    F1C200s 用 tplayerdemo 播放视频,非常抖,关闭播放屏幕显示就正常了,请问这是什么问题呢?
    7
    19
    15783
      yixiuge LV 5 最后由 whycan 编辑
      root@TinaLinux:/mnt/exUDISK/abc# tplayerdemo
      set c200s audio pass through
      numid=23,iface=MIXER,name='head phone volume'
        ; type=INTEGER,access=rw---R--,values=1,min=0,max=63,step=0
        : values=30
      amixer: Control default element TLV read error: No such device or address
      WARNING: awplayer <log_set_level:30>: Set log level to 3
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-0 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-1 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-2 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-3 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-4 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-5 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-6 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-7 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-8 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-9 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-10 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-11 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-12 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-13 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-14 ok.
      DEBUG  : awplayer <ReadPluginEntry:194>: read plugin entry adecoder-15 fail!
      DEBUG  : awplayer <CdxPluginLoadList:221>: have config 15 entry
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open adecoder lib
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.aac comment is "aac_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_aacdec.so
      DEBUG  : awplayer <AwStreamInit:97>: aw stream init...
      DEBUG  : awplayer <AwStreamInit:131>: stream list size:6
      INFO   : awplayer <AwParserInit:399>: aw parser init...
      DEBUG  : awplayer <AwParserInit:470>: aw parser size:17
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.alac comment is "alac_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_alacdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.amr comment is "amr_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_amrdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.ape comment is "ape_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_apedec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.flac comment is "flac_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_flacdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.mp3 comment is "mp3_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_mp3dec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.ogg comment is "ogg_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_oggdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.wav comment is "wav_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_wavdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.atrc comment is "atrc_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_atrcdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.cook comment is "cook_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_cookdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.ra comment is "ra_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_radec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.sipr comment is "sipr_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_siprdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.dsd comment is "dsd_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_dsddec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.g729 comment is "g729_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_g729dec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.opus comment is "opus_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_opusdec.so
      DEBUG  : awplayer <CdxPluginLoadList:202>: Load Plugin list vdecoder
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-0 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-1 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-2 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-3 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-4 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-5 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-6 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-7 ok.
      DEBUG  : awplayer <ReadPluginEntry:194>: read plugin entry vdecoder-8 fail!
      DEBUG  : awplayer <CdxPluginLoadList:221>: have config 8 entry
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open vdecoder lib
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.avs comment is "avs_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawavs.so
      ERROR  : awplayer <DlOpenPlugin:103>: dlopen 'libawavs.so' fail: Error loading shared library libawavs.so: No such file or directory
      DEBUG  : awplayer <CdxPluginLoadList:231>: load vdecoder id vdecoder.avs fail!
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.h264 comment is "h264_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawh264.so
      DEBUG  : awplayer <DlOpenPlugin:116>: plugin init : CedarPluginVDInit
      warning: cedarc <VDecoderRegister:127>: register codec: '115:h264' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mjpeg comment is "mjpeg_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmjpeg.so
      warning: cedarc <VDecoderRegister:127>: register codec: '101:mjpeg' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg2 comment is "mpeg2_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg2.so
      warning: cedarc <VDecoderRegister:127>: register codec: '102:mpeg2' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '103:mpeg2' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg4base comment is "mpeg4base_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg4base.so
      WARNING: awplayer <DlOpenPlugin:112>: Invalid plugin,function CedarPluginVDInit not found.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg4dx comment is "mpeg4dx_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg4dx.so
      warning: cedarc <VDecoderRegister:127>: register codec: '105:mpeg4dx' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '106:mpeg4dx' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '107:mpeg4dx' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10e:mpeg4dx' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10f:mpeg4dx' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg4h263 comment is "mpeg4h263_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg4h263.so
      warning: cedarc <VDecoderRegister:127>: register codec: '104:mpeg4H263' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10b:mpeg4H263' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10d:mpeg4H263' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg4normal comment is "mpeg4normal_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg4normal.so
      warning: cedarc <VDecoderRegister:127>: register codec: '10a:mpeg4Normal' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10c:mpeg4Normal' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '108:mpeg4Normal' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '109:mpeg4Normal' success.
      DEBUG  : awplayer <CdxPluginLoadList:202>: Load Plugin list plugin
      DEBUG  : awplayer <ReadPluginEntry:194>: read plugin entry plugin-0 fail!
      DEBUG  : awplayer <CdxPluginLoadList:221>: have config 0 entry
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open plugin lib
      * This program implements a simple player, you can type commands to control the player.
      * To show what commands supported, type 'help'.
      tag   : tina3.5
      branch: tina-dev
      DEBUG : tplayer <TPlayerCreate:193>: TPlayerCreate
      DEBUG  : awplayer <XPlayerCreate:219>: XPlayerCreate.
      DEBUG  : awplayer <LogVersionInfo:34>:
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> CedarX <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : CedarX-2.8.0
      branch: master
      commit: 967535b8ff6a073cb4f38e85a4ae5fa6008014d8
      date  : Mon, 15 May 2017 01:30:22 +0000 (09:30 +0800)
      author:
      DEBUG : tsoundcontrol <TSoundDeviceCreate:151>: TinaSoundDeviceInit()
      DEBUG : tsoundcontrol <openSoundDevice:17>: openSoundDevice() in dmix style
      DEBUG  : awplayer <LayerCreate:958>: LayerCreate.
