2D: Module initialized.major:253
      [    0.316011] sunxi_spi_probe()2322 - [spi0] SPI MASTER MODE
      [    0.316078] sunxi_spi_request_gpio()1948 - [spi0] Pinctrl init spi0
      [    0.316142] sunxi_spi_clk_init()1998 - [spi0] mclk 200000000
      [    0.316599] spi spi0: master is unqueued, this is deprecated
      [    0.316875] sunxi_spi_probe()2407 - [spi0]: driver probe succeed, base d085e000, irq 306
      [    0.317193] media: Linux media interface: v0.10
      [    0.317248] Linux video capture interface: v2.00
      [    0.318601] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.318878] ion_parse_dt_heap_common: id 1 type 1 name sys_contig align 1000
      [    0.319102] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.319306] ion_parse_dt_heap_common: id 2 type 2 name carveout align 1000
      [    0.319319] ion_parse_dt_heap_common: carveout(ion_carveout_list-2): base 0x44c00000, size 0xb400000
      [    0.412908] Advanced Linux Sound Architecture Driver Initialized.
      [    0.414298] [axp2101] chip id detect 0x47 !
      [    0.414431] [axp2101] enable dcdc2 dvm.
      [    0.440470] clocksource: Switched to clocksource arch_sys_counter
      [    0.443184] get androidboot.mode fail
      [    0.443201] sunxi_i2c_adap_init()2494 - init
      [    0.443620] [i2c0] twi_regulator: vcc-pi
      [    0.443691] sunxi_i2c_probe()2253 - [i2c0] twi_drv_used = 1
      [    0.443779] twi_request_gpio()450 - [i2c0] init name: twi0
      [    0.450383] sunxi_i2c_dma_request()1104 - [i2c0] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
      [    0.450762] sunxi_i2c_probe()2196 - [i2c1] warning: failed to get regulator id
      [    0.450846] sunxi_i2c_probe()2253 - [i2c1] twi_drv_used = 1
      [    0.450857] twi_request_gpio()450 - [i2c1] init name: twi1
      [    0.451066] sunxi_i2c_dma_request()1104 - [i2c1] using dma0chan2 (tx) and dma0chan3 (rx)for DMA transfers
      [    0.451367] sunxi_i2c_probe()2196 - [i2c2] warning: failed to get regulator id
      [    0.451430] sunxi_i2c_probe()2253 - [i2c2] twi_drv_used = 0
      [    0.451440] twi_request_gpio()450 - [i2c2] init name: twi2
      [    0.453254] NET: Registered protocol family 2
      [    0.453889] TCP established hash table entries: 16 (order: -6, 64 bytes)
      [    0.453911] TCP bind hash table entries: 16 (order: -5, 128 bytes)
      [    0.453920] TCP: Hash tables configured (established 16 bind 16)
      [    0.453970] UDP hash table entries: 128 (order: 0, 4096 bytes)
      [    0.453990] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
      [    0.454155] NET: Registered protocol family 1
      [    0.454438] sunxi budget cooling probe start !
      [    0.454462] CPU freq cooling register Success
      [    0.454478] CPU hotplug cooling register Success
      [    0.454732] CPU budget cooling register Success
      [    0.456370] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.462206] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.462472] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
      [    0.463939] io scheduler noop registered
      [    0.463952] io scheduler deadline registered
      [    0.464141] io scheduler cfq registered (default)
      [    0.464856] [DISP]disp_module_init
      [    0.523450] [DISP] lcd_clk_config,line:652:
      [    0.523468] disp 0, clk: pll(100000000),clk(100000000),dclk(25000000) dsi_rate(25000000)
      [    0.523468]      clk real:pll(99000000),clk(99000000),dclk(24750000) dsi_rate(24750000)
      [    0.524057] [DISP]disp_module_init finish
      [    0.525665] uart0: ttyS0 at MMIO 0x5000000 (irq = 297, base_baud = 1500000) is a SUNXI
      [    0.525690] sw_console_setup()1777 - console setup baud 115200 parity n bits 8, flow n
      [    1.230963] [DISP] disp_device_attached_and_enable,line:221:
      [    1.230964] attached ok, mgr0<-->dev0
      [    1.230974] [DISP] disp_device_attached_and_enable,line:224:
      [    1.230975] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
      [    1.443795] console [ttyS0] enabled
      [    1.448561] uart4: ttyS4 at MMIO 0x5001000 (irq = 298, base_baud = 1500000) is a SUNXI
      [    1.458325] misc dump reg init
      [    1.464640] loop: module loaded
      [    1.468548] m25p80 spi0.0: found mx25l25635e, expected m25p80
      [    1.475116] m25p80 spi0.0: mx25l25635e (32768 Kbytes)
      [    1.482546] 7 sunxipart partitions found on MTD device spi0.0
      [    1.489012] Creating 7 MTD partitions on "spi0.0":
      [    1.494432] 0x000000000000-0x000000100000 : "uboot"
      [    1.511275] 0x000000100000-0x0000003c0000 : "boot"
      [    1.517949] 0x0000003c0000-0x000000f00000 : "rootfs"
      [    1.534845] 0x000000f00000-0x000000f80000 : "overlay"
      [    1.551736] 0x000000f80000-0x000000fa0000 : "env"
      [    1.568221] 0x000000fa0000-0x000000fe0000 : "bootlogo"
      [    1.575249] 0x000000fe0000-0x000002000000 : "UDISK"
      [    1.592170] usb_serial_number:20080411
      [    1.596608] sunxi_gpadc_init,1773, success
      [    1.602049] input: sunxi-gpadc0 as /devices/virtual/input/input0
      [    1.609833] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    1.616794] sunxi-rtc rtc: RTC enabled
      [    1.621323] i2c /dev entries driver
      [    1.625842] sunxi cedar version 0.1
      [    1.629882] VE: install start!!!
      [    1.629882]
      [    1.635317] cedar_ve: cedar-ve the get irq is 294
      [    1.640711] VE: line 1811 set the sram data
      [    1.640711]
      [    1.647406] VE: ve_debug_proc_info:c0407cec, data:c466c000, lock:c0407d74
      [    1.647406]
      [    1.656731] VE: install end!!!
      [    1.656731]
      [    1.662175] google_vp9: sunxi google vp9 version 0.1
      [    1.668344] bat_param node not found
      [    1.681036] input: axp2101-powerkey as /devices/platform/soc/pmu0/axp2101-powerkey/input/input1
      [    1.696238] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.705562] sunxi_cpufreq_init: only one opp_table
      [    1.710976] [cpu_freq] ERR: DEBUG: get cpu 0 device
      [    1.717650] cpuidle: enable-method property 'psci' found operations
      [    1.725238] cpuidle: enable-method property 'psci' found operations
      [    1.733741] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    1.743076] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    1.752407] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
      [    1.761719] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    1.771034] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
      [    1.780333] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    1.789896] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
      [    1.798821] sunxi-mmc sdc0: regulator prop vmmc,str vcc-sdc
      [    1.805112] sunxi-mmc sdc0: Can't get vqmmc regulator string
      [    1.811490] sunxi-mmc sdc0: Can't get vdmmc regulator string
      [    1.817860] sunxi-mmc sdc0: regulator prop vdmmc33sw,str vcc33-pf
      [    1.824724] sunxi-mmc sdc0: regulator prop vdmmc18sw,str vcc18-pf
      [    1.831590] sunxi-mmc sdc0: regulator prop vqmmc33sw,str vcc33-pf
      [    1.838448] sunxi-mmc sdc0: regulator prop vqmmc18sw,str vcc18-pf
      [    1.845345] get() with no identifier
      [    1.849361] get() with no identifier
      [    1.853499] sunxi-mmc sdc0: No vmmc regulator found
      [    1.858983] sunxi-mmc sdc0: No vqmmc regulator found
      [    1.864578] sunxi-mmc sdc0: No vdmmc regulator found
      [    1.870583] sunxi-mmc sdc0: set host busy
      [    1.875133] mmc:failed to get gpios
      [    1.879777] sunxi-mmc sdc0: filter speed is 7340032 B/s
      [    1.885717] sunxi-mmc sdc0: filter sector is 8 sector
      [    1.891413] sunxi-mmc sdc0: Perf function is enable
      [    1.897116] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.930497] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.970517] sunxi-mmc sdc0: detmode:data3
      [    1.975039] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
      [    1.981050] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
      [    1.981072] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.989133] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.000963] sunxi-mmc sdc0: smc 0 p0 err, cmd 8, RTO !!
      [    2.011757] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
      [    2.017664] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
      [    2.018632] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
      [    2.020450] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
      [    2.026990] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
      [    2.032912] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
      [    2.038807] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
      [    2.044711] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
      [    2.044740] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.050806] sunxi-mmc sdc0: smc 0 p0 err, cmd 1, RTO !!
      [    2.050828] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.051844] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.080575] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.118328] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
      [    2.127162] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
      [    2.133194] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
      [    2.133213] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.141273] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.153103] sunxi-mmc sdc0: smc 0 p0 err, cmd 8, RTO !!
      [    2.163893] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
      [    2.169795] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
      [    2.175696] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
      [    2.181595] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
      [    2.187717] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
      [    2.193622] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
      [    2.199627] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
      [    2.205626] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
      [    2.205644] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.211684] sunxi-mmc sdc0: smc 0 p0 err, cmd 1, RTO !!
      [    2.211709] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.245721] sunxi-mmc sdc1: Can't get vmmc regulator string
      [    2.252004] sunxi-mmc sdc1: Can't get vqmmc regulator string
      [    2.258367] sunxi-mmc sdc1: Can't get vdmmc regulator string
      [    2.264747] sunxi-mmc sdc1: Can't get vdmmc33sw regulator string
      [    2.271511] sunxi-mmc sdc1: Can't get vdmmc18sw regulator string
      [    2.278265] sunxi-mmc sdc1: Can't get vqmmc33sw regulator string
      [    2.285033] sunxi-mmc sdc1: Can't get vqmmc18sw regulator string
      [    2.291794] get() with no identifier
      [    2.295808] get() with no identifier
      [    2.299826] get() with no identifier
      [    2.303850] get() with no identifier
      [    2.307864] get() with no identifier
      [    2.311887] get() with no identifier
      [    2.315906] get() with no identifier
      [    2.319923] sunxi-mmc sdc1: No vmmc regulator found
      [    2.325415] sunxi-mmc sdc1: No vqmmc regulator found
      [    2.331014] sunxi-mmc sdc1: No vdmmc regulator found
      [    2.336595] sunxi-mmc sdc1: No vd33sw regulator found
      [    2.342283] sunxi-mmc sdc1: No vd18sw regulator found
      [    2.347969] sunxi-mmc sdc1: No vq33sw regulator found
      [    2.353657] sunxi-mmc sdc1: No vq18sw regulator found
      [    2.359345] sunxi-mmc sdc1: Cann't get uart0 pinstate,check if needed
      [    2.366953] sunxi-mmc sdc1: set host busy
      [    2.371531] mmc:failed to get gpios
      [    2.375640] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.385965] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    2.420495] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.460499] sunxi-mmc sdc1: detmode:manually by software
      [    2.466500] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.472509] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.472537] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.480587] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.492414] sunxi-mmc sdc1: smc 1 p1 err, cmd 8, RTO !!
