    解决 D1-H & D1s 驱动 RGB LCD(HV)时由于DCLK频率过高导致花屏
      YterAA LV 7 最后由 YterAA 编辑
      lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp
      做以下修改即可
      diff --git a/de/disp_display.c b/de/disp_display.c
      index 45cb431..e3261f2 100644
      --- a/de/disp_display.c
      +++ b/de/disp_display.c
      @@ -1313,11 +1313,10 @@ s32 bsp_disp_lcd_set_panel_funs(char *name, disp_lcd_panel_fun *lcd_cfg)
       	/*now only support lcd0*/
       	num_compat_cnt = disp_get_compat_lcd_panel_num(0);
      -	for (screen_id = 0; screen_id < num_compat_cnt; screen_id++) {
      -		lcd = disp_get_lcd_compat(0, screen_id);
      +	for (screen_id = 1; screen_id <= num_compat_cnt; screen_id++) {
      +		lcd = disp_get_direct_lcd_compat(0, screen_id);
       		if (lcd && (lcd->set_panel_func)) {
       			if (!lcd->set_panel_func(lcd, name, lcd_cfg)) {
      -				gdisp.lcd_registered[screen_id] = 1;
       				registered_cnt++;
       				DE_INF("panel driver %s register for compatible usage\n", name);
      diff --git a/de/disp_lcd.c b/de/disp_lcd.c
      index 6dc6447..afe600f 100644
      --- a/de/disp_lcd.c
      +++ b/de/disp_lcd.c
      @@ -20,8 +20,8 @@ struct disp_lcd_private_data
       	disp_lcd_flow             open_flow;
       	disp_lcd_flow             close_flow;
      -	/*0 for using this panel, other for index of compat_panel*/
       	u32                       compat_panel_index;
      +	u32                       switch_to_compat_panel_index;
       	disp_panel_para           panel_info;
       	panel_extend_para         panel_extend_info;
       	disp_lcd_cfg              lcd_cfg;
      @@ -67,51 +67,66 @@ static void disp_lcd_post_disable_ex(unsigned int disp);
       s32 disp_lcd_set_bright(struct disp_device *lcd, u32 bright);
       s32 disp_lcd_get_bright(struct disp_device *lcd);
       int disp_update_lcd_param(int lcd_param_index);
      -/*now only lcd0   index is the index for var lcds_compat*/
      -struct disp_device *disp_get_lcd_compat(u32 disp, u32 index)
      +static struct disp_lcd_private_data *disp_lcd_get_priv(struct disp_device *lcd)
      -	u32 num_compat;
      -	u32 num_screens;
      +	if (NULL == lcd) {
      +		DE_WRN("param is NULL!\n");
      +		return NULL;
      +	return (struct disp_lcd_private_data *)lcd->priv_data;
      +struct disp_device *disp_get_direct_lcd_compat(u32 disp, u32 index)
      +	 *    if g_compat_index is set, means not first boot, lcd_compat is NULL.
      +	 * disp_lcd_compat_set_panel_funs may try to get lcd_compat, so return NULL
      +	 * to prevent access NULL pointer.
       	if (g_compat_index)
      -		return NULL;/*  if g_compat_index is set, means not first boot, lcd_compat is NULL.
      -			     * disp_lcd_compat_set_panel_funs may try to get lcd_compat, so return NULL.
