    芒果的tiny200s板子 gt911电容屏不能中断,一筹莫展中
    f1c200s gt911
    6024
      使用的是这个SDK: buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 * 已支持DVP摄像头 *
      i2c 检测 gt911 正常
      [    4.444256] Goodix-TS 0-0014: 0-0014 supply AVDD28 not found, using dummy regulator
      [    4.452376] Goodix-TS 0-0014: 0-0014 supply VDDIO not found, using dummy regulator
      [    4.460527] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
      [    4.739056] Goodix-TS 0-0014: ID 911, version: 1060
      [    4.803438] input: Goodix Capacitive TouchScreen as /devices/platform/soc/1c27000.i2c/i2c-0/0-0014/input/input0
      [    5.560878] urandom_read: 1 callbacks suppressed
      [    5.560903] random: dd: uninitialized urandom read (512 bytes read)
      [    5.838436] file system registered
      [    5.984015] read descriptors
      [    5.987311] read strings
      evtest不听使唤:
      # evtest /dev/input/event0
      Input driver version is 1.0.1
      Input device ID: bus 0x18 vendor 0x416 product 0x38f version 0x1060
      Input device name: "Goodix Capacitive TouchScreen"
      Supported events:
        Event type 0 (EV_SYN)
        Event type 1 (EV_KEY)
          Event code 125 (KEY_LEFTMETA)
          Event code 330 (BTN_TOUCH)
        Event type 3 (EV_ABS)
          Event code 0 (ABS_X)
            Value      0
            Min        0
            Max      799
          Event code 1 (ABS_Y)
            Value      0
            Min        0
            Max      479
          Event code 47 (ABS_MT_SLOT)
            Value      0
            Min        0
            Max        4
          Event code 48 (ABS_MT_TOUCH_MAJOR)
            Value      0
            Min        0
            Max      255
          Event code 50 (ABS_MT_WIDTH_MAJOR)
            Value      0
            Min        0
            Max      255
          Event code 53 (ABS_MT_POSITION_X)
            Value      0
            Min        0
            Max      799
          Event code 54 (ABS_MT_POSITION_Y)
            Value      0
            Min        0
            Max      479
          Event code 57 (ABS_MT_TRACKING_ID)
            Value      0
            Min        0
            Max    65535
      Properties:
        Property type 1 (INPUT_PROP_DIRECT)
      Testing ... (interrupt to exit)
      gt911 中断次数0:
      # cat /proc/interrupts
                 CPU0
       16:       4309  sun4i_irq  13 Edge      timer@1c20c00
       17:          0  sun4i_irq  18 Edge      1c02000.dma-controller
       18:          3  sun4i_irq  10 Edge      sun6i-spi
       19:        316  sun4i_irq  29 Edge      1c0c000.lcd-controller
       20:          0  sun4i_irq  34 Edge      cedar_dev
       21:       3970  sun4i_irq  23 Edge      sunxi-mmc
       22:          1  sun4i_irq  26 Edge      musb-hdrc.1.auto
       28:        839  sun4i_irq   2 Edge      ttyS0
       29:       2261  sun4i_irq   7 Edge      mv64xxx_i2c
       76:         0  sunxi_pio_edge  44 Edge      gt911
      Err:          0
        我记得以前是正常的
        三块新屏都是一样的问题,用万用表量了一下,触摸的时候屏的INT引脚确实不能下拉.
          刚刚有朋友提醒我,把中断腿设置为io模式,看能拉高拉低,
          测试 PE12 输出高低电平:
          echo $((4*32+12))
          echo 140 > /sys/class/gpio/export
          echo out > /sys/class/gpio/gpio140/direction
          echo 0 > /sys/class/gpio/gpio140/value
          然后果然不能拉高拉低,难道板子坏了吗?
            还好板子多,换块板子再试一试,可以拉高拉低了.
            接着测试一下中断.