      [    2.503215] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.509116] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.515016] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.520917] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.526819] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
      [    2.532720] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
      [    2.538710] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
      [    2.544712] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
      [    2.544731] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.550768] sunxi-mmc sdc1: smc 1 p1 err, cmd 1, RTO !!
      [    2.550787] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.586888] [sunxi_hdmi_codec_init] driver and deivce register finished.
      [    2.596194] gpio-spk setting ok
      [    2.600185] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.609157] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD0L Mixer
      [    2.621020] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.629736] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD0L Mixer
      [    2.641597] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.650307] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD0R Mixer
      [    2.662165] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.670888] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD0R Mixer
      [    2.682742] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.691716] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD1L Mixer
      [    2.703574] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.712300] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD1R Mixer
      [    2.724182] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.732907] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2DACL Switch -> DACL Mixer
      [    2.744181] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.752901] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2DACR Switch -> DACR Mixer
      [    2.764706] sunxi-codec-machine sndcodec: codec-aif1 <-> i2s mapping ok
      [    2.774409] sndhdmi sndhdmi: audiohdmi-dai <-> audiohdmi mapping ok
      [    2.782116] sndhdmi sndhdmi: [sunxi_sndhdmi_dev_probe] register card finished.
      [    2.790755] NET: Registered protocol family 17
      [    2.795807] NET: Registered protocol family 15
      [    2.801696] sid_get_phy_base()316 - Failed to find "" in dts.
      [    2.808193] sid_get_phy_base()316 - Failed to find "" in dts.
      [    2.815149] sid_get_phy_base()316 - Failed to find "" in dts.
      [    2.821977] sid_efuse_key_is_readable()756 - The key thermal_sensor write protect bit not burned!
      [    2.832045] sid_get_phy_base()316 - Failed to find "" in dts.
      [    2.838854] sid_get_phy_base()316 - Failed to find "" in dts.
      [    2.845697] sid_get_phy_base()316 - Failed to find "" in dts.
      [    2.854323] Registering SWP/SWPB emulation handler
      [    2.865607] input: gpiokey as /devices/platform/soc/gpiokey/input/input2
      [    2.873599] sunxi-rtc rtc: setting system clock to 2019-10-01 00:00:44 UTC (1569888044)
      [    2.883392] axp2101_dcdc2: incomplete constraints, leaving on
      [    2.889925] axp2101_dcdc4: incomplete constraints, leaving on
      [    2.896414] axp2101_rtc1: incomplete constraints, leaving on
      [    2.902872] axp2101_aldo3: incomplete constraints, leaving on
      [    2.909534] axp2101_cpuldos: incomplete constraints, leaving on
      [    2.910469] random: fast init done
      [    2.920227] ALSA device list:
      [    2.923576]   #0: audiocodec
      [    2.926809]   #1: sndhdmi
      [    2.932115] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
      [    2.942359] devtmpfs: mounted
      [    2.945942] Freeing unused kernel memory: 160K
      [    2.950974] This architecture does not have kernel memory protection.
      mount: mounting pstore on /sys/fs/pstore failed: No such file or directory
      mount: mounting /dev/by-name/rootfs_data on /overlay failed: No such file or directory
      Mount Failed: formating /dev/by-name/rootfs_data to jffs2 ...
      Not Found /usr/sbin/mkfs.jffs2 or /sbin/mkfs.jffs2
      starting pid 610, tty '': '/etc/preinit'
      [preinit]: Early Setuping virtual filesystem
      [preinit]: Got overlay partitions is /dev/mtdblock3
      Try to mount /dev/mtdblock3 using squashfs
      Try to mount /dev/mtdblock3 using vfat
      [    3.245660] error free fat start 0,fat len 0
      [    3.253752] error free:Relase fat
      [    3.257485] no sbi
      Try to mount /dev/mtdblock3 using msdos[    3.263026] error free fat start 0,fat len 0
      [    3.268416] error free:Relase fat
      Try to mount /dev/mtdblock3 using jffs2
      [preinit]: Uion filesystem
      init: must be run as PID 1
      starting pid 632, tty '': '/bin/mount -t proc proc /proc'
      starting pid 633, tty '': '/bin/mount -t tmpfs tmpfs /run'
      starting pid 634, tty '': '/bin/mount -o remount,rw /'
      starting pid 635, tty '': '/bin/mkdir -p /dev/pts'
      starting pid 636, tty '': '/bin/mkdir -p /dev/shm'
      starting pid 637, tty '': '/bin/mount -a'
      starting pid 638, tty '': '/bin/hostname -F /etc/hostname'
      can't run '/bin/hostname': No such file or directory
      starting pid 639, tty '': '/etc/init.d/rcS boot'
      /etc/init.d/rcS: line 117: /bin/hostname: not found
      /etc/init.d/rcS: line 119: /sbin/mdev: not found
      ------run rc.final file-----
      Load mpp modules
      [    3.492282] sunxi-wlan wlan: wlan_busnum (1)
      [    3.497096] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      [    3.497121] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      [    3.505970] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      [    3.505990] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      [    3.515709] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      [    3.515728] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      [    3.515735] [VIN_DEV_I2C]imx335_mipi sensor read retry = 2
      [    3.525137] [VIN]val = 0x3, Sent msg to user
      [    3.564782] sunxi-wlan wlan: wlan_power_num (-1)
      [    3.569985] sunxi-wlan wlan: io_regulator_name (vcc18-wifi)
      [    3.576289] sunxi-wlan wlan: request pincrtl handle for device [wlan] failed
      [    3.584274] sunxi-wlan wlan: wlan_regon gpio=198  mul-sel=1  pull=-1  drv_level=-1  data=0
      [    3.593618] sunxi-wlan wlan: get gpio chip_en failed
      [    3.599211] sunxi-wlan wlan: wlan_hostwake gpio=199  mul-sel=6  pull=-1  drv_level=-1  data=0
      [    3.608901] sunxi-wlan wlan: clk_name ()
      [    3.613538] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = ff
      [    3.622188] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = fe
      [    3.630645] [tp9950]V4L2_IDENT_SENSOR = 0x0
      [    3.638217] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = ff
      [    3.647480] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = fe
      [    3.656133] [tp9950]retry = 0, V4L2_IDENT_SENSOR = 0x0
      [    3.663218] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = ff
      [    3.672055] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = fe
      [    3.680638] [tp9950]retry = 1, V4L2_IDENT_SENSOR = 0x0
      [    3.686772] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = ff
      [    3.696010] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = fe
      [    3.704698] [tp9950]retry = 2, V4L2_IDENT_SENSOR = 0x0
      [    3.711942] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = ff
      [    3.721054] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = fe
      [    3.730151] [tp9950]retry = 3, V4L2_IDENT_SENSOR = 0x0
      [    3.736809] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = ff
      [    3.747400] [VIN CCI_1 ERR] Status error at addr_8bit = 88, wr_flag = 1, val = fe
      [    3.756400] [tp9950]retry = 4, V4L2_IDENT_SENSOR = 0x0
      [    3.762589] [tp9950] error, chip found is not an target chip.
      mount: mounting /dev/mmcblk0p1 on /mnt/extsd failed: No such file or directory[    3.773008] [VIN_ERR]registering tp9950, No such device!
      /etc/init.d/S01app: line 108: can't create /sys/block/mmcblk0/queue/max_sectors_kb: nonexistent directory
      Populating /dev using udev: [    3.930955] udevd[769]: starting version 3.2
      [    3.936313] random: udevd: uninitialized urandom read (16 bytes read)
      [    3.943878] random: udevd: uninitialized urandom read (16 bytes read)
      [    3.951322] random: udevd: uninitialized urandom read (16 bytes read)
      [    3.984926] udevd[769]: specified group 'tty' unknown
      [    3.991037] udevd[769]: specified group 'dialout' unknown
      [    3.997316] udevd[769]: specified group 'kmem' unknown
      [    4.003322] udevd[769]: specified group 'input' unknown
      [    4.009388] udevd[769]: specified group 'video' unknown
      [    4.015876] udevd[769]: specified group 'lp' unknown
      [    4.021859] udevd[769]: specified group 'disk' unknown
      [    4.027927] udevd[769]: specified group 'cdrom' unknown
      [    4.034156] udevd[769]: specified group 'tape' unknown
      [    4.045675] udevd[770]: starting eudev-3.2
      done
      mkdir: can't create directory '/dev/pts': File exists
      mkdir: can't create directory '/dev/shm': File exists
      enable android usb
      insmod: can't insert '/lib/modules/4.9.118/sunxi_usb_udc.ko': No such file or directory
      insmod: can't insert '/lib/modules/4.9.118/sunxi_usbc.ko': No such file or directory
      mkdir: can't create directory '/sys/kernel/config/usb_gadget/g1/functions/uvc.usb0': No such file or directory
      mkdir: can't create directory '/sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/': No such file or directory
      /etc/init.d/S50usb: line 99: can't create /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/wWidth: nonexistent directory
      /etc/init.d/S50usb: line 99: can't create /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/wHeigh[    4.705361] file system registered
      t: nonexistent directory
      /etc/init.d/S50usb: line 99: can't create /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streamin[    4.723285] Mass Storage Function, version: 2009/09/11
      g/mjpeg/m/720p/dwFrameInterval: nonexistent directory
      /etc/init.d/S50usb: line 99: can't create /sys/kernel/config/usb_gadget/g[    4.729506] LUN: removable file: (no medium)
      1/functions/uvc.usb0/streaming/mjpeg/m/720p/dwDefaultFrameInterval: nonexistent directory
      /etc/init.d/S50usb: line 99: can't create /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/dwMinBitRate: nonexistent directory
      /etc/init.d/S50usb: line 99: can't create /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/dwMaxBitRate: nonexistent directory
      /etc/init.d/S50usb: line 99: can't create /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/dwMaxVideoFrameBufferSize: nonexistent directory
      mkdir: can't create directory '/sys/kernel/config/usb_gadget/g1/functions/[    4.797638] read descriptors
      uvc.usb0/streaming/header/h': No such file or directory
      ln: /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/heade[    4.804189] read strings
      r/h/: No such file or directory
      ln: /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/class/fs: No such file or dir[    4.821054] random: crng init done
      ectory
      ln: /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/class/hs: No such file or directory
      mkdir: can't create directory '/sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/header/h': No such file or directory
      ln: /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/class/fs/: No such file or directory
      ln: /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/class/ss/: No such file or directory
      WARNING: awplayer <log_set_level:30>: Set log level to 3
      DEBUG  : awplayer <ReadPluginEntry:194>: read plugin entry adecoder-0 fail!