      -	num_screens = bsp_disp_feat_get_num_screens();
      -	num_compat = disp_get_compat_lcd_panel_num(0);
      -	if (disp >= num_screens || !bsp_disp_feat_is_supported_output_types(disp, DISP_OUTPUT_TYPE_LCD)) {
      -		DE_INF("disp %d not support lcd output\n", disp);
       		return NULL;
      -	if (index >= num_compat) {
      -		DE_INF("not find %d lcd_compatible param for disp%d \n", index, disp);
      +	return &lcds_compat[index - 1];
      +/*now only lcd0   index is the index for var lcds_compat*/
      +static struct disp_device *disp_get_lcd_compat(u32 disp, u32 index)
      +	static int count;
      +	struct disp_lcd_private_data *lcd_compatp = &lcd_compat_private[index - 1];
      +	u32 next_index = lcd_compatp->switch_to_compat_panel_index;
      +	count++;
      +	if (count > 100) {
      +		DE_WRN("disp_get_lcd_compat endless loop ?\n");
       		return NULL;
      -	return &lcds_compat[index];
      +	if (next_index)
      +		return disp_get_lcd_compat(disp, next_index);
      +	else {
      +		count = 0;
       struct disp_device* disp_get_lcd(u32 disp)
      -	u32 num_screens;
      +	u32 num_screens = bsp_disp_feat_get_num_screens();
      +	u32 num_compat = disp_get_compat_lcd_panel_num(0);
      +	u32 index = ((struct disp_lcd_private_data *)(lcds[disp].priv_data))->switch_to_compat_panel_index;
       		return NULL;
      -	if (!((struct disp_lcd_private_data *)(lcds[disp].priv_data))->compat_panel_index)
      -		return &lcds[disp];
      -	else
      -		return disp_get_lcd_compat(disp, (((struct disp_lcd_private_data *)(lcds[disp].priv_data))->compat_panel_index) - 1);
      -static struct disp_lcd_private_data *disp_lcd_get_priv(struct disp_device *lcd)
      -	if (NULL == lcd) {
      -		DE_WRN("param is NULL!\n");
      -		return NULL;
      -	return (struct disp_lcd_private_data *)lcd->priv_data;
      +	if (index) {
      +		if (index > num_compat) {
      +			DE_WRN("not find %d lcd_compatible param for disp%d \n", index, disp);
      +			return NULL;
      +		return disp_get_lcd_compat(disp, index);
      +	} else
      +		return &lcds[disp];
       static s32 disp_lcd_is_used(struct disp_device* lcd)
      @@ -869,6 +884,7 @@ static s32 lcd_clk_exit(struct disp_device* lcd)
       static s32 lcd_clk_config(struct disp_device* lcd)
       	struct disp_lcd_private_data *lcdp = disp_lcd_get_priv(lcd);
      +	disp_panel_para *panel = &lcdp->panel_info;
       	struct lcd_clk_info clk_info;
       	unsigned long pll_rate = 297000000, lcd_rate = 33000000, dclk_rate = 33000000, dsi_rate = 0;//hz
       	unsigned long pll_rate_set = 297000000, lcd_rate_set = 33000000, dclk_rate_set = 33000000, dsi_rate_set = 0;//hz
      @@ -939,8 +955,19 @@ static s32 lcd_clk_config(struct disp_device* lcd)
       	dclk_rate_set = lcd_rate_set / clk_info.tcon_div;
       	if ((pll_rate_set != pll_rate) || (lcd_rate_set != lcd_rate)
       		|| (dclk_rate_set != dclk_rate)) {
      -			DE_WRN("disp %d, clk: pll(%ld),clk(%ld),dclk(%ld) dsi_rate(%ld)\n     clk real:pll(%ld),clk(%ld),dclk(%ld) dsi_rate(%ld)\n",
      -				lcd->disp, pll_rate, lcd_rate, dclk_rate, dsi_rate, pll_rate_set, lcd_rate_set, dclk_rate_set, dsi_rate_set);
      +		/*  ajust the tcon_div to fix the real pll  */
      +		if (pll_rate_set > pll_rate) {
