    V536 Tina Linux camerademo运行报错
    • jinxiangwzh
      jinxiangwzh LV 7 最后由 编辑
      我ISP已经关闭,但是还是打印ISP的错误log,log截取如下,主要是两个
      [ISP_WARN]open /mnt/isp0_ctx_saved.bin failed!!!
      和
      [ISP_ERR] func: isp_set_table1_map, line: 223,VIDIOC_VIN_ISP_TABLE_MAPPING error!
      麻烦问一下是怎么回事?
      [ISP]register sensor entity is imx317_mipi
      [ISP]open isp device[0] success!
      [ISP]find imx317_mipi_3840_2160_30_0 isp config
      [CAMERA] capture num is [0]
      [CAMERA_DEBUG]*****DQBUF[0] FINISH*****
      [CAMERA_PROMPT] the time interval from the start to the first frame is 22 ms
      [CAMERA_DEBUG] the interval of two frames is 0 ms
      write file:/tmp/source_YUV422P_1.yuv
      [ISP_ERR] func: isp_set_table2_map, line: 234,VIDIOC_VIN_ISP_TABLE_MAPPING error!
      [CAMERA_DEBUG]************QBUF[0] FINISH**************
      [CAMERA] capture num is [1]
      [CAMERA_DEBUG]*****DQBUF[1] FINISH*****
      [CAMERA_DEBUG] the interval of two frames is 100 ms
      write file:/tmp/source_YUV422P_2.yuv
      [CAMERA_DEBUG]************QBUF[1] FINISH**************
      [CAMERA] capture num is [2]
      [CAMERA_DEBUG]*****DQBUF[2] FINISH*****
      write file:/tmp/source_YUV422P_3.yuv
      [CAMERA_DEBUG]************QBUF[2] FINISH**************
