    T113 做USB主机连接4G模块,时断时续
      Vogelweide LV 6 最后由 编辑
      HI,各位大佬,请教下:我用T113连接4G模块,不停打印 断开连接,连接,如下。。。可能是什么问题呢?
      测量4G模块电源正常,USB DP DM没接反,有时也会显示出4个设备和枚举出来的一堆串口,可能是dts吗?高速信号layout的不好?
      &usbc1 {
      device_type = "usbc1";
      usb_port_type = <0x01>;
      usb_regulator_io = "nocare";
      上面是我的USB1口 DTS
      下面是串口打印:
      [ 5.543126] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 5.648240] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 5.983112] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 5.992030] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
      [ 6.118241] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 6.373139] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 6.588242] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 6.813122] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 6.838240] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 7.033142] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
      [ 7.040503] usb usb1-port1: attempt power cycle
      [ 7.463116] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 7.513157] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
      [ 7.536238] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 7.903116] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 7.938236] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 8.343114] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 8.352034] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
      [ 8.408240] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 8.653112] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 8.878240] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 9.313116] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 9.348239] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 9.533146] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
      [ 9.540507] usb usb1-port1: unable to enumerate USB device
      [ 9.546722] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 9.583158] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
      [ 9.590607] usb usb2-port1: attempt power cycle
      [ 9.948238] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 10.153132] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [ 10.358238] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
        这种问题大概率最后可能还是 4G模块电源问题和USB通讯问题。
        S 1 条回复 最后回复 回复 引用 分享 0
          Vogelweide LV 6 @whycan 最后由 编辑
          @whycan 谢谢回复,我再自查一下。
