    f1c100s tina系统,修改bootlogo分区大小,打包的时候报错
      waterworld LV 5 最后由 xiaowenge 编辑
      ;    mbr的大小, 以Kbyte为单位
      [mbr]
      size = 4096
      ;  partition 定义范例:
      ; 注:1、name唯一, 不允许同名
      ;     2、name最大12个字符
      ;     4、为了安全和效率考虑,分区大小最好保证为16M字节的整数倍
      [partition_start]
      [partition]
          name         = bootlogo
          size         = 6084 ==》1024改成6084
          downloadfile = "bootlogo.fex"
          user_type    = 0x8000
      [partition]
          name         = env
          size         = 512
          downloadfile = "env.fex"
          user_type    = 0x8000
      [partition]
          name         = boot
          ;size         = 4096
          size         = 12288
          downloadfile = "boot.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfs
          size         = 51200
          downloadfile = "rootfs.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfs_data
          size         = 51200
          user_type    = 0x8000
      ;[partition]
      ;  name         = extend
      ;   size         = 8192
      ;    downloadfile = "usr.fex"
      ;    user_type    = 0x8000
      [partition]
          name         = misc
          size         = 512
          user_type    = 0x8000
      [partition]
          name         = private
          size         = 512
          user_type    = 0x8000
      [partition]
          name         = UDISK
          user_type    = 0x8100
      打包提示错误:
      这是怎么回事,我里面logo分区的大小,我更换了几个值,上面mbr的大小我也改变过,还是一样的结果
      W 1 条回复 最后回复 回复 引用 分享 0
        waterworld LV 5 @waterworld 最后由 xiaowenge 编辑
        @waterworld
        iot@server-211:~/jkangli/f1c100s/tina$ pack
        No kernel param, parse it from c200s
        copying tools file
        copying configs file
        image/arisc.fex
        image/aultls32.fex
        image/aultools.fex
        image/bootlogo.fex
        image/boot_package.cfg
        image/boot_package.fex
        image/boot_package_nor.cfg
        image/cardscript.fex
        image/cardscript_secure.fex
        image/cardtool.fex
        image/diskfs.fex
        image/env-3.10.cfg
        image/env_burn.cfg
        image/esm.fex
        image/image_crashdump.cfg
        renamed 'image/image_linux.cfg' -> 'image/image.cfg'
        image/image_nor.cfg
        image/split_xxxx.fex
        image/sunxi.fex
        image/sw-subimgs-ab.cfg
        image/sw-subimgs.cfg
        image/sw-subimgs-secure.cfg
        image/sys_config.fex
        image/sys_partition_dump.fex
        image/sys_partition.fex
        image/sys_partition_nor.fex
        image/sys_partition_private.fex
        image/toc0.fex
        image/toc1.fex
        image/usbtool_crash.fex
        image/usbtool.fex
        image/usbtool_test.fex
        image/writable.fex
        /home/iot/jkangli/f1c100s/tina
        storage_type value is 5
        rm /home/iot/jkangli/f1c100s/tina/out/c200s-F1C200s/image/sys_partition_nor.fex
        rm /home/iot/jkangli/f1c100s/tina/out/c200s-F1C200s/image/image_nor.cfg
        copying boot resource
        LZMA 4.65 : Igor Pavlov : Public domain : 2009-02-03
        copying boot file
        make user resource for : /home/iot/jkangli/f1c100s/tina/out/c200s-F1C200s/image/sys_partition.fex
        handle partition user-res
        no user resource partitions
        unable to find key partition_start
        ERROR: update mbr file fail
        no app resource partitions
        /home/iot/jkangli/f1c100s/tina/scripts/pack_img.sh: line 722: let: DATA_PART_SIZE_IN_K=/2: syntax error: operand expected (error token is "/2")
