    d1h, docker镜像编译报错
      ztcontrol LV 4 最后由 编辑
      代码什么都没改呢, 刚pull下来, 直接make报错, make clean之后 make -j1也报错, 这是最后报错的地方, 大神们帮看看什么原因,
      我需要改什么?
      /home/nihao/sdk/tina-d1-open_new/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/bin/../lib/gcc/riscv64-unknown-linux-gnu/8.1.0/../../../../riscv64-unknown-linux-gnu/bin/ld: /home/nihao/sdk/tina-d1-open_new/out/d1-nezha/compile_dir/target/alsa-plugins-1.1.4/rate-lavc/rate_lavcrate.c:187: undefined reference to `av_resample'
      /home/nihao/sdk/tina-d1-open_new/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/bin/../lib/gcc/riscv64-unknown-linux-gnu/8.1.0/../../../../riscv64-unknown-linux-gnu/bin/ld: .libs/rate_lavcrate.o: in function `pcm_src_free':
      /home/nihao/sdk/tina-d1-open_new/out/d1-nezha/compile_dir/target/alsa-plugins-1.1.4/rate-lavc/rate_lavcrate.c:51: undefined reference to `av_resample_close'
      /home/nihao/sdk/tina-d1-open_new/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/bin/../lib/gcc/riscv64-unknown-linux-gnu/8.1.0/../../../../riscv64-unknown-linux-gnu/bin/ld: .libs/rate_lavcrate.o: in function `pcm_src_init':
      /home/nihao/sdk/tina-d1-open_new/out/d1-nezha/compile_dir/target/alsa-plugins-1.1.4/rate-lavc/rate_lavcrate.c:91: undefined reference to `av_resample_init'
      collect2: error: ld returned 1 exit status
      make[6]: *** [Makefile:419: libasound_module_rate_lavcrate.la] Error 1
      make[6]: Leaving directory '/home/nihao/sdk/tina-d1-open_new/out/d1-nezha/compile_dir/target/alsa-plugins-1.1.4/rate-lavc'
      make[5]: *** [Makefile:431: all-recursive] Error 1
      make[5]: Leaving directory '/home/nihao/sdk/tina-d1-open_new/out/d1-nezha/compile_dir/target/alsa-plugins-1.1.4'
      make[4]: *** [Makefile:363: all] Error 2
      make[4]: Leaving directory '/home/nihao/sdk/tina-d1-open_new/out/d1-nezha/compile_dir/target/alsa-plugins-1.1.4'
      make[3]: *** [Makefile:90: /home/nihao/sdk/tina-d1-open_new/out/d1-nezha/compile_dir/target/alsa-plugins-1.1.4/.built] Error 2
      make[3]: Leaving directory '/home/nihao/sdk/tina-d1-open_new/package/libs/alsa-plugins'
      make[2]: *** [package/Makefile:193: package/libs/alsa-plugins/compile] Error 2
      make[2]: Leaving directory '/home/nihao/sdk/tina-d1-open_new'
      make[1]: *** [package/Makefile:189: /home/nihao/sdk/tina-d1-open_new/out/d1-nezha/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/home/nihao/sdk/tina-d1-open_new'
      make: *** [/home/nihao/sdk/tina-d1-open_new/build/toplevel.mk:306: world] Error 2
      [2]+  Done                    $T/tools/build/buildserver --path $T
      #### make failed to build some targets (01:05:40 (hh:mm:ss)) ####
        YterAA LV 7 最后由 编辑
        m menuconfig 关闭 alsa-plugins
