    MQ-Pro overlay挂载的问题
    7
    6402
      lbuque LV 4 最后由 编辑
      sdk: tina v2.0
      patch: https://github.com/mangopi-sbc/Tina_d1x_append
      问题:挂载/dev/by-name/rootfs_data找不到块设备
      查了相关资料,需要修改sys_partition.fex,
      看了tina-d1-h/device/config/chips/d1-h/configs/mq_pro/sys_partition.fex 文件,没看到有UDISK这个分区。
        UDISK分区可能是pack打包程序生成,也可能是烧录软件生成的,也可能是运行的时候脚本生成的,我还不确定。
        L 2 条回复 最后回复 回复 引用 分享 0
          lbuque LV 4 @whycan 最后由 编辑
          @whycan 附上pack的log
          PACK_CHIP         sun20iw1p1
          PACK_PLATFORM     tina
          PACK_BOARD        d1-h-mq_pro
          PACK_KERN
          PACK_DEBUG        uart0
          PACK_SIG          none
          PACK_SECURE       none
          PACK_MODE         normal
          PACK_FUNC         android
          PACK_PROGRAMMER   none
          PACK_TAR_IMAGE    none
          PACK_TOPDIR       /home/lewin/tina-d1-h
          No kernel param, parse it from d1-h
          copying tools file
          copying configs file
          storage_type value is 1
          rm /home/lewin/tina-d1-h/out/d1-h-mq_pro/image/sys_partition_nor.fex
          rm /home/lewin/tina-d1-h/out/d1-h-mq_pro/image/image_nor.cfg
          copying boot resource
          LZMA 4.65 : Igor Pavlov : Public domain : 2009-02-03
          copying boot file
          make user resource for : /home/lewin/tina-d1-h/out/d1-h-mq_pro/image/sys_partition.fex
          handle partition user-res
          no user resource partitions
          APP_PART_DOWNLOAD_FILE = /home/lewin/tina-d1-h/out/d1-h-mq_pro/image/app.fex
          Need size of filesystem
          no data resource partitions
          don't build dtbo ...
          update_chip
          pack boot package
          content_count=3
          packing for tina linux
          normal
          mbr count = 4
          partitation file Path=/home/lewin/tina-d1-h/out/d1-h-mq_pro/image/sys_partition.bin
          mbr_name file Path=/home/lewin/tina-d1-h/out/d1-h-mq_pro/image/sunxi_mbr.fex
          download_name file Path=/home/lewin/tina-d1-h/out/d1-h-mq_pro/image/dlinfo.fex
          mbr size = 252
          mbr magic softw411
          disk name=boot-resource
          disk name=env
          disk name=env-redund
          disk name=boot
          disk name=rootfs
          disk name=dsp0
          disk name=recovery
          this is not a partition key
          update_for_part_info 0
          crc 0 = 4c7bc2df
          crc 1 = d9c69382
          crc 2 = bc706624
          crc 3 = 29cd3779
          gpt_head->header_crc32 = 0x892c53ba
          GPT----part num 8---
          gpt_entry: 128
          gpt_header: 92
          GPT:boot-resource: a1f8          c177
          GPT:env         : c178          c36f
          GPT:env-redund  : c370          c567
          GPT:boot        : c568          1161f
          GPT:rootfs      : 11620         1b597
          GPT:dsp0        : 1b598         1b987
          GPT:recovery    : 1b988         227c7
          GPT:UDISK       : 227c8         ffffffde
          update gpt file ok
          update mbr file ok
          temp = 20
          mbr count = 4 total_sectors = 15269888 logic_offset = 40960
          mbr size = 252
          mbr magic softw411
          disk name=env
          disk name=boot
          disk name=rootfs
          disk name=dsp0
          disk name=recovery
          crc 0 = 4c7bc2df
          crc 1 = d9c69382
          crc 2 = bc706624
          crc 3 = 29cd3779
          gpt_head->header_crc32 = 0x1328fa28
          gpt_entry: 128
          gpt_header: 92
          GPT:env         : c178          c36f
          GPT:UDISK       : 227c8         e8ffde
          update gpt file ok
          update mbr file ok
            [mbr]
            mbr_size  : 252 Kbyte
            partition_name  : boot-resource
            partition_size  : 8064
            boot-resource.fex size : 3.0M byte
            partition_name  : env
            partition_size  : 504
            downloadfile  : env.fex
            env.fex size : 128K byte
            partition_name  : env-redund
            partition_size  : 20664
            downloadfile  : boot.fex
            boot.fex -> /home/lewin/tina-d1-h/out/d1-h-mq_pro/boot.img
            boot.img size : 5.0M byte
            partition_name  : rootfs
            partition_size  : 40824
            downloadfile  : rootfs.fex
            rootfs.fex -> /home/lewin/tina-d1-h/out/d1-h-mq_pro/rootfs.img
            rootfs.img size : 17M byte
            partition_name  : dsp0
            partition_size  : 1008
            downloadfile  : dsp0.fex
            dsp0.fex size : 249K byte
            partition_name  : recovery
            partition_size  : 28224
          /home/lewin/tina-d1-h/out/host/bin/
          Begin Parse sys_partion.fex
          FilePath: boot-resource.fex
          FileLength=2f8c00Add partion env.fex ENV_FEX000000000
          FilePath: env.fex
          FileLength=20000Add partion env.fex ENV_FEX000000000
          FilePath: env.fex
          FilePath: boot.fex
          FileLength=4f4800Add partion rootfs.fex ROOTFS_FEX000000
          FilePath: rootfs.fex
          FileLength=1060000Add partion dsp0.fex DSP0_FEX00000000
          Add partion very dsp0.fex DSP0_FEX00000000
          FilePath: dsp0.fex
          FileLength=3e38cBuildImg 0
          ----------image is for nand/emmc----------
          /home/lewin/tina-d1-h/out/d1-h-mq_pro/tina_d1-h-mq_pro_uart0.img
          pack finish
              lbuque LV 4 最后由 编辑
              原因:
              打上patch https://github.com/mangopi-sbc/Tina_d1x_append, lunch选择mq pro的板卡进行编译,tina/target/allwinner/<方案名>/base-files/etc/config/fstab 这个文件并没有正常,导致无法成功将UDISK分区挂载到/overlay
                casojie LV 5 @lbuque 最后由 编辑
                @lbuque 大哥,这个pack要怎么打,不会啊,全部下载放到SDK根目录下吗
                • B
                  beiyi LV 4 最后由 编辑
                  大佬,我用的是D1H,和您这个是一个问题吗?
