    V831 用 eMMC 启动出错,但是TF卡正常,请问 怎么回事呢?
    v831 emmc
    • U
      ubuntu LV 7 最后由 编辑
      [35]HELLO! BOOT0 is starting!
      [38]BOOT0 commit : e3b2a9e
      [41]board init start
      [43]set pll start
      [45]set pll end
      [47][pmu]: bus read error
      [49][pmu]: bus read error
      [52]board init ok
      [54]chip id check OK
      [56]DRAM BOOT DRIVE INFO: V0.41
      [59]DRAM CLK = 528 MHz
      [61]DRAM Type = 2 (2:DDR2,3:DDR3)
      [64]DRAMC read ODT  off.
      [67]DRAM ODT off.
      [69]DRAM SIZE =64 M
      [75]DRAM simple test OK.
      [77]rtc standby flag is 0x0, super standby flag is 0x0
      [82]dram size =64
      [85]card no is 0
      [86]sdcard 0 line count 4
      [89][mmc]: mmc driver ver 2020-01-08 17:05
      [93][mmc]: sdc0 spd mode error, 2
      [96][mmc]: set f_max to 50M, set f_max_ddr to 25M
      [101][mmc]: mmc 0 bias 0
      [109][mmc]: Wrong media type 0x0
      [112][mmc]: ***Try SD card 0***
      [116][mmc]: mmc 0 cmd 8 timeout, err 100
      [119][mmc]: mmc 0 cmd 8 err 100
      [122][mmc]: mmc 0 send if cond failed
      [127][mmc]: mmc 0 cmd 55 timeout, err 100
      [131][mmc]: mmc 0 cmd 55 err 100
      [134][mmc]: mmc 0 send app cmd failed
      [137][mmc]: ***Try MMC card 0***
      [153][mmc]: wrong bus width(8) for current speed mode
      [158][mmc]: switch bus width fail
      [161][mmc]: switch to SDR speed mode failed
      [165][mmc]: mmc 0 Change speed mode failed
      [169][mmc]: ***SD/MMC 0 init error!!!***
      [173][mmc]: mmc 0 register failed
      [176]Loading boot-pkg fail(error=2)
      CCC
      U 1 条回复 最后回复 回复 引用 分享 0
      • U
        ubuntu LV 7 @ubuntu 最后由 编辑
        @ubuntu
        TF卡正常, 是这样的:
        [258]HELLO! BOOT0 is starting!
        [261]BOOT0 commit : e3b2a9e
        [264]board init start
        [266]set pll start
        [269]set pll end
        [270][pmu]: bus read error
        [273][pmu]: bus read error
        [276]board init ok
        [278]chip id check OK
        [280]DRAM BOOT DRIVE INFO: V0.41
        [283]DRAM CLK = 528 MHz
        [285]DRAM Type = 2 (2:DDR2,3:DDR3)
        [288]DRAMC read ODT  off.
        [291]DRAM ODT off.
        [293]DRAM SIZE =64 M
        [299]DRAM simple test OK.
        [302]rtc standby flag is 0x0, super standby flag is 0x0
        [307]dram size =64
        [310]card no is 0
        [311]sdcard 0 line count 4
        [314][mmc]: mmc driver ver 2020-01-08 17:05
        [318][mmc]: sdc0 spd mode error, 2
        [321][mmc]: set f_max to 50M, set f_max_ddr to 25M
        [326][mmc]: mmc 0 bias 0
        [334][mmc]: Wrong media type 0x0
        [337][mmc]: ***Try SD card 0***
        [356][mmc]: HSSDR52/SDR25 4 bit
        [359][mmc]: 50000000 Hz
        [362][mmc]: 118 MB
        [363][mmc]: ***SD/MMC 0 init OK!!!***
        [418]Loading boot-pkg Succeed(index=0).
        [422]Entry_name        = optee
        [425]Entry_name        = u-boot
        [431]Entry_name        = dtb
        [435]Jump to second Boot.