      +			panel->tcon_clk_div_ajust.clk_div_increase_or_decrease = INCREASE;
      +			panel->tcon_clk_div_ajust.div_multiple = pll_rate_set / pll_rate;
      +			dclk_rate_set /= panel->tcon_clk_div_ajust.div_multiple;
      +		} else {
      +			panel->tcon_clk_div_ajust.clk_div_increase_or_decrease = DECREASE;
      +			panel->tcon_clk_div_ajust.div_multiple = pll_rate / pll_rate_set;
      +			dclk_rate_set *= panel->tcon_clk_div_ajust.div_multiple;
      +		DE_WRN("disp %d, clk: pll(%ld),clk(%ld),dclk(%ld) dsi_rate(%ld)\n     clk real:pll(%ld),clk(%ld),dclk(%ld) dsi_rate(%ld)\n",
      +			lcd->disp, pll_rate, lcd_rate, dclk_rate, dsi_rate, pll_rate_set, lcd_rate_set, dclk_rate_set, dsi_rate_set);
      @@ -1889,8 +1916,11 @@ s32 disp_lcd_switch_compat_panel(struct disp_device *lcd, unsigned int index)
       	disp_lcd_post_disable_ex(lcd->disp);
       	lcd->exit(lcd);
      -	lcdp->compat_panel_index = index;
      -	lcd_compat = disp_get_lcd_compat(lcd->disp, index - 1);
      +	/*this flag make disp_get_lcd get correct compat_panel*/
      +	lcdp->switch_to_compat_panel_index = index;
      +	lcd_compat = disp_get_lcd_compat(lcd->disp, index);
       	lcdp = disp_lcd_get_priv(lcd_compat);
       	lcdp->need_open_again = true;
      @@ -51,7 +51,7 @@
       struct disp_device *disp_get_lcd(u32 disp);
      -struct disp_device *disp_get_lcd_compat(u32 disp, u32 index);
      +struct disp_device *disp_get_direct_lcd_compat(u32 disp, u32 index);
       struct disp_device *disp_get_hdmi(u32 disp);
      diff --git a/de/include.h b/de/include.h
      index 57c5db6..5e81f37 100644
      --- a/de/include.h
      +++ b/de/include.h
      @@ -658,6 +658,16 @@ enum disp_lcd_dsi_port {
       	DISP_LCD_DSI_DUAL_PORT,
      +enum div_flag {
      +	 INCREASE        = 1,
      +	 DECREASE        = -1,
      +struct clk_div_ajust {
      +	enum div_flag clk_div_increase_or_decrease;
      +	int div_multiple;
       typedef struct {
       	disp_lcd_if              lcd_if;
      @@ -737,6 +747,7 @@ typedef struct {
       	unsigned int            ccir_clk_div; /*not need to config for user*/
       	unsigned int            input_csc;
       	unsigned int lcd_hv_data_polarity;
      +	struct clk_div_ajust tcon_clk_div_ajust;
       } disp_panel_para;
       typedef enum {
      diff --git a/de/lowlevel_v2x/de_dsi.c b/de/lowlevel_v2x/de_dsi.c
      index 6d629c5..3bb405d 100644
      --- a/de/lowlevel_v2x/de_dsi.c
      +++ b/de/lowlevel_v2x/de_dsi.c
      @@ -454,8 +454,11 @@ s32 dsi_dcs_rd(u32 sel, u8 cmd, u8 *para_p, u32 *num_p)
       		count++;
       		dsi_delay_us(100);
      -	if (count >= 50)
      +	if (count >= 50) {
       		dsi_dev[sel]->dsi_basic_ctl0.bits.inst_st = 0;
      +		dsi_dev[sel]->dsi_gctl.bits.dsi_en = 0;
      +		dsi_dev[sel]->dsi_gctl.bits.dsi_en = 1;
       	if (dsi_dev[sel]->dsi_cmd_ctl.bits.rx_flag) {
       		if (dsi_dev[sel]->dsi_cmd_ctl.bits.rx_overflow)
      @@ -920,7 +923,6 @@ static s32 dsi_basic_cfg(u32 sel, disp_panel_para *panel)
       		dsi_dev[sel]->dsi_trans_zero.bits.hs_zero_reduce_set = 0;
       	} else {
       		s32 start_delay = panel->lcd_vt - panel->lcd_y - 10;
      -		u32 vfp = panel->lcd_vt - panel->lcd_y - panel->lcd_vbp;
       		u32 dsi_start_delay;