      DEBUG  : awplayer <CdxPluginLoadList:221>: have config 0 entry
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open adecoder lib
      DEBUG  : awplayer <CdxPluginLoadList:202>: Load Plugin list vdecoder
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-0 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-1 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-2 ok.
      DEBUG  : awplayer <ReadPluginEntry:194>: read plugin entry vdecoder-3 fail!
      DEBUG  : awplayer <CdxPluginLoadList:221>: have config 3 entry
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open vdecoder lib
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.h264 comment is "h264_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawh264.so
      ERROR  : awplayer <DlOpenPlugin:103>: dlopen 'libawh264.so' fail: Error loading shared library libawh264.so: No such file or directory
      DEBUG  : awplayer <CdxPluginLoadList:231>: load vdecoder id vdecoder.h264 fail!
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.h265 comment is "h265_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawh265.so
      ERROR  : awplayer <DlOpenPlugin:103>: dlopen 'libawh265.so' fail: Error loading shared library libawh265.so: No such file or directory
      DEBUG  : awplayer <CdxPluginLoadList:231>: load vdecoder id vdecoder.h265 fail!
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mjpegplus comment is "mjpegplus_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmjpegplus.so
      ERROR  : awplayer <DlOpenPlugin:103>: dlopen 'libawmjpegplus.so' fail: Error loading shared library libawmjpegplus.so: No such file or directory
      DEBUG  : awplayer <CdxPluginLoadList:231>: load vdecoder id vdecoder.mjpegplus fail!
      DEBUG  : awplayer <CdxPluginLoadList:202>: Load Plugin list plugin
      DEBUG  : awplayer <ReadPluginEntry:194>: read plugin entry plugin-0 fail!
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open plugin lib
      DEBUG  : awp[    5.059841] android_work: sent uevent USB_STATE=CONNECTED
      layer <AwStreamInit:92>: aw stream init...
      DEBUG  : awplayer <AwStreamInit:124>: stream list size:2
      INFO   : awplayer <AwParserInit:397>: aw parser init...
      DEBUG  : awplayer <AwParserInit:467>: aw parser size:6
      start minigui init time: 1569888046s.673370ms
      end minigui init time: 1569888046s.715136ms
      [    5.100575] configfs-gadget gadget: high-speed config #1: c
      [    5.106973] android_work: sent uevent USB_STATE=CONFIGURED
      I1001 00:00:46.770227   750 mpi_sys.c:761]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      modName : MPP-Platform
      tag   : V1.0 Release
      branch: v5-dev
      commit: 4eed413532ad87725895a8cb1ba75e22fc328233
      date  : 20170725
      author: jenkins
      I1001 00:00:46.857844   750 mpi_sys.c:798]                  <AW_MPI_SYS_Init_S1> ISP init
      [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
      IPCORE: ISP520
      branch: libisp-dev
      commit: f682a1b81071fac76784c9601a4d5f6a9bf64072
      date  : Tue May 28 14:03:02 2019 +0800
      author: jiangwei
      I1001 00:00:46.858330   750 mpi_sys.c:800]                  <AW_MPI_SYS_Init_S1> ISP init done
      I1001 00:00:46.900094   750 hwdisplay.c:83]                 <hw_display_init> <hw_display_init:83>
      I1001 00:00:46.900485   750 hwdisplay.c:984]                <hwd_init> <hwd_init:984>     (hwd_init 984)
      I1001 00:00:46.900717   750 hwdisplay.c:1039]               <hwd_init> <hwd_init:1039>    ret[0][2,0]ch[2]lyl[0] init: enable[1], screenwin[0,0, 480x640], zorder[16], alpha[mode:0, value:255]
      E1001 00:00:46.903774   750 power_manager.cpp:1057]         <getAhdInsertOnline> getAhdInsertOnline online =
      E1001 00:00:46.904001   750 power_manager.cpp:1067]         <getAhdInsertOnline> getAhdInsertOnline othe value
      W1001 00:00:46.906939   750 power_manager.cpp:1079]         <getPowenOnType> poweron type is axp2101:REG[0x20]=0x0
      W1001 00:00:46.907191   750 power_manager.cpp:1082]         <getPowenOnType> tmpString type is  = =0x0
      I1001 00:00:46.907343   750 newPreview.cpp:1854]            <CheckCameraExist> CamId 0 did not create yet!
      I1001 00:00:46.907459   750 camera_factory.cpp:20]          <CreateCamera> create camera: 4
      E1001 00:00:46.907649   750 menu_config_lua.cpp:36]         <MenuConfigLua> MenuConfigLua::MenuConfigLua
      W1001 00:00:46.907785   750 menu_config_lua.cpp:822]        <ChangeMenuConfig> ready to ChangeMenuConfig-----------------------
      W1001 00:00:46.987960   750 menu_config_lua.cpp:856]        <ChangeMenuConfig> usr_update_str = false   usr_ver_str = TF700-20191101a-7P025a-09091
      W1001 00:00:46.992394   750 menu_config_lua.cpp:752]        <IsVersionSame> IsNewVersion    external_version : TF700-20191101a-7P025a-09091  ---  local_version : TF700-20191101a-7P025a-09091
      W1001 00:00:46.992655   750 menu_config_lua.cpp:757]        <IsVersionSame> invalid fileName:TF700-20191101a-7P025a-09091
      W1001 00:00:46.992820   750 menu_config_lua.cpp:970]        <ComparisonProfile> ready to read out the data menu_config.lua data
      W1001 00:00:46.997815   750 menu_config_lua.cpp:1102]       <ComparisonProfile> ready to read out the data menu_config.lua data
      LuaConfig: <line[110] LoadValueToStack> [string "value=menu.photo.qualtiy.count"]:1: attempt to index fie[    5.469633] sid_get_phy_base()316 - Failed to find "" in dts.
      ld 'qualtiy' (a nil value)
      W1001 00:00:47.002990   750 menu_config_lua.cpp:1233]       <ComparisonProfile> read to c[    5.479511] sid_get_phy_base()316 - Failed to find "" in dts.
      ompare usr/--/menu_config.lua  and  data/menu_config.lua   one by one
      W1001 00:00:47.003549   750 menu_config_lua.cp[    5.496974] sid_get_phy_base()316 - Failed to find "" in dts.
      p:1482]                                                     <ComparisonProfile> ready to set the data to the usr_luacfg
      W1001 00:00:47.012609   750 menu_config[    5.514499] sid_get_phy_base()316 - Failed to find "" in dts.
      _lua.cpp:1620]                                              <ComparisonProfile> ready to save the compare result to the usr/--/menu_config_temp.lua
      W100[    5.532106] cedar_ve: VE real_fre=600000000
      1 00:00:47.022009   750 menu_config_lua.cpp:1627]           <ComparisonProfile> Comparison is ok
      E1001 00:00:47.0346[    5.557510] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      77   750 menu_config_lua.cpp:1659]                          <LoadMenuConfig> read and set menu_cfg_
      E1001 00:00:47.039595   750 menu[    5.567444] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      _config_lua.cpp:1788]                                       <LoadMenuConfig> menu_cfg_: timezone: 8 24
      E1001 00:00:47.039927   750 menu_config_lu[    5.588288] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      a.cpp:1792]                                                 <LoadMenuConfig> menu_cfg_: device_carid: AB123456
      E1001 00:00:47.040108   750 menu_config_lua.[    5.608165] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      cpp:63]                                                     <MenuConfigLua> set timezone at startup: 0
      E1001 00:00:47.000774   750 camera_factory.cpp:177]     5.628985] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      D                                                            <CreateNormalCamera> RECORD_RESOLUTION idx: 0
      E1001 00:00:47.001644   750 osd_manager.cpp:1441]           <setT[    5.648852] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      imeOsdPostion> osd not init yet
      E1001 00:00:47.001741   750 osd_manager.cpp:2178]           <setGpsOsdPosition> osd n[    5.669648] [VIN_DEV_I2C]imx335_mipi sensor read retry = 2
      ot init yet
      E1001 00:00:47.001808   750 osd_manager.cpp:1411]           <setCaridOsdPosition> osd not init yet
      I1[    5.688897] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      001 00:00:47.001914   750 storage_manager.cpp:43]           <Init> start init
      E1001 00:00:47.002483   750 event_manager.[    5.706898] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      cpp:171]                                                    <EventManager> =============close ir led=============
      W1001 00:00:47.002799   750 camera.cpp:145] [    5.727701] [VIN_DEV_I2C_ERR]sensor_write error!
        <Camera> 1111 phy_cam_id = 0
      ConfigCamera : CsiChn = 0,ispdev = 0,vippchnValue0 = 0,vippchnValue1 = 1
      W10[    5.743963] [VIN_DEV_I2C_ERR]imx335_mipi sensor write array error, array_size 55!
      01 00:00:47.050122   750 EyeseeCamera.cpp:537]              <initCamerasConfiguration> warning: we don't init cameraInfos according[    5.763530] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
       to real system situation. It it not ready. So we use default for example.
      W1001 00:00:47.050293   750 EyeseeCamera.c[    5.783637] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      pp:582]                                                     <clearCamerasConfiguration> warning: I don't know how to operate lower v4l2 drivers, so it take no effect.
          5.804237] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      mopen camera: 0
      I1001 00:00:47.050627   750 VIDevice.cpp:42]                <VIDevice> Construct
      I1001 00:00:47.050724   750 camera[    5.824108] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      .cpp:2091]                                                  <SetVflip> vflip: 0, mirror: 0
      open main channel time: 1569888047s.50790ms
      debug  : ionAlloc <__GetIonMem[    5.844947] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      OpsS:956>: *** get __GetIonMemOpsS ***
      debug  : ionAlloc <ion_alloc_open:137>: begin ion_alloc_open
      debug  : cedarc <VeInit[    5.864811] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      ialize:1214>: *** nPhyOffset = 0x0
      debug  : cedarc <VeSetSpeed:1730>: *** set ve freq to 600 Mhz ***
      debug  : cedarc <VeInitia[    5.885607] [VIN_DEV_I2C]imx335_mipi sensor read retry = 2
      lize:1270>: ve init ok
      debug  : ionAlloc <ion_alloc_open:178>: ** phy offset = 0
      debug  : cedarc <VeRelease:1342>: ve releas[    5.902911] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      e ok
      [debug_jaosn]:main_enc_chn_ = 0,sub_enc_chn_ = -1, main_chn_ 0, sub_chn_  1
      I1001 00:00:47.129953   750 camera.cpp:404][    5.922786] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
        <InitCamera> main_enc_chn_ : init_param_.vflip = 0,init_param_.mirror = 0
      I1001 00:00:47.130066   750 camera.cpp:409[    5.943620] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      ]                                                           <InitCamera> sensor fps 25
      prepare main channel time: 1569888047s.130122ms
      [ISP]video device name is vin_video0
      [[    5.963489] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      ISP]chipid: 0x1!!!