        MESSAGE: [0x0] TEE-CORE: OP-TEE version: sun8iw19p1_v0.6.0-14-gf6954e7 #1 2019年 11月 21日 星期四 01:34:42 UTC arm
        ERROR:   [0x0] TEE-CORE:platform_standby_fdt_parse:126: no pmu node
        ERROR:   [0x0] TEE-CORE:sunxi_twi_parse_from_dt:84: no pmu node
        U-Boot 2018.05 (May 10 2022 - 19:02:33 +0800) Allwinner Technology
        [00.505]CPU:   Allwinner Family
        [00.508]Model: sun8iw19
        I2C:   ready
        [00.512]DRAM:  64 MiB
        [00.515]Relocation Offset is: f9f46000
        [00.537]secure enable bit: 0
        [00.539]pmu_axp152_probe pmic_bus_read fail
        [00.543]pmu_axp2101_probe pmic_bus_read fail
        [00.547]bmu_axp152_probe pmic_bus_read fail
        [00.551]bmu_axp2101_probe pmic_bus_read fail
        [00.555]CPU=816 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=132Mhz
        [00.561]gic: sec monitor mode
        [00.564]flash init start
        [00.566]workmode = 0,storage type = 1
        [00.570]MMC:     0
        [00.571]get mem for descripter OK !
        card_caps:0x3000000a
        host_caps:0x3000003f
        [00.819]sunxi flash init ok
        [00.823]Loading Environment from SUNXI_FLASH... OK
        [00.842]update dts
        root_partition is rootfs
        set root to /dev/mmcblk0p4
        [00.854]update part info
        [00.862]update bootcmd
        [00.864]No ethernet found.
        ## Booting kernel from Legacy Image at 45000000 ...
           Image Name:   ARM OpenWrt Linux-4.9.118
           Image Type:   ARM Linux Kernel Image (uncompressed)
           Data Size:    2817392 Bytes = 2.7 MiB
           Load Address: 40008000
           Entry Point:  40008000
        [01.253]Starting kernel ...
        [01.256]mmc 2 not find, so not exit
        [    0.000000] Linux version 4.9.118 (whycan@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #74 PREEMPT Tue May 17 15:23:54 UTC 2022
        [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
        [    0.000000] OF: fdt:Machine model: sun8iw19
        [    0.000000] ion_mem_reserve: err format for ion reserve list!
        [    0.000000] cma: Reserved 4 MiB at 0x43c00000
        [    0.000000] Memory policy: Data cache writeback
        [    0.000000] free_area_init_node: node 0, pgdat c048f820, node_mem_map c3b77000
        [    0.000000]   Normal zone: 128 pages used for memmap
        [    0.000000]   Normal zone: 16384 pages, LIFO batch:3
        [    0.000000] CPU: All CPU(s) started in SVC mode.
        [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
        [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 rootwait init=/pseudo_init rdinit=/rdinit partitions=boot-res@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:rootfs_data@mmcblk0p5:UDISK@mmcblk0p6 cma=4M mac_addr= wifi_mac= bt_mac= selinux= specialstr= coherent_pool=16K ion_carveout_list= androidboot.mode=normal androidboot.hardware=sun8iw19p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(05/10/2022-19:02:33) mbr_offset=1032192 bootreason=unknow
        [    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
        [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
        [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
        [    0.000000] Memory: 55656K/65536K available (2962K kernel code, 224K rwdata, 1168K rodata, 132K init, 127K bss, 5784K reserved, 4096K cma-reserved)
        [    0.000000]     vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
        [    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
        [    0.000000]     modules : 0xbf800000 - 0xc0000000   (   8 MB)
        [    0.000000]       .text : 0xc0008000 - 0xc02eca98   (2963 kB)
        [    0.000000]       .init : 0xc0437000 - 0xc0458000   ( 132 kB)
        [    0.000000]       .data : 0xc0458000 - 0xc0490358   ( 225 kB)
        [    0.000000]        .bss : 0xc0490358 - 0xc04b0000   ( 128 kB)
        [    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
        [    0.000022] Switching to timer-based delay loop, resolution 41ns
        [    0.000163] Console: colour dummy device 80x30
        [    0.000191] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
        [    0.000206] pid_max: default: 32768 minimum: 301
        [    0.000381] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
        [    0.000393] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
        [    0.000998] CPU: Testing write buffer coherency: ok
        [    0.001278] Setting up static identity map for 0x400081c0 - 0x4000820c
        [    0.002711] devtmpfs: initialized
        [    0.031754] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
        [    0.031969] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.031995] futex hash table entries: 256 (order: -1, 3072 bytes)
        [    0.032336] atomic64_test: passed
        [    0.032350] pinctrl core: initialized pinctrl subsystem
        [    0.033235] NET: Registered protocol family 16
        [    0.034573] DMA: preallocated 16 KiB pool for atomic coherent allocations
        [    0.036053] dump_class_init,857, success
        [    0.037355] sunxi iommu: irq = 23
        [    0.041181] sun8iw19p1-r-pinctrl r_pio: initialized sunXi PIO driver
        [    0.056225] use hosc , set rate 1000000
        [    0.056256] sun8iw19p1-pinctrl pio: initialized sunXi PIO driver
        [    0.057936] iommu: Adding device 1c0e000.ve to group 0
        [    0.058644] iommu: Adding device 2300000.eise to group 0
        [    0.062173] iommu: Adding device 1000000.disp to group 0
        [    0.062988] iommu: Adding device 1480000.g2d to group 0
        [    0.063366] iommu: Adding device 2400000.nna to group 0
        [    0.077017] pwm module init!
