    Error: "distro_bootcmd" not defined
    9504
      huangjun.zopudt LV 4 最后由 xiaowenge 编辑
      我们使用F133-B的evb1,启动错误如下:
      [36]HELLO! BOOT0 is starting!
      [39]BOOT0 commit : 7520e33c67
      [42]set pll start
      [44]1008M
      [45]periph0 has been enabled
      [48]set pll end
      [50][pmu]: bus read error
      [52]board init ok
      [54]ZQ value = 0x31
      [56]get_pmu_exist() = -1
      [58]DRAM BOOT DRIVE INFO: V0.34
      [61]DRAM CLK = 528 MHz
      [63]DRAM Type = 2 (2:DDR2,3:DDR3)
      [66]DRAMC read ODT  off.
      [69]DRAM ODT off.
      [70]ddr_efuse_type: 0xa
      [73]DRAM SIZE =64 M
      [75]dram_tpr4:0x0
      [77]PLL_DDR_CTRL_REG:0xf8002b00
      [79]DRAM_CLK_REG:0xc0000000
      [82][TIMING DEBUG] MR2= 0x0
      [86]DRAM simple test OK.
      [89]dram size =64
      [92]spi sample_mode:1 sample_delay:23
      [96]spinor id is: 1c 70 18, read cmd: 6b
      [100]Succeed in reading toc file head.
      [104]The size of toc is 68000.
      [115]Entry_name        = opensbi
      [118]Entry_name        = u-boot
      [121]Entry_name        = dtb
      [124]Jump to second Boot.
      OpenSBI auto-t113-linux-V0.8-1-g771d82e
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,
      Boot 2018.05-00006-gbe58720-dirty (Jun 18 2021 - 10:21:46 +0800) Allwinner Technology
      [00.210]DRAM:  64 MiB
      [00.212]Relocation Offset is: 01fa5000
      [00.216]secure enable bit: 0
      [00.218]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.225]flash init start
      [00.227]workmode = 0,storage type = 3
      SF: Detected en25qh128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
      [00.240]sunxi flash init ok
      GUID Partition Table Header signature is wrong: 0x6F627464 != 0x5452415020494645
      ERROR: attempting read past flash size
      *** ERROR: Can't read GPT header ***
      [00.265]Loading Environment from SUNXI_FLASH... GUID Partition Table Header signature is wrong: 0x6F627464 != 0x5452415020494645
      *** Warning - no device, using default environment
      Failed (-19)
      [00.298]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [00.309]usb prepare ok
      [00.516]usb sof ok
      [00.518]usb probe ok
      [00.520]usb setup ok
      set address 0x14
      set address 0x14 ok
      set address 0x15
      set address 0x15 ok
      try to update
      [03.525]do_burn_from_boot usb : have no handshake
      [03.552]update part info
      [03.577]update bootcmd
      [03.625]change working_fdt 0x43564da0 to 0x43544da0
      disable nand error: FDT_ERR_NOTFOUND
      [03.646]update dts
      ## Error: "distro_bootcmd" not defined
      请问:这个问题错误出在哪里?
        YterAA LV 7 最后由 编辑
        系统刷写不完整,或者env.cfg丢失了
        H 2 条回复 最后回复 回复 引用 分享 0
          huangjun.zopudt LV 4 @YterAA 最后由 编辑
          @yteraa
          有哪些解决方案?
          Y 1 条回复 最后回复 回复 引用 分享 0
            YterAA LV 7 @huangjun.zopudt 最后由 编辑
            @huangjun-zopudt 看一下 config/chip/d1-h/nezha/env.cfg有没有
                @yteraa
                我用版本是F133的V1.0版本 。
                BSP分为F133-A与F133-B。我使用的F133-B。
                我们只在原SDK 上调整了输出串口PIN,匹配了SPI Nor Flash (16M )。
                  YterAA LV 7 最后由 编辑
                  系统分区损坏了。无法读取到fs里的文件。可以参考下这个是怎么写的 https://www.aw-ol.com/downloads/resources/72
                  H 1 条回复 最后回复 回复 引用 分享 0
                    @yteraa
                    F133 SDK的V1.0与以前V0.5,V0.8有哪些变化?
                    这个问题在V0.5与V0.8上没有出现。
                      @huangjun-zopudt 更新了mtd驱动,你可以试试全盘擦除再刷写
                        @yteraa https://www.aw-ol.com/downloads/resources/72
                        打开资料后,分不清楚资料中文件与SDK中文件的对应关系。
                        请给一下patch格式的资料,或按目录结构归档的压缩包。或告知一下正确的打开方式
                        谢谢!
                        下图是资料的部分截图:
                          @yteraa
                          我一直用的是:全盘擦除升级。
                          A 1 条回复 最后回复 回复 引用 分享 1
                            a54799 LV 1 @huangjun.zopudt 最后由 编辑
                            @huangjun-zopudt 我的有全盘擦除,怎么选不上呢,灰色的,请教