      DEBUG  : awplayer <LayerCreate:978>: ==== callback: 0xb6f50e5c, pUser: 0xb6ff1e40
      DEBUG  : awplayer <LayerCreate:989>: screen:w 800, screen:h 480
      DEBUG : tsubtitlectrl <SubtitleCreate:84>: ==== pCallback: 0xb6f50ccc, pUser: 0xb6ff1e40
      DEBUG  : awplayer <XPlayerSetVideoSurfaceTexture:594>: setVideoSurfaceTexture, surface = 0x1178710
      DEBUG  : awplayer <XPlayerThread:1906>: process message XPLAYER_COMMAND_SET_SURFACE.
      DEBUG  : awplayer <XPlayerThread:1967>: ==== process message XPLAYER_COMMAND_SET_SUBCTRL.
      DEBUG  : awplayer <PlayerSetSubCtrl:679>: === PlayerSetSubCtrl
      DEBUG  : awplayer <XPlayerSetDeinterlace:695>: set deinterlace
      DEBUG  : awplayer <XPlayerThread:1982>: ==== process message XPLAYER_COMMAND_SET_SUBCTRL.
      dd: writing '/dev/fb0': No space left on device
      6001+0 records in
      6000+0 records out
      tplayerdemo# play url:/mnt/exUDISK/abc/3.mp4
      tplayerdemo# demoPlayer.mUrl = /mnt/exUDISK/abc/3.mp4WARNING: awplayer <XPlayerReset:948>: reset...
      DEBUG  : awplayer <PlayerStop:850>: ****** PlayerStop
      ERROR  : awplayer <PlayerStop:855>: invalid stop operation, player already in stopped status.
      reset the player ok.
      DEBUG  : awplayer <XPlayerSetDataSourceUrl:459>: setDataSource(url), url='/mnt/exUDISK/abc/3.mp4'
      INFO   : awplayer <XPlayerThread:1743>: process message XPLAYER_COMMAND_SET_SOURCE.
      DEBUG  : awplayer <XPlayerPrepare:744>: prepare
      DEBUG  : awplayer <XPlayerThread:1996>: process message XPLAYER_COMMAND_PREPARE. mPriData->mStatus: 1
      DEBUG  : demuxComponent <DemuxThread:1784>: process message DEMUX_COMMAND_PREPARE.
      DEBUG  : demuxComponent <DemuxThread:1851>: === prepare msg
      DEBUG  : awplayer <CdxParserPrepare:728>: source uri 'file:///mnt/exUDISK/abc/3.mp4'
      DEBUG  : awplayer <__FileStreamCreate:533>: local file 'file:///mnt/exUDISK/abc/3.mp4'
      DEBUG  : awplayer <__FileStreamConnect:392>:     *************impl->size=2646187646
      DEBUG  : awplayer <__FileStreamConnect:404>: impl->filePath=fd://7?offset=0&length=2646187646
      DEBUG  : awplayer <__FileStreamConnect:486>: :16:[00 00 00 14 66 74 79 70 69 73 6f 6d 00 00 00 01]
      DEBUG  : awplayer <__FileStreamGetMetaData:363>: redriect url '(null)'
      WARNING: awplayer <__FileStreamGetMetaData:368>: key(stream.accessibleUri) not found...
      WARNING: awplayer <ParserTypeGuess:586>: Sorry, I don't know what it is!
      DEBUG  : CdxMovParser <__CdxMovParserProbe:1298>:  --- probe: it is mov parser
      DEBUG  : awplayer <CdxParserCreate:677>: Good, it's 'mov'
      INFO   : CdxMovParser <__CdxMovParserOpen:1206>: mov parser is not support multi-stream yet!!!
      DEBUG  : CdxMovParser <__CdxMovParserOpen:1235>: --- c->bSeekAble = 1
      DEBUG  : awplayer <CdxParserCreate:683>: parser type(0)
      DEBUG  : Mov Id3 Test <_MovParseFtyp:3713>: ---- compatible = isom
      DEBUG  : Mov Id3 Test <_MovParseTkhd:2176>: tkhd width = 1280, height = 720
      DEBUG  : Mov Id3 Test <_MovParseMdhd:1982>: -- language = und
      DEBUG  : Mov Id3 Test <_MovParseStsd:1377>: stsd width = 1280, height = 720
      INFO   : Mov Id3 Test <_MovParseStbl:1733>:  !!!! careful ctts atom is tested yet
      DEBUG  : Mov Id3 Test <_MovParseCtts:729>: track[0].ctts.entries = 167433
      DEBUG  : Mov Id3 Test <_MovParseStsz:874>: -- sample_size = 0
      DEBUG  : Mov Id3 Test <_MovParseTkhd:2176>: tkhd width = 0, height = 0
      DEBUG  : Mov Id3 Test <_MovParseMdhd:1982>: -- language = eng
      DEBUG  : Mov Id3 Test <_MovParseMdhd:1982>: -- language = chi
      DEBUG  : CdxMovParser <__CdxMovParserInit:1178>: ***** mov open success!!
