    F133A烧录时大概率卡住失败
      casojie LV 5 最后由 编辑
      背景:开始时使用F133B芯片,编译了镜像烧录,几乎没怎么遇到烧录失败的情况
      现在做了一款新的PCB板子,贴的是F133A芯片,就大概率出现卡0%,卡10%,卡55%,卡70%,但也有大约10%的概率成功,据之前有个大哥说,代码软件层面上不用区分F133A和F133B,但是同样的镜像对F133B和F133A烧录情况不一致(当然PCB的电路也不一样),现在就不知道是我代码编译出的镜像有问题,还是后面的F133A电路硬件上有问题,请大佬指点,烧录卡住时的打印如下
      10%
      tfs 5, d200, 8000
      recovery 6, 4d80, 8000
      rootfs_data 7, 2800, 8000
      UDISK 8, 0, 0
      [09.637]erase all part start
      need erase flash: 18
      [09.643][mmc]: erase from: 0, to: 7634943, cnt: 7634944, erase_group: 1024
      [09.678][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x1c ms
      [09.685]read item0 copy0
      [09.687]Item0 (Map) magic is bad
      [09.690]the secure storage item0 copy0 magic is bad
      [09.695]Item0 (Map) magic is bad
      [09.698]the secure storage item0 copy1 magic is bad
      [09.702]Item0 (Map) magic is bad
      [09.705]the secure storage map is empty
      [09.710]erase secure storage: 0 ok
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      write primary GPT success
      write Backup GPT success
      [09.727]update partition map
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      ******Has init
      卡50%
      total part: 9
      mbr 0, 8000, 8000
      boot-resource 1, 1f8, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 3200, 8000
      rootfs 5, d200, 8000
      UDISK 8, 0, 0
      [09.491]erase all part start
      [09.497][mmc]: erase from: 0, to: 7634943, cnt: 7634944, erase_group: 1024
      [09.513][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xa ms
      [09.520]read item0 copy0
      [09.522]Item0 (Map) magic is bad
      [09.525]the secure storage item0 copy0 magic is bad
      [09.530]Item0 (Map) magic is bad
      [09.533]the secure storage item0 copy1 magic is bad
      [09.537]Item0 (Map) magic is bad
      [09.540]the secure storage map is empty
      [09.545]erase secure storage: 0 ok
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      [09.562]update partition map
      ******Has init
      FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x14000
      FEX_CMD_fes_verify_value, start 0x81f8, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value 0xa0bf6d78
      FEX_CMD_fes_verify_value, start 0x83f0, size high 0x0:low 0x20000
      卡79%
      DISK 8, 0, 0
      [09.584]erase all part start
      [09.590][mmc]: erase from: 0, to: 7634943, cnt: 7634944, erase_group: 1024
      [09.606][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xa ms
      [09.613]read item0 copy0
      [09.615]Item0 (Map) magic is bad
      [09.618]the secure storage item0 copy0 magic is bad
      [09.623]Item0 (Map) magic is bad
      [09.626]the secure storage item0 copy1 magic is bad
      [09.630]Item0 (Map) magic is bad
      [09.633]the secure storage map is empty
      [09.638]erase secure storage: 0 ok
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      [09.655]update partition map
      ******Has init
      FEX_CMD_fes_verify_value 0x882de1bc
      FEX_CMD_fes_verify_value, start 0x85e8, size high 0x0:low 0x5fc000
      FEX_CMD_fes_verify_value 0xd668265a
        YterAA LV 7 最后由 编辑
        卡住一般是因为硬件,请问使用什么储存器启动
          casojie LV 5 @YterAA 最后由 编辑
          @yteraa emmc, 谢谢