        [    0.080614] SCSI subsystem initialized
        [    0.080961] usbcore: registered new interface driver usbfs
        [    0.081047] usbcore: registered new interface driver hub
        [    0.081173] usbcore: registered new device driver usb
        [    0.081270] sunxi_i2c_adap_init()2534 - init
        [    0.081555] media: Linux media interface: v0.10
        [    0.081625] Linux video capture interface: v2.00
        [    0.082300] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
        [    0.082476] ion_parse_dt_heap_common: id 1 type 1 name sys_contig align 1000
        [    0.082600] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
        [    0.082989] Advanced Linux Sound Architecture Driver Initialized.
        [    0.085154] G2D: rcq version initialized.major:251
        [    0.085915] clocksource: Switched to clocksource arch_sys_counter
        [    0.094522] udc_init,0
        [    0.094703] NET: Registered protocol family 2
        [    0.095494] TCP established hash table entries: 16 (order: -6, 64 bytes)
        [    0.095516] TCP bind hash table entries: 16 (order: -6, 64 bytes)
        [    0.095526] TCP: Hash tables configured (established 16 bind 16)
        [    0.095593] UDP hash table entries: 256 (order: 0, 4096 bytes)
        [    0.095613] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
        [    0.095791] NET: Registered protocol family 1
        [    0.097645] workingset: timestamp_bits=30 max_order=14 bucket_order=0
        [    0.106742] squashfs: version 4.0 (2009/01/31) Phillip Lougher
        [    0.107065] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
        [    0.109334] NET: Registered protocol family 38
        [    0.109379] io scheduler noop registered
        [    0.109388] io scheduler deadline registered
        [    0.109658] io scheduler cfq registered (default)
        [    0.110392] [DISP]disp_module_init
        [    0.142078] [DISP] Fb_copy_boot_fb,line:1503:
        [    0.142093] no boot_fb0
        [    0.147439] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147463] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147478] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147492] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147506] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147520] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147534] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147548] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147564] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147580] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147595] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.147611] sun8iw19p1-pinctrl pio: expect_func as:rgb8, but muxsel(2) is func:lcd0
        [    0.148370] [DISP]disp_module_init finish
        [    0.149533] uart uart0: get regulator failed
        [    0.149561] uart0 supply uart not found, using dummy regulator
        [    0.149755] uart uart0: uart0 error to get fifo size property
        [    0.149816] uart0: ttyS0 at MMIO 0x5000000 (irq = 294, base_baud = 1500000) is a SUNXI
        [    0.149845] sw_console_setup()1830 - console setup baud 115200 parity n bits 8, flow n
        [    0.281581] [ST7789V LCD INFO] LINE:0208-->LCD_panel_init:
        [    0.281591] [ST7789V LCD INFO] LINE:0225-->lcd_panel_st7789v_init:
        [    0.781687] [DISP] disp_device_attached_and_enable,line:221:
        [    0.781687] attached ok, mgr0<-->dev0
        [    0.781699] [DISP] disp_device_attached_and_enable,line:224:
        [    0.781700] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
        [    1.048394] console [ttyS0] enabled
        [    1.052949] uart uart1: get regulator failed
        [    1.057812] uart1 supply uart not found, using dummy regulator
        [    1.064598] uart uart1: uart1 error to get fifo size property
        [    1.071150] uart1: ttyS1 at MMIO 0x5000400 (irq = 295, base_baud = 1500000) is a SUNXI
        [    1.080707] uart uart2: get regulator failed
        [    1.085529] uart2 supply uart not found, using dummy regulator
        [    1.092304] uart uart2: uart2 error to get fifo size property
        [    1.098853] uart2: ttyS2 at MMIO 0x5000800 (irq = 296, base_baud = 1500000) is a SUNXI
        [    1.108458] misc dump reg init
        [    1.113066] libphy: Fixed MDIO Bus: probed
        [    1.117997] sun8iw19p1-pinctrl pio: expect_func as:gmac0, but muxsel(5) is func:ephy
        [    1.127012] sun8iw19p1-pinctrl pio: pin PD1 already requested by soc@03000000:lcd0@01c0c000; cannot claim for 5020000.eth
        [    1.139368] sun8iw19p1-pinctrl pio: pin-97 (5020000.eth) status -22
        [    1.146431] sun8iw19p1-pinctrl pio: could not request pin 97 (PD1) from group PD1  on device pio
        [    1.156326] sunxi-gmac 5020000.eth: Error applying setting, reverse things back
        [    1.164584] sunxi-gmac: probe of 5020000.eth failed with error -22
        [    1.171671] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
        [    1.179241] get drv_vbus is fail, 84
        [    1.183262] get ehci0-controller, regulator_io is no nocare
        [    1.189559] get ehci0-controller wakeup-source is fail.