      DEBUG  : demuxComponent <DemuxThread:1888>: --- demux->shiftedTimeUrl =
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:800>: Get mediainfo
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:827>: --- codecformat = 115
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:842>: ---- frame rate = 23976, st->time_scale: 24000, st->sample_duration: 1001
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:851>: width = 1280, height = 720
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:854>: extradataSize = 40
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:882>: ********* audio 0************
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:883>: ****eCodecFormat:    4
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:884>: ****eSubCodecFormat: 0
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:885>: ****nChannelNum:     2
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:886>: ****nBitsPerSample:  16
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:887>: ****nSampleRate:     48000
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:888>: ****nAvgBitrate:     131560
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:889>: ****nMaxBitRate:     169888
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:890>: ****extradataSize    5
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:891>: ***************************
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:882>: ********* audio 1************
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:888>: ****nAvgBitrate:     136184
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:889>: ****nMaxBitRate:     171576
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:934>: streamNum = 3, videoNum = 1, audioNum = 2, subtitleNum = 0
      DEBUG  : awplayer <CdxMovSetStream:397>: == stss_size: 1005
      DEBUG  : awplayer <CdxMovSetStream:416>: mvhd = 7047103,
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:947>: -- mov duration = 7047104
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:953>: ****video_avg_bitrate:  3004000
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:974>: --i = 0, stsd_type = 1, stream_index = 0, nb_streams = 3
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:974>: --i = 1, stsd_type = 2, stream_index = 0, nb_streams = 3
      DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:974>: --i = 2, stsd_type = 2, stream_index = 1, nb_streams = 3
      DEBUG  : demuxComponent <PrintMediaInfo:466>: *********PrintMediaInfo begin*********
      DEBUG  : demuxComponent <PrintMediaInfo:480>: fileSize = 2646187646, bSeekable = 1, duration = 7047104, audioNum = 2, videoNum = 1, subtitleNum = 0
      DEBUG  : demuxComponent <PrintMediaInfo:498>: ***Video[0]*** eCodecFormat = 0x115, nWidth = 1280, nHeight = 720, nFrameRate = 23976, nFrameDuration = 0, bIs3DStream = 0
      DEBUG  : demuxComponent <PrintMediaInfo:516>: ***Audio[0]*** eCodecFormat = 0x4, eSubCodecFormat = 0x0, nChannelNum = 2, nBitsPerSample = 16, nSampleRate = 48000
      DEBUG  : demuxComponent <PrintMediaInfo:516>: ***Audio[1]*** eCodecFormat = 0x4, eSubCodecFormat = 0x0, nChannelNum = 2, nBitsPerSample = 16, nSampleRate = 48000
      DEBUG  : demuxComponent <PrintMediaInfo:532>: *********PrintMediaInfo end*********
      DEBUG  : awplayer <initializePlayer:1465>: mVideoRotateDegree = 0
      DEBUG  : awplayer <initializePlayer:1474>: rotate degree level = 0
      debug  : cedarc <LogVersionInfo:40>:
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Cedar Codec <<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : CedarC-v1.1.9
      branch: master
      commit: 1951abe1456450ea48bfd446e801861a1354e93c
      date  : Wed May 30 18:59:36 2018 +0800
      author: jenkins8080
      patch :
      debug  : cedarc <CreateVideoDecoder:215>:CreateVideoDecoder ****
      DEBUG  : awplayer <VideoDecCompSetVideoStreamInfo:255>: ++++++++ pVconfig->bGpuBufValid = 1,nGpuAlignStride = 32
      debug  : ionAlloc <__GetIonMemOpsS:985>:*** get __GetIonMemOpsS ***
      debug  : cedarc <InitializeVideoDecoder:344>:*** pVconfig->nVeFreq = 0
      debug  : ionAlloc <ion_alloc_open:134>:begin ion_alloc_open
      debug  : cedarc <VeSetSpeed:1559>: *** set ve freq to 300 Mhz ***
      debug  : cedarc <VeInitialize:1198>: ve init ok
      debug  : ionAlloc <ion_alloc_open:175>:** phy offset = 40000000
      debug  : cedarc <VeRelease:1253>: ve release ok
      warning: cedarc <InitializeVideoDecoder:428>:warning: the nDeInterlaceHoldingFrameBufferNum is 0
      debug  : cedarc <DecideStreamBufferSize:1897>:nBufferSize=1048576
      debug  : cedarc <VideoEngineCreate:388>: *** pEngine->nIcVeVersion = 1663, decIpVersion = 0
      debug  : cedarc <VeGetChipId:1385>: 00000000
      debug  : cedarc <CreateSpecificDecoder:1209>: Create decoder '115:h264'
      debug  : cedarc <VideoEngineCreate:481>: **************eCtlAfcbMode = 0
      debug  : cedarc <GetSbmInterface:1705>:*********GetSbmInterface, nType=4
      debug  : cedarc <GetSbmInterfaceFrame:1663>:******* sbm-type: Frame*******
      debug  : cedarc <SbmFrameInit:178>:************pSbm->sbmInterface.bUseNewVeMemoryProgram=0
      debug  : cedarc <CdcMessageQueueCreate:47>:nMessageSize = 20
      DEBUG  : awplayer <VideoRenderCompSetWindow:454>: video render component setting window: 0x1178710
      DEBUG  : awplayer <handleSetWindow:375>: process MESSAGE_ID_SET_WINDOW message, p->pPicture(0)
      DEBUG  : awplayer <__LayerResetNativeWindow:819>: LayerResetNativeWindow : 0
      DEBUG  : awplayer <__LayerControl:903>: layer control cmd = 259
      DEBUG  : awplayer <VideoRenderCompSetDeinterlace:310>: video render component setting deinterlace: 0xb6f11970
      DEBUG  : awplayer <PlayerConfigDropDelayFrame:1762>: PlayerConfigDropDelayFrame
      DEBUG  : awplayer <PlayerConfigDropDelayFrame:1765>: VideoDecCompSetDropDelayFrames
      DEBUG  : audioDecItf <AudioDecCompCreate:206>: libadecoder.so dlopen success, to load internal symbols...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(ParserRequestBsBuffer) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(ParserUpdateBsBuffer) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(BsQueryQuality) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(AudioStreamDataSize) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(AudioStreamBufferSize) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(AudioStreamBufferMaxFrameNum) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(AudioPCMDataSize) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(DecRequestPcmBuffer) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(DecUpdatePcmBuffer) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(PlybkRequestPcmBuffer) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(PlybkUpdatePcmBuffer) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(PlybkRequestPcmPts) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(PcmQueryQuality) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(AudioDecoderSeek) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(InitializeAudioDecoder) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(ResetAudioDecoder) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(DecodeAudioStream) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(DestroyAudioDecoder) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(CreateAudioDecoder) link success...
