    【FAQ】全志V853芯片 如何查看NPU时钟电源配置以及信息?
    v853 faq 技术支持
      [KERNEL_DIR]/arch/arm/boot/dts/sun8iw21p1.dtsi
      npu: npu@03050000 {
          compatible = "allwinner,npu";
          reg = <0x0 0x03050000 0x0 0x1000>;
          device_type = "npu";
          dev_name = "npu";
          interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
          clocks = <&clk_npu>,
              <&clk_pll_npux4>;
          clock-frequency = <504000000>;
          interrupt-names = "npu";
          iommus = <&mmu_aw 6 1>;
          power-domains = <&pd V853_PD_NPU>;
      一:如何使能电源控制以及电源状态确认
      在dts确认配置power-domains后,电源默认打开,如果NPU模块电源需要关闭,需要内核支持CONFIG_SUNXI_POWER_DOMAINS=y;不用的时候应用层软件会默认将其关闭;
      root@TinaLinux:/# echo 0x070010a0,0x070010ac > /sys/class/sunxi_dump/dump && cat
      0x070010a0: 0x00000002 0x00020000 0x00000000 0x00000000
      如上为电源处理关闭状态
      0x070010a0: 0x00000001 0x00010000 0x00000000 0x00000000
      如上电源处于开启状态
      二:如何配置支持的频率
      clock-frequency = <504000000>;代表现在设置的频率为504M;客户请严格按照原厂建议配置,或直接默认配置,勿随意更改其频点;
      clocks = <&clk_npu>,<&clk_pll_npux4>;前面为模块时钟,后面为父时钟;
      在[KERNEL_DIR]/drivers/clk/sunxi/clk-sun8iw21_tbl.c中有如下table代表目前所支持的频点;
      /* PLL_NPU(n, d1, freq)	F_N8X8_D1V1X1 */
      struct sunxi_clk_factor_freq factor_pllnpux4_tbl[] = {
      PLLNPU(24,     1,      300000000U),
      PLLNPU(40,     1,      492000000U),
      PLLNPU(20,     0,      504000000U),
      PLLNPU(25,     0,      624000000U),
      PLLNPU(28,     0,      696000000U),
      PLLNPU(41,     0,     1008000000U),
      PLLNPU(57,     0,     1392000000U),
      配置规则为:
      npu4x的计算公式为:24M * (N+1) / (M+1)N:0-254M:0-1
      在clk-sun8iw21_tbl.c中截图部分添加新的频率组即可
      如:492PLLNPU(40,     1,     492000000U),24*(40+1)/(1+1)= 492
      通过clk_summary我们可以看到配置是否生效
      root@TinaLinux:/# cat /sys/kernel/debug/clk/clk_summary
       pll_npux4                             0            2   504000000          0 0
             npu                                0            1   504000000          0 0
      当然我们也可以从probe的打印看到时钟的相关配置
      [  843.717406] Want set pclk rate(504000000) support(504000000) real(504000000)
      [  843.725445] Want set mclk rate(504000000) support(504000000) real(504000000)
      三:怎么用命令修改时钟的频率
      reboot uboot
      #等待其处于uboot中后:
      fdt list /soc/npu
      fdt set /soc/npu clock-frequency <696000000>
      fdt list /soc/npu
      save
      boot