      [ISP]open video device[0] success!
      W1001 00:00:47.130367   750 VIChannel.cpp:969]              <startCh[    5.984325] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      annel> Be careful! not find match sensor param set! isp param will be selected near user param!
      I1001 00:00:47.130458   750 [    6.004192] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      VIChannel.cpp:973]                                          <startChannel> set vipp[0]attr:[2560x1440],fps[25], pixFmt[0x31324d4e], nbufs[4]
      I1001 00:00:47.26[    6.028385] [VIN_DEV_I2C]imx335_mipi sensor read retry = 2
      8761   750 VIChannel.cpp:986]                               <startChannel> get vipp[0]attr:[2560x1440],fps[25], pixFmt[0x31324d4e], nbufs[4]
      loop VideoInputHw_CapThread vipp_id = 0, buf_num=4.
      E1001 00:00:47.629328   750 video_buffer_manager.c:211]     <VideoBufMgrCreate> Alloc 20 input frame buffers in list manager.
      E1001 00:00:47.629570   750 VideoVirVi_Component.c:471]     <VideoViSetViDevAttr> fps 25 nbufs 4
      [ISP]open isp device[0] success!
      [ISP_WARN]sdcard is not mounted!!!
      [IS[    6.076123] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      P_WARN]cannot find imx335_mipi_2592_1944_25_0 isp config, use imx335_mipi_2592_1944_30_0!
      I100[    6.095002] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      1 00:00:47.654557   750 VIDevice.cpp:1137]                  <startChannel> ISP[0] run
      I1001 00:00:47.654700   750 videoInputHw.c:3079][    6.115823] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
        <videoInputHw_Isp_GetNR> isp[0]2vipp[0].
      I1001 00:00:47.654769   750 videoInputHw.c:3147]            <videoInputHw_I[    6.135692] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      sp_Get3DNR> isp[0]2vipp[0].
      I1001 00:00:47.654825   750 videoInputHw.c:3011]            <videoInputHw_Isp_GetWDR> isp[0]2vipp[0[    6.156514] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      open sub channel time: 1569888047s.654867ms
      [FUN]:setISPParameters mIspDevId:0
      I1001 00:00:47.654940   750 videoInputHw.[    6.176382] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x1a)
      c:1995]                                                     <videoInputHw_IspAwb_SetMode> isp[0]2vipp[0].
      I1001 00:00:47.655086   7[    6.197169] [VIN_DEV_I2C]imx335_mipi sensor read retry = 2
      50 camera.cpp:3238]                                         <GetModeConfigIndex> [fangjj]:GetModeConfigIndex  index:[3]
      I1001 00:00:47.655153   750 camera.cpp:2000]                <SetExposureValue> =====m_ExposureBias is 4=====
      I1001 00:00:47.655228   750 VIDevice.cpp:238]               <setISPParameters> change AE Exposure Bias
      I1001 00:00:47.655282   750 videoInputHw.c:1768]            <videoInputHw_IspAe_SetExposureBias> isp[0]2vipp[0].
      E1001 00:00:47.655364   750 camera.cpp:439]                 <InitCamera> =======m_ExposureBias 4=======
      I1001 00:00:47.655438   750 camera.cpp:3238]                <GetModeConfigIndex> [fangjj]:GetModeConfigIndex  index:[0]
      I1001 00:00:47.655490   750 camera.cpp:2026]                <SetLightFreq> Camera::SetLightFreq, index: 0, flcker value: 1
      I1001 00:00:47.655563   750 VIDevice.cpp:325]               <setISPParameters> change flicker
      I1001 00:00:47.655616   750 videoInputHw.c:2079]            <videoInputHw_Isp_SetFlicker> isp[0]2vipp[0].
      E1001 00:00:47.655689   750 camera.cpp:442]                 <InitCamera> =======m_LightFreq 1=======
      debug  : ionAlloc <__GetIonMemOpsS:956>: *** get __GetIonMemOpsS ***
      I1001 00:00:47.656381   750 camera.cpp:768]                 <StartPreview> sub_enc_chn_ : init_param_.vflip = 0,init_param_.mirror = 0
      prepare channel time: 1569888047s.656486ms
      [ISP]video device name is vin_video1
      [ISP]chipid: 0x1!!!
      [ISP]open video device[1] success!
      I1001 00:00:47.656922   750 hwdisplay.c:1239]               <hwd_get_disp_type> <hwd_get_disp_type:1239> Current the  disp_type:0x1  tv_mode:0x0
      I1001 00:00:47.657075   750 camera.cpp:271]                 <InitDisplay> ############request layer_id, layer_id: 0
      I1001 00:00:47.657135   750 camera.cpp:272]                 <InitDisplay> init display zorder 0
      I1001 00:00:47.657194   750 hwdisplay.c:1112]               <hwd_layer_request_hlay> <hwd_layer_request_hlay:1112> hlay:0, zorder=0, cnt:2
      I1001 00:00:47.657326   750 display.cpp:106]                <RequestLayer> request layer: 0, hlay: 0
      I1001 00:00:47.657395   750 mpi_vo.c:1030]                  <AW_MPI_VO_SetVideoLayerAttr> ch[0]lyl[0]:dispRect changed, [0, 0, 320x240]->[60, 0, 360x640]
      I1001 00:00:47.657459   750 hwdisplay.c:403]                <hwd_layer_set_rect> <hwd_layer_set_rect:403> ch[0]lyl[0]: screen_win[60,0, 360x640]
      I1001 00:00:47.657521   750 camera.cpp:303]                 <InitDisplay> request layer, hlay: 0
      I1001 00:00:47.657584   750 VIChannel.cpp:973]              <startChannel> set vipp[1]attr:[640x360],fps[25], pixFmt[0x31324d4e], nbufs[4]
      I1001 00:00:47.796254   750 VIChannel.cpp:986]              <startChannel> get vipp[1]attr:[640x360],fps[25], pixFmt[0x31324d4e], nbufs[4]
      loop VideoInputHw_CapThread vipp_id = 1, buf_num=4.
      E1001 00:00:47.798193   750 video_buffer_manager.c:211]     <VideoBufMgrCreate> Alloc 20 input frame buffers in list manager.
      E1001 00:00:47.798419   750 VideoVirVi_Component.c:471]     <VideoViSetViDevAttr> fps 25 nbufs 4
      I1001 00:00:48.049038   750 PreviewWindow.cpp:138]          <startPreview> create vo channel[0] success!
      I1001 00:00:48.049260   750 PreviewWindow.cpp:239]          <startPreview> left [0] idle frames at start preview
      show preview time: 1569888048s.49321ms
      E1001 00:00:48.049355   750 newPreview.cpp:1916]            <OnWindowLoaded> SetLayerAlpha LAYER_UI 150
      I1001 00:00:48.049432   750 mpi_vo.c:1130]                  <AW_MPI_VO_SetVideoLayerAlpha> video layer alpha changed, [0, 255]->[0, 150]
      I1001 00:00:48.049566   750 display.cpp:326]                <SetLayerAlpha> layer id: 3, hlay: 8, alpha: 150
      I1001 00:00:48.049628   750 camera.cpp:617]                 <ShowPreview> open layer to show preview m_dispHandle:0 cam_status_:2 phy_cam_id_:0
      W1001 00:00:48.049681   750 camera.cpp:666]                 <ShowPreview> wrong status: 2
      E1001 00:00:48.049747   750 newPreview.cpp:1963]            <OnWindowLoaded> OnWindowLoaded end
      tag   : V1.0 Release
      branch: v5-dev
      date  : 20170725
      author: jenkins
      I1001 00:00:48.051803   858 alsa_interface.c:632]           <alsaOpenMixer> open mixer
      W1001 00:00:48.158610   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:48.158943   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      I1001 00:00:48.178560   858 alsa_interface.c:715]           <alsaOpenMixer> set player pa switch level 0
      I1001 00:00:48.179759   858 alsa_interface.c:687]           <alsaOpenMixer> set playback vol_val to value: 27
      W1001 00:00:48.298799   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:48.298979   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      Extracting sxf_26x26.bin
      fileOff---------->:376356
      Everything is Ok
      Magic: U F L
      nSection: 1
      pSection: 0xd289a0
      YSize: 26
      sh: write error: Resource busy
      starting pid 870, tty '/dev/console': '-/bin/sh'
      ------run profile file-----
      Extracting sxf_30x30.bin
      fileOff---------->:317424
      Everything is Ok
      Magic: U F L
      nSection: 1
      pSection: 0xd30560
      YSize: 30
      root@tina:/# Extracting sxf_30x30.bin
      fileOff---------->:299484
      Everything is Ok
      Magic: U F L
      nSection: 1
      pSection: 0xd30690
      YSize: 30
      Init_TSLib&KEY_Input
      IAL>TSLib: can not find the env value, use the device node: from the MiniGUI.cfg
      [file]:sunxikeytslib.c  [fun]:InitSUNXIKeyTSLibInput [line]:335 the tslib node is not ready, please check the config of node!!!
      Init_TSLib&KEY_Input finish
      W1001 00:00:48.659272   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:48.659451   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:48.799180   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:48.799284   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:49.159665   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:49.159811   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:49.299450   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:49.299544   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      E1001 00:00:49.516505   750 newPreview.cpp:87]              <InitWindow> Init window
      W1001 00:00:49.517968   880 audio_hw.c:100]                 <audioHw_Construct> audio_hw has already been constructed!