      DEBUG  : audioDecItf <AudioDecCompCreate:221>: func(SetRawPlayParam) link success...
      DEBUG  : audioRender <AudioRenderCompSetAudioSink:195>: audio render component setting AudioSink
      setDataSource end
      DEBUG  : awplayer <XPlayerPrepareAsync:724>: prepareAsync
      DEBUG  : awplayer <XPlayerThread:1996>: process message XPLAYER_COMMAND_PREPARE. mPriData->mStatus: 4
      INFO   : awplayer <XPlayerThread:2032>: xxxxxxxxxx video size: width = 1280, height = 720
      DEBUG : tplayer <CallbackFromXPlayer:83>: video width = 1280,height = 720
      *****tplayer:video width = 1280,height = 720
      warning: unknown callback from Tinaplayer.
      TPLAYER_NOTIFY_PREPARED,has prepared.
      preparing...
      prepared ok
      TPlayerSetHoldLastPicture()
      DEBUG  : awplayer <VideoRenderSetHoldLastPicture:580>: video render component setting hold last picture(bHold=1).
      start play
      DEBUG  : awplayer <XPlayerStart:774>: start
      DEBUG  : awplayer <__LayerCtrlHoldLastPicture:584>: LayerCtrlHoldLastPicture, bHold = 1
      DEBUG  : awplayer <XPlayerThread:2181>: process message XPLAYER_COMMAND_START.
      DEBUG  : awplayer <PlayerStart:728>: player start
      DEBUG  : awplayer <BaseCompPostAndWait:61>: video decoder receive cmd: start
      debug  : cedarc <SbmFrameReset:588>:** wait for reset sem
      debug  : cedarc <ProcessThread:1591>:*** post reset sem
      debug  : cedarc <SbmFrameReset:590>:** wait for reset sem ok
      debug  : cedarc <SbmFrameReset:595>:SbmFrameReset finish
      DEBUG  : awplayer <BaseCompPostAndWait:61>: audio decoder receive cmd: start
      debug  : cedarc <H264ProcessExtraData2:579>: H264ProcessNaluUnit, bNeedFindSPS = 0, bNeedFindPPS = 0
      (Allwinner Audio Middle Layer),line(958) : Create Decoder!!=====
      DEBUG  : audioDecItf <handleStart:1065>: Create libadecoder success...
      (Allwinner Audio Middle Layer),line(592) : AudioDec_Installaudiolib ok
      (Allwinner Audio Middle Layer),line(595) : audio decoder init start ...
      (AllwinnerAlibs),line(50) :
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Audio <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : audiocodec-v1.2
      branch: new
      commit: 3ba65962c01cbf1280ddda19d843009b6ef8ce85
      date  : Tue Jan 8 16:25:27 2019 +0800
      (AllwinnerAlibs),line(679) : ----Loading so success!
      (AllwinnerAlibs),line(877) : *************pAudioStreamInfo start******************
      (AllwinnerAlibs),line(878) : eCodecFormat         :id(4), name(aac low-complexy)
      (AllwinnerAlibs),line(879) : eSubCodecFormat      :0
      (AllwinnerAlibs),line(880) : nChannelNum          :2
      (AllwinnerAlibs),line(881) : nBitsPerSample       :16
      (AllwinnerAlibs),line(882) : nSampleRate          :48000
      (AllwinnerAlibs),line(883) : nAvgBitrate          :131560
      (AllwinnerAlibs),line(884) : nMaxBitRate          :169888
      (AllwinnerAlibs),line(885) : nFileSize            :0
      (AllwinnerAlibs),line(886) : eAudioBitstreamSource:0
      (AllwinnerAlibs),line(887) : eDataEncodeType      :0
      (AllwinnerAlibs),line(888) : nCodecSpecificDataLen:5
      (AllwinnerAlibs),line(889) : pCodecSpecificData   :0x119bec0
      (AllwinnerAlibs),line(890) : nFlags               :0
      (AllwinnerAlibs),line(891) : nBlockAlign          :0
      (AllwinnerAlibs),line(892) : *************pAudioStreamInfo end  ******************
      (AAC Decoder),line(36) : init successs...
      (Allwinner Audio Middle Layer),line(603) : AUDIO DECODE INIT OK...0
      DEBUG  : awplayer <BaseCompPostAndWait:61>: video render receive cmd: start
      DEBUG  : awplayer <handleStart:640>: video render handleStart:p->eStatus = 0
      DEBUG  : awplayer <BaseCompPostAndWait:61>: audio render receive cmd: start
      INFO   : audioRender <handleStart:295>: audio render process start message.
      DEBUG  : audioRender <initSoundDevice:478>: init sound device.
