    LVGL8的窗口切换 (转)
    GUI
    5451
        转载: LVGL8的窗口切换方式
        LVGL8实现两个窗口的切换方式:
        方法一:切换到窗口2时,删除窗口1的容器,这样可以删除窗口1下的所有子对象,这种方式适用于运存较小的设备
        方法二:显示窗口1之前给窗口2的容器设置LV_OBJ_FLAG_HIDDEN隐藏属性,显示窗口2之前给窗口1的容器设置LV_OBJ_FLAG_HIDDEN隐藏属性
        还是通过codeblock来模拟代码的运行,代码如下:
        #define HIDDEN_WIN  (0)
        static lv_obj_t *win1_contanier = NULL;
        static lv_obj_t *win2_contanier = NULL;
        static void win_btn_event_callback1(lv_event_t* event);
        static void win_btn_event_callback2(lv_event_t* event);
        static void show_button_win1()
            static lv_style_t obj_style;
            lv_style_reset(&obj_style);
            lv_style_init(&obj_style); // 初始化按钮样式
            lv_style_set_radius(&obj_style, 0); // 设置样式圆角弧度
            lv_obj_t * btn =NULL;
            win1_contanier = lv_obj_create(lv_scr_act());  // 基于屏幕创建一个和屏幕大小一样的容器win1_contanier
            if (win1_contanier != NULL)
                lv_obj_set_style_bg_color(win1_contanier, lv_palette_main(LV_PALETTE_RED), 0);
                lv_obj_set_size(win1_contanier, 800, 480);
                lv_obj_add_style(win1_contanier, &obj_style, 0);
                btn = lv_btn_create(win1_contanier);
                if (btn != NULL)
                    lv_obj_set_size(btn, 100, 50);
                    lv_obj_add_event_cb(btn, win_btn_event_callback1, LV_EVENT_ALL, NULL); // 给对象添加CLICK事件和事件处理回调函数
                    lv_obj_center(btn);
                    lv_obj_t *label = lv_label_create(btn); // 给按钮添加标签
                    if (label != NULL)
                        lv_label_set_text(label, "Button1"); // 设置标签文本
                        lv_obj_center(label); // 标签居中显示
        static void show_button_win2()
            win2_contanier = lv_obj_create(lv_scr_act()); // 基于屏幕创建一个和屏幕大小一样的容器win2_contanier
            if (win2_contanier != NULL)
                lv_obj_set_style_bg_color(win2_contanier, lv_palette_main(LV_PALETTE_BLUE), 0);
                lv_obj_set_size(win2_contanier, 800, 480);
                lv_obj_add_style(win2_contanier, &obj_style, 0);
                btn = lv_btn_create(win2_contanier);
                if (btn != NULL)
                    lv_obj_add_event_cb(btn, win_btn_event_callback2, LV_EVENT_ALL, NULL); // 给对象添加CLICK事件和事件处理回调函数
                    lv_obj_center(btn);
                    lv_obj_set_style_bg_color(btn, lv_palette_main(LV_PALETTE_RED), 0);
                    if (label != NULL)
                        lv_label_set_text(label, "Button2"); // 设置标签文本
            lv_event_code_t code = lv_event_get_code(event);
            if (code == LV_EVENT_CLICKED)
        #if HIDDEN_WIN
                // 给窗口1的容器添加隐藏属性,清除窗口2的隐藏属性
                lv_obj_add_flag(win1_contanier, LV_OBJ_FLAG_HIDDEN);
                lv_obj_clear_flag(win2_contanier, LV_OBJ_FLAG_HIDDEN);
        #else
                // 删除窗口1的win1_contanier容器,这样就可以把win1_contanier上的子对象全部删除,然后显示窗口2
                lv_obj_del(win1_contanier);
                show_button_win2();
        #if HIDDEN_WIN
                // 给窗口2的容器添加隐藏属性,清除窗口1的隐藏属性
                lv_obj_add_flag(win2_contanier, LV_OBJ_FLAG_HIDDEN);
                lv_obj_clear_flag(win1_contanier, LV_OBJ_FLAG_HIDDEN);
        #else
                // 删除窗口2的win2_contanier容器,这样就可以把win2_contanier上的子对象全部删除,然后显示窗口1
                lv_obj_del(win2_contanier);
                show_button_win1();
        void lv_win_switch_main()
            show_button_win1();
        #if HIDDEN_WIN
            show_button_win2();
            // 给窗口2的容器添加隐藏属性
        Y 1 条回复 最后回复 回复 引用 分享 0
          whycan晕哥 LV 9 最后由 whycan 编辑
          #include "lvgl/lvgl.h"
              lv_obj_t * btn = NULL;
              lv_obj_t * label1 = NULL;
                  label1 = lv_label_create(win1_contanier);
                  if (btn != NULL)
                      //lv_obj_set_pos(btn, 100, 100);
                      lv_obj_center(btn);
                      lv_obj_align_to(label1, btn, LV_ALIGN_OUT_TOP_LEFT, 0, -10);
                      lv_label_set_text(label1, "This is window1");
                      if (label != NULL)
              lv_obj_t * label2 = NULL;
                  label2 = lv_label_create(win1_contanier);
                  if (btn != NULL)
                      lv_obj_center(btn);
                      lv_obj_align_to(label2, btn, LV_ALIGN_OUT_TOP_LEFT, 0, -20);
                      lv_label_set_text(label2, "This is window2");
                      if (label != NULL)
          #if HIDDEN_WIN
          #else
                  show_button_win2();
          #if HIDDEN_WIN
          #else
                  show_button_win1();
              show_button_win1();
          #if HIDDEN_WIN
              show_button_win2();
              // 给窗口2的容器添加隐藏属性
          添加 label 后的代码
          参考 LVGL系列(四)概述 之 位置、尺寸和布局
          J 1 条回复 最后回复 回复 引用 分享 0
            jeffdev LV 8 @whycan 最后由 编辑
            @whycan 如果窗口顶层对象是lv_obj_create(NULL)创建的对象,直接用lv_scr_load_anim和lv_scr_load加载,lv_scr_load_anim可以指定是否删除原来的窗口对象,lv_scr_load不删除原来的。
              Yuwei123456 LV 4 @whycan 最后由 编辑
              @whycan