      E1001 00:00:49.518165   880 audioCtrl.cpp:30]               <AudioCtrl> AudioCtrl::AudioCtrl
      I1001 00:00:49.523584   750 window.cpp:828]                 <LoadRes> start parse ui resources
      CreateMainWindowEx  run 1313I1001 00:00:49.525434   879 mpi_venc.c:2768] <AW_MPI_VENC_SetVEFreq> change global ve freq[0]->[520]
      E1001 00:00:49.525624   879 power_manager.cpp:1196]         <SetBrightnessLevel> SetBrightnessLevel --- level = 1
      I1001 00:00:49.525864   880 wav_player.cpp:41]              <GetPcmParam> audio file format(1, 16, 44100)
      I1001 00:00:49.566804   750 window.cpp:109]                 <CreateWidget> create window: StatusBarBottomWindow
      CreateMainWindowEx  run 1313I1001 00:00:49.600826   880 wav_player.cpp:41] <GetPcmParam> audio file format(1, 16, 44100)
      I1001 00:00:49.601945   880 wav_player.cpp:41]              <GetPcmParam> audio file format(1, 16, 44100)
      E1001 00:00:49.603255   880 audioCtrl.cpp:59]               <AudioCtrl> open wav file failed, file: /usr/share/minigui/res/audio/autophoto.wav, error: No such file or directory
      I1001 00:00:49.621094   880 wav_player.cpp:41]              <GetPcmParam> audio file format(1, 16, 44100)
      I1001 00:00:49.622653   880 wav_player.cpp:135]             <AOChannelInit> param dump:
      I1001 00:00:49.622859   880 wav_player.cpp:137]             <AOChannelInit> trackCnt: 1, sampleRate: 44100, bitwidth: 16, aoCardType: 0
      E1001 00:00:49.622965   880 audio_hw.c:650]                 <AudioHw_AO_GetPubAttr> get attr when attr is not set!
      I1001 00:00:49.623107   880 wav_player.cpp:151]             <AOChannelInit> enWorkmode:0 enSoundmode:0 u32EXFlag:0 u32FrmNum:-1368340933 u32PtNumPerFrm:13866064 u32ChnCnt:3269587 u32ClkSel:3269568
      I1001 00:00:49.623210   880 wav_player.cpp:160]             <AOChannelInit> AIO_ATTR_S: [1, 44100, 1]
      I1001 00:00:49.623309   880 alsa_interface.c:434]           <alsaOpenPcm> open pcm! card:[default], pcmFlag:[1](0-cap;1-play)
      [ISP_ERR]video_wait_buffer, line: 442,video0 select timeout!
      E1001 00:00:49.631472   844 videoInputHw.c:3875]            <VideoInputHw_CapThread> fatal error! vipp[0] get frame fail, but all frames are release!
      W1001 00:00:49.660050   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:49.660249   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      I1001 00:00:49.743629   750 window.cpp:740]                 <Load> images_file :/usr/share/minigui/res/layout/StatusBarBottomWindow.qrc
      E1001 00:00:49.747184   750 status_bar_bottom_window.cpp:348] <PlayingWindownButtonStatus> 5 icon hide
      E1001 00:00:49.747499   750 window_manager.cpp:111]         <CreateWindowById> create window :7
      E1001 00:00:49.747690   750 status_bar_window.cpp:164]      <StatusBarWindow> StatusBarWindow
      I1001 00:00:49.747931   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:49.750388   750 window.cpp:109]                 <CreateWidget> create window: StatusBarWindow
      CreateMainWindowEx  run 1313I1001 00:00:49.771551   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/StatusBarWindow.qrc
      W1001 00:00:49.800001   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:49.800464   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      [ISP_ERR]video_wait_buffer, line: 442,video1 select timeout!
      E1001 00:00:49.800891   853 videoInputHw.c:3875]            <VideoInputHw_CapThread> fatal error! vipp[1] get frame fail, but all frames are release!
      I1001 00:00:49.871628   880 alsa_interface.c:345]           <alsaSetPcmParams> set pcm params
      I1001 00:00:49.874760   880 alsa_interface.c:415]           <alsaSetPcmParams> ----------------ALSA setting----------------
      I1001 00:00:49.874915   880 alsa_interface.c:416]           <alsaSetPcmParams> >>Channels:      1, BitWidth:    16, SampRate:   44100
      I1001 00:00:49.875010   880 alsa_interface.c:417]           <alsaSetPcmParams> >>ChunkBytes: 2048, ChunkSize: 1024, BufferSize: 8192
      I1001 00:00:49.875470   880 wav_player.cpp:169]             <AOChannelInit> create ao channel[0] success!
      I1001 00:00:49.875839   880 audioCtrl.cpp:126]              <SetBeepToneVolume> the val is 83
      I1001 00:00:49.876098   880 alsa_interface.c:758]           <alsaMixerSetVolume> playback setVolume:25, err:0
      I1001 00:00:49.876260   889 AOChannel_Component.c:1452]     <AOChannel_ComponentThread> AO get first pcm frome ADec, nBufferLen: 2048, nTimeStamp:0us, use it to init AudioRenderHal
      W1001 00:00:49.876317   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.876428   889 audio_hw.c:633]                 <AudioHw_AO_SetPubAttr> Careful for 2 AoChns at the same time! They must have the same param!
      W1001 00:00:49.876446   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      I1001 00:00:49.876565   889 AOChannel_Component.c:1463]     <AOChannel_ComponentThread> audio render hal init and run ok!
      W1001 00:00:49.876667   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.876791   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.876910   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.877027   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.877141   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.877257   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.877372   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.877487   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.877602   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.877717   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.877833   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.877948   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.878062   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.878175   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.878289   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.878404   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.878517   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.878631   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.878746   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.878860   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:49.878976   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      create timer data is 0x0xd946d0
      W1001 00:00:50.201848   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.160547   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:50.202014   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.202239   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:50.202311   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.202432   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.202554   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.202679   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.202801   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.202919   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.203033   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.203156   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      W1001 00:00:50.203279   880 AOChannel_Component.c:275]      <AOAddFrame_l> input frame list is empty, increase one
      E1001 00:00:50.222288   750 status_bar_window.cpp:861]      <ParkIconHander> [zhb]:ParkIconHander  index:[0]
      E1001 00:00:50.224448   750 status_bar_window.cpp:886]      <AwmdIconHander> [zhb]:AwmdIconHander  index:[0]
      E1001 00:00:50.224874   750 status_bar_window.cpp:909]      <VoiceIconHandler> [zhb]:VoiceIconHandler  index:[1]
      E1001 00:00:50.226766   750 status_bar_window.cpp:1488]     <UpdateGpsStatus> [zhb]:gpsIconHandler  show: 0 index:[1]
      E1001 00:00:50.231361   750 status_bar_window.cpp:465]      <RecordStatusTimeUi> mstart: 0
      W1001 00:00:50.260710   750 status_bar_window.cpp:406]      <RecordTimeUiOnoff> RecordTimeUiOnoff: 0
      E1001 00:00:50.261051   750 status_bar_middle_window.cpp:105] <StatusBarMiddleWindow> StatusBarMiddleWindow
      I1001 00:00:50.261272   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:50.262326   750 window.cpp:109]                 <CreateWidget> create window: StatusBarMiddleWindow
      CreateMainWindowEx  run 1313I1001 00:00:50.267539   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/StatusBarMiddleWindow.qrc
      create timer data is 0x0xdba660
      begain to set the period timer, timer id is 0xda6b6692
      E1001 00:00:50.280653   750 window_manager.cpp:111]         <CreateWindowById> create window :5
      E1001 00:00:50.280869   750 window_manager.cpp:111]         <CreateWindowById> create window :6
      I1001 00:00:50.281093   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:50.281985   750 window.cpp:109]                 <CreateWidget> create window: NewSettingWindow
      CreateMainWindowEx  run 1313I1001 00:00:50.282595   750 list_view.cpp:30] <ListView>
      I1001 00:00:50.285903   750 window.cpp:740]                 <Load> images_file :/usr/share/minigui/res/layout/NewSettingWindow.qrc
      E1001 00:00:50.287184   750 newSettingWindow.cpp:245]       <NewSettingWindow> NewSettingWindow create
      W1001 00:00:50.300931   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:50.301167   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      E1001 00:00:50.393307   750 newSettingWindow.cpp:416]       <InitListviewbmpMap> listviewbmp size: 27
      E1001 00:00:50.393699   750 newSettingWindow.cpp:1032]      <InitListViewItem> NewSettingWindow firstinit true
      E1001 00:00:50.393831   750 newSettingWindow.cpp:1035]      <InitListViewItem> InitListViewItem winstatus: 0
      W1001 00:00:50.400920   750 newSettingWindow.cpp:1614]      <getSdcardInfo> habo---> str_tf = 无卡
      W1001 00:00:50.401069   750 newSettingWindow.cpp:1624]      <getSdcardInfo> [debug_zhb]-----getSdcardInfo-----info_str = 无卡
      I1001 00:00:50.403731   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:50.404527   750 window.cpp:109]                 <CreateWidget> create window: Sublist
      CreateMainWindowEx  run 1313I1001 00:00:50.405068   750 list_view.cpp:30] <ListView>
      I1001 00:00:50.406347   750 window.cpp:740]                 <Load> images_file :/usr/share/minigui/res/layout/Sublist.qrc
      I1001 00:00:50.407102   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:50.409921   750 window.cpp:109]                 <CreateWidget> create window: TimeSettingWindowNew
      CreateMainWindowEx  run 1313I1001 00:00:50.439827   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/TimeSettingWindowNew.qrc
      I1001 00:00:50.455616   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:50.464162   750 window.cpp:109]                 <CreateWidget> create window: InfoDialog
      CreateMainWindowEx  run 1313I1001 00:00:50.467849   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/InfoDialog.qrc
      create timer data is 0x0xdfa160
      I1001 00:00:50.468736   750 bulletCollection.cpp:94]        <initButtonDialog> debug_zhb--------ready to create dialog
      I1001 00:00:50.468968   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:50.470322   750 window.cpp:109]                 <CreateWidget> create window: Dialog
      CreateMainWindowEx  run 1313I1001 00:00:50.486124   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/Dialog.qrc
      I1001 00:00:50.500634   750 window.cpp:901]                 <SetWindowBackImage> ------ready to refresh
      I1001 00:00:50.503597   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:50.506150   750 window.cpp:109]                 <CreateWidget> create window: CaridSettingWindow