      DEBUG  : audioRender <initSoundDevice:486>: set sound devide param, sample rate = 48000, channel num = 2.
      DEBUG : tsoundcontrol <TSoundDeviceSetFormat:197>: TinaSoundDeviceSetFormat(),sc->sound_status == 2
      DEBUG : tsoundcontrol <TSoundDeviceSetFormat:199>: TinaSoundDeviceSetFormat()
      DEBUG : tsoundcontrol <TSoundDeviceSetFormat:205>: TinaSoundDeviceSetFormat()>>>sample_rate:48000,channel_num:2,sc->bytes_per_sample:4
      WARNING: awplayer <callbackProcess:3560>: message 0x40a not handled.
      DEBUG  : demuxComponent <DemuxThread:2043>: process message DEMUX_COMMAND_START.
      started.
      debug  : cedarc <AvcSbmFrameCheckBitStreamType:320>:result: bStreamWithStartCode[0], with[0], whitout[1]
      debug  : cedarc <H264DecodePictureScanType:2688>: here3:hCtx->bProgressice=1
      DEBUG  : awplayer <CallbackProcess:2906>: first audio pts = 0
      debug  : fbm.c <FbmCreateBuffer:133>:FbmCreate, total fbm number: 8, decoder needed: 5,  nWidth=1280, nHeight=720 nAlignStride = 32
      debug  : fbm.c <FbmCreateBuffer:280>:*** calcute nLower2BitBufOffset = 0(0.00), stride = 0
      debug  : fbm.c <FbmCreateBuffer:379>:*** finish fbmCreateBuffer
      DEBUG  : awplayer <RenderGetVideoFbmBufInfo:1468>: video buffer info: nWidth[1280],nHeight[736],nBufferCount[8],ePixelFormat[7]
      DEBUG  : awplayer <RenderGetVideoFbmBufInfo:1471>: video buffer info: nAlignValue[32],bProgressiveFlag[1],bIsSoftDecoderFlag[0]
      DEBUG  : awplayer <__LayerControl:903>: layer control cmd = 257
      DEBUG  : awplayer <__LayerControl:905>: get the fbm buf info
      DEBUG  : awplayer <__LayerControl:907>: fbmBufInfo->bProgressiveFlag = 1
      DEBUG  : awplayer <__LayerControl:913>: lc->mNumHoldByLayer = 1
      DEBUG  : awplayer <__LayerSetDisplayPixelFormat:499>: Layer set expected pixel format, format = 7
      DEBUG  : awplayer <__LayerSetDisplayBufferSize:451>: __LayerSetDisplayBufferSize:width = 1280,height = 736
      DEBUG  : awplayer <__LayerSetDisplayBufferCount:792>: LayerSetBufferCount: count = 8
      DEBUG  : awplayer <__LayerGetBufferNumHoldByGpu:807>: num hold by gpu is 1
      DEBUG  : awplayer <SetGpuBufferToDecoder:1509>: SetGpuBufferToDecoder:nNumHoldByLayer = 1,p->nGpuBufferNum = 8
      DEBUG  : awplayer <setLayerBuffer:131>: setLayerBuffer:Fmt(7),(1280 736, 0 x 0)
      DEBUG  : awplayer <setLayerBuffer:134>: Disp(1280x736)buf_cnt(8),ProFlag(0),SoftDecFlag(0)
      DEBUG  : awplayer <setLayerBuffer:231>: SunxiMemPalloc mHoldLastPictureBuf successfully,with = 1920,height = 1088
      DEBUG  : awplayer <setLayerBuffer:244>: SunxiMemPalloc buf[0]:0xb5527000
      DEBUG  : awplayer <setLayerBuffer:244>: SunxiMemPalloc buf[1]:0xb538f000
      DEBUG  : awplayer <setLayerBuffer:244>: SunxiMemPalloc buf[2]:0xb51f7000
      DEBUG  : awplayer <setLayerBuffer:244>: SunxiMemPalloc buf[3]:0xb505f000
      DEBUG  : awplayer <setLayerBuffer:244>: SunxiMemPalloc buf[4]:0xb4ec7000
      DEBUG  : awplayer <setLayerBuffer:244>: SunxiMemPalloc buf[5]:0xb4d2f000
      DEBUG  : awplayer <setLayerBuffer:244>: SunxiMemPalloc buf[6]:0xb4b97000
      DEBUG  : awplayer <setLayerBuffer:244>: SunxiMemPalloc buf[7]:0xb4a33000
      DEBUG  : awplayer <__LayerDequeueBuffer:624>: numNotHoldByLayer = 7,lc->nGpuBufferCount = 8
      DEBUG  : awplayer <callbackProcess:3396>: *************decoded nWidth = 1280,nHeight = 720********
      DEBUG : tplayer <CallbackFromXPlayer:94>: video decoded width = 1280,height = 720
      *****tplayer:video decoded width = 1280,height = 720
      *****tplayerdemo:video decoded width = 1280,height = 720real set to display rect:w = 1280,h = 720
      INFO   : awplayer <callbackProcess:3412>: xxxxxxxxxx video size : width = 1280, height = 720
      DEBUG  : awplayer <CallbackProcess:2781>: first video pts = 83416
      WARNING: audioRender <checkSampleRate:647>: sample rate change from 48000 to 48000.
      WARNING: audioRender <checkSampleRate:649>: channel num change from 2 to 2.
      WARNING: audioRender <checkSampleRate:651>: bitPerSample num change from 16 to 16.
