    R329编译XR819S WiFi模组驱动错误
    • R
      ROIDMI LV 4 最后由 编辑
      CC      drivers/net/wireless/xr819s/umac/main.o
      In file included from ./drivers/net/wireless/xr819s/include/net/mac80211.h:22:0,
                       from drivers/net/wireless/xr819s/umac/main.c:11:
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:616:24: error: field 'mode' has incomplete type
        enum nl80211_key_mode mode;
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:654:26: error: field 'noack' has incomplete type
        enum nl80211_tid_config noack;
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:3122:36: error: field 'action' has incomplete type
        enum nl80211_external_auth_action action;
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:3213:52: error: field 'failure_reason' has incomplete type
        enum nl80211_peer_measurement_ftm_failure_reasons failure_reason;
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:3260:39: error: field 'status' has incomplete type
        enum nl80211_peer_measurement_status status;
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:3267:37: error: field 'type' has incomplete type
        enum nl80211_peer_measurement_type type;
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:3290:24: error: field 'preamble' has incomplete type
        enum nl80211_preamble preamble;
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h: In function 'cfg80211_channel_is_psc':
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:5246:20: error: 'NL80211_BAND_6GHZ' undeclared (first use in this function)
        if (chan->band != NL80211_BAND_6GHZ)
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:5246:20: note: each undeclared identifier is reported only once for each function it appears in
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h: In function 'cfg80211_gen_new_bssid':
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:5915:18: error: implicit declaration of function 'ether_addr_to_u64' [-Werror=implicit-function-declaration]
        u64 bssid_u64 = ether_addr_to_u64(bssid);
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:5923:2: error: implicit declaration of function 'u64_to_ether_addr' [-Werror=implicit-function-declaration]
        u64_to_ether_addr(new_bssid_u64, new_bssid);
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h: At top level:
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:6640:30: error: field 'timeout_reason' has incomplete type
        enum nl80211_timeout_reason timeout_reason;
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:6704:36: error: parameter 10 ('timeout_reason') has incomplete type
              enum nl80211_timeout_reason timeout_reason)
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:6700:1: error: function declaration isn't a prototype [-Werror=strict-prototypes]
       cfg80211_connect_bss(struct net_device *dev, const u8 *bssid,
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h: In function 'cfg80211_connect_result':
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:6749:9: error: 'NL80211_TIMEOUT_UNSPECIFIED' undeclared (first use in this function)
               NL80211_TIMEOUT_UNSPECIFIED);
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:6773:33: error: parameter 6 ('timeout_reason') has incomplete type
      ./drivers/net/wireless/xr819s/include/net/cfg80211.h:6771:1: error: function declaration isn't a prototype [-Werror=strict-prototypes]
       cfg80211_connect_timeout(struct net_device *dev, const u8 *bssid,
      In file included from drivers/net/wireless/xr819s/umac/ieee80211_i.h:34:0,
                       from drivers/net/wireless/xr819s/umac/main.c:34:
      drivers/net/wireless/xr819s/umac/key.h:17:25: fatal error: crypto/arc4.h: No such file or directory
       #include <crypto/arc4.h>
      cc1: some warnings being treated as errors
      compilation terminated.
      make[9]: *** [scripts/Makefile.build:335: drivers/net/wireless/xr819s/umac/main.o] Error 1
      make[8]: *** [scripts/Makefile.build:648: drivers/net/wireless/xr819s] Error 2
      make[7]: *** [scripts/Makefile.build:648: drivers/net/wireless] Error 2
      make[6]: *** [scripts/Makefile.build:648: drivers/net] Error 2
      make[5]: *** [Makefile:1092: drivers] Error 2
      make[5]: Leaving directory '/home/ubuntu/R329-Tina/lichee/linux-4.9'
      make[4]: *** [Makefile:32: /home/ubuntu/R329-Tina/out/r329-evb5_pro_v1/compile_dir/target/linux-r329-evb5_pro_v1/linux-4.9.191/.image] Error 2
      make[4]: Leaving directory '/home/ubuntu/R329-Tina/target/allwinner/r329-evb5_pro_v1'
      make[3]: *** [Makefile:13: install] Error 2
      make[3]: Leaving directory '/home/ubuntu/R329-Tina/target/allwinner'
      make[2]: *** [target/Makefile:22: target/allwinner/install] Error 2
      make[2]: Leaving directory '/home/ubuntu/R329-Tina'
      make[1]: *** [target/Makefile:17: /home/ubuntu/R329-Tina/out/r329-evb5_pro_v1/staging_dir/target/stamp/.target_install] Error 2
      make[1]: Leaving directory '/home/ubuntu/R329-Tina'
      make: *** [/home/ubuntu/R329-Tina/build/toplevel.mk:306:world] 错误 2
      #### make failed to build some targets (40 seconds) ####