      CreateMainWindowEx  run 1313I1001 00:00:50.539834   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/CaridSettingWindow.qrc
      E1001 00:00:50.554106   750 window_manager.cpp:111]         <CreateWindowById> create window :9
      W1001 00:00:50.558423   750 power_manager.cpp:1079]         <getPowenOnType> poweron type is axp2101:REG[0x20]=0x0
      W1001 00:00:50.558631   750 power_manager.cpp:1082]         <getPowenOnType> tmpString type is  = =0x0
      E1001 00:00:50.576511   750 osd_manager.cpp:700]            <loadBitmapFromFile> loadBitmapFromFile the path is NULL
      Copying 8198 bytes
      Copying 32770 bytes
      create timer data is 0x0xcb86d0
      I1001 00:00:50.588655   750 main.cpp:406]                   <UIInit> ui init
      I1001 00:00:50.588855   750 window_manager.cpp:142]         <ChangeWindow> ChangeWindow:src====-1, dst===9
      I1001 00:00:50.588953   750 window_manager.cpp:161]         <ChangeWindow> src win[-1], dst win[9]
      I1001 00:00:50.590200   750 device_setting.cpp:88]          <OnWindowLoaded> window load
      I1001 00:00:50.590322   750 device_setting.cpp:2312]        <DeviceModelInit> device setting presenter device model init
      I1001 00:00:50.590443   750 window_manager.cpp:142]         <ChangeWindow> ChangeWindow:src====-1, dst===7
      I1001 00:00:50.590531   750 window_manager.cpp:161]         <ChangeWindow> src win[-1], dst win[7]
      I1001 00:00:50.591559   750 status_bar_bottom.cpp:52]       <OnWindowLoaded> window load
      I1001 00:00:50.591667   750 window_manager.cpp:142]         <ChangeWindow> ChangeWindow:src====-1, dst===6
      [ISP_ERR]events_loop, line: 162,isp0 event select timeout
      W1001 00:00:50.801466   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      I1001 00:00:50.922931   750 window_manager.cpp:161]         <ChangeWindow> src win[-1], dst win[6]
      W1001 00:00:50.923005   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:50.702551   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:50.923247   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      I1001 00:00:50.930210   750 status_bar_window.cpp:1005]     <Update> handle msg:1  win_status_ =0
      E1001 00:00:50.930389   750 status_bar_window.cpp:1079]     <Update> MSG_STORAGE_UNMOUNT
      E1001 00:00:50.933068   750 status_bar_window.cpp:465]      <RecordStatusTimeUi> mstart: 0
      I1001 00:00:50.963589   750 status_bar_window.cpp:1005]     <Update> handle msg:60  win_status_ =0
      I1001 00:00:50.963907   750 status_bar_window.cpp:1005]     <Update> handle msg:65  win_status_ =0
      I1001 00:00:50.964565   750 event_manager.cpp:789]          <CheckNetLink> ioctl SIOCGIFFLAGS error, interface[wlan0], No such device
      I1001 00:00:50.964751   750 status_bar_window.cpp:1005]     <Update> handle msg:48  win_status_ =0
      I1001 00:00:50.964854   750 window_manager.cpp:142]         <ChangeWindow> ChangeWindow:src====9, dst===4
      E1001 00:00:50.964963   750 playback_window.cpp:1265]       <PlaybackWindow> PlaybackWindow create
      I1001 00:00:50.965159   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:50.967140   750 window.cpp:109]                 <CreateWidget> create window: PlaybackWindow
      CreateMainWindowEx  run 1313I1001 00:00:50.975780   750 progress_bar.cpp:184] <HandleMessage>
      I1001 00:00:50.994669   750 icon_view.cpp:26]               <IconView>
      I1001 00:00:50.999119   750 window.cpp:740]                 <Load> images_file :/usr/share/minigui/res/layout/PlaybackWindow.qrc
      I1001 00:00:51.063779   750 window.cpp:901]                 <SetWindowBackImage> ------ready to refresh
      create timer data is 0x0xe4ec30
      create timer data is 0x0xe4d3f0
      I1001 00:00:51.156486   750 bulletCollection.cpp:94]        <initButtonDialog> debug_zhb--------ready to create dialog
      I1001 00:00:51.156746   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:51.158077   750 window.cpp:109]                 <CreateWidget> create window: Dialog
      CreateMainWindowEx  run 1313I1001 00:00:51.183317   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/Dialog.qrc
      I1001 00:00:51.197495   750 window.cpp:901]                 <SetWindowBackImage> ------ready to refresh
      E1001 00:00:51.230700   750 window_manager.cpp:111]         <CreateWindowById> create window :4
      W1001 00:00:51.230908   750 window_manager.cpp:120]         <CreateWindowById> habo---> windowid = 4
      I1001 00:00:51.231036   750 window_manager.cpp:161]         <ChangeWindow> src win[9], dst win[4]
      I1001 00:00:51.232283   750 device_setting.cpp:100]         <OnWindowDetached> window detach
      E1001 00:00:51.235191   750 playback.cpp:124]               <OnWindowLoaded> PlaybackPresenter window load
      E1001 00:00:51.235361   750 status_bar_window.cpp:617]      <WinstatusIconHander> WinstatusIconHander: -1
      I1001 00:00:51.235520   750 display.cpp:326]                <SetLayerAlpha> layer id: 3, hlay: 8, alpha: 150
      I1001 00:00:51.244696   750 status_bar_bottom_window.cpp:378] <Update> handle msg:122
      I1001 00:00:51.245839   750 status_bar_window.cpp:1005]     <Update> handle msg:122  win_status_ =0
      I1001 00:00:51.245983   750 window_manager.cpp:142]         <ChangeWindow> ChangeWindow:src====4, dst===3
      I1001 00:00:51.246084   750 preview_window.cpp:685]         <PreviewWindow>
      I1001 00:00:51.246246   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:51.255414   750 window.cpp:109]                 <CreateWidget> create window: PreviewWindow
      CreateMainWindowEx  run 1313I1001 00:00:51.282685   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/PreviewWindow.qrc
      I1001 00:00:51.284262   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:51.284976   750 window.cpp:109]                 <CreateWidget> create window: ShutDownWindow
      CreateMainWindowEx  run 1313I1001 00:00:51.288552   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/ShutDownWindow.qrc
      I1001 00:00:51.341979   750 window.cpp:901]                 <SetWindowBackImage> ------ready to refresh
      I1001 00:00:51.342911   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:51.343992   750 window.cpp:109]                 <CreateWidget> create window: PromptBox
      CreateMainWindowEx  run 1313I1001 00:00:51.356163   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/PromptBox.qrc
      create timer data is 0x0xe4f0f0
      I1001 00:00:51.372788   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:51.373793   750 window.cpp:109]                 <CreateWidget> create window: Prompt
      CreateMainWindowEx  run 1313I1001 00:00:51.385624   750 window.cpp:740] <Load> images_file :/usr/share/minigui/res/layout/Prompt.qrc
      I1001 00:00:51.399979   750 window.cpp:901]                 <SetWindowBackImage> ------ready to refresh
      create timer data is 0x0xe54170
      W1001 00:00:51.405103   750 preview_window.cpp:729]         <PreviewWindow> photo mode =0      time =0
      create timer data is 0x0xe6c840
      I1001 00:00:51.405486   750 bulletCollection.cpp:94]        <initButtonDialog> debug_zhb--------ready to create dialog
      I1001 00:00:51.405704   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:51.406961   750 window.cpp:109]                 <CreateWidget> create window: Dialog
      CreateMainWindowEx  run 1313W1001 00:00:51.423308   848 VIChannel.cpp:1793] <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:51.423501   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:51.423593   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:51.423652   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      I1001 00:00:51.438369   750 window.cpp:740]                 <Load> images_file :/usr/share/minigui/res/layout/Dialog.qrc
      I1001 00:00:51.452960   750 window.cpp:901]                 <SetWindowBackImage> ------ready to refresh
      create timer data is 0x0xe57de0
      I1001 00:00:51.457998   750 window.cpp:828]                 <LoadRes> start parse ui resources
      I1001 00:00:51.458914   750 window.cpp:109]                 <CreateWidget> create window: USBModeWindow
      CreateMainWindowEx  run 1313I1001 00:00:51.462378   750 list_view.cpp:30] <ListView>
      I1001 00:00:51.468575   750 window.cpp:740]                 <Load> images_file :/usr/share/minigui/res/layout/USBModeWindow.qrc
      I1001 00:00:51.499807   750 window.cpp:901]                 <SetWindowBackImage> ------ready to refresh
      E1001 00:00:51.504616   750 window_manager.cpp:111]         <CreateWindowById> create window :3
      W1001 00:00:51.504807   750 window_manager.cpp:120]         <CreateWindowById> habo---> windowid = 3
      I1001 00:00:51.504932   750 window_manager.cpp:161]         <ChangeWindow> src win[4], dst win[3]
      E1001 00:00:51.506273   750 playback.cpp:188]               <OnWindowDetached> PlaybackPresenter window detach
      I1001 00:00:51.509531   750 window_manager.cpp:316]         <sendmsg> msg 232, val 0
      I1001 00:00:51.509668   750 status_bar_bottom_window.cpp:378] <Update> handle msg:2343
      E1001 00:00:51.509832   750 status_bar_bottom_window.cpp:431] <Update> MSG_SETTING_TO_PREIVEW_CHANG_STATUS_BAR_BOTTOM p_CamID 0
      I1001 00:00:51.510010   750 status_bar_window.cpp:1005]     <Update> handle msg:2343  win_status_ =0
      I1001 00:00:51.510097   750 status_bar_window.cpp:1087]     <Update> zhb---MSG_PLAYBACK_TO_PREIVEW_CHANG_STATUS_BAR_BOTTOM
      E1001 00:00:51.510185   750 status_bar_window.cpp:1090]     <Update> zhb---MSG_SETTING_TO_PREIVEW_CHANG_STATUS_BAR_BOTTOM win_statu_save: 0
      E1001 00:00:51.510293   750 status_bar_window.cpp:1764]     <SetStatusPreview> zhb---MSG_CHANG_STATU_PREVIEW
      E1001 00:00:51.510452   750 status_bar_window.cpp:617]      <WinstatusIconHander> WinstatusIconHander: 0
      E1001 00:00:51.515213   750 status_bar_window.cpp:861]      <ParkIconHander> [zhb]:ParkIconHander  index:[0]
      E1001 00:00:51.516719   750 status_bar_window.cpp:886]      <AwmdIconHander> [zhb]:AwmdIconHander  index:[0]
      E1001 00:00:51.516888   750 status_bar_window.cpp:909]      <VoiceIconHandler> [zhb]:VoiceIconHandler  index:[1]
      E1001 00:00:51.519098   750 status_bar_window.cpp:1488]     <UpdateGpsStatus> [zhb]:gpsIconHandler  show: 1 index:[4]
      W1001 00:00:51.526473   750 status_bar_window.cpp:954]      <UpdatePlaybackFileTime> [habo]---> fileTime =  m_show = 0
      I1001 00:00:51.526686   750 window_manager.cpp:454]         <ResetConfigLua> [fangjj]: ResetConfigLua----
      I1001 00:00:51.526787   750 device_setting.cpp:2140]        <UpdateAllSetting> [fangjj]:--------------NotifyAll------------begin
      I1001 00:00:51.526878   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[179], val[1]
      I1001 00:00:51.526965   750 device_setting.cpp:719]         <SetLedSwitch> [debug_jaosn]:####LedSwitch val = 1####
      I1001 00:00:51.527053   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[138], val[0]
      W1001 00:00:51.527139   750 preview_window.cpp:1220]        <Update> handle msg:2311
      W1001 00:00:51.527247   750 preview_window.cpp:1812]        <Update> [debug_jason]: isWifiStarting = 0
      I1001 00:00:51.527356   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[168], val[0]
      I1001 00:00:51.854440   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[129], val[0]
      E1001 00:00:51.854638   750 recorder.cpp:609]               <SetRecordEncodeSize> param dump:video_size: [3840x2160], fps: 25, bitrate: 31457280
      E1001 00:00:51.854496   844 videoInputHw.c:3875]            <VideoInputHw_CapThread> fatal error! vipp[0] get frame fail, but all frames are release!