      WARNING: audioRender <checkSampleRate:653>: if need direct out put flag change from 0 to 1.
      WARNING: audioRender <checkSampleRate:655>: data type change from 1 to 1.
      DEBUG : tsoundcontrol <TSoundDeviceStop:263>: TinaSoundDeviceStop():sc->sound_status = 2
      DEBUG : tsoundcontrol <TSoundDeviceStop:266>: Sound device already stopped.
      DEBUG  : awplayer <CallbackProcess:2906>: first audio pts = 39999
      DEBUG  : audioRender <startSoundDevice:708>: start sound device.
      DEBUG : tsoundcontrol <TSoundDeviceStart:216>: TinaSoundDeviceStart(): sc->sound_status = 2
      DEBUG : tsoundcontrol <setSoundDeviceParams:66>: setSoundDeviceParams()
      ERROR  : awplayer <__LayerQueueBuffer:765>: *** picNode is full when queue buffer
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(0.083)
      ERROR  : awplayer <ProcessVideoSync:1305>: need to drop this frame
      error  : fbm.c <FbmReturnPicture:932>:invalid frame status, a picture being returned,                 but bUsedByRender=0, bInValidPictureQueue=0, bAlreadyDisplayed=0.
      error  : fbm.c <FbmReturnPicture:933>:**picture[0x120abd0],id[7]
      warning: cedarc <ReturnPicture:1525>:FbmReturnPicture return fail,            it means the picture being returned it not one of this FBM.
      DEBUG : tsoundcontrol <setSoundDeviceParams:121>: alsa-init: chunksize set to 1024
      DEBUG : tsoundcontrol <setSoundDeviceParams:130>: alsa-init: fragcount=8
      DEBUG : tsoundcontrol <setSoundDeviceParams:140>: setSoundDeviceParams():sc->alsa_can_pause = 0
      WARNING: awplayer <CallbackProcess:3653>: reset the timer to 0.040, time difference is -0.449
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(1.001)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(2.002)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(3.003)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(4.004)
      ERROR : tsoundcontrol <TSoundDeviceGetCachedTime:418>: TinaSoundDeviceGetCachedTime(),ret = -32 , delay = 0
      ERROR : tsoundcontrol <TSoundDeviceWrite:389>: MSGTR_AO_ALSA_WriteError,res = -32
      WARNING: awplayer <CallbackProcess:3653>: reset the timer to 4.360, time difference is -0.291
      WARNING: awplayer <CallbackProcess:3653>: reset the timer to 4.480, time difference is -0.402
      WARNING: awplayer <CallbackProcess:3653>: reset the timer to 4.600, time difference is -0.404
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(5.547)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(6.006)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(7.007)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(8.008)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(9.009)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(10.010)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(11.011)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(12.012)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(13.013)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(14.014)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(15.015)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(16.016)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(17.017)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(18.018)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(19.019)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(20.020)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(21.021)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(22.022)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(23.023)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(24.024)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(25.025)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(26.026)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(27.027)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(28.028)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(29.029)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(30.030)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(31.031)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(32.032)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(33.033)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(34.034)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(35.035)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(36.036)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(37.037)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(38.038)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(39.039)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(40.040)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(41.041)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(42.000)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(43.001)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(44.002)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(45.003)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(46.004)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(47.005)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(48.006)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(49.007)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(50.008)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(51.009)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(52.010)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(53.011)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(54.012)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(55.013)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(56.014)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(57.015)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(58.016)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(59.017)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(60.018)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(61.019)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(62.020)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(63.021)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(64.022)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(65.023)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(66.024)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(67.025)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(68.026)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(69.027)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(70.028)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(71.029)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(72.030)
      WARNING: awplayer <CallbackProcess:3653>: reset the timer to 73.480, time difference is -0.153
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(74.449)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(75.033)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(76.034)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(77.035)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(78.036)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(79.037)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(80.038)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(81.039)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(82.040)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(83.041)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(84.001)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(85.002)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(86.003)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(87.004)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(88.005)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(89.006)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(90.007)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(91.008)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(92.009)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(93.010)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(94.011)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(95.012)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(96.013)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(97.014)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(98.015)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(99.016)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(100.017)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(101.018)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(102.019)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(103.020)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(104.021)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(105.022)
      DEBUG  : awplayer <QueueBufferToShow:1360>: video pts(106.023)
      • E
        emperg LV 4 最后由 编辑
        我之前也有这个问题
        tplayer默认使用的是CreateVideoOutport创建的接口,这个可以直接显示Yuv图层,但是非常抖。
        后来我就直接自己照着例程写解码程序然后再用scaler转yuv就不抖了
        Y H 3 条回复 最后回复 回复 引用 分享 0
          yixiuge LV 5 @emperg 最后由 编辑
          @emperg
          请教CreateVideoOutport 与 照着例程写解码程序然后再用scaler转yuv 有什么区别呢?