      @@ -928,8 +930,7 @@ static s32 dsi_basic_cfg(u32 sel, disp_panel_para *panel)
       		 * set ready sync early to dramfreq, so set start_delay 1
       		start_delay = 1;
      -		dsi_start_delay = panel->lcd_vt - vfp + start_delay;
      +		dsi_start_delay = start_delay;
       		if (dsi_start_delay > panel->lcd_vt)
       			dsi_start_delay -= panel->lcd_vt;
       		if (dsi_start_delay == 0)
      @@ -942,7 +943,7 @@ static s32 dsi_basic_cfg(u32 sel, disp_panel_para *panel)
       		    dsi_start_delay;
       		dsi_dev[sel]->dsi_basic_ctl1.bits.video_precision_mode_align =
       		    1;
      -		dsi_dev[sel]->dsi_basic_ctl1.bits.video_frame_start = 0; /* 1 */
      +		dsi_dev[sel]->dsi_basic_ctl1.bits.video_frame_start = 1;
       		dsi_dev[sel]->dsi_trans_start.bits.trans_start_set = 10;
       		dsi_dev[sel]->dsi_basic_ctl1.bits.dsi_mode = 1;
      diff --git a/de/lowlevel_v2x/de_lcd_sun50iw10.c b/de/lowlevel_v2x/de_lcd_sun50iw10.c
      index 203e8a3..5a4cdf6 100644
      --- a/de/lowlevel_v2x/de_lcd_sun50iw10.c
      +++ b/de/lowlevel_v2x/de_lcd_sun50iw10.c
      @@ -393,7 +393,7 @@ s32 lvds_open(u32 sel, disp_panel_para *panel)
       #if defined(SUPPORT_COMBO_DPHY)
       		if (sel == 0) {
       			lvds_combphy_open(sel, panel);
      -		} else {
      +		} else if (sel < DEVICE_NUM) {
       			lcd_dev[sel]->tcon0_lvds_ana[0].bits.c = 2;
       			lcd_dev[sel]->tcon0_lvds_ana[0].bits.v = 3;
       			lcd_dev[sel]->tcon0_lvds_ana[0].bits.pd = 2;
      @@ -774,6 +774,7 @@ static s32 tcon0_cfg_mode_tri(u32 sel, disp_panel_para *panel)
       	u32 start_delay = 0;
       	u32 de_clk_rate = de_get_clk_rate() / 1000000;
      +	u32 delay_line = 0;
       	de_clk_rate = (de_clk_rate == 0) ? 250 : de_clk_rate;
      @@ -783,8 +784,30 @@ static s32 tcon0_cfg_mode_tri(u32 sel, disp_panel_para *panel)
       	lcd_dev[sel]->tcon0_cpu_tri1.bits.block_num = panel->lcd_y - 1;
       	lcd_dev[sel]->tcon0_cpu_tri2.bits.trans_start_mode = 0;
       	lcd_dev[sel]->tcon0_cpu_tri2.bits.sync_mode = 0;
      -	start_delay = (panel->lcd_vt - panel->lcd_y - 8 - 1)
      -	    * panel->lcd_ht * de_clk_rate / panel->lcd_dclk_freq / 8;
      +	 * When the blanking area of LCD is too small, the following formula is
      +	 * not applicable, that calculates the start_ Delay is too large.
      +	 * The formula is
      +	 * 		start_delay = (panel->lcd_vt - panel->lcd_y - 8 - 1)
      +	 *    			* panel->lcd_ht * de_clk_rate / panel->lcd_dclk_freq / 8;
      +	 * Therefore, the following formula is obtained by balancing the
      +	 * requirements of DE, TCON and PANEL modules for pixel data speed
      +	if (panel->lcd_vbp > 10)
      +		delay_line = 10;
      +	else if (panel->lcd_vbp <= 10 && panel->lcd_vbp > 4)
      +		delay_line = panel->lcd_vbp - 1;
      +	else {
      +		DE_WRN("vbp is too small, please readjust the timing parameters to increase vbp. \n");
      +		delay_line = panel->lcd_vbp;
      +	start_delay = delay_line * panel->lcd_ht * de_clk_rate / panel->lcd_dclk_freq / 8;
       	lcd_dev[sel]->tcon0_cpu_tri2.bits.start_delay = start_delay;
       	lcd_dev[sel]->tcon0_cpu_ctl.bits.trigger_fifo_en = 1;
      diff --git a/de/lowlevel_v2x/disp_al.c b/de/lowlevel_v2x/disp_al.c
      index 635db57..cf76927 100644