        DATA_PART_DOWNLOAD_FILE = /home/iot/jkangli/f1c100s/tina/out/c200s-F1C200s/image/data.fex
        Need size of filesystem
        /home/iot/jkangli/f1c100s/tina/out/c200s-F1C200s/image/data.fex is not ext4 img
        /home/iot/jkangli/f1c100s/tina/out/c200s-F1C200s/image/data.fex: cannot open `/home/iot/jkangli/f1c100s/tina/out/c200s-F1C200s/image/data.fex' (No such file or directory)
        sys_config exist
        Multiconfig num:0
        copying tools file
        image/arisc.fex
        image/aultls32.fex
        image/aultools.fex
        image/boot0_nand.fex
        image/boot0_sdcard.fex
        image/boot0_spinor.fex
        image/bootlogo.fex
        image/cardtool.fex
        image/diskfs.fex
        image/env-3.10.cfg
        image/env_bk.cfg
        image/env_burn.cfg
        image/env.cfg
        image/esm.fex
        image/fes1.fex
        image/image.cfg
        image/image_nor.cfg
        image/sunxi.fex
        image/sys_partition_tmp_app.fex
        image/sys_partition_tmp_data.fex
        image/toc0.fex
        image/toc1.fex
        image/u-boot.fex
        image/u-boot-spinor.fex
        image/usbtool.fex
        image/writable.fex
        copying boot file
        p=soc c=product state=0
        p=soc c=platform state=0
        p=soc c=target state=0
        p=soc c=norflash state=0
        p=soc c=power_sply state=0
        p=soc c=pwr_ctrl state=0
        p=soc c=card_boot state=0
        p=soc c=pm_para state=0
        p=soc c=card0_boot_para state=0
        p=soc c=card2_boot_para state=0
        p=soc c=card1_boot_para state=0
        p=soc c=twi_para state=0
        p=soc c=uart_para state=0
        p=soc c=jtag_para state=0
        p=soc c=dram state=0
        p=soc c=twi0 state=0
        p=soc c=twi1 state=0
        p=soc c=twi2 state=0
        p=soc c=uart0 state=0
        p=soc c=uart1 state=0
        p=soc c=uart2 state=0
        p=soc c=spi0 state=0
        p=soc c=spi1 state=0
        p=soc c=rtp_para state=0
        p=soc c=ctp state=0
        p=twi0 c=goodix_ts state=0
        p=soc c=tkey_para state=0
        p=soc c=motor_para state=0
        p=soc c=nand0 state=0
        p=soc c=disp state=0
        p=soc c=lcd0 state=0
        p=soc c=pwm0_para state=0
        p=soc c=pwm1_para state=0
        p=soc c=vip0 state=0
        p=soc c=tvout_para state=0
        p=soc c=tvin_para state=0
        p=soc c=di state=0
        p=soc c=sdc0 state=0
        p=soc c=sdc1 state=0
        p=soc c=smc state=0
        p=soc c=usbc0 state=0
        p=soc c=gsensor_para state=0
        p=soc c=gps_para state=0
        p=soc c=wlan state=0
        p=soc c=gy_para state=0
        p=soc c=ls_para state=0
        p=soc c=compass_para state=0
        p=soc c=bt_para state=0
        p=soc c=audiospdif state=0
        p=soc c=spdif_machine state=0
        p=soc c=audiohdmi state=0
        p=soc c=hdmi_machine state=0
        p=soc c=pmu0 state=0
        p=soc c=pmu0_regu state=0
        p=soc c=dvfs_table state=0
        p=soc c=Vdevice state=0
        p=soc c=fel_key state=0
        p=soc c=partitions state=0
        Conver script to dts ok.
        pack boot package
        content_count=3
        toc1 file Path=/home/iot/jkangli/f1c100s/tina/out/c200s-F1C200s/image/boot_package.fex
        script file Path=/home/iot/jkangli/f1c100s/tina/out/c200s-F1C200s/image/sys_config.bin
        cant get board_id_enable
        script update toc1 ok
        packing for tina linux
        normal
        ERROR: update_mbr failed