            @emperg
            root@TinaLinux:/# decodertest /tmp/binghe.mp4 /tmp 0 NV21 2 10
             before strcpy(tmpUrl, url)
             before CdxParserPrepare() file:///tmp/binghe.mp4
            DEBUG  : awplayer <CdxParserPrepare:728>: source uri 'file:///tmp/binghe.mp4'
            DEBUG  : awplayer <__FileStreamCreate:533>: local file 'file:///tmp/binghe.mp4'
            DEBUG  : awplayer <__FileStreamConnect:392>:     *************impl->size=1621069
            DEBUG  : awplayer <__FileStreamConnect:404>: impl->filePath=fd://4?offset=0&length=1621069
            DEBUG  : awplayer <__FileStreamConnect:486>: :16:[00 00 00 20 66 74 79 70 69 73 6f 6d 00 00 02 00]
            DEBUG  : Mov Id3 Test <_MovParseFtyp:3713>: ---- compatible = isomiso2avc1mp41
            DEBUG  : Mov Id3 Test <_MovParseCtts:729>: track[0].ctts.entries = 182
            DEBUG  : Mov Id3 Test <_MovParseStbl:1746>: ============ sbgp
            DEBUG  : Mov Id3 Test <_MovParseSbgp:663>: ========= grouping_type:0x6c6c6f72
             before CdxParserGetMediaInfo()
            DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:842>: ---- frame rate = 24000, st->time_scale: 12288, st->sample_duration: 512
            DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:854>: extradataSize = 41
            DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:888>: ****nAvgBitrate:     128867
            DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:889>: ****nMaxBitRate:     128867
            DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:934>: streamNum = 2, videoNum = 1, audioNum = 1, subtitleNum = 0
            DEBUG  : awplayer <CdxMovSetStream:416>: mvhd = 10022,
            DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:947>: -- mov duration = 10022
            DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:953>: ****video_avg_bitrate:  1294000
            DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:974>: --i = 0, stsd_type = 1, stream_index = 0, nb_streams = 2
            DEBUG  : CdxMovParser <__CdxMovParserGetMediaInfo:974>: --i = 1, stsd_type = 2, stream_index = 0, nb_streams = 2
            DEBUG  : awplayer <PrintMediaInfo:466>: *********PrintMediaInfo begin*********
            DEBUG  : awplayer <PrintMediaInfo:480>: fileSize = 1621069, bSeekable = 1, duration = 10022, audioNum = 1, videoNum = 1, subtitleNum = 0
            DEBUG  : awplayer <PrintMediaInfo:498>: ***Video[0]*** eCodecFormat = 0x115, nWidth = 1280, nHeight = 720, nFrameRate = 24000, nFrameDuration = 0, bIs3DStream = 0
            DEBUG  : awplayer <PrintMediaInfo:516>: ***Audio[0]*** eCodecFormat = 0x4, eSubCodecFormat = 0x0, nChannelNum = 2, nBitsPerSample = 16, nSampleRate = 48000
            DEBUG  : awplayer <PrintMediaInfo:532>: *********PrintMediaInfo end*********
             before CreateVideoDecoder()
            tag   : CedarC-v1.1.9
            branch: master
            author: jenkins8080
            patch :
             before InitializeVideoDecoder()
            debug  : cedarc <DecideStreamBufferSize:1943>:nBufferSize=6291456
             after InitializeVideoDecoder()
             initDecoder OK
             decoder input file: file:///tmp/binghe.mp4
             decoder output directory: /tmp
             output pixel format: NV21
             DecodeThread(), thread created
             parserThreadFunc(), thread created
             data trunk number: 153, i = 101
             DecodeThread() Decode Video Stream start ....
            debug  : fbm.c <FbmCreateBuffer:133>:FbmCreate, total fbm number: 3, decoder needed: 3,  nWidth=1280, nHeight=720 nAlignStride = 0
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 0, maxNum = 3
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 1, maxNum = 3
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 2, maxNum = 3
            warning: cedarc <H264MallocBuffer:1235>:  h264 scale down fbm buffer number need double check!
            debug  : fbm.c <FbmCreateBuffer:133>:FbmCreate, total fbm number: 8, decoder needed: 3,  nWidth=1280, nHeight=720 nAlignStride = 0
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 0, maxNum = 8
            debug  : fbm.c <FbmAllocatePictureBuffer:1410>:pPicture->bEnableAfbcFlag = 0
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 1, maxNum = 8
            debug  [  263.504634] sunxi-ion ion.6: Fail to allocate buffer
            : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 2, maxNum = 8
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 3, maxNum = 8
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 4, maxNum = 8
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 5, maxNum = 8
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 6, maxNum = 8
            debug  : fbm.c <FbmCreateBuffer:226>:** call allocate pic buf, i = 7, maxNum = 8
            error  : ionAlloc <ion_alloc_palloc:335>:ION_IOC_ALLOC error
            error  : fbm.c <FbmAllocatePictureBuffer:1407>:memory alloc fail, require 1382400 bytes for picture buffer.
            error  : fbm.c <FbmCreateBuffer:294>:memory alloc fail, only 7 frames allocated,             we need 8 frames.
            debug  : cedarc <H264ProcessNaluUnit:2448>: malloc buffer error
             decoder return error. decoder exit
             decoder thread exit....
             hevc parser receive other thread error. exit flag
             parser exit.....
