    【代码编不过请看这里】D1 Tina SDK完整编译log
      DOT小文哥 LV 8 最后由 xiaowenge 编辑
      有开发者提到Tina编译会出现问题,不知道怎么解决,这里我们将完整Tina SDK编译时候的log打包一份供大家参考。下载地址:https://www.aw-ol.com/downloads/resources/41
      我的代码仓库曾经编译过代码,故我先将out目录删掉全部重新编译,这样的log会比较全:
      xiaowenge@ubuntu:~/workspace/d_tina_d1_open_v1.0$ rm -rf out/
      xiaowenge@ubuntu:~/workspace/d_tina_d1_open_v1.0$ source build/envsetup.sh
      Setup env done! Please run lunch next.
      xiaowenge@ubuntu:~/workspace/d_tina_d1_open_v1.0$ lunch
      You're building on Linux
      Lunch menu... pick a combo:
           1. d1_nezha_min-tina
           2. d1_nezha-tina
      Which would you like? [Default d1_nezha]: 2
      TINA_BUILD_TOP=/home/xiaowenge/workspace/d_tina_d1_open_v1.0
      TINA_TARGET_ARCH=riscv
      TARGET_PRODUCT=d1_nezha
      TARGET_PLATFORM=d1
      TARGET_BOARD=d1-nezha
      TARGET_PLAN=nezha
      TARGET_BUILD_VARIANT=tina
      TARGET_BUILD_TYPE=release
      TARGET_KERNEL_VERSION=5.4
      TARGET_UBOOT=u-boot-2018
      TARGET_CHIP=sun20iw1p1
      xiaowenge@ubuntu:~/workspace/d_tina_d1_open_v1.0$ make -j > compilelog.log
      [1] 57825
      Collecting target info: done+ mkdir -p /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/host
      + mkdir -p /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/d1-nezha/staging_dir/target
      + cd /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/host
      + mkdir -p bin lib include stamp
      + cd /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/d1-nezha/staging_dir/target
      This is not dpkg install-info anymore, but GNU install-info
      See the man page for ginstall-info for command line arguments
      src/sstrip.c: In function 'readelfheader32':
      src/sstrip.c:363:1: warning: format '%d' expects argument of type 'int', but argument 5 has type 'long unsigned int' [-Wformat=]
       HEADER_FUNCTIONS(32)
      完整log见上面的下载链接
      编译成功后打包log:
      xiaowenge@ubuntu:~/workspace/d_tina_d1_open_v1.0$ pack
      PACK_CHIP         sun20iw1p1
      PACK_PLATFORM     tina
      PACK_BOARD        d1-nezha
      PACK_KERN
      PACK_DEBUG        uart0
      PACK_SIG          none
      PACK_SECURE       none
      PACK_MODE         normal
      PACK_FUNC         android
      PACK_PROGRAMMER   none
      PACK_TAR_IMAGE    none
      PACK_TOPDIR       /home/kunyao/workspace/d_tina_d1_open_v1.0
      No kernel param, parse it from d1
      copying tools file
      copying configs file
      storage_type value is 5
      rm /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/d1-nezha/image/sys_partition_nor.fex
      rm /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/d1-nezha/image/image_nor.cfg
      copying boot resource
      LZMA 4.65 : Igor Pavlov : Public domain : 2009-02-03
      copying boot file
      make user resource for : /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/d1-nezha/image/sys_partition.fex
      handle partition user-res
      no user resource partitions
      APP_PART_DOWNLOAD_FILE = /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/d1-nezha/image/app.fex
      Need size of filesystem
      no data resource partitions
      don't build dtbo ...