        [    1.195593] sunxi ehci0-controller don't init wakeup source
        [    1.201896] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xc04aaef0, 0x:c4883000, irq_no:12a
        [    1.214087] sunxi-ehci 5101000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
        [    1.224317] sunxi-ehci 5101000.ehci0-controller: new USB bus registered, assigned bus number 1
        [    1.234209] sunxi-ehci 5101000.ehci0-controller: irq 298, io mem 0xc3776400
        [    1.265948] sunxi-ehci 5101000.ehci0-controller: USB 0.0 started, EHCI 1.00
        [    1.274687] hub 1-0:1.0: USB hub found
        [    1.279015] hub 1-0:1.0: 1 port detected
        [    1.284003] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
        [    1.291289] get drv_vbus is fail, 84
        [    1.295311] get ohci0-controller, regulator_io is no nocare
        [    1.301635] get ohci0-controller wakeup-source is fail.
        [    1.307684] sunxi ohci0-controller don't init wakeup source
        [    1.314035] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xc04aa6a0
        [    1.323800] sunxi-ohci 5101000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
        [    1.333640] sunxi-ohci 5101000.ohci0-controller: new USB bus registered, assigned bus number 2
        [    1.343352] sunxi-ohci 5101000.ohci0-controller: irq 299, io mem 0xc3776800
        [    1.420808] hub 2-0:1.0: USB hub found
        [    1.425066] hub 2-0:1.0: 1 port detected
        [    1.430189] usbcore: registered new interface driver uas
        [    1.436365] usbcore: registered new interface driver usb-storage
        [    1.443169] usbcore: registered new interface driver ums-alauda
        [    1.449890] usbcore: registered new interface driver ums-cypress
        [    1.456715] usbcore: registered new interface driver ums-datafab
        [    1.463530] usbcore: registered new interface driver ums_eneub6250
        [    1.470546] usbcore: registered new interface driver ums-freecom
        [    1.477331] usbcore: registered new interface driver ums-isd200
        [    1.484044] usbcore: registered new interface driver ums-jumpshot
        [    1.490964] usbcore: registered new interface driver ums-karma
        [    1.497554] usbcore: registered new interface driver ums-onetouch
        [    1.504480] usbcore: registered new interface driver ums-realtek
        [    1.511267] usbcore: registered new interface driver ums-sddr09
        [    1.517955] usbcore: registered new interface driver ums-sddr55
        [    1.524655] usbcore: registered new interface driver ums-usbat
        [    1.531335] usb_serial_number:20080411
        [    1.536400] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
        [    1.543294] sunxi-rtc rtc: RTC enabled
        [    1.547809] i2c /dev entries driver
        [    1.551769] sunxi cedar version 0.1
        [    1.555788] VE: install start!!!
        [    1.555788]
        [    1.561238] cedar_ve: cedar-ve the get irq is 291
        [    1.566633] VE: line 1811 set the sram data
        [    1.566633]
        [    1.573291] VE: ve_debug_proc_info:c04ad0f8, data:c378c000, lock:c04ad180
        [    1.573291]
        [    1.582630] VE: install end!!!