      --- a/de/lowlevel_v2x/disp_al.c
      +++ b/de/lowlevel_v2x/disp_al.c
      @@ -746,10 +746,6 @@ int disp_al_lcd_get_clk_info(u32 screen_id, struct lcd_clk_info *info,
      -	if (panel->lcd_dclk_freq < 48 && panel->lcd_dclk_freq >= 3) {
      -		tcon_div = 300 / panel->lcd_dclk_freq;
       	info->tcon_div = tcon_div;
       	info->lcd_div = lcd_div;
       	info->dsi_div = dsi_div;
      @@ -773,6 +769,11 @@ int disp_al_lcd_cfg(u32 screen_id, disp_panel_para *panel,
       	tcon_init(screen_id);
       	disp_al_lcd_get_clk_info(screen_id, &info, panel);
      +	if (panel->tcon_clk_div_ajust.clk_div_increase_or_decrease == INCREASE) {
      +		info.tcon_div = info.tcon_div * panel->tcon_clk_div_ajust.div_multiple;
      +	} else if (panel->tcon_clk_div_ajust.clk_div_increase_or_decrease == DECREASE) {
      +		info.tcon_div = info.tcon_div / panel->tcon_clk_div_ajust.div_multiple;
       	tcon0_set_dclk_div(screen_id, info.tcon_div);
       #if !defined(TCON1_DRIVE_PANEL)
      diff --git a/dev_disp.c b/dev_disp.c
      index b850d96..1fcd080 100644
      --- a/dev_disp.c
      +++ b/dev_disp.c
      @@ -992,6 +992,17 @@ long disp_ioctl(struct file *file, unsigned int cmd, unsigned long arg)
       	//----layer----
       	case DISP_LAYER_SET_CONFIG:
      +		const unsigned int lyr_cfg_size = ARRAY_SIZE(lyr_cfg);
      +		if (IS_ERR_OR_NULL((void __user *)ubuffer[1])) {
      +			__wrn("incoming pointer of user is ERR or NULL");
      +			return -EFAULT;
      +		if (ubuffer[2] == 0 || ubuffer[2] > lyr_cfg_size) {
      +			__wrn("layer number need to be set from 1 to %d\n", lyr_cfg_size);
      +			return -EFAULT;
       		if (copy_from_user(lyr_cfg,
       			(void __user *)ubuffer[1],
       			sizeof(struct disp_layer_config) * ubuffer[2]))	{
      @@ -1005,6 +1016,17 @@ long disp_ioctl(struct file *file, unsigned int cmd, unsigned long arg)
       	case DISP_LAYER_GET_CONFIG:
      +			return -EFAULT;
      +			return -EFAULT;
      @@ -1026,6 +1048,17 @@ long disp_ioctl(struct file *file, unsigned int cmd, unsigned long arg)
       	case DISP_LAYER_SET_CONFIG2:
      +		const unsigned int lyr_cfg_size = ARRAY_SIZE(lyr_cfg2);
      +			return -EFAULT;
      +			return -EFAULT;
       		if (copy_from_user(lyr_cfg2,
       		    sizeof(struct disp_layer_config2) * ubuffer[2])) {
      @@ -1040,6 +1073,17 @@ long disp_ioctl(struct file *file, unsigned int cmd, unsigned long arg)
       	case DISP_LAYER_GET_CONFIG2:
      +			return -EFAULT;
      +			return -EFAULT;
      diff --git a/disp_sys_intf.c b/disp_sys_intf.c
      index a8032b5..5afccf1 100644
      --- a/disp_sys_intf.c
      +++ b/disp_sys_intf.c
      @@ -378,6 +378,7 @@ int disp_get_set_lcd_param_index_from_flash(bool is_set, int idx)
       			ret = -1;
       	} else {
      +#ifdef CONFIG_COMPATIBLE_PANEL_RECORD
       #ifdef CONFIG_FAT_WRITE
       		if (idx < 0 || idx > 9) {
       			ret = -1;
      @@ -399,6 +400,9 @@ int disp_get_set_lcd_param_index_from_flash(bool is_set, int idx)
       		pr_error("please enable FAT_WRITE for lcd compatible first\n");
       		ret = -1;
      +#else
      +		ret = idx_get = idx;
      +#endif
       exit_free:
       	kfree(buf);
      • aldfaaa
        whycan矿工-小叶 LV 7 最后由 编辑
        大佬, 方便发一下修改过的源文件吗?