      update_chip
      pack boot package
      content_count=3
      packing for tina linux
      normal
      this is not a partition key
      gpt_head->header_crc32 = 0x5277aea2
      GPT----part num 8---
      gpt_entry: 128
      gpt_header: 92
      GPT:boot-resource: 1f8           2177
      GPT:env         : 2178          236f
      GPT:env-redund  : 2370          2567
      GPT:boot        : 2568          761f
      GPT:rootfs      : 7620          11597
      GPT:dsp0        : 11598         11987
      GPT:recovery    : 11988         187c7
      GPT:UDISK       : 187c8         187d7
      update gpt file ok
      update mbr file ok
        [mbr]
        mbr_size  : 252 Kbyte
        partition_name  : boot-resource
        partition_size  : 8064
        boot-resource.fex size : 3.0M byte
        partition_name  : env
        partition_size  : 504
        downloadfile  : env.fex
        env.fex size : 128K byte
        partition_name  : env-redund
        partition_size  : 20664
        downloadfile  : boot.fex
        boot.fex -> /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/d1-nezha/boot.img
        boot.img size : 9.1M byte
        partition_name  : rootfs
        partition_size  : 40824
        downloadfile  : rootfs.fex
        rootfs.fex -> /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/d1-nezha/rootfs.img
        rootfs.img size : 16M byte
        partition_name  : dsp0
        partition_size  : 1008
        downloadfile  : dsp0.fex
        dsp0.fex size : 258K byte
        partition_name  : recovery
        partition_size  : 28224
      /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/host/bin/
      Begin Parse sys_partion.fex
      FilePath: boot-resource.fex
      FileLength=2f8c00Add partion env.fex ENV_FEX000000000
      FilePath: env.fex
      FileLength=20000Add partion env.fex ENV_FEX000000000
      FilePath: env.fex
      FilePath: boot.fex
      FileLength=912000Add partion rootfs.fex ROOTFS_FEX000000
      FilePath: rootfs.fex
      FileLength=fa0000Add partion dsp0.fex DSP0_FEX00000000
      Add partion very dsp0.fex DSP0_FEX00000000
      FilePath: dsp0.fex
      FileLength=4059csys_config.fex Len: 0x4ebe
      config.fex Len: 0x6c00
      board.fex Len: 0x400
      split_xxxx.fex Len: 0x200
      sys_partition.fex Len: 0xbe3
      sunxi.fex Len: 0xd400
      boot0_nand.fex Len: 0x10000
      boot0_sdcard.fex Len: 0x10000
      u-boot.fex Len: 0xdc000
      u-boot-crash.fex Len: 0x25
      toc1.fex Len: 0x8
      toc0.fex Len: 0x8
      fes1.fex Len: 0xa560
      boot_package.fex Len: 0xfc000
      usbtool.fex Len: 0x24e00
      usbtool_crash.fex Len: 0x1ec00
      aultools.fex Len: 0x28a73
      aultls32.fex Len: 0x25205
      cardtool.fex Len: 0x11e00
      cardscript.fex Len: 0x6de
      sunxi_gpt.fex Len: 0x2000
      sunxi_mbr.fex Len: 0x10000
      dlinfo.fex Len: 0x4000
      arisc.fex Len: 0xf
      vmlinux.fex Len: 0x8
      tinaconf.fex Len: 0xcd00
      boot-resource.fex Len: 0x2f8c00
      Vboot-resource.fex Len: 0x4
      env.fex Len: 0x20000
      Venv.fex Len: 0x4
      Venv.fex Len: 0x4
      boot.fex Len: 0x912000
      Vboot.fex Len: 0x4
      rootfs.fex Len: 0xfa0000
      Vrootfs.fex Len: 0x4
      dsp0.fex Len: 0x4059c
      Vdsp0.fex Len: 0x4
      BuildImg 0
      ----------image is for nand/emmc----------
      /home/xiaowenge/workspace/d_tina_d1_open_v1.0/out/d1-nezha/tina_d1-nezha_uart0.img
      pack finish
      我的代码版本是v1.0.1的:
      xiaowenge@ubuntu:~/workspace/d_tina_d1_open_v1.0/lichee/linux-5.4$ git log .
      commit 035e3450a899008ef15bb387d0ed41aafd733a8a (HEAD -> product-smartx-d1-tina-v1.0-release, tag: smartx-d1-tina-v1.0.1-release, tina/product-smartx-d1-tina-v1.0-release, m/master)
      Author: liwencong <liwencong@allwinnertech.com>
      Date:   Fri May 21 14:01:26 2021 +0800
          smartx-d1-tina-v1.0.1-release release
      commit 9e841db240d4f7161ac1c931bd889dc17eb9b076 (tag: smartx-d1-tina-v1.0.0-release)
      Date:   Fri Apr 30 19:24:15 2021 +0800
          smartx-d1-tina-v1.0.0-release release
      • Referenced by  Kirin Kirin
