    Windows/Linux 给 lvgl8 添加本地文件系统支持。
    GUI
    4778
      whycan晕哥 LV 9 最后由 whycan 编辑
      转载: LVGL V8之使用PC文件系统驱动适配lvgl文件系统
      注册lvgl文件系统
      void init_fs_config(void)
          static lv_fs_drv_t pcfs_drv;                         /*A driver descriptor*/
          lv_fs_drv_init(&pcfs_drv);
          pcfs_drv.user_data = NULL;
          pcfs_drv.letter = 'P';
          pcfs_drv.ready_cb = pcfs_ready;
          pcfs_drv.write_cb = pcfs_write;
          pcfs_drv.open_cb = pcfs_open;
          pcfs_drv.close_cb = pcfs_close;
          pcfs_drv.read_cb = pcfs_read;
          pcfs_drv.seek_cb = pcfs_seek;
          pcfs_drv.tell_cb = pcfs_tell;
          lv_fs_drv_register(&pcfs_drv);
      文件系统是否准备好被回调函数pcfs_ready
      bool pcfs_ready(lv_fs_drv_t* drv)
          (void)drv; /*Unused*/
          return true;  //这里仅返回true,如果是嵌入式,则是返回嵌入式文件系统挂载成功与否的标志
      打开文件被回调的函数pcfs_open
      static void* pcfs_open(lv_fs_drv_t* drv, const char* fn, lv_fs_mode_t mode)
          errno = 0;
          const char* flags = "";
          if (mode == LV_FS_MODE_WR) flags = "wb";
          else if (mode == LV_FS_MODE_RD) flags = "rb";
          else if (mode == (LV_FS_MODE_WR | LV_FS_MODE_RD)) flags = "a+";
          /*Make the path relative to the current directory (the projects root folder)*/
          char buf[256];
          sprintf(buf, "./%s", fn);
          return fopen(buf, flags);
      写入文件被回调的函数pcfs_write
      static lv_fs_res_t pcfs_write(struct _lv_fs_drv_t* drv, void* file_p, const void* buf, uint32_t btw, uint32_t* bw)
          *bw = (uint32_t)fwrite(buf, 1, btw, file_p);
          return LV_FS_RES_OK;
      读取文件被回调的函数pcfs_read
      static lv_fs_res_t pcfs_read(lv_fs_drv_t* drv, void* file_p, void* buf, uint32_t btr, uint32_t* br)
          //pc_file_t* fp = file_p;        /*Just avoid the confusing casings*/
          *br = (uint32_t)fread(buf, 1, btr, file_p);
      关闭文件被回调的函数pcfs_close
      static lv_fs_res_t pcfs_close(lv_fs_drv_t* drv, void* file_p)
          return fclose(file_p);
      移动文件位置被回调的函数pcfs_seek
      static lv_fs_res_t pcfs_seek(lv_fs_drv_t* drv, void* file_p, uint32_t pos,lv_fs_whence_t whence)
          return fseek(file_p, pos, whence);
      获取文件位置被回调的函数pcfs_tell
      static lv_fs_res_t pcfs_tell(lv_fs_drv_t* drv, void* file_p, uint32_t* pos_p)
          *pos_p = ftell(file_p);
      初时化调用init_fs_config函数
      init_fs_config();
      加载外部图片
          lv_obj_t* obj = lv_img_create(lv_scr_act());
          lv_img_set_src(obj, "P:/lock_icon.bin");
          lv_obj_center(obj);
      效果图
      加载外部字体需要匹配读取数据函数
      static uint8_t __g_font_buf[364];//如bin文件存在SPI FLASH可使用此buff
      static uint8_t *__user_font_getdata(int offset, int size){
          //如字模保存在SPI FLASH, SPIFLASH_Read(__g_font_buf,offset,size);
          //如字模已加载到SDRAM,直接返回偏移地址即可如:return (uint8_t*)(sdram_fontddr+offset);
          lv_fs_file_t file;
          lv_fs_res_t result;
          result = lv_fs_open(&file, "P:/myFont.bin", LV_FS_MODE_RD);
          if (result != LV_FS_RES_OK)
              return NULL;
          lv_fs_seek(&file, offset, LV_FS_SEEK_CUR);
          uint32_t len;
          lv_fs_read(&file, __g_font_buf, size, &len);
          lv_fs_close(&file);
          return __g_font_buf;
      使用外部字显示
          lv_obj_t* obj = lv_btn_create(lv_scr_act());
          lv_obj_set_size(obj, 300, 300);
          lv_obj_center(obj);
          lv_obj_t* label = lv_label_create(obj);
          lv_obj_set_style_text_font(label, &_myFont, 0);
          lv_label_set_text(label, "外部字体测试");
          lv_obj_center(label);
      中文内容需要utf-8格式编译
      #pragma execution_character_set("utf-8") `
      X 1 条回复 最后回复 回复 引用 分享 0
        用这代码, 显示本地 gif 图片成功。
        • X
          xfdr0805 LV 5 @whycan 最后由 编辑
          @whycan lvgl本身就支持吧,只要在lv_config.h配置一下就可以用了
          • 3rd party libraries
          /*File system interfaces for common APIs
          To enable set a driver letter for that API/
          #define LV_USE_FS_STDIO '\0' /Uses fopen, fread, etc/
          //#define LV_FS_STDIO_PATH "/home/john/" /*Set the working directory. If commented it will be "./" */
          #define LV_USE_FS_POSIX 1 /Uses open, read, etc/
          #define CONFIG_LV_FS_POSIX_LETTER 'S' /Uses open, read, etc/
          //#define LV_FS_POSIX_PATH "/" /*Set the working directory. If commented it will be "./" */
          #define LV_USE_FS_WIN32 '\0' /Uses CreateFile, ReadFile, etc/
          //#define LV_FS_WIN32_PATH "C:\Users\john\" /*Set the working directory. If commented it will be ".\" */
          #define LV_USE_FS_FATFS '\0' /Uses f_open, f_read, etc/
            whycan晕哥 LV 9 @xfdr0805 最后由 whycan 编辑
            @xfdr0805
            感谢指教, 我搜索了一下本地文件确实没有, 是比较旧的 v8.0.x
            看了一下主线, 真有了:
            https://github.com/lvgl/lvgl/commits/master/src/extra/libs/fsdrv/lv_fs_posix.c
            https://github.com/lvgl/lvgl/blob/master/lv_conf_template.h