              触摸完全OK:
              Supported events:
                    Value      0
                    Min        0
                    Max      799
                    Value      0
                    Min        0
                    Max      479
                    Value      0
                    Min        0
                    Max        4
                    Value      0
                    Min        0
                    Max      255
                    Value      0
                    Min        0
                    Max      255
                    Value      0
                    Min        0
                    Max      799
                    Value      0
                    Min        0
                    Max      479
                    Value      0
                    Min        0
                    Max    65535
              Properties:
              Event: time 11.891769, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 0
              Event: time 11.891769, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 435
              Event: time 11.891769, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 260
              Event: time 11.891769, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 29
              Event: time 11.891769, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 29
              Event: time 11.891769, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 11.891769, type 3 (EV_ABS), code 0 (ABS_X), value 435
              Event: time 11.891769, type 3 (EV_ABS), code 1 (ABS_Y), value 260
              Event: time 11.891769, -------------- SYN_REPORT ------------
              Event: time 11.943724, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 11.943724, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 11.943724, -------------- SYN_REPORT ------------
              Event: time 12.207591, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 1
              Event: time 12.207591, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 432
              Event: time 12.207591, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 238
              Event: time 12.207591, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 34
              Event: time 12.207591, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 34
              Event: time 12.207591, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 12.207591, type 3 (EV_ABS), code 0 (ABS_X), value 432
              Event: time 12.207591, type 3 (EV_ABS), code 1 (ABS_Y), value 238
              Event: time 12.207591, -------------- SYN_REPORT ------------
              Event: time 12.291078, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 12.291078, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 12.291078, -------------- SYN_REPORT ------------
              [   31.842433] vcc3v0: disabling
              [   31.845438] vcc5v0: disabling
              Event: time 94.686680, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 2
              Event: time 94.686680, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 295
              Event: time 94.686680, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 194
              Event: time 94.686680, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 21
              Event: time 94.686680, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 21
              Event: time 94.686680, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 94.686680, type 3 (EV_ABS), code 0 (ABS_X), value 295
              Event: time 94.686680, type 3 (EV_ABS), code 1 (ABS_Y), value 194
              Event: time 94.686680, -------------- SYN_REPORT ------------
              Event: time 94.717502, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 94.717502, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 94.717502, -------------- SYN_REPORT ------------
              Event: time 94.833846, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 3
              Event: time 94.833846, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 293
              Event: time 94.833846, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 209
              Event: time 94.833846, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 37
              Event: time 94.833846, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 37
              Event: time 94.833846, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 94.833846, type 3 (EV_ABS), code 0 (ABS_X), value 293
              Event: time 94.833846, type 3 (EV_ABS), code 1 (ABS_Y), value 209
              Event: time 94.833846, -------------- SYN_REPORT ------------
              [   94.919685] random: crng init done
              Event: time 94.920955, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 94.920955, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 94.920955, -------------- SYN_REPORT ------------
              Event: time 95.044346, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 4
              Event: time 95.044346, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 295
              Event: time 95.044346, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 211
              Event: time 95.044346, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 28
              Event: time 95.044346, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 28
              Event: time 95.044346, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 95.044346, type 3 (EV_ABS), code 0 (ABS_X), value 295
              Event: time 95.044346, type 3 (EV_ABS), code 1 (ABS_Y), value 211
              Event: time 95.044346, -------------- SYN_REPORT ------------
              Event: time 95.085689, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 95.085689, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 95.085689, -------------- SYN_REPORT ------------
              Event: time 95.233558, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 5
              Event: time 95.233558, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 296
              Event: time 95.233558, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 230
              Event: time 95.233558, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 14
              Event: time 95.233558, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 14
              Event: time 95.233558, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 95.233558, type 3 (EV_ABS), code 0 (ABS_X), value 296
              Event: time 95.233558, type 3 (EV_ABS), code 1 (ABS_Y), value 230
              Event: time 95.233558, -------------- SYN_REPORT ------------
              Event: time 95.264502, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 95.264502, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 95.264502, -------------- SYN_REPORT ------------
              Event: time 97.795859, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 6
              Event: time 97.795859, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 754
              Event: time 97.795859, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 9
              Event: time 97.795859, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 31
              Event: time 97.795859, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 31
              Event: time 97.795859, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 97.795859, type 3 (EV_ABS), code 0 (ABS_X), value 754
              Event: time 97.795859, type 3 (EV_ABS), code 1 (ABS_Y), value 9
              Event: time 97.795859, -------------- SYN_REPORT ------------
              Event: time 97.879491, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 97.879491, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 97.879491, -------------- SYN_REPORT ------------
              Event: time 98.290574, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 7
              Event: time 98.290574, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 744
              Event: time 98.290574, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 6
              Event: time 98.290574, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 28
              Event: time 98.290574, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 28
              Event: time 98.290574, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 98.290574, type 3 (EV_ABS), code 0 (ABS_X), value 744
              Event: time 98.290574, type 3 (EV_ABS), code 1 (ABS_Y), value 6
              Event: time 98.290574, -------------- SYN_REPORT ------------
              Event: time 98.384787, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 98.384787, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 98.384787, -------------- SYN_REPORT ------------
              Event: time 99.332530, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 8
              Event: time 99.332530, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 750
              Event: time 99.332530, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 451
              Event: time 99.332530, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 43
              Event: time 99.332530, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 43
              Event: time 99.332530, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 99.332530, type 3 (EV_ABS), code 0 (ABS_X), value 750
              Event: time 99.332530, type 3 (EV_ABS), code 1 (ABS_Y), value 451
              Event: time 99.332530, -------------- SYN_REPORT ------------
              Event: time 99.405632, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 99.405632, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 99.405632, -------------- SYN_REPORT ------------
              Event: time 100.258616, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 9
              Event: time 100.258616, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 6
              Event: time 100.258616, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 474
              Event: time 100.258616, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 8
              Event: time 100.258616, type 3 (EV_ABS), code 50 (ABS_MT_WIDTH_MAJOR), value 8
              Event: time 100.258616, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
              Event: time 100.258616, type 3 (EV_ABS), code 0 (ABS_X), value 6
              Event: time 100.258616, type 3 (EV_ABS), code 1 (ABS_Y), value 474
              Event: time 100.258616, -------------- SYN_REPORT ------------
              Event: time 100.310865, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
              Event: time 100.310865, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
              Event: time 100.310865, -------------- SYN_REPORT ------------
              中断正常:
                         CPU0
               76:         93  sunxi_pio_edge  44 Edge      gt911
              Err:          0
                结论: 板子坏了,换块板子中断正常了.
                  jmhh247 LV 6 最后由 编辑
                  板子多,屏也多,666
