    tina编译突然莫名其妙的报错
    12
    9690
    • jinxiangwzh
      jinxiangwzh LV 7 最后由 编辑
      之前编译一直正常,也没修改什么东西,突然报下面的错误
      > /home/jamo/workspace/lindenis-v536/out/v536-Lindenis_SBC/compile_dir/target/linux-v536-Lindenis_SBC/busybox-init-base-files/ipkg-sunxi/busybox-init-base-files/CONTROL/conffiles; fi done
      find /home/jamo/workspace/lindenis-v536/out/v536-Lindenis_SBC/compile_dir/target/linux-v536-Lindenis_SBC/busybox-init-base-files/ipkg-sunxi/busybox-init-base-files -name 'CVS' -o -name '.svn' -o -name '.#*' -o -name '*~'| xargs -r rm -rf
      Package busybox-init-base-files is missing dependencies for the following libraries:
      libc.so.6
      libpthread.so.0
      Makefile:228: recipe for target '/home/jamo/workspace/lindenis-v536/out/v536-Lindenis_SBC/packages/base/busybox-init-base-files_167-1654496826_sunxi.ipk' failed
      make[3]: *** [/home/jamo/workspace/lindenis-v536/out/v536-Lindenis_SBC/packages/base/busybox-init-base-files_167-1654496826_sunxi.ipk] Error 1
      make[3]: Leaving directory '/home/jamo/workspace/lindenis-v536/package/busybox-init-base-files'
      package/Makefile:192: recipe for target 'package/busybox-init-base-files/compile' failed
      make[2]: *** [package/busybox-init-base-files/compile] Error 2
      make[2]: Leaving directory '/home/jamo/workspace/lindenis-v536'
      package/Makefile:189: recipe for target '/home/jamo/workspace/lindenis-v536/out/v536-Lindenis_SBC/staging_dir/target/stamp/.package_compile' failed
      make[1]: *** [/home/jamo/workspace/lindenis-v536/out/v536-Lindenis_SBC/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/home/jamo/workspace/lindenis-v536'
      /home/jamo/workspace/lindenis-v536/build/toplevel.mk:304: recipe for target 'world' failed
      make: *** [world] Error 2
      #### make failed to build some targets (05:09 (mm:ss)) ####
      重点好像是这个,但是不知道怎么修改
      libc.so.6
      libpthread.so.0
      请求帮助
        YterAA LV 7 最后由 编辑
        busybox-init-base-files 打包缺少两个库文件,如果之前一直可以编译那make clean重新编译下试试
        • jinxiangwzh
          jinxiangwzh LV 7 @YterAA 最后由 编辑
          @yteraa 试过了 我把out文件也手动删除了 还是没用
            whycan晕哥 LV 9 @jinxiangwzh 最后由 whycan 编辑
            @jinxiangwzh
            修改 package/busybox-init-base-files 目录下面的 Makefile 文件, 增加一个复制 libc.so.6, libpthread.so.0的shell指令。
            whycan jinxiangwzh 2 条回复 最后回复 回复 引用 分享 0
              whycan晕哥 LV 9 @whycan 最后由 编辑
              @whycan
              依葫芦画瓢:
              $ grep cp -r package/ --include "Makefile" |grep libpthread
              package/qt/qt5/Makefile:  DEPENDS:=+librt +zlib +libstdcpp +libinput +libpthread +glib2 @!LINUX_2_6
              package/lang/node/Makefile:  DEPENDS:=+libpthread +librt +libstdcpp +libopenssl +libuv
              package/network/alljoyn/alljoyn/Makefile:  DEPENDS:=+libopenssl +libpthread +librt +libstdcpp +libcap
              package/network/iotivity/Makefile:  DEPENDS:=+iotivity +libpthread +libstdcpp
              package/allwinner/liballwinner-ipc/Makefile:  DEPENDS:=+libpthread +libstdcpp
              package/allwinner/homlet/libvop/Makefile:       DEPENDS:=+libpthread +libstdcpp
              package/allwinner/homlet/p2p_utils/Makefile:    DEPENDS:=+libpthread +libstdcpp
              package/allwinner/softap/Makefile:  DEPENDS:=+libpthread +libstdcpp +liballwinner-base +libopenssl +iw +hostapd +dnsmasq +iptables
              package/allwinner/usb-gadget/Makefile:  DEPENDS:=+libpthread +libstdcpp
              package/allwinner/dlna-service/Makefile:  DEPENDS:=+libpthread +libstdcpp +liballwinner-base +liballwinner
              package/allwinner/peq/Makefile:  DEPENDS:=+libpthread +libstdcpp +liballwinner-base +libopenssl +iw +alsa-utils
              package/allwinner/logwrapper/Makefile:  DEPENDS:=+libpthread +libstdcpp
              package/allwinner/dlna_demo/Makefile:  DEPENDS:=+libpthread +libstdcpp +liballwinner-base +liballwinner +dlna-service
              package/allwinner/wifimanager/Makefile:  DEPENDS:=+libpthread +libstdcpp +liballwinner-base
              package/allwinner/bluetooth/Makefile:  DEPENDS:=+libpthread +librt +alsa-lib +resample +libuci +libstdcpp
              package/allwinner/smartlinkd/Makefile:  DEPENDS:=+libpthread +libstdcpp +liballwinner-base +alsa-lib +libopenssl +libuci
              package/libs/libdirectfb/Makefile:    DEPENDS:=+libstdcpp +tslib +libpng +libjpeg +libpthread +libfreetype +libsysfs +flux
              package/libs/boost/Makefile:  DEPENDS:=+libstdcpp +libpthread +librt
              package/libs/libglog/Makefile:  DEPENDS:= +libstdcpp +libpthread +libunwind
              package/libs/icu/Makefile:  DEPENDS:=+libstdcpp +libpthread
              package/routing/mcproxy/Makefile:  DEPENDS:=+libpthread +libstdcpp @(!GCC_VERSION_4_4&&!GCC_VERSION_4_6)
              • jinxiangwzh
                jinxiangwzh LV 7 @whycan 最后由 编辑
                @whycan 嗯 我从网上 搜索到这么一个帖子 ,就是cp命令报错
                $(CP) libc.so.6 libpthread.so.0 $(PKG_BUILD_DIR)/
                不知道从哪个目录复制哪个目录
                  whycan晕哥 LV 9 @jinxiangwzh 最后由 编辑
                  @jinxiangwzh
                  libc.so.6 libpthread.so.0 改成完整路径?
                  • jinxiangwzh
                    @whycan 😧 就是不知道完整目录在哪里 然后要复制到哪个目录
                      @jinxiangwzh
                      find 命令值得拥有。
                      find $PWD -name libpthread.so.0*  -type f
                        yelong98 LV 7 最后由 编辑
                        放弃挣扎吧,我也遇到过,有时候用make j1又可以过。有时候咋都不行,整个工程删除重来,我遇到好几次了,ubuntu20.04环境
                          建议用Ubuntu16.04, 这里有干净版本ubuntu16.04虚拟机下载:
                          https://pan.baidu.com/s/1_4HbkRZt3oLMWWGOa5fV5g?pwd=awol
                          https://www.aliyundrive.com/s/QrwYdthyKqs
                          • jinxiangwzh
                            @whycan 感谢 我最终也没搞清楚原因,我又重新创建了一个文件夹拉取了一遍代码编译的。
