    v853 开发板 使用 i2cdetect 检查 i2c 设备,报错 incomplete xfer status: 0x48,
    5358
      wxid_disxysjskla LV 5 最后由 编辑
      V853 的所有 i2c 测试都是这样的错误,但是设备又是正常使用的,摄像头也是正常的。
      之前在v831上也遇到过这个问题
      root@TinaLinux:/# i2cdetect -l
      i2c-0   i2c             twi0                                    I2C adapter
      i2c-1   i2c             twi1                                    I2C adapter
      i2c-2   i2c             twi2                                    I2C adapter
      i2c-3   i2c             twi3                                    I2C adapter
      i2c-4   i2c             twi4                                    I2C adapter
      测试指令:
      root@TinaLinux:/# i2cdetect -y -r 0
      报错。
           0  1  2  3  4  5  6  7  8  [  115.384854] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x8)
      9  a  b  c  d  e  f
      00:        [  115.397002] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x9)
                       -- [  115.409100] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0xa)
      -- -- [  115.420038] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0xb)
      -- [  115.429774] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0xc)
      -- [  115.439425] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0xd)
      -- [  115.449238] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0xe)
      -- [  115.458871] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0xf)
      10: [  115.468484] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x10)
      -- [  115.478725] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x11)
      -- [  115.488403] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x12)
      -- [  115.498150] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x13)
      -- [  115.507783] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x14)
      -- [  115.517525] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x15)
      -- [  115.527204] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x16)
      -- [  115.536938] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x17)
      -- [  115.546696] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x18)
      -- [  115.556442] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x19)
      -- [  115.566120] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x1a)
      -- [  115.575860] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x1b)
      -- [  115.585540] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x1c)
      -- [  115.595306] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x1d)
      -- [  115.604980] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x1e)
      -- [  115.614720] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x1f)
      20: [  115.624423] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x20)
      -- [  115.634657] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x21)
      -- [  115.644333] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x22)
      -- [  115.654066] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x23)
      -- [  115.663783] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x24)
      -- [  115.673600] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x25)
      -- [  115.683283] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x26)
      -- [  115.693030] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x27)
      -- [  115.702712] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x28)
      -- [  115.712452] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x29)
      -- [  115.722156] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x2a)
      -- [  115.731898] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x2b)
      -- [  115.741577] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x2c)
      -- [  115.751314] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x2d)
      -- [  115.760992] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x2e)
      -- [  115.770727] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x2f)
      30: [  115.780423] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x30)
      -- [  115.790658] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x31)
      -- [  115.800404] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x32)
      -- [  115.810162] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x33)
      -- [  115.819856] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x34)
      -- [  115.829599] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x35)
      -- [  115.839278] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x36)
      -- [  115.849042] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x37)
      -- [  115.858714] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x38)
      -- [  115.868454] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x39)
      -- [  115.878135] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x3a)
      -- [  115.887835] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x3b)
      -- [  115.897520] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x3c)
      -- [  115.907259] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x3d)
      -- [  115.916941] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x3e)
      -- [  115.926676] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x3f)
      40: [  115.936449] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x40)
      -- [  115.946696] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x41)
      -- [  115.956373] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x42)
      -- [  115.966113] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x43)
      -- [  115.976119] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x44)
      -- [  115.985738] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x45)
      -- [  115.995480] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x46)
      -- [  116.005160] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x47)
      -- [  116.014896] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x48)
      -- [  116.024570] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x49)
      -- [  116.034306] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x4a)
      -- [  116.043980] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x4b)
      -- [  116.053713] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x4c)
      -- [  116.063464] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x4d)
      -- [  116.073224] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x4e)
      -- [  116.082905] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x4f)
      50: [  116.092670] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x50)
      -- [  116.102897] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x51)
      -- [  116.112603] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x52)
      -- [  116.122342] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x53)
      -- [  116.132027] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x54)
      -- [  116.141761] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x55)
      -- [  116.151440] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x56)
      -- [  116.161175] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x57)
      -- [  116.170853] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x58)
      -- [  116.180586] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x59)
      -- [  116.190322] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x5a)
      -- [  116.200080] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x5b)
      -- [  116.209757] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x5c)
      -- [  116.219525] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x5d)
      -- [  116.229204] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x5e)
      -- [  116.238971] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x5f)
      60: [  116.248676] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x60)
      -- [  116.258902] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x61)
      -- [  116.268579] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x62)
      -- [  116.278314] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x63)
      -- [  116.287964] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x64)
      -- [  116.297658] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x65)
      -- [  116.307341] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x66)
      -- [  116.317073] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x67)
      -- [  116.326823] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x68)
      -- [  116.336581] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x69)
      -- [  116.346327] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x6a)
      -- [  116.356087] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x6b)
      -- [  116.365767] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x6c)
      -- [  116.375534] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x6d)
      -- [  116.385214] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x6e)
      -- [  116.394960] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x6f)
      70: [  116.404662] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x70)
      -- [  116.414896] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x71)
      -- [  116.424572] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x72)
      -- [  116.434313] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x73)
      -- [  116.443985] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x74)
      -- [  116.453798] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x75)
      -- [  116.463480] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x76)
      -- [  116.473222] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x77)
        whycan晕哥 LV 9 最后由 whycan 编辑
        又一个被骗的,那个只是提示信息,不是错误信息。
        把loglevel的等级提高估计没了。
        W 1 条回复 最后回复 回复 引用 分享 0
          wxid_disxysjskla LV 5 @whycan 最后由 编辑
          @whycan 学到了,可以关掉这个打印吗
            whycan晕哥 LV 9 @wxid_disxysjskla 最后由 编辑
            @wxid_disxysjskla
            可以的,grep一下代码,暴力一点就直接注释起来。
            文明一点就看下是不是受什么宏控制,把宏定义开启或者关闭。
              wxid_disxysjskla LV 5 @whycan 最后由 wxid_disxysjskla 编辑
              @whycan
              kernel/linux-4.9/drivers/i2c/busses/i2c-sunxi.c L1973 加了一个判断,drop掉 0x48 错误
              if(ret != 0x48){
              	I2C_ERR("[i2c%d] incomplete xfer (status: 0x%x, dev addr: 0x%x)\n",
              			i2c->bus_num, ret, msgs->addr);
                wonderfullook LV 4 @wxid_disxysjskla 最后由 编辑
                @wxid_disxysjskla 建议用 && 来判断,避免丢失了别的错误信息