      I1001 00:00:51.854784   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[134], val[3]
      E1001 00:00:51.854688   853 videoInputHw.c:3875]            <VideoInputHw_CapThread> fatal error! vipp[1] get frame fail, but all frames are release!
      I1001 00:00:51.854876   750 device_setting.cpp:2170]        <UpdateAllSetting> debug_zhb----->SETTING_SCREEN_BRIGHTNESS val= 3
      I1001 00:00:51.854964   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[165], val[0]
      I1001 00:00:51.855049   750 device_setting.cpp:390]         <SetScreenDisturbMode> [debug_zhb]----SetScreenDisturbMode = 0
      I1001 00:00:51.855134   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[137], val[1]
      I1001 00:00:51.855216   750 device_setting.cpp:395]         <SetVoiceTakePhotoSwitch> [debug_zhb]----SetVoiceTakePhotoSwitch = 1
      I1001 00:00:51.855299   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[164], val[1]
      I1001 00:00:51.855381   750 device_setting.cpp:400]         <SetVolumeSelection> [debug_zhb]----SetVolumeSelection = 1
      I1001 00:00:51.855463   750 audioCtrl.cpp:126]              <SetBeepToneVolume> the val is 83
      I1001 00:00:51.855545   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[161], val[1]
      I1001 00:00:51.855626   750 device_setting.cpp:406]         <SetPowerOnVoiceSwitch> [debug_zhb]----SetPowerOnVoiceSwitch = 1
      I1001 00:00:51.863507   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[160], val[1]
      I1001 00:00:51.863692   750 device_setting.cpp:413]         <SetKeyPressVoiceSwitch> [debug_zhb]----SetKeyPressVoiceSwitch = 1
      I1001 00:00:51.863786   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[147], val[1]
      I1001 00:00:51.863871   750 device_setting.cpp:418]         <SetDriveringReportSwitch> [debug_zhb]----SetDriveringReportSwitch = 1
      I1001 00:00:51.863955   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[141], val[1]
      I1001 00:00:51.864034   750 device_setting.cpp:440]         <SetAccSwitch> [debug_zhb]----open acc
      I1001 00:00:51.864116   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[142], val[1]
      I1001 00:00:51.864194   750 device_setting.cpp:430]         <SetAdasSwitch> [debug_zhb]----open adas
      I1001 00:00:51.864276   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[145], val[1]
      I1001 00:00:51.864358   750 device_setting.cpp:451]         <SetStandbyClockSwitch> [debug_zhb]----SetStandbyClockSwitch --- val = 1
      I1001 00:00:51.864442   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[166], val[1]
      I1001 00:00:51.864526   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[167], val[1]
      I1001 00:00:51.864609   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[143], val[1]
      I1001 00:00:51.864689   750 device_setting.cpp:492]         <SetWatchDogSwitch> [debug_zhb]----noly open watch dog probe prompt switch
      I1001 00:00:51.864773   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[162], val[1]
      W1001 00:00:51.923871   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      I1001 00:00:52.187229   750 device_setting.cpp:503]         <SetWatchProbePrompt> [debug_zhb]--- SetWatchProbePrompt---val = 1
      I1001 00:00:52.187368   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[163], val[0]
      W1001 00:00:52.187363   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:51.923871   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:52.187664   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      I1001 00:00:52.187474   750 device_setting.cpp:509]         <SetWatchSpeedPrompt> [debug_zhb]--- SetWatchSpeedPrompt---val = 0
      I1001 00:00:52.187855   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[132], val[0]
      I1001 00:00:52.187942   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[136], val[0]
      I1001 00:00:52.188024   750 device_setting.cpp:519]         <SetEmerRecordSwitch> [debug_zhb]----close SetEmerRecordSwitch
      I1001 00:00:52.188107   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[152], val[1]
      E1001 00:00:52.188201   750 gsensor_manager.cpp:654]        <writeImpactHappenLevel> GsensorManager level 1
      I1001 00:00:52.188311   750 gsensor_manager.cpp:705]        <writeImpactHappenLevel> by owl writeImpactHappenLevel impact_happen_level mGsensorImpactTarget=1
      I1001 00:00:52.188396   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[156], val[1]
      I1001 00:00:52.188479   750 device_setting.cpp:546]         <SetParkingWarnLampStatus> [debug_zhb]----SetParkingWarnLampStatus = 1
      I1001 00:00:52.188563   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[157], val[1]
      I1001 00:00:52.188645   750 device_setting.cpp:550]         <SetParkingAbnormalMonitoryStatus> [debug_zhb]----SetParkingAbnormalMonitoryStatus = 1
      I1001 00:00:52.188730   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[158], val[1]
      I1001 00:00:52.188812   750 device_setting.cpp:554]         <SetParkingAbnormalNoticeStatus> [debug_zhb]----SetParkingAbnormalNoticeStatus = 1
      I1001 00:00:52.188896   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[159], val[1]
      I1001 00:00:52.188978   750 device_setting.cpp:560]         <SetParkingLoopRecordStatus> [debug_zhb]----SetParkingLoopRecordStatus = 1
      I1001 00:00:52.189061   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[155], val[0]
      I1001 00:00:52.189144   750 device_setting.cpp:564]         <SetParkingLoopResolution> [debug_zhb]----SetParkingLoopResolution = 0
      I1001 00:00:52.189229   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[139], val[1]
      I1001 00:00:52.189308   750 device_setting.cpp:423]         <Set4GNetWorkSwitch> [debug_zhb]----Set4GNetWorkSwitch = 1
      I1001 00:00:52.189393   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[187], val[0]
      I1001 00:00:52.189476   750 device_setting.cpp:581]         <SetEncoderType> [debug_jaosn]:####SetVideoEncoder val = 0####
      E1001 00:00:52.189577   750 recorder.cpp:636]               <SetVideoEncoderType> ==============EncoderType 1==============
      E1001 00:00:52.189693   750 device_setting.cpp:299]         <getRecorder> [debug_joson]: first can't find the recoder
      I1001 00:00:52.189803   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[153], val[1]
      I1001 00:00:52.310613   889 wav_player.cpp:267]             <MPPAOCallback> AO callback_cnt_:98, find EOF, pcm play END!
      E1001 00:00:52.520011   750 device_setting.cpp:609]         <SetVideoRecordTime> [debug_jaosn]:####SetVideoRecordTime val = 1####
      I1001 00:00:52.520094   880 AOChannel_Component.c:170]      <AOSetStreamEof> AO end flag is set! drain pcm flag:1!
      W1001 00:00:52.520187   750 recorder.cpp:441]               <SetVideoClcRecordTime> record time: 120000, bitrate: 31457280
      I1001 00:00:52.520231   889 AOChannel_Component.c:1435]     <AOChannel_ComponentThread> B. AO notify player eof!
      W1001 00:00:52.520324   750 recorder.cpp:442]               <SetVideoClcRecordTime> [debug_jason]:record clc time is 2
      I1001 00:00:52.520439   750 media_file_manager.cpp:1670]    <Update> handle msg:86
      E1001 00:00:52.520535   750 device_setting.cpp:299]         <getRecorder> [debug_joson]: first can't find the recoder
      I1001 00:00:52.520648   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[144], val[0]
      W1001 00:00:52.520733   750 gsensor_manager.cpp:533]        <writeParkingSensibility> writeGsensorIntEnable false
      W1001 00:00:52.520840   750 gsensor_manager.cpp:479]        <writeGsensorIntEnable> writeGsensorIntEnable 0
      E1001 00:00:52.520943   750 gsensor_manager.cpp:484]        <writeGsensorIntEnable> by hero  GsensorIntEnable is close, do not set intEnable
      I1001 00:00:52.521056   750 gsensor_manager.cpp:586]        <set_sysfs_input_attr> by hero set_sysfs_input_attr class_path =
      E1001 00:00:52.521142   750 gsensor_manager.cpp:494]        <writeGsensorIntEnable> by hero writeGsensorIntEnable isEnable=0
      E1001 00:00:52.521251   750 gsensor_manager.cpp:538]        <writeParkingSensibility> by hero writeParkingSensibility value=3 mGsensorParkingImpactSlope=30000
      I1001 00:00:52.521360   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[175], val[3]
      I1001 00:00:52.521443   750 device_setting.cpp:701]         <SetExposureValue> [debug_jaosn]:####SetExposureValue val = 3####
      I1001 00:00:52.521538   750 camera.cpp:2000]                <SetExposureValue> =====m_ExposureBias is 4=====
      I1001 00:00:52.521721   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[176], val[0]
      I1001 00:00:52.521817   750 device_setting.cpp:710]         <SetWhiteBalance> [debug_jaosn]:####SetWhiteBalance val = 0####
      I1001 00:00:52.521908   750 camera.cpp:1913]                <SetWhiteBalance> SetWhiteBalance:0
      I1001 00:00:52.522043   750 newPreview.cpp:1374]            <Update> NewPreview recive msg 14
      I1001 00:00:52.522204   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[135], val[3]
      create timer data is 0x0xe916c0
      I1001 00:00:52.522717   750 device_setting.cpp:2059]        <SetAutoScreensaver> SetAutoScreensaver:val[3]
      I1001 00:00:52.522848   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[180], val[0]
      create timer data is 0x0xe91700
      I1001 00:00:52.523089   750 device_setting.cpp:2089]        <SetTimedShutdown> SetTimedShutdown:val[0]
      I1001 00:00:52.523192   750 autoshutdown.cpp:66]            <Stop> Autoshutdown stop
      I1001 00:00:52.523281   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[178], val[0]
      E1001 00:00:52.523367   750 device_setting.cpp:731]         <SetLightFreq> [debug_jaosn]:####SetLightFreq val = 0####
      I1001 00:00:52.523488   750 camera.cpp:2026]                <SetLightFreq> Camera::SetLightFreq, index: 0, flcker value: 1
      W1001 00:00:52.687757   848 VIChannel.cpp[   11.310634] sunxi_i2c_drv_core_process()992 - [i2c0] Timeout when sending 9th SCL clk
      W1001[   11.310688] i2c_sunxi_drv_complete()1162 - [i2c0] incomplete xfer(status: 0x1, dev addr: 0x27)
       00:00:52.852919   848 VIChannel.cpp:1797]                  <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
         11.310823] sunxi_i2c_drv_core_process()992 - [i2c1] Timeout when sending 9th SCL clk
      mW1001 00:00:52.687909   839 VIChannel.cpp:1793]            <captureThread> vipp[0] channel contain [0] frame buffers
      [   11.310859] i2c_sunxi_drv_complete()1162 - [i2c1] incomplete xfer(status: 0x1, dev addr: 0x27)
      I1001 00:00:52.570711   880 utils.cpp:135]                  <verify_bin_md5> run application from rootfs, no need verify md5, just chec[   11.386429] [MIR3DA] 'Find Mir3da gsensor!!