        [    1.582630]
        [    1.587962] google_vp9: sunxi google vp9 version 0.1
        [    1.594167] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
        [    1.604115] sun8iw19p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
        [    1.613471] sun8iw19p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
        [    1.622793] sun8iw19p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
        [    1.632104] sun8iw19p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
        [    1.641414] sun8iw19p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
        [    1.650723] sun8iw19p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
        [    1.660346] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.37 2019-12-4 9:48)
        [    1.669191] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
        [    1.674537] sunxi-mmc sdc0: No vmmc regulator found
        [    1.680051] sunxi-mmc sdc0: No vqmmc regulator found
        [    1.685632] sunxi-mmc sdc0: No vdmmc regulator found
        [    1.691230] sunxi-mmc sdc0: No vd33sw regulator found
        [    1.696920] sunxi-mmc sdc0: No vd18sw regulator found
        [    1.702594] sunxi-mmc sdc0: No vq33sw regulator found
        [    1.708283] sunxi-mmc sdc0: No vq18sw regulator found
        [    1.714485] sunxi-mmc sdc0: set host busy
        [    1.719098] mmc:failed to get gpios
        [    1.723043] sunxi-mmc sdc0: min-frequency:100000
        [    1.728433] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    1.738760] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
        [    1.765946] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    1.805948] sunxi-mmc sdc0: detmode:alway in(non removable)
        [    1.805974] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    1.814355] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    1.837330] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    1.848382] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.37 2019-12-4 9:48)
        [    1.848526] sunxi-mmc sdc1: No vmmc regulator found
        [    1.848532] sunxi-mmc sdc1: No vqmmc regulator found
        [    1.848538] sunxi-mmc sdc1: No vdmmc regulator found
        [    1.848543] sunxi-mmc sdc1: No vd33sw regulator found
        [    1.848548] sunxi-mmc sdc1: No vd18sw regulator found
        [    1.848554] sunxi-mmc sdc1: No vq33sw regulator found
        [    1.848559] sunxi-mmc sdc1: No vq18sw regulator found
        [    1.848573] sunxi-mmc sdc1: Cann't get uart0 pinstate,check if needed
        [    1.849034] sunxi-mmc sdc1: set host busy
        [    1.849100] mmc:failed to get gpios
        [    1.849302] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    1.849338] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
        [    1.880471] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    1.909410] sunxi-mmc sdc1: detmode:manually by software
        [    1.910305] KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK
        [    1.910519] MMMMMMMMMMMMMMMMMMMM
        [    1.910523]  NNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
        [    1.910595] ledtrig-cpu: registered to indicate activity on CPUs
        [    1.976570] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    1.988616] usbcore: registered new interface driver usbhid
        [    1.988619] usbhid: USB HID core driver
        [    1.988856] mostcore: init()
        [    1.990050] --->sunxi_daudio_dev_probe<--- strat.
        [    1.990194] sunxi-daudio daudio0: regulator missing or invalid
        [    1.990318] --->sunxi_daudio_dev_probe<--- end.
        [    1.991240] NET: Registered protocol family 17
        [    1.991291] NET: Registered protocol family 15
        [    1.991944] Registering SWP/SWPB emulation handler
        [    2.045614] get det_vbus is fail, 84
        [    2.049703] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
        [    2.055755] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
        [    2.055782] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.063882] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.075739] sunxi-mmc sdc1: smc 1 p1 err, cmd 8, RTO !!
        [    2.086535] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
        [    2.092446] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
        [    2.098362] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
        [    2.104264] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
        [    2.110189] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
        [    2.116102] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
        [    2.122111] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
        [    2.128121] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
        [    2.128165] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    2.134232] sunxi-mmc sdc1: smc 1 p1 err, cmd 1, RTO !!
        [    2.134261] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [    2.152168] mmc0: host does not support reading read-only switch, assuming write-enable
        [    2.158097] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [    2.158174] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [    2.158316] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
        [    2.158374] mmc0: new high speed SD card at address 1388
        [    2.169378] mmcblk0: mmc0:1388 Stora 119 MiB
        [    2.190150]  mmcblk0: p1 p2 p3 p4 p5 p6
        [    2.228929] get id is fail, 84
        [    2.233001] sunxi-rtc rtc: setting system clock to 1970-01-01 00:03:07 UTC (187)
        [    2.242245] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
        [    2.251659] snddaudio snddaudio0: snd-soc-dummy-dai <-> daudio0 mapping ok
        [    2.260472] ALSA device list:
        [    2.263812]   #0: snddaudio0
        [    2.271871] VFS: Mounted root (squashfs filesystem) readonly on device 179:4.
        [    2.282864] devtmpfs: mounted
        [    2.286571] Freeing unused kernel memory: 132K
        [    2.291569] This architecture does not have kernel memory protection.
        [    2.490554] EXT4-fs (mmcblk0p5): recovery complete
        [    2.496110] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
        Starting syslogd: OK
        Starting klogd: OK
        Running sysctl: OK
        Populating /dev using udev: [    2.744049] udevd[150]: starting version 3.2.9
        [    2.754932] random: udevd: uninitialized urandom read (16 bytes read)
        [    2.762996] random: udevd: uninitialized urandom read (16 bytes read)
        [    2.770741] random: udevd: uninitialized urandom read (16 bytes read)
        [    2.806837] udevd[151]: starting eudev-3.2.9
        done
        Initializing random number generator: OK
        Saving random seed: OK
        Starting network: OK
        Starting upmpdcli: OK
          YterAA LV 7 最后由 编辑
          没扫到卡
          1. eMMC 的bus宽度应该是4,v831貌似没有8bit的 SDC 接口
          2. eMMC的rst、ds是否正确处理