             demoDecoder finish.decode frame: 0, cost 0 s
            WARNING: Id3Base <EraseId3:1059>: id3 has already been free
            DEBUG  : awplayer <CdxMovClose:204>: mov close stream = 0xb6cc5d80
            DEBUG  : awplayer <__FileStreamClose:167>: FileStreamClose
             after CdxParserClose()
            debug  : cedarc <ProcessThread:1656>: exit sbm thread
            root@TinaLinux:/#
            想试一下单解码, 也挂了:
            [   63.124981] sunxi-ion ion.6: Fail to allocate buffer
            [  100.639605] sunxi-ion ion.6: Fail to allocate buffer
            [  106.299117] sunxi-ion ion.6: Fail to allocate buffer
            Y H 2 条回复 最后回复 回复 引用 分享 0
              yixiuge LV 5 @yixiuge 最后由 编辑
              @yixiuge
              这就尴尬了😧 😧
                houxiaoni LV 5 @yixiuge 最后由 编辑
                @yixiuge 挂掉的原因是内存不足导致,可以打开缩放试一下,decodertest /tmp/binghe.mp4 /tmp 1 NV21 2 10
                Y 1 条回复 最后回复 回复 引用 分享 0
                  yixiuge LV 5 @houxiaoni 最后由 编辑
                  @houxiaoni
                  嗯,感谢, decodertest 这个问题解决了。
                  请问 tplayerdemo 抖动的问题怎么解决了,现在我把 dclk 从 33Mhz降到 20Mhz,tplayerdemo 全屏播放不抖了,但是如果app里面用了 ui层和yuv层的话, 在yuv层附近ui层也会抖 .
                    houxiaoni LV 5 @emperg 最后由 编辑
                    @emperg 从log看,是alsa写错误发生后,出现了丢帧现象,抖动应该是丢帧导致的,可以尝试以下验证看看是哪里的问题:
                    ① 在menuconfig中打开ONLY_DISABLE_AUDIO,验证是否audio导致丢帧;
                    ② 看一下该视频的帧率是多少,会不会是帧率过高导致解码丢帧;也可以在vdecoder.c中打开宏AW_VDECODER_SPEED_INFO,看一下解码速度;
                    ③ 有可能是pts错误导致丢帧,可以在vdecoder.c中打开宏DEBUG_SAVE_BITSTREAM,保存裸流,然后在PC端播放看看是否正常。
                    Y 2 条回复 最后回复 回复 引用 分享 0
                      @houxiaoni
                      是这个对吗?
                      package/allwinner/tina_multimedia/libcedarx/libcore/playback/player.c:
                      #define CONFIG_DISABLE_AUDIO    (0)
                      我改成1 先试一试.
                        @houxiaoni
                        禁用audio结果还是一样
                        #define CONFIG_DISABLE_AUDIO    (1)
                        如果dlck 20M 就不抖:
                        [    0.421611] pll_freq=297000000HZ, lcd_dclk_freq=20000000HZ, clk_div=14
                        [    0.428986] *******************************
                        [    0.433412] ***
                        [    0.435286] *** LCD Panel Parameter Check
                        [    0.439440] ***
                        [    0.441307] ***             by guozhenjie
                        [    0.445503] ***
                        [    0.447374] ********************************
                        [    0.451822] ***
                        [    0.453693] *** Interface:
                        [    0.456265] *** Parallel HV Panel
                        [    0.459989] *** Lcd Frm to RGB666
                        [    0.463473] ***
                        [    0.465342] *** Timing:
                        [    0.467915] *** lcd_x:      800
                        [    0.471190] *** lcd_y:      480
                        [    0.474497] *** lcd_ht:     1056
                        [    0.477862] *** lcd_hbp:    55
                        [    0.481049] *** lcd_vt:     525
                        [    0.484357] *** lcd_vbp:    35
                        [    0.487546] *** lcd_hspw:   20
                        [    0.490735] *** lcd_vspw:   10
                        [    0.493953] *** lcd_frame_frq:  36Hz
                        [    0.497668] ***
                        [    0.499538] *** WRN03: Recommend "lcd_dclk_frq = 33"
                        [    0.504688] ***
                        [    0.506557] *** LCD Panel Parameter Check End
                        [    0.511064] *******************************
                        如果恢复到33Mhz就抖得不行:
                          yixiuge LV 5 最后由 编辑
                          这个视频文件的码率非常低,
                          60秒才 191K 大小,这是原视频文件:
                            @yixiuge
                            不信邪,把视频文件resize到 320x240,仍然抖得狠,既撕裂,又异位,人眼看到就是抖了,感觉是显示部分出问题了.
                              yixiuge LV 5 最后由 编辑
                              这个这个YUV层打开就会抖,感觉还是显示驱动问题.
                              Y C 2 条回复 最后回复 回复 引用 分享 0
                                Yuwei123456 LV 4 @yixiuge 最后由 编辑
                                @yixiuge 老哥解决抖动问题了吗?我用tina解码也是这样
                                  cdaozhi LV 4 @yixiuge 最后由 编辑
                                  @yixiuge C200S播放抖动是DDR带宽的原因,当前的解决方案是降低图层的刷新率,sys_config.fex的lcd_dclk_freq默认是按60fps计算的,按30fps计算应该就可以了。
                                  lcd_driver_name     = "ili6122_800x480"
                                  lcd_if              = 0
                                  lcd_x               = 800
                                  lcd_y               = 480
                                  lcd_width           = 164
                                  lcd_height          = 100
                                  lcd_dclk_freq       = 13
                                    yixiuge LV 5 @cdaozhi 最后由 编辑
                                    @cdaozhi
                                    原来如此,谢谢大佬指教。
                                    I 1 条回复 最后回复 回复 引用 分享 0
                                    • I
                                      iincity LV 5 @yixiuge 最后由 编辑
                                      @yixiuge 这个问题解决了吗,我按照上面配置还是抖动😕
                                        allwinnercoding LV 4 @iincity 最后由 编辑
                                        @iincity 降低帧率,用硬解直接显示。
                                        • I
                                          iincity LV 5 @allwinnercoding 最后由 编辑
                                          @allwinnercoding 硬解?能不能具体说说如何做。现在tplayerdemo默认不是硬解吗