      k build version
      W1001 00:00:52.853173   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      I1001 00:00:52.852972   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[148], val[0]
      I1001 00:00:52.862335   750 device_setting.cpp:2034]        <GetMenuConfig> [fangjj]:GetMenuConfig:msg[[   11.403408] ParkMonitor* powerOn status is 0
      190], val[0]
      W1001 00:00:52.862524   750 VIChannel.cpp:437]              <stopMODDetect> MOD already disable
      I1001 00:0[   11.415266] ParkMonitor hwmon_device_register
      0:52.862655   750 device_setting.cpp:2296]                  <UpdateAllSetting> --------------NotifyAll------------ over
      W1001 0[   11.416073] ParkMonitor input_set_abs_params
      0:00:52.864333   750 preview_window.cpp:1000]               <DetectSdcardNewVersion> debug_zhb-------ready------detecte the new vers[   11.416080] ParkMonitor input_register_polled_device
      ion
      W1001 00:00:52.864635   750 preview_window.cpp:1005]        <DetectSdcardNewVersion> get sdcard version info f[   11.417186] input: da380 as /devices/virtual/input/input3
      ail
      I1001 00:00:52.864992   923 event_manager.cpp:1015]         <EventLoopThread> event loop
      I1001 00:00:52.865674   926 [   11.417810] ParkMonitor sysfs_create_group
      event_manager.cpp:453]                                      <openSerialPort> standard input is not a terminal device
      I1001 00:00:52.865876   926 event_man[   11.417980] ParkMonitor misc_register
      ager.cpp:408]                                               <configureSerialPort> set done!
      E1001 00:00:52.865887   925 event_manager.cpp:3386]         <C[   11.418977] ParkMonitor gsensor_int.gpio=-2
      heckAccEvent> CheckAccEvent DC in
      E1001 00:00:52.866035   924 event_manager.cpp:2689]         <CheckImpackEvent> Ch[   11.418984] [MIR3DA] mir3da_probe: gsensor_int is invalid.
      [   11.418984]
      eckImpackEvent Load gsensor driver after IOVDD-CSI ON
      I1001 00:00:52.866091   925 event_manager.cpp:3389]         <CheckA[   11.423177] ParkMonitor init finish !!!
      ccEvent> notify MSG_ACCON_STARTCHECK
      W1001 00:00:52.870643   750 power_manager.cpp:1079]         <getPowenOnType> powe[   11.423886] [VIN CCI_1 ERR] Status error at addr_8bit = 4e, wr_flag = 0, val = c000000
      W1001 00:00:52.870862   750 power_manager.cpp:1082]         <getPowenOnType> tm[   11.440060] [VIN CCI_1 ERR] Status error at addr_8bit = 4e, wr_flag = 1, val = f
      W1001 00:00:52.871623   930 newPreview.cpp:1998]            <OnUILoaded> ========== OnUILoad[   11.456217] [VIN CCI_1 ERR] Status error at addr_8bit = 4e, wr_flag = 1, val = 1
      ed
      [   11.472322] [VIN CCI_1 ERR] Status error at addr_8bit = 4e, wr_flag = 1, val = 1
      [   11.472334] [MIR3DA] Can't find Mir3da gsensor!!
      [   11.472348] mir3da_init i2c i2c_add_driver is 0
      W1001 00:00:53.353262   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:53.353442   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:53.353482   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:53.353595   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:53.571305   924 gsensor_manager.cpp:804]        <RunGsensorManager> by hero *** RunGsensorManager
      I1001 00:00:53.571882   924 gsensor_manager.cpp:211]        <searchDevice> ret:1
      I1001 00:00:53.572926   924 gsensor_manager.cpp:321]        <sensorsDetect> name is da380
      I1001 00:00:53.573052   924 gsensor_manager.cpp:322]        <sensorsDetect> devname is /dev/input/event3
      W1001 00:00:53.652428   924 gsensor_manager.cpp:479]        <writeGsensorIntEnable> writeGsensorIntEnable 1
      E1001 00:00:53.652686   924 gsensor_manager.cpp:484]        <writeGsensorIntEnable> by hero  GsensorIntEnable is close, do not set [   12.071614] mir3da_int2_enable_store on=0 slope_th=0x97  int_latch_mode=0x83
      intEnable
      I1001 00:00:53.652819   924 gsensor_manager.cpp:586]        <set_sysfs_input_attr> by hero set_sysfs_input_attr class_path = /sys/class/input/input3
      I1001 00:00:53.653069   924 gsensor_manager.cpp:595]        <set_sysfs_input_attr> by hero set_sysfs_input_attr path = /sys/class/input/input3/int2_enable
      E1001 00:00:53.653901   924 gsensor_manager.cpp:494]        <writeGsensorIntEnable> by hero writeGsensorIntEnable isEnable=0
      E1001 00:00:53.654264   931 gsensor_manager.cpp:840]        <GsensorManagerThread> by hero GsensorManagerThread path = /sys/class/input/input3/int2_start_status
      E1001 00:00:53.654352   932 gsensor_manager.cpp:986]        <DealNormalAxisDataThread> [OWL_DEBUG] 00 DealNormalAxisDataThread axis_x_key = /sys/class/input/input3/axis_x_value
      W1001 00:00:53.853899   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:53.853917   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:53.854125   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:53.854189   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      E1001 00:00:53.866914   925 event_manager.cpp:3301]         <CheckAccEvent> AccEvent DC in
      I1001 00:00:53.867099   925 storage_manager.cpp:1028]       <Update> handle msg:113
      I1001 00:00:53.867187   925 storage_manager.cpp:1075]       <Update> send MSG_ACCON_HAPPEN start
      I1001 00:00:53.867270   925 camera.cpp:2176]                <Update> handle msg:113
      I1001 00:00:53.867352   925 media_file_manager.cpp:1670]    <Update> handle msg:113
      I1001 00:00:53.867435   925 newPreview.cpp:1374]            <Update> NewPreview recive msg 113
      E1001 00:00:53.867518   925 newPreview.cpp:1430]            <Update> NewPreview send MSG_ACCON_HAPPEN start
      I1001 00:00:53.867630   925 status_bar_bottom_window.cpp:378] <Update> handle msg:113
      I1001 00:00:53.867719   925 status_bar_window.cpp:1005]     <Update> handle msg:113  win_status_ =0
      W1001 00:00:53.867807   925 preview_window.cpp:1220]        <Update> handle msg:113
      W1001 00:00:53.867914   925 preview_window.cpp:1268]        <Update> by hero *** ------PreviewWindow------------MSG_ACCON_HAPPEN ---
      I1001 00:00:53.868026   925 screensaver.cpp:181]            <ForceScreenOnBySdcard> debug_zhb---> screensaver::ForceScreenOnBySdcard()  saver_switch_ = 0
      W1001 00:00:53.868456   925 preview_window.cpp:2108]        <HandlerPromptInfo> [debug_jaosn]:PROMPT_TF_NULL 22
      W1001 00:00:53.868598   925 preview_window.cpp:2048]        <ShowPromptInfo> [debug_zhb]-------PreviewWindow-----ShowPromptInfo  prompt_id:14
      E1001 00:00:53.897153   844 videoInputHw.c:3875]            <VideoInputHw_CapThread> fatal error! vipp[0] get frame fail, but all frames are release!
      E1001 00:00:53.897429   853 videoInputHw.c:3875]            <VideoInputHw_CapThread> fatal error! vipp[1] get frame fail, but all frames are release!
      I1001 00:00:53.906802   925 window.cpp:901]                 <SetWindowBackImage> ------ready to refresh
      I1001 00:00:53.908367   925 prompt.cpp:278]                 <DoShow> debug_zhb---> prompt doshow window id:3
      W1001 00:00:53.909907   925 prompt.cpp:124]                 <ShowPromptInfo> [debug-zhb]-----------prompt_id = 14  title =    text = ml_prompt_tf_null
      begain to set the period timer, timer id is 0xda463e92
      I1001 00:00:54.053952   925 newPreview.cpp:1432]            <Update> NewPreview send MSG_ACCON_HAPPEN end
      I1001 00:00:54.054113   925 storage_manager.cpp:1077]       <Update> send MSG_ACCON_HAPPEN end
      W1001 00:00:54.354408   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:54.354413   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:54.354665   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:54.354732   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:54.854955   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:54.854955   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:54.855201   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:54.855269   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      I1001 00:00:55.054042   916 prompt.cpp:228]                 <HandlePromptTime> zhb---------pt->timercount = 1
      W1001 00:00:55.355504   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:55.355504   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:55.355763   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:55.355834   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:55.856052   839 VIChannel.cpp:1793]             <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:55.856055   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:55.856315   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:55.856381   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
      t[ISP_ERR]video_wait_buffer, line: 442,video0 select timeout!
      E1001 00:00:55.939646   844 videoInputHw.c:3875]            <VideoInputHw_CapThread> fatal error! vipp[0] get frame fail, but all frames are release!
      E1001 00:00:55.939913   853 videoInputHw.c:3875]            <VideoInputHw_CapThread> fatal error! vipp[1] get frame fail, but all frames are release!
      oI1001 00:00:56.054039   916 prompt.cpp:228]                <HandlePromptTime> zhb---------pt->timercount = 2
      pW1001 00:00:56.356617   839 VIChannel.cpp:1793]            <captureThread> vipp[0] channel contain [0] frame buffers
      W1001 00:00:56.356618   848 VIChannel.cpp:1793]             <captureThread> vipp[1] channel contain [0] frame buffers
      W1001 00:00:56.356871   839 VIChannel.cpp:1797]             <captureThread> vipp[0]: preview_num: 0, picture_num: 0, timeout: 500ms
      W1001 00:00:56.356945   848 VIChannel.cpp:1797]             <captureThread> vipp[1]: preview_num: 0, picture_num: 0, timeout: 500ms
