    tina linux bug反馈
    • jinxiangwzh
      jinxiangwzh LV 7 最后由 编辑
      lichee/linux-4.9/drivers/media/platform/sunxi-vin/vin-video/vin_video.c
      static int vin_close(struct file *file)
      	struct vin_core *vinc = video_drvdata(file);
      	struct vin_md *vind = dev_get_drvdata(vinc->v4l2_dev->dev);
      	struct vin_vid_cap *cap = &vinc->vid_cap;
      	struct modules_config *module = &vind->modules[vinc->sensor_sel];
      	int valid_idx = module->sensors.valid_idx;
      	int ret;
      	if (!vin_busy(cap)) {
      		vin_warn("video%d have been closed!\n", vinc->id);
      	if (vin_streaming(cap))
      		vin_timer_del(vinc);
      #if 0  // cause  kernel NULL pointer
      	mutex_lock(&cap->vdev.entity.graph_obj.mdev->graph_mutex);
      	if (!cap->pipe.sd[VIN_IND_SENSOR]->entity.use_count) {
      		vin_err("%s is not used, video%d cannot be close!\n", cap->pipe.sd[VIN_IND_SENSOR]->name, vinc->id);
      		mutex_unlock(&cap->vdev.entity.graph_obj.mdev->graph_mutex);
      		return -1;
      	if (vin_streaming(cap)) {
      		clear_bit(VIN_STREAM, &cap->state);
      		vin_pipeline_call(vinc, set_stream, &cap->pipe, 0);
      		vb2_ioctl_streamoff(file, NULL, V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE);
      这个位置的代码会造成系统崩溃
      		return -1;
